[PATCH] score: Add function to destroy SMP locks
Fri Mar 7 12:01:32 UTC 2014
This makes it necessary to add a function to destroy RTEMS chains:
rtems_chain_destroy().  This function complicates the RTEMS chains API.
 cpukit/libcsupport/src/termios.c           |    1 +
 cpukit/rtems/include/rtems/rtems/intr.h    |   10 ++++++++++
 cpukit/sapi/include/rtems/chain.h          |   16 ++++++++++++++++
 cpukit/score/include/rtems/score/isrlock.h |   16 ++++++++++++++++
 cpukit/score/include/rtems/score/smplock.h |   16 ++++++++++++++--
 testsuites/libtests/block06/init.c         |   10 ++++++++++
 testsuites/sptests/sp37/init.c             |    4 ++++
 testsuites/sptests/spchain/init.c          |   20 ++++++++++++++++++++
 8 files changed, 91 insertions(+), 2 deletions(-)
diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
index ea0e87a..65072a0 100644
--- a/cpukit/libcsupport/src/termios.c
+++ b/cpukit/libcsupport/src/termios.c
@@ -445,6 +445,7 @@ rtems_termios_close (void *arg)
     if ((tty->device.pollRead == NULL) ||
         (tty->device.outputUsesInterrupts == TERMIOS_TASK_DRIVEN))
       rtems_semaphore_delete (tty->rawInBuf.Semaphore);
+    rtems_interrupt_lock_destroy (&tty->interrupt_lock);
     free (tty->rawInBuf.theBuf);
     free (tty->rawOutBuf.theBuf);
     free (tty->cbuf);
diff --git a/cpukit/rtems/include/rtems/rtems/intr.h b/cpukit/rtems/include/rtems/rtems/intr.h
index 62d2dad..04bcb72 100644
--- a/cpukit/rtems/include/rtems/rtems/intr.h
+++ b/cpukit/rtems/include/rtems/rtems/intr.h
@@ -180,6 +180,16 @@ typedef ISR_lock_Context rtems_interrupt_lock_context;
   _ISR_lock_Initialize( _lock )
+ * @brief Destroys an interrupt lock.
+ * Concurrent destruction leads to unpredictable results.
+ * @param[in,out] _lock The interrupt lock control.
+#define rtems_interrupt_lock_destroy( _lock ) \
+  _ISR_lock_Destroy( _lock )
  * @brief Acquires an interrupt lock.
  * Interrupts will be disabled.  On SMP configurations this function acquires
diff --git a/cpukit/sapi/include/rtems/chain.h b/cpukit/sapi/include/rtems/chain.h
index 0927055..f423e6d 100644
--- a/cpukit/sapi/include/rtems/chain.h
+++ b/cpukit/sapi/include/rtems/chain.h
@@ -179,6 +179,22 @@ RTEMS_INLINE_ROUTINE void rtems_chain_initialize_empty(
+ * @brief Destroys the chain.
+ * This routine destroys the specified chain.  This routine is only necessary
+ * in SMP configurations if the protected functions are used and profiling is
+ * enabled.
+ * @param[in] the_chain is the chain to be destroyed.
+RTEMS_INLINE_ROUTINE void rtems_chain_destroy(
+  rtems_chain_control *the_chain
+  _ISR_lock_Destroy( &the_chain->Lock );
  * @brief Set off chain.
  * This function sets the next and previous fields of the @a node to NULL
diff --git a/cpukit/score/include/rtems/score/isrlock.h b/cpukit/score/include/rtems/score/isrlock.h
index e118475..27e4aad 100644
--- a/cpukit/score/include/rtems/score/isrlock.h
+++ b/cpukit/score/include/rtems/score/isrlock.h
@@ -95,6 +95,22 @@ static inline void _ISR_lock_Initialize( ISR_lock_Control *lock )
+ * @brief Destroys an ISR lock.
+ * @param[in,out] lock The ISR lock control.
+static inline void _ISR_lock_Destroy( ISR_lock_Control *lock )
+#if defined( RTEMS_SMP )
+  _SMP_lock_Destroy( &lock->lock );
+#else
+  (void) lock;
+#endif
  * @brief Acquires an ISR lock.
diff --git a/cpukit/score/include/rtems/score/smplock.h b/cpukit/score/include/rtems/score/smplock.h
index 101aa0a..cc94e2e 100644
--- a/cpukit/score/include/rtems/score/smplock.h
+++ b/cpukit/score/include/rtems/score/smplock.h
@@ -131,11 +131,11 @@ typedef struct {
 #define SMP_LOCK_INITIALIZER { SMP_TICKET_LOCK_INITIALIZER }
- * @brief Initializes an SMP lock control.
+ * @brief Initializes an SMP lock.
  * Concurrent initialization leads to unpredictable results.
- * @param[out] lock The SMP lock control.
+ * @param[in,out] lock The SMP lock control.
 static inline void _SMP_lock_Initialize( SMP_lock_Control *lock )
@@ -143,6 +143,18 @@ static inline void _SMP_lock_Initialize( SMP_lock_Control *lock )
+ * @brief Destroys an SMP lock.
