psxtests/psxkey08 failure
Tue Mar 11 12:24:59 UTC 2014
Ok, I had a closer look at the test since it failed now on another simulator.
This test is broken:
   puts( "Init - pthread Key create - OK" );
   sc = pthread_key_create( &Key, NULL );
   rtems_test_assert( !sc );
   for ( ; ; ) {
     task_id_p = malloc( sizeof( rtems_id ) );
     rtems_test_assert( task_id_p );
     sc = rtems_task_create(
       rtems_build_name('T','A',created_task_count, ' '),
       1,
       RTEMS_MINIMUM_STACK_SIZE,
       RTEMS_DEFAULT_MODES,
       RTEMS_DEFAULT_ATTRIBUTES,
       task_id_p
     rtems_test_assert(
       (sc == RTEMS_UNSATISFIED) ||
       (sc == RTEMS_TOO_MANY) ||
       (sc == RTEMS_SUCCESSFUL)
      * when return is RTEMS_TOO_MANY or RTEMS_UNSATISFIED, there is not
      * enough source to create task.
     if ( (sc == RTEMS_TOO_MANY) || (sc == RTEMS_UNSATISFIED) ) {
       break;
     ++created_task_count;
     sc = rtems_task_start( *task_id_p,  test_task, 0 );
     rtems_test_assert( sc == RTEMS_SUCCESSFUL );
     sc = rtems_semaphore_obtain( sema1, RTEMS_WAIT, 0 );
We have a unified work area.  So depending on the memory layout the
or the
       1,
       task_id_p
     rtems_test_assert(
may fail.  If we are unlucky then we hit the first case and the test fails.
Why do we malloc the task_id_p?  Its a memory leak and it is used only locally?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
