[PATCH 06/11] score: Add SMP lock profiling support
Mon Mar 10 16:26:04 UTC 2014
On Mon, Mar 10, 2014 at 9:28 AM, Sebastian Huber
>  c/src/lib/libbsp/sparc/leon3/amba/amba.c      |    3 +-
>  cpukit/libblock/src/diskdevs.c                |    3 +-
>  cpukit/libcsupport/src/sup_fs_location.c      |    2 +-
>  cpukit/libcsupport/src/termios.c              |    2 +-
>  cpukit/posix/src/psignal.c                    |    2 +-
>  cpukit/rtems/include/rtems/rtems/asrimpl.h    |    2 +-
>  cpukit/rtems/include/rtems/rtems/intr.h       |    8 +-
>  cpukit/sapi/src/chainsmp.c                    |    2 +-
>  cpukit/sapi/src/profilingiterate.c            |   60 ++++
>  cpukit/score/Makefile.am                      |    1 +
>  cpukit/score/include/rtems/score/isrlock.h    |   16 +-
>  cpukit/score/include/rtems/score/percpu.h     |   21 ++-
>  cpukit/score/include/rtems/score/smplock.h    |  396 +++++++++++++++++++++++-
>  cpukit/score/src/coretod.c                    |    2 +-
>  cpukit/score/src/percpu.c                     |    3 +-
>  cpukit/score/src/profilingsmplock.c           |   42 +++
>  cpukit/score/src/smp.c                        |    2 +-
>  cpukit/score/src/threaddispatchdisablelevel.c |    2 +-
>  cpukit/score/src/threadhandler.c              |    3 +-
>  testsuites/smptests/smplock01/init.c          |    6 +-
>  testsuites/sptests/sp37/init.c                |    8 +-
>  testsuites/sptests/spcache01/init.c           |    4 +-
>  testsuites/sptests/spnsext01/init.c           |    2 +-
>  testsuites/tmtests/tmcontext01/init.c         |    2 +-
>  24 files changed, 543 insertions(+), 51 deletions(-)
>  create mode 100644 cpukit/score/src/profilingsmplock.c
> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> index 65550cb..01d83cb 100644
> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> @@ -23,7 +23,8 @@
>  struct ambapp_bus ambapp_plb;
> -rtems_interrupt_lock LEON3_IrqCtrl_Lock = RTEMS_INTERRUPT_LOCK_INITIALIZER;
> +rtems_interrupt_lock LEON3_IrqCtrl_Lock =
> +  RTEMS_INTERRUPT_LOCK_INITIALIZER("LEON3 IrqCtrl");
>  /* Pointers to Interrupt Controller configuration registers */
>  volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
> diff --git a/cpukit/libblock/src/diskdevs.c b/cpukit/libblock/src/diskdevs.c
> index 7e01ab3..c057056 100644
> --- a/cpukit/libblock/src/diskdevs.c
> +++ b/cpukit/libblock/src/diskdevs.c
> @@ -57,7 +57,8 @@ static rtems_id diskdevs_mutex;
>  static volatile bool diskdevs_protected;
> -static rtems_interrupt_lock diskdevs_lock = RTEMS_INTERRUPT_LOCK_INITIALIZER;
> +static rtems_interrupt_lock diskdevs_lock =
> +  RTEMS_INTERRUPT_LOCK_INITIALIZER("diskdevs");
>  static rtems_status_code
>  disk_lock(void)
> diff --git a/cpukit/libcsupport/src/sup_fs_location.c b/cpukit/libcsupport/src/sup_fs_location.c
> index 040f8c2..226ba28 100644
> --- a/cpukit/libcsupport/src/sup_fs_location.c
> +++ b/cpukit/libcsupport/src/sup_fs_location.c
> @@ -29,7 +29,7 @@
>  #include <rtems/score/threaddispatch.h>
>  rtems_interrupt_lock rtems_filesystem_mt_entry_lock_control =
> -  RTEMS_INTERRUPT_LOCK_INITIALIZER;
> +  RTEMS_INTERRUPT_LOCK_INITIALIZER("mount table entry");
>  static rtems_filesystem_global_location_t *deferred_released_global_locations;
> diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
> index 65072a0..9582995 100644
> --- a/cpukit/libcsupport/src/termios.c
> +++ b/cpukit/libcsupport/src/termios.c
