[PATCH 16/18] bsp/altera-cyclone-v: Add Alteras hwlib
Ralf Kirchner ralf.kirchner at embedded-brains.de
Wed Mar 12 16:22:05 UTC 2014
Add files from Alteras hwlib
 .../hwlib/include/alt_address_space.h              |  390 +
 .../hwlib/include/alt_clock_group.h                |   95 +
 .../hwlib/include/alt_clock_manager.h              | 1431 ++
 .../hwlib/include/alt_generalpurpose_io.h          | 1236 +
 .../hwlib/include/alt_hwlibs_ver.h                 |   52 +
 .../hwlib/include/alt_interrupt_common.h           |  531 +
 .../hwlib/include/alt_mpu_registers.h              |  156 +
 .../hwlib/include/alt_reset_manager.h              |  249 +
 .../arm/altera-cyclone-v/hwlib/include/hwlib.h     |  190 +
 .../hwlib/include/socal/alt_clkmgr.h               | 6464 +++++
 .../hwlib/include/socal/alt_gpio.h                 | 1991 ++
 .../altera-cyclone-v/hwlib/include/socal/alt_l3.h  | 6299 +++++
 .../hwlib/include/socal/alt_rstmgr.h               | 3382 +++
 .../altera-cyclone-v/hwlib/include/socal/alt_sdr.h | 4149 ++++
 .../hwlib/include/socal/alt_sysmgr.h               |24810 ++++++++++++++++++++
 .../hwlib/include/socal/alt_uart.h                 | 5158 ++++
 .../arm/altera-cyclone-v/hwlib/include/socal/hps.h | 8026 +++++++
 .../altera-cyclone-v/hwlib/include/socal/socal.h   |  356 +
 .../hwlib/src/hwmgr/alt_address_space.c            |  184 +
 .../hwlib/src/hwmgr/alt_clock_manager.c            | 5208 ++++
 .../hwlib/src/hwmgr/alt_generalpurpose_io.c        |  745 +
 .../hwlib/src/hwmgr/alt_reset_manager.c            |  135 +
 22 Dateien geändert, 71237 Zeilen hinzugefügt(+)
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_address_space.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_group.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_manager.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_generalpurpose_io.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_hwlibs_ver.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_interrupt_common.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_mpu_registers.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_reset_manager.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/hwlib.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_clkmgr.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_gpio.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_l3.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_rstmgr.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sdr.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sysmgr.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_uart.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/hps.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/socal.h
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_address_space.c
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_clock_manager.c
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_generalpurpose_io.c
 create mode 100644 c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/src/hwmgr/alt_reset_manager.c
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_address_space.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_address_space.h
new file mode 100644
index 0000000..b66ccdf
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_address_space.h
@@ -0,0 +1,390 @@
+/*! \file
+ *  Altera - SoC FPGA Address Space Manager
+* Copyright 2013 Altera Corporation. All Rights Reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions are met:
+* 1. Redistributions of source code must retain the above copyright notice,
+* this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright notice,
+* this list of conditions and the following disclaimer in the documentation
+* and/or other materials provided with the distribution.
+* 3. The name of the author may not be used to endorse or promote products
+* derived from this software without specific prior written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef __ALT_ADDR_SPACE_H__
+#define __ALT_ADDR_SPACE_H__
+#include <stdbool.h>
+#include "hwlib.h"
+#include "socal/hps.h"
+#ifdef __cplusplus
+extern "C"
+#endif  /* __cplusplus */
+// ARM Level 2 Cache Controller L2C-310 Register Interface
+// Address Filtering Start Register
+// The Address Filtering Start Register is a read and write register.
+// Bits     Field                       Description
+// [31:20] | address_filtering_start   | Address filtering start address for
+//         |                           | bits [31:20] of the filtering address.
+// [19:1]  | Reserved                  | SBZ/RAZ
+// [0]     | address_filtering_enable  | 0 - address filtering disabled
+//         |                           | 1 - address filtering enabled.
+// Address Filtering Start Register Address
+#define L2_CACHE_ADDR_FILTERING_START_OFST      0xC00
+#define L2_CACHE_ADDR_FILTERING_START_ADDR      (ALT_MPUL2_OFST + L2_CACHE_ADDR_FILTERING_START_OFST)
+// Address Filtering Start Register - Start Value Mask
+#define L2_CACHE_ADDR_FILTERING_START_ADDR_MASK 0xFFF00000
+// Address Filtering Start Register - Reset Start Address Value (1 MB)
+#define L2_CACHE_ADDR_FILTERING_START_RESET     0x100000
+// Address Filtering Start Register - Enable Flag Mask
+#define L2_CACHE_ADDR_FILTERING_ENABLE_MASK     0x00000001
+// Address Filtering Start Register - Reset Enable Flag Value (Enabled)
+#define L2_CACHE_ADDR_FILTERING_ENABLE_RESET    0x1
+// Address Filtering End Register
+// The Address Filtering End Register is a read and write register.
+// [31:20] | address_filtering_end     | Address filtering end address for bits
+//         |                           | [31:20] of the filtering address.
+// [19:0]  | Reserved                  | SBZ/RAZ
+// Address Filtering End Register Address
+#define L2_CACHE_ADDR_FILTERING_END_OFST        0xC04
+#define L2_CACHE_ADDR_FILTERING_END_ADDR        (ALT_MPUL2_OFST + L2_CACHE_ADDR_FILTERING_END_OFST)
+// Address Filtering End Register - End Value Mask
+#define L2_CACHE_ADDR_FILTERING_END_ADDR_MASK   0xFFF00000
+// Address Filtering End Register - Reset End Address Value (3 GB)
+#define L2_CACHE_ADDR_FILTERING_END_RESET       0xC0000000
+#ifndef __ASSEMBLY__
+/*! \addtogroup ADDR_SPACE_MGR The Address Space Manager
+ * This module contains group APIs for managing the HPS address space. This
+ * module contains group APIs to manage:
+ * * Memory Map Control
+ * * Memory Coherence
+ * * Cache Managment
+ * * MMU Managment
+/*! \addtogroup ADDR_SPACE_MGR_REMAP Address Space Mapping Control
+ * This group API provides functions to map and remap selected address ranges
+ * into the accessible (visible) views of the MPU and non MPU address spaces.
+ * \b Caveats
+ * \b NOTE: Caution should be observed when remapping address 0 to different
+ * memory.  The code performing the remapping operation should not be executing
+ * in the address range being remapped to different memory.
+ * For example, if address 0 is presently mapped to OCRAM and the code is
+ * preparing to remap address 0 to SDRAM, then the code must not be executing in
+ * the range 0 to 64 KB as this address space is about to be remapped to
+ * different memory. If the code performing the remap operation is executing
+ * from OCRAM then it needs to be executing from its permanently mapped OCRAM
+ * address range in upper memory (i.e. ALT_OCRAM_LB_ADDR to ALT_OCRAM_UB_ADDR).
+ * \b NOTE: The MPU address space view is controlled by two disparate hardware
+ * control interfaces: the L3 remap register and the L2 cache address filtering
+ * registers. To complicate matters, the L3 remap register is write-only which
+ * means not only that current remap register state cannot be read but also that
+ * a read-modify-write operation cannot be performed on the register.
+ * This should not present a problem in most use case scenarios except for the
+ * case where a current MPU address space mapping of 0 to SDRAM is being changed
+ * to to a mapping of 0 to Boot ROM or OCRAM.
+ * In this case, a two step process whereby the L3 remap register is first set
+ * to the new desired MPU address 0 mapping and then the L2 cache address
+ * filtering registers have their address ranges adjusted accordingly must be
+ * followed. An example follows:
+\verbatim
+// 1 MB reset default value for address filtering start
+uint32_t addr_filt_start;
+uint32_t addr_filt_end;
+// Perform L3 remap register programming first by setting the desired new MPU
+// address space 0 mapping. Assume OCRAM for the example.
+alt_addr_space_remap(ALT_ADDR_SPACE_MPU_ZERO_AT_OCRAM, ...);
+// Next, adjust the L2 cache address filtering range. Set the start address to
+// the default reset value and retain the existing end address configuration.
+alt_l2_addr_filter_cfg_get(&addr_filt_start, &addr_filt_end);
+if (addr_filt_start != L2_CACHE_ADDR_FILTERING_START_RESET)
+    alt_l2_addr_filter_cfg_set(L2_CACHE_ADDR_FILTERING_START_RESET, addr_filt_end);
+\endverbatim
+ * This type definition enumerates the MPU address space attributes.
+ * The MPU address space consists of the ARM Cortex A9 processors and associated
+ * processor peripherals (cache, MMU).
+typedef enum ALT_ADDR_SPACE_MPU_ATTR_e
+    ALT_ADDR_SPACE_MPU_ZERO_AT_BOOTROM,     /*!< Maps the Boot ROM to address
+                                             *   0x0 for the MPU L3 master. Note
+                                             *   that the Boot ROM is also
+                                             *   always mapped to address
+                                             *   0xfffd_0000 for the MPU L3
+                                             *   master independent of
+                                             *   attribute.
+    ALT_ADDR_SPACE_MPU_ZERO_AT_OCRAM        /*!< Maps the On-chip RAM to address
+                                             *   that the On-chip RAM is also
+                                             *   0xffff_0000 for the MPU L3
+                                             *   master independent of this
+                                             *   attribute.
+} ALT_ADDR_SPACE_MPU_ATTR_t;
+ * This type definition enumerates the non-MPU address space attributes.
+ * The non-MPU address space consists of the non-MPU L3 masters including the
+ * DMA controllers (standalone and those built into peripherals), the F2H AXI
+ * Bridge, and the DAP.
+typedef enum ALT_ADDR_SPACE_NONMPU_ATTR_e
+    ALT_ADDR_SPACE_NONMPU_ZERO_AT_OCRAM,    /*!< Maps the SDRAM to address 0x0
+                                             *   for the non-MPU L3 masters.
+    ALT_ADDR_SPACE_NONMPU_ZERO_AT_SDRAM     /*!< Maps the On-chip RAM to address
+                                             *   0x0 for the non-MPU L3
+                                             *   masters. Note that the On-chip
+                                             *   RAM is also always mapped to
+                                             *   address 0xffff_0000 for the
+                                             *   non-MPU L3 masters independent
+                                             *   of this attribute.
+} ALT_ADDR_SPACE_NONMPU_ATTR_t;
+ * This type definition enumerates the HPS to FPGA bridge accessiblity
+ * attributes.
+typedef enum ALT_ADDR_SPACE_H2F_BRIDGE_ATTR_e
+    ALT_ADDR_SPACE_H2F_INACCESSIBLE,        /*!< The H2F AXI Bridge is not
+                                             *   visible to L3 masters. Accesses
+                                             *   to the associated address range
+                                             *   return an AXI decode error to
+                                             *   the master.
+    ALT_ADDR_SPACE_H2F_ACCESSIBLE           /*!< The H2F AXI Bridge is visible
+                                             *   to L3 masters.
+} ALT_ADDR_SPACE_H2F_BRIDGE_ATTR_t;
+ * This type definition enumerates the Lightweight HPS to FPGA bridge
+ * accessiblity attributes.
+typedef enum ALT_ADDR_SPACE_LWH2F_BRIDGE_ATTR_e
+    ALT_ADDR_SPACE_LWH2F_INACCESSIBLE,      /*!< The LWH2F AXI Bridge is not
+                                             *   the master.
+    ALT_ADDR_SPACE_LWH2F_ACCESSIBLE         /*!< The LWH2F AXI Bridge is visible
+                                             *   to L3 masters.
+} ALT_ADDR_SPACE_LWH2F_BRIDGE_ATTR_t;
+ * Configures the mapped and accessible (visible) address ranges for the HPS
+ * MPU, non-MPU, and Bridge address spaces.
+ * \param       mpu_attr
+ *              The MPU address space configuration attributes.
+ * \param       nonmpu_attr
+ *              The non-MPU address space configuration attributes.
+ * \param       h2f_attr
+ *              The H2F Bridge attribute mapping and accessibility attributes.
+ * \param       lwh2f_attr
+ *              The Lightweight H2F Bridge attribute mapping and accessibility
+ *              attributes.
+ * \retval      ALT_E_SUCCESS       The operation was succesful.
+ * \retval      ALT_E_ERROR         The operation failed.
+ * \retval      ALT_E_INV_OPTION    One or more invalid attribute options were
+ *                                  specified.
+ALT_STATUS_CODE alt_addr_space_remap(ALT_ADDR_SPACE_MPU_ATTR_t mpu_attr,
+                                     ALT_ADDR_SPACE_NONMPU_ATTR_t nonmpu_attr,
+                                     ALT_ADDR_SPACE_H2F_BRIDGE_ATTR_t h2f_attr,
+                                     ALT_ADDR_SPACE_LWH2F_BRIDGE_ATTR_t lwh2f_attr);
+ * Maps SDRAM to address 0x0 for the MPU address space view.
+ * When address 0x0 is mapped to the Boot ROM or on-chip RAM, only the lowest
+ * 64KB of the boot region are accessible because the size of the Boot ROM and
+ * on-chip RAM are only 64KB.  Addresses in the range 0x100000 (1MB) to
+ * 0xC0000000 (3GB) access SDRAM and addresses in the range 0xC0000000 (3GB) to
+ * 0xFFFFFFFF access the L3 interconnect. Thus, the lowest 1MB of SDRAM is not
+ * accessible to the MPU unless address 0 is remapped to SDRAM after reset.
+ * This function remaps the addresses between 0x0 to 0x100000 (1MB) to access
+ * SDRAM.
+ * \internal
+ * The remap to address 0x0 is achieved by configuring the L2 cache Address
+ * Filtering Registers to redirect address 0x0 to \e sdram_end_addr to the SDRAM
+ * AXI (M1) master port by calling:
+ * alt_l2_addr_filter_cfg_set(0x0, <current_addr_filt_end_value>);
+ * See: <em>ARM DDI 0246F, CoreLink Level 2 Cache Controller L2C-310 Technical
+ * Reference Manual, Section 3.3.12 Address Filtering </em>.
+ * \endinternal
+ALT_STATUS_CODE alt_mpu_addr_space_remap_0_to_sdram(void);
+/*! \addtogroup L2_ADDR_FLTR L2 Cache Address Filter
+ * The L2 cache address filter controls where physical addresses within certain
+ * ranges of the MPU address space are directed.
+ * The L2 cache has master port connections to the L3 interconnect and the SDRAM
+ * controller. A programmable address filter controls which portions of the
+ * 32-bit physical address space use each master.
+ * When l2 address filtering is configured and enabled, a physical address will
+ * be redirected to one master or the other based upon the address filter
+ * configuration.
+ * If \b address_filter_start <= \e physical_address < \b address_filter_end:
+ * * then redirect \e physical_address to AXI Master Port M1 (SDRAM controller)
+ * * else redirect \e physical_address to AXI Master Port M0 (L3 interconnect)
+ * Reference Manual, Section 3.3.12 Address Filtering </em> for more information.
+ * Get the L2 cache address filtering configuration settings.
+ * \param       addr_filt_start
+ *              [out] An output parameter variable for the address filtering
+ *              start address for the range of physical addresses redirected to
+ *              the SDRAM AXI master port. The value returned is always a 1 MB
+ *              aligned address.
+ * \param       addr_filt_end
+ *              end address for the range of physical addresses redirected to
+ * \retval      ALT_E_SUCCESS   The operation was successful.
+ * \retval      ALT_E_BAD_ARG   An bad argument was passed. Either \e addr_filt_start
+ *                              or \e addr_filt_end or both are invalid addresses.
+ALT_STATUS_CODE alt_l2_addr_filter_cfg_get(uint32_t* addr_filt_start,
+                                           uint32_t* addr_filt_end);
+ * Set the L2 cache address filtering configuration settings.
+ * Address filtering start and end values must be 1 MB aligned.
+ *              The address filtering start address for the range of physical
+ *              addresses redirected to the SDRAM AXI master port. Only bits
+ *              [31:20] of the address are valid. Any bits outside the range
+ *              [31:20] are invalid and will cause an error status to be
+ *              returned.
+ *              The address filtering end address for the range of physical
+ *              returned.
+ * \retval      ALT_E_ARG_RANGE An argument violates a range constraint. One or
+ *                              more address arguments do not satisfy the argument
+ *                              constraints.
+ALT_STATUS_CODE alt_l2_addr_filter_cfg_set(uint32_t addr_filt_start,
+                                           uint32_t addr_filt_end);
+#endif  /* __ASSEMBLY__ */
+#ifdef __cplusplus
+#endif  /* __ALT_ADDR_SPACE_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_group.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_group.h
index 0000000..a5e8c92
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_group.h
@@ -0,0 +1,95 @@
+/*! \file
+ *  Contains the definition of an opaque data structure that contains raw
+ *  configuration information for a clock group.
+* OF SUCH DAMAGE.
+#ifndef __ALT_CLK_GRP_H__
+#define __ALT_CLK_GRP_H__
+#include "hwlib.h"
+#include "socal/alt_clkmgr.h"
+#ifdef __cplusplus
+extern "C"
+/*! This type definition enumerates the clock groups
+typedef enum ALT_CLK_GRP_e
+	ALT_MAIN_PLL_CLK_GRP,					/*!< Main PLL clock group */
+	ALT_PERIPH_PLL_CLK_GRP,					/*!< Peripheral PLL clock group */
+	ALT_SDRAM_PLL_CLK_GRP					/*!< SDRAM PLL clock group */
+} ALT_CLK_GRP_t;
+/*! This type definition defines an opaque data structure for holding the
+ *  configuration settings for a complete clock group.
+typedef struct ALT_CLK_GROUP_RAW_CFG_s
+    uint32_t      			  verid;		/*!< SoC FPGA version identifier. This field
+											*   encapsulates the silicon identifier and
+											*   version information associated with this
+											*   clock group configuration. It is used to
+											*   assert that this clock group configuration
+											*   is valid for this device.
+    uint32_t				  siliid2;		/*!< Reserved register - reserved for future
+     	 	 	 	 	 	 	 	 	 	*	 device IDs or capability flags/
+    ALT_CLK_GRP_t     		  clkgrpsel;	/*!< Clock group union discriminator */
+    /*! This union holds the raw register values for configuration of the set of
+     *  possible clock groups on the SoC FPGA. The \e clkgrpsel discriminator
+     *  identifies the valid clock group union data member.
+    union ALT_CLK_GROUP_RAW_CFG_u
+        ALT_CLKMGR_MAINPLL_t  mainpllgrp;   /*!< Raw clock group configuration for Main PLL group */
+        ALT_CLKMGR_PERPLL_t   perpllgrp;    /*!< Raw clock group configuration for Peripheral PLL group */
+        ALT_CLKMGR_SDRPLL_t   sdrpllgrp;    /*!< Raw clock group configuration for SDRAM PLL group */
+    } clkgrp;
+} ALT_CLK_GROUP_RAW_CFG_t;
+#ifdef __cplusplus
+#endif  /* __ALT_CLK_GRP_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_manager.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_manager.h
index 0000000..7cf0e12
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_clock_manager.h
@@ -0,0 +1,1431 @@
+/*! \file
+ *  Contains definitions for the Altera Hardware Libraries Clock Manager
+ *  Application Programming Interface
+* OF SUCH DAMAGE.
+#ifndef __ALT_CLK_MGR_H__
+#define __ALT_CLK_MGR_H__
+#include "hwlib.h"
+#include "alt_clock_group.h"
+#ifdef __cplusplus
+extern "C"
+/*! \addtogroup CLK_MGR The Clock Manager API
+ * This module defines the Clock Manager API for accessing, configuring, and
+ * controlling the HPS clock resources.
+ * This type definition is an opaque type definition for clock frequency values
+ * in Hz.
+typedef uint32_t    alt_freq_t;
+ * This type definition enumerates the names of the clock and PLL resources
+ * managed by the Clock Manager.
+typedef enum ALT_CLK_e
+    /* Clock Input Pins */
+    ALT_CLK_IN_PIN_OSC1,
+                                        /*!< \b OSC_CLK_1_HPS
+                                         *   External oscillator input:
+                                         *   * Input Pin
+                                         *   * Clock source to Main PLL
+                                         *   * Clock source to SDRAM PLL
+                                         *     and Peripheral PLL if selected via
+                                         *     register write
+                                         *   * Clock source for clock in safe mode
+    ALT_CLK_IN_PIN_OSC2,
+                                        /*!< \b OSC_CLK_2_HPS
+                                         *   External Oscillator input:
+                                         *   * Input Pin
+                                         *   * Optional clock source to SDRAM PLL
+                                         *   * Typically used for Ethernet
+                                         *     reference clock
+    /* FPGA Clock Sources External to HPS */
+    ALT_CLK_F2H_PERIPH_REF,
+                                        /*<! Alternate clock source from FPGA
+                                         * for HPS Peripheral PLL. */
+    ALT_CLK_F2H_SDRAM_REF,
+                                         * for HPS SDRAM PLL. */
+    /* Other Clock Sources External to HPS */
+    ALT_CLK_IN_PIN_JTAG,
+                                        /*!< \b JTAG_TCK_HPS
+                                         *   * Input Pin
+                                         *   * External HPS JTAG clock input.
+    ALT_CLK_IN_PIN_ULPI0,
+                                        /*!< \b ULPI0_CLK
+                                         *   ULPI Clock provided by external USB0
+                                         *   PHY
+                                         *   * Input Pin
+    ALT_CLK_IN_PIN_ULPI1,
+                                        /*!< \b ULPI1_CLK
+                                         *   ULPI Clock provided by external USB1
+                                         *   PHY
+                                         *   * Input Pin
+    ALT_CLK_IN_PIN_EMAC0_RX,
+                                        /*!< \b EMAC0:RX_CLK
+                                         *   Rx Reference Clock for EMAC0
+                                         *   * Input Pin
+    ALT_CLK_IN_PIN_EMAC1_RX,
+                                        /*!< \b EMAC1:RX_CLK
+                                         *   Rx Reference Clock for EMAC1
+                                         *   * Input Pin
+    /* PLLs */
+    ALT_CLK_MAIN_PLL,
+                                        /*!< \b main_pll_ref_clkin
+                                         *   Main PLL input reference clock,
+                                         *   used to designate the Main PLL in
+                                         *   PLL clock selections.
+    ALT_CLK_PERIPHERAL_PLL,
+                                        /*!< \b periph_pll_ref_clkin
+                                         *   Peripheral PLL input reference
+                                         *   clock, used to designate the
+                                         *   Peripheral PLL in PLL clock
+                                         *   selections.
+    ALT_CLK_SDRAM_PLL,
+                                        /*!< \b sdram_pll_ref_clkin
+                                         *   SDRAM PLL input reference clock,
+                                         *   used to designate the SDRAM PLL in
+    /* OSC1 Clock Group - The OSC1 clock group contains those clocks which are derived
+     * directly from the osc_clk_1_HPS pin */
+    ALT_CLK_OSC1,
+                                        /*!< \b osc1_clk
+                                         *   OSC1 Clock Group - The
+                                         *   OSC1 clock group contains
+                                         *   those clocks which are
+                                         *   derived directly from the
+                                         *   osc_clk_1_HPS pin.
+                                         *   * alias for ALT_CLK_IN_PIN_OSC1
+    /* Main Clock Group - The following clocks are derived from the Main PLL. */
+    ALT_CLK_MAIN_PLL_C0,
+                                        /*!< \b Main PLL C0 Output */
+    ALT_CLK_MAIN_PLL_C1,
+                                        /*!< \b Main PLL C1 Output */
+    ALT_CLK_MAIN_PLL_C2,
+                                        /*!< \b Main PLL C2 Output */
+    ALT_CLK_MAIN_PLL_C3,
+                                        /*!< \b Main PLL C3 Output */
+    ALT_CLK_MAIN_PLL_C4,
+                                        /*!< \b Main PLL C4 Output */
+    ALT_CLK_MAIN_PLL_C5,
+                                        /*!< \b Main PLL C5 Output */
+    ALT_CLK_MPU,
+                                        /*!< \b mpu_clk
+                                         *   Main PLL C0 Output. Clock for MPU
+                                         *   subsystem, including CPU0 and CPU1.
+                                         *   * Alias for \e ALT_CLK_MAIN_PLL_C0
+    ALT_CLK_MPU_L2_RAM,
+                                        /*!< \b mpu_l2_ram_clk
+                                         *   Clock for MPU level 2 (L2) RAM
+    ALT_CLK_MPU_PERIPH,
+                                        /*!< \b mpu_periph_clk
+                                         *   Clock for MPU snoop control unit
+                                         *   (SCU) peripherals, such as the
+                                         *   general interrupt controller (GIC)
+    ALT_CLK_L3_MAIN,
+                                        /*!< \b main_clk
+                                         *   Main PLL C1 Output
+                                         *   * Alias for \e ALT_CLK_MAIN_PLL_C1
+    ALT_CLK_L3_MP,
+                                        /*!< \b l3_mp_clk
+                                         *   Clock for L3 Master Peripheral Switch
+    ALT_CLK_L3_SP,
+                                        /*!< \b l3_sp_clk
+                                         *   Clock for L3 Slave Peripheral Switch
+    ALT_CLK_L4_MAIN,
+                                        /*!< \b l4_main_clk
+                                         *   Clock for L4 main bus
+                                         *   * Clock for DMA
+                                         *   * Clock for SPI masters
+    ALT_CLK_L4_MP,
+                                        /*!< \b l4_mp_clk
+                                         *   Clock for L4 master peripherals (MP) bus
+    ALT_CLK_L4_SP,
+                                        /*!< \b l4_sp_clk
+                                         *   Clock for L4 slave peripherals (SP) bus
+    ALT_CLK_DBG_BASE,
+                                        /*!< \b dbg_base_clk
+                                         *   Main PLL C2 Output
+                                         *   * Alias for \e ALT_CLK_MAIN_PLL_C2
+    ALT_CLK_DBG_AT,
+                                        /*!< \b dbg_at_clk
+                                         *   Clock for CoreSight debug Advanced
+                                         *   Microcontroller Bus Architecture
+                                         *   (AMBA) Trace Bus (ATB)
+    ALT_CLK_DBG_TRACE,
+                                        /*!< \b dbg_trace_clk
+                                         *   Clock for CoreSight debug Trace
+                                         *   Port Interface Unit (TPIU)
+    ALT_CLK_DBG_TIMER,
+                                        /*!< \b dbg_timer_clk
+                                         *   Clock for the trace timestamp
+                                         *   generator
+    ALT_CLK_DBG,
+                                        /*!< \b dbg_clk
+                                         *   Clock for Debug Access Port (DAP)
+                                         *   and debug Advanced Peripheral Bus
+                                         *   (APB)
+    ALT_CLK_MAIN_QSPI,
+                                        /*!< \b main_qspi_clk
+                                         *   Main PLL C3 Output. Quad SPI flash
+                                         *   internal logic clock.
+                                         *   * Alias for \e ALT_CLK_MAIN_PLL_C3
+    ALT_CLK_MAIN_NAND_SDMMC,
+                                        /*!< \b main_nand_sdmmc_clk
+                                         *   Main PLL C4 Output. Input clock to
+                                         *   flash controller clocks block.
+                                         *   * Alias for \e ALT_CLK_MAIN_PLL_C4
+    ALT_CLK_CFG,
+                                        /*!< \b cfg_clk
+                                         *   FPGA manager configuration clock.
+    ALT_CLK_H2F_USER0,
+                                        /*!< \b h2f_user0_clock
+                                         *   Clock to FPGA fabric
+    /* Peripherals Clock Group - The following clocks are derived from the Peripheral PLL */
+    ALT_CLK_PERIPHERAL_PLL_C0,
+                                        /*!< \b Peripheral PLL C0 Output */
+    ALT_CLK_PERIPHERAL_PLL_C1,
+                                        /*!< \b Peripheral PLL C1 Output */
+    ALT_CLK_PERIPHERAL_PLL_C2,
+                                        /*!< \b Peripheral PLL C2 Output */
+    ALT_CLK_PERIPHERAL_PLL_C3,
+                                        /*!< \b Peripheral PLL C3 Output */
+    ALT_CLK_PERIPHERAL_PLL_C4,
+                                        /*!< \b Peripheral PLL C4 Output */
+    ALT_CLK_PERIPHERAL_PLL_C5,
+                                        /*!< \b Peripheral PLL C5 Output */
+    ALT_CLK_USB_MP,
+                                        /*!< \b usb_mp_clk
+                                         *   Clock for USB
+    ALT_CLK_SPI_M,
+                                        /*!< \b spi_m_clk
+                                         *   Clock for L4 SPI master bus
+    ALT_CLK_QSPI,
+                                        /*!< \b qspi_clk
+                                         *   Clock for Quad SPI
+    ALT_CLK_NAND_X,
+                                        /*!< \b nand_x_clk
+                                         *   NAND flash controller master and
+                                         *   slave clock
+    ALT_CLK_NAND,
+                                        /*!< \b nand_clk
+                                         *   Main clock for NAND flash
+                                         *   controller
+    ALT_CLK_SDMMC,
+                                        /*!< \b sdmmc_clk
+                                         *   Clock for SD/MMC logic input clock
+    ALT_CLK_EMAC0,
+                                        /*!< \b emac0_clk
+                                         *   EMAC 0 clock - Peripheral PLL C0
+                                         *   Output
+                                         *   * Alias for \e ALT_CLK_PERIPHERAL_PLL_C0
+    ALT_CLK_EMAC1,
+                                        /*!< \b emac1_clk
+                                         *   EMAC 1 clock - Peripheral PLL C1
+                                         *   Output
+                                         *   * Alias for \e ALT_CLK_PERIPHERAL_PLL_C1
+    ALT_CLK_CAN0,
+                                        /*!< \b can0_clk
+                                         *   Controller area network (CAN)
+                                         *   controller 0 clock
+    ALT_CLK_CAN1,
+                                        /*!< \b can1_clk
+                                         *   controller 1 clock
+    ALT_CLK_GPIO_DB,
+                                        /*!< \b gpio_db_clk
+                                         *   Debounce clock for GPIO0, GPIO1,
+                                         *   and GPIO2
+    ALT_CLK_H2F_USER1,
+                                        /*!< \b h2f_user1_clock
+                                         *   Clock to FPGA fabric - Peripheral
+                                         *   PLL C5 Output
+                                         *   * Alias for \e ALT_CLK_PERIPHERAL_PLL_C5
+    /* SDRAM Clock Group - The following clocks are derived from the SDRAM PLL */
+    ALT_CLK_SDRAM_PLL_C0,
+                                        /*!< \b SDRAM PLL C0 Output */
+    ALT_CLK_SDRAM_PLL_C1,
+                                        /*!< \b SDRAM PLL C1 Output */
+    ALT_CLK_SDRAM_PLL_C2,
+                                        /*!< \b SDRAM PLL C2 Output */
+    ALT_CLK_SDRAM_PLL_C3,
+                                        /*!< \b SDRAM PLL C3 Output */
+    ALT_CLK_SDRAM_PLL_C4,
+                                        /*!< \b SDRAM PLL C4 Output */
+    ALT_CLK_SDRAM_PLL_C5,
+                                        /*!< \b SDRAM PLL C5 Output */
+    ALT_CLK_DDR_DQS,
+                                        /*!< \b ddr_dqs_clk
+                                         *   Clock for MPFE, single-port
+                                         *   controller, CSR access, and PHY -
+                                         *   SDRAM PLL C0 Output
+                                         *   * Alias for \e ALT_CLK_SDRAM_PLL_C0
+    ALT_CLK_DDR_2X_DQS,
+                                        /*!< \b ddr_2x_dqs_clk
+                                         *    Clock for PHY - SDRAM PLL C1 Output
+                                         *   * Alias for \e ALT_CLK_SDRAM_PLL_C1
+    ALT_CLK_DDR_DQ,
+                                        /*!< \b ddr_dq_clk
+                                         *   Clock for PHY - SDRAM PLL C2 Output
+                                         *   * Alias for \e ALT_CLK_SDRAM_PLL_C2
+    ALT_CLK_H2F_USER2,
+                                        /*!< \b h2f_user2_clock
+                                         *   Clock to FPGA fabric - SDRAM PLL C5
+                                         *   Output
+                                         *   * Alias for \e ALT_CLK_SDRAM_PLL_C5
+    /* Clock Output Pins */
+    ALT_CLK_OUT_PIN_EMAC0_TX,
+                                       /*!< \b EMAC0:TX_CLK
+                                        *   Tx Reference Clock for EMAC0
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_EMAC1_TX,
+                                       /*!< \b EMAC1:TX_CLK
+                                        *   Tx Reference Clock for EMAC1
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_SDMMC,
+                                       /*!< \b SDMMC:CLK
+                                        *   SD/MMC Card Clock
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_I2C0_SCL,
+                                       /*!< \b I2C0:SCL
+                                        *   I2C Clock for I2C0
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_I2C1_SCL,
+                                       /*!< \b I2C1:SCL
+                                        *   I2C Clock for I2C1
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_I2C2_SCL,
+                                       /*!< \b I2C2:SCL
+                                        *   I2C Clock for I2C2/2 wire
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_I2C3_SCL,
+                                       /*!< \b I2C3:SCL
+                                        *   I2C Clock for I2C1/2 wire
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_SPIM0,
+                                       /*!< \b SPIM0:CLK
+                                        *   SPI Clock
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_SPIM1,
+                                       /*!< \b SPIM1:CLK
+                                        *   SPI Clock
+                                        *   * Output Pin
+    ALT_CLK_OUT_PIN_QSPI,
+                                       /*!< \b QSPI:CLK
+                                        *   QSPI Flash Clock
+                                        *   * Output Pin
+    ALT_CLK_UNKNOWN
+} ALT_CLK_t;
+/*! \addtogroup CLK_MGR_STATUS Clock Manager Status
+ * This functional group provides status information on various aspects and
+ * properties of the Clock Manager state.
+ * This type definition defines the lock condition status codes for each of the
+ * PLLs. If the PLL lock status condition is enabled (See: alt_clk_irq_enable())
+ * then it contributes to the overall \b clkmgr_IRQ signal assertion state.
+typedef enum ALT_CLK_PLL_LOCK_STATUS_e
+    ALT_MAIN_PLL_LOCK_ACHV    = 0x00000001, /*!< This condition is set if the Main
+                                             *   PLL has achieved lock at least once
+                                             *   since this condition was last
+                                             *   cleared.
+    ALT_PERIPH_PLL_LOCK_ACHV  = 0x00000002, /*!< This condition is set if the Peripheral
+                                             *   cleared.
+    ALT_SDR_PLL_LOCK_ACHV     = 0x00000004, /*!< This condition is set if the SDRAM
+                                             *   cleared.
+    ALT_MAIN_PLL_LOCK_LOST    = 0x00000008, /*!< This condition is set if the Main
+                                             *   PLL has lost lock at least once
+                                             *   cleared.
+    ALT_PERIPH_PLL_LOCK_LOST  = 0x00000010, /*!< This condition is set if the Peripheral
+                                             *   cleared.
+    ALT_SDR_PLL_LOCK_LOST     = 0x00000020  /*!< This condition is set if the SDRAM
+                                             *   cleared.
+} ALT_CLK_PLL_LOCK_STATUS_t;
+ * Clear the selected PLL lock status conditions.
+ * This function clears assertions of one or more of the PLL lock status
+ * conditions.
+ * NOTE: This function is used to clear \b clkmgr_IRQ interrupt signal source
+ * assertion conditions.
+ * \param       lock_stat_mask
+ *              Specifies the PLL lock status conditions to clear. \e lock_stat_mask
+ *              is a mask of logically OR'ed \ref ALT_CLK_PLL_LOCK_STATUS_t
+ *              values designating the PLL lock conditions to clear.
+ * \retval      ALT_E_SUCCESS   Successful status.
+ * \retval      ALT_E_BAD_ARG   The \e lock_stat_mask argument contains an
+ *                              unknown condition value.
+ALT_STATUS_CODE alt_clk_lock_status_clear(ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask);
+ * Returns the PLL lock status condition values.
+ * This function returns the value of the PLL lock status conditions.
+ * \returns The current values of the PLL lock status conditions as defined by
+ * the \ref ALT_CLK_PLL_LOCK_STATUS_t mask bits. If the corresponding bit is set
+ * then the condition is asserted.
+uint32_t alt_clk_lock_status_get(void);
+ * Returns ALT_E_TRUE if the designated PLL is currently locked and ALT_E_FALSE
+ * otherwise.
+ * \param       pll
+ *              The PLL to return the lock status of.
+ * \retval      ALT_E_TRUE      The specified PLL is currently locked.
+ * \retval      ALT_E_FALSE     The specified PLL is currently not locked.
+ * \retval      ALT_E_BAD_ARG   The \e pll argument designates a non PLL clock
+ *                              value.
+ * \internal
+ * NOTE: This function uses the
+ *       * \b hps::clkmgr::inter::mainplllocked
+ *       * \b hps::clkmgr::inter::perplllocked,
+ *       * \b hps::clkmgr::inter::sdrplllocked
+ *       bits to determine if the PLL is locked or not.
+ * \endinternal
+ALT_STATUS_CODE alt_clk_pll_is_locked(ALT_CLK_t pll);
+/*! \addtogroup CLK_MGR_SAFE_MODE Safe Mode Options
+ * When safe mode is enabled, clocks in the HPS are directly generated from the
+ * \b osc1_clk clock. Safe mode is enabled by the assertion of a safe mode
+ * request from the reset manager or by a cold reset. Assertion of the safe mode
+ * request from the reset manager sets the safe mode bit in the clock manager
+ * control register. No other control register bits are affected by the safe
+ * mode request from the reset manager.
+ * While in safe mode, clock manager register settings which control clock
+ * behavior are not changed. However, the output of the registers which control
+ * the clock manager state are forced to the safe mode values such that the
+ * following conditions occur:
+ * * All PLLs are bypassed to the \b osc1_clk clock, including their counters.
+ * * Clock dividers select their default reset values.
+ * * The flash controllers source clock selections are set to the peripheral
+ *   PLL.
+ * * All clocks are enabled.
+ * * Safe mode is optionally applied to debug clocks.
+ * A write by software is the only way to clear the safe mode bit. All registers
+ * and clocks need to be configured correctly and all software-managed clocks
+ * need to be gated off before clearing safe mode. Software can then gate clocks
+ * on as required.
+ * On cold reset, all clocks are put in safe mode.
+ * On warm reset, safe mode is optionally and independently applied to debug
+ * clocks and normal (i.e.non-debug) clocks based on clock manager register
+ * settings. The default response for warm reset is to put all clocks in safe
+ * mode.
+ * The APIs in this group provide control of the Clock Manager safe mode warm
+ * reset response behavior.
+ * This type definition enumerates the safe mode clock domains under control of
+ * the Clock Manager.
+typedef enum ALT_CLK_SAFE_DOMAIN_e
+     * This enumeration literal specifies the normal safe mode domain. The
+     * normal domain consists of all clocks except debug clocks.
+    ALT_CLK_DOMAIN_NORMAL,
+     * This enumeration literal specifies the debug safe mode domain. The debug
+     * domain consists of all debug clocks.
+    ALT_CLK_DOMAIN_DEBUG
+} ALT_CLK_SAFE_DOMAIN_t;
+ * Clear the safe mode status of the Clock Manager following a reset.
+ * NOTE: Safe mode should only be cleared once clocks have been correctly
+ * configured.
+ALT_STATUS_CODE alt_clk_safe_mode_clear(void);
+ * Return whether the specified safe mode clock domain is in safe mode or not.
+ * \param       clk_domain
+ *              The safe mode clock domain to check whether in safe mode or not.
+ * \retval      TRUE            The safe mode clock domain is in safe mode.
+ * \retval      FALSE           The safe mode clock domain is not in safe mode.
+bool alt_clk_is_in_safe_mode(ALT_CLK_SAFE_DOMAIN_t clk_domain);
+/*! \addtogroup CLK_MGR_BYPASS PLL Bypass Control
+ * When a PLL is in bypass, the PLL clock logic is kept in reset. In this
+ * manner, the PLL clock can be free running while it stabilizes and achieves
+ * lock. The bypass logic isolates PLL configuration registers from the clock
+ * while changes are made to the PLL settings.
