[PATCH 3/4] Classic API Users Guide: Add SMP and affinity services.
Joel Sherrill joel.sherrill at gmail.com
Fri Mar 7 21:40:37 UTC 2014
 doc/ada_user/Makefile.am   |    3 ++-
 doc/ada_user/ada_user.texi |    4 +++-
 doc/ada_user/example.texi  |    7 ++-----
 doc/user/Makefile.am       |    9 +++++++--
 doc/user/c_user.texi       |    2 ++
 5 files changed, 16 insertions(+), 9 deletions(-)
diff --git a/doc/ada_user/Makefile.am b/doc/ada_user/Makefile.am
index d628a29..ab19e71 100644
--- a/doc/ada_user/Makefile.am
+++ b/doc/ada_user/Makefile.am
@@ -24,7 +24,8 @@ COMMON_FILES += \
     $(top_builddir)/user/task.texi $(top_builddir)/user/timer.texi \
     $(top_builddir)/user/userext.texi $(top_builddir)/user/stackchk.texi \
     $(top_builddir)/user/cpuuse.texi $(top_srcdir)/common/cpright.texi \
-    $(top_builddir)/user/object.texi $(top_builddir)/user/cbs.texi
+    $(top_builddir)/user/object.texi $(top_builddir)/user/cbs.texi \
+    $(top_builddir)/user/smp.texi
 FILES = example.texi
diff --git a/doc/ada_user/ada_user.texi b/doc/ada_user/ada_user.texi
index d12663d..80a0e49 100644
--- a/doc/ada_user/ada_user.texi
+++ b/doc/ada_user/ada_user.texi
@@ -8,7 +8,7 @@
 @c %**end of header
 @c
- at c  COPYRIGHT (c) 1989-2013.
+ at c  COPYRIGHT (c) 1989-2014.
 @c  On-Line Applications Research Corporation (OAR).
 @c  All rights reserved.
@@ -107,6 +107,7 @@
 * User Extensions Manager::
 * Configuring a System::
 * Multiprocessing Manager::
+* Symmetric Multiprocessing Services::
 * Stack Bounds Checker::
 * CPU Usage Statistics::
 * Object Services::
@@ -150,6 +151,7 @@
 @include user/userext.texi
 @include user/conf.texi
 @include user/mp.texi
+ at include user/smp.texi
 @include user/stackchk.texi
 @include user/cpuuse.texi
 @include user/object.texi
diff --git a/doc/ada_user/example.texi b/doc/ada_user/example.texi
index 697d1e0..7456767 100644
--- a/doc/ada_user/example.texi
+++ b/doc/ada_user/example.texi
@@ -1,9 +1,9 @@
 @c
- at c  COPYRIGHT (c) 1989-2011.
- at node Example Application, Glossary, Directive Status Codes STATUS_TEXT - Returns a text for a status code, Top
+ at node Example Application, Glossary, Directive Status Codes STATUS_CODE_DESCRIPTION - Returns a description for a status code, Top
 @chapter Example Application
 @example
@@ -11,6 +11,3 @@
 Currently there is no example Ada application provided.
 @end example
diff --git a/doc/user/Makefile.am b/doc/user/Makefile.am
index eec627a..03f776d 100644
--- a/doc/user/Makefile.am
+++ b/doc/user/Makefile.am
@@ -15,7 +15,7 @@ GENERATED_FILES = overview.texi concepts.texi datatypes.texi init.texi \
     signal.texi part.texi region.texi dpmem.texi io.texi fatal.texi \
     schedule.texi rtmon.texi barrier.texi bsp.texi userext.texi conf.texi \
     mp.texi stackchk.texi cpuuse.texi object.texi chains.texi timespec.texi \
-    cbs.texi dirstat.texi
+    cbs.texi dirstat.texi smp.texi
 COMMON_FILES += $(top_srcdir)/common/cpright.texi
@@ -161,10 +161,15 @@ conf.texi: conf.t
 mp.texi: mp.t
 	$(BMENU2) -p "Configuring a System Configuration Data Structures" \
 	    -u "Top" \
+	    -n "Symmetric Multiprocessing Services" < $< > $@
+smp.texi: smp.t
+	$(BMENU2) -p  "Multiprocessing Manager MULTIPROCESSING_ANNOUNCE - Announce the arrival of a packet"\
+	    -u "Top" \
 	    -n "Stack Bounds Checker" < $< > $@
 stackchk.texi: stackchk.t
-	$(BMENU2) -p "Multiprocessing Manager MULTIPROCESSING_ANNOUNCE - Announce the arrival of a packet" \
+	$(BMENU2) -p "Symmetric Multiprocessing Services rtems_task_set_affinity - Set Task Affinity" \
 	    -u "Top" \
 	    -n "CPU Usage Statistics" < $< > $@
diff --git a/doc/user/c_user.texi b/doc/user/c_user.texi
index a1a5fab..2085415 100644
--- a/doc/user/c_user.texi
+++ b/doc/user/c_user.texi
@@ -106,6 +106,7 @@
 * Object Services::
@@ -149,6 +150,7 @@
 @include userext.texi
 @include conf.texi
 @include mp.texi
+ at include smp.texi
 @include stackchk.texi
 @include cpuuse.texi
 @include object.texi
1.7.1
