[PATCH 06/11] score: Add SMP lock profiling support
Tue Mar 11 13:46:46 UTC 2014
 c/src/lib/libbsp/sparc/leon3/amba/amba.c      |    3 +-
 cpukit/libblock/src/diskdevs.c                |    3 +-
 cpukit/libcsupport/src/sup_fs_location.c      |    2 +-
 cpukit/libcsupport/src/termios.c              |    2 +-
 cpukit/posix/src/psignal.c                    |    2 +-
 cpukit/rtems/include/rtems/rtems/asrimpl.h    |    2 +-
 cpukit/rtems/include/rtems/rtems/intr.h       |    8 +-
 cpukit/sapi/src/chainsmp.c                    |    2 +-
 cpukit/sapi/src/profilingiterate.c            |   62 ++++
 cpukit/score/Makefile.am                      |    1 +
 cpukit/score/include/rtems/score/isrlock.h    |   16 +-
 cpukit/score/include/rtems/score/percpu.h     |   21 ++-
 cpukit/score/include/rtems/score/smplock.h    |  409 ++++++++++++++++++++++++-
 cpukit/score/src/coretod.c                    |    2 +-
 cpukit/score/src/percpu.c                     |    3 +-
 cpukit/score/src/profilingsmplock.c           |   42 +++
 cpukit/score/src/smp.c                        |    2 +-
 cpukit/score/src/threaddispatchdisablelevel.c |    2 +-
 cpukit/score/src/threadhandler.c              |    3 +-
 testsuites/smptests/smplock01/init.c          |    6 +-
 testsuites/sptests/sp37/init.c                |    8 +-
 testsuites/sptests/spcache01/init.c           |    4 +-
 testsuites/sptests/spnsext01/init.c           |    2 +-
 testsuites/tmtests/tmcontext01/init.c         |    2 +-
 24 files changed, 558 insertions(+), 51 deletions(-)
 create mode 100644 cpukit/score/src/profilingsmplock.c
diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
index 65550cb..01d83cb 100644
--- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
+++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
@@ -23,7 +23,8 @@
 struct ambapp_bus ambapp_plb;
-rtems_interrupt_lock LEON3_IrqCtrl_Lock = RTEMS_INTERRUPT_LOCK_INITIALIZER;
+rtems_interrupt_lock LEON3_IrqCtrl_Lock =
+  RTEMS_INTERRUPT_LOCK_INITIALIZER("LEON3 IrqCtrl");
 /* Pointers to Interrupt Controller configuration registers */
 volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
diff --git a/cpukit/libblock/src/diskdevs.c b/cpukit/libblock/src/diskdevs.c
index 7e01ab3..c057056 100644
--- a/cpukit/libblock/src/diskdevs.c
+++ b/cpukit/libblock/src/diskdevs.c
@@ -57,7 +57,8 @@ static rtems_id diskdevs_mutex;
 static volatile bool diskdevs_protected;
-static rtems_interrupt_lock diskdevs_lock = RTEMS_INTERRUPT_LOCK_INITIALIZER;
+static rtems_interrupt_lock diskdevs_lock =
+  RTEMS_INTERRUPT_LOCK_INITIALIZER("diskdevs");
 static rtems_status_code
 disk_lock(void)
diff --git a/cpukit/libcsupport/src/sup_fs_location.c b/cpukit/libcsupport/src/sup_fs_location.c
index 040f8c2..226ba28 100644
--- a/cpukit/libcsupport/src/sup_fs_location.c
+++ b/cpukit/libcsupport/src/sup_fs_location.c
@@ -29,7 +29,7 @@
 rtems_interrupt_lock rtems_filesystem_mt_entry_lock_control =
-  RTEMS_INTERRUPT_LOCK_INITIALIZER;
+  RTEMS_INTERRUPT_LOCK_INITIALIZER("mount table entry");
 static rtems_filesystem_global_location_t *deferred_released_global_locations;
diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
index 65072a0..9582995 100644
--- a/cpukit/libcsupport/src/termios.c
+++ b/cpukit/libcsupport/src/termios.c
@@ -230,7 +230,7 @@ rtems_termios_open (
     tty->device = *callbacks;
-    rtems_interrupt_lock_initialize (&tty->interrupt_lock);
