[PATCH 12/18] bsp/arm: Add handling for level 2 L2C-310 cache controller
Ralf Kirchner ralf.kirchner at embedded-brains.de
Fri Mar 7 13:59:16 UTC 2014
arm-l2c-310/cache_.h contains the handling for the L2C-310
level 2 cache controller from arm. It references the arm
level 1 cache handling in the new file arm-cache-l1.h.
 c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h   | 1515 ++++++++++++++++++++
 c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h |  483 +++++++
 2 Dateien geändert, 1998 Zeilen hinzugefügt(+)
 create mode 100644 c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
 create mode 100644 c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h
diff --git a/c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h b/c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
new file mode 100644
index 0000000..2c1eb8f
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
@@ -0,0 +1,1515 @@
+ * @file cache_.h
+ * @ingroup L2C-310_cache
+ * @brief Cache definitions and functions.
+ * This file implements handling for the ARM L2C-310 cache controller
+ * Authorship
+ * This software was created by
+ *     R. Claus <claus at slac.stanford.edu>, 2013,
+ *       Stanford Linear Accelerator Center, Stanford University.
+ * Acknowledgement of sponsorship
+ * This software was produced by
+ *     the Stanford Linear Accelerator Center, Stanford University,
+ *     under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ * Government disclaimer of liability
+ * Neither the United States nor the United States Department of Energy,
+ * nor any of their employees, makes any warranty, express or implied, or
+ * assumes any legal liability or responsibility for the accuracy,
+ * completeness, or usefulness of any data, apparatus, product, or process
+ * disclosed, or represents that its use would not infringe privately owned
+ * rights.
+ * Stanford disclaimer of liability
+ * Stanford University makes no representations or warranties, express or
+ * implied, nor assumes any liability for the use of this software.
+ * Stanford disclaimer of copyright
+ * Stanford University, owner of the copyright, hereby disclaims its
+ * copyright and all other rights in this software.  Hence, anyone may
+ * freely use it for any purpose without restriction.
+ * Maintenance of notices
+ * In the interest of clarity regarding the origin and status of this
+ * SLAC software, this and all the preceding Stanford University notices
+ * are to remain affixed to any copy or derivative of this software made
+ * or distributed by the recipient and are to be affixed to any copy of
+ * software made or distributed by the recipient that contains a copy or
+ * derivative of this software.
+ * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
+#ifndef LIBBSP_ARM_SHARED_L2C_310_CACHE_H
+#define LIBBSP_ARM_SHARED_L2C_310_CACHE_H
+#include <assert.h>
+#include <bsp.h>
+#include <libcpu/arm-cp15.h>
+#include <bsp/arm-release-id.h>
+#include <bsp/arm-errata.h>
+#include "../include/arm-cache-l1.h"
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/* These two defines also ensure that the rtems_cache_* functions have bodies */
+#define CPU_DATA_CACHE_ALIGNMENT ARM_CACHE_L1_CPU_DATA_ALIGNMENT
+#define CPU_INSTRUCTION_CACHE_ALIGNMENT ARM_CACHE_L1_CPU_INSTRUCTION_ALIGNMENT
+#define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS \
+  ARM_CACHE_L1_CPU_SUPPORT_PROVIDES_RANGE_FUNCTIONS
+#define CACHE_L2C_310_DATA_LINE_MASK ( CPU_DATA_CACHE_ALIGNMENT - 1 )
+#define CACHE_L2C_310_INSTRUCTION_LINE_MASK \
+  ( CPU_INSTRUCTION_CACHE_ALIGNMENT \
+    - 1 )
+#define CACHE_l2C_310_NUM_WAYS 8
+#define CACHE_l2C_310_WAY_MASK ( ( 1 << CACHE_l2C_310_NUM_WAYS ) - 1 )
+/* RTL release number as can be read from cache_id register */
+typedef enum {
+  CACHE_L2C_310_RTL_RELEASE_R0_P0 = 0x0,
+  CACHE_L2C_310_RTL_RELEASE_R1_P0 = 0x2,
+  CACHE_L2C_310_RTL_RELEASE_R2_P0 = 0x4,
+  CACHE_L2C_310_RTL_RELEASE_R3_P0 = 0x5,
+  CACHE_L2C_310_RTL_RELEASE_R3_P1 = 0x6,
+  CACHE_L2C_310_RTL_RELEASE_R3_P2 = 0x8,
+  CACHE_L2C_310_RTL_RELEASE_R3_P3 = 0x9
+} cache_l2c_310_rtl_release;
+ * @defgroup L2C-310_cache Cache Support
+ * @ingroup arm_shared
+ * @brief Cache Functions and Defitions
+ * @brief L2CC Register Offsets
+typedef struct {
+  /** @brief Cache ID */
+  uint32_t cache_id;
+#define CACHE_L2C_310_L2CC_ID_RTL_MASK 0x3f
+#define CACHE_L2C_310_L2CC_ID_PART_MASK ( 0xf << 6 )
+#define CACHE_L2C_310_L2CC_ID_PART_L210 ( 1 << 6 )
+#define CACHE_L2C_310_L2CC_ID_PART_L310 ( 3 << 6 )
+  /** @brief Cache type */
+  uint32_t cache_type;
+/** @brief 1 if data banking implemented, 0 if not */
+#define CACHE_L2C_310_L2CC_TYPE_DATA_BANKING_MASK 0x80000000
+/** @brief 11xy, where: x=1 if pl310_LOCKDOWN_BY_MASTER is defined, otherwise 0 */
