[PATCH 04/11] sapi: Add SMP lock profiling app. level data
Mon Mar 10 13:28:26 UTC 2014
 cpukit/sapi/include/rtems/profiling.h |   88 ++++++++++++++++++++++++++++++++-
 cpukit/sapi/src/profilingreportxml.c  |   70 ++++++++++++++++++++++++++
 2 files changed, 157 insertions(+), 1 deletions(-)
diff --git a/cpukit/sapi/include/rtems/profiling.h b/cpukit/sapi/include/rtems/profiling.h
index ecb3ff7..2a66015 100644
--- a/cpukit/sapi/include/rtems/profiling.h
+++ b/cpukit/sapi/include/rtems/profiling.h
@@ -66,7 +66,14 @@ typedef enum {
    * @see rtems_profiling_per_cpu.
-  RTEMS_PROFILING_PER_CPU
+  RTEMS_PROFILING_PER_CPU,
+   * @brief Type of SMP lock profiling data.
+   * @see rtems_profiling_smp_lock.
+  RTEMS_PROFILING_SMP_LOCK
 } rtems_profiling_type;
@@ -152,6 +159,80 @@ typedef struct {
 } rtems_profiling_per_cpu;
+ * @brief Count of lock contention counters for SMP lock profiling.
+#define RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS 4
+ * @brief SMP lock profiling data.
+ * The lock acquire attempt instant is the point in time right after the
+ * interrupt disable action in the lock acquire sequence.
+ * The lock acquire instant is the point in time right after the lock
+ * acquisition.  This is the begin of the critical section code execution.
+ * The lock release instant is the point in time right before the interrupt
+ * enable action in the lock release sequence.
+ * The lock section time is the time elapsed between the lock acquire instant
+ * and the lock release instant.
+ * The lock acquire time is the time elapsed between the lock acquire attempt
+ * instant and the lock acquire instant.
+typedef struct {
+   * @brief The profiling data header.
+  rtems_profiling_header header;
+   * @brief The lock name.
+  const char *name;
+   * @brief The maximum lock section time in nanoseconds.
+  uint32_t max_section_time;
+   * @brief The maximum lock acquire time in nanoseconds.
+  uint32_t max_acquire_time;
+   * @brief The count of lock uses.
+   * This value may overflow.
+  uint64_t usage_count;
+   * @brief Total lock section time in nanoseconds.
+   * The average lock section time is the total section time divided by the
+   * lock usage count.
+  uint64_t total_section_time;
+   * @brief The counts of lock acquire operations by contention.
+   * The contention count for index N corresponds to a lock acquire attempt
+   * with an initial queue length of N.  The last index corresponds to all
+   * lock acquire attempts with an initial queue length greater than or equal
+   * to RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS minus one.
+   * The values may overflow.
+  uint64_t contention_counts[RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS];
+} rtems_profiling_smp_lock;
  * @brief Collection of profiling data.
 typedef union {
@@ -164,6 +245,11 @@ typedef union {
    * @brief Per-CPU profiling data if indicated by the header.
   rtems_profiling_per_cpu per_cpu;
+   * @brief SMP lock profiling data if indicated by the header.
+  rtems_profiling_smp_lock smp_lock;
 } rtems_profiling_data;
diff --git a/cpukit/sapi/src/profilingreportxml.c b/cpukit/sapi/src/profilingreportxml.c
index f0a6fd6..5aa1282 100644
--- a/cpukit/sapi/src/profilingreportxml.c
+++ b/cpukit/sapi/src/profilingreportxml.c
@@ -18,6 +18,7 @@
 #include <rtems/profiling.h>
+#include <stddef.h>
 #include <inttypes.h>
 typedef struct {
@@ -128,6 +129,72 @@ static void report_per_cpu(context *ctx, const rtems_profiling_per_cpu *per_cpu)
   update_retval(ctx, rv);
+static void report_smp_lock(context *ctx, const rtems_profiling_smp_lock *smp_lock)
+  rtems_profiling_printf printf_func = ctx->printf_func;
+  void *printf_arg = ctx->printf_arg;
+  int rv;
+  size_t i;
+  indent(ctx, 1);
+  rv = (*printf_func)(
+    printf_arg,
+    "<SMPLockProfilingReport name=\"%s\">\n",
+    smp_lock->name
+  update_retval(ctx, rv);
+  indent(ctx, 2);
+    printf_arg,
+    "<MaxSectionTime unit=\"ns\">%" PRIu32 "</MaxSectionTime>\n",
+    smp_lock->max_section_time
+  indent(ctx, 2);
+    printf_arg,
+    "<MaxAcquireTime unit=\"ns\">%" PRIu32 "</MaxAcquireTime>\n",
+    smp_lock->max_acquire_time
+  indent(ctx, 2);
+    printf_arg,
+    "<UsageCount>%" PRIu64 "</UsageCount>\n",
+    smp_lock->usage_count
+  indent(ctx, 2);
+    printf_arg,
+    "<TotalSectionTime unit=\"ns\">%" PRIu64 "</TotalSectionTime>\n",
+    smp_lock->total_section_time
+  for (i = 0; i < RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS; ++i) {
+    indent(ctx, 2);
+      printf_arg,
+      "<ContentionCount initialQueueLength=\"%zu\">%" PRIu64 "</ContentionCount>\n",
+      i,
+      smp_lock->contention_counts[i]
+  indent(ctx, 1);
+    printf_arg,
+    "</SMPLockProfilingReport>\n"
 static void report(void *arg, const rtems_profiling_data *data)
   context *ctx = arg;
@@ -136,6 +203,9 @@ static void report(void *arg, const rtems_profiling_data *data)
     case RTEMS_PROFILING_PER_CPU:
       report_per_cpu(ctx, &data->per_cpu);
       break;
+    case RTEMS_PROFILING_SMP_LOCK:
+      report_smp_lock(ctx, &data->smp_lock);
+      break;
1.7.7
