[PATCH 4/4] score: Use Resource Handler for MrsP semaphores
Tue Jun 3 14:23:56 UTC 2014
On 2014-06-03 16:14, Gedare Bloom wrote:
> On Tue, Jun 3, 2014 at 6:55 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> >I think the bigger problem is that the priority inheritance affects only one
>> >level, see new test sptests/spsem03.
> Is there a bug PR associated with this test? The behavior under test
> looks like a bug to me.
I don't know how old the priority inheritance implementation is in RTEMS, but I
guess it is very old.  So this is probably not a bug, its a feature.
With the simple resource count base implementation I think it is impossible to
recursively walk though the resource dependency tree.  You would have to use
object specific information (for example CORE_mutex_Control::holder) which is
difficult to access from object agnostic routines.
I want to address these issues with the Resource Handler for the MrsP
semaphores.  See diagram here:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ScoreResource.html
Lets suppose all the resources r0 up to r15 are MrsP semaphores, then the owner
n0 of the resource tree can execute using (= scheduler instance + priority) all
the n1 up to n15 nodes (= threads waiting for resource access).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