+#define CACHE_L2C_310_L2CC_TYPE_CTYPE_MASK 0x1E000000
+/** @brief y=1 if pl310_LOCKDOWN_BY_LINE is defined, otherwise 0. */
+#define CACHE_L2C_310_L2CC_TYPE_CTYPE_SHIFT 25
+/** @brief 1 for Harvard architecture, 0 for unified architecture */
+#define CACHE_L2C_310_L2CC_TYPE_HARVARD_MASK 0x01000000
+/** @brief Data cache way size = 2 Exp(value + 2) KB */
+#define CACHE_L2C_310_L2CC_TYPE_SIZE_D_WAYS_MASK 0x00700000
+#define CACHE_L2C_310_L2CC_TYPE_SIZE_D_WAYS_SHIFT 20
+/** @brief Assoziativity aka number of data ways = (value * 8) + 8 */
+#define CACHE_L2C_310_L2CC_TYPE_NUM_D_WAYS_MASK 0x00040000
+#define CACHE_L2C_310_L2CC_TYPE_NUM_D_WAYS_SHIFT 18
+/** @brief Data cache line length 00 - 32 */
+#define CACHE_L2C_310_L2CC_TYPE_LENGTH_D_LINE_MASK 0x00003000
+#define CACHE_L2C_310_L2CC_TYPE_LENGTH_D_LINE_SHIFT 12
+#define CACHE_L2C_310_L2CC_TYPE_LENGTH_D_LINE_VAL_32 0x0
+/** @brief Instruction cache way size = 2 Exp(value + 2) KB */
+#define CACHE_L2C_310_L2CC_TYPE_SIZE_I_WAYS_MASK 0x00000700
+#define CACHE_L2C_310_L2CC_TYPE_SIZE_I_WAYS_SHIFT 8
+/** @brief Assoziativity aka number of instruction ways = (value * 8) + 8 */
+#define CACHE_L2C_310_L2CC_TYPE_NUM_I_WAYS_MASK 0x00000040
+#define CACHE_L2C_310_L2CC_TYPE_NUM_I_WAYS_SHIFT 6
+/** @brief Instruction cache line length 00 - 32 */
+#define CACHE_L2C_310_L2CC_TYPE_LENGTH_I_LINE_MASK 0x00000003
+#define CACHE_L2C_310_L2CC_TYPE_LENGTH_I_LINE_SHIFT 0
+#define CACHE_L2C_310_L2CC_TYPE_LENGTH_I_LINE_VAL_32 0x0
+  uint8_t reserved_8[0x100 - 8];
+  uint32_t ctrl; /* Control */
+/** @brief Enables the L2CC */
+#define CACHE_L2C_310_L2CC_ENABLE_MASK 0x00000001
+  /** @brief Auxiliary control */
+  uint32_t aux_ctrl;
+/** @brief Early BRESP Enable */
+#define CACHE_L2C_310_L2CC_AUX_EBRESPE_MASK 0x40000000
+/** @brief Instruction Prefetch Enable */
+#define CACHE_L2C_310_L2CC_AUX_IPFE_MASK 0x20000000
+/** @brief Data Prefetch Enable */
+#define CACHE_L2C_310_L2CC_AUX_DPFE_MASK 0x10000000
+/** @brief Non-secure interrupt access control */
+#define CACHE_L2C_310_L2CC_AUX_NSIC_MASK 0x08000000
+/** @brief Non-secure lockdown enable */
+#define CACHE_L2C_310_L2CC_AUX_NSLE_MASK 0x04000000
+/** @brief Cache replacement policy */
+#define CACHE_L2C_310_L2CC_AUX_CRP_MASK 0x02000000
+/** @brief Force write allocate */
+#define CACHE_L2C_310_L2CC_AUX_FWE_MASK 0x01800000
+/** @brief Shared attribute override enable */
+#define CACHE_L2C_310_L2CC_AUX_SAOE_MASK 0x00400000
+/** @brief Parity enable */
+#define CACHE_L2C_310_L2CC_AUX_PE_MASK 0x00200000
+/** @brief Event monitor bus enable */
+#define CACHE_L2C_310_L2CC_AUX_EMBE_MASK 0x00100000
+/** @brief Way-size */
+#define CACHE_L2C_310_L2CC_AUX_WAY_SIZE_MASK 0x000E0000
+#define CACHE_L2C_310_L2CC_AUX_WAY_SIZE_SHIFT 17
+#define CACHE_L2C_310_L2CC_AUX_ASSOC_MASK 0x00010000
+/** @brief Shared attribute invalidate enable */
+#define CACHE_L2C_310_L2CC_AUX_SAIE_MASK 0x00002000
+/** @brief Exclusive cache configuration */
+#define CACHE_L2C_310_L2CC_AUX_EXCL_CACHE_MASK 0x00001000
+/** @brief Store buffer device limitation Enable */
+#define CACHE_L2C_310_L2CC_AUX_SBDLE_MASK 0x00000800
+/** @brief High Priority for SO and Dev Reads Enable */
+#define CACHE_L2C_310_L2CC_AUX_HPSODRE_MASK 0x00000400
+/** @brief Full line of zero enable */
+#define CACHE_L2C_310_L2CC_AUX_FLZE_MASK 0x00000001
+/** @brief Enable all prefetching, */
+#define CACHE_L2C_310_L2CC_AUX_REG_DEFAULT_MASK \
+  ( CACHE_L2C_310_L2CC_AUX_WAY_SIZE_MASK & ( 0x3 << CACHE_L2C_310_L2CC_AUX_WAY_SIZE_SHIFT ) ) \
+  | CACHE_L2C_310_L2CC_AUX_PE_MASK      /* Prefetch enable */ \
+  | CACHE_L2C_310_L2CC_AUX_SAOE_MASK    /* Shared attribute override enable */ \
+  | CACHE_L2C_310_L2CC_AUX_CRP_MASK     /* Cache replacement policy */ \
+  | CACHE_L2C_310_L2CC_AUX_DPFE_MASK    /* Data prefetch enable */ \
+  | CACHE_L2C_310_L2CC_AUX_IPFE_MASK    /* Instruction prefetch enable */ \
+  | CACHE_L2C_310_L2CC_AUX_EBRESPE_MASK /* Early BRESP enable */
+#define CACHE_L2C_310_L2CC_AUX_REG_ZERO_MASK 0xFFF1FFFF
+/** @brief 1 cycle of latency, there is no additional latency fot tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_1_CYCLE_LAT_VAL 0x00000000
+/** @brief 2 cycles of latency for tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_2_CYCLE_LAT_VAL 0x00000001
+/** @brief 3 cycles of latency for tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_3_CYCLE_LAT_VAL 0x00000002
+/** @brief 4 cycles of latency for tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_4_CYCLE_LAT_VAL 0x00000003
+/** @brief 5 cycles of latency for tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_5_CYCLE_LAT_VAL 0x00000004
+/** @brief 6 cycles of latency for tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_6_CYCLE_LAT_VAL 0x00000005
+/** @brief 7 cycles of latency for tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_7_CYCLE_LAT_VAL 0x00000006