+    rtems_interrupt_lock_initialize (&tty->interrupt_lock, "Termios");
      * Create I/O tasks
diff --git a/cpukit/posix/src/psignal.c b/cpukit/posix/src/psignal.c
index fbe96b3..76f4c11 100644
--- a/cpukit/posix/src/psignal.c
+++ b/cpukit/posix/src/psignal.c
@@ -45,7 +45,7 @@ RTEMS_STATIC_ASSERT(
 /*** PROCESS WIDE STUFF ****/
-ISR_lock_Control _POSIX_signals_Lock = ISR_LOCK_INITIALIZER;
+ISR_lock_Control _POSIX_signals_Lock = ISR_LOCK_INITIALIZER("POSIX signals");
 sigset_t  _POSIX_signals_Pending;
diff --git a/cpukit/rtems/include/rtems/rtems/asrimpl.h b/cpukit/rtems/include/rtems/rtems/asrimpl.h
index d67198f..442ee38 100644
--- a/cpukit/rtems/include/rtems/rtems/asrimpl.h
+++ b/cpukit/rtems/include/rtems/rtems/asrimpl.h
@@ -46,7 +46,7 @@ RTEMS_INLINE_ROUTINE void _ASR_Initialize (
   asr->signals_posted  = 0;
   asr->signals_pending = 0;
   asr->nest_level      = 0;
-  _ISR_lock_Initialize( &asr->Lock );
+  _ISR_lock_Initialize( &asr->Lock, "ASR" );
diff --git a/cpukit/rtems/include/rtems/rtems/intr.h b/cpukit/rtems/include/rtems/rtems/intr.h
index 04bcb72..01820f8 100644
--- a/cpukit/rtems/include/rtems/rtems/intr.h
+++ b/cpukit/rtems/include/rtems/rtems/intr.h
@@ -167,7 +167,7 @@ typedef ISR_lock_Context rtems_interrupt_lock_context;
  * @brief Initializer for static initialization of interrupt locks.
-#define RTEMS_INTERRUPT_LOCK_INITIALIZER ISR_LOCK_INITIALIZER
+#define RTEMS_INTERRUPT_LOCK_INITIALIZER( _name ) ISR_LOCK_INITIALIZER( _name )
  * @brief Initializes an interrupt lock.
@@ -175,9 +175,11 @@ typedef ISR_lock_Context rtems_interrupt_lock_context;
  * Concurrent initialization leads to unpredictable results.
  * @param[in,out] _lock The interrupt lock.
+ * @param[in] _name The name for the interrupt lock.  This name must be
+ * persistent throughout the life time of this lock.
-#define rtems_interrupt_lock_initialize( _lock ) \
-  _ISR_lock_Initialize( _lock )
+#define rtems_interrupt_lock_initialize( _lock, _name ) \
+  _ISR_lock_Initialize( _lock, _name )
  * @brief Destroys an interrupt lock.
diff --git a/cpukit/sapi/src/chainsmp.c b/cpukit/sapi/src/chainsmp.c
index 3f041ba..267d1cd 100644
--- a/cpukit/sapi/src/chainsmp.c
+++ b/cpukit/sapi/src/chainsmp.c
@@ -22,7 +22,7 @@
 #include <rtems/score/smplock.h>
-static SMP_lock_Control chain_lock = SMP_LOCK_INITIALIZER;
+static SMP_lock_Control chain_lock = SMP_LOCK_INITIALIZER("chains");
 static void chain_acquire( SMP_lock_Context *lock_context )
diff --git a/cpukit/sapi/src/profilingiterate.c b/cpukit/sapi/src/profilingiterate.c
index 28c06a4..956dbde 100644
--- a/cpukit/sapi/src/profilingiterate.c
+++ b/cpukit/sapi/src/profilingiterate.c
@@ -18,6 +18,7 @@
 #include <rtems/profiling.h>
 #include <rtems/counter.h>
+#include <rtems/score/smplock.h>
@@ -76,6 +77,66 @@ static void per_cpu_stats_iterate(
 #endif
+#if defined(RTEMS_PROFILING) && defined(RTEMS_SMP)
+RTEMS_STATIC_ASSERT(
+  RTEMS_PROFILING_SMP_LOCK_CONTENTION_COUNTS
+    == SMP_LOCK_STATS_CONTENTION_COUNTS,
+  smp_lock_contention_counts
+#endif
+static void smp_lock_stats_iterate(
+  rtems_profiling_visitor visitor,
+  void *visitor_arg,
+  rtems_profiling_data *data
+  SMP_lock_Stats_iteration_context iteration_context;
+  SMP_lock_Stats snapshot;
+  char name[64];
+  memset(data, 0, sizeof(*data));
+  data->header.type = RTEMS_PROFILING_SMP_LOCK;
