[PATCH] sparc64/niagara: add bsp_fatal_handler to terminate execution
Fri Mar 14 18:32:38 UTC 2014
Terminates the execution of niagara BSP when running in gem5.
 c/src/lib/libbsp/sparc64/niagara/Makefile.am       |    5 +-
 .../lib/libbsp/sparc64/niagara/startup/bspclean.c  |   22 +++
 c/src/lib/libbsp/sparc64/niagara/startup/m5op.h    |   90 ++++++++++++
 .../libbsp/sparc64/niagara/startup/m5op_sparc.S    |  153 ++++++++++++++++++++
 c/src/lib/libbsp/sparc64/niagara/startup/m5ops.h   |   83 +++++++++++
 5 files changed, 351 insertions(+), 2 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c
 create mode 100644 c/src/lib/libbsp/sparc64/niagara/startup/m5op.h
 create mode 100644 c/src/lib/libbsp/sparc64/niagara/startup/m5op_sparc.S
 create mode 100644 c/src/lib/libbsp/sparc64/niagara/startup/m5ops.h
diff --git a/c/src/lib/libbsp/sparc64/niagara/Makefile.am b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
index c251bee..7cc2e81 100644
--- a/c/src/lib/libbsp/sparc64/niagara/Makefile.am
+++ b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
@@ -32,13 +32,14 @@ nodist_include_HEADERS += ../../shared/include/coverhd.h
 EXTRA_DIST = ../shared/start/start.S
-start.$(OBJEXT): ../shared/start/start.S
+%.$(OBJEXT):%.S
 	$(CPPASCOMPILE) -o $@ -c $<
 project_lib_DATA = start.$(OBJEXT)
 dist_project_lib_DATA += ../shared/startup/linkcmds
-startup_SOURCES = ../../shared/bspclean.c ../../shared/bsplibc.c \
+startup_SOURCES = startup/bspclean.c startup/m5op_sparc.S \
+    ../../shared/bsplibc.c \
     ../../shared/bsppredriverhook.c ../../shared/bsppretaskinghook.c \
     ../../shared/bsppost.c \
     ../../shared/bootcard.c ../../shared/sbrk.c \
diff --git a/c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c b/c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c
new file mode 100644
index 0000000..88750aa
--- /dev/null
+++ b/c/src/lib/libbsp/sparc64/niagara/startup/bspclean.c
@@ -0,0 +1,22 @@
+ * Copyright (c) 2014 Gedare Bloom.
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <rtems/bspIo.h>
+#include "m5op.h"
+void bsp_fatal_extension(
+  rtems_fatal_source source,
+  bool is_internal,
+  rtems_fatal_code code
+  m5_exit(0);
diff --git a/c/src/lib/libbsp/sparc64/niagara/startup/m5op.h b/c/src/lib/libbsp/sparc64/niagara/startup/m5op.h
index 0000000..9df9a74
--- /dev/null
+++ b/c/src/lib/libbsp/sparc64/niagara/startup/m5op.h
@@ -0,0 +1,90 @@
+ * Copyright (c) 2003-2006 The Regents of The University of Michigan
+ * All rights reserved.
+ * modification, are permitted provided that the following conditions are
+ * met: redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer;
+ * redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution;
+ * neither the name of the copyright holders nor the names of its
+ * contributors may be used to endorse or promote products derived from
+ * this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+ * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+ * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+ * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Authors: Nathan Binkert
+ *          Ali Saidi
+#ifndef __M5OP_H__
+#define __M5OP_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdint.h>
+void arm(uint64_t address);
+void quiesce(void);
+void quiesceNs(uint64_t ns);
+void quiesceCycle(uint64_t cycles);
+uint64_t quiesceTime(void);
+uint64_t rpns();
+void wakeCPU(uint64_t cpuid);
+void m5_exit(uint64_t ns_delay);
+void m5_fail(uint64_t ns_delay, uint64_t code);
+uint64_t m5_initparam(void);
+void m5_checkpoint(uint64_t ns_delay, uint64_t ns_period);
+void m5_reset_stats(uint64_t ns_delay, uint64_t ns_period);
+void m5_dump_stats(uint64_t ns_delay, uint64_t ns_period);
+void m5_dumpreset_stats(uint64_t ns_delay, uint64_t ns_period);
+uint64_t m5_readfile(void *buffer, uint64_t len, uint64_t offset);
+uint64_t m5_writefile(void *buffer, uint64_t len, uint64_t offset, const char *filename);
+void m5_debugbreak(void);
+void m5_switchcpu(void);
+void m5_addsymbol(uint64_t addr, char *symbol);
+void m5_panic(void);
+void m5_work_begin(uint64_t workid, uint64_t threadid);
+void m5_work_end(uint64_t workid, uint64_t threadid);
+// These operations are for critical path annotation
+void m5a_bsm(char *sm, const void *id, int flags);
+void m5a_esm(char *sm);
+void m5a_begin(int flags, char *st);
+void m5a_end(void);
+void m5a_q(const void *id, char *q, int count);
+void m5a_dq(const void *id, char *q, int count);
+void m5a_wf(const void *id, char *q, char *sm, int count);
+void m5a_we(const void *id, char *q, char *sm, int count);
+void m5a_ws(const void *id, char *q, char *sm);
