[PATCH 1/3] score: Add _Atomic_Fence()
Mon Mar 3 15:29:16 UTC 2014
 cpukit/score/include/rtems/score/atomic.h       |    7 +++
 cpukit/score/include/rtems/score/cpustdatomic.h |    7 +++
 testsuites/smptests/smpatomic01/init.c          |   63 ++++++++++++++++++++---
 testsuites/smptests/smpatomic01/smpatomic01.scn |   26 +++++----
 4 files changed, 84 insertions(+), 19 deletions(-)
diff --git a/cpukit/score/include/rtems/score/atomic.h b/cpukit/score/include/rtems/score/atomic.h
index 757eaf7..81149ab 100644
--- a/cpukit/score/include/rtems/score/atomic.h
+++ b/cpukit/score/include/rtems/score/atomic.h
@@ -43,6 +43,13 @@ extern "C" {
 #define ATOMIC_INITIALIZER_FLAG CPU_ATOMIC_INITIALIZER_FLAG
+static inline void _Atomic_Fence(
+  Atomic_Order order
+  _CPU_atomic_Fence( order );
  * @brief Initializes an atomic type value into a atomic object.
diff --git a/cpukit/score/include/rtems/score/cpustdatomic.h b/cpukit/score/include/rtems/score/cpustdatomic.h
index e364eb9..4023d0c 100644
--- a/cpukit/score/include/rtems/score/cpustdatomic.h
+++ b/cpukit/score/include/rtems/score/cpustdatomic.h
@@ -83,6 +83,13 @@ typedef enum {
 #define CPU_ATOMIC_INITIALIZER_FLAG ATOMIC_FLAG_INIT
+static inline void _CPU_atomic_Fence(
+  atomic_thread_fence( (memory_order) order );
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index 792a17b..8e05307 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -21,6 +21,7 @@
 #include <rtems/score/atomic.h>
 #include <rtems/score/smpbarrier.h>
+#include <limits.h>
 #include "tmacros.h"
@@ -40,6 +41,8 @@ typedef struct {
   Atomic_Ulong atomic_value;
   unsigned long per_worker_value[CPU_COUNT];
   unsigned long normal_value;
+  char unused_space_for_cache_line_separation[128];
+  unsigned long second_value;
   Atomic_Flag global_flag;
 } test_context;
@@ -74,7 +77,7 @@ static void test_fini(
   unsigned long actual_value;
   size_t worker_index;
-  printf("=== atomic %s test case ==\n", test);
+  printf("=== atomic %s test case ===\n", test);
   for (worker_index = 0; worker_index < ctx->worker_count; ++worker_index) {
     unsigned long worker_value = ctx->per_worker_value[worker_index];
@@ -255,6 +258,48 @@ static void test_atomic_or_and_fini(test_context *ctx)
   test_fini(ctx, "or/and", true);
+static void test_atomic_fence_init(test_context *ctx)
+  ctx->normal_value = 0;
+  ctx->second_value = 0;
+  _Atomic_Fence(ATOMIC_ORDER_RELEASE);
+static void test_atomic_fence_body(test_context *ctx, size_t worker_index)
+  if (is_master_worker(worker_index)) {
+    unsigned long counter = 0;
+    while (!stop(ctx)) {
+      ++counter;
+      ctx->normal_value = counter;
+      ctx->second_value = counter;
+  } else {
+      unsigned long n;
+      unsigned long s;
+      s = ctx->second_value;
+      _Atomic_Fence(ATOMIC_ORDER_ACQUIRE);
+      n = ctx->normal_value;
+      rtems_test_assert(n - s < LONG_MAX);
+static void test_atomic_fence_fini(test_context *ctx)
+  printf(
+    "=== atomic fence test case ===\n"
+    "normal value = %lu, second value = %lu\n",
+    ctx->normal_value,
+    ctx->second_value
 static const test_case test_cases[] = {
     test_atomic_add_init,
@@ -276,6 +321,10 @@ static const test_case test_cases[] = {
     test_atomic_or_and_init,
     test_atomic_or_and_body,
+    test_atomic_fence_init,
+    test_atomic_fence_body,
+    test_atomic_fence_fini
@@ -432,7 +481,7 @@ static void test_simple_atomic_add_body(test_context *ctx)
   unsigned long a = 2, b = 1;