+static inline void _SMP_lock_Destroy( SMP_lock_Control *lock )
+  (void) lock;
  * @brief Acquires an SMP lock.
  * This function will not disable interrupts.  The caller must ensure that the
diff --git a/testsuites/libtests/block06/init.c b/testsuites/libtests/block06/init.c
index e51bf27..59dd188 100644
--- a/testsuites/libtests/block06/init.c
+++ b/testsuites/libtests/block06/init.c
@@ -786,6 +786,8 @@ bdbuf_tests_task_0_test_2 (bdbuf_task_control* tc)
   tc->passed = passed;
   tc->test = 0;
+  rtems_chain_destroy (&buffers);
@@ -964,6 +966,8 @@ bdbuf_tests_task_0_test_4 (bdbuf_task_control* tc)
   tc->test = 0;
 static void
@@ -1027,6 +1031,8 @@ bdbuf_tests_task_0_test_6 (bdbuf_task_control* tc)
   tc->test = 0;
 static void
@@ -1085,6 +1091,8 @@ bdbuf_tests_task_0_test_7 (bdbuf_task_control* tc)
   tc->test = 0;
 static void
@@ -1172,6 +1180,8 @@ bdbuf_tests_task_0_test_8 (bdbuf_task_control* tc)
   tc->test = 0;
 static void
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index cd49ae2..e321a78 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -178,6 +178,8 @@ static void test_isr_locks( void )
   _ISR_lock_Release( &lock, &lock_context );
   rtems_test_assert( normal_interrupt_level == _ISR_Get_level() );
+  _ISR_lock_Destroy( &lock );
 static rtems_mode get_interrupt_level( void )
@@ -212,6 +214,8 @@ static void test_interrupt_locks( void )
   rtems_interrupt_lock_release_isr( &lock, &lock_context );
   rtems_test_assert( normal_interrupt_level == get_interrupt_level() );
+  rtems_interrupt_lock_destroy( &lock );
 void test_interrupt_inline(void)
diff --git a/testsuites/sptests/spchain/init.c b/testsuites/sptests/spchain/init.c
index 747f404..3a355ad 100644
--- a/testsuites/sptests/spchain/init.c
+++ b/testsuites/sptests/spchain/init.c
@@ -56,6 +56,8 @@ static void test_chain_control_initializer(void)
     rtems_chain_immutable_tail( &one_node_chain )
       == rtems_chain_immutable_next( &node_of_one_node_chain )
+  rtems_chain_destroy( &chain );
 static void test_chain_control_layout(void)
@@ -96,6 +98,8 @@ static void test_chain_get_with_wait(void)
   sc = rtems_chain_get_with_wait( &chain, EVENT, TIMEOUT, &p );
   rtems_test_assert( sc == RTEMS_TIMEOUT );
   rtems_test_assert( p == NULL );
 static void test_chain_first_and_last(void)
@@ -115,6 +119,8 @@ static void test_chain_first_and_last(void)
   puts( "INIT - Verify rtems_chain_is_last" );
   cnode = rtems_chain_last(&chain);
   rtems_test_assert( rtems_chain_is_last( cnode ) );
 static void test_chain_with_notification(void)
@@ -151,6 +157,8 @@ static void test_chain_with_notification(void)
   rtems_test_assert( sc == RTEMS_SUCCESSFUL );
   rtems_test_assert( p == &a );
   puts( "INIT - Verify rtems_chain_prepend_with_notification" );
   rtems_chain_initialize_empty( &chain );
   sc = rtems_chain_prepend_with_notification(
@@ -174,6 +182,8 @@ static void test_chain_with_notification(void)
   puts( "INIT - Verify rtems_chain_get_with_notification" );
@@ -195,6 +205,8 @@ static void test_chain_with_notification(void)
   rtems_test_assert( out == EVENT );
 static void test_chain_with_empty_check(void)
@@ -211,6 +223,7 @@ static void test_chain_with_empty_check(void)
   rtems_test_assert( empty );
   empty = rtems_chain_append_with_empty_check( &chain, &a );
   rtems_test_assert( !empty );
   puts( "INIT - Verify rtems_chain_prepend_with_empty_check" );
@@ -220,6 +233,7 @@ static void test_chain_with_empty_check(void)
   empty = rtems_chain_prepend_with_empty_check( &chain, &b );
   puts( "INIT - Verify rtems_chain_get_with_empty_check" );
@@ -234,6 +248,8 @@ static void test_chain_with_empty_check(void)
   empty = rtems_chain_get_with_empty_check( &chain, &p );
   rtems_test_assert( p == &b );
 static void test_chain_node_count(void)
@@ -254,6 +270,8 @@ static void test_chain_node_count(void)
     count = rtems_chain_node_count_unprotected( &chain );
     rtems_test_assert( count == i + 1 );
 static bool test_order( const Chain_Node *left, const Chain_Node *right )
@@ -324,6 +342,8 @@ rtems_task Init(
+  rtems_chain_destroy( &chain1 );
   test_chain_first_and_last();
   test_chain_with_empty_check();
   test_chain_with_notification();
1.7.7
