[PATCH 04/11] sapi: Add SMP lock profiling app. level data
Tue Mar 11 08:13:15 UTC 2014
On 2014-03-10 16:52, Gedare Bloom wrote:
> On Mon, Mar 10, 2014 at 9:28 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>>   cpukit/sapi/include/rtems/profiling.h |   88 ++++++++++++++++++++++++++++++++-
>>   cpukit/sapi/src/profilingreportxml.c  |   70 ++++++++++++++++++++++++++
>>   2 files changed, 157 insertions(+), 1 deletions(-)
>> diff --git a/cpukit/sapi/include/rtems/profiling.h b/cpukit/sapi/include/rtems/profiling.h
>> index ecb3ff7..2a66015 100644
>> --- a/cpukit/sapi/include/rtems/profiling.h
>> +++ b/cpukit/sapi/include/rtems/profiling.h
>> @@ -66,7 +66,14 @@ typedef enum {
>>      * @see rtems_profiling_per_cpu.
>> -  RTEMS_PROFILING_PER_CPU
>> +  RTEMS_PROFILING_PER_CPU,
>> +   * @brief Type of SMP lock profiling data.
>> +   * @see rtems_profiling_smp_lock.
>> +  RTEMS_PROFILING_SMP_LOCK
>>   } rtems_profiling_type;
>> @@ -152,6 +159,80 @@ typedef struct {
>>   } rtems_profiling_per_cpu;
>> + * @brief Count of lock contention counters for SMP lock profiling.
>> +#define RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS 4
>> + * @brief SMP lock profiling data.
>> + * The lock acquire attempt instant is the point in time right after the
>> + * interrupt disable action in the lock acquire sequence.
>> + * The lock acquire instant is the point in time right after the lock
>> + * acquisition.  This is the begin of the critical section code execution.
>> + * The lock release instant is the point in time right before the interrupt
>> + * enable action in the lock release sequence.
>> + * The lock section time is the time elapsed between the lock acquire instant
>> + * and the lock release instant.
>> + * The lock acquire time is the time elapsed between the lock acquire attempt
>> + * instant and the lock acquire instant.
> Move this last point up to where you define lock acquire attempt
> instant and lock acquire instant.
Ok.
>> +typedef struct {
>> +   * @brief The profiling data header.
>> +  rtems_profiling_header header;
>> +   * @brief The lock name.
>> +  const char *name;
>> +   * @brief The maximum lock section time in nanoseconds.
>> +  uint32_t max_section_time;
>> +   * @brief The maximum lock acquire time in nanoseconds.
>> +  uint32_t max_acquire_time;
> Any possible issues with 32-bit values here?
It would be a major bug if you spend 4 seconds in an SMP lock.
>> +   * @brief The count of lock uses.
>> +   * This value may overflow.
>> +  uint64_t usage_count;
>> +   * @brief Total lock section time in nanoseconds.
>> +   * The average lock section time is the total section time divided by the
>> +   * lock usage count.
>> +  uint64_t total_section_time;
>> +   * @brief The counts of lock acquire operations by contention.
>> +   * The contention count for index N corresponds to a lock acquire attempt
>> +   * with an initial queue length of N.  The last index corresponds to all
>> +   * lock acquire attempts with an initial queue length greater than or equal
>> +   * to RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS minus one.
>> +   * The values may overflow.
>> +  uint64_t contention_counts[RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS];
> contention_counts[0] is when there is no contention hence negligible
> acquire_time?
Yes, optimally you get the high numbers for contention_counts[0].  In case of
the Giant lock it looks like this (smptests/smpload01):
     <SMPLockProfilingReport name="Giant">
       <MaxSectionTime unit="ns">233360</MaxSectionTime>
       <MaxAcquireTime unit="ns">192160</MaxAcquireTime>
       <UsageCount>9281</UsageCount>
       <TotalSectionTime unit="ns">464815740</TotalSectionTime>
       <ContentionCount initialQueueLength="0">2480</ContentionCount>
       <ContentionCount initialQueueLength="1">3893</ContentionCount>
       <ContentionCount initialQueueLength="2">2201</ContentionCount>
       <ContentionCount initialQueueLength="3">707</ContentionCount>
     </SMPLockProfilingReport>
> Is total_acquire_time not feasible or interesting to profile?
Hm, a good question.  I think the contention counter and the total acquire time
are a measure for lock contention.  The ratio of total_acquire_time /
total_section_time might be interesting.
Should I add it?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