> @@ -230,7 +230,7 @@ rtems_termios_open (
>      tty->device = *callbacks;
> -    rtems_interrupt_lock_initialize (&tty->interrupt_lock);
> +    rtems_interrupt_lock_initialize (&tty->interrupt_lock, "Termios");
>       * Create I/O tasks
> diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
> index fbe96b3..76f4c11 100644
> --- a/cpukit/posix/src/psignal.c
> +++ b/cpukit/posix/src/psignal.c
> @@ -45,7 +45,7 @@ RTEMS_STATIC_ASSERT(
>  /*** PROCESS WIDE STUFF ****/
> -ISR_lock_Control _POSIX_signals_Lock = ISR_LOCK_INITIALIZER;
> +ISR_lock_Control _POSIX_signals_Lock = ISR_LOCK_INITIALIZER("POSIX signals");
>  sigset_t  _POSIX_signals_Pending;
> diff --git a/cpukit/rtems/include/rtems/rtems/asrimpl.h b/cpukit/rtems/include/rtems/rtems/asrimpl.h
> index d67198f..442ee38 100644
> --- a/cpukit/rtems/include/rtems/rtems/asrimpl.h
> +++ b/cpukit/rtems/include/rtems/rtems/asrimpl.h
> @@ -46,7 +46,7 @@ RTEMS_INLINE_ROUTINE void _ASR_Initialize (
>    asr->signals_posted  = 0;
>    asr->signals_pending = 0;
>    asr->nest_level      = 0;
> -  _ISR_lock_Initialize( &asr->Lock );
> +  _ISR_lock_Initialize( &asr->Lock, "ASR" );
> diff --git a/cpukit/rtems/include/rtems/rtems/intr.h b/cpukit/rtems/include/rtems/rtems/intr.h
> index 04bcb72..01820f8 100644
> --- a/cpukit/rtems/include/rtems/rtems/intr.h
> +++ b/cpukit/rtems/include/rtems/rtems/intr.h
> @@ -167,7 +167,7 @@ typedef ISR_lock_Context rtems_interrupt_lock_context;
>   * @brief Initializer for static initialization of interrupt locks.
> -#define RTEMS_INTERRUPT_LOCK_INITIALIZER ISR_LOCK_INITIALIZER
> +#define RTEMS_INTERRUPT_LOCK_INITIALIZER( _name ) ISR_LOCK_INITIALIZER( _name )
>   * @brief Initializes an interrupt lock.
> @@ -175,9 +175,11 @@ typedef ISR_lock_Context rtems_interrupt_lock_context;
>   * Concurrent initialization leads to unpredictable results.
>   * @param[in,out] _lock The interrupt lock.
> + * @param[in] _name The name for the interrupt lock.  This name must be
> + * persistent throughout the life time of this lock.
> -#define rtems_interrupt_lock_initialize( _lock ) \
> -  _ISR_lock_Initialize( _lock )
> +#define rtems_interrupt_lock_initialize( _lock, _name ) \
> +  _ISR_lock_Initialize( _lock, _name )
>   * @brief Destroys an interrupt lock.
> diff --git a/cpukit/sapi/src/chainsmp.c b/cpukit/sapi/src/chainsmp.c
> index 3f041ba..267d1cd 100644
> --- a/cpukit/sapi/src/chainsmp.c
> +++ b/cpukit/sapi/src/chainsmp.c
> @@ -22,7 +22,7 @@
>  #include <rtems/score/smplock.h>
> -static SMP_lock_Control chain_lock = SMP_LOCK_INITIALIZER;
> +static SMP_lock_Control chain_lock = SMP_LOCK_INITIALIZER("chains");
>  static void chain_acquire( SMP_lock_Context *lock_context )
> diff --git a/cpukit/sapi/src/profilingiterate.c b/cpukit/sapi/src/profilingiterate.c
> index 28c06a4..00a09cd 100644
> --- a/cpukit/sapi/src/profilingiterate.c
> +++ b/cpukit/sapi/src/profilingiterate.c
> @@ -18,6 +18,7 @@
>  #include <rtems/profiling.h>
>  #include <rtems/counter.h>
> +#include <rtems/score/smplock.h>
>  #include <rtems.h>
>  #include <string.h>
> @@ -76,6 +77,64 @@ static void per_cpu_stats_iterate(
>  #endif
> +#ifdef RTEMS_PROFILING
> +RTEMS_STATIC_ASSERT(
> +  RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS
> +    == SMP_LOCK_STATS_CONTENTION_COUNTS,
> +  smp_lock_contention_counts
Is the requirement these two CPP macros be equal documented somewhere?
