BSP submitting requirements
Marcos Díaz marcos.diaz at tallertechnologies.com
Thu Jun 5 14:24:52 UTC 2014
>From tmtests folder the following tests used more than 3 tasks: tm02,
tm03, tm04, tm05, tm06, tm07, tm10, tm11, tm12, tm13, tm14, tm15, tm
16, tm17, tm18, tm19, tm21, tm22, tm23, tm24, tm 25, tm26, tm29.
 Although we reduced the count of tasks for those tests (with the
OPERATION_COUNT macro) with stacks of 4kb there isn't room for more
than 2 or 3 tasks. With this change we  could run 17 of 33 tests of
tmtests. (see times_tests file).
On Thu, Jun 5, 2014 at 10:57 AM, Marcos Díaz
<marcos.diaz at tallertechnologies.com> wrote:
> Not all the tests run but we achieved many more tests working with this change.
> On Thu, Jun 5, 2014 at 10:54 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 2014-06-05 15:04, Marcos Díaz wrote:
>>> Yes, we made this patch in order to the testsuites work correctly. So
>>> you think we should change the macro value in cpu.h and arm.h as i
>>> proposed before?
>> So you can run the complete test suite with a default stack size of 1024?
>> I wouldn't change the default for ARM, since this can break existing
>> applications that rely on the 4k.
>> I think this new BSP specific setting makes it harder for users to know what
>> is going on.  Since I don't have a better alternative, your patch is fine.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> ______________________________
> Marcos Díaz
> Software Engineer
> San Lorenzo 47, 3rd Floor, Office 5
> Córdoba, Argentina
> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
> Skype: markdiaz22
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22,