+ * The bypass controls are used by software to change the source clock input
+ * reference (for Peripheral and SDRAM PLLs) and is recommended when changing
+ * settings that may affect the ability of the VCO to maintain lock.  When a PLL
+ * is taken in or out of bypass the PLL output clocks will pause momentarily
+ * while the clocks are in transition, There will be no glitches or clocks
+ * shorter than the either the old or the new clock period.
+ * In summary, the PLL bypass controls permit:
+ * * Each PLL to be individually bypassed.
+ * * Bypass of all PLL clock outputs to \b osc1_clk or alternatively the PLLs
+ *   reference clock input source reference clock selection.
+ * * Isolation of a the PLL VCO frequency registers (multiplier and divider),
+     phase shift registers (negative phase) , and post scale counters.
+ * * Glitch free clock transitions.
+ * Disable bypass mode for the specified PLL. This operation takes the PLL out
+ * of bypass mode.
+ * \param       pll
+ *              The PLL to take out of bypass mode.
+ * \retval      ALT_E_BAD_ARG   The \e pll argument specified a non PLL clock
+ *                              value.
+ALT_STATUS_CODE alt_clk_pll_bypass_disable(ALT_CLK_t pll);
+ * Enable bypass mode for the specified PLL.
+ * \param       pll
+ *              The PLL to put into bypass mode.
+ * \param       use_input_mux
+ *              If TRUE then use the PLLs reference clock input source selection
+ *              to directly drive the bypass clock. If FALSE then use bypass
+ *              clock directly driven by the \b osc1_clk.
+ *                                  clock value.
+ * \retval      ALT_E_INV_OPTION    TRUE is an invalid option for
+ *                                  \e use_input_mux with the \e pll selection.
+ALT_STATUS_CODE alt_clk_pll_bypass_enable(ALT_CLK_t pll,
+                                          bool use_input_mux);
+ * Return whether the specified PLL is in bypass or not.
+ * \internal
+ * This function must also test the \b clkmgr.ctrl.safemode bit in
+ * addition to the PLLs bypass bit to tell whether the bypass mode is
+ * effect or not.
+ * \endinternal
+ * \param       pll
+ *              The PLL to check whether in bypass mode or not.
+ * \retval      ALT_E_TRUE      The PLL is in bypass mode.
+ * \retval      ALT_E_FALSE     The PLL is not in bypass mode.
+ *                              value.
+ALT_STATUS_CODE alt_clk_pll_is_bypassed(ALT_CLK_t pll);
+/*! \addtogroup CLK_MGR_GATE Clock Gating Control
+ * This functional group provides gating control of selected clock signals.
+ * When a clock is enabled, then its clock signal propogates to its respective
+ * clocked IP block(s).  When a clock is disabled, then its clock signal is
+ * prevented from propogating to its respective clocked IP block(s).
+ * The following clocks may be gated:
+ * * Main PLL Group
+ *   - l4_main_clk
+ *   - l3_mp_clk
+ *   - l4_mp_clk
+ *   - l4_sp_clk
+ *   - dbg_at_clk
+ *   - dbg_clk
+ *   - dbg_trace_clk
+ *   - dbg_timer_clk
+ *   - cfg_clk
+ *   - s2f_user0_clk
+ * * SDRAM PLL Group
+ *   - ddr_dqs_clk
+ *   - ddr_2x_clk
+ *   - ddr_dq_clk
+ *   - s2f_user2_clk
+ * * Peripheral PLL Group
+ *   - emac0_clk
+ *   - emac1_clk
+ *   - usb_mp_clk
+ *   - spi_m_clk
+ *   - can0_clk
+ *   - can1_clk
+ *   - gpio_db_clk
+ *   - s2f_user1_clk
+ *   - sdmmc_clk
+ *   - nand_clk
+ *   - nand_x_clk
+ *   - qspi_clk
+ * Disable the specified clock. Once the clock is disabled, its clock signal does
+ * not propogate to its clocked elements.
+ * \param       clk
+ *              The clock to disable.
+ * \retval      ALT_E_BAD_ARG   The \e clk argument designates a non gated clock
+ *                              value.
+ALT_STATUS_CODE alt_clk_clock_disable(ALT_CLK_t clk);
+ * Enable the specified clock. Once the clock is enabled, its clock signal
+ * propogates to its elements.
+ * \param       clk
+ *              The clock to enable.
+ *                              value.
+ALT_STATUS_CODE alt_clk_clock_enable(ALT_CLK_t clk);
+ * Return whether the specified clock is enabled or not.
+ * \param       clk
+ *              The clock to check whether enabled or not.
+ * \retval      ALT_E_TRUE      The clock is enabled.
+ * \retval      ALT_E_FALSE     The clock is not enabled.
+ *                              value.
+ALT_STATUS_CODE alt_clk_is_enabled(ALT_CLK_t clk);
+/*! \addtogroup CLK_MGR_CLK_SEL Clock Source Selection
+ * This API group provide access and control to the input reference clock source
+ * selection for a clock or PLL.
+ * \internal
+ * These are the clocks that have software configurable input reference clock
+ * source selection available. Each clock below is listed with its valid
+ * input reference clock source selections.
+ * + Valid reference clock input selections for \b sdram_pll_ref_clkin
+ *   - osc_clk_1
+ *   - osc_clk_2
+ *   - f2h_sdram_ref_clk
+ * + Valid reference clock input selections for \b periph_pll_ref_clkin
+ *   - osc_clk_1
+ *   - osc_clk_2,
+ *   - f2h_periph_ref_clk
+ * + Valid reference clock input selections for \b l4_mp_clk
+ *   - periph_base_clk
+ *   - main_clk
+ * + Valid reference clock input selections for \b l4_sp_clk
+ *   - main_clk
+ * + Valid reference clock input selections for \b sdmmc_clk
+ *   - main_nand_sdmmc_clk
+ *   - periph_nand_sdmmc_clk
+ * + Valid reference clock input selections for \b nand_clk
+ * + Valid reference clock input selections for \b qspi_clk
+ *   - main_qspi_clk
+ *   - periph_qspi_clk
+ * \endinternal
+ * Get the input reference clock source selection value for the specified clock
+ * or PLL.
+ * NOTE: This function returns a clock value even though \e clk may specify a
+ *       clock that does not have a selectable input reference clock source. In
+ *       this case, the clock value returned is the static clock source for the
+ *       specified clock. For example calling alt_clk_source_get() with \e clk
+ *       set to \ref ALT_CLK_MAIN_PLL will return \ref ALT_CLK_OSC1.
+ * \param       clk
+ *              The clock or PLL to retrieve the input reference clock source
+ *              selection value for.
+ * \returns     The clock's currently selected input reference clock source.
+ALT_CLK_t alt_clk_source_get(ALT_CLK_t clk);
+ * Set the specified clock's input reference clock source selection.
+ * \param       clk
+ *              The clock or PLL to set the input reference clock source
+ *              selection for.
+ * \param       ref_clk
+ *              The input reference clock source selection value.
+ * \retval      ALT_E_BAD_ARG       The \e clk argument designates a clock that
+ *                                  does not have a selectable input reference
+ *                                  clock source.
+ * \retval      ALT_E_INV_OPTION    The \e ref_clk argument designates a clock that
+ *                                  is an invalid reference clock source for the
+ALT_STATUS_CODE alt_clk_source_set(ALT_CLK_t clk,
+                                   ALT_CLK_t ref_clk);
+/*! \addtogroup CLK_MGR_FREQ Clock Frequency Control
+ * This API group provides access and control of the output frequency of a clock
+ * or PLL.
+ * Set the external clock frequency value.
+ * The function is used to specify the frequency of the external clock source as
+ * a measure of Hz. The supplied frequency should be within the Fmin and Fmax
+ * values allowed for the external clock source.
+ * \param       clk
+ *              The external clock source. Valid external clocks are
+ *              * \e ALT_CLK_OSC1
+ *              * \e ALT_CLK_OSC2
+ *              * \e ALT_CLK_F2H_PERIPH_REF
+ *              * \e ALT_CLK_F2H_SDRAM_REF
+ * \param       freq
+ *              The frequency of the external clock in Hz.
+ * \retval      ALT_E_BAD_ARG   A bad argument value was passed. Either the \e clk
+ *                              argument is bad or not a valid external clock
+ *                              source
+ * \retval      ALT_E_ARG_RANGE The frequency value violates the range constraints
+ *                              for the specified clock.
+ALT_STATUS_CODE alt_clk_ext_clk_freq_set(ALT_CLK_t clk,
+                                         alt_freq_t freq);
+ * Get the external clock frequency value.
+ * This function returns the frequency of the external clock source as
+ * \param       clk
+ * \retval      freq
+alt_freq_t alt_clk_ext_clk_freq_get(ALT_CLK_t clk);
+ * This type definition defines a structure to contain the generalized
+ * configuration settings for a PLL.
+typedef struct ALT_CLK_PLL_CFG_s
+    ALT_CLK_t           ref_clk;        /*!< PLL Reference Clock Source */
+    uint32_t            mult;           /*!< VCO Frequency Configuration -
+                                         *   Multiplier (M) value, range 1 to 4096
+    uint32_t            div;            /*!< VCO Frequency Configuration -
+                                         *   Divider (N) value, range 1 to 64
+    uint32_t            cntrs[6];       /*!< Post-Scale Counters (C0 - C5) -
+                                         *   range 1 to 512
+    uint32_t            pshift[6];      /*!< Phase Shift - 1/8 (45 degrees) of
+    									 *   negative phase shift per increment,
+                                         *   range 0 to 4096
+} ALT_CLK_PLL_CFG_t;
+ * Get the current PLL configuration.
+ * \param       pll
+ *              The PLL to get the configuration from.
+ * \param       pll_cfg
+ *              [out] Pointer to an output parameter variable for the returned
+ *              PLL configuration.
+ALT_STATUS_CODE alt_clk_pll_cfg_get(ALT_CLK_t pll,
+                                    ALT_CLK_PLL_CFG_t* pll_cfg);
+ * Set the PLL configuration using the configuration parameters specified in
+ * \e pll_cfg.
+ * \param       pll
+ *              The PLL to set the configuration for.
+ * \param       pll_cfg
+ *              Pointer to a ALT_CLK_PLL_CFG_t structure specifying the desired
+ALT_STATUS_CODE alt_clk_pll_cfg_set(ALT_CLK_t pll,
+                                    const ALT_CLK_PLL_CFG_t* pll_cfg);
+ * Get the current PLL VCO frequency configuration.
+ * \param       pll
+ *              The PLL to get the VCO frequency configuration for.
+ * \param       mult
+ *              [out] Pointer to an output variable for the returned
+ *              configured PLL VCO multiplier (M) value.
+ * \param       div
+ *              configured PLL VCO divider (N) value.
+ALT_STATUS_CODE alt_clk_pll_vco_cfg_get(ALT_CLK_t pll,
+                                        uint32_t* mult,
+                                        uint32_t* div);
+ * Set the PLL VCO frequency configuration using the supplied multiplier and
+ * divider arguments.
+ * \param       pll
+ *              The PLL to set the VCO frequency configuration for.
+ * \param       mult
+ *              The PLL VCO multiplier (M). Expected argument range 1 to 4096.
+ * \param       div
+ *              The PLL VCO divider (N). Expected argument range 1 to 64.
+ALT_STATUS_CODE alt_clk_pll_vco_cfg_set(ALT_CLK_t pll,
+                                        uint32_t mult,
+                                        uint32_t div);
+ * Get the VCO frequency of the specified PLL.
+ * \param       pll
+ *              The PLL to retrieve the VCO frequency from.
+ * \param       freq
+ *              [out] Pointer to the an output parameter variable to return the
+ *              PLL VCO frequency value. The frequency value is returned as a
+ *              measures of Hz.
+ *                              the \e pll argument is invalid or a bad
+ *                              \e freq pointer value was passed.
+ALT_STATUS_CODE alt_clk_pll_vco_freq_get(ALT_CLK_t pll,
+                                         alt_freq_t* freq);
+ * Get the PLL frequency guard band value.
+ * \param       pll
+ *              The PLL from which to return the current guard band value.
+ * \returns     The current guard band range in effect for the PLL.
+uint32_t alt_clk_pll_guard_band_get(ALT_CLK_t pll);
+ * Set the PLL frequency guard band value.
+ * Once a PLL has achieved lock, any changes to the PLL VCO frequency that are
+ * within a specific guard band range (default value 20%) of the reference
+ * period should not cause the PLL to lose lock.
+ * Programmatic changes to the PLL frequency within this guard band range are
+ * permitted to be made without the risk of breaking lock during the transition
+ * to the new frequency.
+ * The clk_mgr_pll_guard_band_set() function changes the guard band from its
+ * current value to permit a more lenient or stringent policy to be in effect in
+ * the implementation of the functions configuring PLL VCO frequency. The
+ * rationale for changing the default guard band value might be to accommodate
+ * unexpected environmental conditions (noise, temperature, and other
+ * instability factors) that may affect the PLLs ability to maintain lock during
+ * a frequency change.
+ * \param       pll
+ *              The PLL to set the guard band value for.
+ * \param       guard_band
+ *              The guard band value. Value should be 0 <= \e guard_band <= 100.
+ * \retval      ALT_E_ARG_RANGE The guard band value violates its range constraint.
+ALT_STATUS_CODE alt_clk_pll_guard_band_set(ALT_CLK_t pll,
+                                           uint32_t guard_band);
+ * Get the configured divider value for the specified clock.
+ * This function is used to get the configured values of both internal and
+ * external clock dividers.  The internal divider (PLL counters C0-C5) values
+ * are retrieved by specifying the clock name that is the divider output
+ * (e.g. ALT_CLK_MPU is used to get the Main PLL C0 counter value). \n
+ * It returns the actual divider value, not the encoded bitfield stored
+ * in the register, due to the variety of different encodings.
+ * \param       clk
+ *              The clock divider to get the value from.
+ * \param       div
+ *              [out] Pointer to an output variable for the returned clock
+ *              divider value.
+ * \retval      ALT_E_BAD_ARG   An invalid clock argument was specified or a
+ *                              clock that does not have a divider.
+ALT_STATUS_CODE alt_clk_divider_get(ALT_CLK_t clk,
+                                    uint32_t* div);
+ * Set the divider value for the specified clock.
+ * This function is used to set the values of both internal and external clock
+ * dividers.  The internal divider (PLL counters C0-C5) values are set by
+ * specifying the clock name that is the divider output (e.g. ALT_CLK_MPU is
+ * used to set the Main PLL C0 counter value).
+ * \param       clk
+ *              The clock divider to set the value for.
+ * \param       div
+ *              The clock divider value. NOTE: The valid range of clock divider
+ *              values depends on the clock being configured. This is the
+ *              real divisor ratio, not how the divisor is coded into the
+ *              register, and is always one or greater.
+ * \retval      ALT_E_ARG_RANGE The divider value violates the range constraints
+ *                              for the clock divider.
+ALT_STATUS_CODE alt_clk_divider_set(ALT_CLK_t clk,
+                                    uint32_t div);
+ * Get the output frequency of the specified clock.
+ * \param       clk
+ *              The clock to retrieve the output frequency from.
+ * \param       freq
+ *              clock output frequency value. The frequency value is returned as
+ *              a measures of Hz.
+ *                              the \e clk argument is invalid or a bad
+ALT_STATUS_CODE alt_clk_freq_get(ALT_CLK_t clk,
+/*! \addtogroup CLK_MGR_INT Clock Manager Interrupt Management
+ * The functions in this group provide management of interrupts originating from
+ * The following interrupt request (IRQ) signals are sourced from the Clock
+ * Manager:
+ * * \b clkmgr_IRQ - Clock Manager lock status interrupt output.  The PLL lock
+ *                   status interrupt is the logical \e OR of six interrupt
+ *                   sources defining the loss or achievement of lock status for
+ *                   each PLL. The six PLL lock status conditions are:
+ *                   - Main PLL Achieved Lock
+ *                   - Main PLL Lost Lock
+ *                   - Peripheral PLL Achieved Lock
+ *                   - Peripheral PLL Lost Lock
+ *                   - SDRAM PLL Achieved Lock
+ *                   - SDRAM PLL Lost Lock
+ *                   They are enumeratated by the type \ref ALT_CLK_PLL_LOCK_STATUS_t.
+ *                   Each PLL lock condition may be individually disabled/enabled
+ *                   as a contributor to the determination of the \b clkmgr_IRQ
+ *                   assertion status.
+ *                   The alt_clk_lock_status_clear() function is used to clear
+ *                   the PLL lock conditions causing the \b clkmgr_IRQ
+ *                   assertion.
+ * * \b mpuwakeup_IRQ - MPU wakeup interrupt output. This interrupt notifies the
+ *                      MPU to "wake up" after a transition of the Main PLL into
+ *                      or out of bypass mode has been safely achieved. The need
+ *                      for the "wake up" notification is because the PLL clocks
+ *                      pause for a short number of clock cycles during bypass
+ *                      state transition. ARM recommeds that the CPUs are placed
+ *                      in standby if the clocks are ever paused.
+ * NOTE: \b mpuwakeup_IRQ appears to be an Altera private interrupt and may not
+ *        be part of the public API although clearly it has important utility in
+ *        implementing safe changes to PLL settings and transitions into and out
+ *        of bypass mode.
+ * Disable the \b clkmgr_IRQ interrupt signal source lock status condition(s).
+ * This function disables one or more of the lock status conditions as
+ * contributors to the \b clkmgr_IRQ interrupt signal state.
+ * NOTE: A set bit for a PLL lock status condition in the mask value does not
+ * have the effect of enabling it as a contributor to the \b clkmgr_IRQ
+ * interrupt signal state. The function alt_clk_irq_enable is used to enable PLL
+ * lock status source condition(s).
+ *              Specifies the PLL lock status conditions to disable as interrupt
+ *              source contributors. \e lock_stat_mask is a mask of logically
+ *              OR'ed ALT_CLK_PLL_LOCK_STATUS_t values that designate the PLL lock
+ *              conditions to disable.
+ALT_STATUS_CODE alt_clk_irq_disable(ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask);
+ * Enable the \b clkmgr_IRQ interrupt signal source lock status condition(s).
+ * This function enables one or more of the lock status conditions as
+ * NOTE: A cleared bit for any PLL lock status condition in the mask value does
+ * not have the effect of disabling it as a contributor to the \b clkmgr_IRQ
+ * interrupt signal state. The function alt_clk_irq_disable is used to disable
+ * PLL lock status source condition(s).
+ *              Specifies the PLL lock status conditions to enable as interrupt
+ *              conditions to enable.
+ALT_STATUS_CODE alt_clk_irq_enable(ALT_CLK_PLL_LOCK_STATUS_t lock_stat_mask);
+/*! \addtogroup CLK_MGR_GROUP_CFG Clock Group Configuration
+ * This API provides the ability to safely set the configuration of a clock
+ * group with a single function call.
+ * A clock group is defined as set of clocks and signals generated from a common
+ * PLL VCO. The PLL and its derived clocks are treated as a single clock
+ * group. The clocks sourced directly or indirectly from the PLL may or may not
+ * have these features:
+ * * Clock Gates
+ * * Clock Dividers
+ * * Clock Source Selection Options
+ * The use case for application of the Clock Group Configuration functions is the
+ * ability to safely configure an entire clock group from a known good clock
+ * group configuration using the run-time function alt_clk_group_cfg_raw_set().
+ * A known good clock group configuration may be generated by one of the
+ * following methods:
+ * * As static design information generated by an ACDS clock configuration tool
+ *   and passed to embedded software for dynamic loading.
+ * * By calling alt_clk_group_cfg_raw_get() at run-time from an SoC FPGA that has
+ *   programmatically established a known good clock group configuration using
+ *   the clock manager API configuration functions.
+ * Get the raw configuration state of the designated clock group.
+ * This function is used to capture the configuration state of the specified
+ * clock group in a private (raw) data structure.  The raw data structure may be
+ * saved and used later to restore the clock group configuration using
+ * alt_clk_group_cfg_raw_get().
+ * \param       clk_group
+ *              The clock group configuration to capture.
+ * \param       clk_group_raw_cfg
+ *              [out] A pointer to a private (raw) data structure to store the
+ *              captured clock group configuration.
+ * \retval      ALT_E_ERROR     Details about error status code
+ALT_STATUS_CODE alt_clk_group_cfg_raw_get(ALT_CLK_GRP_t clk_group,
+                                          ALT_CLK_GROUP_RAW_CFG_t* clk_group_raw_cfg);
+ * Set the clock group configuration.
+ * This function is used to safely set the configuration state of a clock
+ * group from a raw clock group configuration specification.  The raw clock
+ * group configuration specification may be a configuration previously
+ * captured with alt_clk_group_cfg_raw_get() or a group clock configuration
+ * generated by an external utility.
+ *              A pointer to the specification to use in the configuration of
+ *              the clock group.
+ * \retval      ALT_E_BAD_VERSION   The clock group configuration specification is
+ *                                  invalid for this device.
+ALT_STATUS_CODE alt_clk_group_cfg_raw_set(const ALT_CLK_GROUP_RAW_CFG_t* clk_group_raw_cfg);
+#ifdef __cplusplus
+#endif  /* __ALT_CLK_MGR_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_generalpurpose_io.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_generalpurpose_io.h
index 0000000..d8a38f5
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_generalpurpose_io.h
@@ -0,0 +1,1236 @@
+/*! \file
+ *  Altera - GPIO Module
+* OF SUCH DAMAGE.
+#ifndef __ALT_GPIO_H__
+#define __ALT_GPIO_H__
+#include <stdint.h>
+#include "hwlib.h"
+#ifdef __cplusplus
+extern "C" {
+#define     ALT_GPIO_BITMASK                0x1FFFFFFF
+/* If the GPIO special test mode flag was not defined in the makefile,   */
+    /* set the ALT_GPIO_DATAREAD_TEST_MODE flag to false to specify that     */
+    /* the production code version of alt_gpio_port_data_read() is included. */
+    /* If the flag is defined as true in the makefile, then the test version */
+    /* located in the test code file is substituted instead of the version   */
+    /* in this file.                                                         */
+#ifndef     ALT_GPIO_DATAREAD_TEST_MODE
+#define     ALT_GPIO_DATAREAD_TEST_MODE     false
+#endif
+/*! \addtogroup ALT_GPIO_API The General Purpose Input/Output Manager API
+ * This module defines the General Purpose Input/Output Manager API for
+ * accessing, configuring, and controlling the General Purpose Input/Output
+ * Manager resources. These include both the general-purpose GPIO signals and
+ * the input-only GPI signals that are shared with the DDR interface.\n \n
+ * The GPIO API presents two views or perspectives of the GPIO signals. The first
+ * is to view the GPIO signals in a traditional way, as separate GPIO ports
+ * each comprised of a number of GPIO bits. The second perspective is of a
+ * unified flat view that presents the GPIO and GPI signals as a set of indexed
+ * bits, a view that allows the programmer to mostly ignore the port and pin
+ * hardware configuration and read/write/configure the GPIO and GPI signals
+ * independently of the underlying hardware implementation.
+/*! \addtogroup ALT_GPIO_API_CONFIG General-Purpose IO Configuration Functions
+ * This functional group contains functions to control, configure and manage
+ * the general-purpose IO signals as individual signals or as groups of signals.
+ * This group of functions can operate on multiple bits within the same GPIO
+ * port and accepts a bit mask to specify which bits an operation will operate on.
+ * Other bits within the same GPIO port are not changed.
+ * This example shows how multiple drivers or applications can use this feature
+ * to easily prevent conflict while accessing the same GPIO port:
+ * \verbatim
+ #define DRIVER_0_GPIO_MSK   0x0010FF03;
+ #define DRIVER_1_GPIO_MSK   0x002000F8;
+ #define DRIVER_2_GPIO_MSK   0x03C00004;
+ #define DRIVER_3_GPIO_MSK   0x000F0000;
+    alt_gpio_port_data_write(ALT_GPIO_PORTA, DRIVER_0_GPIO_MSK, init_val0);
+    alt_gpio_port_data_write(ALT_GPIO_PORTA, DRIVER_1_GPIO_MSK, init_val1);
+    alt_gpio_port_data_write(ALT_GPIO_PORTA, DRIVER_2_GPIO_MSK, init_val2);
+    alt_gpio_port_data_write(ALT_GPIO_PORTA, DRIVER_3_GPIO_MSK, init_val3);
+    alt_gpio_port_int_type_set(ALT_GPIO_PORTA, DRIVER_1_GPIO_MSK, config_val1);
+ \endverbatim
+ * This type definition enumerates the data direction (input or output) of
+ * the GPIO signals.
+typedef enum ALT_GPIO_PIN_DIR_e
+    ALT_GPIO_PIN_INPUT,
+    ALT_GPIO_PIN_OUTPUT
+} ALT_GPIO_PIN_DIR_t;
+ * This type definition enumerates the type of interrupt source
+ * (level-triggered or edge-triggered) of the GPIO signals.
+typedef enum ALT_GPIO_PIN_TYPE_e
+    ALT_GPIO_PIN_LEVEL_TRIG_INT,
+    ALT_GPIO_PIN_EDGE_TRIG_INT
+} ALT_GPIO_PIN_TYPE_t;
+ * This type definition enumerates the polarity of the interrupt sources
+ * (falling-edge or rising-edge for edge-triggered interrupts, active-low or
+ * active-high for level-triggered interrupts) of the GPIO signals.
+typedef enum ALT_GPIO_PIN_POL_e
+    /*! Indicates active-low for level-triggered interrupts and
+     * falling-edge for edge-triggered interrupts */
+    ALT_GPIO_PIN_ACTIVE_LOW,
+    /*! Indicates active-high for level-triggered interrupts and
+     * rising-edge for edge-triggered interrupt */
+    ALT_GPIO_PIN_ACTIVE_HIGH
+} ALT_GPIO_PIN_POL_t;
+ * This type definition enumerates whether or not the debounce metastability
+ * flip-flops are inserted or not. These are used to debounce signals presented
+ * to the GPIO inputs. A signal must be steady for two periods of the
+ * gpio_db_clk clock before it is considered valid. The frequency of the
+ * gpio_db_clk clock may be set using the Clock Manager API.
+typedef enum ALT_GPIO_PIN_DEBOUNCE_e
+    ALT_GPIO_PIN_NODEBOUNCE,
+    ALT_GPIO_PIN_DEBOUNCE
+} ALT_GPIO_PIN_DEBOUNCE_t;
+ * This type definition enumerates whether or not level-sensitive interrupts
+ * are synchronized to the internal pclk_intr clock. It has no effect for GPIO
+ * signals that are selected as outputs, or if the interrupt is not enabled,
+ * or if the interrupt is set to be edge-triggered. This is a port-wide option.
+typedef enum ALT_GPIO_PIN_SYNC_e
+    ALT_GPIO_PIN_NOSYNC,
+    ALT_GPIO_PIN_SYNC
+} ALT_GPIO_PIN_SYNC_t;
+ * This type definition enumerates the possible data states of the GPIO bits.
+typedef enum ALT_GPIO_PIN_DATA_e
+    ALT_GPIO_PIN_DATAZERO,
+    ALT_GPIO_PIN_DATAONE
+} ALT_GPIO_PIN_DATA_t;
+ * This type definition enumerates the GPIO ports that the GPIO manager
+ * handles.
+typedef enum ALT_GPIO_PORT_e
+     * \b Port \b A - 29-bit GPIO port A.
+    ALT_GPIO_PORTA,
+     * \b Port \b B - 29-bit GPIO port B.
+    ALT_GPIO_PORTB,
+     * \b Port \b C - 29-bit GPIO port C. \n 13 bits are used for GPIO signals,
+     *                14 bits are used for GPI-only signals that are shared
+     *                with the DDR interface, 2 bits are not used. Some signals
+     *                may not be connected on some versions. See the relevant
+     *                pin mux data.
+    ALT_GPIO_PORTC,
+     * \b Unknown \b Port - Used to indicate an error.
+    ALT_GPIO_PORT_UNKNOWN
+} ALT_GPIO_PORT_t;
+ * This type definition enumerates the individual bits within the GPIO ports
+ * used by the GPIO manager. The bit-ordering must match the hardware
+ * bit-ordering. Since the ordering and packing of bitfields is not
+ * standardized in C/C++, the following are defined as masks. \n
+ * For example, to set bits 3 and 4 of GPIO port B outputs (assuming the bits
+ * had previously been set to outputs), the user could use the syntax: \par
+ * \b alt_gpio_port_data_write(\b ALT_GPIO_PORTB, \b ALT_GPIO_BIT3 \b | \b
+ * ALT_GPIO_BIT4);
+typedef enum ALT_GPIO_PORTBIT_e
+    ALT_GPIO_BIT0 = ALT_TWO_TO_POW0,
+    ALT_GPIO_BIT1 = ALT_TWO_TO_POW1,
+    ALT_GPIO_BIT2 = ALT_TWO_TO_POW2,
+    ALT_GPIO_BIT3 = ALT_TWO_TO_POW3,
+    ALT_GPIO_BIT4 = ALT_TWO_TO_POW4,
+    ALT_GPIO_BIT5 = ALT_TWO_TO_POW5,
+    ALT_GPIO_BIT6 = ALT_TWO_TO_POW6,
+    ALT_GPIO_BIT7 = ALT_TWO_TO_POW7,
+    ALT_GPIO_BIT8 = ALT_TWO_TO_POW8,
+    ALT_GPIO_BIT9 = ALT_TWO_TO_POW9,
+    ALT_GPIO_BIT10 = ALT_TWO_TO_POW10,
+    ALT_GPIO_BIT11 = ALT_TWO_TO_POW11,
+    ALT_GPIO_BIT12 = ALT_TWO_TO_POW12,
+    ALT_GPIO_BIT13 = ALT_TWO_TO_POW13,
+    ALT_GPIO_BIT14 = ALT_TWO_TO_POW14,
+    ALT_GPIO_BIT15 = ALT_TWO_TO_POW15,
+    ALT_GPIO_BIT16 = ALT_TWO_TO_POW16,
+    ALT_GPIO_BIT17 = ALT_TWO_TO_POW17,
+    ALT_GPIO_BIT18 = ALT_TWO_TO_POW18,
+    ALT_GPIO_BIT19 = ALT_TWO_TO_POW19,
+    ALT_GPIO_BIT20 = ALT_TWO_TO_POW20,
+    ALT_GPIO_BIT21 = ALT_TWO_TO_POW21,
+    ALT_GPIO_BIT22 = ALT_TWO_TO_POW22,
+    ALT_GPIO_BIT23 = ALT_TWO_TO_POW23,
+    ALT_GPIO_BIT24 = ALT_TWO_TO_POW24,
+    ALT_GPIO_BIT25 = ALT_TWO_TO_POW25,
+    ALT_GPIO_BIT26 = ALT_TWO_TO_POW26,
+    ALT_GPIO_BIT27 = ALT_TWO_TO_POW27,
+    ALT_GPIO_BIT28 = ALT_TWO_TO_POW28,
+    ALT_GPIO_BIT29 = ALT_TWO_TO_POW29,              /* Not currently used */
+    ALT_GPIO_BIT30 = ALT_TWO_TO_POW30,              /* Not currently used */
+    ALT_GPIO_BIT31 = (int32_t) (1UL<<31),           /* Not currently used */
+    ALT_GPIO_BITNUM_MAX = (28),
+    ALT_GPIO_BIT_MAX = (1 << ALT_GPIO_BITNUM_MAX),
+    ALT_END_OF_GPIO_PORT_SIGNALS = (32)
+} ALT_GPIO_PORTBIT_t;
+ * Sets the specified GPIO data bits to use the data direction(s)
+ * specified.
+ * \param       gpio_pid
+ *              The GPIO port identifier.
+ * \param       mask
+ *              The group of bits (where mask bits equal one) to apply this
+ *              operation to. Other bits (where mask bits equal zero) are
+ *              not changed. Specify mask = ALT_GPIO_BITMASK (0x1FFFFFFF) to
+ *              configure all data direction bits of the port.
+ * \param       config
+ *              The data-directions of the bits to be set in this operation.
+ *              Individual bits are: \n \b 0 - Use as an input (default). \n
+ *              \b 1 - Use as an output.
+ * \retval      ALT_E_BAD_ARG   Bad input argument.
+ALT_STATUS_CODE alt_gpio_port_datadir_set(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t mask, uint32_t config);
+ * Returns the data direction configuration of selected bits of the
+ * specified GPIO module.
+ * \param       gpio_pid
+ * \param       mask
+ *              The group of bits (where mask bits equal one) to read and
+ *              return. Other bits (where mask bits equal zero) are returned
+ *              as zero. Specify mask = ALT_GPIO_BITMASK (0x1FFFFFFF) to
+ *              return all data direction bits of the port.
+ * \retval      uint32_t \n Individual bits are: \n \b 0 - The signal is
+ *              configured as an input.
+ *              \n \b 1 - The signal is configured as an output.
+uint32_t alt_gpio_port_datadir_get(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t mask);
+ * Sets the GPIO data outputs of the specified GPIO module to a logic one or
+ * zero. Outputs are only set if the data direction for those bits is also
+ * set to configure them as outputs.
+ * \param       gpio_pid
+ * \param       mask
+ *              The group of bits (mask bits equal one) to apply this
+ *              operation to. Other bits (mask bits equal zero) are
+ *              not changed.
+ * \param       val
+ *              The 32-bit word to write to the GPIO outputs. Only the 29 LSBs
+ *              are used. Setting the three MSBs causes an error.
+ALT_STATUS_CODE alt_gpio_port_data_write(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t mask, uint32_t val);
+ * Returns the value of the data inputs of the specified GPIO module. This is
+ * the current logic value of the pin, whether set to be an input or an output.
+ * \n If a given signal is set to be an output, this input value can be read to
+ * determine if the pin is grounded, pulled high, or is floating.
+ * \param       gpio_pid
+ * \param       mask
+ *              The group of bits (where mask bits equal one) to return. Other
+ *              bits (where mask bits equal zero) are returned as zero. Specify
+ *              mask = ALT_GPIO_BITMASK (0x1FFFFFFF) to return all data bits of
+ *              the port.
+ * \retval      uint32_t   The current value of the GPIO module input signals.
+uint32_t alt_gpio_port_data_read(ALT_GPIO_PORT_t gpio_pid, uint32_t mask);
+/*! \addtogroup ALT_GPIO_INT General-Purpose IO Interrupt Functions
+ * This functional group contains functions to control and manage the
+ * interrupts of the General-Purpose IO modules.
+ * Sets edge-triggered or level-triggered interrupt configuration for the
+ * specified signals of the specified GPIO module.
+ * \param       gpio_pid
+ * \param       mask
+ *              configure all interrupt type bits of the port.
+ * \param       config
+ *              The interrupt configuration to write. Individual bits
+ *              are: \n \b 0 - Set the
+ *              interrupt for this bit to be level-sensitive (default). \n \b
+ *              1 - Set the interrupt for this bit to be edge-sensitive.
+ * \retval      ALT_E_BAD_ARG   Invalid input data.
+ALT_STATUS_CODE alt_gpio_port_int_type_set(ALT_GPIO_PORT_t gpio_pid,
+ * Returns the interrupt configuration (edge-triggered or level-triggered) for
+ * the specified bits of the specified GPIO module.
+ * \param       gpio_pid
+ * \param       mask
+ *              mask = ALT_GPIO_BITMASK (0x1FFFFFFF) to return all configuration
+ *              bits of the port.
+ *              The current interrupt source configuration. Individual bits
+ *              are: \n \b 0 - The interrupt for this bit is set to be
+ *              level-sensitive. \n \b 1 -
+ *              The interrupt for this bit is set to be edge-sensitive.
+uint32_t alt_gpio_port_int_type_get(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t mask);
+ * Sets the interrupt polarity of the signals of the specified GPIO register
+ * (when used as inputs) to active-high or active-low (for level-sensitive
+ * interrupts) or to rising-edge or falling-edge (for edge-sensitive interrupts).
+ * \param       gpio_pid
+ * \param       mask
+ *              not changed.
+ * \param       config
+ *              The interrupt polarity configuration to set. Individual bits
+ *              are: \n \b 0 - Set the interrupt polarity for this bit to
+ *              active-low or falling-edge mode (default). \n \b 1 - Set the
+ *              interrupt polarity for this bit to active-high or rising-edge mode.
+ALT_STATUS_CODE alt_gpio_port_int_pol_set(ALT_GPIO_PORT_t gpio_pid,
+ * Returns the active-high or active-low polarity configuration for the
+ * possible interrupt sources of the specified GPIO module.
+ * \param       gpio_pid
+ * \param       mask
+ *              mask = ALT_GPIO_BITMASK (0x1FFFFFFF) to return all the
+ *              configuration bits of the port.
+ *              The current polarity configuration. Individual bits are: \n
+ *              \b 0 = The interrupt polarity for this bit is set to
+ *              active-low or falling-edge mode. \n \b 1 = The interrupt
+ *              polarity for this bit is set to active-high or rising-edge mode.
+uint32_t alt_gpio_port_int_pol_get(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t mask);
+ * Sets the debounce configuration for input signals of the specified GPIO
+ * module. If debounce is selected, metastability flip-flops are inserted to
+ * debounce signals presented to the GPIO inputs. A signal must be steady for
+ * two periods of the gpio_db_clk clock before it is considered valid. The
+ * frequency of the gpio_db_clk clock may be set using the Clock Manager API.
+ * \param       gpio_pid
+ * \param       mask
+ *              configure the debounce setting for all bits of the port.
+ * \param       config
+ *              The debounce configuration to set. Individual bits are: \n
+ *              \b 0 - Debounce is not selected for this signal (default). \n
+ *              \b 1 - Debounce is selected for this signal.
+ALT_STATUS_CODE alt_gpio_port_debounce_set(ALT_GPIO_PORT_t gpio_pid,
+ * Returns the debounce configuration for the input signals of the specified
+ * GPIO register. If debounce is selected, metastability flip-flops are
+ * inserted to debounce signals presented to the GPIO inputs.
+ * \param       gpio_pid
+ * \param       mask
+ *              mask = ALT_GPIO_BITMASK (0x1FFFFFFF) to return all debounce
+ *              The current debounce configuration.Individual bits are: \n
+ *              \b 0 - Debounce is not selected for this signal. \n \b 1 -
+ *              Debounce is selected for this signal.
+uint32_t alt_gpio_port_debounce_get(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t mask);
+ * Sets the synchronization configuration for the signals of the specified
+ * GPIO register. This allows for synchronizing level-sensitive interrupts to
+ * an internal clock signal. This is a port-wide option that controls all
+ * level-sensitive interrupt signals of that GPIO port.
+ * \param       gpio_pid
+ * \param       config
+ *              \n \b Any \b non-zero \b value - Synchronize to internal clock signal.
+ *              \n \b Zero - Do not synchronize to internal clock signal.
+ALT_STATUS_CODE alt_gpio_port_sync_set(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t config);
+ * Returns the synchronization configuration for the signals of the
+ * specified GPIO register. This allows for synchronizing level-sensitive
+ * interrupts to the internal clock signal. This is a port-wide option that
+ * controls all level-sensitive interrupt signals of that GPIO port.
+ * \param       gpio_pid
+ * \retval      ALT_E_TRUE      Synchronization to clock is enabled for
+ *                              level-sensitive interrupts.
+ * \retval      ALT_E_FALSE     Synchronization to clock is disabled for
+ * \retval      ALT_E_BAD_ARG   Invalid input argument.
+ALT_STATUS_CODE alt_gpio_port_sync_get(ALT_GPIO_PORT_t gpio_pid);
+ * Configures a group of GPIO signals with identical setup parameters. Allows
+ * for configuring all parameters of a given port at one time.
+ * \param       gpio_pid
+ * \param       mask
+ *              The group of bits to apply this operation to. Other bits (mask
+ *              set to zero) are not changed.
+ * \param       dir
+ *              Data direction.
+ * \param       type
+ *              Edge-triggered or level-triggered interrupts.
+ * \param       pol
+ *              Active-high or active-low polarity.
