Posix patchs to support affinity attribute in newlib
Mon Mar 3 16:46:09 UTC 2014
On Mon, Mar 3, 2014 at 10:56 AM, Sebastian Huber
> On 2014-03-03 16:36, Jennifer Averett wrote:
>>> >Is the implementation correct for CPU sets which are not pre-allocated?
>> Until we have a system that supports over 32 CPU's the implementation can
>> not be tested for this.  I minimized the locations that will have to be
>> touched
>> when we support this but I didn't think it was correct to add code that
>> can not
>> be tested.
> You can test the inline functions separately.  You can add an _Assert() if
> someone hits a not implemented path.  If you copy an attribute with somehow
> allocated CPU sets, then you need to allocate somehow memory for the copy.
> This allocation may fail, so you cannot use a void function?
This is a good point. Most copy functions return the destination pointer.
> rtems-devel mailing list
> rtems-devel at rtems.org
