Patch - Enable POSIX Keys in All Configurations
Wed Mar 5 23:09:41 UTC 2014
On 3/5/2014 2:51 PM, Gedare Bloom wrote:
> Joel,
> I suspect you need more changes in confdefs.h to put the keys in the
> configuration and debug configurations structures, and to accurately
> estimate the workspace memory usage, in case POSIX_KEYS are used
> without having posix enabled.
Ahh... yep... forgot both those. Not surprising since this turned out to be
a lot of simple changes spread out.
> Nothing else seemed obviously wrong at a quick read through.
> Considering you updated the .scn files, I take it you have run the
> psxkey tests with this change.
Yep. Both with POSIX enabled and disabled.
I will fix that in condefs.h and shoot it again.
> Gedare
> On Wed, Mar 5, 2014 at 2:36 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> As discussed in various threads and private conversations, task variables
>> are broken by design on SMP systems. POSIX keys are a standard way
>> to have SMP safe per task data. But currently they are only available
>> when --enable-posix is specified.
>> This rather tedious patch enables them all the time. It touches the
>> configuration, code, and reworks the tests to use Classic tasks.
>> The next step is to eliminate the use of task variables in the
>> cpukit code. That code is unsafe for SMP systems.
>> OK to apply?
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