+/** @brief 8 cycles of latency for tag RAM */
+#define CACHE_L2C_310_L2CC_RAM_8_CYCLE_LAT_VAL 0x00000007
+/** @brief Shift left setup latency values by this value */
+#define CACHE_L2C_310_L2CC_RAM_SETUP_SHIFT 0x00000000
+/** @brief Shift left read latency values by this value */
+#define CACHE_L2C_310_L2CC_RAM_READ_SHIFT 0x00000004
+/** @brief Shift left write latency values by this value */
+#define CACHE_L2C_310_L2CC_RAM_WRITE_SHIFT 0x00000008
+/** @brief Mask for RAM setup latency */
+#define CACHE_L2C_310_L2CC_RAM_SETUP_LAT_MASK 0x00000007
+/** @brief Mask for RAM read latency */
+#define CACHE_L2C_310_L2CC_RAM_READ_LAT_MASK 0x00000070
+#define CACHE_L2C_310_L2CC_RAM_WRITE_LAT_MASK 0x00000700
+  /** @brief Latency for tag RAM */
+  uint32_t tag_ram_ctrl;
+/* @brief Latency for tag RAM */
+#define CACHE_L2C_310_L2CC_TAG_RAM_DEFAULT_LAT \
+  ( ( CACHE_L2C_310_L2CC_RAM_2_CYCLE_LAT_VAL << CACHE_L2C_310_L2CC_RAM_SETUP_SHIFT ) \
+    | ( CACHE_L2C_310_L2CC_RAM_2_CYCLE_LAT_VAL << CACHE_L2C_310_L2CC_RAM_READ_SHIFT ) \
+    | ( CACHE_L2C_310_L2CC_RAM_2_CYCLE_LAT_VAL << CACHE_L2C_310_L2CC_RAM_WRITE_SHIFT ) )
+  /** @brief Latency for data RAM */
+  uint32_t data_ram_ctrl;
+/** @brief Latency for data RAM */
+#define CACHE_L2C_310_L2CC_DATA_RAM_DEFAULT_MASK \
+    | ( CACHE_L2C_310_L2CC_RAM_3_CYCLE_LAT_VAL << CACHE_L2C_310_L2CC_RAM_READ_SHIFT ) \
+  uint8_t reserved_110[0x200 - 0x110];
+  /** @brief Event counter control */
+  uint32_t ev_ctrl;
+  /** @brief Event counter 1 configuration */
+  uint32_t ev_cnt1_cfg;
+  /** @brief Event counter 0 configuration */
+  uint32_t ev_cnt0_cfg;
+  /** @brief Event counter 1 value */
+  uint32_t ev_cnt1;
+  /** @brief Event counter 0 value */
+  uint32_t ev_cnt0;
+  /** @brief Interrupt enable mask */
+  uint32_t int_mask;
+  /** @brief Masked   interrupt status (read-only)*/
+  uint32_t int_mask_status;
+  /** @brief Unmasked interrupt status */
+  uint32_t int_raw_status;
+  /** @brief Interrupt clear */
+  uint32_t int_clr;
+ * @name Interrupt bit masks
+/** @brief DECERR from L3 */
+#define CACHE_L2C_310_L2CC_INT_DECERR_MASK 0x00000100
+/** @brief SLVERR from L3 */
+#define CACHE_L2C_310_L2CC_INT_SLVERR_MASK 0x00000080
+/** @brief Error on L2 data RAM (Read) */
+#define CACHE_L2C_310_L2CC_INT_ERRRD_MASK 0x00000040
+/** @brief Error on L2 tag RAM (Read) */
+#define CACHE_L2C_310_L2CC_INT_ERRRT_MASK 0x00000020
+/** @brief Error on L2 data RAM (Write) */
+#define CACHE_L2C_310_L2CC_INT_ERRWD_MASK 0x00000010
+/** @brief Error on L2 tag RAM (Write) */
+#define CACHE_L2C_310_L2CC_INT_ERRWT_MASK 0x00000008
+/** @brief Parity Error on L2 data RAM (Read) */
+#define CACHE_L2C_310_L2CC_INT_PARRD_MASK 0x00000004
+/** @brief Parity Error on L2 tag RAM (Read) */
+#define CACHE_L2C_310_L2CC_INT_PARRT_MASK 0x00000002
+/** @brief Event Counter1/0 Overflow Increment */
+#define CACHE_L2C_310_L2CC_INT_ECNTR_MASK 0x00000001
+  uint8_t reserved_224[0x730 - 0x224];
+  /** @brief Drain the STB */
+  uint32_t cache_sync;
+  uint8_t reserved_734[0x740 - 0x734];
+  /** @brief ARM Errata 753970 for pl310-r3p0 */
+  uint32_t dummy_cache_sync_reg;
+  uint8_t reserved_744[0x770 - 0x744];
+  /** @brief Invalidate line by PA */
+  uint32_t inv_pa;
+  uint8_t reserved_774[0x77c - 0x774];
+  /** @brief Invalidate by Way */
+  uint32_t inv_way;
+  uint8_t reserved_780[0x7b0 - 0x780];
+  /** @brief Clean Line by PA */
+  uint32_t clean_pa;
+  uint8_t reserved_7b4[0x7b8 - 0x7b4];
+  /** @brief Clean Line by Set/Way */
+  uint32_t clean_index;
+  /** @brief Clean by Way */
+  uint32_t clean_way;
+  uint8_t reserved_7c0[0x7f0 - 0x7c0];
+  /** @brief Clean and Invalidate Line by PA */
+  uint32_t clean_inv_pa;
+  uint8_t reserved_7f4[0x7f8 - 0x7f4];
+  /** @brief Clean and Invalidate Line by Set/Way */
+  uint32_t clean_inv_indx;
+  /** @brief Clean and Invalidate by Way */
+  uint32_t clean_inv_way;
+  /** @brief Data        lock down 0 */
+  uint32_t d_lockdown_0;
+  /** @brief Instruction lock down 0 */
+  uint32_t i_lockdown_0;
+  /** @brief Data        lock down 1 */
+  uint32_t d_lockdown_1;
+  /** @brief Instruction lock down 1 */
+  uint32_t i_lockdown_1;
+  /** @brief Data        lock down 2 */
+  uint32_t d_lockdown_2;
+  /** @brief Instruction lock down 2 */
+  uint32_t i_lockdown_2;
+  /** @brief Data        lock down 3 */
+  uint32_t d_lockdown_3;
+  /** @brief Instruction lock down 3 */
+  uint32_t i_lockdown_3;
+  /** @brief Data        lock down 4 */
+  uint32_t d_lockdown_4;
+  /** @brief Instruction lock down 4 */
+  uint32_t i_lockdown_4;
+  /** @brief Data        lock down 5 */
+  uint32_t d_lockdown_5;
+  /** @brief Instruction lock down 5 */
+  uint32_t i_lockdown_5;
+  /** @brief Data        lock down 6 */
