[PATCH] bsps/sparc: Add common gnat handler function prototype.
Thu Mar 13 14:24:09 UTC 2014
Does the new header file <gnatcomman.h> need to be installed, or is it
only used internally during the BSP build?
On Thu, Mar 13, 2014 at 10:14 AM, Daniel Cederman <cederman at gaisler.com> wrote:
> Moved prototype for __gnat_install_handler and __gnat_install_handler_common to common header file.
>  c/src/lib/libbsp/sparc/Makefile.am                 |    1 +
>  c/src/lib/libbsp/sparc/erc32/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c   |    2 +-
>  c/src/lib/libbsp/sparc/erc32/preinstall.am         |    4 ++++
>  c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c   |    2 +-
>  c/src/lib/libbsp/sparc/leon2/preinstall.am         |    4 ++++
>  c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
>  c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c   |    2 +-
>  c/src/lib/libbsp/sparc/leon3/preinstall.am         |    4 ++++
>  c/src/lib/libbsp/sparc/shared/gnatcommon.c         |    1 +
>  c/src/lib/libbsp/sparc/shared/include/gnatcommon.h |   19 +++++++++++++++++++
>  12 files changed, 39 insertions(+), 3 deletions(-)
>  create mode 100644 c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
> diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
> index 3508d89..3d433fb 100644
> --- a/c/src/lib/libbsp/sparc/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/Makefile.am
> @@ -6,6 +6,7 @@ SUBDIRS = @RTEMS_BSP_FAMILY@
>  EXTRA_DIST =
>  EXTRA_DIST += shared/gnatcommon.c
> +EXTRA_DIST += shared/include/gnatcommon.h
>  EXTRA_DIST += shared/start/start.S
>  # Interrupt
> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> index 677c44e..5f161e1 100644
> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> @@ -39,6 +39,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>  libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
>  # gnatsupp
>  libbsp_a_SOURCES += gnatsupp/gnatsupp.c ../../sparc/shared/gnatcommon.c
> +include_HEADERS += ../shared/include/gnatcommon.h
>  # console
>  libbsp_a_SOURCES += console/erc32_console.c ../../shared/console.c \
>      ../../shared/console_select.c  ../../shared/console_control.c \
> diff --git a/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c b/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
> index ebab714..74403cd 100644
> --- a/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
> +++ b/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
> @@ -4,7 +4,7 @@
>   * Jiri Gaisler, ESA/ESTEC, 17-02-1999.
> -void __gnat_install_handler_common( int, int );
> +#include "../../shared/include/gnatcommon.h"
>  void
>  __gnat_install_handler (void)
> diff --git a/c/src/lib/libbsp/sparc/erc32/preinstall.am b/c/src/lib/libbsp/sparc/erc32/preinstall.am
> index a235296..b3f4f22 100644
> --- a/c/src/lib/libbsp/sparc/erc32/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/erc32/preinstall.am
> @@ -73,6 +73,10 @@ $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(d
>         $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>  PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
> +$(PROJECT_INCLUDE)/gnatcommon.h: ../shared/include/gnatcommon.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gnatcommon.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/gnatcommon.h
>  $(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index c08f159..50e61fb 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -56,6 +56,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
>  # gnatsupp
>  # console
>  libbsp_a_SOURCES += console/console.c console/debugputs.c
>  # clock
> diff --git a/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c b/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
> index b3a7c18..c0ee1e2 100644
> --- a/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
> +++ b/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
> @@ -10,7 +10,7 @@
> -void __gnat_install_handler_common (int t1, int t2);
>   *  Avoid trap 0x18 which is used by the clock tick, and
> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> index 84aa2b4..2fe4f1c 100644
> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> @@ -141,6 +141,10 @@ $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(d
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index 3c87e18..7fbf5ba 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -45,6 +45,7 @@ libbsp_a_SOURCES += startup/cpucounter.c
>  # gnatsupp
>  # AMBA bus
>  include_HEADERS += include/amba.h
>  include_HEADERS += ../../sparc/shared/include/ambapp.h
> diff --git a/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c b/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
> index 4b1056f..0e65ee7 100644
> --- a/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
> +++ b/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
> @@ -8,7 +8,7 @@
> +#include <gnatcommon.h>
> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> index 0005edd..ed6e96d 100644
> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> @@ -85,6 +85,10 @@ $(PROJECT_LIB)/linkcmds.ngmp: startup/linkcmds.ngmp $(PROJECT_LIB)/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ngmp
>  PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ngmp
>  $(PROJECT_INCLUDE)/amba.h: include/amba.h $(PROJECT_INCLUDE)/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/amba.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/amba.h
> diff --git a/c/src/lib/libbsp/sparc/shared/gnatcommon.c b/c/src/lib/libbsp/sparc/shared/gnatcommon.c
> index 4128982..32d9de9 100644
> --- a/c/src/lib/libbsp/sparc/shared/gnatcommon.c
> +++ b/c/src/lib/libbsp/sparc/shared/gnatcommon.c
> @@ -11,6 +11,7 @@
>  #include <rtems/bspIo.h>
>  #include <signal.h>
>  #include <stdlib.h>
>   * Synchronous trap handler. Map the trap number of SIGFPE, SIGSEGV
> diff --git a/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h b/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
> new file mode 100644
> index 0000000..1a04449
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
> @@ -0,0 +1,19 @@
> +#ifndef __GNATCOMMON_H
> +#define __GNATCOMMON_H
> + * Support for gnat/rtems interrupts and exception handling.
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +void __gnat_install_handler (void);
> +void __gnat_install_handler_common (int t1, int t2);
> +#ifdef __cplusplus
> +#endif
> +#endif
> 1.7.9.5
> rtems-devel mailing list
> rtems-devel at rtems.org
