psxtests/psxkey08 failure
    Sebastian Huber
    Mon Mar 10 14:32:45 UTC 2014
On 2014-03-10 15:23, Joel Sherrill wrote:
> On Mar 10, 2014 8:14 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
> wrote:
>  > On 2014-03-10 14:04, Joel Sherrill wrote:
>  > > On Mar 10, 2014 7:57 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
>  > > wrote:
>  > >  > Hello,
>  > >  > this test fails now on SIS with debugging enabled:
>  > >  > *** TEST KEY 08 ***
>  > >  > Init - Semaphore 1 create - OK
>  > >  > Init - Semaphore 2 create - OK
>  > >  > Init - pthread Key create - OK
> ../../../../../../../rtems/c/src/../../testsuites/psxtests/psxkey08/init.c: 93
>  > >  > task_id_p
>  > > Grrr.. I will try to look at it today. Any obvious code conversion mistake?
>  > I fixed some obvious thread affinity bugs, but this one exceeded my time limit
>  > for today.
> What configuration is this failing in? I tried with --enable-rtems-debug and
> POSIX enabled and disabled.  Both builds ran fine.
> My tree doesn't have any patches newer than the one where I enabled keys in all
> configurations.
That is with --enable-rtems-debug --enable-smp?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