> +#endif
> +static void smp_lock_stats_iterate(
> +  rtems_profiling_visitor visitor,
> +  void *visitor_arg,
> +  rtems_profiling_data *data
> +  SMP_lock_Stats_iteration_context iteration_context;
> +  SMP_lock_Stats snapshot;
> +  char name[64];
> +  memset(data, 0, sizeof(*data));
> +  data->header.type = RTEMS_PROFILING_SMP_LOCK;
> +  _SMP_lock_Stats_iteration_start(&iteration_context);
> +  while (
> +    _SMP_lock_Stats_iteration_next(
> +      &iteration_context,
> +      &snapshot,
> +      &name[0],
> +      sizeof(name)
> +    rtems_profiling_smp_lock *smp_lock_data = &data->smp_lock;
> +    smp_lock_data->name = name;
> +    smp_lock_data->max_section_time =
> +      rtems_counter_ticks_to_nanoseconds(snapshot.max_section_time);
> +    smp_lock_data->max_acquire_time =
> +      rtems_counter_ticks_to_nanoseconds(snapshot.max_acquire_time);
> +    smp_lock_data->usage_count = snapshot.usage_count;
> +    smp_lock_data->total_section_time =
> +      rtems_counter_ticks_to_nanoseconds(snapshot.total_section_time);
> +    memcpy(
> +      &smp_lock_data->contention_counts[0],
> +      &snapshot.contention_counts[0],
> +      sizeof(smp_lock_data->contention_counts)
> +    (*visitor)(visitor_arg, data);
> +  _SMP_lock_Stats_iteration_stop(&iteration_context);
> +#else
> +  (void) visitor;
> +  (void) visitor_arg;
> +  (void) data;
> +#endif
>  void rtems_profiling_iterate(
>    void *visitor_arg
> @@ -84,4 +143,5 @@ void rtems_profiling_iterate(
>    rtems_profiling_data data;
>    per_cpu_stats_iterate(visitor, visitor_arg, &data);
> +  smp_lock_stats_iterate(visitor, visitor_arg, &data);
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index f3f53a9..d747c91 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -123,6 +123,7 @@ libscore_a_SOURCES += src/mpci.c src/objectmp.c src/threadmp.c
>  endif
>  if HAS_SMP
> +libscore_a_SOURCES += src/profilingsmplock.c
>  libscore_a_SOURCES += src/schedulerprioritysmp.c
>  libscore_a_SOURCES += src/schedulersimplesmp.c
>  libscore_a_SOURCES += src/schedulersmpstartidle.c
> diff --git a/cpukit/score/include/rtems/score/isrlock.h b/cpukit/score/include/rtems/score/isrlock.h
> index 27e4aad..b12b174 100644
> --- a/cpukit/score/include/rtems/score/isrlock.h
> +++ b/cpukit/score/include/rtems/score/isrlock.h
> @@ -71,10 +71,10 @@ typedef struct {
>   * @brief Initializer for static initialization of ISR locks.
>  #if defined( RTEMS_SMP )
> -  #define ISR_LOCK_INITIALIZER \
> -    { SMP_LOCK_INITIALIZER }
> +  #define ISR_LOCK_INITIALIZER( name ) \
> +    { SMP_LOCK_INITIALIZER( name ) }
>  #else
>  #endif
> @@ -84,13 +84,19 @@ typedef struct {
>   * @param[in,out] lock The ISR lock control.
> + * @param[in] name The name for the ISR lock.  This name must be persistent
> + * throughout the life time of this lock.
> -static inline void _ISR_lock_Initialize( ISR_lock_Control *lock )
> +static inline void _ISR_lock_Initialize(
> +  ISR_lock_Control *lock,
> +  const char *name
> -  _SMP_lock_Initialize( &lock->lock );
> +  _SMP_lock_Initialize( &lock->lock, name );
>  #else
>    (void) lock;
> +  (void) name;
>  #endif
> diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
> index e8f3370..c279ee3 100644
> --- a/cpukit/score/include/rtems/score/percpu.h
> +++ b/cpukit/score/include/rtems/score/percpu.h
> @@ -40,7 +40,11 @@ extern "C" {
>     * used in assembler code to easily get the per-CPU control for a particular
>     * processor.
> -  #define PER_CPU_CONTROL_SIZE_LOG2 7
> +  #if defined( RTEMS_PROFILING )
> +    #define PER_CPU_CONTROL_SIZE_LOG2 8
> +  #else
> +    #define PER_CPU_CONTROL_SIZE_LOG2 7
> +  #endif
>    #define PER_CPU_CONTROL_SIZE ( 1 << PER_CPU_CONTROL_SIZE_LOG2 )
>  #endif
> @@ -287,6 +291,11 @@ typedef struct {
>      SMP_ticket_lock_Control Lock;
> +     * @brief Lock statistics context for the per-CPU lock.
