[rtems commit] POSIX keys now enabled in all configurations.
Tue Mar 11 12:18:52 UTC 2014
On 2014-03-07 20:13, Joel Sherrill wrote:
> diff --git a/testsuites/psxtests/psxkey07/init.c b/testsuites/psxtests/psxkey07/init.c
> index e911dc7..b2aabb7 100644
> --- a/testsuites/psxtests/psxkey07/init.c
> +++ b/testsuites/psxtests/psxkey07/init.c
> @@ -1,6 +1,6 @@
>    *  Copyright (c) 2012 Zhongwei Yao.
> - *  COPYRIGHT (c) 1989-2012.
> + *  COPYRIGHT (c) 1989-2014.
>    *  On-Line Applications Research Corporation (OAR).
>    *  The license and distribution terms for this file may be
> @@ -19,8 +19,8 @@
>   #include "pmacros.h"
>   /* forward declarations to avoid warnings */
> -void *POSIX_Init(void *argument);
> -void *Test_Thread(void *argument);
> +rtems_task Init(rtems_task_argument argument);
> +rtems_task Test_Thread(rtems_task_argument argument);
>   pthread_key_t Key;
>   int created_thread_count, setted_thread_count, got_thread_count;
> @@ -28,17 +28,15 @@ int all_thread_created;
>   pthread_mutex_t mutex1, mutex2;
>   pthread_cond_t create_condition_var, set_condition_var;
> -void *Test_Thread(
> -  void *argument
>     int sc;
>     int *value_p, *value_p2;
>     value_p = malloc( sizeof( int ) );
> -  //printf( "Test_Thread%d  - Key pthread_setspecific - OK\n", (int)pthread_self() );
>     sc = pthread_setspecific( Key, value_p );
>     rtems_test_assert( !sc );
>     pthread_mutex_lock( &mutex1 );
>     ++setted_thread_count;
>     pthread_cond_signal( &set_condition_var );
> @@ -52,21 +50,20 @@ void *Test_Thread(
>       pthread_cond_wait( &create_condition_var, &mutex2 );
>     pthread_mutex_unlock( &mutex2 );
> -  //printf( "Test_Thread%d  - Key pthread_getspecific - OK\n", (int)pthread_self() );
>     value_p2 = pthread_getspecific( Key );
>     rtems_test_assert( value_p == value_p2 );
>     ++got_thread_count;
> -  return NULL;
> +  rtems_task_delete( RTEMS_SELF );
> -void *POSIX_Init(
> -  void *ignored
> -  pthread_t        *thread_p;
> -  int              sc;
> -  struct timespec  delay_request;
> +  rtems_id          *thread_p;
> +  rtems_status_code  rc;
> +  int                sc;
> +  struct timespec    delay_request;
>     all_thread_created = 0;
>     puts( "\n\n*** TEST KEY 07 ***" );
> @@ -74,12 +71,15 @@ void *POSIX_Init(
>     puts( "Init - Mutex 1 create - OK" );
>     sc = pthread_mutex_init( &mutex1, NULL );
>     puts( "Init - Mutex 2 create - OK" );
>     sc = pthread_mutex_init( &mutex2, NULL );
>     puts( "Init - Condition variable 1 create - OK" );
>     sc = pthread_cond_init( &create_condition_var, NULL );
>     puts( "Init - Condition variable 2 create - OK" );
>     sc = pthread_cond_init( &set_condition_var, NULL );
> @@ -88,34 +88,54 @@ void *POSIX_Init(
>     sc = pthread_key_create( &Key, NULL );
> -  for( ; ; )
> -      thread_p = malloc( sizeof( pthread_t ) );
> -      rtems_test_assert( thread_p );
> -      pthread_mutex_lock( &mutex1 );
> -      sc = pthread_create( thread_p, NULL, Test_Thread, NULL );
> -      rtems_test_assert( ( sc == 0 ) || ( sc == EAGAIN ) );
> -       * check if return is EAGAIN, it means RTEMS Workspace RAM
> -       * have been exhausted.
> -      if ( sc == EAGAIN )
> -          pthread_mutex_unlock( &mutex1 );
> -          break;
> -      ++created_thread_count;
> -       * wait for test thread set key, the while loop here is used to
> -       * avoid suprious wakeup.
> -      while( created_thread_count > setted_thread_count )
> -        pthread_cond_wait( &set_condition_var, &mutex1 );
> +  for ( ; ; ) {
> +    thread_p = malloc( sizeof( rtems_id ) );
> +    rtems_test_assert( thread_p );
> +    pthread_mutex_lock( &mutex1 );
> +    rc = rtems_task_create(
> +      rtems_build_name( 'T', 'E', 'S', 'T' ),
> +      1,
> +      RTEMS_MINIMUM_STACK_SIZE,
> +      RTEMS_DEFAULT_MODES,
> +      RTEMS_DEFAULT_ATTRIBUTES,
> +      thread_p
> +      ( rc == RTEMS_SUCCESSFUL ) || ( rc == RTEMS_UNSATISFIED )
> +    if ( rc == RTEMS_SUCCESSFUL ) {
> +      rc = rtems_task_start( *thread_p, Test_Thread, 0 );
> +      rtems_test_assert( rc == RTEMS_SUCCESSFUL );
> +     * check if return is EAGAIN, it means RTEMS Workspace RAM
> +     * have been exhausted.
> +    if ( rc == RTEMS_UNSATISFIED ) {
> +      break;
> -  printf( "Init - %d pthreads have been created - OK\n", created_thread_count );
> -  printf( "Init - %d pthreads have been setted key data - OK\n", setted_thread_count );
> +    ++created_thread_count;
> +     * wait for test thread set key, the while loop here is used to
> +     * avoid suprious wakeup.
> +    while( created_thread_count > setted_thread_count )
> +      pthread_cond_wait( &set_condition_var, &mutex1 );
> +    pthread_mutex_unlock( &mutex1 );
> +  printf(
> +    "Init - %d pthreads have been created - OK\n"
> +    "Init - %d pthreads have been setted key data - OK\n",
> +    created_thread_count,
> +    setted_thread_count
>     rtems_test_assert( created_thread_count == setted_thread_count );
Why did you convert this test to Classic API tasks?  It uses POSIX condition
variables and mutexes.  I would change it back.
The following patch is necessary if we want to keep the current version:
@@ -104,6 +116,7 @@ rtems_task Init(rtems_task_argument argument)
      rtems_test_assert(
+        || ( rc == RTEMS_TOO_MANY )
@@ -112,10 +125,10 @@ rtems_task Init(rtems_task_argument argument)
+     * check if return is not successful, it means RTEMS Workspace RAM
-    if ( rc == RTEMS_UNSATISFIED ) {
+    if ( rc != RTEMS_SUCCESSFUL ) {
        break;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
