psxtests/psxkey08 failure
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Mar 10 14:54:48 UTC 2014
On Mar 10, 2014 9:32 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 2014-03-10 15:23, Joel Sherrill wrote:
> > On Mar 10, 2014 8:14 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
> > wrote:
> >  > On 2014-03-10 14:04, Joel Sherrill wrote:
> >  > > On Mar 10, 2014 7:57 AM, Sebastian Huber <sebastian.huber at embedded-brains.de>
> >  > > wrote:
> >  > >  > Hello,
> >  > >  > this test fails now on SIS with debugging enabled:
> >  > >  > *** TEST KEY 08 ***
> >  > >  > Init - Semaphore 1 create - OK
> >  > >  > Init - Semaphore 2 create - OK
> >  > >  > Init - pthread Key create - OK
> > ../../../../../../../rtems/c/src/../../testsuites/psxtests/psxkey08/init.c: 93
> >  > >  > task_id_p
> >  > > Grrr.. I will try to look at it today. Any obvious code conversion mistake?
> >  > I fixed some obvious thread affinity bugs, but this one exceeded my time limit
> >  > for today.
> > What configuration is this failing in? I tried with --enable-rtems-debug and
> > POSIX enabled and disabled.  Both builds ran fine.
> > My tree doesn't have any patches newer than the one where I enabled keys in all
> > configurations.
> That is with --enable-rtems-debug --enable-smp?
Hmmm.. Maybe something broke since my last update. It still works for me. I am at the doctor's office and testing while waiting. I couldn't update git.
I will try again when my tree is up to date but I am not seeing it.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140310/265dad6d/attachment.html>