> +    SMP_lock_Stats_context Lock_stats_context;
>       * @brief Context for the Giant lock acquire and release pair of this
>       * processor.
> @@ -333,7 +342,10 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
>  #define _Per_CPU_Acquire( per_cpu ) \
> -  _SMP_ticket_lock_Acquire( &( per_cpu )->Lock )
> +  _SMP_ticket_lock_Acquire( \
> +    &( per_cpu )->Lock, \
> +    &( per_cpu )->Lock_stats_context \
>  #else
>    do { \
> @@ -343,7 +355,10 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
>  #define _Per_CPU_Release( per_cpu ) \
> -  _SMP_ticket_lock_Release( &( per_cpu )->Lock )
> +  _SMP_ticket_lock_Release( \
>  #else
>    do { \
> diff --git a/cpukit/score/include/rtems/score/smplock.h b/cpukit/score/include/rtems/score/smplock.h
> index 288fd45..6b98f1c 100644
> --- a/cpukit/score/include/rtems/score/smplock.h
> +++ b/cpukit/score/include/rtems/score/smplock.h
> @@ -27,6 +27,11 @@
>  #include <rtems/score/atomic.h>
>  #include <rtems/score/isrlevel.h>
> +#if defined( RTEMS_PROFILING )
> +#include <rtems/score/chainimpl.h>
> +#include <string.h>
> +#endif
>  #ifdef __cplusplus
>  extern "C" {
>  #endif /* __cplusplus */
> @@ -50,18 +55,159 @@ extern "C" {
> + * @brief Count of lock contention counters for lock statistics.
> +#define SMP_LOCK_STATS_CONTENTION_COUNTS 4
> + * @brief SMP lock statistics.
> + * The lock acquire attempt instant is the point in time right after the
> + * interrupt disable action in the lock acquire sequence.
> + * The lock acquire instant is the point in time right after the lock
> + * acquisition.  This is the begin of the critical section code execution.
> + * The lock release instant is the point in time right before the interrupt
> + * enable action in the lock release sequence.
> + * The lock section time is the time elapsed between the lock acquire instant
> + * and the lock release instant.
> + * The lock acquire time is the time elapsed between the lock acquire attempt
> + * instant and the lock acquire instant.
> +typedef struct {
> +   * @brief Node for SMP lock statistics chain.
> +  Chain_Node Node;
> +   * @brief The maximum lock section time in CPU counter ticks.
> +  CPU_Counter_ticks max_section_time;
> +   * @brief The maximum lock acquire time in CPU counter ticks.
> +  CPU_Counter_ticks max_acquire_time;
> +   * @brief The count of lock uses.
> +   * This value may overflow.
> +  uint64_t usage_count;
> +   * @brief The counts of lock acquire operations by contention.
> +   * The contention count for index N corresponds to a lock acquire attempt
> +   * with an initial queue length of N.  The last index corresponds to all
> +   * lock acquire attempts with an initial queue length greater than or equal
> +   * to SMP_LOCK_STATS_CONTENTION_COUNTS minus one.
> +   * The values may overflow.
> +  uint64_t contention_counts[SMP_LOCK_STATS_CONTENTION_COUNTS];
> +   * @brief Total lock section time in CPU counter ticks.
> +   * The average lock section time is the total section time divided by the
> +   * lock usage count.
> +  uint64_t total_section_time;
> +   * @brief The lock name.
> +  const char *name;
> +#endif /* defined( RTEMS_PROFILING ) */
> +} SMP_lock_Stats;
> + * @brief Local context for SMP lock statistics.
> +typedef struct {
> +   * @brief The last lock acquire instant in CPU counter ticks.
> +   * This value is used to measure the lock section time.
> +  CPU_Counter_ticks acquire_instant;
> +#endif
> +} SMP_lock_Stats_context;
> + * @brief SMP lock statistics initializer for static initialization.
> +#define SMP_LOCK_STATS_INITIALIZER( name ) \
> +  { { NULL, NULL }, 0, 0, 0, { 0, 0, 0, 0 }, 0, name }
> +#else
> +#endif
> + * @brief Initializes an SMP lock statistics block.
> + * @param[in, out] stats The SMP lock statistics block.
> + * @param[in] name The name for the SMP lock statistics.  This name must be
> + * persistent throughout the life time of this statistics block.
> +static inline void _SMP_lock_Stats_initialize(
> +  SMP_lock_Stats *stats,
> +  const char *name
> +  SMP_lock_Stats init = SMP_LOCK_STATS_INITIALIZER( name );
> +  *stats = init;
> + * @brief Destroys an SMP lock statistics block.
> + * @param[in,out] stats The SMP lock statistics block.
