Posix patchs to support affinity attribute in newlib
Jennifer Averett Jennifer.Averett at OARcorp.com
Mon Mar 3 15:36:27 UTC 2014
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Monday, March 03, 2014 8:10 AM
> To: Jennifer Averett
> Cc: rtems-devel at rtems.org
> Subject: Re: Posix patchs to support affinity attribute in newlib
> >> >From:rtems-devel-bounces at rtems.org  [mailto:rtems-devel-
> >> >bounces at rtems.org] On Behalf Of Sebastian Huber
> >> >Sent: Friday, February 28, 2014 1:12 AM To:rtems-devel at rtems.org
> >> >On 2014-02-27 14:24, Jennifer Averett wrote:
> >>> > >+ * @brief Copy POSIX Thread attribute structure
> >>> > >+ * This routine copies the attr2 thread attribute structure
> >>> > >+ * to the attr1 Thread Attribute structure.
> >>> > >+ * @param[out] attr1 is a pointer to the thread attribute
> >>> > >+ * structure to copy into.
> >>> > >+ * @param[out] attr2 is a pointer to the thread attribute
> >> >Should be @param[in].
> >> >Why not name this src_attr and dst_attr or something similar?
> > Will change.
> If you look at something like this
>   * @param[in] attr2 is a pointer to the thread attribute
>   * structure to copy from.
> RTEMS_INLINE_ROUTINE void _POSIX_Threads_Copy_attributes(
>    pthread_attr_t  *attr1,
>    const pthread_attr_t  *attr2
>    *attr1 = *attr2;
> #if HAVE_SYS_CPUSET_H
>    attr1->affinityset = &attr1->affinitysetpreallocated; #endif }
> will you read the comment at all?
> Apart from that the @brief doesn't follow the Doxygen recommendations:
> http://www.rtems.org/wiki/index.php/Doxygen_Recommendations#Declari
> ng_functions
> Is the implementation correct for CPU sets which are not pre-allocated?
Until we have a system that supports over 32 CPU's the implementation can
not be tested for this.  I minimized the locations that will have to be touched
when we support this but I didn't think it was correct to add code that can not
be tested.