+ * \param       debounc
+ *              Debounce signals or not.
+ * \param       data
+ *              Set the data output to this value.
+ALT_STATUS_CODE alt_gpio_port_config(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t mask, ALT_GPIO_PIN_DIR_t dir, ALT_GPIO_PIN_TYPE_t type,
+        ALT_GPIO_PIN_POL_t pol, ALT_GPIO_PIN_DEBOUNCE_t debounc,
+        uint32_t data);
+ * Enables the specified GPIO data input interrupts.
+ * \param       gpio_pid
+ * \param       config
+ *              Individual bit interrupt enables \n
+ *              \b 0 - Interrupt disabled. \n
+ *              \b 1 - Interrupt enabled.
+ALT_STATUS_CODE alt_gpio_port_int_enable(ALT_GPIO_PORT_t gpio_pid, uint32_t config);
+ * Disables the specified GPIO data module interrupt.
+ * \param       gpio_pid
+ * \param       config
+ALT_STATUS_CODE alt_gpio_port_int_disable(ALT_GPIO_PORT_t gpio_pid, uint32_t config);
+ *  Returns the current state of the specified GPIO port interrupts enables.
+ * \param       gpio_pid
+ *              The interrupt enable configuration that was read. Individual bits
+ *              are: \n \b 0 = The interrupt for this bit is not enabled. \n \b
+ *              1 = The interrupt for this bit is enabled.
+uint32_t alt_gpio_port_int_enable_get(ALT_GPIO_PORT_t gpio_pid);
+ * Masks or unmasks selected interrupt source bits of the data register of
+ * the specified GPIO module. Uses a second bit mask to determine which
+ * signals may be changed by this call.
+ * \param       gpio_pid
+ * \param       mask
+ *              Which bits to change among the port \n \b 0 =
+ *              Do not change this bit. \n \b 1 = Allow this bit to change.
+ * \param       val
+ *              The interrupt mask to write. Individual bits are: \n \b 0 =
+ *              Do not mask the interrupt for this bit (default). \n \b 1 =
+ *              Mask the interrupt for this bit.
+ALT_STATUS_CODE alt_gpio_port_int_mask_set(ALT_GPIO_PORT_t gpio_pid,
+ * Returns the interrupt mask of the specified GPIO module.
+ * \param       gpio_pid
+ *              The interrupt mask that was read. Individual bits are: \n
+ *              \b 0 = The interrupt for this bit is not masked. \n \b 1 = The
+ *              interrupt for this bit is masked.
+uint32_t alt_gpio_port_int_mask_get(ALT_GPIO_PORT_t gpio_pid);
+ * Returns the interrupt pending status of all signals of the specified GPIO
+ * register.
+ * \param       gpio_pid
+ *              The current interrupt pending status. Individual bits are: \n
+ *              \b 0 - The interrupt for this bit is not pending. \n \b 1 -
+ *              The interrupt for this bit is pending.
+uint32_t alt_gpio_port_int_status_get(ALT_GPIO_PORT_t gpio_pid);
+ * Clear the interrupt pending status of selected signals of the
+ * \param       gpio_pid
+ * \param       clrmask
+ *              The interrupt bits to clear. Individual bits are: \n \b 0 -
+ *              The interrupt for this bit will not be changed. \n \b 1 -
+ *              The interrupt for this bit will be cleared.
+ALT_STATUS_CODE alt_gpio_port_int_status_clear(ALT_GPIO_PORT_t gpio_pid,
+        uint32_t clrmask);
+/*! \addtogroup ALT_GPIO_BITVIEW General-Purpose IO via Bit Index
+ * This functional group presents a perspective of the General-Purpose IO
+ * signals as individual GPIO and GPI bits spread across a number of signals
+ * across several GPIO ports. This allows the programmer the freedom to generally
+ * ignore the underlying port and signal structure of the GPIO hardware if
+ * desired.
+ * This type definition enumerates the individual bits as one flat array spread
+ * across the multiple GPIO ports handled by the GPIO manager. The bit-ordering
+ * must match the hardware bit-ordering.
+typedef enum ALT_GPIO_1BIT_e
+    ALT_GPIO_1BIT_0,
+    ALT_GPIO_1BIT_1,
+    ALT_GPIO_1BIT_2,
+    ALT_GPIO_1BIT_3,
+    ALT_GPIO_1BIT_4,
+    ALT_GPIO_1BIT_5,
+    ALT_GPIO_1BIT_6,
+    ALT_GPIO_1BIT_7,
+    ALT_GPIO_1BIT_8,
+    ALT_GPIO_1BIT_9,
+    ALT_GPIO_1BIT_10,
+    ALT_GPIO_1BIT_11,
+    ALT_GPIO_1BIT_12,
+    ALT_GPIO_1BIT_13,
+    ALT_GPIO_1BIT_14,
+    ALT_GPIO_1BIT_15,
+    ALT_GPIO_1BIT_16,
+    ALT_GPIO_1BIT_17,
+    ALT_GPIO_1BIT_18,
+    ALT_GPIO_1BIT_19,
+    ALT_GPIO_1BIT_20,
+    ALT_GPIO_1BIT_21,
+    ALT_GPIO_1BIT_22,
+    ALT_GPIO_1BIT_23,
+    ALT_GPIO_1BIT_24,
+    ALT_GPIO_1BIT_25,
+    ALT_GPIO_1BIT_26,
+    ALT_GPIO_1BIT_27,
+    ALT_GPIO_1BIT_28,
+    ALT_GPIO_1BIT_29,
+    ALT_GPIO_1BIT_30,
+    ALT_GPIO_1BIT_31,
+    ALT_GPIO_1BIT_32,
+    ALT_GPIO_1BIT_33,
+    ALT_GPIO_1BIT_34,
+    ALT_GPIO_1BIT_35,
+    ALT_GPIO_1BIT_36,
+    ALT_GPIO_1BIT_37,
+    ALT_GPIO_1BIT_38,
+    ALT_GPIO_1BIT_39,
+    ALT_GPIO_1BIT_40,
+    ALT_GPIO_1BIT_41,
+    ALT_GPIO_1BIT_42,
+    ALT_GPIO_1BIT_43,
+    ALT_GPIO_1BIT_44,
+    ALT_GPIO_1BIT_45,
+    ALT_GPIO_1BIT_46,
+    ALT_GPIO_1BIT_47,
+    ALT_GPIO_1BIT_48,
+    ALT_GPIO_1BIT_49,
+    ALT_GPIO_1BIT_50,
+    ALT_GPIO_1BIT_51,
+    ALT_GPIO_1BIT_52,
+    ALT_GPIO_1BIT_53,
+    ALT_GPIO_1BIT_54,
+    ALT_GPIO_1BIT_55,
+    ALT_GPIO_1BIT_56,
+    ALT_GPIO_1BIT_57,
+    ALT_GPIO_1BIT_58,
+    ALT_GPIO_1BIT_59,
+    ALT_GPIO_1BIT_60,
+    ALT_GPIO_1BIT_61,
+    ALT_GPIO_1BIT_62,
+    ALT_GPIO_1BIT_63,
+    ALT_GPIO_1BIT_64,
+    ALT_GPIO_1BIT_65,
+    ALT_GPIO_1BIT_66,
+    ALT_GPIO_1BIT_67,        /* Not bonded out on some versions */
+    ALT_GPIO_1BIT_68,        /* Not bonded out on some versions */
+    ALT_GPIO_1BIT_69,        /* Not bonded out on some versions */
+    /*! The last of the input/output bits */
+    ALT_GPIO_1BIT_70,        /* Not bonded out on some versions */
+    /*! This and the following signals are not present on all SoCs. \n
+     * If present, the selection between their use as 14 General-purpose inputs or
+     * use as 14 DDR interface signals is made in the IOCSR (IO Configuration Shift
+     * Register) and software to make this selection is in the IO Manager API. If
+     * they are present, they are restricted to using the same power supply voltage
+     * as the SDRAM module.*/
+    ALT_HLGPI_0,        /* Not bonded out on some versions */
+    ALT_HLGPI_1,        /* Not bonded out on some versions */
+    ALT_HLGPI_2,        /* Not bonded out on some versions */
+    ALT_HLGPI_3,        /* Not bonded out on some versions */
+    ALT_HLGPI_4,        /* Not bonded out on some versions */
+    ALT_HLGPI_5,        /* Not bonded out on some versions */
+    ALT_HLGPI_6,        /* Not bonded out on some versions */
+    ALT_HLGPI_7,        /* Not bonded out on some versions */
+    ALT_HLGPI_8,        /* Not bonded out on some versions */
+    ALT_HLGPI_9,        /* Not bonded out on some versions */
+    ALT_HLGPI_10,       /* Not bonded out on some versions */
+    ALT_HLGPI_11,       /* Not bonded out on some versions */
+    ALT_HLGPI_12,       /* Not bonded out on some versions */
+    ALT_HLGPI_13,       /* Not bonded out on some versions */
+    ALT_HLGPI_14,       /* Not bonded out */
+    ALT_HLGPI_15,       /* Not bonded out */
+    ALT_GPIO_INVALID,
+    ALT_END_OF_GPIO_SIGNALS = -1,
+    ALT_LAST_VALID_GPIO_BIT = ALT_HLGPI_15
+} ALT_GPIO_1BIT_t;
+ * This configuration record definition is used for configuring bits and
+ * groups of bits of the GPIO interface.
+typedef struct ALT_GPIO_CONFIG_RECORD_s
+     * The index number of the signal to configure. */
+    ALT_GPIO_1BIT_t             signal_number;
+     * The data direction of the signal. */
+    ALT_GPIO_PIN_DIR_t          direction;
+     * Edge-triggered or level triggered interrupts. */
+    ALT_GPIO_PIN_TYPE_t         type;
+     * Active-high or active-low trigger for the interrupt. */
+    ALT_GPIO_PIN_POL_t          polarity;
+     * Enable or disable GPIO debounce capability. */
+    ALT_GPIO_PIN_DEBOUNCE_t     debounce;
+     * If the signal is an output, the data value to be output. */
+    ALT_GPIO_PIN_DATA_t         data;
+} ALT_GPIO_CONFIG_RECORD_t;
+ * This pin record type definition is comprised of the signal index and
+ * associated input or output data.
+typedef struct ALT_GPIO_PIN_RECORD_s
+     * The index number of the signal. */
+     * Data - zero or one. */
+    ALT_GPIO_PIN_DATA_t     val;
+} ALT_GPIO_PIN_RECORD_t;
+ * Configures all parameters for one bit (signal) of the GPIO ports.
+ * \param       signal_num
+ *              The GPIO port signal index.
+ * \param       dir
+ *              The data direction for this signal.
+ * \param       type
+ *              Edge-triggered or Level-triggered interrupt for this signal.
+ * \param       pol
+ *              Active-high or active-low interrupt polarity for this signal.
+ * \param       debounce
+ *              Enable the debounce flip-flops for this signal or not.
+ * \param       data
+ *              If the GPIO signal is set to be an output, set it to
+ *              this value
+ * \retval      ALT_E_SUCCESS   The operation was successful.
+ * \retval      ALT_E_ERROR     The operation failed.
+ALT_STATUS_CODE alt_gpio_bit_config(ALT_GPIO_1BIT_t signal_num,
+        ALT_GPIO_PIN_DIR_t dir, ALT_GPIO_PIN_TYPE_t type,
+        ALT_GPIO_PIN_POL_t pol, ALT_GPIO_PIN_DEBOUNCE_t debounce,
+        ALT_GPIO_PIN_DATA_t data);
+ * Returns the configuration parameters of a given GPIO bit.
+ * \param       config
+ *              Pointer to a single GPIO_CONFIG_RECORD_s configuration record.
+ *              The fields of this configuration record are filled in
+ *              by the function.
+ALT_STATUS_CODE alt_gpio_bitconfig_get(ALT_GPIO_1BIT_t signal_num,
+        ALT_GPIO_CONFIG_RECORD_t *config);
+ * Configures a list of GPIO bits. The GPIO bits do not have to be
+ * configured the same, as was the case for the mask version of this function,
+ * alt_gpio_port_config(). Each bit may be configured differently and bits may
+ * be listed in any order.
+ * \param       config_array
+ *              Pointer to an array of GPIO_CONFIG_RECORD_s configuration
+ *              records. These definitions contain all the parameters
+ *              needed to set up the listed pins. All or
+ *              any subset of the GPIO signals can be configured. Signals do
+ *              not have to be listed in numerical order or be unique. If a
+ *              signal number is listed multiple times, the last configuration
+ *              listed is used. \n Configuration terminates either when \b len
+ *              signals have been configured or if the next signal number index
+ *              in the array is equal to \b ALT_END_OF_GPIO_SIGNALS (-1).
+ * \param       len
+ *              Length of array to configure.
+ALT_STATUS_CODE alt_gpio_group_config(ALT_GPIO_CONFIG_RECORD_t* config_array,
+        uint32_t len);
+ * Returns a list of the pin signal indices and the associated configuration
+ * settings (data direction, interrupt type, polarity, and debounce) of that
+ * list of signals.
+ *              Pointer to an array of ALT_GPIO_CONFIG_RECORD_t configuration
+ *              records. Only the signal indices in the first field of each
+ *              configuration record need be filled in. This function will
+ *              fill in all the other fields of the configuration record,
+ *              returning all configuration parameters in the array.
+ *              Signals do not have to be listed in numerical order or be
+ *              unique. If a signal number is listed multiple times, the
+ *              configuration record will contain multiple entries for
+ *              that signal. \n Configuration reading terminates either when
+ *              \b len signal configurations have been read or if the next
+ *              signal number index in the array is equal to
+ *              \b ALT_END_OF_GPIO_SIGNALS (-1).
+ * \param       len
+ *              Length of configuration array to read and return.
+ALT_STATUS_CODE alt_gpio_group_config_get(ALT_GPIO_CONFIG_RECORD_t *config_array,
+        uint32_t len);
+ * list of signals. The difference between this version and
+ * alt_gpio_group_config_get() is this version follows a separate list of
+ * signal indices instead of having the signal list provided in the first
+ * field of the configuration records in the array.
+ * \param       pinid_array
+ *              Pointer to a list of signal index numbers. These indices
+ *              are copied to the first field of each configuration record
+ *              in the returned array.
+ *              records. This function will fill in the fields of the
+ *              configuration record, returning all configuration parameters
+ *              in the array. Signals do not have to be listed in numerical
+ *              order or be unique. If a signal number is listed multiple
+ *              times, the configuration record array will contain multiple
+ *              identical entries for that signal. \n Configuration reading
+ *              terminates either when \b len signal configurations have been
+ *              read or if the next signal number index in the array is equal
+ *              to \b ALT_END_OF_GPIO_SIGNALS (-1).
+ * \param       len
+ *              Length of configuration array to read.
+ALT_STATUS_CODE alt_gpio_group_config_get2(ALT_GPIO_1BIT_t* pinid_array,
+        ALT_GPIO_CONFIG_RECORD_t *config_array, uint32_t len);
+/*! \addtogroup ALT_GPIO_UTILITY General-Purpose IO Utility Functions
+ * These are useful utility functions for the general-purpose input & output
+ * module.
+ * Returns the ID code of the specified GPIO module.
+ * \param       gpio_pid
+ * \retval      uint32_t    The component code of the module, GPIO_MODULE_IDCODE.
+uint32_t alt_gpio_port_idcode_get(ALT_GPIO_PORT_t gpio_pid);
+ * Returns the version code of the specified GPIO module.
+ * \param       gpio_pid
+ * \retval      uint32_t      The encoded revision number of the module.
+uint32_t alt_gpio_port_ver_get(ALT_GPIO_PORT_t gpio_pid);
+ * Extracts the GPIO port ID from the supplied GPIO Signal Index Number.
+ALT_GPIO_PORT_t alt_gpio_bit_to_pid(ALT_GPIO_1BIT_t pin_num);
+ * Extracts the GPIO signal (pin) offset from the supplied GPIO Signal Index
+ * Number.
+ALT_GPIO_PORTBIT_t alt_gpio_bit_to_port_pin(ALT_GPIO_1BIT_t pin_num);
+ * Extracts the GPIO Signal Index Number from the supplied GPIO port ID and
+ * signal mask. If passed a bitmask composed of more than one signal, the
+ * signal number of the lowest bit in the bitmask presented is returned.
+ALT_GPIO_1BIT_t alt_gpio_port_pin_to_bit(ALT_GPIO_PORT_t pid,
+        uint32_t bitmask);
+#ifdef __cplusplus
+#endif  /* __cplusplus */
+#endif  /* __ALT_GPIO_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_hwlibs_ver.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_hwlibs_ver.h
new file mode 100644
index 0000000..57f0f0d
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_hwlibs_ver.h
@@ -0,0 +1,52 @@
+* Copyright 2013 Altera Corporation. All Rights Reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions are met:
+* 1. Redistributions of source code must retain the above copyright notice,
+* this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright notice,
+* this list of conditions and the following disclaimer in the documentation
+* and/or other materials provided with the distribution.
+* 3. The name of the author may not be used to endorse or promote products
+* derived from this software without specific prior written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
+* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef __ALT_HWLIBS_VER_H__
+ * Set of macros to provide version information
+/* This is the major revision of the Altera ACDS Release    */
+#define ALTERA_ACDS_MAJOR_REV           13
+/* This is the minor revision of the Altera ACDS Release    */
+#define ALTERA_ACDS_MINOR_REV            0
+/* This is an internal HwLibs revision control code.        */
+/* End-users should NOT depend upon the value of this field */
+#define ALTERA_HWLIBS_REV                0
+/* This is a text string containing the current release and service pack IDs */
+#define ALTERA_ACDS_REV_STR             "13.0SP1"
+#endif   /* __ALT_HWLIBS_VER_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_interrupt_common.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_interrupt_common.h
index 0000000..db1e6dd
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_interrupt_common.h
@@ -0,0 +1,531 @@
+* OF SUCH DAMAGE.
+#ifndef __ALT_INT_COMMON_H__
+#define __ALT_INT_COMMON_H__
+#include "hwlib.h"
+#include <stdbool.h>
+#include <stddef.h>
+#ifdef __cplusplus
+extern "C"
+#endif
+ * \addtogroup INT_COMMON Interrupt Controller Common Definitions
+ * This module contains the definitions common to the Interrupt Controller
+ * Low-Level API and Interrupt Controller Manager Interface.
+ * This type definition enumerates all the interrupt identification types.
+typedef enum ALT_INT_INTERRUPT_e
+    ALT_INT_INTERRUPT_SGI0  =  0, /*!< # */
+    ALT_INT_INTERRUPT_SGI1  =  1, /*!< # */
+    ALT_INT_INTERRUPT_SGI2  =  2, /*!< # */
+    ALT_INT_INTERRUPT_SGI3  =  3, /*!< # */
+    ALT_INT_INTERRUPT_SGI4  =  4, /*!< # */
+    ALT_INT_INTERRUPT_SGI5  =  5, /*!< # */
+    ALT_INT_INTERRUPT_SGI6  =  6, /*!< # */
+    ALT_INT_INTERRUPT_SGI7  =  7, /*!< # */
+    ALT_INT_INTERRUPT_SGI8  =  8, /*!< # */
+    ALT_INT_INTERRUPT_SGI9  =  9, /*!< # */
+    ALT_INT_INTERRUPT_SGI10 = 10, /*!< # */
+    ALT_INT_INTERRUPT_SGI11 = 11, /*!< # */
+    ALT_INT_INTERRUPT_SGI12 = 12, /*!< # */
+    ALT_INT_INTERRUPT_SGI13 = 13, /*!< # */
+    ALT_INT_INTERRUPT_SGI14 = 14, /*!< # */
+    ALT_INT_INTERRUPT_SGI15 = 15,
+     * Software Generated Interrupts (SGI), 0 - 15.
+     *  * All interrupts in this group are software triggered.
+    ALT_INT_INTERRUPT_PPI_TIMER_GLOBAL   = 27, /*!< # */
+    ALT_INT_INTERRUPT_PPI_TIMER_PRIVATE  = 29, /*!< # */
+    ALT_INT_INTERRUPT_PPI_TIMER_WATCHDOG = 30, /*!< # */
+     * Private Peripheral Interrupts (PPI) for the Global Timer, per CPU
+     * private timer, and watchdog timer.
+     *  * All interrupts in this group are edge triggered.
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL         = 32, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_BTAC    = 33, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_GHB     = 34, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_TAG   = 35, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_DATA  = 36, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_TLB     = 37, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_OUTER = 38, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_TAG   = 39, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_DATA  = 40, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_DEFLAGS0           = 41, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_DEFLAGS1           = 42, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_DEFLAGS2           = 43, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_DEFLAGS3           = 44, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_DEFLAGS4           = 45, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_DEFLAGS5           = 46, /*!< # */
+    ALT_INT_INTERRUPT_CPU0_DEFLAGS6           = 47,
+     * Interrupts sourced from CPU0.
+     * The ALT_INT_INTERRUPT_CPU0_PARITYFAIL interrupt combines the
+     * BTAC, GHB, I_TAG, I_DATA, TLB, D_OUTER, D_TAG, and D_DATA interrupts
+     * for CPU0.
+     *  * PARITYFAIL interrupts in this group are edge triggered.
+     *  * DEFFLAGS interrupts in this group are level triggered.
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL         = 48, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_BTAC    = 49, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_GHB     = 50, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_TAG   = 51, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_DATA  = 52, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_TLB     = 53, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_OUTER = 54, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_TAG   = 55, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_DATA  = 56, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_DEFLAGS0           = 57, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_DEFLAGS1           = 58, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_DEFLAGS2           = 59, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_DEFLAGS3           = 60, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_DEFLAGS4           = 61, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_DEFLAGS5           = 62, /*!< # */
+    ALT_INT_INTERRUPT_CPU1_DEFLAGS6           = 63,
+     * Interrupts sourced from CPU1.
+     * The ALT_INT_INTERRUPT_CPU1_PARITYFAIL interrupt combines the
+     * for CPU1.
+    ALT_INT_INTERRUPT_SCU_PARITYFAIL0 =  64, /*!< # */
+    ALT_INT_INTERRUPT_SCU_PARITYFAIL1 =  65, /*!< # */
+    ALT_INT_INTERRUPT_SCU_EV_ABORT    =  66,
+     * Interrupts sourced from the Snoop Control Unit (SCU).
+    ALT_INT_INTERRUPT_L2_ECC_BYTE_WR_IRQ     = 67, /*!< # */
+    ALT_INT_INTERRUPT_L2_ECC_CORRECTED_IRQ   = 68, /*!< # */
+    ALT_INT_INTERRUPT_L2_ECC_UNCORRECTED_IRQ = 69, /*!< # */
+    ALT_INT_INTERRUPT_L2_COMBINED_IRQ        = 70,
+     * Interrupts sourced from the L2 Cache Controller.
+     * The ALT_INT_INTERRUPT_L2_COMBINED_IRQ interrupt combines the cache
+     * controller internal DECERRINTR, ECNTRINTR, ERRRDINTR, ERRRTINTR,
+     * ERRWDINTR, ERRWTINTR, PARRDINTR, PARRTINTR, and SLVERRINTR interrupts.
+     * Consult the L2C documentation for information on these interrupts.
+     *  * ECC interrupts in this group are edge triggered.
+     *  * Other interrupts in this group are level triggered.
+    ALT_INT_INTERRUPT_DDR_ECC_ERROR_IRQ =  71,
+     * Interrupts sourced from the SDRAM Controller.
+     *  * All interrupts in this group are level triggered.
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ0  =  72, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ1  =  73, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ2  =  74, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ3  =  75, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ4  =  76, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ5  =  77, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ6  =  78, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ7  =  79, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ8  =  80, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ9  =  81, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ10 =  82, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ11 =  83, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ12 =  84, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ13 =  85, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ14 =  86, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ15 =  87, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ16 =  88, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ17 =  89, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ18 =  90, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ19 =  91, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ20 =  92, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ21 =  93, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ22 =  94, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ23 =  95, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ24 =  96, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ25 =  97, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ26 =  98, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ27 =  99, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ28 = 100, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ29 = 101, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ30 = 102, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ31 = 103, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ32 = 104, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ33 = 105, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ34 = 106, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ35 = 107, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ36 = 108, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ37 = 109, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ38 = 110, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ39 = 111, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ40 = 112, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ41 = 113, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ42 = 114, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ43 = 115, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ44 = 116, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ45 = 117, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ46 = 118, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ47 = 119, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ48 = 120, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ49 = 121, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ50 = 122, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ51 = 123, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ52 = 124, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ53 = 125, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ54 = 126, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ55 = 127, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ56 = 128, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ57 = 129, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ58 = 130, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ59 = 131, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ60 = 132, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ61 = 133, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ62 = 134, /*!< # */
+    ALT_INT_INTERRUPT_F2S_FPGA_IRQ63 = 135,
+     * Interrupt request from the FPGA logic, 0 - 63.
+     *  * Trigger type depends on the implementation in the FPGA.
+    ALT_INT_INTERRUPT_DMA_IRQ0                = 136, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ1                = 137, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ2                = 138, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ3                = 139, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ4                = 140, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ5                = 141, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ6                = 142, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ7                = 143, /*!< # */
+    ALT_INT_INTERRUPT_DMA_IRQ_ABORT           = 144, /*!< # */
+    ALT_INT_INTERRUPT_DMA_ECC_CORRECTED_IRQ   = 145, /*!< # */
+    ALT_INT_INTERRUPT_DMA_ECC_UNCORRECTED_IRQ = 146,
+     * Interrupts sourced from the DMA Controller.
+    ALT_INT_INTERRUPT_EMAC0_IRQ                    = 147, /*!< # */
+    ALT_INT_INTERRUPT_EMAC0_TX_ECC_CORRECTED_IRQ   = 148, /*!< # */
+    ALT_INT_INTERRUPT_EMAC0_TX_ECC_UNCORRECTED_IRQ = 149, /*!< # */
+    ALT_INT_INTERRUPT_EMAC0_RX_ECC_CORRECTED_IRQ   = 150, /*!< # */
+    ALT_INT_INTERRUPT_EMAC0_RX_ECC_UNCORRECTED_IRQ = 151,
+     * Interrupts sourced from the Ethernet MAC 0 (EMAC0).
+    ALT_INT_INTERRUPT_EMAC1_IRQ                    = 152, /*!< # */
+    ALT_INT_INTERRUPT_EMAC1_TX_ECC_CORRECTED_IRQ   = 153, /*!< # */
+    ALT_INT_INTERRUPT_EMAC1_TX_ECC_UNCORRECTED_IRQ = 154, /*!< # */
+    ALT_INT_INTERRUPT_EMAC1_RX_ECC_CORRECTED_IRQ   = 155, /*!< # */
+    ALT_INT_INTERRUPT_EMAC1_RX_ECC_UNCORRECTED_IRQ = 156,
+     * Interrupts sourced from the Ethernet MAC 1 (EMAC1).
+    ALT_INT_INTERRUPT_USB0_IRQ             = 157, /*!< # */
+    ALT_INT_INTERRUPT_USB0_ECC_CORRECTED   = 158, /*!< # */
+    ALT_INT_INTERRUPT_USB0_ECC_UNCORRECTED = 159,
+     * Interrupts sourced from the USB OTG 0.
+    ALT_INT_INTERRUPT_USB1_IRQ             = 160, /*!< # */
+    ALT_INT_INTERRUPT_USB1_ECC_CORRECTED   = 161, /*!< # */
+    ALT_INT_INTERRUPT_USB1_ECC_UNCORRECTED = 162,
+     * Interrupts sourced from the USB OTG 1.
+    ALT_INT_INTERRUPT_CAN0_STS_IRQ             = 163, /*!< # */
+    ALT_INT_INTERRUPT_CAN0_MO_IRQ              = 164, /*!< # */
+    ALT_INT_INTERRUPT_CAN0_ECC_CORRECTED_IRQ   = 165, /*!< # */
+    ALT_INT_INTERRUPT_CAN0_ECC_UNCORRECTED_IRQ = 166,
+     * Interrupts sourced from the CAN Controller 0.
+    ALT_INT_INTERRUPT_CAN1_STS_IRQ             = 167, /*!< # */
+    ALT_INT_INTERRUPT_CAN1_MO_IRQ              = 168, /*!< # */
+    ALT_INT_INTERRUPT_CAN1_ECC_CORRECTED_IRQ   = 169, /*!< # */
+    ALT_INT_INTERRUPT_CAN1_ECC_UNCORRECTED_IRQ = 170,
+     * Interrupts sourced from the CAN Controller 1.
+    ALT_INT_INTERRUPT_SDMMC_IRQ                   = 171, /*!< # */
+    ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_CORRECTED   = 172, /*!< # */
+    ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_UNCORRECTED = 173, /*!< # */
+    ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_CORRECTED   = 174, /*!< # */
+    ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_UNCORRECTED = 175,
+     * Interrupts sourced from the SDMMC Controller.
+    ALT_INT_INTERRUPT_NAND_IRQ                  = 176, /*!< # */
+    ALT_INT_INTERRUPT_NANDR_ECC_CORRECTED_IRQ   = 177, /*!< # */
+    ALT_INT_INTERRUPT_NANDR_ECC_UNCORRECTED_IRQ = 178, /*!< # */
+    ALT_INT_INTERRUPT_NANDW_ECC_CORRECTED_IRQ   = 179, /*!< # */
+    ALT_INT_INTERRUPT_NANDW_ECC_UNCORRECTED_IRQ = 180, /*!< # */
+    ALT_INT_INTERRUPT_NANDE_ECC_CORRECTED_IRQ   = 181, /*!< # */
+    ALT_INT_INTERRUPT_NANDE_ECC_UNCORRECTED_IRQ = 182,
+     * Interrupts sourced from the NAND Controller.
+    ALT_INT_INTERRUPT_QSPI_IRQ                 = 183, /*!< # */
+    ALT_INT_INTERRUPT_QSPI_ECC_CORRECTED_IRQ   = 184, /*!< # */
+    ALT_INT_INTERRUPT_QSPI_ECC_UNCORRECTED_IRQ = 185,
+     * Interrupts sourced from the QSPI Controller.
+    ALT_INT_INTERRUPT_SPI0_IRQ = 186, /*!< # */
+    ALT_INT_INTERRUPT_SPI1_IRQ = 187, /*!< # */
+    ALT_INT_INTERRUPT_SPI2_IRQ = 188, /*!< # */
+    ALT_INT_INTERRUPT_SPI3_IRQ = 189,
+     * Interrupts sourced from the SPI Controllers 0 - 3.
+    ALT_INT_INTERRUPT_I2C0_IRQ = 190, /*!< # */
+    ALT_INT_INTERRUPT_I2C1_IRQ = 191, /*!< # */
+    ALT_INT_INTERRUPT_I2C2_IRQ = 192, /*!< # */
+    ALT_INT_INTERRUPT_I2C3_IRQ = 193,
+     * Interrupts sourced from the I2C Controllers 0 - 3.
+    ALT_INT_INTERRUPT_UART0 = 194, /*!< # */
+    ALT_INT_INTERRUPT_UART1 = 195,
+     * Interrupts sourced from the UARTs 0 - 1.
+    ALT_INT_INTERRUPT_GPIO0 = 196, /*!< # */
+    ALT_INT_INTERRUPT_GPIO1 = 197, /*!< # */
+    ALT_INT_INTERRUPT_GPIO2 = 198,
+     * Interrupts sourced from the GPIO 0 - 2.
+    ALT_INT_INTERRUPT_TIMER_L4SP_0_IRQ = 199, /*!< # */
+    ALT_INT_INTERRUPT_TIMER_L4SP_1_IRQ = 200, /*!< # */
+    ALT_INT_INTERRUPT_TIMER_OSC1_0_IRQ = 201, /*!< # */
+    ALT_INT_INTERRUPT_TIMER_OSC1_1_IRQ = 202,
+     * Interrupts sourced from the Timer controllers.
+    ALT_INT_INTERRUPT_WDOG0_IRQ = 203, /*!< # */
+    ALT_INT_INTERRUPT_WDOG1_IRQ = 204,
+     * Interrupts sourced from the Watchdog Timers 0 - 1.
+    ALT_INT_INTERRUPT_CLKMGR_IRQ = 205,
+     * Interrupts sourced from the Clock Manager.
+    ALT_INT_INTERRUPT_MPUWAKEUP_IRQ = 206,
+     * Interrupts sourced from the Clock Manager MPU Wakeup.
+    ALT_INT_INTERRUPT_FPGA_MAN_IRQ = 207,
+     * Interrupts sourced from the FPGA Manager.
+    ALT_INT_INTERRUPT_NCTIIRQ0 = 208, /*!< # */
+    ALT_INT_INTERRUPT_NCTIIRQ1 = 209,
+     * Interrupts sourced from the CoreSight for CPU0 and CPU1's CTI.
+    ALT_INT_INTERRUPT_RAM_ECC_CORRECTED_IRQ   = 210, /*!< # */
+    ALT_INT_INTERRUPT_RAM_ECC_UNCORRECTED_IRQ = 211
+     * Interrupts sourced from the On-chip RAM.
+} ALT_INT_INTERRUPT_t;
+ * This is the CPU target type. It is used to specify a set of CPUs on the
+ * system. If only bit 0 is set then it specifies a set of CPUs containing
+ * only CPU 0. Multiple CPUs can be specified by setting the appropriate bit
+ * up to the number of CPUs on the system.
+typedef uint32_t alt_int_cpu_target_t;
+ * This type definition enumerates all the interrupt trigger types.
+typedef enum ALT_INT_TRIGGER_e
+     * Edge triggered interrupt. This applies to Private Peripheral Interrupts
+     * (PPI) and Shared Peripheral Interrupts (SPI) only, with interrupt IDs
+     * 16 - 1019.
+    ALT_INT_TRIGGER_EDGE,
+     * Level triggered interrupt. This applies to Private Peripheral
+     * Interrupts (PPI) and Shared Peripheral Interrupts (SPI) only, with
+     * interrupt IDs 16 - 1019.
+    ALT_INT_TRIGGER_LEVEL,
+     * Software triggered interrupt. This applies to Software Generated
+     * Interrupts (SGI) only, with interrupt IDs 0 - 15.
+    ALT_INT_TRIGGER_SOFTWARE,
+     * All triggering types except for those in the Shared Peripheral Interrupts
+     * (SPI) F2S FPGA family interrupts can be determined by the system
+     * automatically. In all functions which ask for the triggering type, the
+     * ALT_INT_TRIGGER_AUTODETECT can be used to select the correct trigger
+     * type for all non F2S interrupt types.
+    ALT_INT_TRIGGER_AUTODETECT,
+     * The interrupt triggering information is not applicable. This is possibly
+     * due to querying an invalid interrupt identifier.
+    ALT_INT_TRIGGER_NA
+ALT_INT_TRIGGER_t;
+ * This type definition enumerates all the target list filter options. This is
+ * used by the trigger Software Generated Interrupt (SGI) feature to issue a
+ * SGI to the specified processor(s) in the system. Depending on the target
+ * list filter and the target list, interrupts can be routed to any
+ * combinations of CPUs.
+typedef enum ALT_INT_SGI_TARGET_e
+     * This filter list uses the target list parameter to specify which CPUs
+     * to send the interrupt to. If target list is 0, no interrupts are sent.
+    ALT_INT_SGI_TARGET_LIST,
+     * This filter list sends the interrupt all CPUs except the current CPU.
+     * The target list parameter is ignored.
+    ALT_INT_SGI_TARGET_ALL_EXCL_SENDER,
+     * This filter list sends the interrupt to the current CPU only. The
+     * target list parameter is ignored.
+    ALT_INT_SGI_TARGET_SENDER_ONLY
+ALT_INT_SGI_TARGET_t;
+ * Extracts the CPUID field from the ICCIAR register.
+#define ALT_INT_ICCIAR_CPUID_GET(icciar)    ((icciar >> 10) & 0x7)
+ * Extracts the ACKINTID field from the ICCIAR register.
+#define ALT_INT_ICCIAR_ACKINTID_GET(icciar) (icciar & 0x3FF)
+ * The callback to use when an interrupt needs to be serviced.
+ * \param       icciar          The Interrupt Controller CPU Interrupt
+ *                              Acknowledgement Register value (ICCIAR) value
+ *                              corresponding to the current interrupt.
+ * \param       context         The user provided context.
+typedef void (*alt_int_callback_t)(uint32_t icciar, void * context);
+#ifdef __cplusplus
+#endif
+#endif /* __ALT_INT_COMMON_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_mpu_registers.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_mpu_registers.h
index 0000000..2ead15d
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_mpu_registers.h
@@ -0,0 +1,156 @@
+* OF SUCH DAMAGE.
+#ifndef __ALT_MPUSCU_H__
+#define __ALT_MPUSCU_H__
+#ifdef __cplusplus
+extern "C"
+/*                                alt_mpuscu.h        */
+/*  Definitions for the ARM Snoop Control Unit, which contains the Snoop Control Unit, the Watchdog         */
+/*  Timer, the Private Timer, the Global Timer, the Interrupt Controller, and the Interrupt Distributor.    */
+#ifndef ALT_HPS_ADDR
+#define ALT_HPS_ADDR 0x00
+#endif
+/*     ALT_MPUSCU_OFST is defined as a offset from ALT_HPS_ADDR in the SoCAL file hps.h            */
+/*    and is the address of the base of the Snoop Control Unit (SCU)                                */
+#define GLOBALTMR_BASE                      (ALT_MPUSCU_OFST + GLOBALTMR_MODULE_BASE_OFFSET)
+#define CPU_WDTGPT_TMR_BASE                 (ALT_MPUSCU_OFST + WDOG_TIMER_MODULE_BASE_OFFSET)
+#define CPU_PRIVATE_TMR_BASE                (ALT_MPUSCU_OFST + CPU_PRIV_TIMER_MODULE_BASE_OFFSET)
+#define CPU_INT_CTRL_BASE                   (ALT_MPUSCU_OFST + INT_CONTROLLER_MODULE_BASE_OFFSET)
+#define CPU_INT_DIST_BASE                   (ALT_MPUSCU_OFST + INT_DISTRIBUTOR_MODULE_BASE_OFFSET)
+            /* offsets */
+        /* Global Timer offsets */
+#define GLOBALTMR_MODULE_BASE_OFFSET        0x00000200
+#define GLOBALTMR_CNTR_LO_REG_OFFSET        0x00000000
+#define GLOBALTMR_CNTR_HI_REG_OFFSET        0x00000004
+#define GLOBALTMR_CTRL_REG_OFFSET           0x00000008
+#define GLOBALTMR_INT_STAT_REG_OFFSET       0x0000000C
+#define GLOBALTMR_COMP_LO_REG_OFFSET        0x00000010
+#define GLOBALTMR_COMP_HI_REG_OFFSET        0x00000014
+#define GLOBALTMR_AUTOINC_REG_OFFSET        0x00000018
+/* Global Timer bitmasks */
+#define GLOBALTMR_ENABLE_BIT                0x00000001
+#define GLOBALTMR_COMP_ENABLE_BIT           0x00000002
+#define GLOBALTMR_INT_ENABLE_BIT            0x00000004
+#define GLOBALTMR_AUTOINC_ENABLE_BIT        0x00000008
+#define GLOBALTMR_PS_MASK                   0x0000FF00
+#define GLOBALTMR_PS_SHIFT                  8
+#define GLOBALTMR_INT_STATUS_BIT            0x00000001
+/* Global timer constants */
+#define GLOBALTMR_MAX                       0xFFFFFFFF
+#define GLOBALTMR_PS_MAX                    0x000000FF
+/* Private timer offsets */
+#define CPU_PRIV_TIMER_MODULE_BASE_OFFSET   0x00000600
+#define CPU_PRIV_TMR_LOAD_REG_OFFSET        0x00000000
+#define CPU_PRIV_TMR_CNTR_REG_OFFSET        0x00000004
+#define CPU_PRIV_TMR_CTRL_REG_OFFSET        0x00000008
+#define CPU_PRIV_TMR_INT_STATUS_REG_OFFSET  0x0000000C
+/* Private timer bitmasks */
+#define CPU_PRIV_TMR_ENABLE                 0x00000001
+#define CPU_PRIV_TMR_AUTO_RELOAD            0x00000002
+#define CPU_PRIV_TMR_INT_EN                 0x00000004
+#define CPU_PRIV_TMR_PS_MASK                0x0000FF00
+#define CPU_PRIV_TMR_PS_SHIFT               8
+#define CPU_PRIV_TMR_INT_STATUS             0x00000001
+/* Private timer constants */
+#define CPU_PRIV_TMR_MAX                    0xFFFFFFFF
+#define CPU_PRIV_TMR_PS_MAX                 0x000000FF
+    /* Watchdog timer offsets */
+#define WDOG_TIMER_MODULE_BASE_OFFSET       0x00000620
+#define WDOG_LOAD_REG_OFFSET                0x00000000
+#define WDOG_CNTR_REG_OFFSET                0x00000004
+#define WDOG_CTRL_REG_OFFSET                0x00000008
+#define WDOG_INTSTAT_REG_OFFSET             0x0000000C
+#define WDOG_RSTSTAT_REG_OFFSET             0x00000010
+#define WDOG_DISABLE_REG_OFFSET             0x00000014
+    /* Watchdog timer bitmasks : */
+    /* Control Register bitmasks */
+#define WDOG_TMR_ENABLE                     0x00000001
+#define WDOG_AUTO_RELOAD                    0x00000002
+#define WDOG_INT_EN                         0x00000004
+#define WDOG_WDT_MODE                       0x00000008
+#define WDOG_PS_MASK                        0x0000FF00
+#define WDOG_PS_SHIFT                       8
+    /* Interrupt Status Register bitmasks */
+#define WDOG_INT_STAT_BIT                   0x00000001
+    /* Reset Status Register bitmasks */
+#define WDOG_RST_STAT_BIT                   0x00000001
+    /* Watchdog timer constants */
+#define WDOG_TMR_MAX                        UINT32_MAX
+#define WDOG_PS_MAX                         UINT8_MAX
+#define WDOG_DISABLE_VAL0                   0x12345678
+#define WDOG_DISABLE_VAL1                   0x87654321
+    /* Interrupt Manager offsets */
+/*   <Add definitions here> */
+#define INT_CONTROLLER_MODULE_BASE_OFFSET   0x00000100
+#define INT_DISTRIBUTOR_MODULE_BASE_OFFSET  0x00001000
+#define INT_DIST_TYPE_REG                   0x00000004
+/*  Upper bound of the MPUSCU address space  */
+#define MPUSCU_MAX                          0x00001FFF
+#ifdef __cplusplus
+#endif  /* __ALT_MPUSCU_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_reset_manager.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_reset_manager.h
index 0000000..7b0da34
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/alt_reset_manager.h
@@ -0,0 +1,249 @@
+/*! \file
+ *  Altera - SoC Reset Manager
+* OF SUCH DAMAGE.