> +static inline void _SMP_lock_Stats_destroy( SMP_lock_Stats *stats );
> + * @param[in] stats_context The SMP lock statistics context.
> +static inline void _SMP_lock_Stats_release_update(
> +  const SMP_lock_Stats_context *stats_context
>   * @brief SMP ticket lock control.
>  typedef struct {
>    Atomic_Uint next_ticket;
>    Atomic_Uint now_serving;
> +  SMP_lock_Stats Stats;
>  } SMP_ticket_lock_Control;
>   * @brief SMP ticket lock control initializer for static initialization.
> -#define SMP_TICKET_LOCK_INITIALIZER \
> -  { ATOMIC_INITIALIZER_UINT( 0U ), ATOMIC_INITIALIZER_UINT( 0U ) }
> +#define SMP_TICKET_LOCK_INITIALIZER( name ) \
> +    ATOMIC_INITIALIZER_UINT( 0U ), \
> +    SMP_LOCK_STATS_INITIALIZER( name ) \
>   * @brief Initializes an SMP ticket lock.
> @@ -69,11 +215,17 @@ typedef struct {
>   * @param[in,out] lock The SMP ticket lock control.
> + * @param[in] name The name for the SMP ticket lock.  This name must be
> -static inline void _SMP_ticket_lock_Initialize( SMP_ticket_lock_Control *lock )
> +static inline void _SMP_ticket_lock_Initialize(
> +  SMP_ticket_lock_Control *lock,
> +  const char *name
>    _Atomic_Init_uint( &lock->next_ticket, 0U );
>    _Atomic_Init_uint( &lock->now_serving, 0U );
> +  _SMP_lock_Stats_initialize( &lock->Stats, name );
> @@ -85,7 +237,7 @@ static inline void _SMP_ticket_lock_Initialize( SMP_ticket_lock_Control *lock )
>  static inline void _SMP_ticket_lock_Destroy( SMP_ticket_lock_Control *lock )
> -  (void) lock;
> +  _SMP_lock_Stats_destroy( &lock->Stats );
> @@ -96,30 +248,81 @@ static inline void _SMP_ticket_lock_Destroy( SMP_ticket_lock_Control *lock )
>   * the SMP ticket lock.
> + * @param[out] stats_context The SMP lock statistics context.
> -static inline void _SMP_ticket_lock_Acquire( SMP_ticket_lock_Control *lock )
> +static inline void _SMP_ticket_lock_Acquire(
> +  SMP_lock_Stats_context *stats_context
> -  unsigned int my_ticket =
> -    _Atomic_Fetch_add_uint( &lock->next_ticket, 1U, ATOMIC_ORDER_RELAXED );
> +  unsigned int my_ticket;
>    unsigned int now_serving;
> -  do {
> -    now_serving =
> -      _Atomic_Load_uint( &lock->now_serving, ATOMIC_ORDER_ACQUIRE );
> -  } while ( now_serving != my_ticket );
> +  SMP_lock_Stats *stats = &lock->Stats;
> +  CPU_Counter_ticks first;
> +  CPU_Counter_ticks second;
> +  CPU_Counter_ticks delta;
> +  unsigned int initial_queue_length;
> +  first = _CPU_Counter_read();
> +#endif
> +  my_ticket =
> +    _Atomic_Fetch_add_uint( &lock->next_ticket, 1U, ATOMIC_ORDER_RELAXED );
> +  now_serving =
> +    _Atomic_Load_uint( &lock->now_serving, ATOMIC_ORDER_ACQUIRE );
> +  initial_queue_length = my_ticket - now_serving;
> +  if ( initial_queue_length > 0 ) {
> +#endif
> +    do {
> +      now_serving =
> +    } while ( now_serving != my_ticket );
> +  second = _CPU_Counter_read();
> +  stats_context->acquire_instant = second;
> +  delta = _CPU_Counter_difference( second, first );
> +  ++stats->usage_count;
> +  if ( stats->max_acquire_time < delta ) {
> +    stats->max_acquire_time = delta;
> +  if ( initial_queue_length >= SMP_LOCK_STATS_CONTENTION_COUNTS ) {
> +    initial_queue_length = SMP_LOCK_STATS_CONTENTION_COUNTS - 1;
> +  ++stats->contention_counts[initial_queue_length];
> +#else
> +  (void) stats_context;
> +#endif
>   * @brief Releases an SMP ticket lock.
