[PATCH 4/6] score: Decouple thread and scheduler nodes on SMP
Fri Jun 13 16:36:14 UTC 2014
On 06/13/2014 05:50 PM, Gedare Bloom wrote:
> On Fri, Jun 13, 2014 at 10:37 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Add a chain node to the scheduler node to decouple the thread and
>> scheduler nodes.  It is now possible to enqueue a thread in a thread
>> wait queue and use its scheduler node at the same for other threads,
>> e.g. a resouce owner.
>>   cpukit/score/include/rtems/score/scheduler.h       |   19 ++-
>>   cpukit/score/include/rtems/score/schedulerimpl.h   |   22 ++
>>   .../include/rtems/score/schedulerprioritysmpimpl.h |   48 ++--
>>   .../score/include/rtems/score/schedulersimplesmp.h |    8 +-
>>   cpukit/score/include/rtems/score/schedulersmp.h    |    5 +
>>   .../score/include/rtems/score/schedulersmpimpl.h   |  251 +++++++++++---------
>>   cpukit/score/src/schedulerpriorityaffinitysmp.c    |  175 +++++++-------
>>   cpukit/score/src/schedulerprioritysmp.c            |   43 ++--
>>   cpukit/score/src/schedulersimplesmp.c              |   98 +++++----
>>   cpukit/score/src/schedulersmpstartidle.c           |    2 +-
>>   10 files changed, 392 insertions(+), 279 deletions(-)
>> diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
>> index 542e4ae..918c6df 100644
>> --- a/cpukit/score/include/rtems/score/scheduler.h
>> +++ b/cpukit/score/include/rtems/score/scheduler.h
>> @@ -165,7 +165,24 @@ struct Scheduler_Control {
>>    * @brief Scheduler node for per-thread data.
>>   struct Scheduler_Node {
>> -  /* No fields yet */
>> +#if defined(RTEMS_SMP)
>> +   * @brief Chain node for usage in various scheduler data structures.
>> +   * Strictly this is the wrong place for this field since the data structures
>> +   * to manage scheduler nodes belong to the particular scheduler
>> +   * implementation.  Currently all SMP scheduler implementations use chains.
>> +   * The node is here to simplify things, just like the object node in the
>> +   * thread control block.  It may be replaced with a union to add a red-black
>> +   * tree node in the future.
>> +  Chain_Node Node;
>> +   * @brief The thread owning this node.
>> +  Thread_Control *owner;
>> +#endif
>> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
>> index 364c658..391a8d7 100644
>> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
>> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
>> @@ -652,6 +652,28 @@ RTEMS_INLINE_ROUTINE Scheduler_Node *_Scheduler_Node_get(
>>     return the_thread->Scheduler.node;
>> +RTEMS_INLINE_ROUTINE void _Scheduler_Node_do_initialize(
> I'd just use "Node_initialize".
This is already used for the corresponding scheduler operation. This
"do" is already present in similar cases.
>> diff --git a/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
>> index d3e2106..8671035 100644
>> --- a/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
>> +++ b/cpukit/score/include/rtems/score/schedulerprioritysmpimpl.h
>> @@ -26,6 +26,7 @@
>>   #include <rtems/score/schedulerprioritysmp.h>
>>   #include <rtems/score/schedulerpriorityimpl.h>
>>   #include <rtems/score/schedulersimpleimpl.h>
>> +#include <rtems/score/schedulersmpimpl.h>
>>   #ifdef __cplusplus
>>   extern "C" {
>> @@ -50,26 +51,25 @@ static inline Scheduler_priority_SMP_Node *_Scheduler_priority_SMP_Node_get(
>>     return (Scheduler_priority_SMP_Node *) _Scheduler_Node_get( thread );
>> -static Scheduler_priority_SMP_Node *_Scheduler_priority_SMP_Node_downcast(
>> -  Scheduler_Node *node
>> +static inline Scheduler_priority_SMP_Node *
>> +_Scheduler_priority_SMP_Node_downcast( Scheduler_Node *node )
>>     return (Scheduler_priority_SMP_Node *) node;
> Is there a reason not to just cast it where it is used?
I think this makes it easier to grep for the uses cases.
>>   static inline void _Scheduler_priority_SMP_Insert_ready_lifo(
>>     Scheduler_Context *context,
>> -  Thread_Control *thread
>> +  Scheduler_Node    *thread
> It's no longer a thread, I'd change the parameter name. Repeated a few times.
Oh, yes.
>> diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
>> index f5ab8cf..f1dcacd 100644
>> --- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
>> +++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
>> @@ -134,28 +137,34 @@ static inline void _Scheduler_SMP_Allocate_processor_exact(
>>    * the highest ready thread must have affinity such that it can
>>    * be executed on the victim's processor.
>> -static Thread_Control *_Scheduler_priority_affinity_SMP_Get_highest_ready(
>> +static Scheduler_Node *_Scheduler_priority_affinity_SMP_Get_highest_ready(
>> -  Thread_Control    *victim
>> +  Scheduler_Node    *victim
>> -  Scheduler_priority_SMP_Context *self =
>> +  Scheduler_priority_SMP_Context       *self =
>>       _Scheduler_priority_SMP_Get_self( context );
>> -  Priority_Control                index;
>> -  Thread_Control                 *highest = NULL;
>> -  int                             victim_cpu;
>> +  Priority_Control                      index;
>> +  Scheduler_Node                       *highest = NULL;
>> +  Thread_Control                       *victim_thread;
>> +  uint32_t                              victim_cpu_index;
>> +  Scheduler_priority_affinity_SMP_Node *node;
>>      * This is done when we need to check if reevaluations are needed.
>>     if ( victim == NULL ) {
>> -    return _Scheduler_priority_Ready_queue_first(
>> +    node = (Scheduler_priority_affinity_SMP_Node *)
>> +      _Scheduler_priority_Ready_queue_first(
>>           &self->Bit_map,
>>           &self->Ready[ 0 ]
>> +    return &node->Base.Base.Base;
> This Base.Base.Base is quite awkward and not at all clear what it
> means. Shouldn't this be using a downcast() function? Repeated a few
> times.
> -Gedare
No, this Base.Base.Base basically is an upcast.  In C++ this stuff would
be hidden the compiler for you, but we use C, so object oriented stuff
is awkward.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