+#ifndef __ALT_RESET_MGR_H__
+#define __ALT_RESET_MGR_H__
+#include "hwlib.h"
+#ifdef __cplusplus
+extern "C"
+/*! \addtogroup RST_MGR The Reset Manager
+ * The Reset Manager API defines functions for accessing, configuring, and
+ * controlling the HPS reset behavior.
+/*! \addtogroup RST_MGR_STATUS Reset Status
+ * This functional group provides information on various aspects of SoC reset
+ * status and timeout events.
+ * This type definition enumerates the set of reset causes and timeout events as
+ * register mask values.
+typedef enum ALT_RESET_EVENT_e
+    /*! Power-On Voltage Detector Cold Reset */
+    ALT_RESET_EVENT_PORVOLTRST          = 0x00000001,
+    /*! nPOR Pin Cold Reset                  */
+    ALT_RESET_EVENT_NPORPINRST          = 0x00000002,
+    /*! FPGA Core Cold Reset                 */
+    ALT_RESET_EVENT_FPGACOLDRST         = 0x00000004,
+    /*! CONFIG_IO Cold Reset                 */
+    ALT_RESET_EVENT_CONFIGIOCOLDRST     = 0x00000008,
+    /*! Software Cold Reset                  */
+    ALT_RESET_EVENT_SWCOLDRST           = 0x00000010,
+    /*! nRST Pin Warm Reset                  */
+    ALT_RESET_EVENT_NRSTPINRST          = 0x00000100,
+    /*! FPGA Core Warm Reset                 */
+    ALT_RESET_EVENT_FPGAWARMRST         = 0x00000200,
+    /*! Software Warm Reset                  */
+    ALT_RESET_EVENT_SWWARMRST           = 0x00000400,
+    /*! MPU Watchdog 0 Warm Reset            */
+    ALT_RESET_EVENT_MPUWD0RST           = 0x00001000,
+    /*! MPU Watchdog 1 Warm Reset            */
+    ALT_RESET_EVENT_MPUWD1RST           = 0x00002000,
+    /*! L4 Watchdog 0 Warm Reset             */
+    ALT_RESET_EVENT_L4WD0RST            = 0x00004000,
+    /*! L4 Watchdog 1 Warm Reset             */
+    ALT_RESET_EVENT_L4WD1RST            = 0x00008000,
+    /*! FPGA Core Debug Reset                */
+    ALT_RESET_EVENT_FPGADBGRST          = 0x00040000,
+    /*! DAP Debug Reset                      */
+    ALT_RESET_EVENT_CDBGREQRST          = 0x00080000,
+    /*! SDRAM Self-Refresh Timeout           */
+    ALT_RESET_EVENT_SDRSELFREFTIMEOUT   = 0x01000000,
+    /*! FPGA manager handshake Timeout       */
+    ALT_RESET_EVENT_FPGAMGRHSTIMEOUT    = 0x02000000,
+    /*! SCAN manager handshake Timeout       */
+    ALT_RESET_EVENT_SCANHSTIMEOUT       = 0x04000000,
+    /*! FPGA handshake Timeout               */
+    ALT_RESET_EVENT_FPGAHSTIMEOUT       = 0x08000000,
+    /*! ETR Stall Timeout                    */
+    ALT_RESET_EVENT_ETRSTALLTIMEOUT     = 0x10000000
+} ALT_RESET_EVENT_t;
+ * Gets the reset and timeout events that caused the last reset.
+ * The ALT_RESET_EVENT_t enumeration values should be used to selectively
+ * examine the returned reset cause(s).
+ * \returns     A mask of the reset and/or timeout events that caused the last
+ *              reset.
+uint32_t alt_reset_event_get(void);
+ * Clears the reset and timeout events that caused the last reset.
+ * \param       event_mask
+ *              A mask of the selected reset and timeout events to clear in the
+ *              Reset Manager \e stat register. The mask selection can be formed
+ *              using the ALT_RESET_EVENT_t enumeration values.
+ * \retval      ALT_E_SUCCESS   The operation was succesful.
+ALT_STATUS_CODE alt_reset_event_clear(uint32_t event_mask);
+/*! \addtogroup RST_MGR_CTRL Reset Control
+ * This functional group provides global and selective reset control for the SoC
+ * and its constituent modules.
+ * Initiate a cold reset of the SoC.
+ * If this function is successful, then it should never return.
+ALT_STATUS_CODE alt_reset_cold_reset(void);
+ * Initiate a warm reset of the SoC.
+ * Perform a hardware sequenced warm reset of the SoC. A hardware sequenced
+ * reset handshake with certain modules can optionally be requested in an
+ * attempt to ensure an orderly reset transition.
+ * \param       warm_reset_delay
+ *              Specifies the number of cycles after the Reset Manager releases
+ *              the Clock Manager reset before releasing any other hardware
+ *              controlled resets. Value must be greater than 16 and less than
+ *              256.
+ * \param       nRST_pin_clk_assertion
+ *              Specifies that number of clock cycles (osc1_clk?) to externally
+ *              assert the warm reset pin (nRST). 0 <= \e nRST_pin_clk_assertion <=
+ *              (2**20 - 1). A value of 0 prevents any assertion of nRST.
+ * \param       sdram_refresh
+ *              Controls whether the contents of SDRAM survive a hardware
+ *              sequenced warm reset. The reset manager requests the SDRAM
+ *              controller to put SDRAM devices into self-refresh mode before
+ *              asserting warm reset signals. An argument value of \b true
+ *              enables the option, \b false disables the option.
+ * \param       fpga_mgr_handshake
+ *              Controls whether a handshake between the reset manager and FPGA
+ *              manager occurs before a warm reset. The handshake is used to
+ *              warn the FPGA manager that a warm reset is imminent so it can
+ *              prepare for it by driving its output clock to a quiescent state
+ *              to avoid glitches. An argument value of \b true enables the
+ *              option, \b false disables the option.
+ * \param       scan_mgr_handshake
+ *              Controls whether a handshake between the reset manager and scan
+ *              warn the scan manager that a warm reset is imminent so it can
+ * \param       fpga_handshake
+ *              Controls whether a handshake between the reset manager and the
+ *              FPGA occurs before a warm reset. The handshake is used to warn
+ *              the FPGA that a warm reset is imminent so that the FPGA prepare
+ *              for the reset event in soft IP. An argument value of \b true
+ * \param       etr_stall
+ *              Controls whether the ETR is requested to idle its AXI master
+ *              interface (i.e. finish outstanding transactions and not initiate
+ *              any more) to the L3 Interconnect before a warm reset. An
+ *              argument value of \b true enables the option, \b false disables
+ *              the option.
+ALT_STATUS_CODE alt_reset_warm_reset(uint32_t warm_reset_delay,
+                                     uint32_t nRST_pin_clk_assertion,
+                                     bool sdram_refresh,
+                                     bool fpga_mgr_handshake,
+                                     bool scan_mgr_handshake,
+                                     bool fpga_handshake,
+                                     bool etr_stall);
+#ifdef __cplusplus
+#endif  /* __ALT_RESET_MGR_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/hwlib.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/hwlib.h
index 0000000..7a3bbfd
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/hwlib.h
@@ -0,0 +1,190 @@
+* OF SUCH DAMAGE.
+#ifndef __HWLIB_H__
+#define __HWLIB_H__
+#ifdef __cplusplus
+#include <cstddef>
+#include <cstdbool>
+#include <cstdint>
+#else   /* __cplusplus */
+#include "alt_hwlibs_ver.h"
+#ifdef __cplusplus
+extern "C"
+ * The type definition for status codes returned by the HWLIB.
+typedef int32_t             ALT_STATUS_CODE;
+/*! Definitions of status codes returned by the HWLIB. */
+/*! The operation was successful. */
+#define ALT_E_SUCCESS               0
+/*! The operation failed. */
+#define ALT_E_ERROR                 (-1)
+/*! FPGA configuration error detected.*/
+#define ALT_E_FPGA_CFG              (-2)
+/*! FPGA CRC error detected. */
+#define ALT_E_FPGA_CRC              (-3)
+/*! An error occurred on the FPGA configuration bitstream input source. */
+#define ALT_E_FPGA_CFG_STM          (-4)
+/*! The FPGA is powered off. */
+#define ALT_E_FPGA_PWR_OFF          (-5)
+/*! The SoC does not currently control the FPGA. */
+#define ALT_E_FPGA_NO_SOC_CTRL      (-6)
+/*! The FPGA is not in USER mode. */
+#define ALT_E_FPGA_NOT_USER_MODE    (-7)
+/*! An argument violates a range constraint. */
+#define ALT_E_ARG_RANGE             (-8)
+/*! A bad argument value was passed. */
+#define ALT_E_BAD_ARG               (-9)
+/*! The operation is invalid or illegal. */
+#define ALT_E_BAD_OPERATION         (-10)
+/*! An invalid option was selected. */
+#define ALT_E_INV_OPTION            (-11)
+/*! An operation or response timeout period expired. */
+#define ALT_E_TMO                   (-12)
+/*! The argument value is reserved or unavailable. */
+#define ALT_E_RESERVED              (-13)
+/*! A clock is not enabled or violates an operational constraint. */
+#define ALT_E_BAD_CLK               (-14)
+/*! The version ID is invalid. */
+#define ALT_E_BAD_VERSION           (-15)
+/*! The buffer does not contain enough free space for the operation. */
+#define ALT_E_BUF_OVF               (-20)
+ * Indicates a FALSE condition.
+#define ALT_E_FALSE                 (0)
+ * Indicates a TRUE condition.
+#define ALT_E_TRUE                  (1)
+/* Note, additional positive status codes may be defined to return
+ * a TRUE condition with additional information */
+/* Some other useful definitions */
+ * Specifies the current major and minor revision of the HWLibs. The
+ * MS four decimal digits specify the Altera ACDS release number, the
+ * LS two decimal digits specify minor revisions of the HWLibs, if any.
+ * A typical use is:
+ * \code
+ * #if  ALTERA_HWLIBS_VERSION_CODE >= ALT_HWLIBS_VERSION(13, 1, 0)
+ * \endcode
+ *     for a dependency on the major or minor ACDS revision
+ *   or
+ * \code
+ * #if  ALTERA_HWLIBS_VERSION_CODE == ALT_HWLIBS_VERSION(13, 0, 12)
+ * \endcode
+ *     for a dependency on the hwlibs revision
+#define ALT_HWLIBS_VERSION(a,b,c)   (((a)*10000)+((b)*100)+(c))
+#define ALTERA_HWLIBS_VERSION_CODE   ALT_HWLIBS_VERSION(ALTERA_ACDS_MAJOR_REV, \
+                                    ALTERA_ACDS_MINOR_REV, ALTERA_HWLIBS_REV)
+ * Allow some parts of the documentation to be hidden by setting to zero
+#define ALTERA_INTERNAL_ONLY_DOCS   1
+ * Provide base address of MPU address space
+#endif
+ * These constants are sometimes useful:
+#define ALT_MILLISECS_IN_A_SEC      1000
+#define ALT_MICROSECS_IN_A_SEC      1000000
+#define ALT_NANOSECS_IN_A_SEC       1000000000
+#define ALT_TWO_TO_POW0             (1)
+#define ALT_TWO_TO_POW1             (1<<1)
+#define ALT_TWO_TO_POW2             (1<<2)
+#define ALT_TWO_TO_POW3             (1<<3)
+#define ALT_TWO_TO_POW4             (1<<4)
+#define ALT_TWO_TO_POW5             (1<<5)
+#define ALT_TWO_TO_POW6             (1<<6)
+#define ALT_TWO_TO_POW7             (1<<7)
+#define ALT_TWO_TO_POW8             (1<<8)
+#define ALT_TWO_TO_POW9             (1<<9)
+#define ALT_TWO_TO_POW10            (1<<10)
+#define ALT_TWO_TO_POW11            (1<<11)
+#define ALT_TWO_TO_POW12            (1<<12)
+#define ALT_TWO_TO_POW13            (1<<13)
+#define ALT_TWO_TO_POW14            (1<<14)
+#define ALT_TWO_TO_POW15            (1<<15)
+#define ALT_TWO_TO_POW16            (1<<16)
+#define ALT_TWO_TO_POW17            (1<<17)
+#define ALT_TWO_TO_POW18            (1<<18)
+#define ALT_TWO_TO_POW19            (1<<19)
+#define ALT_TWO_TO_POW20            (1<<20)
+#define ALT_TWO_TO_POW21            (1<<21)
+#define ALT_TWO_TO_POW22            (1<<22)
+#define ALT_TWO_TO_POW23            (1<<23)
+#define ALT_TWO_TO_POW24            (1<<24)
+#define ALT_TWO_TO_POW25            (1<<25)
+#define ALT_TWO_TO_POW26            (1<<26)
+#define ALT_TWO_TO_POW27            (1<<27)
+#define ALT_TWO_TO_POW28            (1<<28)
+#define ALT_TWO_TO_POW29            (1<<29)
+#define ALT_TWO_TO_POW30            (1<<30)
+#define ALT_TWO_TO_POW31            (1<<31)
+#ifdef __cplusplus
+#endif  /* __HWLIB_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_clkmgr.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_clkmgr.h
index 0000000..1875a84
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_clkmgr.h
@@ -0,0 +1,6464 @@
+* Copyright 2013 Altera Corporation. All Rights Reserved.                      *
+* Redistribution and use in source and binary forms, with or without           *
+* modification, are permitted provided that the following conditions are met:  *
+* 1. Redistributions of source code must retain the above copyright notice,    *
+*    this list of conditions and the following disclaimer.                     *
+* 2. Redistributions in binary form must reproduce the above copyright notice, *
+*    this list of conditions and the following disclaimer in the documentation *
+*    and/or other materials provided with the distribution.                    *
+* 3. The name of the author may not be used to endorse or promote products     *
+*    derived from this software without specific prior written permission.     *
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO  *
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,       *
+* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
+* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;  *
+* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,     *
+* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR      *
+* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF       *
+* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                                   *
+/* Altera - ALT_CLKMGR */
+#ifndef __ALTERA_ALT_CLKMGR_H__
+#define __ALTERA_ALT_CLKMGR_H__
+#ifdef __cplusplus
+extern "C"
+ * Component : Clock Manager Module - ALT_CLKMGR
+ * Clock Manager Module
+ * Registers in the Clock Manager module
+ * Register : Control Register - ctrl
+ * Contains fields that control the entire Clock Manager.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [0]    | RW     | 0x1   | Safe Mode
+ *  [1]    | ???    | 0x0   | *UNDEFINED*
+ *  [2]    | RW     | 0x1   | Enable SafeMode on Warm Reset
+ *  [31:3] | ???    | 0x0   | *UNDEFINED*
+ * Field : Safe Mode - safemode
+ * When set the Clock Manager is in Safe Mode.
+ * In Safe Mode Clock Manager register settings defining clock behavior are ignored
+ * and clocks are set to a Safe Mode state.In Safe Mode all clocks with the
+ * optional exception of debug clocks, are directly generated from the EOSC1 clock
+ * input, all PLLs are bypassed, all programmable dividers are set to 1 and all
+ * clocks are enabled.
+ * This bit should only be cleared when clocks have been correctly configured
+ * This field is set on a cold reset and optionally on a warm reset and may not be
+ * set by SW.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_CTL_SAFEMOD register field. */
+#define ALT_CLKMGR_CTL_SAFEMOD_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_CTL_SAFEMOD register field. */
+#define ALT_CLKMGR_CTL_SAFEMOD_MSB        0
+/* The width in bits of the ALT_CLKMGR_CTL_SAFEMOD register field. */
+#define ALT_CLKMGR_CTL_SAFEMOD_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_CTL_SAFEMOD register field value. */
+#define ALT_CLKMGR_CTL_SAFEMOD_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_CTL_SAFEMOD register field value. */
+#define ALT_CLKMGR_CTL_SAFEMOD_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_CTL_SAFEMOD register field. */
+#define ALT_CLKMGR_CTL_SAFEMOD_RESET      0x1
+/* Extracts the ALT_CLKMGR_CTL_SAFEMOD field value from a register. */
+#define ALT_CLKMGR_CTL_SAFEMOD_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_CTL_SAFEMOD register field value suitable for setting the register. */
+#define ALT_CLKMGR_CTL_SAFEMOD_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Enable SafeMode on Warm Reset - ensfmdwr
+ * When set the Clock Manager will respond to a Safe Mode request from the Reset
+ * Manager on a warm reset by setting the Safe Mode bit. When clear the clock
+ * manager will not set the the Safe Mode bit on a warm reset This bit is cleared
+ * on a cold reset. Warm reset has no affect on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_MSB        2
+/* The width in bits of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_CTL_ENSFMDWR register field value. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_CTL_ENSFMDWR register field value. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_CTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_RESET      0x1
+/* Extracts the ALT_CLKMGR_CTL_ENSFMDWR field value from a register. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_CTL_ENSFMDWR register field value suitable for setting the register. */
+#define ALT_CLKMGR_CTL_ENSFMDWR_SET(value) (((value) << 2) & 0x00000004)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_CLKMGR_CTL.
+struct ALT_CLKMGR_CTL_s
+    uint32_t  safemode :  1;  /* Safe Mode */
+    uint32_t           :  1;  /* *UNDEFINED* */
+    uint32_t  ensfmdwr :  1;  /* Enable SafeMode on Warm Reset */
+    uint32_t           : 29;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_CTL. */
+typedef volatile struct ALT_CLKMGR_CTL_s  ALT_CLKMGR_CTL_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_CLKMGR_CTL register from the beginning of the component. */
+#define ALT_CLKMGR_CTL_OFST        0x0
+ * Register : PLL Bypass Register - bypass
+ * Contains fields that control bypassing each PLL.
+ * Register Layout
+ *  [0]    | RW     | 0x1   | Main PLL Bypass
+ *  [1]    | RW     | 0x1   | SDRAM PLL Bypass
+ *  [2]    | RW     | 0x0   | SDRAM PLL Bypass Source
+ *  [3]    | RW     | 0x1   | Peripheral PLL Bypass
+ *  [4]    | RW     | 0x0   | Peripheral PLL Bypass Source
+ *  [31:5] | ???    | 0x0   | *UNDEFINED*
+ * Field : Main PLL Bypass - mainpll
+ * When set, causes the Main PLL VCO and counters to be bypassed so that all clocks
+ * generated by the Main PLL are directly driven from the Main PLL input clock. The
+ * bypass source for Main PLL is the external eosc1_clk.
+ * The reset value for this bit is applied on a cold reset.   Warm reset has no
+ * affect on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_MSB        0
+/* The width in bits of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_BYPASS_MAINPLL register field value. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_BYPASS_MAINPLL register field value. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_BYPASS_MAINPLL register field. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_RESET      0x1
+/* Extracts the ALT_CLKMGR_BYPASS_MAINPLL field value from a register. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_BYPASS_MAINPLL register field value suitable for setting the register. */
+#define ALT_CLKMGR_BYPASS_MAINPLL_SET(value) (((value) << 0) & 0x00000001)
+ * Field : SDRAM PLL Bypass - sdrpll
+ * When set, causes the SDRAM PLL VCO and counters to be bypassed so that all
+ * clocks generated by the SDRAM PLL are directly driven from either eosc1_clk or
+ * the SDRAM PLL input clock.
+ * The bypass clock source for SDRAM PLL is determined by the SDRAM PLL Bypass
+ * Source Register bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_MSB        1
+/* The width in bits of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_BYPASS_SDRPLL register field value. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_BYPASS_SDRPLL register field value. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_BYPASS_SDRPLL register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_RESET      0x1
+/* Extracts the ALT_CLKMGR_BYPASS_SDRPLL field value from a register. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_BYPASS_SDRPLL register field value suitable for setting the register. */
+#define ALT_CLKMGR_BYPASS_SDRPLL_SET(value) (((value) << 1) & 0x00000002)
+ * Field : SDRAM PLL Bypass Source - sdrpllsrc
+ * This bit defines the bypass source forSDRAM PLL.
+ * When changing fields that affect VCO lock the PLL must be bypassed and this bit
+ * must be set to OSC1_CLK.
+ * Field Enumeration Values:
+ *  Enum                                           | Value | Description
+ *  ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_EOSC1     | 0x0   | Select EOSC1
+ *  ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_INPUT_MUX | 0x1   | Select PLL Input Mux
+ * Enumerated value for register field ALT_CLKMGR_BYPASS_SDRPLLSRC
+ * Select EOSC1
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_EOSC1      0x0
+ * Select PLL Input Mux
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_E_SELECT_INPUT_MUX  0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_MSB        2
+/* The width in bits of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_BYPASS_SDRPLLSRC register field value. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_BYPASS_SDRPLLSRC register field value. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_BYPASS_SDRPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_RESET      0x0
+/* Extracts the ALT_CLKMGR_BYPASS_SDRPLLSRC field value from a register. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_BYPASS_SDRPLLSRC register field value suitable for setting the register. */
+#define ALT_CLKMGR_BYPASS_SDRPLLSRC_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Peripheral PLL Bypass - perpll
+ * When set, causes the Peripheral PLL VCO and counters to be bypassed so that all
+ * clocks generated by the Peripheral PLL are directly driven from either eosc1_clk
+ * or the Peripheral PLL input clock.
+ * The bypass clock source for Peripheral PLL is determined by the Peripheral PLL
+ * Bypass Source Register bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_PERPLL register field. */
+#define ALT_CLKMGR_BYPASS_PERPLL_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_PERPLL register field. */
+#define ALT_CLKMGR_BYPASS_PERPLL_MSB        3
+/* The width in bits of the ALT_CLKMGR_BYPASS_PERPLL register field. */
+#define ALT_CLKMGR_BYPASS_PERPLL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_BYPASS_PERPLL register field value. */
+#define ALT_CLKMGR_BYPASS_PERPLL_SET_MSK    0x00000008
+/* The mask used to clear the ALT_CLKMGR_BYPASS_PERPLL register field value. */
+#define ALT_CLKMGR_BYPASS_PERPLL_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_CLKMGR_BYPASS_PERPLL register field. */
+#define ALT_CLKMGR_BYPASS_PERPLL_RESET      0x1
+/* Extracts the ALT_CLKMGR_BYPASS_PERPLL field value from a register. */
+#define ALT_CLKMGR_BYPASS_PERPLL_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_CLKMGR_BYPASS_PERPLL register field value suitable for setting the register. */
+#define ALT_CLKMGR_BYPASS_PERPLL_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Peripheral PLL Bypass Source - perpllsrc
+ * This bit defines the bypass source forPeripheral PLL.
+ *  ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_EOSC1     | 0x0   | Select EOSC1
+ *  ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_INPUT_MUX | 0x1   | Select PLL Input Mux
+ * Enumerated value for register field ALT_CLKMGR_BYPASS_PERPLLSRC
+ * Select EOSC1
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_EOSC1      0x0
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_E_SELECT_INPUT_MUX  0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_MSB        4
+/* The width in bits of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_BYPASS_PERPLLSRC register field value. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET_MSK    0x00000010
+/* The mask used to clear the ALT_CLKMGR_BYPASS_PERPLLSRC register field value. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_CLR_MSK    0xffffffef
+/* The reset value of the ALT_CLKMGR_BYPASS_PERPLLSRC register field. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_RESET      0x0
+/* Extracts the ALT_CLKMGR_BYPASS_PERPLLSRC field value from a register. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_CLKMGR_BYPASS_PERPLLSRC register field value suitable for setting the register. */
+#define ALT_CLKMGR_BYPASS_PERPLLSRC_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_CLKMGR_BYPASS.
+struct ALT_CLKMGR_BYPASS_s
+    uint32_t  mainpll   :  1;  /* Main PLL Bypass */
+    uint32_t  sdrpll    :  1;  /* SDRAM PLL Bypass */
+    uint32_t  sdrpllsrc :  1;  /* SDRAM PLL Bypass Source */
+    uint32_t  perpll    :  1;  /* Peripheral PLL Bypass */
+    uint32_t  perpllsrc :  1;  /* Peripheral PLL Bypass Source */
+    uint32_t            : 27;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_BYPASS. */
+typedef volatile struct ALT_CLKMGR_BYPASS_s  ALT_CLKMGR_BYPASS_t;
+/* The byte offset of the ALT_CLKMGR_BYPASS register from the beginning of the component. */
+#define ALT_CLKMGR_BYPASS_OFST        0x4
+ * Register : Interrupt Status Register - inter
+ * Contains fields that indicate the PLL lock status.
+ * Fields are only reset by a cold reset.
+ * Register Layout
+ *  [0]    | RW     | 0x0     | Main PLL Achieved Lock
+ *  [1]    | RW     | 0x0     | Peripheral PLL Achieved Lock
+ *  [2]    | RW     | 0x0     | SDRAM PLL Achieved Lock
+ *  [3]    | RW     | 0x0     | Main PLL Lost Lock
+ *  [4]    | RW     | 0x0     | Peripheral PLL Lost Lock
+ *  [5]    | RW     | 0x0     | SDRAM PLL Lost Lock
+ *  [6]    | R      | Unknown | Main PLL Current Lock Status
+ *  [7]    | R      | Unknown | Peripheral PLL Current Lock Status
+ *  [8]    | R      | Unknown | SDRAM PLL Current Lock Status
+ *  [31:9] | ???    | 0x0     | *UNDEFINED*
+ * Field : Main PLL Achieved Lock - mainpllachieved
+ * If 1, the Main PLL has achieved lock at least once since this bit was cleared.
+ * If 0, the Main PLL has not achieved lock since this bit was cleared.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_MSB        0
+/* The width in bits of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_INTER_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_MAINPLLACHIEVED field value from a register. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_INTER_MAINPLLACHIEVED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_MAINPLLACHIEVED_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Peripheral PLL Achieved Lock - perpllachieved
+ * If 1, the Peripheral PLL has achieved lock at least once since this bit was
+ * cleared. If 0, the Peripheral PLL has not achieved lock since this bit was
+ * cleared.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_MSB        1
+/* The width in bits of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_PERPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_INTER_PERPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_INTER_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_PERPLLACHIEVED field value from a register. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_INTER_PERPLLACHIEVED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_PERPLLACHIEVED_SET(value) (((value) << 1) & 0x00000002)
+ * Field : SDRAM PLL Achieved Lock - sdrpllachieved
+ * If 1, the SDRAM PLL has achieved lock at least once since this bit was cleared.
+ * If 0, the SDRAM PLL has not achieved lock since this bit was cleared.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_MSB        2
+/* The width in bits of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_INTER_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_SDRPLLACHIEVED field value from a register. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_INTER_SDRPLLACHIEVED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_SDRPLLACHIEVED_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Main PLL Lost Lock - mainplllost
+ * If 1, the Main PLL has lost lock at least once since this bit was cleared. If 0,
+ * the Main PLL has not lost lock since this bit was cleared.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_MSB        3
+/* The width in bits of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_MAINPLLLOST register field value. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_SET_MSK    0x00000008
+/* The mask used to clear the ALT_CLKMGR_INTER_MAINPLLLOST register field value. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_CLKMGR_INTER_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_MAINPLLLOST field value from a register. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_CLKMGR_INTER_MAINPLLLOST register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_MAINPLLLOST_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Peripheral PLL Lost Lock - perplllost
+ * If 1, the Peripheral PLL has lost lock at least once since this bit was cleared.
+ * If 0, the Peripheral PLL has not lost lock since this bit was cleared.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_MSB        4
+/* The width in bits of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_PERPLLLOST register field value. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_SET_MSK    0x00000010
+/* The mask used to clear the ALT_CLKMGR_INTER_PERPLLLOST register field value. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_CLR_MSK    0xffffffef
+/* The reset value of the ALT_CLKMGR_INTER_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_PERPLLLOST field value from a register. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_CLKMGR_INTER_PERPLLLOST register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_PERPLLLOST_SET(value) (((value) << 4) & 0x00000010)
+ * Field : SDRAM PLL Lost Lock - sdrplllost
+ * If 1, the SDRAM PLL has lost lock at least once since this bit was cleared. If
+ * 0, the SDRAM PLL has not lost lock since this bit was cleared.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_MSB        5
+/* The width in bits of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_SDRPLLLOST register field value. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_SET_MSK    0x00000020
+/* The mask used to clear the ALT_CLKMGR_INTER_SDRPLLLOST register field value. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_CLKMGR_INTER_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_SDRPLLLOST field value from a register. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_CLKMGR_INTER_SDRPLLLOST register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_SDRPLLLOST_SET(value) (((value) << 5) & 0x00000020)
+ * Field : Main PLL Current Lock Status - mainplllocked
+ * If 1, the Main PLL is currently locked. If 0, the Main PLL is currently not
+ * locked.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_MSB        6
+/* The width in bits of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_MAINPLLLOCKED register field value. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET_MSK    0x00000040
+/* The mask used to clear the ALT_CLKMGR_INTER_MAINPLLLOCKED register field value. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_CLKMGR_INTER_MAINPLLLOCKED register field is UNKNOWN. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_MAINPLLLOCKED field value from a register. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_CLKMGR_INTER_MAINPLLLOCKED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_MAINPLLLOCKED_SET(value) (((value) << 6) & 0x00000040)
+ * Field : Peripheral PLL Current Lock Status - perplllocked
+ * If 1, the Peripheral PLL is currently locked. If 0, the Peripheral PLL is
+ * currently not locked.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_PERPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_PERPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_MSB        7
+/* The width in bits of the ALT_CLKMGR_INTER_PERPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_PERPLLLOCKED register field value. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET_MSK    0x00000080
+/* The mask used to clear the ALT_CLKMGR_INTER_PERPLLLOCKED register field value. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_CLKMGR_INTER_PERPLLLOCKED register field is UNKNOWN. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_PERPLLLOCKED field value from a register. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_CLKMGR_INTER_PERPLLLOCKED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_PERPLLLOCKED_SET(value) (((value) << 7) & 0x00000080)
+ * Field : SDRAM PLL Current Lock Status - sdrplllocked
+ * If 1, the SDRAM PLL is currently locked. If 0, the SDRAM PLL is currently not
+ * locked.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_MSB        8
+/* The width in bits of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTER_SDRPLLLOCKED register field value. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET_MSK    0x00000100
+/* The mask used to clear the ALT_CLKMGR_INTER_SDRPLLLOCKED register field value. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_CLKMGR_INTER_SDRPLLLOCKED register field is UNKNOWN. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTER_SDRPLLLOCKED field value from a register. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_CLKMGR_INTER_SDRPLLLOCKED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTER_SDRPLLLOCKED_SET(value) (((value) << 8) & 0x00000100)
+ * The struct declaration for register ALT_CLKMGR_INTER.
+struct ALT_CLKMGR_INTER_s
+    uint32_t        mainpllachieved :  1;  /* Main PLL Achieved Lock */
+    uint32_t        perpllachieved  :  1;  /* Peripheral PLL Achieved Lock */
+    uint32_t        sdrpllachieved  :  1;  /* SDRAM PLL Achieved Lock */
+    uint32_t        mainplllost     :  1;  /* Main PLL Lost Lock */
+    uint32_t        perplllost      :  1;  /* Peripheral PLL Lost Lock */
+    uint32_t        sdrplllost      :  1;  /* SDRAM PLL Lost Lock */
+    const uint32_t  mainplllocked   :  1;  /* Main PLL Current Lock Status */
+    const uint32_t  perplllocked    :  1;  /* Peripheral PLL Current Lock Status */
+    const uint32_t  sdrplllocked    :  1;  /* SDRAM PLL Current Lock Status */
+    uint32_t                        : 23;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_INTER. */
+typedef volatile struct ALT_CLKMGR_INTER_s  ALT_CLKMGR_INTER_t;
+/* The byte offset of the ALT_CLKMGR_INTER register from the beginning of the component. */
+#define ALT_CLKMGR_INTER_OFST        0x8
+ * Register : Interrupt Enable Register - intren
+ * Contain fields that enable the interrupt.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | Main PLL Achieved Lock Interrupt Enable
+ *  [1]    | RW     | 0x0   | Peripheral PLL Achieved Lock Interrupt Enable
+ *  [2]    | RW     | 0x0   | SDRAM PLL Achieved Lock Interrupt Enable
+ *  [3]    | RW     | 0x0   | Main PLL Achieved Lock Interrupt Enable
+ *  [4]    | RW     | 0x0   | Peripheral PLL Achieved Lock Interrupt Enable
+ *  [5]    | RW     | 0x0   | SDRAM PLL Achieved Lock Interrupt Enable
+ *  [31:6] | ???    | 0x0   | *UNDEFINED*
+ * Field : Main PLL Achieved Lock Interrupt Enable - mainpllachieved
+ * When set to 1, the Main PLL achieved lock bit is ORed into the Clock Manager
+ * interrupt output.  When set to 0 the Main PLL achieved lock bit is not ORed into
+ * the Clock Manager interrupt output.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_MSB        0
+/* The width in bits of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTREN_MAINPLLACHIEVED field value from a register. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_INTREN_MAINPLLACHIEVED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTREN_MAINPLLACHIEVED_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Peripheral PLL Achieved Lock Interrupt Enable - perpllachieved
+ * When set to 1, the Peripheral PLL achieved lock bit is ORed into the Clock
+ * Manager interrupt output.  When set to 0 the Peripheral PLL achieved lock bit is
+ * not ORed into the Clock Manager interrupt output.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_MSB        1
+/* The width in bits of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_INTREN_PERPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTREN_PERPLLACHIEVED field value from a register. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_INTREN_PERPLLACHIEVED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTREN_PERPLLACHIEVED_SET(value) (((value) << 1) & 0x00000002)
+ * Field : SDRAM PLL Achieved Lock Interrupt Enable - sdrpllachieved
+ * When set to 1, the SDRAM PLL achieved lock bit is ORed into the Clock Manager
+ * interrupt output.  When set to 0 the SDRAM PLL achieved lock bit is not ORed
+ * into the Clock Manager interrupt output.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_MSB        2
+/* The width in bits of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field value. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTREN_SDRPLLACHIEVED field value from a register. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_INTREN_SDRPLLACHIEVED register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTREN_SDRPLLACHIEVED_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Main PLL Achieved Lock Interrupt Enable - mainplllost
+ * When set to 1, the Main PLL lost lock bit is ORed into the Clock Manager
+ * interrupt output.  When set to 0 the Main PLL lost lock bit is not ORed into the
+ * Clock Manager interrupt output.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_MSB        3
+/* The width in bits of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTREN_MAINPLLLOST register field value. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET_MSK    0x00000008
+/* The mask used to clear the ALT_CLKMGR_INTREN_MAINPLLLOST register field value. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_CLKMGR_INTREN_MAINPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTREN_MAINPLLLOST field value from a register. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_CLKMGR_INTREN_MAINPLLLOST register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTREN_MAINPLLLOST_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Peripheral PLL Achieved Lock Interrupt Enable - perplllost
+ * When set to 1, the Peripheral PLL lost lock bit is ORed into the Clock Manager
+ * interrupt output.  When set to 0 the Peripheral PLL lost lock bit is not ORed
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_MSB        4
+/* The width in bits of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTREN_PERPLLLOST register field value. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_SET_MSK    0x00000010
+/* The mask used to clear the ALT_CLKMGR_INTREN_PERPLLLOST register field value. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_CLR_MSK    0xffffffef
+/* The reset value of the ALT_CLKMGR_INTREN_PERPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTREN_PERPLLLOST field value from a register. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_CLKMGR_INTREN_PERPLLLOST register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTREN_PERPLLLOST_SET(value) (((value) << 4) & 0x00000010)
+ * Field : SDRAM PLL Achieved Lock Interrupt Enable - sdrplllost
+ * When set to 1, the SDRAM PLL lost lock bit is ORed into the Clock Manager
+ * interrupt output.  When set to 0 the SDRAM PLL lost lock bit is not ORed into
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_MSB        5
+/* The width in bits of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_INTREN_SDRPLLLOST register field value. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET_MSK    0x00000020
+/* The mask used to clear the ALT_CLKMGR_INTREN_SDRPLLLOST register field value. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_CLKMGR_INTREN_SDRPLLLOST register field. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_RESET      0x0
+/* Extracts the ALT_CLKMGR_INTREN_SDRPLLLOST field value from a register. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_CLKMGR_INTREN_SDRPLLLOST register field value suitable for setting the register. */
+#define ALT_CLKMGR_INTREN_SDRPLLLOST_SET(value) (((value) << 5) & 0x00000020)
+ * The struct declaration for register ALT_CLKMGR_INTREN.
+struct ALT_CLKMGR_INTREN_s
+    uint32_t  mainpllachieved :  1;  /* Main PLL Achieved Lock Interrupt Enable */
+    uint32_t  perpllachieved  :  1;  /* Peripheral PLL Achieved Lock Interrupt Enable */
+    uint32_t  sdrpllachieved  :  1;  /* SDRAM PLL Achieved Lock Interrupt Enable */
+    uint32_t  mainplllost     :  1;  /* Main PLL Achieved Lock Interrupt Enable */
+    uint32_t  perplllost      :  1;  /* Peripheral PLL Achieved Lock Interrupt Enable */
+    uint32_t  sdrplllost      :  1;  /* SDRAM PLL Achieved Lock Interrupt Enable */
+    uint32_t                  : 26;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_INTREN. */
+typedef volatile struct ALT_CLKMGR_INTREN_s  ALT_CLKMGR_INTREN_t;
+/* The byte offset of the ALT_CLKMGR_INTREN register from the beginning of the component. */
+#define ALT_CLKMGR_INTREN_OFST        0xc
+ * Register : Debug clock Control Register - dbctrl
+ * Contains fields that control the debug clocks.