> -static inline void _SMP_ticket_lock_Release( SMP_ticket_lock_Control *lock )
> +static inline void _SMP_ticket_lock_Release(
>    unsigned int current_ticket =
>      _Atomic_Load_uint( &lock->now_serving, ATOMIC_ORDER_RELAXED );
>    unsigned int next_ticket = current_ticket + 1U;
> +  _SMP_lock_Stats_release_update( &lock->Stats, stats_context );
>    _Atomic_Store_uint( &lock->now_serving, next_ticket, ATOMIC_ORDER_RELEASE );
> @@ -135,12 +338,13 @@ typedef struct {
>  typedef struct {
>    ISR_Level isr_level;
> +  SMP_lock_Stats_context Stats_context;
>  } SMP_lock_Context;
>   * @brief SMP lock control initializer for static initialization.
> -#define SMP_LOCK_INITIALIZER { SMP_TICKET_LOCK_INITIALIZER }
> +#define SMP_LOCK_INITIALIZER( name ) { SMP_TICKET_LOCK_INITIALIZER( name ) }
>   * @brief Initializes an SMP lock.
> @@ -148,10 +352,15 @@ typedef struct {
>   * @param[in,out] lock The SMP lock control.
> -static inline void _SMP_lock_Initialize( SMP_lock_Control *lock )
> +static inline void _SMP_lock_Initialize(
> +  SMP_lock_Control *lock,
> +  const char *name
> -  _SMP_ticket_lock_Initialize( &lock->ticket_lock );
> +  _SMP_ticket_lock_Initialize( &lock->ticket_lock, name );
> @@ -183,7 +392,7 @@ static inline void _SMP_lock_Acquire(
>    (void) context;
> -  _SMP_ticket_lock_Acquire( &lock->ticket_lock );
> +  _SMP_ticket_lock_Acquire( &lock->ticket_lock, &context->Stats_context );
> @@ -199,7 +408,7 @@ static inline void _SMP_lock_Release(
>    (void) context;
> -  _SMP_ticket_lock_Release( &lock->ticket_lock );
> +  _SMP_ticket_lock_Release( &lock->ticket_lock, &context->Stats_context );
> @@ -234,6 +443,159 @@ static inline void _SMP_lock_Release_and_ISR_enable(
>    _ISR_Enable_without_giant( context->isr_level );
> +typedef struct {
> +  SMP_lock_Control Lock;
> +  Chain_Control Stats_chain;
> +  Chain_Control Iterator_chain;
> +} SMP_lock_Stats_control;
> +typedef struct {
> +  Chain_Node Node;
> +  SMP_lock_Stats *current;
> +} SMP_lock_Stats_iteration_context;
> +extern SMP_lock_Stats_control _SMP_lock_Stats_control;
> +static inline void _SMP_lock_Stats_iteration_start(
> +  SMP_lock_Stats_iteration_context *iteration_context
> +  SMP_lock_Stats_control *control = &_SMP_lock_Stats_control;
> +  SMP_lock_Context lock_context;
> +  _SMP_lock_ISR_disable_and_acquire( &control->Lock, &lock_context );
> +  _Chain_Append_unprotected(
> +    &control->Iterator_chain,
> +    &iteration_context->Node
> +  iteration_context->current =
> +    (SMP_lock_Stats *) _Chain_First( &control->Stats_chain );
> +  _SMP_lock_Release_and_ISR_enable( &control->Lock, &lock_context );
> +static inline bool _SMP_lock_Stats_iteration_next(
> +  SMP_lock_Stats_iteration_context *iteration_context,
> +  SMP_lock_Stats *snapshot,
> +  char *name,
> +  size_t name_size
> +  bool valid;
> +  current = iteration_context->current;
> +  if ( !_Chain_Is_tail( &control->Stats_chain, &current->Node ) ) {
> +    size_t name_len = strlen(current->name);
> +    valid = true;
> +    iteration_context->current = (SMP_lock_Stats *)
> +      _Chain_Next( &current->Node );
> +    *snapshot = *current;
> +    snapshot->name = name;
> +    if ( name_len >= name_size ) {
> +      name_len = name_size - 1;
> +    name[name_len] = '\0';
> +    memcpy(name, current->name, name_len);
> +  } else {
> +    valid = false;
> +  return valid;
> +static inline void _SMP_lock_Stats_iteration_stop(
> +  _Chain_Extract_unprotected( &iteration_context->Node );
> +#endif
> +  if ( !_Chain_Is_node_off_chain( &stats->Node ) ) {
> +    SMP_lock_Stats_iteration_context *iteration_context;
> +    SMP_lock_Stats_iteration_context *iteration_context_tail;
> +    SMP_lock_Stats *next_stats;
> +    next_stats = (SMP_lock_Stats *) _Chain_Next( &stats->Node );