+  uint32_t d_lockdown_6;
+  /** @brief Instruction lock down 6 */
+  uint32_t i_lockdown_6;
+  /** @brief Data        lock down 7 */
+  uint32_t d_lockdown_7;
+  /** @brief Instruction lock down 7 */
+  uint32_t i_lockdown_7;
+  uint8_t reserved_940[0x950 - 0x940];
+  /** @brief Lockdown by Line Enable */
+  uint32_t lock_line_en;
+  /** @brief Cache lockdown by way */
+  uint32_t unlock_way;
+  uint8_t reserved_958[0xc00 - 0x958];
+  /** @brief Address range redirect, part 1 */
+  uint32_t addr_filtering_start;
+  /** @brief Address range redirect, part 2 */
+  uint32_t addr_filtering_end;
+/** @brief Address filtering valid bits*/
+#define CACHE_L2C_310_L2CC_ADDR_FILTER_VALID_MASK 0xFFF00000
+/** @brief Address filtering enable bit*/
+#define CACHE_L2C_310_L2CC_ADDR_FILTER_ENABLE_MASK 0x00000001
+  uint8_t reserved_c08[0xf40 - 0xc08];
+  /** @brief Debug control */
+  uint32_t debug_ctrl;
+/** @brief Debug SPIDEN bit */
+#define CACHE_L2C_310_L2CC_DEBUG_SPIDEN_MASK 0x00000004
+/** @brief Debug DWB bit, forces write through */
+#define CACHE_L2C_310_L2CC_DEBUG_DWB_MASK 0x00000002
+/** @brief Debug DCL bit, disables cache line fill */
+#define CACHE_L2C_310_L2CC_DEBUG_DCL_MASK 0x00000002
+  uint8_t reserved_f44[0xf60 - 0xf44];
+  /** @brief Purpose prefetch enables */
+  uint32_t prefetch_ctrl;
+/** @brief Prefetch offset */
+#define CACHE_L2C_310_L2CC_PREFETCH_OFFSET_MASK 0x0000001F
+  uint8_t reserved_f64[0xf80 - 0xf64];
+  /** @brief Purpose power controls */
+  uint32_t power_ctrl;
+} L2CC;
+/* Errata table for the LC2 310 Level 2 cache from ARM.
+* Information taken from ARMs
+* "CoreLink controllers and peripherals
+* - System controllers
+* - L2C-310 Level 2 Cache Controller
+* - Revision r3p3
+* - Software Developer Errata Notice
+* - ARM CoreLink Level 2 Cache Controller (L2C-310 or PL310),
+*   r3 releases Software Developers Errata Notice"
+* The corresponding link is:
+* http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0360f/BABJFIBA.html
+* Please see this document for more information on these erratas */
+static bool l2c_310_cache_errata_is_applicable_753970(
+  void
+  volatile L2CC                  *l2cc          =
+    (volatile L2CC *) BSP_ARM_L2CC_BASE;
+  const cache_l2c_310_rtl_release RTL_RELEASE   =
+    l2cc->cache_id & CACHE_L2C_310_L2CC_ID_RTL_MASK;
+  bool                            is_applicable = false;
+  switch( RTL_RELEASE ) {
+    case CACHE_L2C_310_RTL_RELEASE_R3_P3:
+    case CACHE_L2C_310_RTL_RELEASE_R3_P2:
+    case CACHE_L2C_310_RTL_RELEASE_R3_P1:
+    case CACHE_L2C_310_RTL_RELEASE_R2_P0:
+    case CACHE_L2C_310_RTL_RELEASE_R1_P0:
+    case CACHE_L2C_310_RTL_RELEASE_R0_P0:
+      is_applicable = false;
+    break;
+    case CACHE_L2C_310_RTL_RELEASE_R3_P0:
+      is_applicable = true;
+    break;
+    default:
+       assert(   RTL_RELEASE == CACHE_L2C_310_RTL_RELEASE_R3_P3
+              || RTL_RELEASE == CACHE_L2C_310_RTL_RELEASE_R3_P2
+              || RTL_RELEASE == CACHE_L2C_310_RTL_RELEASE_R3_P1
+              || RTL_RELEASE == CACHE_L2C_310_RTL_RELEASE_R3_P0
+              || RTL_RELEASE == CACHE_L2C_310_RTL_RELEASE_R2_P0
+              || RTL_RELEASE == CACHE_L2C_310_RTL_RELEASE_R1_P0
+              || RTL_RELEASE == CACHE_L2C_310_RTL_RELEASE_R0_P0 );
+     break;
+  return is_applicable;
+static bool l2c_310_cache_errata_is_applicable_727913(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_727914(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_727915(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_729806(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_729815(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_742884(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_752271(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_765569(
+  void
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_769419(
+  void
+    break;
+    break;
+    default:
+     break;
+static bool l2c_310_cache_errata_is_applicable_588369(
+  void
+    break;
+    break;
+    default:
+     break;
+#ifdef CACHE_ERRATA_CHECKS_FOR_IMPLEMENTED_ERRATAS
+static bool l2c_310_cache_errata_is_applicable_754670(
+  void
+    break;
+    default:
+     break;
+#endif /* CACHE_ERRATA_CHECKS_FOR_IMPLEMENTED_ERRATAS */
+/* Errata Handlers */
+#if ( defined( RTEMS_SMP ) )
+  #define CACHE_ARM_ERRATA_764369_HANDLER()                    \
+    if( arm_errata_is_applicable_processor_errata_764369() ) { \
+      _ARM_Data_synchronization_barrier();                     \
+#else /* #if ( defined( RTEMS_SMP ) ) */
+#endif /* #if ( defined( RTEMS_SMP ) ) */
+/* The common workaround for this erratum would be to add a
+ * data synchronization barrier to the beginning of the abort handler.
+ * But for RTEMS a call of the abort handler means a fatal condition anyway.