+ * Register Layout
+ *  [0]    | RW     | 0x1   | Debug Clocks Stay on EOSC1_CLK
+ *  [1]    | RW     | 0x1   | Debug Clocks Enable Safe Mode
+ *  [31:2] | ???    | 0x0   | *UNDEFINED*
+ * Field : Debug Clocks Stay on EOSC1_CLK - stayosc1
+ * When this bit is set the debug root clock (Main PLL C2 output) will always be
+ * bypassed to the EOSC1_clk independent of any other clock manager settings.
+ * When clear the debug source will be a function of register settings in the clock
+ * manager.  Clocks affected by this bit are dbg_at_clk, dbg_clk, dbg_trace_clk,
+ * and dbg_timer_clk.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_MSB        0
+/* The width in bits of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_DBCTL_STAYOSC1 register field value. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_DBCTL_STAYOSC1 register field value. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_DBCTL_STAYOSC1 register field. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_RESET      0x1
+/* Extracts the ALT_CLKMGR_DBCTL_STAYOSC1 field value from a register. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_DBCTL_STAYOSC1 register field value suitable for setting the register. */
+#define ALT_CLKMGR_DBCTL_STAYOSC1_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Debug Clocks Enable Safe Mode - ensfmdwr
+ * When this bit is set the debug clocks will be affected by the assertion of Safe
+ * Mode on a warm reset if Stay OSC1 is not set.
+ * When this bit is clear the debug clocks will not be affected by the assertion of
+ * Safe Mode on a warm reset.
+ * If Debug Clocks are in Safe Mode they are taken out of Safe Mode when the Safe
+ * Mode bit is cleared independent of this bit.The reset value of this bit is
+ * applied on a cold reset; warm reset has no affect on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_MSB        1
+/* The width in bits of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_DBCTL_ENSFMDWR register field value. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_DBCTL_ENSFMDWR register field value. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_DBCTL_ENSFMDWR register field. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_RESET      0x1
+/* Extracts the ALT_CLKMGR_DBCTL_ENSFMDWR field value from a register. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_DBCTL_ENSFMDWR register field value suitable for setting the register. */
+#define ALT_CLKMGR_DBCTL_ENSFMDWR_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_CLKMGR_DBCTL.
+struct ALT_CLKMGR_DBCTL_s
+    uint32_t  stayosc1 :  1;  /* Debug Clocks Stay on EOSC1_CLK */
+    uint32_t  ensfmdwr :  1;  /* Debug Clocks Enable Safe Mode */
+    uint32_t           : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_DBCTL. */
+typedef volatile struct ALT_CLKMGR_DBCTL_s  ALT_CLKMGR_DBCTL_t;
+/* The byte offset of the ALT_CLKMGR_DBCTL register from the beginning of the component. */
+#define ALT_CLKMGR_DBCTL_OFST        0x10
+ * Register : Status Register - stat
+ * Provides status of Hardware Managed Clock transition State Machine.
+ * Register Layout
+ *  [0]    | R      | 0x0   | HW Managed Clocks BUSY
+ *  [31:1] | ???    | 0x0   | *UNDEFINED*
+ * Field : HW Managed Clocks BUSY - busy
+ * This read only bit indicates that the Hardware Managed clock's state machine is
+ * active.  If the state machine is active, then the clocks are in transition.
+ * Software should poll this bit after changing the source of internal clocks when
+ * writing to the BYPASS, CTRL or DBCTRL registers.   Immediately following writes
+ * to any of these registers, SW should wait until this bit is IDLE before
+ * proceeding with any other register writes in the Clock Manager.
+ * The reset value of this bit is applied on a cold reset; warm reset has no affect
+ * on this bit.
+ *  ALT_CLKMGR_STAT_BUSY_E_IDLE | 0x0   | Clocks stable
+ *  ALT_CLKMGR_STAT_BUSY_E_BUSY | 0x1   | Clocks in transition
+ * Enumerated value for register field ALT_CLKMGR_STAT_BUSY
+ * Clocks stable
+#define ALT_CLKMGR_STAT_BUSY_E_IDLE 0x0
+ * Clocks in transition
+#define ALT_CLKMGR_STAT_BUSY_E_BUSY 0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_STAT_BUSY register field. */
+#define ALT_CLKMGR_STAT_BUSY_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_STAT_BUSY register field. */
+#define ALT_CLKMGR_STAT_BUSY_MSB        0
+/* The width in bits of the ALT_CLKMGR_STAT_BUSY register field. */
+#define ALT_CLKMGR_STAT_BUSY_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_STAT_BUSY register field value. */
+#define ALT_CLKMGR_STAT_BUSY_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_STAT_BUSY register field value. */
+#define ALT_CLKMGR_STAT_BUSY_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_STAT_BUSY register field. */
+#define ALT_CLKMGR_STAT_BUSY_RESET      0x0
+/* Extracts the ALT_CLKMGR_STAT_BUSY field value from a register. */
+#define ALT_CLKMGR_STAT_BUSY_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_STAT_BUSY register field value suitable for setting the register. */
+#define ALT_CLKMGR_STAT_BUSY_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_CLKMGR_STAT.
+struct ALT_CLKMGR_STAT_s
+    const uint32_t  busy :  1;  /* HW Managed Clocks BUSY */
+    uint32_t             : 31;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_STAT. */
+typedef volatile struct ALT_CLKMGR_STAT_s  ALT_CLKMGR_STAT_t;
+/* The byte offset of the ALT_CLKMGR_STAT register from the beginning of the component. */
+#define ALT_CLKMGR_STAT_OFST        0x14
+ * Register Group : Main PLL Group - ALT_CLKMGR_MAINPLL
+ * Main PLL Group
+ * Contains registers with settings for the Main PLL.
+ * Register : Main PLL VCO Control Register - vco
+ * Contains settings that control the Main PLL VCO. The VCO output frequency is the
+ * input frequency multiplied by the numerator (M+1) and divided by the denominator
+ * (N+1). The VCO input clock source is always eosc1_clk.
+ * Register Layout
+ *  [0]     | RW     | 0x1   | BG PWRDN
+ *  [1]     | RW     | 0x0   | Enable
+ *  [2]     | RW     | 0x1   | Power down
+ *  [15:3]  | RW     | 0x1   | Numerator (M)
+ *  [21:16] | RW     | 0x1   | Denominator (N)
+ *  [23:22] | ???    | 0x0   | *UNDEFINED*
+ *  [24]    | RW     | 0x0   | All Output Counter Reset
+ *  [30:25] | RW     | 0x0   | Output Counter Reset
+ *  [31]    | RW     | 0x1   | External Regulator Input Select
+ * Field : BG PWRDN - bgpwrdn
+ * If '1', powers down bandgap. If '0', bandgap is not power down.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_MSB        0
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_BGPWRDN field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_BGPWRDN register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Enable - en
+ * If '1', VCO is enabled. If '0', VCO is in reset.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_MSB        1
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_EN register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_EN register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_EN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_EN field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_EN register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Power down - pwrdn
+ * If '1', power down analog circuitry. If '0', analog circuitry not powered down.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_MSB        2
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_PWRDN field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_PWRDN register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Numerator (M) - numer
+ * Numerator in VCO output frequency equation. For incremental frequency change, if
+ * the new value lead to less than 20% of the frequency change, this value can be
+ * changed without resetting the PLL. The Numerator and Denominator can not be
+ * changed at the same time for incremental frequency changed.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_MSB        15
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_WIDTH      13
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_NUMER register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET_MSK    0x0000fff8
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_NUMER register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_CLR_MSK    0xffff0007
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_NUMER field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_NUMER register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
+ * Field : Denominator (N) - denom
+ * Denominator in VCO output frequency equation. For incremental frequency change,
+ * if the new value lead to less than 20% of the frequency change, this value can
+ * be changed without resetting the PLL. The Numerator and Denominator can not be
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_MSB        21
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_DENOM register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET_MSK    0x003f0000
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_DENOM register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_CLR_MSK    0xffc0ffff
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_DENOM field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_DENOM register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
+ * Field : All Output Counter Reset - outresetall
+ * Before releasing Bypass, All Output Counter Reset must be set and cleared by
+ * software for correct clock operation.
+ * If '1', Reset phase multiplexer and all output counter state. So that after the
+ * assertion all the clocks output are start from rising edge align.
+ * If '0', phase multiplexer and output counter state not reset and no change to
+ * the phase of the clock outputs.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_LSB        24
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_MSB        24
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET_MSK    0x01000000
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_CLR_MSK    0xfeffffff
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
+ * Field : Output Counter Reset - outreset
+ * Resets the individual PLL output counter.
+ * For software to change the PLL output counter without producing glitches on the
+ * respective clock, SW must set the VCO register respective Output Counter Reset
+ * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
+ * the Output Counter Reset Ack Status Register. Software then writes the
+ * appropriate counter register, and then clears the respective VCO register Output
+ * Counter Reset bit.
+ * LSB 'outreset[0]' corresponds to PLL output clock C0, etc.
+ * If set to '1', reset output divider, no clock output from counter.
+ * If set to '0', counter is not reset.
+ * on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_LSB        25
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_MSB        30
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET_MSK    0x7e000000
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_CLR_MSK    0x81ffffff
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_OUTRST field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_OUTRST register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
+ * Field : External Regulator Input Select - regextsel
+ * If set to '1', the external regulator is selected for the PLL.
+ * If set to '0', the internal regulator is slected.
+ * It is strongly recommended to select the external regulator while the PLL is not
+ * enabled (in reset), and  then disable the external regulater once the PLL
+ * becomes enabled.  Software should simulateously update the 'Enable' bit and the
+ * 'External Regulator Input Select' in the same write access to the VCO register.
+ * When the 'Enable' bit is clear, the 'External Regulator Input Select' should be
+ * set, and vice versa.
+ * on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_LSB        31
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_MSB        31
+/* The width in bits of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET_MSK    0x80000000
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field value. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_CLR_MSK    0x7fffffff
+/* The reset value of the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL field value from a register. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
+/* Produces a ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_VCO.
+struct ALT_CLKMGR_MAINPLL_VCO_s
+    uint32_t  bgpwrdn     :  1;  /* BG PWRDN */
+    uint32_t  en          :  1;  /* Enable */
+    uint32_t  pwrdn       :  1;  /* Power down */
+    uint32_t  numer       : 13;  /* Numerator (M) */
+    uint32_t  denom       :  6;  /* Denominator (N) */
+    uint32_t              :  2;  /* *UNDEFINED* */
+    uint32_t  outresetall :  1;  /* All Output Counter Reset */
+    uint32_t  outreset    :  6;  /* Output Counter Reset */
+    uint32_t  regextsel   :  1;  /* External Regulator Input Select */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_VCO. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_VCO_s  ALT_CLKMGR_MAINPLL_VCO_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_VCO register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_VCO_OFST        0x0
+ * Register : Main PLL VCO Advanced Control Register - misc
+ * Contains VCO control signals and other PLL control signals need to be
+ * controllable through register.
+ * Register Layout
+ *  [0]     | RW     | 0x0   | Loop Bandwidth Adjust Enabled
+ *  [12:1]  | RW     | 0x1   | Loop Bandwidth Adjust
+ *  [13]    | RW     | 0x0   | Fast Locking Enable
+ *  [14]    | RW     | 0x1   | Saturation Enable
+ *  [31:15] | ???    | 0x0   | *UNDEFINED*
+ * Field : Loop Bandwidth Adjust Enabled - bwadjen
+ * If set to 1, the Loop Bandwidth Adjust value comes from the Loop Bandwidth
+ * Adjust field.
+ * If set to 0, the Loop Bandwidth Adjust value equals the M field divided by 2
+ * value of the VCO Control Register.  The M divided by 2 is the upper 12 bits
+ * (12:1) of the M field in the VCO register.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_MSB        0
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MISC_BWADJEN field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_MISC_BWADJEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Loop Bandwidth Adjust - bwadj
+ * Provides Loop Bandwidth Adjust value.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_MSB        12
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_WIDTH      12
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET_MSK    0x00001ffe
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_CLR_MSK    0xffffe001
+/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_MISC_BWADJ field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
+/* Produces a ALT_CLKMGR_MAINPLL_MISC_BWADJ register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MISC_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
+ * Field : Fast Locking Enable - fasten
+ * Enables fast locking circuit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_MSB        13
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET_MSK    0x00002000
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MISC_FASTEN field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_CLKMGR_MAINPLL_MISC_FASTEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MISC_FASTEN_SET(value) (((value) << 13) & 0x00002000)
+ * Field : Saturation Enable - saten
+ * Enables saturation behavior.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_MSB        14
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MISC_SATEN register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET_MSK    0x00004000
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MISC_SATEN register field value. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_CLKMGR_MAINPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_MISC_SATEN field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_CLKMGR_MAINPLL_MISC_SATEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MISC_SATEN_SET(value) (((value) << 14) & 0x00004000)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_MISC.
+struct ALT_CLKMGR_MAINPLL_MISC_s
+    uint32_t  bwadjen :  1;  /* Loop Bandwidth Adjust Enabled */
+    uint32_t  bwadj   : 12;  /* Loop Bandwidth Adjust */
+    uint32_t  fasten  :  1;  /* Fast Locking Enable */
+    uint32_t  saten   :  1;  /* Saturation Enable */
+    uint32_t          : 17;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MISC. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_MISC_s  ALT_CLKMGR_MAINPLL_MISC_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_MISC register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_MISC_OFST        0x4
+ * Register : Main PLL C0 Control Register for Clock mpu_clk - mpuclk
+ * Contains settings that control clock mpu_clk generated from the C0 output of the
+ * Main PLL.
+ * Only reset by a cold reset.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [8:0]  | RW     | 0x0   | Counter
+ * Field : Counter - cnt
+ * Divides the VCO/2 frequency by the value+1 in this field.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MPUCLK_CNT field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_MPUCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_MPUCLK.
+struct ALT_CLKMGR_MAINPLL_MPUCLK_s
+    uint32_t  cnt :  9;  /* Counter */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MPUCLK. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_MPUCLK_s  ALT_CLKMGR_MAINPLL_MPUCLK_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_CLKMGR_MAINPLL_MPUCLK register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_MPUCLK_OFST        0x8
+ * Register : Main PLL C1 Control Register for Clock main_clk - mainclk
+ * Contains settings that control clock main_clk generated from the C1 output of
+ * the Main PLL.
+ * Register Layout
+ * Divides the VCO/4 frequency by the value+1 in this field.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MAINCLK_CNT field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_MAINCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINCLK.
+struct ALT_CLKMGR_MAINPLL_MAINCLK_s
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINCLK. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_MAINCLK_s  ALT_CLKMGR_MAINPLL_MAINCLK_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINCLK register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_MAINCLK_OFST        0xc
+ * Register : Main PLL C2 Control Register for Clock dbg_base_clk - dbgatclk
+ * Contains settings that control clock dbg_base_clk generated from the C2 output
+ * of the Main PLL.
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_DBGATCLK_CNT field value from a register. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_DBGATCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_DBGATCLK.
+struct ALT_CLKMGR_MAINPLL_DBGATCLK_s
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_DBGATCLK. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_DBGATCLK_s  ALT_CLKMGR_MAINPLL_DBGATCLK_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_DBGATCLK register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_DBGATCLK_OFST        0x10
+ * Register : Main PLL C3 Control Register for Clock main_qspi_clk - mainqspiclk
+ * Contains settings that control clock main_qspi_clk generated from the C3 output
+ * Register Layout
+ *  [8:0]  | RW     | 0x3   | Counter
+ * Divides the VCO frequency by the value+1 in this field.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_RESET      0x3
+/* Extracts the ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINQSPICLK.
+struct ALT_CLKMGR_MAINPLL_MAINQSPICLK_s
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINQSPICLK. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_MAINQSPICLK_s  ALT_CLKMGR_MAINPLL_MAINQSPICLK_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINQSPICLK register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_MAINQSPICLK_OFST        0x14
+ * Register : Main PLL C4 Control Register for Clock main_nand_sdmmc_clk - mainnandsdmmcclk
+ * Contains settings that control clock main_nand_sdmmc_clk generated from the C4
+ * output of the Main PLL.
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_RESET      0x3
+/* Extracts the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK.
+struct ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_s
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_s  ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_OFST        0x18
+ * Register : Main PLL C5 Control Register for Clock cfg_s2f_user0_clk - cfgs2fuser0clk
+ * Contains settings that control clock cfg_s2f_user0_clk generated from the C5
+ * Qsys and user documenation refer to cfg_s2f_user0_clk as cfg_h2f_user0_clk.
+ * Register Layout
+ *  [8:0]  | RW     | 0xf   | Counter
+ *  [31:9] | ???    | 0x0   | *UNDEFINED*
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field value. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_RESET      0xf
+/* Extracts the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT field value from a register. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK.
+struct ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_s
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_s  ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_OFST        0x1c
+ * Register : Enable Register - en
+ * Contains fields that control clock enables for clocks derived from the Main PLL.
+ * 1: The clock is enabled.
+ * 0: The clock is disabled.
+ * Fields are only reset by a cold reset.
+ * Register Layout
+ *  [0]     | RW     | 0x1   | l4_main_clk Enable
+ *  [1]     | RW     | 0x1   | l3_mp_clk Enable
+ *  [2]     | RW     | 0x1   | l4_mp_clk Enable
+ *  [3]     | RW     | 0x1   | l4_sp_clk Enable
+ *  [4]     | RW     | 0x1   | dbg_at_clk Enable
+ *  [5]     | RW     | 0x1   | dbg_clk Enable
+ *  [6]     | RW     | 0x1   | dbg_trace_clk Enable
+ *  [7]     | RW     | 0x1   | dbg_timer_clk Enable
+ *  [8]     | RW     | 0x1   | cfg_clk Enable
+ *  [9]     | RW     | 0x1   | s2f_user0_clk Enable
+ *  [31:10] | ???    | 0x0   | *UNDEFINED*
+ * Field : l4_main_clk Enable - l4mainclk
+ * Enables clock l4_main_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_MSB        0
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_L4MAINCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_L4MAINCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MAINCLK_SET(value) (((value) << 0) & 0x00000001)
+ * Field : l3_mp_clk Enable - l3mpclk
+ * Enables clock l3_mp_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_MSB        1
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_L3MPCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_L3MPCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_L3MPCLK_SET(value) (((value) << 1) & 0x00000002)
+ * Field : l4_mp_clk Enable - l4mpclk
+ * Enables clock l4_mp_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_MSB        2
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_L4MPCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_L4MPCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_L4MPCLK_SET(value) (((value) << 2) & 0x00000004)
+ * Field : l4_sp_clk Enable - l4spclk
+ * Enables clock l4_sp_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_MSB        3
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET_MSK    0x00000008
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_L4SPCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_L4SPCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_L4SPCLK_SET(value) (((value) << 3) & 0x00000008)
+ * Field : dbg_at_clk Enable - dbgatclk
+ * Enables clock dbg_at_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_MSB        4
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET_MSK    0x00000010
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_CLR_MSK    0xffffffef
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGATCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGATCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGATCLK_SET(value) (((value) << 4) & 0x00000010)
+ * Field : dbg_clk Enable - dbgclk
+ * Enables clock dbg_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_MSB        5
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET_MSK    0x00000020
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGCLK_SET(value) (((value) << 5) & 0x00000020)
+ * Field : dbg_trace_clk Enable - dbgtraceclk
+ * Enables clock dbg_trace_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_MSB        6
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET_MSK    0x00000040
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTRACECLK_SET(value) (((value) << 6) & 0x00000040)
+ * Field : dbg_timer_clk Enable - dbgtimerclk
+ * Enables clock dbg_timer_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_MSB        7
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET_MSK    0x00000080
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_DBGTMRCLK_SET(value) (((value) << 7) & 0x00000080)
+ * Field : cfg_clk Enable - cfgclk
+ * Enables clock cfg_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_MSB        8
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET_MSK    0x00000100
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_CFGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_CFGCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_CFGCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_CFGCLK_SET(value) (((value) << 8) & 0x00000100)
+ * Field : s2f_user0_clk Enable - s2fuser0clk
+ * Enables clock s2f_user0_clk output.
+ * Qsys and user documenation refer to s2f_user0_clk as h2f_user0_clk.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_MSB        9
+/* The width in bits of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET_MSK    0x00000200
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field value. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_EN_S2FUSER0CLK_SET(value) (((value) << 9) & 0x00000200)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_EN.
+struct ALT_CLKMGR_MAINPLL_EN_s
+    uint32_t  l4mainclk   :  1;  /* l4_main_clk Enable */
+    uint32_t  l3mpclk     :  1;  /* l3_mp_clk Enable */
+    uint32_t  l4mpclk     :  1;  /* l4_mp_clk Enable */
+    uint32_t  l4spclk     :  1;  /* l4_sp_clk Enable */
+    uint32_t  dbgatclk    :  1;  /* dbg_at_clk Enable */
+    uint32_t  dbgclk      :  1;  /* dbg_clk Enable */
+    uint32_t  dbgtraceclk :  1;  /* dbg_trace_clk Enable */
+    uint32_t  dbgtimerclk :  1;  /* dbg_timer_clk Enable */
+    uint32_t  cfgclk      :  1;  /* cfg_clk Enable */
+    uint32_t  s2fuser0clk :  1;  /* s2f_user0_clk Enable */
+    uint32_t              : 22;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_EN. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_EN_s  ALT_CLKMGR_MAINPLL_EN_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_EN register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_EN_OFST        0x20
+ * Register : Main Divide Register - maindiv
+ * Contains fields that control clock dividers for main clocks derived from the
+ * Main PLL
+ * Register Layout
+ *  [1:0]   | RW     | 0x0   | L3 MP Clock Divider
+ *  [3:2]   | RW     | 0x0   | L3 SP Clock Divider
+ *  [6:4]   | RW     | 0x0   | L4 MP Clock Divider
+ *  [9:7]   | RW     | 0x0   | L4 SP Clock Divider
+ * Field : L3 MP Clock Divider - l3mpclk
+ * The l3_mp_clk is divided down from the l3_main_clk by the value specified in
+ * this field.
+ * Field Enumeration Values:
+ *  Enum                                      | Value | Description
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV1 | 0x0   | Divide by 1
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV2 | 0x1   | Divide by 2
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK
+ * Divide by 1
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV1   0x0
+ * Divide by 2
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_E_DIV2   0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_MSB        1
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET_MSK    0x00000003
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3MPCLK_SET(value) (((value) << 0) & 0x00000003)
+ * Field : L3 SP Clock Divider - l3spclk
+ * The l3_sp_clk is divided down from the l3_mp_clk by the value specified in this
+ * field.
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV1 | 0x0   | Divide by 1
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV2 | 0x1   | Divide by 2
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK
+ * Divide by 1
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV1   0x0
+ * Divide by 2
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_E_DIV2   0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_MSB        3
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET_MSK    0x0000000c
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_CLR_MSK    0xfffffff3
+/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_GET(value) (((value) & 0x0000000c) >> 2)
+/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L3SPCLK_SET(value) (((value) << 2) & 0x0000000c)
+ * Field : L4 MP Clock Divider - l4mpclk
+ * The l4_mp_clk is divided down from the periph_base_clk by the value specified in
+ * this field.
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV1   | 0x0   | Divide By 1
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV2   | 0x1   | Divide By 2
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV4   | 0x2   | Divide By 4
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV8   | 0x3   | Divide By 8
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV16  | 0x4   | Divide By 16
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_1 | 0x5   | Reserved
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_2 | 0x6   | Reserved
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_3 | 0x7   | Reserved
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK
+ * Divide By 1
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV1   0x0
+ * Divide By 2
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV2   0x1
+ * Divide By 4
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV4   0x2
+ * Divide By 8
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV8   0x3
+ * Divide By 16
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_DIV16  0x4
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_1 0x5
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_2 0x6
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_E_RSVD_3 0x7
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_MSB        6
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_WIDTH      3
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET_MSK    0x00000070
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_CLR_MSK    0xffffff8f
+/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_GET(value) (((value) & 0x00000070) >> 4)
+/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4MPCLK_SET(value) (((value) << 4) & 0x00000070)
+ * Field : L4 SP Clock Divider - l4spclk
+ * The l4_sp_clk is divided down from the periph_base_clk by the value specified in
+ * this field.
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV1   | 0x0   | Divide By 1
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV2   | 0x1   | Divide By 2
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV4   | 0x2   | Divide By 4
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV8   | 0x3   | Divide By 8
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV16  | 0x4   | Divide By 16
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_1 | 0x5   | Reserved
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_2 | 0x6   | Reserved
+ *  ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_3 | 0x7   | Reserved
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK
+ * Divide By 1
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV1   0x0
+ * Divide By 2
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV2   0x1
+ * Divide By 4
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV4   0x2
+ * Divide By 8
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV8   0x3
+ * Divide By 16
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_DIV16  0x4
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_1 0x5
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_2 0x6
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_E_RSVD_3 0x7
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_MSB        9
+/* The width in bits of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_WIDTH      3
+/* The mask used to set the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET_MSK    0x00000380
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_CLR_MSK    0xfffffc7f
+/* The reset value of the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_GET(value) (((value) & 0x00000380) >> 7)
+/* Produces a ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_L4SPCLK_SET(value) (((value) << 7) & 0x00000380)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_MAINDIV.
+struct ALT_CLKMGR_MAINPLL_MAINDIV_s
+    uint32_t  l3mpclk :  2;  /* L3 MP Clock Divider */
+    uint32_t  l3spclk :  2;  /* L3 SP Clock Divider */
+    uint32_t  l4mpclk :  3;  /* L4 MP Clock Divider */
+    uint32_t  l4spclk :  3;  /* L4 SP Clock Divider */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_MAINDIV. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_MAINDIV_s  ALT_CLKMGR_MAINPLL_MAINDIV_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_MAINDIV register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_MAINDIV_OFST        0x24
+ * Register : Debug Divide Register - dbgdiv
+ * Contains fields that control clock dividers for debug clocks derived from the
+ * Main PLL
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | Debug AT Clock Divider
+ *  [3:2]  | RW     | 0x1   | Debug Clock Divider
+ *  [31:4] | ???    | 0x0   | *UNDEFINED*
+ * Field : Debug AT Clock Divider - dbgatclk
+ * The dbg_at_clk is divided down from the C2 output of  the Main PLL by the value
+ * specified in this field.
+ *  ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV1 | 0x0   | Divide by 1
+ *  ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV2 | 0x1   | Divide by 2
+ *  ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV4 | 0x2   | Divide by 4
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK
+ * Divide by 1
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV1   0x0
+ * Divide by 2
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV2   0x1
+ * Divide by 4
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_E_DIV4   0x2
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_MSB        1
+/* The width in bits of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET_MSK    0x00000003
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGATCLK_SET(value) (((value) << 0) & 0x00000003)
+ * Field : Debug Clock Divider - dbgclk
+ * The dbg_clk is divided down from the dbg_at_clk by the value specified in this
+ * field.
+ *  ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV2 | 0x1   | Divide by 2
+ *  ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV4 | 0x2   | Divide by 4
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK
+ * Divide by 2
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV2 0x1
+ * Divide by 4
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_E_DIV4 0x2
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_MSB        3
+/* The width in bits of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET_MSK    0x0000000c
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field value. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_CLR_MSK    0xfffffff3
+/* The reset value of the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_GET(value) (((value) & 0x0000000c) >> 2)
+/* Produces a ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_DBGCLK_SET(value) (((value) << 2) & 0x0000000c)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_DBGDIV.
+struct ALT_CLKMGR_MAINPLL_DBGDIV_s
+    uint32_t  dbgatclk :  2;  /* Debug AT Clock Divider */
+    uint32_t  dbgclk   :  2;  /* Debug Clock Divider */
+    uint32_t           : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_DBGDIV. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_DBGDIV_s  ALT_CLKMGR_MAINPLL_DBGDIV_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_DBGDIV register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_DBGDIV_OFST        0x28
+ * Register : Debug Trace Divide Register - tracediv
+ * Contains a field that controls the clock divider for the debug trace clock
+ * derived from the Main PLL
+ * Register Layout
+ *  [2:0]  | RW     | 0x0   | Debug Trace Clock Divider
+ *  [31:3] | ???    | 0x0   | *UNDEFINED*
+ * Field : Debug Trace Clock Divider - traceclk
+ * The dbg_trace_clk is divided down from the C2 output of  the Main PLL by the
+ * value specified in this field.
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV1   | 0x0   | Divide By 1
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV2   | 0x1   | Divide By 2
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV4   | 0x2   | Divide By 4
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV8   | 0x3   | Divide By 8
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV16  | 0x4   | Divide By 16
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_1 | 0x5   | Reserved
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_2 | 0x6   | Reserved
+ *  ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_3 | 0x7   | Reserved
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK
+ * Divide By 1
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV1     0x0
+ * Divide By 2
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV2     0x1
+ * Divide By 4
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV4     0x2
+ * Divide By 8
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV8     0x3
+ * Divide By 16
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_DIV16    0x4
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_1   0x5
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_2   0x6
+ * Reserved
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_E_RSVD_3   0x7
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_MSB        2
+/* The width in bits of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_WIDTH      3
+/* The mask used to set the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field value. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET_MSK    0x00000007
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field value. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_CLR_MSK    0xfffffff8
+/* The reset value of the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_GET(value) (((value) & 0x00000007) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_TRACECLK_SET(value) (((value) << 0) & 0x00000007)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_TRACEDIV.
+struct ALT_CLKMGR_MAINPLL_TRACEDIV_s
+    uint32_t  traceclk :  3;  /* Debug Trace Clock Divider */
+    uint32_t           : 29;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_TRACEDIV. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_TRACEDIV_s  ALT_CLKMGR_MAINPLL_TRACEDIV_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_TRACEDIV register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_TRACEDIV_OFST        0x2c
+ * Register : L4 MP SP APB Clock Source - l4src
+ * Contains fields that select the clock source for L4 MP and SP APB interconnect
+ * Register Layout
+ *  [0]    | RW     | 0x0   | l4_mp_clk Source
+ *  [1]    | RW     | 0x0   | l4_sp_clk Source
+ *  [31:2] | ???    | 0x0   | *UNDEFINED*
+ * Field : l4_mp_clk Source - l4mp
+ * Selects the source for l4_mp_clk
+ *  ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_MAINPLL   | 0x0   | main_clk
+ *  ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_PERIPHPLL | 0x1   | periph_base_clk
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_L4SRC_L4MP
+ * main_clk
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_MAINPLL     0x0
+ * periph_base_clk
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_E_PERIPHPLL   0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_MSB        0
+/* The width in bits of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field value. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field value. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_L4SRC_L4MP field value from a register. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_L4SRC_L4MP register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4MP_SET(value) (((value) << 0) & 0x00000001)
+ * Field : l4_sp_clk Source - l4sp
+ * Selects the source for l4_sp_clk
+ *  ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_MAINPLL   | 0x0   | main_clk
+ *  ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_PERIPHPLL | 0x1   | periph_base_clk
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_L4SRC_L4SP
+ * main_clk
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_MAINPLL     0x0
+ * periph_base_clk
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_E_PERIPHPLL   0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_MSB        1
+/* The width in bits of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field value. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field value. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_L4SRC_L4SP field value from a register. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_MAINPLL_L4SRC_L4SP register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_L4SP_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_L4SRC.
+struct ALT_CLKMGR_MAINPLL_L4SRC_s
+    uint32_t  l4mp :  1;  /* l4_mp_clk Source */
+    uint32_t  l4sp :  1;  /* l4_sp_clk Source */
+    uint32_t       : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_L4SRC. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_L4SRC_s  ALT_CLKMGR_MAINPLL_L4SRC_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_L4SRC register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_L4SRC_OFST        0x30
+ * Register : Main PLL Output Counter Reset Ack Status Register - stat
+ * Contains Output Clock Counter Reset acknowledge status.
+ * Register Layout
+ *  [5:0]  | R      | 0x0   | Output Counter Reset Acknowledge
+ *  [31:6] | ???    | 0x0   | *UNDEFINED*
+ * Field : Output Counter Reset Acknowledge - outresetack
+ * These read only bits per PLL output indicate that the PLL has received the
+ * Output Reset Counter request and has gracefully stopped the respective PLL
+ * output clock.
+ * The reset value of this bit is applied on a cold reset; warm reset has no affect
+ * on this bit.
+ *  ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_IDLE    | 0x0   | Idle
+ *  ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_ACK_RXD | 0x1   | Output Counter Acknowledge received.
+ * Enumerated value for register field ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK
+ * Idle
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_IDLE    0x0
+ * Output Counter Acknowledge received.
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_E_ACK_RXD 0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_MSB        5
+/* The width in bits of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field value. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET_MSK    0x0000003f
+/* The mask used to clear the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field value. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_CLR_MSK    0xffffffc0
+/* The reset value of the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_RESET      0x0
+/* Extracts the ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK field value from a register. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
+/* Produces a ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK register field value suitable for setting the register. */
+#define ALT_CLKMGR_MAINPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
+ * The struct declaration for register ALT_CLKMGR_MAINPLL_STAT.
+struct ALT_CLKMGR_MAINPLL_STAT_s
+    const uint32_t  outresetack :  6;  /* Output Counter Reset Acknowledge */
+    uint32_t                    : 26;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_MAINPLL_STAT. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_STAT_s  ALT_CLKMGR_MAINPLL_STAT_t;
+/* The byte offset of the ALT_CLKMGR_MAINPLL_STAT register from the beginning of the component. */
+#define ALT_CLKMGR_MAINPLL_STAT_OFST        0x34
+ * The struct declaration for register group ALT_CLKMGR_MAINPLL.
+struct ALT_CLKMGR_MAINPLL_s
+    volatile ALT_CLKMGR_MAINPLL_VCO_t               vco;                /* ALT_CLKMGR_MAINPLL_VCO */
+    volatile ALT_CLKMGR_MAINPLL_MISC_t              misc;               /* ALT_CLKMGR_MAINPLL_MISC */
+    volatile ALT_CLKMGR_MAINPLL_MPUCLK_t            mpuclk;             /* ALT_CLKMGR_MAINPLL_MPUCLK */
+    volatile ALT_CLKMGR_MAINPLL_MAINCLK_t           mainclk;            /* ALT_CLKMGR_MAINPLL_MAINCLK */
+    volatile ALT_CLKMGR_MAINPLL_DBGATCLK_t          dbgatclk;           /* ALT_CLKMGR_MAINPLL_DBGATCLK */
+    volatile ALT_CLKMGR_MAINPLL_MAINQSPICLK_t       mainqspiclk;        /* ALT_CLKMGR_MAINPLL_MAINQSPICLK */
+    volatile ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK_t  mainnandsdmmcclk;   /* ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK */
+    volatile ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK_t    cfgs2fuser0clk;     /* ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK */
+    volatile ALT_CLKMGR_MAINPLL_EN_t                en;                 /* ALT_CLKMGR_MAINPLL_EN */
+    volatile ALT_CLKMGR_MAINPLL_MAINDIV_t           maindiv;            /* ALT_CLKMGR_MAINPLL_MAINDIV */
+    volatile ALT_CLKMGR_MAINPLL_DBGDIV_t            dbgdiv;             /* ALT_CLKMGR_MAINPLL_DBGDIV */
+    volatile ALT_CLKMGR_MAINPLL_TRACEDIV_t          tracediv;           /* ALT_CLKMGR_MAINPLL_TRACEDIV */
+    volatile ALT_CLKMGR_MAINPLL_L4SRC_t             l4src;              /* ALT_CLKMGR_MAINPLL_L4SRC */
+    volatile ALT_CLKMGR_MAINPLL_STAT_t              stat;               /* ALT_CLKMGR_MAINPLL_STAT */
+    volatile uint32_t                               _pad_0x38_0x40[2];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_CLKMGR_MAINPLL. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_s  ALT_CLKMGR_MAINPLL_t;
+/* The struct declaration for the raw register contents of register group ALT_CLKMGR_MAINPLL. */
+struct ALT_CLKMGR_MAINPLL_raw_s
+    volatile uint32_t  vco;                /* ALT_CLKMGR_MAINPLL_VCO */
+    volatile uint32_t  misc;               /* ALT_CLKMGR_MAINPLL_MISC */
+    volatile uint32_t  mpuclk;             /* ALT_CLKMGR_MAINPLL_MPUCLK */
+    volatile uint32_t  mainclk;            /* ALT_CLKMGR_MAINPLL_MAINCLK */
+    volatile uint32_t  dbgatclk;           /* ALT_CLKMGR_MAINPLL_DBGATCLK */
+    volatile uint32_t  mainqspiclk;        /* ALT_CLKMGR_MAINPLL_MAINQSPICLK */
+    volatile uint32_t  mainnandsdmmcclk;   /* ALT_CLKMGR_MAINPLL_MAINNANDSDMMCCLK */
+    volatile uint32_t  cfgs2fuser0clk;     /* ALT_CLKMGR_MAINPLL_CFGS2FUSER0CLK */
+    volatile uint32_t  en;                 /* ALT_CLKMGR_MAINPLL_EN */
+    volatile uint32_t  maindiv;            /* ALT_CLKMGR_MAINPLL_MAINDIV */
+    volatile uint32_t  dbgdiv;             /* ALT_CLKMGR_MAINPLL_DBGDIV */
+    volatile uint32_t  tracediv;           /* ALT_CLKMGR_MAINPLL_TRACEDIV */
+    volatile uint32_t  l4src;              /* ALT_CLKMGR_MAINPLL_L4SRC */
+    volatile uint32_t  stat;               /* ALT_CLKMGR_MAINPLL_STAT */
+/* The typedef declaration for the raw register contents of register group ALT_CLKMGR_MAINPLL. */
+typedef volatile struct ALT_CLKMGR_MAINPLL_raw_s  ALT_CLKMGR_MAINPLL_raw_t;
+ * Register Group : Peripheral PLL Group - ALT_CLKMGR_PERPLL
+ * Peripheral PLL Group
+ * Contains registers with settings for the Peripheral PLL.
+ * Register : Peripheral PLL VCO Control Register - vco
+ * Contains settings that control the Peripheral PLL VCO. The VCO output frequency
+ * is the input frequency multiplied by the numerator (M+1) and divided by the
+ * denominator (N+1).
+ * Register Layout
+ *  [0]     | RW     | 0x1   | BG PWRDN
+ *  [1]     | RW     | 0x0   | Enable
+ *  [2]     | RW     | 0x1   | Power down
+ *  [15:3]  | RW     | 0x1   | Numerator (M)
+ *  [21:16] | RW     | 0x1   | Denominator (N)
+ *  [23:22] | RW     | 0x0   | Clock Source
+ *  [24]    | RW     | 0x0   | All Output Counter Reset
+ *  [30:25] | RW     | 0x0   | Output Counter Reset
+ *  [31]    | RW     | 0x1   | External Regulator Input Select
+ * Field : BG PWRDN - bgpwrdn
+ * If '1', powers down bandgap. If '0', bandgap is not power down.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_MSB        0
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_BGPWRDN field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_BGPWRDN register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Enable - en
+ * If '1', VCO is enabled. If '0', VCO is in reset.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_MSB        1
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_EN register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_EN register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_EN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_EN field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_EN register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Power down - pwrdn
+ * If '1', power down analog circuitry. If '0', analog circuitry not powered down.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_MSB        2
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_PWRDN register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_PWRDN register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_PWRDN field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_PWRDN register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Numerator (M) - numer
+ * Numerator in VCO output frequency equation. For incremental frequency change, if
+ * the new value lead to less than 20% of the frequency change, this value can be
+ * changed without resetting the PLL. The Numerator and Denominator can not be
+ * changed at the same time for incremental frequency changed.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_MSB        15
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_WIDTH      13
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_NUMER register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET_MSK    0x0000fff8
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_NUMER register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_CLR_MSK    0xffff0007
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_NUMER field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_NUMER register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
+ * Field : Denominator (N) - denom
+ * Denominator in VCO output frequency equation. For incremental frequency change,
+ * if the new value lead to less than 20% of the frequency change, this value can
+ * be changed without resetting the PLL. The Numerator and Denominator can not be
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_MSB        21
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_DENOM register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET_MSK    0x003f0000
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_DENOM register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_CLR_MSK    0xffc0ffff
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_DENOM field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_DENOM register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
+ * Field : Clock Source - psrc
+ * Controls the VCO input clock source.