+void m5a_sq(const void *id, char *q, int count, int flags);
+void m5a_aq(const void *id, char *q, int count);
+void m5a_pq(const void *id, char *q, int count);
+void m5a_l(char *lsm, const void *id, char *sm);
+void m5a_identify(uint64_t id);
+uint64_t m5a_getid(void);
+#define M5_AN_FL_NONE   0x0
+#define M5_AN_FL_BAD    0x2
+#define M5_AN_FL_LINK   0x10
+#define M5_AN_FL_RESET  0x20
+#ifdef __cplusplus
+#endif
+#endif // __M5OP_H__
diff --git a/c/src/lib/libbsp/sparc64/niagara/startup/m5op_sparc.S b/c/src/lib/libbsp/sparc64/niagara/startup/m5op_sparc.S
index 0000000..40248ff
--- /dev/null
+++ b/c/src/lib/libbsp/sparc64/niagara/startup/m5op_sparc.S
@@ -0,0 +1,153 @@
+ *          Ali Saidi
+#define m5_op 0x2
+#define m5_op3 0x37
+#include "m5ops.h"
+#define INST(func, rs1, rs2, rd) \
+        .long (m5_op) << 30 | (rd) << 25 | (m5_op3) << 19 | (func) << 7 |  \
+              (rs1) << 14 | (rs2) << 0;
+#define LEAF(func)                \
+        .section ".text";         \
+        .align   4;               \
+        .global  func;            \
+        .type    func, #function; \
+func:
+#define END(func)         \
+        .size    func, (.-func)
+#define DEBUGBREAK INST(debugbreak_func, 0, 0, 0)
+#define M5EXIT INST(exit_func, 0, 0, 0)
+#define PANIC INST(panic_func, 0, 0, 0)
+#define READFILE INST(readfile_func, 0, 0, 0)
+LEAF(m5_exit)
+    retl
+    M5EXIT
+END(m5_exit)
+LEAF(m5_panic)
+    retl
+    PANIC
+END(m5_panic)
+LEAF(m5_readfile)
+    retl
+    READFILE
+END(m5_readfile)
+LEAF(m5_debugbreak)
+    retl
+    DEBUGBREAK
+END(m5_debugbreak)
+/* !!!!!! All code below here just panics !!!!!! */
+LEAF(arm)
+    retl
+    PANIC
+END(arm)
+LEAF(quiesce)
+    retl
+    PANIC
+END(quiesce)
+LEAF(quiesceNs)
+    retl
+    PANIC
+END(quiesceNs)
+LEAF(quiesceCycle)
+    retl
+    PANIC
+END(quiesceCycle)
+LEAF(quiesceTime)
+    retl
+    PANIC
+END(quiesceTime)
+LEAF(m5_initparam)
+    retl
+    PANIC
+END(m5_initparam)
+LEAF(m5_loadsymbol)
+    retl
+    PANIC
+END(m5_loadsymbol)
+LEAF(m5_reset_stats)
+    retl
+    PANIC
+END(m5_reset_stats)
+LEAF(m5_dump_stats)
+    retl
+    PANIC
+END(m5_dump_stats)
+LEAF(m5_dumpreset_stats)
+    retl
+    PANIC
+END(m5_dumpreset_stats)
+LEAF(m5_checkpoint)
+    retl
+    PANIC
+END(m5_checkpoint)
+LEAF(m5_switchcpu)
+    retl
+    PANIC
+END(m5_switchcpu)
+LEAF(m5_addsymbol)
+    retl
+    PANIC
+END(m5_addsymbol)
+LEAF(m5_anbegin)
+    retl
+    PANIC
+END(m5_anbegin)
+LEAF(m5_anwait)
+    retl
+    PANIC
+END(m5_anwait)
diff --git a/c/src/lib/libbsp/sparc64/niagara/startup/m5ops.h b/c/src/lib/libbsp/sparc64/niagara/startup/m5ops.h
index 0000000..8ff1ac4
--- /dev/null
+++ b/c/src/lib/libbsp/sparc64/niagara/startup/m5ops.h
@@ -0,0 +1,83 @@
+ *          Ali Saidi
+#define arm_func                0x00
+#define quiesce_func            0x01
+#define quiescens_func          0x02
+#define quiescecycle_func       0x03
+#define quiescetime_func        0x04
+#define rpns_func               0x07
+#define wakecpu_func            0x09
+#define deprecated1_func        0x10 // obsolete ivlb
+#define deprecated2_func        0x11 // obsolete ivle
+#define deprecated3_func        0x20 // deprecated exit function
+#define exit_func               0x21
+#define fail_func               0x22
+#define initparam_func          0x30
+#define loadsymbol_func         0x31
+#define resetstats_func         0x40
+#define dumpstats_func          0x41
+#define dumprststats_func       0x42
+#define ckpt_func               0x43
+#define writefile_func          0x4F
+#define readfile_func           0x50
+#define debugbreak_func         0x51
+#define switchcpu_func          0x52
+#define addsymbol_func          0x53
+#define panic_func              0x54
+#define reserved2_func          0x56 // Reserved for user
+#define reserved3_func          0x57 // Reserved for user
+#define reserved4_func          0x58 // Reserved for user
+#define reserved5_func          0x59 // Reserved for user
+#define work_begin_func          0x5a
+#define work_end_func            0x5b
+#define annotate_func     0x55
+#define an_bsm            0x1
+#define an_esm            0x2
+#define an_begin          0x3
+#define an_end            0x4
+#define an_q              0x6
+#define an_dq             0x7
+#define an_wf             0x8
+#define an_we             0x9
+#define an_rq             0xA
+#define an_ws             0xB
+#define an_sq             0xC
+#define an_aq             0xD
+#define an_pq             0xE
+#define an_l              0xF
+#define an_identify       0x10
+#define an_getid          0x11
1.7.1