> +    _Chain_Extract_unprotected( &stats->Node );
> +    iteration_context = (SMP_lock_Stats_iteration_context *)
> +      _Chain_First( &control->Iterator_chain );
> +    iteration_context_tail = (SMP_lock_Stats_iteration_context *)
> +      _Chain_Tail( &control->Iterator_chain );
> +    while ( iteration_context != iteration_context_tail ) {
> +      if ( iteration_context->current == stats ) {
> +        iteration_context->current = next_stats;
> +        _Chain_Next( &iteration_context->Node );
> +#else
> +  (void) stats;
> +#endif
> +  CPU_Counter_ticks first = stats_context->acquire_instant;
> +  CPU_Counter_ticks second = _CPU_Counter_read();
> +  CPU_Counter_ticks delta = _CPU_Counter_difference( second, first );
> +  stats->total_section_time += delta;
> +  if ( stats->max_section_time < delta ) {
> +    stats->max_section_time = delta;
> +    if ( _Chain_Is_node_off_chain( &stats->Node ) ) {
> +      _Chain_Append_unprotected( &control->Stats_chain, &stats->Node );
> +#else
> +  (void) stats;
> +#endif
>  #ifdef __cplusplus
> diff --git a/cpukit/score/src/coretod.c b/cpukit/score/src/coretod.c
> index 25edef0..a6c85f1 100644
> --- a/cpukit/score/src/coretod.c
> +++ b/cpukit/score/src/coretod.c
> @@ -29,7 +29,7 @@ void _TOD_Handler_initialization(void)
>    TOD_Control *tod = &_TOD;
> -  _ISR_lock_Initialize( &tod->lock );
> +  _ISR_lock_Initialize( &tod->lock, "TOD" );
>    _Timestamp_Set( &tod->now, TOD_SECONDS_1970_THROUGH_1988, 0 );
> diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
> index 50e5239..6d31ed4 100644
> --- a/cpukit/score/src/percpu.c
> +++ b/cpukit/score/src/percpu.c
> @@ -26,7 +26,8 @@
>  #if defined(RTEMS_SMP)
> -static SMP_lock_Control _Per_CPU_State_lock = SMP_LOCK_INITIALIZER;
> +static SMP_lock_Control _Per_CPU_State_lock =
> +  SMP_LOCK_INITIALIZER("per-CPU state");
>  static void _Per_CPU_State_busy_wait(
>    const Per_CPU_Control *per_cpu,
> diff --git a/cpukit/score/src/profilingsmplock.c b/cpukit/score/src/profilingsmplock.c
> new file mode 100644
> index 0000000..4ab761b
> --- /dev/null
> +++ b/cpukit/score/src/profilingsmplock.c
> @@ -0,0 +1,42 @@
> + * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +SMP_lock_Stats_control _SMP_lock_Stats_control = {
> +  .Lock = {
> +    .ticket_lock = {
> +      .next_ticket = ATOMIC_INITIALIZER_UINT( 0U ),
> +      .now_serving = ATOMIC_INITIALIZER_UINT( 0U ),
> +      .Stats = {
> +        .Node = CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(
> +          &_SMP_lock_Stats_control.Stats_chain
> +        .name = "SMP lock stats"
> +  .Stats_chain = CHAIN_INITIALIZER_ONE_NODE(
> +    &_SMP_lock_Stats_control.Lock.ticket_lock.Stats.Node
> +  .Iterator_chain = CHAIN_INITIALIZER_EMPTY(
> +    _SMP_lock_Stats_control.Iterator_chain
> diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
> index 40d2ac3..389a4d6 100644
> --- a/cpukit/score/src/smp.c
> +++ b/cpukit/score/src/smp.c
> @@ -32,7 +32,7 @@ void _SMP_Handler_initialize( void )
>    for ( cpu = 0 ; cpu < max_cpus; ++cpu ) {
>      Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
> -    _SMP_ticket_lock_Initialize( &per_cpu->Lock );
> +    _SMP_ticket_lock_Initialize( &per_cpu->Lock, "per-CPU" );
> diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
> index ab004c1..abd8c97 100644
> --- a/cpukit/score/src/threaddispatchdisablelevel.c
> +++ b/cpukit/score/src/threaddispatchdisablelevel.c
> @@ -29,7 +29,7 @@ typedef struct {
>  } Giant_Control;
>  static Giant_Control _Giant = {
> -  .lock = SMP_LOCK_INITIALIZER,
> +  .lock = SMP_LOCK_INITIALIZER("Giant"),
>    .owner_cpu = NO_OWNER_CPU,
>    .nest_level = 0
> diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
> index a85cebe..752b2d5 100644
