[PATCH 6/7] greth: Make local functions static, remove overflow and correct printf call.
Thu Mar 13 14:31:53 UTC 2014
I am OK with this.
On 3/13/2014 9:19 AM, Daniel Cederman wrote:
>  .../lib/libbsp/sparc/leon3/leon_greth/leon_greth.c |    2 +-
>  c/src/libchip/network/greth.c                      |   14 ++++++++------
>  2 files changed, 9 insertions(+), 7 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> index e913137..306ef46 100644
> --- a/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> +++ b/c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c
> @@ -47,7 +47,7 @@ int rtems_leon_greth_driver_attach(
>      *(volatile int *) base_addr = 0;
>      *(volatile int *) base_addr = GRETH_CTRL_RST;
> -    leon_greth_configuration.base_address = base_addr;
> +    leon_greth_configuration.base_address = (void*)base_addr;
>      leon_greth_configuration.vector = eth_irq; /* on LEON vector is IRQ no. */
>      leon_greth_configuration.txd_count = TDA_COUNT;
>      leon_greth_configuration.rxd_count = RDA_COUNT;
> diff --git a/c/src/libchip/network/greth.c b/c/src/libchip/network/greth.c
> index cab41b8..75443a5 100644
> --- a/c/src/libchip/network/greth.c
> +++ b/c/src/libchip/network/greth.c
> @@ -88,7 +88,7 @@ extern void ipalign(struct mbuf *m);
>  #endif
>  const struct timespec greth_tan = {
>     GRETH_AUTONEGO_TIMEOUT_MS/1000,
> -   GRETH_AUTONEGO_TIMEOUT_MS*1000000
> +   (GRETH_AUTONEGO_TIMEOUT_MS % 1000) *1000000
>  /* For optimizing the autonegotiation time */
> @@ -178,7 +178,7 @@ static char *almalloc(int sz)
>  /* GRETH interrupt handler */
> -void greth_interrupt_handler (void *arg)
> +static void greth_interrupt_handler (void *arg)
>          uint32_t status;
>          uint32_t ctrl;
> @@ -258,7 +258,7 @@ static void print_init_info(struct greth_softc *sc)
>  #ifdef GRETH_AUTONEGO_PRINT_TIME
>          if ( sc->auto_neg ) {
> -          printf("Autonegotiation Time: %dms\n", sc->auto_neg_time.tv_sec*1000 +
> +          printf("Autonegotiation Time: %ldms\n", sc->auto_neg_time.tv_sec*1000 +
>                   sc->auto_neg_time.tv_nsec/1000000);
>  #endif
> @@ -533,7 +533,7 @@ void ipalign(struct mbuf *m)
>  #endif
> -void
> +static void
>  greth_Daemon (void *arg)
>      struct ether_header *eh;
> @@ -544,7 +544,9 @@ greth_Daemon (void *arg)
>      rtems_event_set events;
>      rtems_interrupt_level level;
>      int first;
> +#ifdef CPU_U32_FIX
>      unsigned int tmp;
> +#endif
>      for (;;)
> @@ -627,7 +629,7 @@ again:
>                                      tmp = GRETH_MEM_LOAD(4+(uintptr_t)eh);
>                                      tmp = GRETH_MEM_LOAD(8+(uintptr_t)eh);
>                                      tmp = GRETH_MEM_LOAD(12+(uintptr_t)eh);
> +				    (void)tmp;
>                                      ipalign(m);	/* Align packet on 32-bit boundary */
>  #endif
> @@ -738,7 +740,7 @@ sendpacket (struct ifnet *ifp, struct mbuf *m)
> -int
> +static int
>  sendpacket_gbit (struct ifnet *ifp, struct mbuf *m)
>          struct greth_softc *dp = ifp->if_softc;
