Check submission script
    Sebastian Huber
    Tue Jun 10 12:45:46 UTC 2014
On 2014-06-10 14:32, Gedare Bloom wrote:
> On Tue, Jun 10, 2014 at 2:51 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de>  wrote:
>> >Hello,
>> >the check submission script
>> >http://git.rtems.org/rtems-testing/tree/merge-helpers/check_submission
>> >contains a test for timing values
>> >   # Hopefully have some output from the tmtests
>> >   echo "=== Checking for timing information"
>> >   c=$(ls -1 times* 2>/dev/null | wc -l)
>> >   if [[ ${c} -eq 0 ]]; then
>> >     echo "Please run the timing tests and include the results."
>> >   fi
>> >Is it really useful to add such timing values to the sources?  They may be
>> >out of date right with the next commit.
> I agree. The only place timing results make sense is for a release.
> Using the tmtests can also be important when making changes in
> supercore, but that is less often done and should be better handled by
> the developer/tester.
A long term goal should be to monitor the timing test results in automatic test
runs to catch timing regressions, but there are many steps necessary to get to
this point.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
