[PATCH 2/5] SPARC: add BSP specific error handler
Daniel Hellstrom daniel at gaisler.com
Mon Jun 9 09:06:08 UTC 2014
On 06/05/2014 04:54 PM, Sebastian Huber wrote:
> On 2014-06-04 20:48, Daniel Hellstrom wrote:
>> On 06/04/2014 11:51 AM, Sebastian Huber wrote:
>>> On 2014-06-04 11:23, Daniel Hellstrom wrote:
>>>> Instead of calling the system call TA instruction directly it
>>>> is better paractise to isolate the trap implementation to the
>>>> system call functions.
>>>> The BSP_fatal_return() should always exist, regardless of SPARC
>>>> CPU.
>>> Why do we need BSP_fatal_return() and bsp_reset()?
>> The LEON3 doesn't, it does not define bsp_reset. I tried to preserve the
>> behaviour of LEON2 and ERC32 BSPs, the bsp_reset is called from the fatal
>> handler. On all SPARC BSPs, ending up in BSP_fatal_return is a result of
>> bootcard or bsp_start_on_secondary_processor returning which they should never
>> do. The two functions also have different error exit codes.
> Ok, so this BSP_fatal_return() is used to mark unreachable code. Maybe we should just remove these two special cases since its impossible to test this code or we could also add a general
> _Unreachable_code() function.
I'm fine with removing them. I'm not sure why it was originally this way, there was probably some reason for it in the first place.
I'll add a patch for that.
Thanks,
Daniel
