POSIX Once Implementation
Fri Mar 7 18:23:50 UTC 2014
On 03/07/2014 05:19 PM, Joel Sherrill wrote:
> This currently uses a pthread mutex.  That implies when
> I turn it on for all configurations, pthread mutexes will have
> to be enabled.
> Would it be correct and acceptable to rewrite this to use
> CPU atomic locks?
No, this doesn't work.  You must block if you own an SMP lock.
We need an internal mutex here, similar to the allocator mutex.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
