TCP/IP update, possible SMP (GSOC 2014)
Mon Mar 3 07:37:23 UTC 2014
On 2014-03-03 08:30, Daniel Ramirez wrote:
> On Mar 3, 2014 1:13 AM, "Sebastian Huber" <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>  > On 2014-02-28 17:09, Daniel Ramirez wrote:
>  >>         Work that needs to be done within the scheduler API that would
> enable SMP.
>  >>     The work on the clustered/partitioned scheduling is on my high priority
>  >>     list, so I hope that the scheduler API will be stable before the GSoC
>  >>     starts.  I will provide only a fixed priority scheduler.
>  >> So are you suggesting that work on (or within) the clustered/partitioned
>  >> scheduler could possibly be an acceptable gsoc project? Or that projects
>  >> requiring a stable scheduler API would be acceptable?
>  > The plan is that I am finished with the clustered/partition scheduling in
> May, this is when the GSoC coding starts.
> You were planning to implement thread restart/delete as well, correct?
Yes.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