+  _SMP_lock_Stats_iteration_start(&iteration_context);
+  while (
+    _SMP_lock_Stats_iteration_next(
+      &iteration_context,
+      &snapshot,
+      &name[0],
+      sizeof(name)
+    rtems_profiling_smp_lock *smp_lock_data = &data->smp_lock;
+    smp_lock_data->name = name;
+    smp_lock_data->max_acquire_time =
+      rtems_counter_ticks_to_nanoseconds(snapshot.max_acquire_time);
+    smp_lock_data->max_section_time =
+      rtems_counter_ticks_to_nanoseconds(snapshot.max_section_time);
+    smp_lock_data->usage_count = snapshot.usage_count;
+    smp_lock_data->total_acquire_time =
+      rtems_counter_ticks_to_nanoseconds(snapshot.total_acquire_time);
+    smp_lock_data->total_section_time =
+      rtems_counter_ticks_to_nanoseconds(snapshot.total_section_time);
+    memcpy(
+      &smp_lock_data->contention_counts[0],
+      &snapshot.contention_counts[0],
+      sizeof(smp_lock_data->contention_counts)
+    (*visitor)(visitor_arg, data);
+  _SMP_lock_Stats_iteration_stop(&iteration_context);
+#else
+  (void) visitor;
+  (void) visitor_arg;
+  (void) data;
+#endif
 void rtems_profiling_iterate(
   void *visitor_arg
@@ -84,4 +145,5 @@ void rtems_profiling_iterate(
   rtems_profiling_data data;
   per_cpu_stats_iterate(visitor, visitor_arg, &data);
+  smp_lock_stats_iterate(visitor, visitor_arg, &data);
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index f3f53a9..d747c91 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -123,6 +123,7 @@ libscore_a_SOURCES += src/mpci.c src/objectmp.c src/threadmp.c
 endif
 if HAS_SMP
+libscore_a_SOURCES += src/profilingsmplock.c
 libscore_a_SOURCES += src/schedulerprioritysmp.c
 libscore_a_SOURCES += src/schedulersimplesmp.c
 libscore_a_SOURCES += src/schedulersmpstartidle.c
diff --git a/cpukit/score/include/rtems/score/isrlock.h b/cpukit/score/include/rtems/score/isrlock.h
index 27e4aad..b12b174 100644
--- a/cpukit/score/include/rtems/score/isrlock.h
+++ b/cpukit/score/include/rtems/score/isrlock.h
@@ -71,10 +71,10 @@ typedef struct {
  * @brief Initializer for static initialization of ISR locks.
 #if defined( RTEMS_SMP )
-  #define ISR_LOCK_INITIALIZER \
-    { SMP_LOCK_INITIALIZER }
+  #define ISR_LOCK_INITIALIZER( name ) \
+    { SMP_LOCK_INITIALIZER( name ) }
 #else
 #endif
@@ -84,13 +84,19 @@ typedef struct {
  * @param[in,out] lock The ISR lock control.
+ * @param[in] name The name for the ISR lock.  This name must be persistent
+ * throughout the life time of this lock.
-static inline void _ISR_lock_Initialize( ISR_lock_Control *lock )
+static inline void _ISR_lock_Initialize(
+  ISR_lock_Control *lock,
+  const char *name
-  _SMP_lock_Initialize( &lock->lock );
+  _SMP_lock_Initialize( &lock->lock, name );
 #else
   (void) lock;
+  (void) name;
 #endif
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index e8f3370..c279ee3 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -40,7 +40,11 @@ extern "C" {
    * used in assembler code to easily get the per-CPU control for a particular
    * processor.
-  #define PER_CPU_CONTROL_SIZE_LOG2 7
+  #if defined( RTEMS_PROFILING )
+    #define PER_CPU_CONTROL_SIZE_LOG2 8
+  #else
+    #define PER_CPU_CONTROL_SIZE_LOG2 7
+  #endif
   #define PER_CPU_CONTROL_SIZE ( 1 << PER_CPU_CONTROL_SIZE_LOG2 )
 #endif
@@ -287,6 +291,11 @@ typedef struct {
     SMP_ticket_lock_Control Lock;
+     * @brief Lock statistics context for the per-CPU lock.