+ * So there is no need to handle this erratum */
+#define CACHE_ARM_ERRATA_775420_HANDLER()                   \
+  if( arm_errata_is_applicable_processor_errata_775420 ) {  \
+static void l2c_310_cache_check_errata( void )
+  /* This erratum gets handled within the sources */
+  /* Unhandled erratum present: 588369 Errata 588369 says that clean + inv may
+   * keep the cache line if it was clean. See ARMs documentation on the erratum
+   * for a workaround */
+  /* assert( ! l2c_310_cache_errata_is_applicable_588369() ); */
+  /* Unhandled erratum present: 727913 Prefetch dropping feature can cause
+   * incorrect behavior when PL310 handles reads that cross cache line
+   * boundary */
+  assert( ! l2c_310_cache_errata_is_applicable_727913() );
+  /* Unhandled erratum present: 727914 Double linefill feature can cause
+   * deadlock */
+  assert( ! l2c_310_cache_errata_is_applicable_727914() );
+  /* Unhandled erratum present: 727915 Background Clean and Invalidate by Way
+   * operation can cause data corruption */
+  assert( ! l2c_310_cache_errata_is_applicable_727915() );
+  /* Unhandled erratum present: 729806 Speculative reads from the Cortex-A9
+   * MPCore processor can cause deadlock */
+  assert( ! l2c_310_cache_errata_is_applicable_729806() );
+  if( l2c_310_cache_errata_is_applicable_729815() )
+    volatile L2CC *l2cc = (volatile L2CC *) BSP_ARM_L2CC_BASE;
+    assert( 0 == ( l2cc->aux_ctrl & CACHE_L2C_310_L2CC_AUX_HPSODRE_MASK ) );
+    /* Erratum: 729815 The “High Priority for SO and Dev reads” feature can
+     * cause Quality of Service issues to cacheable read transactions*/
+    /* Conditions
+       This problem occurs when the following conditions are met:
+       1. Bit[10] “High Priority for SO and Dev reads enable” of the PL310
+          Auxiliary Control Register is set to 1.
+       2. PL310 receives a cacheable read that misses in the L2 cache.
+       3. PL310 receives a continuous flow of Strongly Ordered or Device
+          reads that take all address slots in the master interface.
+       Workaround
+       A workaround is only necessary in systems that are able to issue a
+       continuous flow of Strongly Ordered or Device reads. In such a case,
+       the workaround is to disable the “High Priority for SO and Dev reads”
+       feature. This is the default behavior.*/
+  /* Unhandled erratum present: 742884 Double linefill feature might introduce
+   * circular dependency and deadlock */
+  assert( ! l2c_310_cache_errata_is_applicable_742884() );
+  /* Unhandled erratum present: 752271 Double linefill feature can cause data
+   * corruption */
+  assert( ! l2c_310_cache_errata_is_applicable_752271() );
+  /* This erratum gets handled with a workaround: 753970 The Cache Sync
+   * operation prevents further bufferable writes from merging in the store.
+     Search for 753970 in cache_.h for detailed information */
+  /* Conditions
+     1. PL310 receives a Cache Sync operation.
+     Workaround
+     The proposed workaround to avoid this erratum is to replace the normal
+     offset of Cache Sync operation (0x730) by another offset targeting an
+     unmapped PL310 register: 0x740.
+     More specifically, find below a pseudo code sequence illustrating the
+     workaround:
+     Replace
+     // PL310 Cache Sync operation
+     LDR r1,=PL310_BASE
+     STR r2,[r1,#0x730]
+     by
+     // Workaround for PL310 Cache Sync operation
+     STR r2,[r1,#0x740] ; write to an unmapped register
+     This write has the same effect as the Cache Sync operation: store buffer
+     drained and waiting for all buffers empty.*/
+  /* assert( ! l2c_310_cache_errata_is_applicable_753970() ); */
+  /* This erratum can not be worked around: 754670 A continuous write flow can
+   * stall a read targeting the same memory area
+   * But this erratum does not lead to any data corruption */
+  /* assert( ! l2c_310_cache_errata_is_applicable_754670() ); */
+  if( l2c_310_cache_errata_is_applicable_765569() )
+    assert( !( ( l2cc->aux_ctrl & CACHE_L2C_310_L2CC_AUX_IPFE_MASK
+                 || l2cc->aux_ctrl & CACHE_L2C_310_L2CC_AUX_DPFE_MASK )
+               && ( ( l2cc->prefetch_ctrl & CACHE_L2C_310_L2CC_PREFETCH_OFFSET_MASK )
+                    == 23 ) ) );
+    /* Unhandled erratum present: 765569 Prefetcher can cross 4KB boundary if
+     * offset is programmed with value 23 */
+    /* Conditions
+       1. One of the Prefetch Enable bits (bits [29:28] of the Auxiliary or
+          Prefetch Control Register) is set HIGH.
+       2. The prefetch offset bits are programmed with value 23 (5'b10111).
+       Workaround
+       A workaround for this erratum is to program the prefetch offset with any
+       value except 23.*/
+  /* Unhandled erratum present: 769419 No automatic Store Buffer drain,
+   * visibility of written data requires an explicit Cache */
+  assert( ! l2c_310_cache_errata_is_applicable_769419() );
+static inline void
+cache_l2c_310_sync( void )
+  if( l2c_310_cache_errata_is_applicable_753970() ) {
+    l2cc->dummy_cache_sync_reg = 0;
+  } else {
+    l2cc->cache_sync           = 0;
+static inline void
+cache_l2c_310_flush_1_line( const void *d_addr )
+  if( l2c_310_cache_errata_is_applicable_588369() ) {
+    * Errata 588369 says that clean + inv may keep the
+    * cache line if it was clean, the recommanded
+    * workaround is to clean then invalidate the cache
+    * line, with write-back and cache linefill disabled.
