TCP/IP update, possible SMP (GSOC 2014)
    Chris Johns
    chrisj at rtems.org
    Wed Mar 12 23:59:11 UTC 2014
On 1/03/2014 3:09 am, Daniel Ramirez wrote:
>         If I'm missing something that would make for a good project and
>         help get SMP up
>         and running, let me know.
>     Some interesting area also useful for the network stack would be
>     flattened device tree support for driver initialization and
>     configuration.
> I will look into this, thanks.
I have Flattened Device Tree (FDT) ported to RTEMS and I have an RTEMS
API to use it. The code is currently not available but I can make it
available.
This is a nice way to describe resources in a system however there are
some catches. For example storing the blob on a disk means you need a
blob to configure the disk's driver to read the blob so some sort of
in-memory support is needed.
Adding support is nice because it means RTEMS can integrate to 3rd party
tools such as Xilinx's tools for the Zynq.