+ * Qsys and user documenation refer to f2s_periph_ref_clk as f2h_periph_ref_clk.
+ *  ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC1          | 0x0   | eosc1_clk
+ *  ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC2          | 0x1   | eosc2_clk
+ *  ALT_CLKMGR_PERPLL_VCO_PSRC_E_F2S_PERIPH_REF | 0x2   | f2s_periph_ref_clk
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_VCO_PSRC
+ * eosc1_clk
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC1          0x0
+ * eosc2_clk
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_EOSC2          0x1
+ * f2s_periph_ref_clk
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_E_F2S_PERIPH_REF 0x2
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_LSB        22
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_MSB        23
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_PSRC register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET_MSK    0x00c00000
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_PSRC register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_CLR_MSK    0xff3fffff
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_PSRC register field. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_PSRC field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_GET(value) (((value) & 0x00c00000) >> 22)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_PSRC register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_PSRC_SET(value) (((value) << 22) & 0x00c00000)
+ * Field : All Output Counter Reset - outresetall
+ * Before releasing Bypass, All Output Counter Reset must be set and cleared by
+ * software for correct clock operation.
+ * If '1', Reset phase multiplexer and all output counter state. So that after the
+ * assertion all the clocks output are start from rising edge align.
+ * If '0', phase multiplexer and output counter state not reset and no change to
+ * the phase of the clock outputs.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_LSB        24
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_MSB        24
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET_MSK    0x01000000
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_CLR_MSK    0xfeffffff
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_OUTRSTALL field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_OUTRSTALL register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
+ * Field : Output Counter Reset - outreset
+ * Resets the individual PLL output counter.
+ * For software to change the PLL output counter without producing glitches on the
+ * respective clock, SW must set the VCO register respective Output Counter Reset
+ * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
+ * the Output Counter Reset Ack Status Register. Software then writes the
+ * appropriate counter register, and then clears the respective VCO register Output
+ * Counter Reset bit.
+ * LSB 'outreset[0]' corresponds to PLL output clock C0, etc.
+ * If set to '1', reset output divider, no clock output from counter.
+ * If set to '0', counter is not reset.
+ * on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_LSB        25
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_MSB        30
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_OUTRST register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET_MSK    0x7e000000
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_OUTRST register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_CLR_MSK    0x81ffffff
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_OUTRST field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_OUTRST register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
+ * Field : External Regulator Input Select - regextsel
+ * If set to '1', the external regulator is selected for the PLL.
+ * If set to '0', the internal regulator is slected.
+ * It is strongly recommended to select the external regulator while the PLL is not
+ * enabled (in reset), and  then disable the external regulater once the PLL
+ * becomes enabled.  Software should simulateously update the 'Enable' bit and the
+ * 'External Regulator Input Select' in the same write access to the VCO register.
+ * When the 'Enable' bit is clear, the 'External Regulator Input Select' should be
+ * set, and vice versa.
+ * on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_LSB        31
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_MSB        31
+/* The width in bits of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET_MSK    0x80000000
+/* The mask used to clear the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field value. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_CLR_MSK    0x7fffffff
+/* The reset value of the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_VCO_REGEXTSEL field value from a register. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
+/* Produces a ALT_CLKMGR_PERPLL_VCO_REGEXTSEL register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_CLKMGR_PERPLL_VCO.
+struct ALT_CLKMGR_PERPLL_VCO_s
+    uint32_t  bgpwrdn     :  1;  /* BG PWRDN */
+    uint32_t  en          :  1;  /* Enable */
+    uint32_t  pwrdn       :  1;  /* Power down */
+    uint32_t  numer       : 13;  /* Numerator (M) */
+    uint32_t  denom       :  6;  /* Denominator (N) */
+    uint32_t  psrc        :  2;  /* Clock Source */
+    uint32_t  outresetall :  1;  /* All Output Counter Reset */
+    uint32_t  outreset    :  6;  /* Output Counter Reset */
+    uint32_t  regextsel   :  1;  /* External Regulator Input Select */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_VCO. */
+typedef volatile struct ALT_CLKMGR_PERPLL_VCO_s  ALT_CLKMGR_PERPLL_VCO_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_CLKMGR_PERPLL_VCO register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_VCO_OFST        0x0
+ * Register : Peripheral PLL VCO Advanced Control Register - misc
+ * Contains VCO control signals and other PLL control signals need to be
+ * controllable through register.
+ * Register Layout
+ *  Bits    | Access | Reset | Description
+ *  [0]     | RW     | 0x0   | Loop Bandwidth Adjust Enabled
+ *  [12:1]  | RW     | 0x1   | Loop Bandwidth Adjust
+ *  [13]    | RW     | 0x0   | Fast Locking Enable
+ *  [14]    | RW     | 0x1   | Saturation Enable
+ *  [31:15] | ???    | 0x0   | *UNDEFINED*
+ * Field : Loop Bandwidth Adjust Enabled - bwadjen
+ * If set to 1, the Loop Bandwidth Adjust value comes from the Loop Bandwidth
+ * Adjust field.
+ * If set to 0, the Loop Bandwidth Adjust value equals the M field divided by 2
+ * value of the VCO Control Register.  The M divided by 2 is the upper 12 bits
+ * (12:1) of the M field in the VCO register.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_MSB        0
+/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_PERPLL_MISC_BWADJEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_MISC_BWADJEN field value from a register. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_MISC_BWADJEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Loop Bandwidth Adjust - bwadj
+ * Provides Loop Bandwidth Adjust value.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_MSB        12
+/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_WIDTH      12
+/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_BWADJ register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET_MSK    0x00001ffe
+/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_BWADJ register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_CLR_MSK    0xffffe001
+/* The reset value of the ALT_CLKMGR_PERPLL_MISC_BWADJ register field. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_MISC_BWADJ field value from a register. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
+/* Produces a ALT_CLKMGR_PERPLL_MISC_BWADJ register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_MISC_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
+ * Field : Fast Locking Enable - fasten
+ * Enables fast locking circuit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_MSB        13
+/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_FASTEN register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET_MSK    0x00002000
+/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_FASTEN register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_CLKMGR_PERPLL_MISC_FASTEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_MISC_FASTEN field value from a register. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_CLKMGR_PERPLL_MISC_FASTEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_MISC_FASTEN_SET(value) (((value) << 13) & 0x00002000)
+ * Field : Saturation Enable - saten
+ * Enables saturation behavior.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_MSB        14
+/* The width in bits of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_MISC_SATEN register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET_MSK    0x00004000
+/* The mask used to clear the ALT_CLKMGR_PERPLL_MISC_SATEN register field value. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_CLKMGR_PERPLL_MISC_SATEN register field. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_MISC_SATEN field value from a register. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_CLKMGR_PERPLL_MISC_SATEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_MISC_SATEN_SET(value) (((value) << 14) & 0x00004000)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_MISC.
+struct ALT_CLKMGR_PERPLL_MISC_s
+    uint32_t  bwadjen :  1;  /* Loop Bandwidth Adjust Enabled */
+    uint32_t  bwadj   : 12;  /* Loop Bandwidth Adjust */
+    uint32_t  fasten  :  1;  /* Fast Locking Enable */
+    uint32_t  saten   :  1;  /* Saturation Enable */
+    uint32_t          : 17;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_MISC. */
+typedef volatile struct ALT_CLKMGR_PERPLL_MISC_s  ALT_CLKMGR_PERPLL_MISC_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_MISC register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_MISC_OFST        0x4
+ * Register : Peripheral PLL C0 Control Register for Clock emac0_clk - emac0clk
+ * Contains settings that control clock emac0_clk generated from the C0 output of
+ * the Peripheral PLL.
+ * Only reset by a cold reset.
+ * Register Layout
+ *  [8:0]  | RW     | 0x1   | Counter
+ *  [31:9] | ???    | 0x0   | *UNDEFINED*
+ * Field : Counter - cnt
+ * Divides the VCO frequency by the value+1 in this field.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EMAC0CLK_CNT field value from a register. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_EMAC0CLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_EMAC0CLK.
+struct ALT_CLKMGR_PERPLL_EMAC0CLK_s
+    uint32_t  cnt :  9;  /* Counter */
+    uint32_t      : 23;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_EMAC0CLK. */
+typedef volatile struct ALT_CLKMGR_PERPLL_EMAC0CLK_s  ALT_CLKMGR_PERPLL_EMAC0CLK_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_EMAC0CLK register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_EMAC0CLK_OFST        0x8
+ * Register : Peripheral PLL C1 Control Register for Clock emac1_clk - emac1clk
+ * Contains settings that control clock emac1_clk generated from the C1 output of
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EMAC1CLK_CNT field value from a register. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_EMAC1CLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_EMAC1CLK.
+struct ALT_CLKMGR_PERPLL_EMAC1CLK_s
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_EMAC1CLK. */
+typedef volatile struct ALT_CLKMGR_PERPLL_EMAC1CLK_s  ALT_CLKMGR_PERPLL_EMAC1CLK_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_EMAC1CLK register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_EMAC1CLK_OFST        0xc
+ * Register : Peripheral PLL C2 Control Register for Clock periph_qspi_clk - perqspiclk
+ * Contains settings that control clock periph_qspi_clk generated from the C2
+ * output of the Peripheral PLL.
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_PERQSPICLK_CNT field value from a register. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_PERQSPICLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_PERQSPICLK.
+struct ALT_CLKMGR_PERPLL_PERQSPICLK_s
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_PERQSPICLK. */
+typedef volatile struct ALT_CLKMGR_PERPLL_PERQSPICLK_s  ALT_CLKMGR_PERPLL_PERQSPICLK_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_PERQSPICLK register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_PERQSPICLK_OFST        0x10
+ * Register : Peripheral PLL C3 Control Register for Clock periph_nand_sdmmc_clk - pernandsdmmcclk
+ * Contains settings that control clock periph_nand_sdmmc_clk generated from the C3
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT field value from a register. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK.
+struct ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_s
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK. */
+typedef volatile struct ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_s  ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_OFST        0x14
+ * Register : Peripheral PLL C4 Control Register for Clock periph_base_clk - perbaseclk
+ * Contains settings that control clock periph_base_clk generated from the C4
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_PERBASECLK_CNT field value from a register. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_PERBASECLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_PERBASECLK.
+struct ALT_CLKMGR_PERPLL_PERBASECLK_s
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_PERBASECLK. */
+typedef volatile struct ALT_CLKMGR_PERPLL_PERBASECLK_s  ALT_CLKMGR_PERPLL_PERBASECLK_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_PERBASECLK register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_PERBASECLK_OFST        0x18
+ * Register : Peripheral PLL C5 Control Register for Clock s2f_user1_clk - s2fuser1clk
+ * Contains settings that control clock s2f_user1_clk generated from the C5 output
+ * of the Peripheral PLL.
+ * Qsys and user documenation refer to s2f_user1_clk as h2f_user1_clk.
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field value. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT field value from a register. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_S2FUSER1CLK.
+struct ALT_CLKMGR_PERPLL_S2FUSER1CLK_s
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_S2FUSER1CLK. */
+typedef volatile struct ALT_CLKMGR_PERPLL_S2FUSER1CLK_s  ALT_CLKMGR_PERPLL_S2FUSER1CLK_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_S2FUSER1CLK register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_S2FUSER1CLK_OFST        0x1c
+ * Register : Enable Register - en
+ * Contains fields that control clock enables for clocks derived from the
+ * Peripheral PLL
+ * 1: The clock is enabled.
+ * 0: The clock is disabled.
+ * Fields are only reset by a cold reset.
+ * Register Layout
+ *  [0]     | RW     | 0x1   | emac0_clk Enable
+ *  [1]     | RW     | 0x1   | emac1_clk Enable
+ *  [2]     | RW     | 0x1   | usb_mp_clk Enable
+ *  [3]     | RW     | 0x1   | spi_m_clk Enable
+ *  [4]     | RW     | 0x1   | can0_clk Enable
+ *  [5]     | RW     | 0x1   | can1_clk Enable
+ *  [6]     | RW     | 0x1   | gpio_clk Enable
+ *  [7]     | RW     | 0x1   | s2f_user1_clk Enable
+ *  [8]     | RW     | 0x1   | sdmmc_clk Enable
+ *  [9]     | RW     | 0x1   | nand_x_clk Enable
+ *  [10]    | RW     | 0x1   | nand_clk Enable
+ *  [11]    | RW     | 0x1   | qspi_clk Enable
+ *  [31:12] | ???    | 0x0   | *UNDEFINED*
+ * Field : emac0_clk Enable - emac0clk
+ * Enables clock emac0_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_MSB        0
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_EMAC0CLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_EN_EMAC0CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC0CLK_SET(value) (((value) << 0) & 0x00000001)
+ * Field : emac1_clk Enable - emac1clk
+ * Enables clock emac1_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_MSB        1
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_EMAC1CLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_PERPLL_EN_EMAC1CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_EMAC1CLK_SET(value) (((value) << 1) & 0x00000002)
+ * Field : usb_mp_clk Enable - usbclk
+ * Enables clock usb_mp_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_MSB        2
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_USBCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_USBCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_USBCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_PERPLL_EN_USBCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_USBCLK_SET(value) (((value) << 2) & 0x00000004)
+ * Field : spi_m_clk Enable - spimclk
+ * Enables clock spi_m_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_MSB        3
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET_MSK    0x00000008
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_SPIMCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_CLKMGR_PERPLL_EN_SPIMCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_SPIMCLK_SET(value) (((value) << 3) & 0x00000008)
+ * Field : can0_clk Enable - can0clk
+ * Enables clock can0_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_MSB        4
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET_MSK    0x00000010
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_CLR_MSK    0xffffffef
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_CAN0CLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_CLKMGR_PERPLL_EN_CAN0CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_CAN0CLK_SET(value) (((value) << 4) & 0x00000010)
+ * Field : can1_clk Enable - can1clk
+ * Enables clock can1_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_MSB        5
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET_MSK    0x00000020
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_CAN1CLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_CLKMGR_PERPLL_EN_CAN1CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_CAN1CLK_SET(value) (((value) << 5) & 0x00000020)
+ * Field : gpio_clk Enable - gpioclk
+ * Enables clock gpio_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_MSB        6
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET_MSK    0x00000040
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_GPIOCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_GPIOCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_CLKMGR_PERPLL_EN_GPIOCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_GPIOCLK_SET(value) (((value) << 6) & 0x00000040)
+ * Field : s2f_user1_clk Enable - s2fuser1clk
+ * Enables clock s2f_user1_clk output.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_MSB        7
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET_MSK    0x00000080
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_S2FUSER1CLK_SET(value) (((value) << 7) & 0x00000080)
+ * Field : sdmmc_clk Enable - sdmmcclk
+ * Enables clock sdmmc_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET_MSK    0x00000100
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_SDMMCCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_CLKMGR_PERPLL_EN_SDMMCCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_SDMMCCLK_SET(value) (((value) << 8) & 0x00000100)
+ * Field : nand_x_clk Enable - nandxclk
+ * Enables clock nand_x_clk output
+ * nand_clk Enable should always be de-asserted before the nand_x_clk Enable, and
+ * the nand_x_clk Enable should always be asserted before the nand_clk Enable is
+ * asserted. A brief delay is also required between switching the enables (8 *
+ * nand_clk period).
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_MSB        9
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET_MSK    0x00000200
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_NANDXCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_NANDXCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_CLKMGR_PERPLL_EN_NANDXCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_NANDXCLK_SET(value) (((value) << 9) & 0x00000200)
+ * Field : nand_clk Enable - nandclk
+ * Enables clock nand_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_MSB        10
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_NANDCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET_MSK    0x00000400
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_NANDCLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_NANDCLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_NANDCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_CLKMGR_PERPLL_EN_NANDCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_NANDCLK_SET(value) (((value) << 10) & 0x00000400)
+ * Field : qspi_clk Enable - qspiclk
+ * Enables clock qspi_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_LSB        11
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_MSB        11
+/* The width in bits of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_PERPLL_EN_QSPICLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET_MSK    0x00000800
+/* The mask used to clear the ALT_CLKMGR_PERPLL_EN_QSPICLK register field value. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_CLR_MSK    0xfffff7ff
+/* The reset value of the ALT_CLKMGR_PERPLL_EN_QSPICLK register field. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_EN_QSPICLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_GET(value) (((value) & 0x00000800) >> 11)
+/* Produces a ALT_CLKMGR_PERPLL_EN_QSPICLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_EN_QSPICLK_SET(value) (((value) << 11) & 0x00000800)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_EN.
+struct ALT_CLKMGR_PERPLL_EN_s
+    uint32_t  emac0clk    :  1;  /* emac0_clk Enable */
+    uint32_t  emac1clk    :  1;  /* emac1_clk Enable */
+    uint32_t  usbclk      :  1;  /* usb_mp_clk Enable */
+    uint32_t  spimclk     :  1;  /* spi_m_clk Enable */
+    uint32_t  can0clk     :  1;  /* can0_clk Enable */
+    uint32_t  can1clk     :  1;  /* can1_clk Enable */
+    uint32_t  gpioclk     :  1;  /* gpio_clk Enable */
+    uint32_t  s2fuser1clk :  1;  /* s2f_user1_clk Enable */
+    uint32_t  sdmmcclk    :  1;  /* sdmmc_clk Enable */
+    uint32_t  nandxclk    :  1;  /* nand_x_clk Enable */
+    uint32_t  nandclk     :  1;  /* nand_clk Enable */
+    uint32_t  qspiclk     :  1;  /* qspi_clk Enable */
+    uint32_t              : 20;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_EN. */
+typedef volatile struct ALT_CLKMGR_PERPLL_EN_s  ALT_CLKMGR_PERPLL_EN_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_EN register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_EN_OFST        0x20
+ * Register : Divide Register - div
+ * Contains fields that control clock dividers for clocks derived from the
+ * Peripheral PLL
+ * Register Layout
+ *  [2:0]   | RW     | 0x0   | USB Clock Divider
+ *  [5:3]   | RW     | 0x0   | SPI Master Clock Divider
+ *  [8:6]   | RW     | 0x0   | CAN0 Clock Divider
+ *  [11:9]  | RW     | 0x0   | CAN1 Clock Divider
+ * Field : USB Clock Divider - usbclk
+ * The usb_mp_clk is divided down from the periph_base_clk by the value specified
+ * in this field.
+ * Field Enumeration Values:
+ *  Enum                                  | Value | Description
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV1   | 0x0   | Divide By 1
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV2   | 0x1   | Divide By 2
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV4   | 0x2   | Divide By 4
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV8   | 0x3   | Divide By 8
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV16  | 0x4   | Divide By 16
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_1 | 0x5   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_2 | 0x6   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_3 | 0x7   | Reserved
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_USBCLK
+ * Divide By 1
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV1     0x0
+ * Divide By 2
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV2     0x1
+ * Divide By 4
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV4     0x2
+ * Divide By 8
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV8     0x3
+ * Divide By 16
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_DIV16    0x4
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_1   0x5
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_2   0x6
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_E_RSVD_3   0x7
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_MSB        2
+/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_WIDTH      3
+/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_USBCLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET_MSK    0x00000007
+/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_USBCLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_CLR_MSK    0xfffffff8
+/* The reset value of the ALT_CLKMGR_PERPLL_DIV_USBCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_DIV_USBCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_GET(value) (((value) & 0x00000007) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_DIV_USBCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_DIV_USBCLK_SET(value) (((value) << 0) & 0x00000007)
+ * Field : SPI Master Clock Divider - spimclk
+ * The spi_m_clk is divided down from the periph_base_clk by the value specified in
+ * this field.
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV1   | 0x0   | Divide By 1
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV2   | 0x1   | Divide By 2
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV4   | 0x2   | Divide By 4
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV8   | 0x3   | Divide By 8
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV16  | 0x4   | Divide By 16
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_1 | 0x5   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_2 | 0x6   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_3 | 0x7   | Reserved
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_SPIMCLK
+ * Divide By 1
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV1    0x0
+ * Divide By 2
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV2    0x1
+ * Divide By 4
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV4    0x2
+ * Divide By 8
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV8    0x3
+ * Divide By 16
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_DIV16   0x4
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_1  0x5
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_2  0x6
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_E_RSVD_3  0x7
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_MSB        5
+/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_WIDTH      3
+/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET_MSK    0x00000038
+/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_CLR_MSK    0xffffffc7
+/* The reset value of the ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_DIV_SPIMCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_GET(value) (((value) & 0x00000038) >> 3)
+/* Produces a ALT_CLKMGR_PERPLL_DIV_SPIMCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_DIV_SPIMCLK_SET(value) (((value) << 3) & 0x00000038)
+ * Field : CAN0 Clock Divider - can0clk
+ * The can0_clk is divided down from the periph_base_clk by the value specified in
+ * this field.
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV1   | 0x0   | Divide By 1
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV2   | 0x1   | Divide By 2
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV4   | 0x2   | Divide By 4
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV8   | 0x3   | Divide By 8
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV16  | 0x4   | Divide By 16
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_1 | 0x5   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_2 | 0x6   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_3 | 0x7   | Reserved
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN0CLK
+ * Divide By 1
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV1    0x0
+ * Divide By 2
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV2    0x1
+ * Divide By 4
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV4    0x2
+ * Divide By 8
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV8    0x3
+ * Divide By 16
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_DIV16   0x4
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_1  0x5
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_2  0x6
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_E_RSVD_3  0x7
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_MSB        8
+/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_WIDTH      3
+/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET_MSK    0x000001c0
+/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_CLR_MSK    0xfffffe3f
+/* The reset value of the ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_DIV_CAN0CLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_GET(value) (((value) & 0x000001c0) >> 6)
+/* Produces a ALT_CLKMGR_PERPLL_DIV_CAN0CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN0CLK_SET(value) (((value) << 6) & 0x000001c0)
+ * Field : CAN1 Clock Divider - can1clk
+ * The can1_clk is divided down from the periph_base_clk by the value specified in
+ * this field.
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV1   | 0x0   | Divide By 1
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV2   | 0x1   | Divide By 2
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV4   | 0x2   | Divide By 4
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV8   | 0x3   | Divide By 8
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV16  | 0x4   | Divide By 16
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_1 | 0x5   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_2 | 0x6   | Reserved
+ *  ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_3 | 0x7   | Reserved
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_DIV_CAN1CLK
+ * Divide By 1
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV1    0x0
+ * Divide By 2
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV2    0x1
+ * Divide By 4
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV4    0x2
+ * Divide By 8
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV8    0x3
+ * Divide By 16
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_DIV16   0x4
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_1  0x5
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_2  0x6
+ * Reserved
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_E_RSVD_3  0x7
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_MSB        11
+/* The width in bits of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_WIDTH      3
+/* The mask used to set the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET_MSK    0x00000e00
+/* The mask used to clear the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field value. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_CLR_MSK    0xfffff1ff
+/* The reset value of the ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_DIV_CAN1CLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_GET(value) (((value) & 0x00000e00) >> 9)
+/* Produces a ALT_CLKMGR_PERPLL_DIV_CAN1CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_DIV_CAN1CLK_SET(value) (((value) << 9) & 0x00000e00)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_DIV.
+struct ALT_CLKMGR_PERPLL_DIV_s
+    uint32_t  usbclk  :  3;  /* USB Clock Divider */
+    uint32_t  spimclk :  3;  /* SPI Master Clock Divider */
+    uint32_t  can0clk :  3;  /* CAN0 Clock Divider */
+    uint32_t  can1clk :  3;  /* CAN1 Clock Divider */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_DIV. */
+typedef volatile struct ALT_CLKMGR_PERPLL_DIV_s  ALT_CLKMGR_PERPLL_DIV_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_DIV register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_DIV_OFST        0x24
+ * Register : GPIO Divide Register - gpiodiv
+ * Contains a field that controls the clock divider for the GPIO De-bounce clock.
+ * Register Layout
+ *  [23:0]  | RW     | 0x1   | GPIO De-bounce Clock Divider
+ *  [31:24] | ???    | 0x0   | *UNDEFINED*
+ * Field : GPIO De-bounce Clock Divider - gpiodbclk
+ * The gpio_db_clk is divided down from the periph_base_clk by the value plus one
+ * specified in this field. The value 0 (divide by 1) is illegal. A value of 1
+ * indicates divide by 2, 2 divide by 3, etc.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_MSB        23
+/* The width in bits of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_WIDTH      24
+/* The mask used to set the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field value. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET_MSK    0x00ffffff
+/* The mask used to clear the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field value. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_CLR_MSK    0xff000000
+/* The reset value of the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK field value from a register. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_GET(value) (((value) & 0x00ffffff) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_GPIODBCLK_SET(value) (((value) << 0) & 0x00ffffff)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_GPIODIV.
+struct ALT_CLKMGR_PERPLL_GPIODIV_s
+    uint32_t  gpiodbclk : 24;  /* GPIO De-bounce Clock Divider */
+    uint32_t            :  8;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_GPIODIV. */
+typedef volatile struct ALT_CLKMGR_PERPLL_GPIODIV_s  ALT_CLKMGR_PERPLL_GPIODIV_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_GPIODIV register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_GPIODIV_OFST        0x28
+ * Register : Flash Clock Source Register - src
+ * Contains fields that select the source clocks for the flash controllers.
+ * Register Layout
+ *  [1:0]  | RW     | 0x1   | SDMMC Clock Source
+ *  [3:2]  | RW     | 0x1   | NAND Clock Source
+ *  [5:4]  | RW     | 0x1   | QSPI Clock Source
+ *  [31:6] | ???    | 0x0   | *UNDEFINED*
+ * Field : SDMMC Clock Source - sdmmc
+ * Selects the source clock for the SDMMC.
+ *  ALT_CLKMGR_PERPLL_SRC_SDMMC_E_F2S_PERIPH_REF_CLK | 0x0   | f2s_periph_ref_clk
+ *  ALT_CLKMGR_PERPLL_SRC_SDMMC_E_MAIN_NAND_CLK      | 0x1   | main_nand_sdmmc_clk
+ *  ALT_CLKMGR_PERPLL_SRC_SDMMC_E_PERIPH_NAND_CLK    | 0x2   | periph_nand_sdmmc_clk
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_SDMMC
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_F2S_PERIPH_REF_CLK    0x0
+ * main_nand_sdmmc_clk
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_MAIN_NAND_CLK         0x1
+ * periph_nand_sdmmc_clk
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_E_PERIPH_NAND_CLK       0x2
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_MSB        1
+/* The width in bits of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_PERPLL_SRC_SDMMC register field value. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET_MSK    0x00000003
+/* The mask used to clear the ALT_CLKMGR_PERPLL_SRC_SDMMC register field value. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_CLKMGR_PERPLL_SRC_SDMMC register field. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_SRC_SDMMC field value from a register. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_SRC_SDMMC register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_SRC_SDMMC_SET(value) (((value) << 0) & 0x00000003)
+ * Field : NAND Clock Source - nand
+ * Selects the source clock for the NAND.
+ *  ALT_CLKMGR_PERPLL_SRC_NAND_E_F2S_PERIPH_REF_CLK | 0x0   | f2s_periph_ref_clk
+ *  ALT_CLKMGR_PERPLL_SRC_NAND_E_MAIN_NAND_CLK      | 0x1   | main_nand_sdmmc_clk
+ *  ALT_CLKMGR_PERPLL_SRC_NAND_E_PERIPH_NAND_CLK    | 0x2   | periph_nand_sdmmc_clk
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_NAND
+#define ALT_CLKMGR_PERPLL_SRC_NAND_E_F2S_PERIPH_REF_CLK 0x0
+#define ALT_CLKMGR_PERPLL_SRC_NAND_E_MAIN_NAND_CLK      0x1
+#define ALT_CLKMGR_PERPLL_SRC_NAND_E_PERIPH_NAND_CLK    0x2
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_MSB        3
+/* The width in bits of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_PERPLL_SRC_NAND register field value. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_SET_MSK    0x0000000c
+/* The mask used to clear the ALT_CLKMGR_PERPLL_SRC_NAND register field value. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_CLR_MSK    0xfffffff3
+/* The reset value of the ALT_CLKMGR_PERPLL_SRC_NAND register field. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_SRC_NAND field value from a register. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_GET(value) (((value) & 0x0000000c) >> 2)
+/* Produces a ALT_CLKMGR_PERPLL_SRC_NAND register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_SRC_NAND_SET(value) (((value) << 2) & 0x0000000c)
+ * Field : QSPI Clock Source - qspi
+ * Selects the source clock for the QSPI.
+ *  ALT_CLKMGR_PERPLL_SRC_QSPI_E_F2S_PERIPH_REF_CLK | 0x0   | f2s_periph_ref_clk
+ *  ALT_CLKMGR_PERPLL_SRC_QSPI_E_MAIN_QSPI_CLK      | 0x1   | main_qspi_clk
+ *  ALT_CLKMGR_PERPLL_SRC_QSPI_E_PERIPH_QSPI_CLK    | 0x2   | periph_qspi_clk
+ * Field Access Macros:
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_SRC_QSPI
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_F2S_PERIPH_REF_CLK 0x0
+ * main_qspi_clk
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_MAIN_QSPI_CLK      0x1
+ * periph_qspi_clk
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_E_PERIPH_QSPI_CLK    0x2
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_MSB        5
+/* The width in bits of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_PERPLL_SRC_QSPI register field value. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET_MSK    0x00000030
+/* The mask used to clear the ALT_CLKMGR_PERPLL_SRC_QSPI register field value. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_CLR_MSK    0xffffffcf
+/* The reset value of the ALT_CLKMGR_PERPLL_SRC_QSPI register field. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_RESET      0x1
+/* Extracts the ALT_CLKMGR_PERPLL_SRC_QSPI field value from a register. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_GET(value) (((value) & 0x00000030) >> 4)
+/* Produces a ALT_CLKMGR_PERPLL_SRC_QSPI register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_SRC_QSPI_SET(value) (((value) << 4) & 0x00000030)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_SRC.
+struct ALT_CLKMGR_PERPLL_SRC_s
+    uint32_t  sdmmc :  2;  /* SDMMC Clock Source */
+    uint32_t  nand  :  2;  /* NAND Clock Source */
+    uint32_t  qspi  :  2;  /* QSPI Clock Source */
+    uint32_t        : 26;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_SRC. */
+typedef volatile struct ALT_CLKMGR_PERPLL_SRC_s  ALT_CLKMGR_PERPLL_SRC_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_SRC register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_SRC_OFST        0x2c
+ * Register : Peripheral PLL Output Counter Reset Ack Status Register - stat
+ * Contains Output Clock Counter Reset acknowledge status.
+ * Register Layout
+ *  [5:0]  | R      | 0x0   | Output Counter Reset Acknowledge
+ * Field : Output Counter Reset Acknowledge - outresetack
+ * These read only bits per PLL output indicate that the PLL has received the
+ * Output Reset Counter request and has gracefully stopped the respective PLL
+ * output clock.
+ * The reset value of this bit is applied on a cold reset; warm reset has no affect
+ * on this bit.
+ *  ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_IDLE    | 0x0   | Idle
+ *  ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_ACK_RXD | 0x1   | Output Counter Acknowledge received.
+ * Enumerated value for register field ALT_CLKMGR_PERPLL_STAT_OUTRSTACK
+ * Idle
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_IDLE     0x0
+ * Output Counter Acknowledge received.
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_E_ACK_RXD  0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_MSB        5
+/* The width in bits of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field value. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET_MSK    0x0000003f
+/* The mask used to clear the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field value. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_CLR_MSK    0xffffffc0
+/* The reset value of the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_RESET      0x0
+/* Extracts the ALT_CLKMGR_PERPLL_STAT_OUTRSTACK field value from a register. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
+/* Produces a ALT_CLKMGR_PERPLL_STAT_OUTRSTACK register field value suitable for setting the register. */
+#define ALT_CLKMGR_PERPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
+ * The struct declaration for register ALT_CLKMGR_PERPLL_STAT.
+struct ALT_CLKMGR_PERPLL_STAT_s
+    const uint32_t  outresetack :  6;  /* Output Counter Reset Acknowledge */
+/* The typedef declaration for register ALT_CLKMGR_PERPLL_STAT. */
+typedef volatile struct ALT_CLKMGR_PERPLL_STAT_s  ALT_CLKMGR_PERPLL_STAT_t;
+/* The byte offset of the ALT_CLKMGR_PERPLL_STAT register from the beginning of the component. */
+#define ALT_CLKMGR_PERPLL_STAT_OFST        0x30
+ * The struct declaration for register group ALT_CLKMGR_PERPLL.
+struct ALT_CLKMGR_PERPLL_s
+    volatile ALT_CLKMGR_PERPLL_VCO_t              vco;                /* ALT_CLKMGR_PERPLL_VCO */
+    volatile ALT_CLKMGR_PERPLL_MISC_t             misc;               /* ALT_CLKMGR_PERPLL_MISC */
+    volatile ALT_CLKMGR_PERPLL_EMAC0CLK_t         emac0clk;           /* ALT_CLKMGR_PERPLL_EMAC0CLK */
+    volatile ALT_CLKMGR_PERPLL_EMAC1CLK_t         emac1clk;           /* ALT_CLKMGR_PERPLL_EMAC1CLK */
+    volatile ALT_CLKMGR_PERPLL_PERQSPICLK_t       perqspiclk;         /* ALT_CLKMGR_PERPLL_PERQSPICLK */
+    volatile ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK_t  pernandsdmmcclk;    /* ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK */
+    volatile ALT_CLKMGR_PERPLL_PERBASECLK_t       perbaseclk;         /* ALT_CLKMGR_PERPLL_PERBASECLK */
+    volatile ALT_CLKMGR_PERPLL_S2FUSER1CLK_t      s2fuser1clk;        /* ALT_CLKMGR_PERPLL_S2FUSER1CLK */
+    volatile ALT_CLKMGR_PERPLL_EN_t               en;                 /* ALT_CLKMGR_PERPLL_EN */
+    volatile ALT_CLKMGR_PERPLL_DIV_t              div;                /* ALT_CLKMGR_PERPLL_DIV */
+    volatile ALT_CLKMGR_PERPLL_GPIODIV_t          gpiodiv;            /* ALT_CLKMGR_PERPLL_GPIODIV */
+    volatile ALT_CLKMGR_PERPLL_SRC_t              src;                /* ALT_CLKMGR_PERPLL_SRC */
+    volatile ALT_CLKMGR_PERPLL_STAT_t             stat;               /* ALT_CLKMGR_PERPLL_STAT */
+    volatile uint32_t                             _pad_0x34_0x40[3];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_CLKMGR_PERPLL. */
+typedef volatile struct ALT_CLKMGR_PERPLL_s  ALT_CLKMGR_PERPLL_t;
+/* The struct declaration for the raw register contents of register group ALT_CLKMGR_PERPLL. */
+struct ALT_CLKMGR_PERPLL_raw_s
+    volatile uint32_t  vco;                /* ALT_CLKMGR_PERPLL_VCO */
+    volatile uint32_t  misc;               /* ALT_CLKMGR_PERPLL_MISC */
+    volatile uint32_t  emac0clk;           /* ALT_CLKMGR_PERPLL_EMAC0CLK */
+    volatile uint32_t  emac1clk;           /* ALT_CLKMGR_PERPLL_EMAC1CLK */
+    volatile uint32_t  perqspiclk;         /* ALT_CLKMGR_PERPLL_PERQSPICLK */
+    volatile uint32_t  pernandsdmmcclk;    /* ALT_CLKMGR_PERPLL_PERNANDSDMMCCLK */
+    volatile uint32_t  perbaseclk;         /* ALT_CLKMGR_PERPLL_PERBASECLK */
+    volatile uint32_t  s2fuser1clk;        /* ALT_CLKMGR_PERPLL_S2FUSER1CLK */
+    volatile uint32_t  en;                 /* ALT_CLKMGR_PERPLL_EN */
+    volatile uint32_t  div;                /* ALT_CLKMGR_PERPLL_DIV */
+    volatile uint32_t  gpiodiv;            /* ALT_CLKMGR_PERPLL_GPIODIV */
+    volatile uint32_t  src;                /* ALT_CLKMGR_PERPLL_SRC */
+    volatile uint32_t  stat;               /* ALT_CLKMGR_PERPLL_STAT */
+/* The typedef declaration for the raw register contents of register group ALT_CLKMGR_PERPLL. */
+typedef volatile struct ALT_CLKMGR_PERPLL_raw_s  ALT_CLKMGR_PERPLL_raw_t;
+ * Register Group : SDRAM PLL Group - ALT_CLKMGR_SDRPLL
+ * SDRAM PLL Group
+ * Contains registers with settings for the SDRAM PLL.
+ * Register : SDRAM PLL VCO Control Register - vco
+ * Contains settings that control the SDRAM PLL VCO. The VCO output frequency is
+ * the input frequency multiplied by the numerator (M+1) and divided by the
+ * denominator (N+1).
+ * Register Layout
+ *  [0]     | RW     | 0x1   | BG PWRDN
+ *  [1]     | RW     | 0x0   | Enable
+ *  [2]     | RW     | 0x1   | Power down
+ *  [15:3]  | RW     | 0x1   | Numerator (M)
+ *  [21:16] | RW     | 0x1   | Denominator (N)
+ *  [23:22] | RW     | 0x0   | Clock Source
+ *  [24]    | RW     | 0x0   | SDRAM All Output Counter Reset
+ *  [30:25] | RW     | 0x0   | Output Counter Reset
+ *  [31]    | RW     | 0x1   | External Regulator Input Select
+ * Field : BG PWRDN - bgpwrdn
+ * If '1', powers down bandgap. If '0', bandgap is not power down.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_MSB        0
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_BGPWRDN field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_BGPWRDN register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_BGPWRDN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Enable - en
+ * If '1', VCO is enabled. If '0', VCO is in reset.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_MSB        1
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_EN register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_EN register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_EN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_EN field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_EN register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_EN_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Power down - pwrdn
+ * If '1', power down analog circuitry. If '0', analog circuitry not powered down.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_MSB        2
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_PWRDN register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_PWRDN field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_PWRDN register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_PWRDN_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Numerator (M) - numer
+ * Numerator in VCO output frequency equation. For incremental frequency change, if
+ * the new value lead to less than 20% of the frequency change, this value can be
+ * changed without resetting the PLL. The Numerator and Denominator can not be
+ * changed at the same time for incremental frequency changed.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_MSB        15
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_WIDTH      13
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_NUMER register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET_MSK    0x0000fff8
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_NUMER register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_CLR_MSK    0xffff0007
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_NUMER register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_NUMER field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_GET(value) (((value) & 0x0000fff8) >> 3)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_NUMER register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_NUMER_SET(value) (((value) << 3) & 0x0000fff8)
+ * Field : Denominator (N) - denom
+ * Denominator in VCO output frequency equation. For incremental frequency change,
+ * if the new value lead to less than 20% of the frequency change, this value can
+ * be changed without resetting the PLL. The Numerator and Denominator can not be
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_MSB        21
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_DENOM register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET_MSK    0x003f0000
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_DENOM register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_CLR_MSK    0xffc0ffff
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_DENOM register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_DENOM field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_GET(value) (((value) & 0x003f0000) >> 16)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_DENOM register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_DENOM_SET(value) (((value) << 16) & 0x003f0000)
+ * Field : Clock Source - ssrc
+ * Controls the VCO input clock source. The PLL must by bypassed to eosc1_clk
+ * before changing this field.
+ * Qsys and user documenation refer to f2s_sdram_ref_clk as f2h_sdram_ref_clk.