+    l2cc->clean_pa     = (uint32_t) d_addr;
+    cache_l2c_310_sync();
+    l2cc->inv_pa       = (uint32_t) d_addr;
+  } else {
+    l2cc->clean_inv_pa = (uint32_t) d_addr;
+static inline void
+cache_l2c_310_flush_range( const void *addr, size_t n_bytes )
+  if ( n_bytes != 0 ) {
+    uint32_t       adx       = (uint32_t) addr
+                               & ~CACHE_L2C_310_DATA_LINE_MASK;
+    const uint32_t ADDR_LAST =
+      ( (uint32_t) addr + n_bytes - 1 ) & ~CACHE_L2C_310_DATA_LINE_MASK;
+    CACHE_ARM_ERRATA_764369_HANDLER();
+    for (; adx <= ADDR_LAST; adx += CPU_DATA_CACHE_ALIGNMENT ) {
+      l2cc->clean_pa = adx;
+static inline void
+cache_l2c_310_flush_entire( void )
+  /* Only flush if level 2 cache is active */
+  if( ( l2cc->ctrl & CACHE_L2C_310_L2CC_ENABLE_MASK ) != 0 ) {
+    /* ensure ordering with previous memory accesses */
+    _ARM_Data_memory_barrier();
+    l2cc->clean_inv_way = CACHE_l2C_310_WAY_MASK;
+    while ( l2cc->clean_inv_way & CACHE_l2C_310_WAY_MASK ) {
+    /* Wait for the flush to complete */
+static inline void
+cache_l2c_310_invalidate_1_line( const void *d_addr )
+static inline void
+cache_l2c_310_invalidate_range( const void *addr, size_t n_bytes )
+                         & ~CACHE_L2C_310_INSTRUCTION_LINE_MASK;
+    const uint32_t end  =
+      ( adx + n_bytes ) & ~CACHE_L2C_310_INSTRUCTION_LINE_MASK;
+    /* Back starting address up to start of a line and invalidate until end */
+    for (;
+         adx < end;
+         adx += CPU_INSTRUCTION_CACHE_ALIGNMENT ) {
+      /* Invalidate L2 cache line */
+      l2cc->inv_pa = adx;
+static inline void
+cache_l2c_310_invalidate_entire( void )
+  /* Invalidate the caches */
+  l2cc->inv_way = CACHE_l2C_310_WAY_MASK;
+  while ( l2cc->inv_way & CACHE_l2C_310_WAY_MASK ) ;
+  /* Wait for the invalidate to complete */
+static inline void
+cache_l2c_310_clean_and_invalidate_entire( void )
+    while ( l2cc->clean_inv_way & CACHE_l2C_310_WAY_MASK ) ;
+static inline void
+cache_l2c_310_store( const void *d_addr )
+static inline void
+cache_l2c_310_freeze( void )
+  /* To be implemented as needed, if supported
+   by hardware at all */
+static inline void
+cache_l2c_310_unfreeze( void )
+static void cache_l2c_310_unlock( void )
+  l2cc->d_lockdown_0 = 0;
+  l2cc->i_lockdown_0 = 0;
+  l2cc->d_lockdown_1 = 0;
+  l2cc->i_lockdown_1 = 0;
+  l2cc->d_lockdown_2 = 0;
+  l2cc->i_lockdown_2 = 0;
+  l2cc->d_lockdown_3 = 0;
+  l2cc->i_lockdown_3 = 0;
+  l2cc->d_lockdown_4 = 0;
+  l2cc->i_lockdown_4 = 0;
+  l2cc->d_lockdown_5 = 0;
+  l2cc->i_lockdown_5 = 0;
+  l2cc->d_lockdown_6 = 0;
+  l2cc->i_lockdown_6 = 0;
+  l2cc->d_lockdown_7 = 0;
+  l2cc->i_lockdown_7 = 0;
+static inline void
+cache_l2c_310_enable( void )
+  uint32_t       cache_id = l2cc->cache_id & CACHE_L2C_310_L2CC_ID_PART_MASK;
+  int            ways     = 0;
+  /* Do we actually have an L2C-310 cache controller?
+   * Has BSP_ARM_L2CC_BASE been configured correctly? */
+  switch ( cache_id ) {
+    case CACHE_L2C_310_L2CC_ID_PART_L310:
+      /* If this assertion fails, you have a release of the
+       * L2C-310 cache for which the l2c_310_cache_errata_is_applicable_ ...
+       * methods are not yet implemented. This means you will get incorrect
+       * errata handling */
+      if ( l2cc->aux_ctrl & ( 1 << 16 ) ) {
+        ways = 16;
+      } else {
+        ways = 8;
+      assert( ways == CACHE_l2C_310_NUM_WAYS );
+    break;
+    case CACHE_L2C_310_L2CC_ID_PART_L210:
+      /* Invalid case */
+      /* Support for this type is not implemented in this driver.
+       * Either support needs to get added or a seperate driver needs to get
+       * implemented */
+      assert( cache_id != CACHE_L2C_310_L2CC_ID_PART_L210 );
+      break;
+    default:
+      /* Unknown case */
+      assert( cache_id == CACHE_L2C_310_L2CC_ID_PART_L310 );
+      break;
+  if ( ways > 0 ) {
+    /* Only enable if L2CC is currently disabled */
+    if ( ways != 0
+         && ( l2cc->ctrl & CACHE_L2C_310_L2CC_ENABLE_MASK ) == 0 ) {
+      rtems_interrupt_level level;
+      uint32_t              aux;
+      rtems_interrupt_disable( level );
+      /* Set up the way size */
+      aux  = l2cc->aux_ctrl;
+      aux &= CACHE_L2C_310_L2CC_AUX_REG_ZERO_MASK; /* Set way_size to 0 */
+      aux |= CACHE_L2C_310_L2CC_AUX_REG_DEFAULT_MASK;
+      /* Make sure that I&D is not locked down when starting */
+      cache_l2c_310_unlock();
+      /* Level 2 configuration and control registers must not get written while
+       * background operations are pending */
+      while ( l2cc->clean_way & CACHE_l2C_310_WAY_MASK ) ;
+      l2cc->aux_ctrl = aux;
+      /* Set up the latencies */
