[PATCH] bsp/leon3: Use interrupt timestamping counter
Sebastian Huber
Fri Mar 7 06:55:57 UTC 2014
Use the interrupt controller timestamping counter for the CPU counter if
available since it runs with a high frequency.
c/src/lib/libbsp/sparc/leon3/include/leon.h | 7 ++
c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c | 90 +++++++++++++++------
2 files changed, 71 insertions(+), 26 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index 476ed5c..2887091 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -399,6 +399,13 @@ static inline uint32_t leon3_get_data_cache_config_register(void)
return leon3_get_system_register(0xc);
+static bool leon3_irqmp_has_timestamp(
+ volatile struct irqmp_timestamp_regs *irqmp_ts
+ return (irqmp_ts->control >> 27) > 0;
#endif /* !ASM */
#ifdef __cplusplus
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c b/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c
index 44faf92..b975e1c 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c
@@ -21,6 +21,14 @@ static volatile struct gptimer_regs *adev_to_gpt(struct ambapp_dev *adev)
return (volatile struct gptimer_regs *) DEV_TO_APB(adev)->start;
+static CPU_Counter_ticks timestamp_counter_difference(
+ CPU_Counter_ticks second,
+ CPU_Counter_ticks first
+ return second - first;
static CPU_Counter_ticks free_counter_difference(
@@ -54,39 +62,69 @@ static void gpt_counter_initialize(
rtems_counter_initialize_converter(frequency);
+static unsigned int get_tstamp(volatile struct irqmp_timestamp_regs *irqmp_ts)
+ return irqmp_ts->control >> 27;
void leon3_cpu_counter_initialize(void)
+ volatile struct irqmp_timestamp_regs *irqmp_ts =
+ &LEON3_IrqCtrl_Regs->timestamp[0];
struct ambapp_dev *adev;
int idx = 1;
- adev = (void *) ambapp_for_each(
- &ambapp_plb,
- OPTIONS_ALL | OPTIONS_APB_SLVS,
- VENDOR_GAISLER,
- GAISLER_GPTIMER,
- ambapp_find_by_idx,
- &idx
- if (adev != NULL) {
- /* Use the second GPTIMER if available */
- volatile struct gptimer_regs *gpt = adev_to_gpt(adev);
- uint32_t max_frequency = ambapp_freq_get(&ambapp_plb, adev);
- unsigned min_prescaler = 8;
- uint32_t frequency = max_frequency / min_prescaler;
+ if (leon3_irqmp_has_timestamp(irqmp_ts)) {
+ /* Use the interrupt controller timestamp counter if available */
- gpt->scaler_reload = min_prescaler - 1;
- gpt->timer[0].reload = 0xffffffff;
- gpt->timer[0].ctrl = LEON3_GPTIMER_EN | LEON3_GPTIMER_RL
- | LEON3_GPTIMER_LD;
+ /* Enable interrupt timestamping for an arbitrary interrupt line */
+ irqmp_ts->control = 0x1;
+ _SPARC_Counter_initialize(
+ (volatile const uint32_t *) &irqmp_ts->counter,
+ timestamp_counter_difference
- gpt_counter_initialize(gpt, 0, frequency, free_counter_difference);
- } else if (LEON3_Timer_Regs != NULL) {
- /* Fall back to the first GPTIMER if available */
- LEON3_Timer_Regs,
- LEON3_CLOCK_INDEX,
- LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER,
- clock_counter_difference
+ /* Get and set the frequency */
+ adev = (void *) ambapp_for_each(
+ &ambapp_plb,
+ OPTIONS_ALL | OPTIONS_APB_SLVS,
+ VENDOR_GAISLER,
+ GAISLER_IRQMP,
+ ambapp_find_by_idx,
+ NULL
+ rtems_counter_initialize_converter(ambapp_freq_get(&ambapp_plb, adev));
+ } else {
+ &ambapp_plb,
+ VENDOR_GAISLER,
+ GAISLER_GPTIMER,
+ &idx
+ if (adev != NULL) {
+ /* Use the second GPTIMER if available */
+ volatile struct gptimer_regs *gpt = adev_to_gpt(adev);
+ uint32_t max_frequency = ambapp_freq_get(&ambapp_plb, adev);
+ unsigned min_prescaler = 8;
+ uint32_t frequency = max_frequency / min_prescaler;
+ gpt->scaler_reload = min_prescaler - 1;
+ gpt->timer[0].reload = 0xffffffff;
+ gpt->timer[0].ctrl = LEON3_GPTIMER_EN | LEON3_GPTIMER_RL
+ | LEON3_GPTIMER_LD;
+ gpt_counter_initialize(gpt, 0, frequency, free_counter_difference);
+ } else if (LEON3_Timer_Regs != NULL) {
+ /* Fall back to the first GPTIMER if available */
+ LEON3_Timer_Regs,
+ LEON3_CLOCK_INDEX,
+ LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER,
+ clock_counter_difference
1.7.7
