[rtems commit] libblock: Add RTEMS_BDBUF_USE_PTHREAD
Sebastian Huber
Tue Jun 3 06:03:26 UTC 2014
On 2014-06-03 01:58, Chris Johns wrote:
> On 3/06/2014 3:37 am, Gedare Bloom wrote:
>> On Mon, Jun 2, 2014 at 10:48 AM, Sebastian Huber <sebh at rtems.org> wrote:
>>> Module: rtems
>>> Branch: master
>>> Commit: 1fc2e960cea37e8d78e142c71faec18262f356d2
>>> Changeset:
>>> http://git.rtems.org/rtems/commit/?id=1fc2e960cea37e8d78e142c71faec18262f356d2
>>> Author: Ralf Kirchner <ralf.kirchner at embedded-brains.de>
>>> Date: Mon Jun 2 14:46:18 2014 +0200
>>> Use the PTHREAD mutexes and condition variables if available. This
>>> helps on SMP configurations to avoid the home grown condition variables
>>> via disabled preemption.
>> If the bdbufs work better with this pthread implementation, should we
>> just get rid of the old code in favor of the new code using
>> pthread_mutex and condvar? This would mean requiring users who want
>> bdbufs to also configure for POSIX, which I'm not sure whether that is
>> a problem or not...
> I also agree. It seems normal to me to have POSIX enabled to use a POSIX
> compliant file system.
The RTEMS_POSIX_API define is mostly POSIX signals and PTHREAD. It has
virtually nothing to do with the file system.
> I think we need to understand the benefit and trade off the --enable-posix
> option gives us these days. The fewer options like this we have the better our
> testing results are. There is a limited number of options we can support before
> the ability to test becomes impossible. We have too many to test now.
This patch changes nothing with respect to testability. It is just one more
area with an RTEMS_POSIX_API usage.
The general question is if we need --enable-posix at all. Here we had only
very small improvements in the last years. The RTEMS_POSIX_API still pulls in
a lot of stuff via exinit.c. I think we need a modular initialization like on
FreeBSD or Linux to tackle this problem, see also
https://www.rtems.org/bugzilla/show_bug.cgi?id=1593
The new network stack uses this approach also and is very flexible. The only
thing necessary is this in our linker command files:
.rtemsrwset : ALIGN_WITH_INPUT {
KEEP (*(SORT(.rtemsrwset.*)))
} > REGION_DATA AT > REGION_DATA_LOAD
.rtemsroset : ALIGN_WITH_INPUT {
KEEP (*(SORT(.rtemsroset.*)))
} > REGION_RODATA AT > REGION_RODATA_LOAD
With this we add new requirements for the linker:
1. We need sections.
2. We need the ability to sort the sections lexicographically by name.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