+    SMP_lock_Stats_context Lock_stats_context;
      * @brief Context for the Giant lock acquire and release pair of this
      * processor.
@@ -333,7 +342,10 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
 #define _Per_CPU_Acquire( per_cpu ) \
-  _SMP_ticket_lock_Acquire( &( per_cpu )->Lock )
+  _SMP_ticket_lock_Acquire( \
+    &( per_cpu )->Lock, \
+    &( per_cpu )->Lock_stats_context \
 #else
   do { \
@@ -343,7 +355,10 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
 #define _Per_CPU_Release( per_cpu ) \
-  _SMP_ticket_lock_Release( &( per_cpu )->Lock )
+  _SMP_ticket_lock_Release( \
 #else
   do { \
diff --git a/cpukit/score/include/rtems/score/smplock.h b/cpukit/score/include/rtems/score/smplock.h
index 288fd45..fc92f28 100644
--- a/cpukit/score/include/rtems/score/smplock.h
+++ b/cpukit/score/include/rtems/score/smplock.h
@@ -27,6 +27,11 @@
 #include <rtems/score/atomic.h>
 #include <rtems/score/isrlevel.h>
+#if defined( RTEMS_PROFILING )
+#include <rtems/score/chainimpl.h>
+#include <string.h>
+#endif
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
@@ -50,18 +55,170 @@ extern "C" {
+ * @brief Count of lock contention counters for lock statistics.
+#define SMP_LOCK_STATS_CONTENTION_COUNTS 4
+ * @brief SMP lock statistics.
+ * The lock acquire attempt instant is the point in time right after the
+ * interrupt disable action in the lock acquire sequence.
+ * The lock acquire instant is the point in time right after the lock
+ * acquisition.  This is the begin of the critical section code execution.
+ * The lock release instant is the point in time right before the interrupt
+ * enable action in the lock release sequence.
+ * The lock section time is the time elapsed between the lock acquire instant
+ * and the lock release instant.
+ * The lock acquire time is the time elapsed between the lock acquire attempt
+ * instant and the lock acquire instant.
+typedef struct {
+   * @brief Node for SMP lock statistics chain.
+  Chain_Node Node;
+   * @brief The maximum lock acquire time in CPU counter ticks.
+  CPU_Counter_ticks max_acquire_time;
+   * @brief The maximum lock section time in CPU counter ticks.
+  CPU_Counter_ticks max_section_time;
+   * @brief The count of lock uses.
+   * This value may overflow.
+  uint64_t usage_count;
+   * @brief Total lock acquire time in nanoseconds.
+   * The average lock acquire time is the total acquire time divided by the
+   * lock usage count.  The ration of the total section and total acquire times
+   * gives a measure for the lock contention.
+  uint64_t total_acquire_time;
+   * @brief The counts of lock acquire operations by contention.
+   * The contention count for index N corresponds to a lock acquire attempt
+   * with an initial queue length of N.  The last index corresponds to all
+   * lock acquire attempts with an initial queue length greater than or equal
+   * to SMP_LOCK_STATS_CONTENTION_COUNTS minus one.
+   * The values may overflow.
+  uint64_t contention_counts[SMP_LOCK_STATS_CONTENTION_COUNTS];
+   * @brief Total lock section time in CPU counter ticks.
+   * The average lock section time is the total section time divided by the
+  uint64_t total_section_time;
+   * @brief The lock name.
+  const char *name;
+#endif /* defined( RTEMS_PROFILING ) */
+} SMP_lock_Stats;
+ * @brief Local context for SMP lock statistics.
+typedef struct {
+   * @brief The last lock acquire instant in CPU counter ticks.
+   * This value is used to measure the lock section time.
+  CPU_Counter_ticks acquire_instant;
+#endif
+} SMP_lock_Stats_context;
+ * @brief SMP lock statistics initializer for static initialization.
+#define SMP_LOCK_STATS_INITIALIZER( name ) \
+  { { NULL, NULL }, 0, 0, 0, 0, { 0, 0, 0, 0 }, 0, name }
+#else
+#endif
+ * @brief Initializes an SMP lock statistics block.
+ * @param[in, out] stats The SMP lock statistics block.
+ * @param[in] name The name for the SMP lock statistics.  This name must be
+ * persistent throughout the life time of this statistics block.
