[PATCH 02/11] sapi: Add profiling application level support
Mon Mar 10 15:22:51 UTC 2014
On Mon, Mar 10, 2014 at 9:28 AM, Sebastian Huber
>  cpukit/sapi/Makefile.am                            |    3 +
>  cpukit/sapi/include/rtems/profiling.h              |  148 ++++++++++++++++++++
>  cpukit/sapi/include/rtems/test.h                   |  104 ++++++++++++++
>  cpukit/sapi/preinstall.am                          |    4 +
>  cpukit/sapi/src/profilingiterate.c                 |   26 ++++
>  cpukit/sapi/src/profilingreportxml.c               |   82 +++++++++++
>  testsuites/sptests/Makefile.am                     |    1 +
>  testsuites/sptests/configure.ac                    |    1 +
>  testsuites/sptests/spprofiling01/Makefile.am       |   19 +++
>  testsuites/sptests/spprofiling01/init.c            |   63 +++++++++
>  testsuites/sptests/spprofiling01/spprofiling01.doc |   11 ++
>  testsuites/sptests/spprofiling01/spprofiling01.scn |    5 +
>  12 files changed, 467 insertions(+), 0 deletions(-)
>  create mode 100644 cpukit/sapi/include/rtems/profiling.h
>  create mode 100644 cpukit/sapi/include/rtems/test.h
>  create mode 100644 cpukit/sapi/src/profilingiterate.c
>  create mode 100644 cpukit/sapi/src/profilingreportxml.c
>  create mode 100644 testsuites/sptests/spprofiling01/Makefile.am
>  create mode 100644 testsuites/sptests/spprofiling01/init.c
>  create mode 100644 testsuites/sptests/spprofiling01/spprofiling01.doc
>  create mode 100644 testsuites/sptests/spprofiling01/spprofiling01.scn
> diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
> index 63eb605..19f7d87 100644
> --- a/cpukit/sapi/Makefile.am
> +++ b/cpukit/sapi/Makefile.am
> @@ -14,6 +14,7 @@ include_rtems_HEADERS += include/rtems/init.h
>  include_rtems_HEADERS += include/rtems/io.h
>  include_rtems_HEADERS += include/rtems/mptables.h
>  include_rtems_HEADERS += include/rtems/cbs.h
> +include_rtems_HEADERS += include/rtems/profiling.h
>  include_rtems_HEADERS += include/rtems/rbheap.h
>  include_rtems_HEADERS += include/rtems/rbtree.h
>  include_rtems_HEADERS += include/rtems/sptables.h
> @@ -36,6 +37,8 @@ libsapi_a_SOURCES += src/chainsmp.c
>  libsapi_a_SOURCES += src/cpucounterconverter.c
>  libsapi_a_SOURCES += src/delayticks.c
>  libsapi_a_SOURCES += src/delaynano.c
> +libsapi_a_SOURCES += src/profilingiterate.c
> +libsapi_a_SOURCES += src/profilingreportxml.c
>  libsapi_a_CPPFLAGS = $(AM_CPPFLAGS)
>  include $(srcdir)/preinstall.am
> diff --git a/cpukit/sapi/include/rtems/profiling.h b/cpukit/sapi/include/rtems/profiling.h
> new file mode 100644
> index 0000000..ee56a03
> --- /dev/null
> +++ b/cpukit/sapi/include/rtems/profiling.h
> @@ -0,0 +1,148 @@
> + * @file
> + * @ingroup Profiling
> + * @brief Profiling API
> + * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifndef _RTEMS_PROFILING_H
> +#define _RTEMS_PROFILING_H
> +#include <stdint.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @defgroup Profiling Profiling Support
> + * @brief The profiling support offers functions to report profiling
> + * information available in the system.
> + * Profiling support is by default disabled.  It must be enabled via the
> + * configure command line with the <tt>--enable-profiling</tt> option.  In this
> + * case the RTEMS_PROFLING pre-processor symbol is defined and profiling
s/PROFLING/PROFILING
> + * statistics will be gathered during system run-time.  The profiling support
> + * increases the time of critical sections and has some memory overhead.  The
> + * overhead should be acceptable for most applications.  The aim of the
> + * profiling implementation is to be available even for production systems so
> + * that verification is simplified.
> + * Profiling information includes critical timing values such as the maximum
> + * time of disabled thread dispatching which is a measure for the thread
> + * dispatch latency.  On SMP configurations statistics of all SMP locks in the
> + * system are available.
> + * Profiling information can be retrieved via rtems_profiling_iterate() and
> + * reported as an XML dump via rtems_profiling_report_xml().  These functions
> + * are always available, but actual profiling data is only available if enabled
> + * at build configuration time.
> + * @brief Type of profiling data.
> +typedef enum {
> +} rtems_profiling_type;
> + * @brief The profiling data header.
> +typedef struct {
> +   * @brief The profiling data type.
