[PATCH 1/7] bsps/sparc: Make local functions for amba plug&play static.
Daniel Cederman
cederman at gaisler.com
Thu Mar 13 14:19:29 UTC 2014
c/src/lib/libbsp/sparc/shared/amba/ambapp.c | 12 ++++++------
c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c | 2 +-
c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c | 1 +
c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c | 2 +-
c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c | 5 +----
5 files changed, 10 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
index 504a3e7..7b3ae4a 100644
--- a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
+++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
@@ -21,7 +21,7 @@
#define AMBA_APB_SLAVES 16
/* Allocate one AMBA device */
-struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
+static struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
int size = sizeof(struct ambapp_dev);
struct ambapp_dev *dev;
@@ -38,7 +38,7 @@ struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
return dev;
-unsigned int
+static unsigned int
ambapp_addr_from (struct ambapp_mmap *mmaps, unsigned int address)
/* no translation? */
@@ -55,7 +55,7 @@ ambapp_addr_from (struct ambapp_mmap *mmaps, unsigned int address)
return 1;
-void ambapp_ahb_dev_init(
+static void ambapp_ahb_dev_init(
unsigned int ioarea,
struct ambapp_pnp_ahb *ahb,
@@ -102,7 +102,7 @@ void ambapp_ahb_dev_init(
-void ambapp_apb_dev_init(
+static void ambapp_apb_dev_init(
unsigned int base,
struct ambapp_pnp_apb *apb,
@@ -123,7 +123,7 @@ void ambapp_apb_dev_init(
apb_info->mask = ambapp_pnp_apb_mask(apb->iobar);
-int ambapp_add_ahbbus(
+static int ambapp_add_ahbbus(
struct ambapp_bus *abus,
unsigned int ioarea
@@ -298,7 +298,7 @@ int ambapp_scan(
/* Match search options againt device */
-int ambapp_dev_match_options(struct ambapp_dev *dev, unsigned int options, int vendor, int device)
+static int ambapp_dev_match_options(struct ambapp_dev *dev, unsigned int options, int vendor, int device)
if ((((options & (OPTIONS_ALL_DEVS)) == OPTIONS_ALL_DEVS) || /* TYPE */
((options & OPTIONS_AHB_MSTS) && (dev->dev_type == DEV_AHB_MST)) ||
diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
index 03c0f68..0d18fea 100644
--- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
+++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_freq.c
@@ -21,7 +21,7 @@
* If a unsupported bridge is found the invalid frequncy of 0Hz is
* returned.
-unsigned int ambapp_freq_calc(
+static unsigned int ambapp_freq_calc(
int ahbidx,
unsigned int freq_hz,
diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
index 4a47366..c0a8d63 100644
--- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
+++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c
@@ -12,6 +12,7 @@
* http://www.rtems.com/license/LICENSE.
+#include <ambapp.h>
#include <ambapp_ids.h>
diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
index 15aebe5..5d8212c 100644
--- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
+++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_old.c
@@ -19,7 +19,7 @@ struct ambapp_dev_find_match_arg {
/* AMBA PP find routines */
-int ambapp_dev_find_match(struct ambapp_dev *dev, int index, void *arg)
+static int ambapp_dev_find_match(struct ambapp_dev *dev, int index, void *arg)
struct ambapp_dev_find_match_arg *p = arg;
diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
index f73ec1d..e4e04fd 100644
--- a/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
+++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp_show.c
@@ -12,16 +12,13 @@
#include <ambapp.h>
-extern char *ambapp_device_id2str(int vendor, int id);
-extern char *ambapp_vendor_id2str(int vendor);
struct ambapp_dev_print_arg {
int show_depth;
static char *unknown = "unknown";
-int ambapp_dev_print(struct ambapp_dev *dev, int index, void *arg)
+static int ambapp_dev_print(struct ambapp_dev *dev, int index, void *arg)
char *dev_str, *ven_str, *type_str;
struct ambapp_dev_print_arg *p = arg;
1.7.9.5
