[PATCH 01/18] bsp/arm: SMP support for a9mpcore_clock_cleanup()
Ralf Kirchner ralf.kirchner at embedded-brains.de
Fri Mar 7 13:59:05 UTC 2014
 .../libbsp/arm/shared/arm-a9mpcore-clock-config.c  |   21 ++++++++++++++++----
 1 Datei geändert, 17 Zeilen hinzugefügt(+), 4 Zeilen entfernt(-)
diff --git a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c
index e32657d..cb3588f 100644
--- a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c
+++ b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c
@@ -105,17 +105,30 @@ CPU_Counter_ticks _CPU_Counter_read(void)
   return gt->cntrlower;
-static void a9mpcore_clock_cleanup(void)
+static void a9mpcore_clock_cleanup_isr( rtems_irq_hdl_param arg )
   volatile a9mpcore_gt *gt = A9MPCORE_GT;
-  rtems_status_code sc;
+  (void)arg;
   gt->ctrl &= A9MPCORE_GT_CTRL_TMR_EN;
   gt->irqst = A9MPCORE_GT_IRQST_EFLG;
+static void a9mpcore_clock_cleanup(void)
+  rtems_status_code sc;
-  sc = rtems_interrupt_handler_remove(
+  /* The relevant registers / bits of the global timer are banked
+   * and chances are, on an SPM system we are executing on the wrong
+   * CPU to reset them. Thus we will have the actual cleanup done
+   * with the next clock tick.
+   * The ISR will execute on the right CPU for the cleanup. */
+  sc = rtems_interrupt_handler_install(
     A9MPCORE_IRQ_GT,
-    (rtems_interrupt_handler) Clock_isr,
+    "Clock",
+    RTEMS_INTERRUPT_REPLACE,
+    a9mpcore_clock_cleanup_isr,
     NULL
   if (sc != RTEMS_SUCCESSFUL) {
1.7.10.4