> +  rtems_profiling_type type;
> +} rtems_profiling_header;
> + * @brief Collection of profiling data.
> +typedef union {
> +   * @brief Header to specify the actual profiling data.
> +  rtems_profiling_header header;
> +} rtems_profiling_data;
> + * @brief Visitor function for the profiling iteration.
> + * @param[in, out] arg The visitor argument.
> + * @param[in] data The current profiling data.
> + * @see rtems_profiling_iterate().
> +typedef void (*rtems_profiling_visitor)(
> +  void *arg,
> +  const rtems_profiling_data *data
> + * @brief Iterates through all profiling data of the system.
> + * @param[in] visitor The visitor.
> + * @param[in, out] visitor_arg The visitor argument.
> +void rtems_profiling_iterate(
> +  rtems_profiling_visitor visitor,
> +  void *visitor_arg
> + * @brief Function for formatted output.
> + * @param[in, out] arg Some argument.
> + * @param[in] format The output format as specified by printf().
> + * @param[in] ... More parameters according to format.
> + * @returns As specified by printf().
> + * @see rtems_profiling_report_xml().
> +typedef int (*rtems_profiling_printf)(void *arg, const char *format, ...);
> + * @brief Reports profiling data as XML.
> + * @param[in] name The name of the profiling report.
> + * @param[in] printf_func The formatted output function.
> + * @param[in, out] printf_arg The formatted output function argument.
> + * @param[in] indentation_level The current indentation level.
> + * @param[in] indentation The string used for indentation.
> +int rtems_profiling_report_xml(
> +  const char *name,
> +  rtems_profiling_printf printf_func,
> +  void *printf_arg,
> +  uint32_t indentation_level,
> +  const char *indentation
> +#ifdef __cplusplus
> +#endif /* _RTEMS_PROFILING_H */
> diff --git a/cpukit/sapi/include/rtems/test.h b/cpukit/sapi/include/rtems/test.h
> index 0000000..dde6a7f
> --- /dev/null
> +++ b/cpukit/sapi/include/rtems/test.h
Did you mean to include this test.h file?
> @@ -0,0 +1,104 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#ifndef _RTEMS_TEST_H
> +#define _RTEMS_TEST_H
> +#include <rtems/bspIo.h>
> +#ifdef __cplusplus
> +extern "C" {
> + * @defgroup RTEMSTest Test Support
> + * @brief Test support functions.
> + * @brief Prints a begin of test message.
> + * @param[in] test_name The test name.
> + * @param[in] handler The output handler.
> + * @param[in, out] handler_context The output handler context.
> +void rtems_test_begin_with_plugin(
> +  const char *test_name,
> +  rtems_printk_plugin_t handler,
> +  void *handler_context
> + * @brief Prints a begin of test message using printf().
> +static inline void rtems_test_begin(const char *test_name)
> +  rtems_test_begin(test_name, rtems_printf_plugin, NULL);
> + * @brief Prints a begin of test message using printk().
> +static inline void rtems_test_begink(const char *test_name)
> +  rtems_test_begin(test_name, printk_plugin, NULL);
> + * @brief Prints an end of test message.
> +void rtems_test_end_with_plugin(
> + * @brief Prints an end of test message using printf().
> +static inline void rtems_test_end(const char *test_name)
> +  rtems_test_end(test_name, rtems_printf_plugin, NULL);
> + * @brief Prints an end of test message using printk().
> +static inline void rtems_test_endk(const char *test_name)
> +  rtems_test_end(test_name, printk_plugin, NULL);
> +#ifdef __cplusplus
> +#endif /* _RTEMS_TEST_H */
> diff --git a/cpukit/sapi/preinstall.am b/cpukit/sapi/preinstall.am
> index 79eceef..d05ab25 100644
> --- a/cpukit/sapi/preinstall.am
> +++ b/cpukit/sapi/preinstall.am
> @@ -72,6 +72,10 @@ $(PROJECT_INCLUDE)/rtems/cbs.h: include/rtems/cbs.h $(PROJECT_INCLUDE)/rtems/$(d
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/cbs.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/cbs.h
> +$(PROJECT_INCLUDE)/rtems/profiling.h: include/rtems/profiling.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/profiling.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/profiling.h
>  $(PROJECT_INCLUDE)/rtems/rbheap.h: include/rtems/rbheap.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/rbheap.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/rbheap.h
> diff --git a/cpukit/sapi/src/profilingiterate.c b/cpukit/sapi/src/profilingiterate.c
> index 0000000..e528932
> --- /dev/null
> +++ b/cpukit/sapi/src/profilingiterate.c
> @@ -0,0 +1,26 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/profiling.h>
> +  void *visitor_arg
> diff --git a/cpukit/sapi/src/profilingreportxml.c b/cpukit/sapi/src/profilingreportxml.c