   unsigned long c;
-  puts("=== atomic simple add test case ==\n");
+  puts("=== atomic simple add test case ===\n");
   _Atomic_Store_uint(&ctx->atomic_int_value, ia, ATOMIC_ORDER_RELAXED);
   _Atomic_Fetch_add_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
@@ -452,7 +501,7 @@ static void test_simple_atomic_sub_body(test_context *ctx)
   unsigned long c;
-  puts("=== atomic simple sub test case ==\n");
+  puts("=== atomic simple sub test case ===\n");
   _Atomic_Fetch_sub_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
@@ -472,7 +521,7 @@ static void test_simple_atomic_or_body(test_context *ctx)
   unsigned long c;
-  puts("=== atomic simple or test case ==\n");
+  puts("=== atomic simple or test case ===\n");
   _Atomic_Fetch_or_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
@@ -492,7 +541,7 @@ static void test_simple_atomic_and_body(test_context *ctx)
   unsigned long c;
-  puts("=== atomic simple and test case ==\n");
+  puts("=== atomic simple and test case ===\n");
   _Atomic_Fetch_and_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
@@ -512,7 +561,7 @@ static void test_simple_atomic_exchange_body(test_context *ctx)
   unsigned long c;
-  puts("=== atomic simple exchange test case ==\n");
+  puts("=== atomic simple exchange test case ===\n");
   _Atomic_Exchange_uint(&ctx->atomic_int_value, ib, ATOMIC_ORDER_RELAXED);
@@ -532,7 +581,7 @@ static void test_simple_atomic_compare_exchange_body(test_context *ctx)
   unsigned long c;
-  puts("=== atomic simple compare exchange test case ==\n");
+  puts("=== atomic simple compare exchange test case ===\n");
   _Atomic_Compare_exchange_uint(&ctx->atomic_int_value, &ia, ib,
diff --git a/testsuites/smptests/smpatomic01/smpatomic01.scn b/testsuites/smptests/smpatomic01/smpatomic01.scn
index 1122fae..4a8c230 100644
--- a/testsuites/smptests/smpatomic01/smpatomic01.scn
+++ b/testsuites/smptests/smpatomic01/smpatomic01.scn
@@ -1,29 +1,31 @@
 *** TEST SMPATOMIC 1 ***
-=== atomic simple add test case ==
-=== atomic simple sub test case ==
-=== atomic simple or test case ==
-=== atomic simple and test case ==
-=== atomic simple exchange test case ==
-=== atomic simple compare exchange test case ==
-=== static and dynamic initialization test case ===
-=== atomic add test case ==
+=== atomic simple add test case ===
+=== atomic simple sub test case ===
+=== atomic simple or test case ===
+=== atomic simple and test case ===
+=== atomic simple exchange test case ===
+=== atomic simple compare exchange test case ===
+=== static and dynamic initialization test case ====
+=== atomic add test case ===
 worker 0 value: 16686
 worker 1 value: 36405
 atomic value: expected = 53091, actual = 53091
-=== atomic flag test case ==
+=== atomic flag test case ===
 worker 0 value: 5588
 worker 1 value: 16019
 atomic value: expected = 21607, actual = 21607
-=== atomic sub test case ==
+=== atomic sub test case ===
 worker 0 value: 4294950967
 worker 1 value: 4294930886
 atomic value: expected = 4294914557, actual = 4294914557
-=== atomic compare exchange test case ==
+=== atomic compare exchange test case ===
 worker 0 value: 2950
 worker 1 value: 22456
 atomic value: expected = 25406, actual = 25406
-=== atomic or/and test case ==
+=== atomic or/and test case ===
 worker 0 value: 1
 worker 1 value: 0
 atomic value: expected = 1, actual = 1
+=== atomic fence test case ===
+normal value = 10759507, second value = 10759507
 *** END OF TEST SMPATOMIC 1 ***
1.7.7