+static inline void _SMP_lock_Stats_initialize(
+  SMP_lock_Stats *stats,
+  const char *name
+  SMP_lock_Stats init = SMP_LOCK_STATS_INITIALIZER( name );
+  *stats = init;
+ * @brief Destroys an SMP lock statistics block.
+ * @param[in,out] stats The SMP lock statistics block.
+static inline void _SMP_lock_Stats_destroy( SMP_lock_Stats *stats );
+ * @param[in] stats_context The SMP lock statistics context.
+static inline void _SMP_lock_Stats_release_update(
+  const SMP_lock_Stats_context *stats_context
  * @brief SMP ticket lock control.
 typedef struct {
   Atomic_Uint next_ticket;
   Atomic_Uint now_serving;
+  SMP_lock_Stats Stats;
 } SMP_ticket_lock_Control;
  * @brief SMP ticket lock control initializer for static initialization.
-#define SMP_TICKET_LOCK_INITIALIZER \
-  { ATOMIC_INITIALIZER_UINT( 0U ), ATOMIC_INITIALIZER_UINT( 0U ) }
+#define SMP_TICKET_LOCK_INITIALIZER( name ) \
+    ATOMIC_INITIALIZER_UINT( 0U ), \
+    SMP_LOCK_STATS_INITIALIZER( name ) \
  * @brief Initializes an SMP ticket lock.
@@ -69,11 +226,17 @@ typedef struct {
  * @param[in,out] lock The SMP ticket lock control.
+ * @param[in] name The name for the SMP ticket lock.  This name must be
-static inline void _SMP_ticket_lock_Initialize( SMP_ticket_lock_Control *lock )
+static inline void _SMP_ticket_lock_Initialize(
+  SMP_ticket_lock_Control *lock,
+  const char *name
   _Atomic_Init_uint( &lock->next_ticket, 0U );
   _Atomic_Init_uint( &lock->now_serving, 0U );
+  _SMP_lock_Stats_initialize( &lock->Stats, name );
@@ -85,7 +248,7 @@ static inline void _SMP_ticket_lock_Initialize( SMP_ticket_lock_Control *lock )
 static inline void _SMP_ticket_lock_Destroy( SMP_ticket_lock_Control *lock )
-  (void) lock;
+  _SMP_lock_Stats_destroy( &lock->Stats );
@@ -96,30 +259,83 @@ static inline void _SMP_ticket_lock_Destroy( SMP_ticket_lock_Control *lock )
  * the SMP ticket lock.
+ * @param[out] stats_context The SMP lock statistics context.
-static inline void _SMP_ticket_lock_Acquire( SMP_ticket_lock_Control *lock )
+static inline void _SMP_ticket_lock_Acquire(
+  SMP_lock_Stats_context *stats_context
-  unsigned int my_ticket =
-    _Atomic_Fetch_add_uint( &lock->next_ticket, 1U, ATOMIC_ORDER_RELAXED );
+  unsigned int my_ticket;
   unsigned int now_serving;
-  do {
-    now_serving =
-      _Atomic_Load_uint( &lock->now_serving, ATOMIC_ORDER_ACQUIRE );
-  } while ( now_serving != my_ticket );
+  SMP_lock_Stats *stats = &lock->Stats;
+  CPU_Counter_ticks first;
+  CPU_Counter_ticks second;
+  CPU_Counter_ticks delta;
+  unsigned int initial_queue_length;
+  first = _CPU_Counter_read();
+#endif
+  my_ticket =
+    _Atomic_Fetch_add_uint( &lock->next_ticket, 1U, ATOMIC_ORDER_RELAXED );
+  now_serving =
+    _Atomic_Load_uint( &lock->now_serving, ATOMIC_ORDER_ACQUIRE );
+  initial_queue_length = my_ticket - now_serving;
+  if ( initial_queue_length > 0 ) {
+#endif
+    do {
+      now_serving =
+    } while ( now_serving != my_ticket );
+  second = _CPU_Counter_read();
+  stats_context->acquire_instant = second;
+  delta = _CPU_Counter_difference( second, first );
+  ++stats->usage_count;
+  stats->total_acquire_time += delta;
+  if ( stats->max_acquire_time < delta ) {
+    stats->max_acquire_time = delta;
+  if ( initial_queue_length >= SMP_LOCK_STATS_CONTENTION_COUNTS ) {
+    initial_queue_length = SMP_LOCK_STATS_CONTENTION_COUNTS - 1;
+  ++stats->contention_counts[initial_queue_length];
+#else
+  (void) stats_context;
+#endif
  * @brief Releases an SMP ticket lock.