> index 0000000..a80cd16
> --- /dev/null
> +++ b/cpukit/sapi/src/profilingreportxml.c
> @@ -0,0 +1,82 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +typedef struct {
> +  rtems_profiling_printf printf_func;
> +  void *printf_arg;
> +  uint32_t indentation_level;
> +  const char *indentation;
> +  int retval;
> +} context;
> +static void update_retval(context *ctx, int rv)
> +  if (rv > 0 && ctx->retval >= 0) {
> +    ctx->retval += rv;
> +static void indent(context *ctx, uint32_t indentation_level)
> +  uint32_t n = ctx->indentation_level + indentation_level;
> +  uint32_t i;
> +  for (i = 0; i < n; ++i) {
> +    int rv = (*ctx->printf_func)(ctx->printf_arg, "%s", ctx->indentation);
> +    update_retval(ctx, rv);
> +static void report(void *arg, const rtems_profiling_data *data)
> +  context *ctx = arg;
> +  const char *name,
> +  void *printf_arg,
> +  context ctx_instance = {
> +    .printf_func = printf_func,
> +    .printf_arg = printf_arg,
> +    .indentation_level = indentation_level,
> +    .indentation = indentation,
> +    .retval = 0
> +  context *ctx = &ctx_instance;
> +  int rv;
> +  indent(ctx, 0);
> +  rv = (*printf_func)(printf_arg, "<ProfilingReport name=\"%s\">\n", name);
> +  rtems_profiling_iterate(report, ctx);
> +  indent(ctx, 0);
> +  rv = (*printf_func)(printf_arg, "</ProfilingReport>\n");
> +  return ctx->retval;
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 3aa1330..d57ae69 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -30,6 +30,7 @@ SUBDIRS = \
>      spsimplesched03 spnsext01 spedfsched01 spedfsched02 spedfsched03 \
>      spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
>      spregion_err01 sppartition_err01
> +SUBDIRS += spprofiling01
>  SUBDIRS += spcache01
>  SUBDIRS += sptls03
>  SUBDIRS += spcpucounter01
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index fe9f816..5f98ba7 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -36,6 +36,7 @@ AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
>  # Explicitly list all Makefiles here
>  AC_CONFIG_FILES([Makefile
> +spprofiling01/Makefile
>  spcache01/Makefile
>  sptls03/Makefile
>  spcpucounter01/Makefile
> diff --git a/testsuites/sptests/spprofiling01/Makefile.am b/testsuites/sptests/spprofiling01/Makefile.am
> index 0000000..872e50a
> --- /dev/null
> +++ b/testsuites/sptests/spprofiling01/Makefile.am
> @@ -0,0 +1,19 @@
> +rtems_tests_PROGRAMS = spprofiling01
> +spprofiling01_SOURCES = init.c
> +dist_rtems_tests_DATA = spprofiling01.scn spprofiling01.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(spprofiling01_OBJECTS)
> +LINK_LIBS = $(spprofiling01_LDLIBS)
> +spprofiling01$(EXEEXT): $(spprofiling01_OBJECTS) $(spprofiling01_DEPENDENCIES)
> +       @rm -f spprofiling01$(EXEEXT)
> +       $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/spprofiling01/init.c b/testsuites/sptests/spprofiling01/init.c
> index 0000000..a1af66b
> --- /dev/null
> +++ b/testsuites/sptests/spprofiling01/init.c
> @@ -0,0 +1,63 @@
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> +#endif
> +#include <rtems.h>
> +#include <stdio.h>
> +#include "tmacros.h"
> +static void test(void)
> +  rtems_status_code sc;
> +  int rv;
> +  sc = rtems_task_wake_after(3);
> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> +  rv = rtems_profiling_report_xml("X", rtems_printf_plugin, NULL, 1, "  ");
> +  printf("characters produced by rtems_profiling_report_xml(): %i\n", rv);
> +static void Init(rtems_task_argument arg)
> +  puts("\n\n*** TEST SPPROFILING 1 ***");
> +  test();
> +  puts("*** END OF TEST SPPROFILING 1 ***");
> +  rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/sptests/spprofiling01/spprofiling01.doc b/testsuites/sptests/spprofiling01/spprofiling01.doc
> index 0000000..2614c64
> --- /dev/null
> +++ b/testsuites/sptests/spprofiling01/spprofiling01.doc
> @@ -0,0 +1,11 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: spprofiling01
> +directives:
> +  - rtems_profiling_report_xml()
> +concepts:
> +  - Ensure that rtems_profiling_report_xml() yields the expected output.
> diff --git a/testsuites/sptests/spprofiling01/spprofiling01.scn b/testsuites/sptests/spprofiling01/spprofiling01.scn
> index 0000000..2c289db
> --- /dev/null
> +++ b/testsuites/sptests/spprofiling01/spprofiling01.scn
> @@ -0,0 +1,5 @@
> +*** TEST SPPROFILING 1 ***
> +  <ProfilingReport name="X">
> +  </ProfilingReport>
> +characters produced by rtems_profiling_report_xml(): 50
> +*** END OF TEST SPPROFILING 1 ***
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
