[PATCH 2/7] bsps/sparc: Make spurious trap handler function static.
Thu Mar 13 14:28:36 UTC 2014
Looks good to me.
On 3/13/2014 9:19 AM, Daniel Cederman wrote:
>  c/src/lib/libbsp/sparc/erc32/startup/spurious.c |    2 +-
>  c/src/lib/libbsp/sparc/leon2/startup/spurious.c |    2 +-
>  c/src/lib/libbsp/sparc/leon3/startup/spurious.c |    2 +-
>  3 files changed, 3 insertions(+), 3 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> index b74f0c7..b8408f2 100644
> --- a/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/erc32/startup/spurious.c
> @@ -118,7 +118,7 @@ void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
> -rtems_isr bsp_spurious_handler(
> +static rtems_isr bsp_spurious_handler(
>     rtems_vector_number trap,
>     CPU_Interrupt_frame *isf
> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> index 0aa6826..5f7cf27 100644
> --- a/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/leon2/startup/spurious.c
> @@ -105,7 +105,7 @@ void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> index e12ac01..210dee0 100644
> --- a/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/spurious.c
> @@ -109,7 +109,7 @@ void _BSP_Exception_frame_print( const CPU_Exception_frame *frame )