+      l2cc->tag_ram_ctrl  = CACHE_L2C_310_L2CC_TAG_RAM_DEFAULT_LAT;
+      l2cc->data_ram_ctrl = CACHE_L2C_310_L2CC_DATA_RAM_DEFAULT_MASK;
+      cache_l2c_310_invalidate_entire();
+      /* Clear the pending interrupts */
+      l2cc->int_clr = l2cc->int_raw_status;
+      l2c_310_cache_check_errata();
+      /* Enable the L2CC */
+      l2cc->ctrl |= CACHE_L2C_310_L2CC_ENABLE_MASK;
+      rtems_interrupt_enable( level );
+static inline void
+cache_l2c_310_disable( void )
+  if ( l2cc->ctrl & CACHE_L2C_310_L2CC_ENABLE_MASK ) {
+    /* Clean and Invalidate L2 Cache */
+    cache_l2c_310_flush_entire();
+    /* Disable the L2 cache */
+    l2cc->ctrl &= ~CACHE_L2C_310_L2CC_ENABLE_MASK;
+static inline void
+_CPU_cache_enable_data( void )
+  cache_l2c_310_enable();
+  arm_cache_l1_enable_data();
+static inline void
+_CPU_cache_disable_data( void )
+  arm_cache_l1_disable_data();
+  cache_l2c_310_disable();
+static inline void
+_CPU_cache_enable_instruction( void )
+  arm_cache_l1_enable_instruction();
+static inline void
+_CPU_cache_disable_instruction( void )
+  arm_cache_l1_disable_instruction();
+static inline void
+_CPU_cache_flush_data_range(
+  const void *d_addr,
+  size_t      n_bytes
+    arm_cache_l1_flush_data_range(
+      d_addr,
+      n_bytes
+    cache_l2c_310_flush_range(
+      d_addr,
+      n_bytes
+static inline void
+_CPU_cache_flush_entire_data( void )
+  arm_cache_l1_flush_entire_data();
+static inline void
+_CPU_cache_invalidate_data_range(
+  const void *addr_first,
+  size_t     n_bytes
+  if ( n_bytes > 0 ) {
+    cache_l2c_310_invalidate_range(
+      addr_first,
+      n_bytes
+    arm_cache_l1_invalidate_data_range(
+      addr_first,
+      n_bytes
+      addr_first,
+      n_bytes
+      addr_first,
+      n_bytes
+static inline void
+_CPU_cache_invalidate_entire_data( void )
+  /* This is broadcast within the cluster */
+  /* forces the address out past level 2 */
+  cache_l2c_310_clean_and_invalidate_entire();
+  /*This is broadcast within the cluster */
+  arm_cache_l1_clean_and_invalidate_entire_data();
+static inline void
+_CPU_cache_store_data_line( const void *d_addr )
+  const void *ADX =
+    (const void *) ( (uint32_t) d_addr & ~CACHE_L2C_310_DATA_LINE_MASK );
+  arm_cache_l1_store_data( ADX );
+  cache_l2c_310_store( ADX );
+static inline void
+_CPU_cache_freeze_data( void )
+  arm_cache_l1_freeze_data();
+  cache_l2c_310_freeze();
+static inline void
+_CPU_cache_unfreeze_data( void )
+  arm_cache_l1_unfreeze_data();
+  cache_l2c_310_unfreeze();
+static inline void
+_CPU_cache_invalidate_instruction_range(
+  const void *i_addr,
+  size_t      n_bytes
+    /* Invalidate L2 cache lines */
+      i_addr,
+      n_bytes
+    arm_cache_l1_invalidate_instruction_range(
+      i_addr,
+      n_bytes
+static inline void
+_CPU_cache_invalidate_entire_instruction( void )
+  arm_cache_l1_invalidate_entire_instruction();
+static inline void
+_CPU_cache_freeze_instruction( void )
+  arm_cache_l1_freeze_instruction();
+static inline void
+_CPU_cache_unfreeze_instruction( void )
+  arm_cache_l1_unfreeze_instruction();
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_SHARED_L2C_310_CACHE_H */
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h b/c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h
index 0000000..0db511d
--- /dev/null
+++ b/c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h
@@ -0,0 +1,483 @@
+ * @file arm-cache-l1.h
+ * @brief Level 1 Cache definitions and functions.
+ * This file implements handling for the ARM Level 1 cache controller
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef LIBBSP_ARM_SHARED_CACHE_L1_H
+#define LIBBSP_ARM_SHARED_CACHE_L1_H
+#include <bsp.h>
+#ifdef __cplusplus
+extern "C" {
+#define ARM_CACHE_L1_CPU_DATA_ALIGNMENT 32
+#define ARM_CACHE_L1_CPU_INSTRUCTION_ALIGNMENT 32
+#define ARM_CACHE_L1_CPU_SUPPORT_PROVIDES_RANGE_FUNCTIONS
+#define ARM_CACHE_L1_CSS_ID_DATA 0
+#define ARM_CACHE_L1_CSS_ID_INSTRUCTION 1
+#define ARM_CACHE_L1_DATA_LINE_MASK ( ARM_CACHE_L1_CPU_DATA_ALIGNMENT - 1 )
+#define ARM_CACHE_L1_INSTRUCTION_LINE_MASK \
+  ( ARM_CACHE_L1_CPU_INSTRUCTION_ALIGNMENT \
+    - 1 )
+  #define ARM_CACHE_L1_ERRATA_764369_HANDLER()                 \
+static void arm_cache_l1_select( const uint32_t selection )
+  /* select current cache level in cssr */
+  arm_cp15_set_cache_size_selection( selection );
+  /* isb to sych the new cssr&csidr */
+  _ARM_Instruction_synchronization_barrier();
+ * @param l1LineSize      Number of bytes in cache line expressed as power of
+ *                        2 value
+ * @param l1Associativity Associativity of cache. The associativity does not
+ *                        have to be a power of 2.