-static inline void _SMP_ticket_lock_Release( SMP_ticket_lock_Control *lock )
+static inline void _SMP_ticket_lock_Release(
   unsigned int current_ticket =
     _Atomic_Load_uint( &lock->now_serving, ATOMIC_ORDER_RELAXED );
   unsigned int next_ticket = current_ticket + 1U;
+  _SMP_lock_Stats_release_update( &lock->Stats, stats_context );
   _Atomic_Store_uint( &lock->now_serving, next_ticket, ATOMIC_ORDER_RELEASE );
@@ -135,12 +351,13 @@ typedef struct {
 typedef struct {
   ISR_Level isr_level;
+  SMP_lock_Stats_context Stats_context;
 } SMP_lock_Context;
  * @brief SMP lock control initializer for static initialization.
-#define SMP_LOCK_INITIALIZER { SMP_TICKET_LOCK_INITIALIZER }
+#define SMP_LOCK_INITIALIZER( name ) { SMP_TICKET_LOCK_INITIALIZER( name ) }
  * @brief Initializes an SMP lock.
@@ -148,10 +365,15 @@ typedef struct {
  * @param[in,out] lock The SMP lock control.
-static inline void _SMP_lock_Initialize( SMP_lock_Control *lock )
+static inline void _SMP_lock_Initialize(
+  SMP_lock_Control *lock,
+  const char *name
-  _SMP_ticket_lock_Initialize( &lock->ticket_lock );
+  _SMP_ticket_lock_Initialize( &lock->ticket_lock, name );
@@ -183,7 +405,7 @@ static inline void _SMP_lock_Acquire(
   (void) context;
-  _SMP_ticket_lock_Acquire( &lock->ticket_lock );
+  _SMP_ticket_lock_Acquire( &lock->ticket_lock, &context->Stats_context );
@@ -199,7 +421,7 @@ static inline void _SMP_lock_Release(
   (void) context;
-  _SMP_ticket_lock_Release( &lock->ticket_lock );
+  _SMP_ticket_lock_Release( &lock->ticket_lock, &context->Stats_context );
@@ -234,6 +456,159 @@ static inline void _SMP_lock_Release_and_ISR_enable(
   _ISR_Enable_without_giant( context->isr_level );
+typedef struct {
+  SMP_lock_Control Lock;
+  Chain_Control Stats_chain;
+  Chain_Control Iterator_chain;
+} SMP_lock_Stats_control;
+typedef struct {
+  Chain_Node Node;
+  SMP_lock_Stats *current;
+} SMP_lock_Stats_iteration_context;
+extern SMP_lock_Stats_control _SMP_lock_Stats_control;
+static inline void _SMP_lock_Stats_iteration_start(
+  SMP_lock_Stats_iteration_context *iteration_context
+  SMP_lock_Stats_control *control = &_SMP_lock_Stats_control;
+  SMP_lock_Context lock_context;
+  _SMP_lock_ISR_disable_and_acquire( &control->Lock, &lock_context );
+  _Chain_Append_unprotected(
+    &control->Iterator_chain,
+    &iteration_context->Node
+  iteration_context->current =
+    (SMP_lock_Stats *) _Chain_First( &control->Stats_chain );
+  _SMP_lock_Release_and_ISR_enable( &control->Lock, &lock_context );
+static inline bool _SMP_lock_Stats_iteration_next(
+  SMP_lock_Stats_iteration_context *iteration_context,
+  SMP_lock_Stats *snapshot,
+  char *name,
+  size_t name_size
+  bool valid;
+  current = iteration_context->current;
+  if ( !_Chain_Is_tail( &control->Stats_chain, &current->Node ) ) {
+    size_t name_len = strlen(current->name);
+    valid = true;
+    iteration_context->current = (SMP_lock_Stats *)
+      _Chain_Next( &current->Node );
+    *snapshot = *current;
+    snapshot->name = name;
+    if ( name_len >= name_size ) {
+      name_len = name_size - 1;
+    name[name_len] = '\0';
+    memcpy(name, current->name, name_len);
+  } else {
+    valid = false;
+  return valid;
+static inline void _SMP_lock_Stats_iteration_stop(
+  _Chain_Extract_unprotected( &iteration_context->Node );
+#endif
+  if ( !_Chain_Is_node_off_chain( &stats->Node ) ) {
+    SMP_lock_Stats_iteration_context *iteration_context;
+    SMP_lock_Stats_iteration_context *iteration_context_tail;
