[PATCH] bsps/sparc: Add common gnat handler function prototype.
Daniel Cederman cederman at gaisler.com
Fri Mar 14 11:15:52 UTC 2014
On 2014-03-14 09:52, Daniel Cederman wrote:
> So I should place gnatcommon.h in
> c/src/lib/libbsp/sparc/shared/include/bsp instead?
Or is it just that I should add the file to include_bsp_HEADERS instead
of include_HEADERS?
Daniel Cederman
Software Engineer
Aeroflex Gaisler AB
Aeroflex Microelectronic Solutions – HiRel
Kungsgatan 12
SE-411 19 Gothenburg, Sweden
Phone: +46 31 7758665
www.Aeroflex.com/Gaisler
> On 2014-03-13 15:23, Joel Sherrill wrote:
>> On 3/13/2014 9:14 AM, Daniel Cederman wrote:
>>> Moved prototype for __gnat_install_handler and
>>> __gnat_install_handler_common to common header file.
>>>   c/src/lib/libbsp/sparc/Makefile.am                 |    1 +
>>>   c/src/lib/libbsp/sparc/erc32/Makefile.am           |    1 +
>>>   c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c   |    2 +-
>>>   c/src/lib/libbsp/sparc/erc32/preinstall.am         |    4 ++++
>>>   c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
>>>   c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c   |    2 +-
>>>   c/src/lib/libbsp/sparc/leon2/preinstall.am         |    4 ++++
>>>   c/src/lib/libbsp/sparc/leon3/Makefile.am           |    1 +
>>>   c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c   |    2 +-
>>>   c/src/lib/libbsp/sparc/leon3/preinstall.am         |    4 ++++
>>>   c/src/lib/libbsp/sparc/shared/gnatcommon.c         |    1 +
>>>   c/src/lib/libbsp/sparc/shared/include/gnatcommon.h |   19
>>>   12 files changed, 39 insertions(+), 3 deletions(-)
>>>   create mode 100644 c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
>>> diff --git a/c/src/lib/libbsp/sparc/Makefile.am
>>> b/c/src/lib/libbsp/sparc/Makefile.am
>>> index 3508d89..3d433fb 100644
>>> --- a/c/src/lib/libbsp/sparc/Makefile.am
>>> +++ b/c/src/lib/libbsp/sparc/Makefile.am
>>> @@ -6,6 +6,7 @@ SUBDIRS = @RTEMS_BSP_FAMILY@
>>>   EXTRA_DIST =
>>>   EXTRA_DIST += shared/gnatcommon.c
>>> +EXTRA_DIST += shared/include/gnatcommon.h
>>>   EXTRA_DIST += shared/start/start.S
>>>   # Interrupt
>>> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am
>>> b/c/src/lib/libbsp/sparc/erc32/Makefile.am
>>> index 677c44e..5f161e1 100644
>>> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
>>> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
>>> @@ -39,6 +39,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c
>>> ../../shared/bsplibc.c \
>>>   libbsp_a_SOURCES += ../../sparc/shared/irq_asm.S
>>>   # gnatsupp
>>>   libbsp_a_SOURCES += gnatsupp/gnatsupp.c
>>> ../../sparc/shared/gnatcommon.c
>>> +include_HEADERS += ../shared/include/gnatcommon.h
>>>   # console
>>>   libbsp_a_SOURCES += console/erc32_console.c ../../shared/console.c \
>>>       ../../shared/console_select.c  ../../shared/console_control.c \
>>> diff --git a/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
>>> b/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
>>> index ebab714..74403cd 100644
>>> --- a/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
>>> +++ b/c/src/lib/libbsp/sparc/erc32/gnatsupp/gnatsupp.c
>>> @@ -4,7 +4,7 @@
>>>    * Jiri Gaisler, ESA/ESTEC, 17-02-1999.
>>> -void __gnat_install_handler_common( int, int );
>>> +#include "../../shared/include/gnatcommon.h"
>> Since you installed this as <gnatcommon.h>, it should use <>
>> not ".../.../"
>> Also I think it should have been installed as <bsp/gnatcommon.h>
>> Other than that, this patch is Ok.