> --- a/cpukit/score/src/threadhandler.c
> +++ b/cpukit/score/src/threadhandler.c
> @@ -56,7 +56,8 @@
>      bool doCons = false;
> -      static SMP_lock_Control constructor_lock = SMP_LOCK_INITIALIZER;
> +      static SMP_lock_Control constructor_lock =
> +        SMP_LOCK_INITIALIZER("constructor");
> diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/smplock01/init.c
> index 7c536c3..a445c84 100644
> --- a/testsuites/smptests/smplock01/init.c
> +++ b/testsuites/smptests/smplock01/init.c
> @@ -48,7 +48,7 @@ typedef struct {
>  static global_context context = {
>    .state = ATOMIC_INITIALIZER_UINT(INITIAL),
>    .barrier = SMP_BARRIER_CONTROL_INITIALIZER,
> +  .lock = SMP_LOCK_INITIALIZER("global")
>  static const char *test_names[TEST_COUNT] = {
> @@ -141,7 +141,7 @@ static void test_2_body(
>    SMP_lock_Control lock;
> -  _SMP_lock_Initialize(&lock);
> +  _SMP_lock_Initialize(&lock, "local");
>    while (assert_state(ctx, START_TEST)) {
>      _SMP_lock_Acquire(&lock, &lock_context);
> @@ -166,7 +166,7 @@ static void test_3_body(
> diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
> index 4a3e08c..1097dc8 100644
> --- a/testsuites/sptests/sp37/init.c
> +++ b/testsuites/sptests/sp37/init.c
> @@ -160,11 +160,11 @@ static void test_isr_level( void )
>  static void test_isr_locks( void )
>    ISR_Level normal_interrupt_level = _ISR_Get_level();
> -  ISR_lock_Control initialized = ISR_LOCK_INITIALIZER;
> +  ISR_lock_Control initialized = ISR_LOCK_INITIALIZER("test");
>    ISR_lock_Control lock;
>    ISR_lock_Context lock_context;
> -  _ISR_lock_Initialize( &lock );
> +  _ISR_lock_Initialize( &lock, "test" );
>    rtems_test_assert( memcmp( &lock, &initialized, sizeof( lock ) ) == 0 );
>    _ISR_lock_ISR_disable_and_acquire( &lock, &lock_context );
> @@ -197,11 +197,11 @@ static rtems_mode get_interrupt_level( void )
>  static void test_interrupt_locks( void )
>    rtems_mode normal_interrupt_level = get_interrupt_level();
> -  rtems_interrupt_lock initialized = RTEMS_INTERRUPT_LOCK_INITIALIZER;
> +  rtems_interrupt_lock initialized = RTEMS_INTERRUPT_LOCK_INITIALIZER("test");
>    rtems_interrupt_lock lock;
>    rtems_interrupt_lock_context lock_context;
> -  rtems_interrupt_lock_initialize( &lock );
> +  rtems_interrupt_lock_initialize( &lock, "test" );
>    rtems_interrupt_lock_acquire( &lock, &lock_context );
> diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
> index 4c0c3c3..92ea4ec 100644
> --- a/testsuites/sptests/spcache01/init.c
> +++ b/testsuites/sptests/spcache01/init.c
> @@ -48,7 +48,7 @@ static void test_data_flush_and_invalidate(void)
>      printf("data cache flush and invalidate test\n");
> -    rtems_interrupt_lock_initialize(&lock);
> +    rtems_interrupt_lock_initialize(&lock, "test");
>      rtems_interrupt_lock_acquire(&lock, &lock_context);
>      for (i = 0; i < n; ++i) {
> @@ -168,7 +168,7 @@ static void test_timing(void)
>    uint32_t cache_level;
>    size_t cache_size;
>    printf(
>      "data cache line size %zi bytes\n"
> diff --git a/testsuites/sptests/spnsext01/init.c b/testsuites/sptests/spnsext01/init.c
> index b445679..2ffd237 100644
> --- a/testsuites/sptests/spnsext01/init.c
> +++ b/testsuites/sptests/spnsext01/init.c
> @@ -51,7 +51,7 @@ static rtems_task Init(rtems_task_argument argument)
>    n = (3 * n) / 2;
>    sc = rtems_clock_get_uptime(&uptime);
>    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
> index bd047a2..aa7bef9 100644
> --- a/testsuites/tmtests/tmcontext01/init.c
> +++ b/testsuites/tmtests/tmcontext01/init.c
> @@ -138,7 +138,7 @@ static void test_by_function_level(int fl, bool dirty)
>    uint64_t q3;
>    uint64_t max;
>    for (s = 0; s < SAMPLES; ++s) {
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