+    SMP_lock_Stats *next_stats;
+    next_stats = (SMP_lock_Stats *) _Chain_Next( &stats->Node );
+    _Chain_Extract_unprotected( &stats->Node );
+    iteration_context = (SMP_lock_Stats_iteration_context *)
+      _Chain_First( &control->Iterator_chain );
+    iteration_context_tail = (SMP_lock_Stats_iteration_context *)
+      _Chain_Tail( &control->Iterator_chain );
+    while ( iteration_context != iteration_context_tail ) {
+      if ( iteration_context->current == stats ) {
+        iteration_context->current = next_stats;
+        _Chain_Next( &iteration_context->Node );
+#else
+  (void) stats;
+#endif
+  CPU_Counter_ticks first = stats_context->acquire_instant;
+  CPU_Counter_ticks second = _CPU_Counter_read();
+  CPU_Counter_ticks delta = _CPU_Counter_difference( second, first );
+  stats->total_section_time += delta;
+  if ( stats->max_section_time < delta ) {
+    stats->max_section_time = delta;
+    if ( _Chain_Is_node_off_chain( &stats->Node ) ) {
+      _Chain_Append_unprotected( &control->Stats_chain, &stats->Node );
+#else
+  (void) stats;
+#endif
 #ifdef __cplusplus
diff --git a/cpukit/score/src/coretod.c b/cpukit/score/src/coretod.c
index 25edef0..a6c85f1 100644
--- a/cpukit/score/src/coretod.c
+++ b/cpukit/score/src/coretod.c
@@ -29,7 +29,7 @@ void _TOD_Handler_initialization(void)
   TOD_Control *tod = &_TOD;
-  _ISR_lock_Initialize( &tod->lock );
+  _ISR_lock_Initialize( &tod->lock, "TOD" );
   _Timestamp_Set( &tod->now, TOD_SECONDS_1970_THROUGH_1988, 0 );
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 50e5239..6d31ed4 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -26,7 +26,8 @@
 #if defined(RTEMS_SMP)
-static SMP_lock_Control _Per_CPU_State_lock = SMP_LOCK_INITIALIZER;
+static SMP_lock_Control _Per_CPU_State_lock =
+  SMP_LOCK_INITIALIZER("per-CPU state");
 static void _Per_CPU_State_busy_wait(
   const Per_CPU_Control *per_cpu,
diff --git a/cpukit/score/src/profilingsmplock.c b/cpukit/score/src/profilingsmplock.c
new file mode 100644
index 0000000..4ab761b
--- /dev/null
+++ b/cpukit/score/src/profilingsmplock.c
@@ -0,0 +1,42 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+SMP_lock_Stats_control _SMP_lock_Stats_control = {
+  .Lock = {
+    .ticket_lock = {
+      .next_ticket = ATOMIC_INITIALIZER_UINT( 0U ),
+      .now_serving = ATOMIC_INITIALIZER_UINT( 0U ),
+      .Stats = {
+        .Node = CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(
+          &_SMP_lock_Stats_control.Stats_chain
+        .name = "SMP lock stats"
+  .Stats_chain = CHAIN_INITIALIZER_ONE_NODE(
+    &_SMP_lock_Stats_control.Lock.ticket_lock.Stats.Node
+  .Iterator_chain = CHAIN_INITIALIZER_EMPTY(
+    _SMP_lock_Stats_control.Iterator_chain
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 40d2ac3..389a4d6 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -32,7 +32,7 @@ void _SMP_Handler_initialize( void )
   for ( cpu = 0 ; cpu < max_cpus; ++cpu ) {
     Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
-    _SMP_ticket_lock_Initialize( &per_cpu->Lock );
+    _SMP_ticket_lock_Initialize( &per_cpu->Lock, "per-CPU" );
diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
index ab004c1..abd8c97 100644
--- a/cpukit/score/src/threaddispatchdisablelevel.c
+++ b/cpukit/score/src/threaddispatchdisablelevel.c
@@ -29,7 +29,7 @@ typedef struct {
 } Giant_Control;
 static Giant_Control _Giant = {
-  .lock = SMP_LOCK_INITIALIZER,
+  .lock = SMP_LOCK_INITIALIZER("Giant"),
   .owner_cpu = NO_OWNER_CPU,
   .nest_level = 0
