[PATCH 4/5] SPARC: Fatal_halt use source and exit codes
Sebastian Huber
Wed Jun 4 09:50:00 UTC 2014
On 2014-06-04 11:23, Daniel Hellstrom wrote:
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index ce5ea60..b625bb9 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -1075,19 +1075,15 @@ void _CPU_Context_Initialize(
> /* Fatal Error manager macros */
> +extern void BSP_Fatal_halt(uint32_t source, uint32_t error)
> + RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
> * This routine copies _error into a known place -- typically a stack
> * location or a register, optionally disables interrupts, and
> * halts/stops the CPU.
> -#define _CPU_Fatal_halt( _source, _error ) \
> - do { \
> - uint32_t level; \
> - level = sparc_disable_interrupts(); \
> - __asm__ volatile ( "mov %0, %%g1 " : "=r" (level) : "0" (level) ); \
> - while (1); /* loop forever */ \
> - } while (0)
> +#define _CPU_Fatal_halt( _source, _error ) BSP_Fatal_halt( _source, _error )
I would name it _BSP_Fatal_halt(), similar to _BSP_Exception_frame_print().
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