+ *  ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC1         | 0x0   | eosc1_clk
+ *  ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC2         | 0x1   | eosc2_clk
+ *  ALT_CLKMGR_SDRPLL_VCO_SSRC_E_F2S_SDRAM_REF | 0x2   | f2s_sdram_ref_clk
+ * Enumerated value for register field ALT_CLKMGR_SDRPLL_VCO_SSRC
+ * eosc1_clk
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC1          0x0
+ * eosc2_clk
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_EOSC2          0x1
+ * f2s_sdram_ref_clk
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_E_F2S_SDRAM_REF  0x2
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_LSB        22
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_MSB        23
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_WIDTH      2
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_SSRC register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET_MSK    0x00c00000
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_SSRC register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_CLR_MSK    0xff3fffff
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_SSRC register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_SSRC field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_GET(value) (((value) & 0x00c00000) >> 22)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_SSRC register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_SSRC_SET(value) (((value) << 22) & 0x00c00000)
+ * Field : SDRAM All Output Counter Reset - outresetall
+ * Before releasing Bypass, All Output Counter Reset must be set and cleared by
+ * software for correct clock operation.
+ * If '1', Reset phase multiplexer and output counter state. So that after the
+ * assertion all the clocks output are start from rising edge align.
+ * If '0', phase multiplexer and output counter state not reset and no change to
+ * the phase of the clock outputs.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_LSB        24
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_MSB        24
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET_MSK    0x01000000
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_CLR_MSK    0xfeffffff
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_GET(value) (((value) & 0x01000000) >> 24)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRSTALL_SET(value) (((value) << 24) & 0x01000000)
+ * Field : Output Counter Reset - outreset
+ * Resets the individual PLL output counter.
+ * For software to change the PLL output counter without producing glitches on the
+ * respective clock, SW must set the VCO register respective Output Counter Reset
+ * bit. Software then polls the respective Output Counter Reset Acknowledge bit in
+ * the Output Counter Reset Ack Status Register. Software then writes the
+ * appropriate counter register, and then clears the respective VCO register Output
+ * Counter Reset bit.
+ * LSB 'outreset[0]' corresponds to PLL output clock C0, etc.
+ * If set to '1', reset output divider, no clock output from counter.
+ * If set to '0', counter is not reset.
+ * on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_LSB        25
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_MSB        30
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET_MSK    0x7e000000
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_CLR_MSK    0x81ffffff
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_OUTRST register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_OUTRST field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_GET(value) (((value) & 0x7e000000) >> 25)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_OUTRST register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_OUTRST_SET(value) (((value) << 25) & 0x7e000000)
+ * Field : External Regulator Input Select - regextsel
+ * If set to '1', the external regulator is selected for the PLL.
+ * If set to '0', the internal regulator is slected.
+ * It is strongly recommended to select the external regulator while the PLL is not
+ * enabled (in reset), and  then disable the external regulater once the PLL
+ * becomes enabled.  Software should simulateously update the 'Enable' bit and the
+ * 'External Regulator Input Select' in the same write access to the VCO register.
+ * When the 'Enable' bit is clear, the 'External Regulator Input Select' should be
+ * set, and vice versa.
+ * on this bit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_LSB        31
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_MSB        31
+/* The width in bits of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET_MSK    0x80000000
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field value. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_CLR_MSK    0x7fffffff
+/* The reset value of the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL field value from a register. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_GET(value) (((value) & 0x80000000) >> 31)
+/* Produces a ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_VCO_REGEXTSEL_SET(value) (((value) << 31) & 0x80000000)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_VCO.
+struct ALT_CLKMGR_SDRPLL_VCO_s
+    uint32_t  bgpwrdn     :  1;  /* BG PWRDN */
+    uint32_t  en          :  1;  /* Enable */
+    uint32_t  pwrdn       :  1;  /* Power down */
+    uint32_t  numer       : 13;  /* Numerator (M) */
+    uint32_t  denom       :  6;  /* Denominator (N) */
+    uint32_t  ssrc        :  2;  /* Clock Source */
+    uint32_t  outresetall :  1;  /* SDRAM All Output Counter Reset */
+    uint32_t  outreset    :  6;  /* Output Counter Reset */
+    uint32_t  regextsel   :  1;  /* External Regulator Input Select */
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_VCO. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_VCO_s  ALT_CLKMGR_SDRPLL_VCO_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_CLKMGR_SDRPLL_VCO register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_VCO_OFST        0x0
+ * Register : SDRAM PLL VCO Advanced Control Register - ctrl
+ * Contains VCO control signals and other PLL control signals need to be
+ * controllable through register.
+ * Register Layout
+ *  Bits    | Access | Reset | Description
+ *  [0]     | RW     | 0x0   | Loop Bandwidth Adjust Enabled
+ *  [12:1]  | RW     | 0x1   | Loop Bandwidth Adjust
+ *  [13]    | RW     | 0x0   | Fast Locking Enable
+ *  [14]    | RW     | 0x1   | Saturation Enable
+ *  [31:15] | ???    | 0x0   | *UNDEFINED*
+ * Field : Loop Bandwidth Adjust Enabled - bwadjen
+ * If set to 1, the Loop Bandwidth Adjust value comes from the Loop Bandwidth
+ * Adjust field.
+ * If set to 0, the Loop Bandwidth Adjust value equals the M field divided by 2
+ * value of the VCO Control Register.  The M divided by 2 is the upper 12 bits
+ * (12:1) of the M field in the VCO register.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_MSB        0
+/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_CTL_BWADJEN field value from a register. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_CTL_BWADJEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJEN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Loop Bandwidth Adjust - bwadj
+ * Provides Loop Bandwidth Adjust value.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_MSB        12
+/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_WIDTH      12
+/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET_MSK    0x00001ffe
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_CLR_MSK    0xffffe001
+/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_BWADJ register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_CTL_BWADJ field value from a register. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_GET(value) (((value) & 0x00001ffe) >> 1)
+/* Produces a ALT_CLKMGR_SDRPLL_CTL_BWADJ register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_CTL_BWADJ_SET(value) (((value) << 1) & 0x00001ffe)
+ * Field : Fast Locking Enable - fasten
+ * Enables fast locking circuit.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_MSB        13
+/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET_MSK    0x00002000
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_FASTEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_CTL_FASTEN field value from a register. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_CLKMGR_SDRPLL_CTL_FASTEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_CTL_FASTEN_SET(value) (((value) << 13) & 0x00002000)
+ * Field : Saturation Enable - saten
+ * Enables saturation behavior.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_MSB        14
+/* The width in bits of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_CTL_SATEN register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET_MSK    0x00004000
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_CTL_SATEN register field value. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_CLKMGR_SDRPLL_CTL_SATEN register field. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_CTL_SATEN field value from a register. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_CLKMGR_SDRPLL_CTL_SATEN register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_CTL_SATEN_SET(value) (((value) << 14) & 0x00004000)
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_CTL.
+struct ALT_CLKMGR_SDRPLL_CTL_s
+    uint32_t  bwadjen :  1;  /* Loop Bandwidth Adjust Enabled */
+    uint32_t  bwadj   : 12;  /* Loop Bandwidth Adjust */
+    uint32_t  fasten  :  1;  /* Fast Locking Enable */
+    uint32_t  saten   :  1;  /* Saturation Enable */
+    uint32_t          : 17;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_CTL. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_CTL_s  ALT_CLKMGR_SDRPLL_CTL_t;
+/* The byte offset of the ALT_CLKMGR_SDRPLL_CTL register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_CTL_OFST        0x4
+ * Register : SDRAM PLL C0 Control Register for Clock ddr_dqs_clk - ddrdqsclk
+ * Contains settings that control clock ddr_dqs_clk generated from the C0 output of
+ * the SDRAM PLL.
+ * Fields are only reset by a cold reset.
+ * Register Layout
+ *  [8:0]   | RW     | 0x1   | Counter
+ *  [20:9]  | RW     | 0x0   | Phase Shift
+ *  [31:21] | ???    | 0x0   | *UNDEFINED*
+ * Field : Counter - cnt
+ * Divides the VCO frequency by the value+1 in this field.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT field value from a register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+ * Field : Phase Shift - phase
+ * Increment the phase of the VCO output by the value in this field multiplied by
+ * 45 degrees. The accumulated phase shift is the total shifted amount since the
+ * last assertion of the 'SDRAM All Output Divider Reset' bit in the SDRAM vco
+ * control register. In order to guarantee the phase shift to a known value, 'SDRAM
+ * clocks output phase align' bit should be asserted before programming this field.
+ * This field is only writeable by SW when it is zero.  HW updates this field in
+ * real time as the phase adjustment is being made.   SW may poll this field
+ * waiting for zero indicating the phase adjustment has completed by HW.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_MSB        20
+/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_WIDTH      12
+/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET_MSK    0x001ffe00
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_CLR_MSK    0xffe001ff
+/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE field value from a register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
+/* Produces a ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_DDRDQSCLK.
+struct ALT_CLKMGR_SDRPLL_DDRDQSCLK_s
+    uint32_t  cnt   :  9;  /* Counter */
+    uint32_t  phase : 12;  /* Phase Shift */
+    uint32_t        : 11;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_DDRDQSCLK. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_DDRDQSCLK_s  ALT_CLKMGR_SDRPLL_DDRDQSCLK_t;
+/* The byte offset of the ALT_CLKMGR_SDRPLL_DDRDQSCLK register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_DDRDQSCLK_OFST        0x8
+ * Register : SDRAM PLL C1 Control Register for Clock ddr_2x_dqs_clk - ddr2xdqsclk
+ * Contains settings that control clock ddr_2x_dqs_clk generated from the C1 output
+ * of the SDRAM PLL.
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT field value from a register. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_MSB        20
+/* The width in bits of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_WIDTH      12
+/* The mask used to set the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET_MSK    0x001ffe00
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_CLR_MSK    0xffe001ff
+/* The reset value of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE field value from a register. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
+/* Produces a ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_DDR2XDQSCLK.
+struct ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_s
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_DDR2XDQSCLK. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_s  ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_t;
+/* The byte offset of the ALT_CLKMGR_SDRPLL_DDR2XDQSCLK register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_OFST        0xc
+ * Register : SDRAM PLL C2 Control Register for Clock ddr_dq_clk - ddrdqclk
+ * Contains settings that control clock ddr_dq_clk generated from the C2 output of
+ * the SDRAM PLL.
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT field value from a register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_MSB        20
+/* The width in bits of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_WIDTH      12
+/* The mask used to set the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET_MSK    0x001ffe00
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_CLR_MSK    0xffe001ff
+/* The reset value of the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE field value from a register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
+/* Produces a ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_DDRDQCLK.
+struct ALT_CLKMGR_SDRPLL_DDRDQCLK_s
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_DDRDQCLK. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_DDRDQCLK_s  ALT_CLKMGR_SDRPLL_DDRDQCLK_t;
+/* The byte offset of the ALT_CLKMGR_SDRPLL_DDRDQCLK register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_DDRDQCLK_OFST        0x10
+ * Register : SDRAM PLL C5 Control Register for Clock s2f_user2_clk - s2fuser2clk
+ * Contains settings that control clock s2f_user2_clk generated from the C5 output
+ * Qsys and user documenation refer to s2f_user2_clk as h2f_user2_clk
+ * Register Layout
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_MSB        8
+/* The width in bits of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_WIDTH      9
+/* The mask used to set the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET_MSK    0x000001ff
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field value. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_CLR_MSK    0xfffffe00
+/* The reset value of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT field value from a register. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_GET(value) (((value) & 0x000001ff) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_CNT_SET(value) (((value) << 0) & 0x000001ff)
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_MSB        20
+/* The width in bits of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_WIDTH      12
+/* The mask used to set the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET_MSK    0x001ffe00
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field value. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_CLR_MSK    0xffe001ff
+/* The reset value of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE field value from a register. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_GET(value) (((value) & 0x001ffe00) >> 9)
+/* Produces a ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_PHASE_SET(value) (((value) << 9) & 0x001ffe00)
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_S2FUSER2CLK.
+struct ALT_CLKMGR_SDRPLL_S2FUSER2CLK_s
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_S2FUSER2CLK. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_S2FUSER2CLK_s  ALT_CLKMGR_SDRPLL_S2FUSER2CLK_t;
+/* The byte offset of the ALT_CLKMGR_SDRPLL_S2FUSER2CLK register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_S2FUSER2CLK_OFST        0x14
+ * Register : Enable Register - en
+ * Contains fields that control the SDRAM Clock Group enables generated from the
+ * SDRAM PLL clock outputs.
+ * 1: The clock is enabled.
+ * 0: The clock is disabled.
+ * Register Layout
+ *  [0]    | RW     | 0x1   | ddr_dqs_clk Enable
+ *  [1]    | RW     | 0x1   | ddr_2x_dqs_clk Enable
+ *  [2]    | RW     | 0x1   | ddr_dq_clk Enable
+ *  [3]    | RW     | 0x1   | s2f_user2_clk Enable
+ *  [31:4] | ???    | 0x0   | *UNDEFINED*
+ * Field : ddr_dqs_clk Enable - ddrdqsclk
+ * Enables clock ddr_dqs_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_MSB        0
+/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET_MSK    0x00000001
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK field value from a register. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQSCLK_SET(value) (((value) << 0) & 0x00000001)
+ * Field : ddr_2x_dqs_clk Enable - ddr2xdqsclk
+ * Enables clock ddr_2x_dqs_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_MSB        1
+/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET_MSK    0x00000002
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK field value from a register. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_EN_DDR2XDQSCLK_SET(value) (((value) << 1) & 0x00000002)
+ * Field : ddr_dq_clk Enable - ddrdqclk
+ * Enables clock ddr_dq_clk output
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_MSB        2
+/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET_MSK    0x00000004
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_EN_DDRDQCLK field value from a register. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_CLKMGR_SDRPLL_EN_DDRDQCLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_EN_DDRDQCLK_SET(value) (((value) << 2) & 0x00000004)
+ * Field : s2f_user2_clk Enable - s2fuser2clk
+ * Enables clock s2f_user2_clk output.
+ * Qsys and user documenation refer to s2f_user2_clk as h2f_user2_clk.
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_MSB        3
+/* The width in bits of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_WIDTH      1
+/* The mask used to set the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET_MSK    0x00000008
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field value. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_RESET      0x1
+/* Extracts the ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK field value from a register. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_EN_S2FUSER2CLK_SET(value) (((value) << 3) & 0x00000008)
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_EN.
+struct ALT_CLKMGR_SDRPLL_EN_s
+    uint32_t  ddrdqsclk   :  1;  /* ddr_dqs_clk Enable */
+    uint32_t  ddr2xdqsclk :  1;  /* ddr_2x_dqs_clk Enable */
+    uint32_t  ddrdqclk    :  1;  /* ddr_dq_clk Enable */
+    uint32_t  s2fuser2clk :  1;  /* s2f_user2_clk Enable */
+    uint32_t              : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_EN. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_EN_s  ALT_CLKMGR_SDRPLL_EN_t;
+/* The byte offset of the ALT_CLKMGR_SDRPLL_EN register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_EN_OFST        0x18
+ * Register : SDRAM PLL Output Counter Reset Ack Status Register - stat
+ * Register Layout
+ * output clock.
+ * on this bit.
+ * Field Enumeration Values:
+ *  Enum                                       | Value | Description
+ *  ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_IDLE    | 0x0   | Idle
+ *  ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_ACK_RXD | 0x1   | Output Counter Acknowledge received.
+ * Enumerated value for register field ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK
+ * Idle
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_IDLE     0x0
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_E_ACK_RXD  0x1
+/* The Least Significant Bit (LSB) position of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_MSB        5
+/* The width in bits of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_WIDTH      6
+/* The mask used to set the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field value. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET_MSK    0x0000003f
+/* The mask used to clear the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field value. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_CLR_MSK    0xffffffc0
+/* The reset value of the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_RESET      0x0
+/* Extracts the ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK field value from a register. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_GET(value) (((value) & 0x0000003f) >> 0)
+/* Produces a ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK register field value suitable for setting the register. */
+#define ALT_CLKMGR_SDRPLL_STAT_OUTRSTACK_SET(value) (((value) << 0) & 0x0000003f)
+ * The struct declaration for register ALT_CLKMGR_SDRPLL_STAT.
+struct ALT_CLKMGR_SDRPLL_STAT_s
+/* The typedef declaration for register ALT_CLKMGR_SDRPLL_STAT. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_STAT_s  ALT_CLKMGR_SDRPLL_STAT_t;
+/* The byte offset of the ALT_CLKMGR_SDRPLL_STAT register from the beginning of the component. */
+#define ALT_CLKMGR_SDRPLL_STAT_OFST        0x1c
+ * The struct declaration for register group ALT_CLKMGR_SDRPLL.
+struct ALT_CLKMGR_SDRPLL_s
+    volatile ALT_CLKMGR_SDRPLL_VCO_t          vco;          /* ALT_CLKMGR_SDRPLL_VCO */
+    volatile ALT_CLKMGR_SDRPLL_CTL_t          ctrl;         /* ALT_CLKMGR_SDRPLL_CTL */
+    volatile ALT_CLKMGR_SDRPLL_DDRDQSCLK_t    ddrdqsclk;    /* ALT_CLKMGR_SDRPLL_DDRDQSCLK */
+    volatile ALT_CLKMGR_SDRPLL_DDR2XDQSCLK_t  ddr2xdqsclk;  /* ALT_CLKMGR_SDRPLL_DDR2XDQSCLK */
+    volatile ALT_CLKMGR_SDRPLL_DDRDQCLK_t     ddrdqclk;     /* ALT_CLKMGR_SDRPLL_DDRDQCLK */
+    volatile ALT_CLKMGR_SDRPLL_S2FUSER2CLK_t  s2fuser2clk;  /* ALT_CLKMGR_SDRPLL_S2FUSER2CLK */
+    volatile ALT_CLKMGR_SDRPLL_EN_t           en;           /* ALT_CLKMGR_SDRPLL_EN */
+    volatile ALT_CLKMGR_SDRPLL_STAT_t         stat;         /* ALT_CLKMGR_SDRPLL_STAT */
+/* The typedef declaration for register group ALT_CLKMGR_SDRPLL. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_s  ALT_CLKMGR_SDRPLL_t;
+/* The struct declaration for the raw register contents of register group ALT_CLKMGR_SDRPLL. */
+struct ALT_CLKMGR_SDRPLL_raw_s
+    volatile uint32_t  vco;          /* ALT_CLKMGR_SDRPLL_VCO */
+    volatile uint32_t  ctrl;         /* ALT_CLKMGR_SDRPLL_CTL */
+    volatile uint32_t  ddrdqsclk;    /* ALT_CLKMGR_SDRPLL_DDRDQSCLK */
+    volatile uint32_t  ddr2xdqsclk;  /* ALT_CLKMGR_SDRPLL_DDR2XDQSCLK */
+    volatile uint32_t  ddrdqclk;     /* ALT_CLKMGR_SDRPLL_DDRDQCLK */
+    volatile uint32_t  s2fuser2clk;  /* ALT_CLKMGR_SDRPLL_S2FUSER2CLK */
+    volatile uint32_t  en;           /* ALT_CLKMGR_SDRPLL_EN */
+    volatile uint32_t  stat;         /* ALT_CLKMGR_SDRPLL_STAT */
+/* The typedef declaration for the raw register contents of register group ALT_CLKMGR_SDRPLL. */
+typedef volatile struct ALT_CLKMGR_SDRPLL_raw_s  ALT_CLKMGR_SDRPLL_raw_t;
+ * The struct declaration for register group ALT_CLKMGR.
+struct ALT_CLKMGR_s
+    volatile ALT_CLKMGR_CTL_t      ctrl;                 /* ALT_CLKMGR_CTL */
+    volatile ALT_CLKMGR_BYPASS_t   bypass;               /* ALT_CLKMGR_BYPASS */
+    volatile ALT_CLKMGR_INTER_t    inter;                /* ALT_CLKMGR_INTER */
+    volatile ALT_CLKMGR_INTREN_t   intren;               /* ALT_CLKMGR_INTREN */
+    volatile ALT_CLKMGR_DBCTL_t    dbctrl;               /* ALT_CLKMGR_DBCTL */
+    volatile ALT_CLKMGR_STAT_t     stat;                 /* ALT_CLKMGR_STAT */
+    volatile uint32_t              _pad_0x18_0x3f[10];   /* *UNDEFINED* */
+    volatile ALT_CLKMGR_MAINPLL_t  mainpllgrp;           /* ALT_CLKMGR_MAINPLL */
+    volatile ALT_CLKMGR_PERPLL_t   perpllgrp;            /* ALT_CLKMGR_PERPLL */
+    volatile ALT_CLKMGR_SDRPLL_t   sdrpllgrp;            /* ALT_CLKMGR_SDRPLL */
+    volatile uint32_t              _pad_0xe0_0x200[72];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_CLKMGR. */
+typedef volatile struct ALT_CLKMGR_s  ALT_CLKMGR_t;
+/* The struct declaration for the raw register contents of register group ALT_CLKMGR. */
+struct ALT_CLKMGR_raw_s
+    volatile uint32_t                  ctrl;                 /* ALT_CLKMGR_CTL */
+    volatile uint32_t                  bypass;               /* ALT_CLKMGR_BYPASS */
+    volatile uint32_t                  inter;                /* ALT_CLKMGR_INTER */
+    volatile uint32_t                  intren;               /* ALT_CLKMGR_INTREN */
+    volatile uint32_t                  dbctrl;               /* ALT_CLKMGR_DBCTL */
+    volatile uint32_t                  stat;                 /* ALT_CLKMGR_STAT */
+    volatile ALT_CLKMGR_MAINPLL_raw_t  mainpllgrp;           /* ALT_CLKMGR_MAINPLL */
+    volatile ALT_CLKMGR_PERPLL_raw_t   perpllgrp;            /* ALT_CLKMGR_PERPLL */
+    volatile ALT_CLKMGR_SDRPLL_raw_t   sdrpllgrp;            /* ALT_CLKMGR_SDRPLL */
+/* The typedef declaration for the raw register contents of register group ALT_CLKMGR. */
+typedef volatile struct ALT_CLKMGR_raw_s  ALT_CLKMGR_raw_t;
+#ifdef __cplusplus
+#endif  /* __cplusplus */
+#endif  /* __ALTERA_ALT_CLKMGR_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_gpio.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_gpio.h
new file mode 100644
index 0000000..8bc4640
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_gpio.h
@@ -0,0 +1,1991 @@
+* Copyright 2013 Altera Corporation. All Rights Reserved.                      *
+* Redistribution and use in source and binary forms, with or without           *
+* modification, are permitted provided that the following conditions are met:  *
+* 1. Redistributions of source code must retain the above copyright notice,    *
+*    this list of conditions and the following disclaimer.                     *
+* 2. Redistributions in binary form must reproduce the above copyright notice, *
+*    this list of conditions and the following disclaimer in the documentation *
+*    and/or other materials provided with the distribution.                    *
+* 3. The name of the author may not be used to endorse or promote products     *
+*    derived from this software without specific prior written permission.     *
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO  *
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,       *
+* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
+* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;  *
+* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,     *
+* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR      *
+* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF       *
+* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                                   *
+/* Altera - ALT_GPIO */
+#ifndef __ALTERA_ALT_GPIO_H__
+#define __ALTERA_ALT_GPIO_H__
+#ifdef __cplusplus
+extern "C"
+ * Component : GPIO Module - ALT_GPIO
+ * GPIO Module
+ * Registers in the GPIO module
+ * Register : Port A Data Register - gpio_swporta_dr
+ * This GPIO Data register is used to input or output data
+ * Check the GPIO chapter in the handbook for details on how GPIO2 is implemented.
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Port A Data
+ *  [31:29] | ???    | 0x0   | *UNDEFINED*
+ * Field : Port A Data - gpio_swporta_dr
+ * Values written to this register are output on the I/O signals of the GPIO Data
+ * Register, if the corresponding data direction bits for GPIO Data Direction Field
+ * are set to Output mode. The value read back is equal to the last value written
+ * to this register.
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_MSB        28
+/* The width in bits of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_WIDTH      29
+/* The mask used to set the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field value. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field value. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_RESET      0x0
+/* Extracts the ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR field value from a register. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR register field value suitable for setting the register. */
+#define ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_SWPORTA_DR.
+struct ALT_GPIO_SWPORTA_DR_s
+    uint32_t  gpio_swporta_dr : 29;  /* Port A Data */
+    uint32_t                  :  3;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_GPIO_SWPORTA_DR. */
+typedef volatile struct ALT_GPIO_SWPORTA_DR_s  ALT_GPIO_SWPORTA_DR_t;
+/* The byte offset of the ALT_GPIO_SWPORTA_DR register from the beginning of the component. */
+#define ALT_GPIO_SWPORTA_DR_OFST        0x0
+/* The address of the ALT_GPIO_SWPORTA_DR register. */
+#define ALT_GPIO_SWPORTA_DR_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_SWPORTA_DR_OFST))
+ * Register : Port A Data Direction Register - gpio_swporta_ddr
+ * This register establishes the direction of each corresponding GPIO Data Field
+ * Bit.
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Port A Data Direction Field
+ * Field : Port A Data Direction Field - gpio_swporta_ddr
+ * Values written to this register independently control the direction of the
+ * corresponding data bit in the Port A Data Register.
+ *  ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_IN  | 0x0   | Input Direction
+ *  ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_OUT | 0x1   | Output Direction
+ * Enumerated value for register field ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR
+ * Input Direction
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_IN  0x0
+ * Output Direction
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_OUT 0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_MSB        28
+/* The width in bits of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_WIDTH      29
+/* The mask used to set the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field value. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field value. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_RESET      0x0
+/* Extracts the ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR field value from a register. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR register field value suitable for setting the register. */
+#define ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_SWPORTA_DDR.
+struct ALT_GPIO_SWPORTA_DDR_s
+    uint32_t  gpio_swporta_ddr : 29;  /* Port A Data Direction Field */
+/* The typedef declaration for register ALT_GPIO_SWPORTA_DDR. */
+typedef volatile struct ALT_GPIO_SWPORTA_DDR_s  ALT_GPIO_SWPORTA_DDR_t;
+/* The byte offset of the ALT_GPIO_SWPORTA_DDR register from the beginning of the component. */
+#define ALT_GPIO_SWPORTA_DDR_OFST        0x4
+/* The address of the ALT_GPIO_SWPORTA_DDR register. */
+#define ALT_GPIO_SWPORTA_DDR_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_SWPORTA_DDR_OFST))
+ * Register : Interrupt Enable Register - gpio_inten
+ * The Interrupt enable register allows interrupts for each bit of the Port A data
+ * register.
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Interrupt Enable Field
+ * Field : Interrupt Enable Field - gpio_inten
+ * Allows each bit of Port A Data Register to be configured for interrupt
+ * capability. Interrupts are disabled on the corresponding bits of Port A Data
+ * Register if the corresponding data direction register is set to Output.
+ *  ALT_GPIO_INTEN_GPIO_INTEN_E_DIS | 0x0   | Disable Interrupt on Port A
+ *  ALT_GPIO_INTEN_GPIO_INTEN_E_EN  | 0x1   | Enable Interrupt on Port A
+ * Field Access Macros:
+ * Enumerated value for register field ALT_GPIO_INTEN_GPIO_INTEN
+ * Disable Interrupt on Port A
+#define ALT_GPIO_INTEN_GPIO_INTEN_E_DIS 0x0
+ * Enable Interrupt on Port A
+#define ALT_GPIO_INTEN_GPIO_INTEN_E_EN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_MSB        28
+/* The width in bits of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_WIDTH      29
+/* The mask used to set the ALT_GPIO_INTEN_GPIO_INTEN register field value. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_INTEN_GPIO_INTEN register field value. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_INTEN_GPIO_INTEN register field. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_RESET      0x0
+/* Extracts the ALT_GPIO_INTEN_GPIO_INTEN field value from a register. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_INTEN_GPIO_INTEN register field value suitable for setting the register. */
+#define ALT_GPIO_INTEN_GPIO_INTEN_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_INTEN.
+struct ALT_GPIO_INTEN_s
+    uint32_t  gpio_inten : 29;  /* Interrupt Enable Field */
+/* The typedef declaration for register ALT_GPIO_INTEN. */
+typedef volatile struct ALT_GPIO_INTEN_s  ALT_GPIO_INTEN_t;
+/* The byte offset of the ALT_GPIO_INTEN register from the beginning of the component. */
+#define ALT_GPIO_INTEN_OFST        0x30
+/* The address of the ALT_GPIO_INTEN register. */
+#define ALT_GPIO_INTEN_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTEN_OFST))
+ * Register : Interrupt Mask Register - gpio_intmask
+ * Controls which pins cause interrupts on Port A Data Register inputs.
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Interrupt Mask Field
+ * Field : Interrupt Mask Field - gpio_intmask
+ * Controls whether an interrupt on Port A Data Register can generate an interrupt
+ * to the interrupt controller by not masking it. The unmasked status can be read
+ * as well as the resultant status after masking.
+ *  ALT_GPIO_INTMSK_GPIO_INTMSK_E_DIS | 0x0   | Interrupt bits are unmasked
+ *  ALT_GPIO_INTMSK_GPIO_INTMSK_E_EN  | 0x1   | Mask Interrupt
+ * Enumerated value for register field ALT_GPIO_INTMSK_GPIO_INTMSK
+ * Interrupt bits are unmasked
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_E_DIS   0x0
+ * Mask Interrupt
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_MSB        28
+/* The width in bits of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_WIDTH      29
+/* The mask used to set the ALT_GPIO_INTMSK_GPIO_INTMSK register field value. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_INTMSK_GPIO_INTMSK register field value. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_INTMSK_GPIO_INTMSK register field. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_RESET      0x0
+/* Extracts the ALT_GPIO_INTMSK_GPIO_INTMSK field value from a register. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_INTMSK_GPIO_INTMSK register field value suitable for setting the register. */
+#define ALT_GPIO_INTMSK_GPIO_INTMSK_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_INTMSK.
+struct ALT_GPIO_INTMSK_s
+    uint32_t  gpio_intmask : 29;  /* Interrupt Mask Field */
+/* The typedef declaration for register ALT_GPIO_INTMSK. */
+typedef volatile struct ALT_GPIO_INTMSK_s  ALT_GPIO_INTMSK_t;
+/* The byte offset of the ALT_GPIO_INTMSK register from the beginning of the component. */
+#define ALT_GPIO_INTMSK_OFST        0x34
+/* The address of the ALT_GPIO_INTMSK register. */
+#define ALT_GPIO_INTMSK_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTMSK_OFST))
+ * Register : Interrupt Level Register - gpio_inttype_level
+ * The interrupt level register defines the type of interrupt (edge or level).
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Interrupt Level Field
+ * Field : Interrupt Level Field - gpio_inttype_level
+ * This field controls the type of interrupt that can occur on the Port A Data
+ * Register.
+ *  ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_LEVEL | 0x0   | Level-sensitive
+ *  ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_EDGE  | 0x1   | Edge-sensitive
+ * Enumerated value for register field ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL
+ * Level-sensitive
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_LEVEL   0x0
+ * Edge-sensitive
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_EDGE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_MSB        28
+/* The width in bits of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_WIDTH      29
+/* The mask used to set the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field value. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field value. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_RESET      0x0
+/* Extracts the ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL field value from a register. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL register field value suitable for setting the register. */
+#define ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_INTTYPE_LEVEL.
+struct ALT_GPIO_INTTYPE_LEVEL_s
+    uint32_t  gpio_inttype_level : 29;  /* Interrupt Level Field */
+/* The typedef declaration for register ALT_GPIO_INTTYPE_LEVEL. */
+typedef volatile struct ALT_GPIO_INTTYPE_LEVEL_s  ALT_GPIO_INTTYPE_LEVEL_t;
+/* The byte offset of the ALT_GPIO_INTTYPE_LEVEL register from the beginning of the component. */
+#define ALT_GPIO_INTTYPE_LEVEL_OFST        0x38
+/* The address of the ALT_GPIO_INTTYPE_LEVEL register. */
+#define ALT_GPIO_INTTYPE_LEVEL_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTTYPE_LEVEL_OFST))
+ * Register : Interrupt Polarity Register - gpio_int_polarity
+ * Controls the Polarity of Interrupts that can occur on inputs of Port A Data
+ * Register
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Polarity Control Field
+ * Field : Polarity Control Field - gpio_int_polarity
+ * Controls the polarity of edge or level sensitivity that can occur on input of
+ * Port A Data Register.
+ *  ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTLOW  | 0x0   | Active low
+ *  ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTHIGH | 0x1   | Active high
+ * Enumerated value for register field ALT_GPIO_INT_POL_GPIO_INT_POL
+ * Active low
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTLOW  0x0
+ * Active high
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTHIGH 0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_MSB        28
+/* The width in bits of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_WIDTH      29
+/* The mask used to set the ALT_GPIO_INT_POL_GPIO_INT_POL register field value. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_INT_POL_GPIO_INT_POL register field value. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_INT_POL_GPIO_INT_POL register field. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_RESET      0x0
+/* Extracts the ALT_GPIO_INT_POL_GPIO_INT_POL field value from a register. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_INT_POL_GPIO_INT_POL register field value suitable for setting the register. */
+#define ALT_GPIO_INT_POL_GPIO_INT_POL_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_INT_POL.
+struct ALT_GPIO_INT_POL_s
+    uint32_t  gpio_int_polarity : 29;  /* Polarity Control Field */
+/* The typedef declaration for register ALT_GPIO_INT_POL. */
+typedef volatile struct ALT_GPIO_INT_POL_s  ALT_GPIO_INT_POL_t;
+/* The byte offset of the ALT_GPIO_INT_POL register from the beginning of the component. */
+#define ALT_GPIO_INT_POL_OFST        0x3c
+/* The address of the ALT_GPIO_INT_POL register. */
+#define ALT_GPIO_INT_POL_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INT_POL_OFST))
+ * Register : Interrupt Status Register - gpio_intstatus
+ * The Interrupt status is reported for all Port A Data Register Bits.
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Interrupt Status Field
+ * Field : Interrupt Status Field - gpio_intstatus
+ * Interrupt status of Port A Data Register.
+ *  ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_INACT | 0x0   | Inactive
+ *  ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_ACT   | 0x1   | Active
+ * Enumerated value for register field ALT_GPIO_INTSTAT_GPIO_INTSTAT
+ * Inactive
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_INACT   0x0
+ * Active
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_ACT     0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_MSB        28
+/* The width in bits of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_WIDTH      29
+/* The mask used to set the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field value. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field value. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_INTSTAT_GPIO_INTSTAT register field. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_RESET      0x0
+/* Extracts the ALT_GPIO_INTSTAT_GPIO_INTSTAT field value from a register. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_INTSTAT_GPIO_INTSTAT register field value suitable for setting the register. */
+#define ALT_GPIO_INTSTAT_GPIO_INTSTAT_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_INTSTAT.
+struct ALT_GPIO_INTSTAT_s
+    uint32_t  gpio_intstatus : 29;  /* Interrupt Status Field */
+/* The typedef declaration for register ALT_GPIO_INTSTAT. */
+typedef volatile struct ALT_GPIO_INTSTAT_s  ALT_GPIO_INTSTAT_t;
+/* The byte offset of the ALT_GPIO_INTSTAT register from the beginning of the component. */
+#define ALT_GPIO_INTSTAT_OFST        0x40
+/* The address of the ALT_GPIO_INTSTAT register. */
+#define ALT_GPIO_INTSTAT_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTSTAT_OFST))
+ * Register : Raw Interrupt Status Register - gpio_raw_intstatus
+ * This is the Raw Interrupt Status Register for Port A Data Register. It is used
+ * with the Interrupt Mask Register to allow interrupts from the Port A Data
+ * Register.
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | Raw Interrupt Status Field
+ * Field : Raw Interrupt Status Field - gpio_raw_intstatus
+ * Raw interrupt of status of Port A Data Register (premasking bits)
+ *  ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_INACT | 0x0   | Inactive
+ *  ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_ACT   | 0x1   | Active
+ * Enumerated value for register field ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT
+ * Inactive
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_INACT   0x0
+ * Active
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_ACT     0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_MSB        28
+/* The width in bits of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_WIDTH      29
+/* The mask used to set the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field value. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field value. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_RESET      0x0
+/* Extracts the ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT field value from a register. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT register field value suitable for setting the register. */
+#define ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_RAW_INTSTAT.
+struct ALT_GPIO_RAW_INTSTAT_s
+    uint32_t  gpio_raw_intstatus : 29;  /* Raw Interrupt Status Field */
+/* The typedef declaration for register ALT_GPIO_RAW_INTSTAT. */
+typedef volatile struct ALT_GPIO_RAW_INTSTAT_s  ALT_GPIO_RAW_INTSTAT_t;
+/* The byte offset of the ALT_GPIO_RAW_INTSTAT register from the beginning of the component. */
+#define ALT_GPIO_RAW_INTSTAT_OFST        0x44
+/* The address of the ALT_GPIO_RAW_INTSTAT register. */
+#define ALT_GPIO_RAW_INTSTAT_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_RAW_INTSTAT_OFST))
+ * Register : Debounce Enable Register - gpio_debounce
+ * Debounces each IO Pin
+ * Register Layout
+ *  [28:0]  | RW     | 0x0   | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE
+ * Field : gpio_debounce
+ * Controls whether an external signal that is the source of an interrupt needs to
+ * be debounced to remove any spurious glitches. A signal must be valid for two
+ * periods of an external clock (gpio_db_clk) before it is internally processed.
+ *  ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_DIS | 0x0   | No debounce
+ *  ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_EN  | 0x1   | Enable debounce
+ * Enumerated value for register field ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE
+ * No debounce
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_DIS   0x0
+ * Enable debounce
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_MSB        28
+/* The width in bits of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_WIDTH      29
+/* The mask used to set the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field value. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field value. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_RESET      0x0
+/* Extracts the ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE field value from a register. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE register field value suitable for setting the register. */
+#define ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_DEBOUNCE.
+struct ALT_GPIO_DEBOUNCE_s
+    uint32_t  gpio_debounce : 29;  /* ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE */
+/* The typedef declaration for register ALT_GPIO_DEBOUNCE. */
+typedef volatile struct ALT_GPIO_DEBOUNCE_s  ALT_GPIO_DEBOUNCE_t;
+/* The byte offset of the ALT_GPIO_DEBOUNCE register from the beginning of the component. */
+#define ALT_GPIO_DEBOUNCE_OFST        0x48
+/* The address of the ALT_GPIO_DEBOUNCE register. */
+#define ALT_GPIO_DEBOUNCE_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_DEBOUNCE_OFST))
+ * Register : Clear Interrupt Register - gpio_porta_eoi
+ * Port A Data Register interrupt handling.
+ * Register Layout
+ *  [28:0]  | W      | 0x0   | Clears Edge Interrupts Field
+ * Field : Clears Edge Interrupts Field - gpio_porta_eoi
+ * Controls the clearing of edge type interrupts from the Port A Data Register.
+ *  ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_NOCLR | 0x0   | No interrupt clear
+ *  ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_CLR   | 0x1   | Clear interrupt
+ * Enumerated value for register field ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI
+ * No interrupt clear
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_NOCLR   0x0
+ * Clear interrupt
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_CLR     0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_MSB        28
+/* The width in bits of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_WIDTH      29
+/* The mask used to set the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field value. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field value. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_RESET      0x0
+/* Extracts the ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI field value from a register. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI register field value suitable for setting the register. */
+#define ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_SET(value) (((value) << 0) & 0x1fffffff)
+ * The struct declaration for register ALT_GPIO_PORTA_EOI.
+struct ALT_GPIO_PORTA_EOI_s
+    uint32_t  gpio_porta_eoi : 29;  /* Clears Edge Interrupts Field */
+/* The typedef declaration for register ALT_GPIO_PORTA_EOI. */
+typedef volatile struct ALT_GPIO_PORTA_EOI_s  ALT_GPIO_PORTA_EOI_t;
+/* The byte offset of the ALT_GPIO_PORTA_EOI register from the beginning of the component. */
+#define ALT_GPIO_PORTA_EOI_OFST        0x4c
+/* The address of the ALT_GPIO_PORTA_EOI register. */
+#define ALT_GPIO_PORTA_EOI_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_PORTA_EOI_OFST))
+ * Register : External Port A Register - gpio_ext_porta
+ * The external port register is used to input data to the metastability flops.