+ * qparam liNumSets       Number of sets in cache
+static inline void arm_cache_l1_properties(
+  uint32_t *l1LineSize,
+  uint32_t *l1Associativity,
+  uint32_t *l1NumSets )
+  uint32_t id;
+  id               = arm_cp15_get_cache_size_id();
+  /* Cache line size in words + 2 -> bytes) */
+  *l1LineSize      = ( id & 0x0007U ) + 2 + 2;
+  /* Number of Ways */
+  *l1Associativity = ( ( id >> 3 ) & 0x03ffU ) + 1;
+  /* Number of Sets */
+  *l1NumSets       = ( ( id >> 13 ) & 0x7fffU ) + 1;
+ * @param log_2_line_bytes The number of bytes per cache line expressed in log2
+ * @param associativity    The associativity of the cache beeing operated
+ * @param cache_level_idx  The level of the cache beeing operated minus 1 e.g 0
+ *                         for cache level 1
+ * @param set              Number of the set to operate on
+ * @param way              Number of the way to operate on
+static inline uint32_t arm_cache_l1_get_set_way_param(
+  const uint32_t log_2_line_bytes,
+  const uint32_t associativity,
+  const uint32_t cache_level_idx,
+  const uint32_t set,
+  const uint32_t way )
+  uint32_t way_shift = __builtin_clz( associativity - 1 );
+  return ( 0
+           | ( way
+    << way_shift ) | ( set << log_2_line_bytes ) | ( cache_level_idx << 1 ) );
+static inline void arm_cache_l1_flush_1_data_line( const void *d_addr )
+  /* Flush the Data cache */
+  arm_cp15_data_cache_clean_and_invalidate_line( d_addr );
+  /* Wait for L1 flush to complete */
+static inline void arm_cache_l1_flush_entire_data( void )
+  uint32_t              l1LineSize, l1Associativity, l1NumSets;
+  uint32_t              s, w;
+  uint32_t              set_way_param;
+  /* make cssr&csidr read atomic */
+  /* Get the L1 cache properties */
+  arm_cache_l1_properties( &l1LineSize, &l1Associativity,
+                                     &l1NumSets );
+  for ( w = 0; w < l1Associativity; ++w ) {
+    for ( s = 0; s < l1NumSets; ++s ) {
+      set_way_param = arm_cache_l1_get_set_way_param(
+        l1LineSize,
+        l1Associativity,
+        0,
+        s,
+        w
+      arm_cp15_data_cache_clean_line_by_set_and_way( set_way_param );
+static inline void arm_cache_l1_invalidate_entire_data( void )
+  uint32_t              s, w;
+                                     &l1NumSets );
+        l1LineSize,
+        l1Associativity,
+        0,
+        s,
+        w
+      arm_cp15_data_cache_invalidate_line_by_set_and_way( set_way_param );
+  /* Wait for L1 invalidate to complete */
+static inline void arm_cache_l1_clean_and_invalidate_entire_data( void )
+  uint32_t              s, w;
+                                     &l1NumSets );
+        l1LineSize,
+        l1Associativity,
+        0,
+        s,
+        w
+      arm_cp15_data_cache_clean_and_invalidate_line_by_set_and_way(
+        set_way_param );
+static inline void arm_cache_l1_store_data( const void *d_addr )
+  /* Store the Data cache line */
+  arm_cp15_data_cache_clean_line( d_addr );
+  /* Wait for L1 store to complete */
+static inline void arm_cache_l1_flush_data_range(
+  size_t      n_bytes
+    uint32_t       adx       = (uint32_t) d_addr
+                               & ~ARM_CACHE_L1_DATA_LINE_MASK;
+      ( (uint32_t) d_addr + n_bytes - 1 ) & ~ARM_CACHE_L1_DATA_LINE_MASK;
+    ARM_CACHE_L1_ERRATA_764369_HANDLER();
+    for (; adx <= ADDR_LAST; adx += ARM_CACHE_L1_CPU_DATA_ALIGNMENT ) {
+      arm_cp15_data_cache_clean_line( (void*)adx );
+static inline void arm_cache_l1_invalidate_1_data_line(
+  const void *d_addr )
+  /* Invalidate the data cache line */
+  arm_cp15_data_cache_invalidate_line( d_addr );
+static inline void arm_cache_l1_freeze_data( void )
+  /* To be implemented as needed, if supported by hardware at all */
+static inline void arm_cache_l1_unfreeze_data( void )
+static inline void arm_cache_l1_invalidate_1_instruction_line(
+  const void *i_addr )
+  /* Invalidate the Instruction cache line */
+  arm_cp15_instruction_cache_invalidate_line( i_addr );
+static inline void arm_cache_l1_invalidate_data_range(
+  size_t      n_bytes
+      ( adx + n_bytes ) & ~ARM_CACHE_L1_DATA_LINE_MASK;
+    for (;
+         adx < end;
+         adx += ARM_CACHE_L1_CPU_DATA_ALIGNMENT ) {
+        arm_cp15_data_cache_invalidate_line( (void*)adx );
+static inline void arm_cache_l1_invalidate_instruction_range(
+  size_t      n_bytes
+    uint32_t       adx = (uint32_t) i_addr
+                         & ~ARM_CACHE_L1_INSTRUCTION_LINE_MASK;
+      ( adx + n_bytes ) & ~ARM_CACHE_L1_INSTRUCTION_LINE_MASK;
+    arm_cache_l1_select( ARM_CACHE_L1_CSS_ID_INSTRUCTION );
+    for (;
+         adx < end;
+         adx += ARM_CACHE_L1_CPU_INSTRUCTION_ALIGNMENT ) {
+        arm_cp15_instruction_cache_invalidate_line( (void*)adx );
+    arm_cache_l1_select( ARM_CACHE_L1_CSS_ID_DATA );
+static inline void arm_cache_l1_invalidate_entire_instruction( void )
+  uint32_t ctrl = arm_cp15_get_control();
+  #ifdef RTEMS_SMP
+  /* invalidate I-cache inner shareable */
+  arm_cp15_instruction_cache_inner_shareable_invalidate_all();
+  /* I+BTB cache invalidate */
+  arm_cp15_instruction_cache_invalidate();
+  #else /* RTEMS_SMP */
+  #endif /* RTEMS_SMP */
+  if ( ( ctrl & ARM_CP15_CTRL_Z ) == 0 ) {
+    arm_cp15_branch_predictor_inner_shareable_invalidate_all();
+    arm_cp15_branch_predictor_invalidate_all();
+static inline void arm_cache_l1_freeze_instruction( void )
+static inline void arm_cache_l1_unfreeze_instruction( void )
+static inline void arm_cache_l1_enable_data( void )
+  uint32_t              ctrl;
+  assert( ARM_CACHE_L1_CPU_DATA_ALIGNMENT == arm_cp15_get_data_cache_line_size() );
+  ctrl = arm_cp15_get_control();
+  /* Only enable the cache if it is disabled */
+  if ( !( ctrl & ARM_CP15_CTRL_C ) ) {
+    /* Clean and invalidate the Data cache */
+    arm_cache_l1_invalidate_entire_data();
+    /* Enable the Data cache */
+    ctrl |= ARM_CP15_CTRL_C;
+    arm_cp15_set_control( ctrl );
+static inline void arm_cache_l1_disable_data( void )
+  /* Disable the Data cache */
+  arm_cp15_set_control( arm_cp15_get_control() & ~ARM_CP15_CTRL_C );
+static inline void arm_cache_l1_disable_instruction( void )
+  /* Synchronize the processor */
+  /* Invalidate the Instruction cache */
+  /* Disable the Instruction cache */
+  arm_cp15_set_control( arm_cp15_get_control() & ~ARM_CP15_CTRL_I );
+static inline void arm_cache_l1_enable_instruction( void )
+  uint32_t              ctrl;
+  assert( ARM_CACHE_L1_CPU_INSTRUCTION_ALIGNMENT
+          == arm_cp15_get_data_cache_line_size() );
+  /* Enable Instruction cache only if it is disabled */
+  if ( !( ctrl & ARM_CP15_CTRL_I ) ) {
+    /* Enable the Instruction cache */
+    ctrl |= ARM_CP15_CTRL_I;
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_SHARED_CACHE_L1_H */
1.7.10.4