>>>   void
>>>   __gnat_install_handler (void)
>>> diff --git a/c/src/lib/libbsp/sparc/erc32/preinstall.am
>>> b/c/src/lib/libbsp/sparc/erc32/preinstall.am
>>> index a235296..b3f4f22 100644
>>> --- a/c/src/lib/libbsp/sparc/erc32/preinstall.am
>>> +++ b/c/src/lib/libbsp/sparc/erc32/preinstall.am
>>> @@ -73,6 +73,10 @@ $(PROJECT_LIB)/linkcmds.base:
>>> ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(d
>>>       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>>>   PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>>> +$(PROJECT_INCLUDE)/gnatcommon.h: ../shared/include/gnatcommon.h
>>> $(PROJECT_INCLUDE)/$(dirstamp)
>>> +    $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gnatcommon.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/gnatcommon.h
>>>   $(PROJECT_INCLUDE)/bsp/irq-generic.h:
>>> ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am
>>> b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>>> index c08f159..50e61fb 100644
>>> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
>>> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
>>> @@ -56,6 +56,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c
>>>   # gnatsupp
>>>   # console
>>>   libbsp_a_SOURCES += console/console.c console/debugputs.c
>>>   # clock
>>> diff --git a/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
>>> b/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
>>> index b3a7c18..c0ee1e2 100644
>>> --- a/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
>>> +++ b/c/src/lib/libbsp/sparc/leon2/gnatsupp/gnatsupp.c
>>> @@ -10,7 +10,7 @@
>>> -void __gnat_install_handler_common (int t1, int t2);
>>>    *  Avoid trap 0x18 which is used by the clock tick, and
>>> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am
>>> b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>>> index 84aa2b4..2fe4f1c 100644
>>> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
>>> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
>>> @@ -141,6 +141,10 @@ $(PROJECT_LIB)/linkcmds.base:
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> index 3c87e18..7fbf5ba 100644
>>> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
>>> @@ -45,6 +45,7 @@ libbsp_a_SOURCES += startup/cpucounter.c
>>>   # gnatsupp
>>>   # AMBA bus
>>>   include_HEADERS += include/amba.h
>>>   include_HEADERS += ../../sparc/shared/include/ambapp.h
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
>>> b/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
>>> index 4b1056f..0e65ee7 100644
>>> --- a/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
>>> +++ b/c/src/lib/libbsp/sparc/leon3/gnatsupp/gnatsupp.c
>>> @@ -8,7 +8,7 @@
>>> +#include <gnatcommon.h>
>>> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> index 0005edd..ed6e96d 100644
>>> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
>>> @@ -85,6 +85,10 @@ $(PROJECT_LIB)/linkcmds.ngmp:
>>> startup/linkcmds.ngmp $(PROJECT_LIB)/$(dirstamp)
>>>       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ngmp
>>>   PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ngmp
>>>   $(PROJECT_INCLUDE)/amba.h: include/amba.h
>>>       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/amba.h
>>>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/amba.h
>>> diff --git a/c/src/lib/libbsp/sparc/shared/gnatcommon.c
>>> b/c/src/lib/libbsp/sparc/shared/gnatcommon.c
>>> index 4128982..32d9de9 100644
>>> --- a/c/src/lib/libbsp/sparc/shared/gnatcommon.c
>>> +++ b/c/src/lib/libbsp/sparc/shared/gnatcommon.c
>>> @@ -11,6 +11,7 @@
>>>   #include <rtems/bspIo.h>
>>>   #include <signal.h>
>>>   #include <stdlib.h>
>>>    * Synchronous trap handler. Map the trap number of SIGFPE, SIGSEGV
>>> diff --git a/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
>>> b/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
>>> new file mode 100644
>>> index 0000000..1a04449
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/sparc/shared/include/gnatcommon.h
>>> @@ -0,0 +1,19 @@
>>> +#ifndef __GNATCOMMON_H
>>> +#define __GNATCOMMON_H
>>> + * Support for gnat/rtems interrupts and exception handling.
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif
>>> +void __gnat_install_handler (void);
>>> +void __gnat_install_handler_common (int t1, int t2);
>>> +#ifdef __cplusplus
>>> +#endif
>>> +#endif
> rtems-devel mailing list
> rtems-devel at rtems.org
