RTEMS Tests and Profiling
Sebastian Huber
Tue Mar 11 14:12:41 UTC 2014
Hello,
in the long run we need a framework to write tests. At the moment I have
absolutely no time to work on this. I need a short term solution to get
profiling data for the tests.
Why is this profiling important? Currently we don't know how good RTEMS is in
terms of thread dispatch latency for example (an important characteristic for
real-time systems). We have some timing tests, but they yield only some
artificial values (except tmcontext01). The timing tests neglect cache effects
and load from other processors on an SMP system. The tmcontext01 is a template
test that addresses this issue. With the profiling data obtained for all tests
of the RTEMS test suite we get a larger sample size. The profiling data is in
XML format which makes it very easy to post-process, e.g.
http://git.rtems.org/rtems/tree/testsuites/tmtests/tmcontext01/plot.py
Supporting SMP will lead to massive changes in the critical sections if we want
to support fine grained locking. Thus we have to show somehow that things
don't get too bad for the single-processor systems. This is why I work on the
profiling first.
With the first profiling data available (smpload01) it is obvious that we need
fine grained locking:
<SMPLockProfilingReport name="Giant">
<MaxAcquireTime unit="ns">245180</MaxAcquireTime>
<MaxSectionTime unit="ns">232130</MaxSectionTime>
<UsageCount>10102</UsageCount>
<TotalAcquireTime unit="ns">416556635</TotalAcquireTime>
<TotalSectionTime unit="ns">529718895</TotalSectionTime>
<ContentionCount initialQueueLength="0">1950</ContentionCount>
<ContentionCount initialQueueLength="1">4735</ContentionCount>
<ContentionCount initialQueueLength="2">2441</ContentionCount>
<ContentionCount initialQueueLength="3">976</ContentionCount>
</SMPLockProfilingReport>
Now back to the tests. The only practically available way to determine if a
test was successful is to look at the "*** END OF TEST" pattern in the test
output. It makes sense to use a common function for test begin and end
messages. Now where should this function be located?
We have a testsuites/support directory with a bunch of files. I would like to
move away from the existing test support. The problem is that you have to add
at least this in every test Makefile.am:
test_SOURCES += ../../support/src/test_support.c
AM_CPPFLAGS += -I$(top_srcdir)/../support/include
I consider ../ paths in Makefiles as hacks.
You have to compile test_support.c again for each tests which increases the
build times.
You have also hacks like this in a header file (buffer_test_io.h):
#if defined(TEST_INIT) || defined(CONFIGURE_INIT)
char _test_output_buffer[_TEST_OUTPUT_BUFFER_SIZE];
int _test_output_buffer_index = 0;
void _test_output_append(char *_buffer)
char *p;
for ( p=_buffer ; *p ; p++ ) {
_test_output_buffer[_test_output_buffer_index++] = *p;
_test_output_buffer[_test_output_buffer_index] = '\0';
#if 0
if ( *p == '\n' ) {
fprintf( stderr, "BUFFER -- %s", _test_output_buffer );
_test_output_buffer[0] = '\0';
#endif
if ( _test_output_buffer_index >= (_TEST_OUTPUT_BUFFER_SIZE - 80) )
_test_output_flush();
#include <termios.h>
#include <unistd.h>
void _test_output_flush(void)
fprintf( stderr, "%s", _test_output_buffer );
tcdrain( 2 );
#endif
Profiling data can be output in a test fatal extension handler.
I propose to move test support code to the cpukit. Attached is an example
header file.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140311/8a7d7db7/attachment.bin>
