BSP submitting requirements
Thu Jun 5 11:37:07 UTC 2014
On 2014-06-04 23:05, Joel Sherrill wrote:
> FWIW I wrote the confdefs.h part and Marcos wrote the documentation.
> He spotted a typo and missed that also.
I am not sure if the BSP should be responsible for a default task stack size.
The BSP has nothing to do with the code generation and the general architecture
specifics that determine the typical stack usage.
Which problem does this new define address?  Is this the test suite?  In case
the tests pass with a stack size of 1024 on this BSP, then they will pass on
all ARM BSPs using the same instruction set.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