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index a85cebe..752b2d5 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -56,7 +56,8 @@
     bool doCons = false;
-      static SMP_lock_Control constructor_lock = SMP_LOCK_INITIALIZER;
+      static SMP_lock_Control constructor_lock =
+        SMP_LOCK_INITIALIZER("constructor");
diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/smplock01/init.c
index 7c536c3..a445c84 100644
--- a/testsuites/smptests/smplock01/init.c
+++ b/testsuites/smptests/smplock01/init.c
@@ -48,7 +48,7 @@ typedef struct {
 static global_context context = {
   .state = ATOMIC_INITIALIZER_UINT(INITIAL),
   .barrier = SMP_BARRIER_CONTROL_INITIALIZER,
+  .lock = SMP_LOCK_INITIALIZER("global")
 static const char *test_names[TEST_COUNT] = {
@@ -141,7 +141,7 @@ static void test_2_body(
   SMP_lock_Control lock;
-  _SMP_lock_Initialize(&lock);
+  _SMP_lock_Initialize(&lock, "local");
   while (assert_state(ctx, START_TEST)) {
     _SMP_lock_Acquire(&lock, &lock_context);
@@ -166,7 +166,7 @@ static void test_3_body(
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 4a3e08c..1097dc8 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -160,11 +160,11 @@ static void test_isr_level( void )
 static void test_isr_locks( void )
   ISR_Level normal_interrupt_level = _ISR_Get_level();
-  ISR_lock_Control initialized = ISR_LOCK_INITIALIZER;
+  ISR_lock_Control initialized = ISR_LOCK_INITIALIZER("test");
   ISR_lock_Control lock;
   ISR_lock_Context lock_context;
-  _ISR_lock_Initialize( &lock );
+  _ISR_lock_Initialize( &lock, "test" );
   rtems_test_assert( memcmp( &lock, &initialized, sizeof( lock ) ) == 0 );
   _ISR_lock_ISR_disable_and_acquire( &lock, &lock_context );
@@ -197,11 +197,11 @@ static rtems_mode get_interrupt_level( void )
 static void test_interrupt_locks( void )
   rtems_mode normal_interrupt_level = get_interrupt_level();
-  rtems_interrupt_lock initialized = RTEMS_INTERRUPT_LOCK_INITIALIZER;
+  rtems_interrupt_lock initialized = RTEMS_INTERRUPT_LOCK_INITIALIZER("test");
   rtems_interrupt_lock lock;
   rtems_interrupt_lock_context lock_context;
-  rtems_interrupt_lock_initialize( &lock );
+  rtems_interrupt_lock_initialize( &lock, "test" );
   rtems_interrupt_lock_acquire( &lock, &lock_context );
diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
index 4c0c3c3..92ea4ec 100644
--- a/testsuites/sptests/spcache01/init.c
+++ b/testsuites/sptests/spcache01/init.c
@@ -48,7 +48,7 @@ static void test_data_flush_and_invalidate(void)
     printf("data cache flush and invalidate test\n");
-    rtems_interrupt_lock_initialize(&lock);
+    rtems_interrupt_lock_initialize(&lock, "test");
     rtems_interrupt_lock_acquire(&lock, &lock_context);
     for (i = 0; i < n; ++i) {
@@ -168,7 +168,7 @@ static void test_timing(void)
   uint32_t cache_level;
   size_t cache_size;
   printf(
     "data cache line size %zi bytes\n"
diff --git a/testsuites/sptests/spnsext01/init.c b/testsuites/sptests/spnsext01/init.c
index b445679..2ffd237 100644
--- a/testsuites/sptests/spnsext01/init.c
+++ b/testsuites/sptests/spnsext01/init.c
@@ -51,7 +51,7 @@ static rtems_task Init(rtems_task_argument argument)
   n = (3 * n) / 2;
   sc = rtems_clock_get_uptime(&uptime);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index bd047a2..aa7bef9 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -138,7 +138,7 @@ static void test_by_function_level(int fl, bool dirty)
   uint64_t q3;
   uint64_t max;
   for (s = 0; s < SAMPLES; ++s) {
1.7.7
