Function pointer within isr
Wendell Silva
silvawp at gmail.com
Mon Jun 30 16:52:24 UTC 2014
André,
Technically, you should be able to call functions (directly or indirectly)
in any point of your program. AFAIK, there are only a subset of RTEMS
directives you shouldn't call from an ISR.
What kind of error have you got? BSP?
--Wendell.
2014-06-30 13:47 GMT-03:00 Andre Marques <andre.lousa.marques at gmail.com>:
> Hello,
> I am trying to call a function through a function pointer from an
> interrupt handler, but I am not sure if this is even possible as the system
> hangs at that point. If not, is there any way in RTEMS to have that
> function executed outside the isr?
> Thanks,
> André Marques.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140630/4a29c311/attachment.html>