+ * Register Layout
+ *  [28:0]  | R      | 0x0   | External Port Field
+ * Field : External Port Field - gpio_ext_porta
+ * When Port A Data Register is configured as Input, then reading this location
+ * reads the values on the signals. When the data direction of Port A Data Register
+ * is set as Output, reading this location reads Port A Data Register
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_MSB        28
+/* The width in bits of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_WIDTH      29
+/* The mask used to set the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field value. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_SET_MSK    0x1fffffff
+/* The mask used to clear the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field value. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_CLR_MSK    0xe0000000
+/* The reset value of the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_RESET      0x0
+/* Extracts the ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA field value from a register. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_GET(value) (((value) & 0x1fffffff) >> 0)
+/* Produces a ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA register field value suitable for setting the register. */
+#define ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_SET(value) (((value) << 0) & 0x1fffffff)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_GPIO_EXT_PORTA.
+struct ALT_GPIO_EXT_PORTA_s
+    const uint32_t  gpio_ext_porta : 29;  /* External Port Field */
+/* The typedef declaration for register ALT_GPIO_EXT_PORTA. */
+typedef volatile struct ALT_GPIO_EXT_PORTA_s  ALT_GPIO_EXT_PORTA_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_GPIO_EXT_PORTA register from the beginning of the component. */
+#define ALT_GPIO_EXT_PORTA_OFST        0x50
+/* The address of the ALT_GPIO_EXT_PORTA register. */
+#define ALT_GPIO_EXT_PORTA_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_EXT_PORTA_OFST))
+ * Register : Synchronization Level Register - gpio_ls_sync
+ * The Synchronization level register is used to synchronize input with l4_mp_clk
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [0]    | RW     | 0x0   | Synchronization Level Field
+ *  [31:1] | ???    | 0x0   | *UNDEFINED*
+ * Field : Synchronization Level Field - gpio_ls_sync
+ * The level-sensitive interrupts is synchronized to l4_mp_clk.
+ *  ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_NOSYNC | 0x0   | No synchronization to l4_mp_clk
+ *  ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_SYNC   | 0x1   | Synchronize to l4_mp_clk
+ * Enumerated value for register field ALT_GPIO_LS_SYNC_GPIO_LS_SYNC
+ * No synchronization to l4_mp_clk
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_NOSYNC  0x0
+ * Synchronize to l4_mp_clk
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_SYNC    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_MSB        0
+/* The width in bits of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_WIDTH      1
+/* The mask used to set the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field value. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_SET_MSK    0x00000001
+/* The mask used to clear the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field value. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_RESET      0x0
+/* Extracts the ALT_GPIO_LS_SYNC_GPIO_LS_SYNC field value from a register. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_GPIO_LS_SYNC_GPIO_LS_SYNC register field value suitable for setting the register. */
+#define ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_GPIO_LS_SYNC.
+struct ALT_GPIO_LS_SYNC_s
+    uint32_t  gpio_ls_sync :  1;  /* Synchronization Level Field */
+    uint32_t               : 31;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_GPIO_LS_SYNC. */
+typedef volatile struct ALT_GPIO_LS_SYNC_s  ALT_GPIO_LS_SYNC_t;
+/* The byte offset of the ALT_GPIO_LS_SYNC register from the beginning of the component. */
+#define ALT_GPIO_LS_SYNC_OFST        0x60
+/* The address of the ALT_GPIO_LS_SYNC register. */
+#define ALT_GPIO_LS_SYNC_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_LS_SYNC_OFST))
+ * Register : ID Code Register - gpio_id_code
+ * GPIO ID code.
+ * Register Layout
+ *  [31:0] | R      | 0x0   | ID Code Field
+ * Field : ID Code Field - gpio_id_code
+ * Chip identification
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_MSB        31
+/* The width in bits of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_WIDTH      32
+/* The mask used to set the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field value. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field value. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_CLR_MSK    0x00000000
+/* The reset value of the ALT_GPIO_ID_CODE_GPIO_ID_CODE register field. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_RESET      0x0
+/* Extracts the ALT_GPIO_ID_CODE_GPIO_ID_CODE field value from a register. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_GPIO_ID_CODE_GPIO_ID_CODE register field value suitable for setting the register. */
+#define ALT_GPIO_ID_CODE_GPIO_ID_CODE_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_GPIO_ID_CODE.
+struct ALT_GPIO_ID_CODE_s
+    const uint32_t  gpio_id_code : 32;  /* ID Code Field */
+/* The typedef declaration for register ALT_GPIO_ID_CODE. */
+typedef volatile struct ALT_GPIO_ID_CODE_s  ALT_GPIO_ID_CODE_t;
+/* The byte offset of the ALT_GPIO_ID_CODE register from the beginning of the component. */
+#define ALT_GPIO_ID_CODE_OFST        0x64
+/* The address of the ALT_GPIO_ID_CODE register. */
+#define ALT_GPIO_ID_CODE_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_ID_CODE_OFST))
+ * Register : GPIO Version Register - gpio_ver_id_code
+ * GPIO Component Version
+ * Register Layout
+ *  [31:0] | R      | 0x3230382a | ASCII Component Version Field
+ * Field : ASCII Component Version Field - gpio_ver_id_code
+ * ASCII value for each number in the version, followed by *. For example.
+ * 32_30_31_2A represents the version 2.01
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_MSB        31
+/* The width in bits of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_WIDTH      32
+/* The mask used to set the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field value. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field value. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_CLR_MSK    0x00000000
+/* The reset value of the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_RESET      0x3230382a
+/* Extracts the ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE field value from a register. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE register field value suitable for setting the register. */
+#define ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_GPIO_VER_ID_CODE.
+struct ALT_GPIO_VER_ID_CODE_s
+    const uint32_t  gpio_ver_id_code : 32;  /* ASCII Component Version Field */
+/* The typedef declaration for register ALT_GPIO_VER_ID_CODE. */
+typedef volatile struct ALT_GPIO_VER_ID_CODE_s  ALT_GPIO_VER_ID_CODE_t;
+/* The byte offset of the ALT_GPIO_VER_ID_CODE register from the beginning of the component. */
+#define ALT_GPIO_VER_ID_CODE_OFST        0x6c
+/* The address of the ALT_GPIO_VER_ID_CODE register. */
+#define ALT_GPIO_VER_ID_CODE_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_VER_ID_CODE_OFST))
+ * Register : Configuration Register 2 - gpio_config_reg2
+ * Specifies the bit width of port A.
+ * Register Layout
+ *  [4:0]   | R      | 0x1c  | Port A Width (less 1)
+ *  [9:5]   | R      | 0x7   | Port B Width (less 1)
+ *  [14:10] | R      | 0x7   | Port C Width (less 1)
+ *  [19:15] | R      | 0x7   | Port D Width (less 1)
+ *  [31:20] | ???    | 0x0   | *UNDEFINED*
+ * Field : Port A Width (less 1) - encoded_id_pwidth_a
+ * Specifies the width of GPIO Port A. The value 28 represents the 29-bit width
+ * less one.
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE8BITS  | 0x7   | Width (less 1) of 8 bits
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE29BITS | 0x1c  | Width (less 1) of 29 bits
+ * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A
+ * Width (less 1) of 8 bits
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE8BITS   0x7
+ * Width (less 1) of 29 bits
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE29BITS  0x1c
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_MSB        4
+/* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_WIDTH      5
+/* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_SET_MSK    0x0000001f
+/* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_CLR_MSK    0xffffffe0
+/* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_RESET      0x1c
+/* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A field value from a register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_GET(value) (((value) & 0x0000001f) >> 0)
+/* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_SET(value) (((value) << 0) & 0x0000001f)
+ * Field : Port B Width (less 1) - encoded_id_pwidth_b
+ * Specifies the width of GPIO Port B. Ignored because there is no Port B in the
+ * GPIO.
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE8BITS  | 0x7   | Width (less 1) of 8 bits
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE29BITS | 0x1c  | Width (less 1) of 29 bits
+ * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE8BITS   0x7
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE29BITS  0x1c
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_MSB        9
+/* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_WIDTH      5
+/* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_SET_MSK    0x000003e0
+/* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_CLR_MSK    0xfffffc1f
+/* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_RESET      0x7
+/* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B field value from a register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_GET(value) (((value) & 0x000003e0) >> 5)
+/* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_SET(value) (((value) << 5) & 0x000003e0)
+ * Field : Port C Width (less 1) - encoded_id_pwidth_c
+ * Specifies the width of GPIO Port C. Ignored because there is no Port C in the
+ * GPIO.
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE8BITS  | 0x7   | Width (less 1) of 8 bits
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE29BITS | 0x1c  | Width (less 1) of 29 bits
+ * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE8BITS   0x7
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE29BITS  0x1c
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_MSB        14
+/* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_WIDTH      5
+/* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_SET_MSK    0x00007c00
+/* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_CLR_MSK    0xffff83ff
+/* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_RESET      0x7
+/* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C field value from a register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_GET(value) (((value) & 0x00007c00) >> 10)
+/* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_SET(value) (((value) << 10) & 0x00007c00)
+ * Field : Port D Width (less 1) - encoded_id_pwidth_d
+ * Specifies the width of GPIO Port D. Ignored because there is no Port D in the
+ * GPIO.
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE8BITS  | 0x7   | Width (less 1) of 8 bits
+ *  ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE29BITS | 0x1c  | Width (less 1) of 29 bits
+ * Enumerated value for register field ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE8BITS   0x7
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE29BITS  0x1c
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_MSB        19
+/* The width in bits of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_WIDTH      5
+/* The mask used to set the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_SET_MSK    0x000f8000
+/* The mask used to clear the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field value. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_CLR_MSK    0xfff07fff
+/* The reset value of the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_RESET      0x7
+/* Extracts the ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D field value from a register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_GET(value) (((value) & 0x000f8000) >> 15)
+/* Produces a ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_SET(value) (((value) << 15) & 0x000f8000)
+ * The struct declaration for register ALT_GPIO_CFG_REG2.
+struct ALT_GPIO_CFG_REG2_s
+    const uint32_t  encoded_id_pwidth_a :  5;  /* Port A Width (less 1) */
+    const uint32_t  encoded_id_pwidth_b :  5;  /* Port B Width (less 1) */
+    const uint32_t  encoded_id_pwidth_c :  5;  /* Port C Width (less 1) */
+    const uint32_t  encoded_id_pwidth_d :  5;  /* Port D Width (less 1) */
+    uint32_t                            : 12;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_GPIO_CFG_REG2. */
+typedef volatile struct ALT_GPIO_CFG_REG2_s  ALT_GPIO_CFG_REG2_t;
+/* The byte offset of the ALT_GPIO_CFG_REG2 register from the beginning of the component. */
+#define ALT_GPIO_CFG_REG2_OFST        0x70
+/* The address of the ALT_GPIO_CFG_REG2 register. */
+#define ALT_GPIO_CFG_REG2_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_CFG_REG2_OFST))
+ * Register : Configuration Register 1 - gpio_config_reg1
+ * Reports settings of various GPIO configuration parameters
+ * Register Layout
+ *  [1:0]   | R      | 0x2   | APB DATA WIDTH
+ *  [3:2]   | R      | 0x0   | NUM PORTS
+ *  [4]     | R      | 0x1   | PORT A SINGLE CTL
+ *  [5]     | R      | 0x1   | PORT B SINGLE CTL
+ *  [6]     | R      | 0x1   | PORT C SINGLE CTL
+ *  [7]     | R      | 0x1   | PORT D SINGLE CTL
+ *  [8]     | R      | 0x0   | HW PORTA
+ *  [11:9]  | ???    | 0x0   | *UNDEFINED*
+ *  [12]    | R      | 0x1   | Port A Interrupt Field
+ *  [13]    | R      | 0x1   | Debounce Field
+ *  [14]    | R      | 0x1   | Encoded GPIO Parameters Available
+ *  [15]    | R      | 0x1   | ID Field
+ *  [20:16] | R      | 0x1f  | Encoded ID Width Field
+ *  [31:21] | ???    | 0x0   | *UNDEFINED*
+ * Field : APB DATA WIDTH - apb_data_width
+ * Fixed to support an ABP data bus width of 32-bits.
+ *  ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_E_WIDTH32BITS | 0x2   | APB Data Width = 32-bits
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_APB_DATA_WIDTH
+ * APB Data Width = 32-bits
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_E_WIDTH32BITS  0x2
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_MSB        1
+/* The width in bits of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_WIDTH      2
+/* The mask used to set the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field value. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_SET_MSK    0x00000003
+/* The mask used to clear the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field value. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_RESET      0x2
+/* Extracts the ALT_GPIO_CFG_REG1_APB_DATA_WIDTH field value from a register. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_GPIO_CFG_REG1_APB_DATA_WIDTH register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_SET(value) (((value) << 0) & 0x00000003)
+ * Field : NUM PORTS - num_ports
+ * The value of this register is fixed at one port (Port A).
+ *  ALT_GPIO_CFG_REG1_NUM_PORTS_E_ONEPORTA | 0x0   | Number of GPIO Ports = 1
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_NUM_PORTS
+ * Number of GPIO Ports = 1
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_E_ONEPORTA  0x0
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_MSB        3
+/* The width in bits of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_WIDTH      2
+/* The mask used to set the ALT_GPIO_CFG_REG1_NUM_PORTS register field value. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_SET_MSK    0x0000000c
+/* The mask used to clear the ALT_GPIO_CFG_REG1_NUM_PORTS register field value. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_CLR_MSK    0xfffffff3
+/* The reset value of the ALT_GPIO_CFG_REG1_NUM_PORTS register field. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_RESET      0x0
+/* Extracts the ALT_GPIO_CFG_REG1_NUM_PORTS field value from a register. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_GET(value) (((value) & 0x0000000c) >> 2)
+/* Produces a ALT_GPIO_CFG_REG1_NUM_PORTS register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_NUM_PORTS_SET(value) (((value) << 2) & 0x0000000c)
+ * Field : PORT A SINGLE CTL - porta_single_ctl
+ * Indicates the mode of operation of Port A to be software controlled only.
+ *  ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_E_SOFTCTLONLY | 0x1   | Software Enabled Individual Port Control
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL
+ * Software Enabled Individual Port Control
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_E_SOFTCTLONLY    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_MSB        4
+/* The width in bits of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_SET_MSK    0x00000010
+/* The mask used to clear the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_CLR_MSK    0xffffffef
+/* The reset value of the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL field value from a register. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_SET(value) (((value) << 4) & 0x00000010)
+ * Field : PORT B SINGLE CTL - portb_single_ctl
+ * Indicates the mode of operation of Port B to be software controlled only.
+ * Ignored because there is no Port B in the GPIO.
+ *  ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_E_SOFTCTLONLY | 0x1   | Software Enabled Individual Port Control
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_E_SOFTCTLONLY    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_MSB        5
+/* The width in bits of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_SET_MSK    0x00000020
+/* The mask used to clear the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL field value from a register. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_SET(value) (((value) << 5) & 0x00000020)
+ * Field : PORT C SINGLE CTL - portc_single_ctl
+ * Indicates the mode of operation of Port C to be software controlled only.
+ * Ignored because there is no Port C in the GPIO.
+ *  ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_E_SOFTCTLONLY | 0x1   | Software Enabled Individual Port Control
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_E_SOFTCTLONLY    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_MSB        6
+/* The width in bits of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_SET_MSK    0x00000040
+/* The mask used to clear the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL field value from a register. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_SET(value) (((value) << 6) & 0x00000040)
+ * Field : PORT D SINGLE CTL - portd_single_ctl
+ * Indicates the mode of operation of Port D to be software controlled only.
+ * Ignored because there is no Port D in the GPIO.
+ *  ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_E_SOFTCTLONLY | 0x1   | Software Enabled Individual Port Control
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_E_SOFTCTLONLY    0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_MSB        7
+/* The width in bits of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_SET_MSK    0x00000080
+/* The mask used to clear the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field value. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL field value from a register. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_SET(value) (((value) << 7) & 0x00000080)
+ * Field : HW PORTA - hw_porta
+ * The value is fixed to enable Port A configuration to be controlled by software
+ * only.
+ * Field Enumeration Values:
+ *  Enum                                     | Value | Description
+ *  ALT_GPIO_CFG_REG1_HW_PORTA_E_PORTANOHARD | 0x0   | Software Configuration Control Enabled
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_HW_PORTA
+ * Software Configuration Control Enabled
+#define ALT_GPIO_CFG_REG1_HW_PORTA_E_PORTANOHARD    0x0
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_MSB        8
+/* The width in bits of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_HW_PORTA register field value. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_SET_MSK    0x00000100
+/* The mask used to clear the ALT_GPIO_CFG_REG1_HW_PORTA register field value. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_GPIO_CFG_REG1_HW_PORTA register field. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_RESET      0x0
+/* Extracts the ALT_GPIO_CFG_REG1_HW_PORTA field value from a register. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_GPIO_CFG_REG1_HW_PORTA register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_HW_PORTA_SET(value) (((value) << 8) & 0x00000100)
+ * Field : Port A Interrupt Field - porta_intr
+ * The value of this field is fixed to allow interrupts on Port A.
+ *  ALT_GPIO_CFG_REG1_PORTA_INTR_E_PORTAINTERR | 0x1   | Port A Interrupts Enabled
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_PORTA_INTR
+ * Port A Interrupts Enabled
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_E_PORTAINTERR  0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_MSB        12
+/* The width in bits of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_PORTA_INTR register field value. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_SET_MSK    0x00001000
+/* The mask used to clear the ALT_GPIO_CFG_REG1_PORTA_INTR register field value. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_CLR_MSK    0xffffefff
+/* The reset value of the ALT_GPIO_CFG_REG1_PORTA_INTR register field. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_PORTA_INTR field value from a register. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_GPIO_CFG_REG1_PORTA_INTR register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_PORTA_INTR_SET(value) (((value) << 12) & 0x00001000)
+ * Field : Debounce Field - debounce
+ * The value of this field is fixed to allow debouncing of the Port A signals.
+ *  ALT_GPIO_CFG_REG1_DEBOUNCE_E_DEBOUNCEA | 0x1   | Debounce is Enabled
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_DEBOUNCE
+ * Debounce is Enabled
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_E_DEBOUNCEA  0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_MSB        13
+/* The width in bits of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_DEBOUNCE register field value. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_SET_MSK    0x00002000
+/* The mask used to clear the ALT_GPIO_CFG_REG1_DEBOUNCE register field value. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_GPIO_CFG_REG1_DEBOUNCE register field. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_DEBOUNCE field value from a register. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_GPIO_CFG_REG1_DEBOUNCE register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_DEBOUNCE_SET(value) (((value) << 13) & 0x00002000)
+ * Field : Encoded GPIO Parameters Available - add_encoded_params
+ * Fixed to allow the indentification of the Designware IP component.
+ *  ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_E_ADDENCPARAMS | 0x1   | Enable IP indentification
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS
+ * Enable IP indentification
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_E_ADDENCPARAMS 0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_MSB        14
+/* The width in bits of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field value. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_SET_MSK    0x00004000
+/* The mask used to clear the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field value. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS field value from a register. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_SET(value) (((value) << 14) & 0x00004000)
+ * Field : ID Field - gpio_id
+ * Provides an ID code value
+ *  ALT_GPIO_CFG_REG1_GPIO_ID_E_IDCODE | 0x1   | GPIO ID Code
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_GPIO_ID
+ * GPIO ID Code
+#define ALT_GPIO_CFG_REG1_GPIO_ID_E_IDCODE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_MSB        15
+/* The width in bits of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_WIDTH      1
+/* The mask used to set the ALT_GPIO_CFG_REG1_GPIO_ID register field value. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_SET_MSK    0x00008000
+/* The mask used to clear the ALT_GPIO_CFG_REG1_GPIO_ID register field value. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_CLR_MSK    0xffff7fff
+/* The reset value of the ALT_GPIO_CFG_REG1_GPIO_ID register field. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_RESET      0x1
+/* Extracts the ALT_GPIO_CFG_REG1_GPIO_ID field value from a register. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_GET(value) (((value) & 0x00008000) >> 15)
+/* Produces a ALT_GPIO_CFG_REG1_GPIO_ID register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_GPIO_ID_SET(value) (((value) << 15) & 0x00008000)
+ * Field : Encoded ID Width Field - encoded_id_width
+ * This value is fixed at 32 bits.
+ *  ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_E_ENCIDWIDTH | 0x1f  | Width of ID Field
+ * Enumerated value for register field ALT_GPIO_CFG_REG1_ENC_ID_WIDTH
+ * Width of ID Field
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_E_ENCIDWIDTH 0x1f
+/* The Least Significant Bit (LSB) position of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_MSB        20
+/* The width in bits of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_WIDTH      5
+/* The mask used to set the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field value. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_SET_MSK    0x001f0000
+/* The mask used to clear the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field value. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_CLR_MSK    0xffe0ffff
+/* The reset value of the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_RESET      0x1f
+/* Extracts the ALT_GPIO_CFG_REG1_ENC_ID_WIDTH field value from a register. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_GET(value) (((value) & 0x001f0000) >> 16)
+/* Produces a ALT_GPIO_CFG_REG1_ENC_ID_WIDTH register field value suitable for setting the register. */
+#define ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_SET(value) (((value) << 16) & 0x001f0000)
+ * The struct declaration for register ALT_GPIO_CFG_REG1.
+struct ALT_GPIO_CFG_REG1_s
+    const uint32_t  apb_data_width     :  2;  /* APB DATA WIDTH */
+    const uint32_t  num_ports          :  2;  /* NUM PORTS */
+    const uint32_t  porta_single_ctl   :  1;  /* PORT A SINGLE CTL */
+    const uint32_t  portb_single_ctl   :  1;  /* PORT B SINGLE CTL */
+    const uint32_t  portc_single_ctl   :  1;  /* PORT C SINGLE CTL */
+    const uint32_t  portd_single_ctl   :  1;  /* PORT D SINGLE CTL */
+    const uint32_t  hw_porta           :  1;  /* HW PORTA */
+    uint32_t                           :  3;  /* *UNDEFINED* */
+    const uint32_t  porta_intr         :  1;  /* Port A Interrupt Field */
+    const uint32_t  debounce           :  1;  /* Debounce Field */
+    const uint32_t  add_encoded_params :  1;  /* Encoded GPIO Parameters Available */
+    const uint32_t  gpio_id            :  1;  /* ID Field */
+    const uint32_t  encoded_id_width   :  5;  /* Encoded ID Width Field */
+    uint32_t                           : 11;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_GPIO_CFG_REG1. */
+typedef volatile struct ALT_GPIO_CFG_REG1_s  ALT_GPIO_CFG_REG1_t;
+/* The byte offset of the ALT_GPIO_CFG_REG1 register from the beginning of the component. */
+#define ALT_GPIO_CFG_REG1_OFST        0x74
+/* The address of the ALT_GPIO_CFG_REG1 register. */
+#define ALT_GPIO_CFG_REG1_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_CFG_REG1_OFST))
+ * The struct declaration for register group ALT_GPIO.
+struct ALT_GPIO_s
+    volatile ALT_GPIO_SWPORTA_DR_t     gpio_swporta_dr;     /* ALT_GPIO_SWPORTA_DR */
+    volatile ALT_GPIO_SWPORTA_DDR_t    gpio_swporta_ddr;    /* ALT_GPIO_SWPORTA_DDR */
+    volatile uint32_t                  _pad_0x8_0x2f[10];   /* *UNDEFINED* */
+    volatile ALT_GPIO_INTEN_t          gpio_inten;          /* ALT_GPIO_INTEN */
+    volatile ALT_GPIO_INTMSK_t         gpio_intmask;        /* ALT_GPIO_INTMSK */
+    volatile ALT_GPIO_INTTYPE_LEVEL_t  gpio_inttype_level;  /* ALT_GPIO_INTTYPE_LEVEL */
+    volatile ALT_GPIO_INT_POL_t        gpio_int_polarity;   /* ALT_GPIO_INT_POL */
+    volatile ALT_GPIO_INTSTAT_t        gpio_intstatus;      /* ALT_GPIO_INTSTAT */
+    volatile ALT_GPIO_RAW_INTSTAT_t    gpio_raw_intstatus;  /* ALT_GPIO_RAW_INTSTAT */
+    volatile ALT_GPIO_DEBOUNCE_t       gpio_debounce;       /* ALT_GPIO_DEBOUNCE */
+    volatile ALT_GPIO_PORTA_EOI_t      gpio_porta_eoi;      /* ALT_GPIO_PORTA_EOI */
+    volatile ALT_GPIO_EXT_PORTA_t      gpio_ext_porta;      /* ALT_GPIO_EXT_PORTA */
+    volatile uint32_t                  _pad_0x54_0x5f[3];   /* *UNDEFINED* */
+    volatile ALT_GPIO_LS_SYNC_t        gpio_ls_sync;        /* ALT_GPIO_LS_SYNC */
+    volatile ALT_GPIO_ID_CODE_t        gpio_id_code;        /* ALT_GPIO_ID_CODE */
+    volatile uint32_t                  _pad_0x68_0x6b;      /* *UNDEFINED* */
+    volatile ALT_GPIO_VER_ID_CODE_t    gpio_ver_id_code;    /* ALT_GPIO_VER_ID_CODE */
+    volatile ALT_GPIO_CFG_REG2_t       gpio_config_reg2;    /* ALT_GPIO_CFG_REG2 */
+    volatile ALT_GPIO_CFG_REG1_t       gpio_config_reg1;    /* ALT_GPIO_CFG_REG1 */
+    volatile uint32_t                  _pad_0x78_0x80[2];   /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_GPIO. */
+typedef volatile struct ALT_GPIO_s  ALT_GPIO_t;
+/* The struct declaration for the raw register contents of register group ALT_GPIO. */
+struct ALT_GPIO_raw_s
+    volatile uint32_t  gpio_swporta_dr;     /* ALT_GPIO_SWPORTA_DR */
+    volatile uint32_t  gpio_swporta_ddr;    /* ALT_GPIO_SWPORTA_DDR */
+    volatile uint32_t  gpio_inten;          /* ALT_GPIO_INTEN */
+    volatile uint32_t  gpio_intmask;        /* ALT_GPIO_INTMSK */
+    volatile uint32_t  gpio_inttype_level;  /* ALT_GPIO_INTTYPE_LEVEL */
+    volatile uint32_t  gpio_int_polarity;   /* ALT_GPIO_INT_POL */
+    volatile uint32_t  gpio_intstatus;      /* ALT_GPIO_INTSTAT */
+    volatile uint32_t  gpio_raw_intstatus;  /* ALT_GPIO_RAW_INTSTAT */
+    volatile uint32_t  gpio_debounce;       /* ALT_GPIO_DEBOUNCE */
+    volatile uint32_t  gpio_porta_eoi;      /* ALT_GPIO_PORTA_EOI */
+    volatile uint32_t  gpio_ext_porta;      /* ALT_GPIO_EXT_PORTA */
+    volatile uint32_t  gpio_ls_sync;        /* ALT_GPIO_LS_SYNC */
+    volatile uint32_t  gpio_id_code;        /* ALT_GPIO_ID_CODE */
+    volatile uint32_t  gpio_ver_id_code;    /* ALT_GPIO_VER_ID_CODE */
+    volatile uint32_t  gpio_config_reg2;    /* ALT_GPIO_CFG_REG2 */
+    volatile uint32_t  gpio_config_reg1;    /* ALT_GPIO_CFG_REG1 */
+/* The typedef declaration for the raw register contents of register group ALT_GPIO. */
+typedef volatile struct ALT_GPIO_raw_s  ALT_GPIO_raw_t;
+#ifdef __cplusplus
+#endif  /* __cplusplus */
+#endif  /* __ALTERA_ALT_GPIO_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_l3.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_l3.h
new file mode 100644
index 0000000..12e6f21
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_l3.h
@@ -0,0 +1,6299 @@
+* Copyright 2013 Altera Corporation. All Rights Reserved.                      *
+* Redistribution and use in source and binary forms, with or without           *
+* modification, are permitted provided that the following conditions are met:  *
+* 1. Redistributions of source code must retain the above copyright notice,    *
+*    this list of conditions and the following disclaimer.                     *
+* 2. Redistributions in binary form must reproduce the above copyright notice, *
+*    this list of conditions and the following disclaimer in the documentation *
+*    and/or other materials provided with the distribution.                    *
+* 3. The name of the author may not be used to endorse or promote products     *
+*    derived from this software without specific prior written permission.     *
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO  *
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,       *
+* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
+* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;  *
+* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,     *
+* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR      *
+* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF       *
+* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                                   *
+/* Altera - ALT_L3 */
+#ifndef __ALTERA_ALT_L3_H__
+#define __ALTERA_ALT_L3_H__
+#ifdef __cplusplus
+extern "C"
+ * Component : L3 (NIC-301) GPV Registers - ALT_L3
+ * L3 (NIC-301) GPV Registers
+ * Registers to control L3 interconnect settings
+ * Register : Remap - remap
+ * The L3 interconnect has separate address maps for the various L3 Masters.
+ * Generally, the addresses are the same for most masters. However, the sparse
+ * interconnect of the L3 switch causes some masters to have holes in their memory
+ * maps. The remap bits are not mutually exclusive. Each bit can be set
+ * independently and in combinations. Priority for the bits is determined by the
+ * bit offset: lower offset bits take precedence over higher offset bits.
+ * Register Layout
+ *  [0]    | W      | 0x0   | MPU at 0x0
+ *  [1]    | W      | 0x0   | Non-MPU at 0x0
+ *  [2]    | ???    | 0x0   | *UNDEFINED*
+ *  [3]    | W      | 0x0   | HPS2FPGA AXI Bridge Visibility
+ *  [4]    | W      | 0x0   | LWHPS2FPGA AXI Bridge Visibility
+ *  [31:5] | ???    | 0x0   | *UNDEFINED*
+ * Field : MPU at 0x0 - mpuzero
+ * Controls whether address 0x0 for the MPU L3 master is mapped to the Boot ROM or
+ * On-chip RAM.  This field only has an effect on the MPU L3 master.
+ *  ALT_L3_REMAP_MPUZERO_E_BOOTROM | 0x0   | Maps the Boot ROM to address 0x0 for the MPU L3
+ * :                               |       | master. Note that the Boot ROM is also always
+ * :                               |       | mapped to address 0xfffd_0000 for the MPU L3
+ * :                               |       | master independent of this field's value.
+ *  ALT_L3_REMAP_MPUZERO_E_OCRAM   | 0x1   | Maps the On-chip RAM to address 0x0 for the MPU
+ * :                               |       | L3 master. Note that the On-chip RAM is also
+ * :                               |       | always mapped to address 0xffff_0000 for the MPU
+ * :                               |       | L3 master independent of this field's value.
+ * Field Access Macros:
+ * Enumerated value for register field ALT_L3_REMAP_MPUZERO
+ * Maps the Boot ROM to address 0x0 for the MPU L3 master. Note that the Boot ROM
+ * is also always mapped to address 0xfffd_0000 for the MPU L3 master independent
+ * of this field's value.
+#define ALT_L3_REMAP_MPUZERO_E_BOOTROM  0x0
+ * Maps the On-chip RAM to address 0x0 for the MPU L3 master. Note that the On-chip
+ * RAM is also always mapped to address 0xffff_0000 for the MPU L3 master
+ * independent of this field's value.
+#define ALT_L3_REMAP_MPUZERO_E_OCRAM    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_MPUZERO register field. */
+#define ALT_L3_REMAP_MPUZERO_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_MPUZERO register field. */
+#define ALT_L3_REMAP_MPUZERO_MSB        0
+/* The width in bits of the ALT_L3_REMAP_MPUZERO register field. */
+#define ALT_L3_REMAP_MPUZERO_WIDTH      1
+/* The mask used to set the ALT_L3_REMAP_MPUZERO register field value. */
+#define ALT_L3_REMAP_MPUZERO_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_REMAP_MPUZERO register field value. */
+#define ALT_L3_REMAP_MPUZERO_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_REMAP_MPUZERO register field. */
+#define ALT_L3_REMAP_MPUZERO_RESET      0x0
+/* Extracts the ALT_L3_REMAP_MPUZERO field value from a register. */
+#define ALT_L3_REMAP_MPUZERO_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_REMAP_MPUZERO register field value suitable for setting the register. */
+#define ALT_L3_REMAP_MPUZERO_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Non-MPU at 0x0 - nonmpuzero
+ * Controls whether address 0x0 for the non-MPU L3 masters is mapped to the SDRAM
+ * or On-chip RAM.  This field only has an effect on the non-MPU L3 masters. The
+ * non-MPU L3 masters are the DMA controllers (standalone and those built-in to
+ * peripherals), the FPGA2HPS AXI Bridge, and the DAP.
+ *  ALT_L3_REMAP_NONMPUZERO_E_SDRAM | 0x0   | Maps the SDRAM to address 0x0 for the non-MPU L3
+ * :                                |       | masters.
+ *  ALT_L3_REMAP_NONMPUZERO_E_OCRAM | 0x1   | Maps the On-chip RAM to address 0x0 for the non-
+ * :                                |       | MPU L3 masters. Note that the On-chip RAM is
+ * :                                |       | also always mapped to address 0xffff_0000 for
+ * :                                |       | the non-MPU L3 masters independent of this
+ * :                                |       | field's value.
+ * Enumerated value for register field ALT_L3_REMAP_NONMPUZERO
+ * Maps the SDRAM to address 0x0 for the non-MPU L3 masters.
+#define ALT_L3_REMAP_NONMPUZERO_E_SDRAM 0x0
+ * Maps the On-chip RAM to address 0x0 for the non-MPU L3 masters. Note that the
+ * On-chip RAM is also always mapped to address 0xffff_0000 for the non-MPU L3
+ * masters independent of this field's value.
+#define ALT_L3_REMAP_NONMPUZERO_E_OCRAM 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_NONMPUZERO register field. */
+#define ALT_L3_REMAP_NONMPUZERO_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_NONMPUZERO register field. */
+#define ALT_L3_REMAP_NONMPUZERO_MSB        1
+/* The width in bits of the ALT_L3_REMAP_NONMPUZERO register field. */
+#define ALT_L3_REMAP_NONMPUZERO_WIDTH      1
+/* The mask used to set the ALT_L3_REMAP_NONMPUZERO register field value. */
+#define ALT_L3_REMAP_NONMPUZERO_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_REMAP_NONMPUZERO register field value. */
+#define ALT_L3_REMAP_NONMPUZERO_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_REMAP_NONMPUZERO register field. */
+#define ALT_L3_REMAP_NONMPUZERO_RESET      0x0
+/* Extracts the ALT_L3_REMAP_NONMPUZERO field value from a register. */
+#define ALT_L3_REMAP_NONMPUZERO_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_REMAP_NONMPUZERO register field value suitable for setting the register. */
+#define ALT_L3_REMAP_NONMPUZERO_SET(value) (((value) << 1) & 0x00000002)
+ * Field : HPS2FPGA AXI Bridge Visibility - hps2fpga
+ * Controls whether the HPS2FPGA AXI Bridge is visible to L3 masters or not.
+ *  ALT_L3_REMAP_H2F_E_INVISIBLE | 0x0   | The HPS2FPGA AXI Bridge is not visible to L3
+ * :                             |       | masters. Accesses to the associated address
+ * :                             |       | range return an AXI decode error to the master.
+ *  ALT_L3_REMAP_H2F_E_VISIBLE   | 0x1   | The HPS2FPGA AXI Bridge is visible to L3
+ * :                             |       | masters.
+ * Enumerated value for register field ALT_L3_REMAP_H2F
+ * The HPS2FPGA AXI Bridge is not visible to L3 masters. Accesses to the associated
+ * address range return an AXI decode error to the master.
+#define ALT_L3_REMAP_H2F_E_INVISIBLE    0x0
+ * The HPS2FPGA AXI Bridge is visible to L3 masters.
+#define ALT_L3_REMAP_H2F_E_VISIBLE      0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_H2F register field. */
+#define ALT_L3_REMAP_H2F_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_H2F register field. */
+#define ALT_L3_REMAP_H2F_MSB        3
+/* The width in bits of the ALT_L3_REMAP_H2F register field. */
+#define ALT_L3_REMAP_H2F_WIDTH      1
+/* The mask used to set the ALT_L3_REMAP_H2F register field value. */
+#define ALT_L3_REMAP_H2F_SET_MSK    0x00000008
+/* The mask used to clear the ALT_L3_REMAP_H2F register field value. */
+#define ALT_L3_REMAP_H2F_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_L3_REMAP_H2F register field. */
+#define ALT_L3_REMAP_H2F_RESET      0x0
+/* Extracts the ALT_L3_REMAP_H2F field value from a register. */
+#define ALT_L3_REMAP_H2F_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_L3_REMAP_H2F register field value suitable for setting the register. */
+#define ALT_L3_REMAP_H2F_SET(value) (((value) << 3) & 0x00000008)
+ * Field : LWHPS2FPGA AXI Bridge Visibility - lwhps2fpga
+ * Controls whether the Lightweight HPS2FPGA AXI Bridge is visible to L3 masters or
+ * not.
+ *  ALT_L3_REMAP_LWH2F_E_INVISIBLE | 0x0   | The LWHPS2FPGA AXI Bridge is not visible to L3
+ *  ALT_L3_REMAP_LWH2F_E_VISIBLE   | 0x1   | The LWHPS2FPGA AXI Bridge is visible to L3
+ * :                               |       | masters.
+ * Enumerated value for register field ALT_L3_REMAP_LWH2F
+ * The LWHPS2FPGA AXI Bridge is not visible to L3 masters. Accesses to the
+ * associated address range return an AXI decode error to the master.
+#define ALT_L3_REMAP_LWH2F_E_INVISIBLE  0x0
+ * The LWHPS2FPGA AXI Bridge is visible to L3 masters.
+#define ALT_L3_REMAP_LWH2F_E_VISIBLE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_LWH2F register field. */
+#define ALT_L3_REMAP_LWH2F_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_LWH2F register field. */
+#define ALT_L3_REMAP_LWH2F_MSB        4
+/* The width in bits of the ALT_L3_REMAP_LWH2F register field. */
+#define ALT_L3_REMAP_LWH2F_WIDTH      1
+/* The mask used to set the ALT_L3_REMAP_LWH2F register field value. */
+#define ALT_L3_REMAP_LWH2F_SET_MSK    0x00000010
+/* The mask used to clear the ALT_L3_REMAP_LWH2F register field value. */
+#define ALT_L3_REMAP_LWH2F_CLR_MSK    0xffffffef
+/* The reset value of the ALT_L3_REMAP_LWH2F register field. */
+#define ALT_L3_REMAP_LWH2F_RESET      0x0
+/* Extracts the ALT_L3_REMAP_LWH2F field value from a register. */
+#define ALT_L3_REMAP_LWH2F_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_L3_REMAP_LWH2F register field value suitable for setting the register. */
+#define ALT_L3_REMAP_LWH2F_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_L3_REMAP.
+struct ALT_L3_REMAP_s
+    uint32_t  mpuzero    :  1;  /* MPU at 0x0 */
+    uint32_t  nonmpuzero :  1;  /* Non-MPU at 0x0 */
+    uint32_t             :  1;  /* *UNDEFINED* */
+    uint32_t  hps2fpga   :  1;  /* HPS2FPGA AXI Bridge Visibility */
+    uint32_t  lwhps2fpga :  1;  /* LWHPS2FPGA AXI Bridge Visibility */
+    uint32_t             : 27;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_REMAP. */
+typedef volatile struct ALT_L3_REMAP_s  ALT_L3_REMAP_t;
+/* The byte offset of the ALT_L3_REMAP register from the beginning of the component. */
+#define ALT_L3_REMAP_OFST        0x0
+ * Register Group : Security Register Group - ALT_L3_SECGRP
+ * Security Register Group
+ * Registers that control slave security.
+ * Register : L4 Main Peripherals Security - l4main
+ * Controls security settings for L4 Main peripherals.
+ * Register Layout
+ *  [0]    | W      | 0x0   | SPI Slave 0 Security
+ *  [1]    | W      | 0x0   | SPI Slave 1 Security
+ *  [2]    | W      | 0x0   | DMA Secure Security
+ *  [3]    | W      | 0x0   | DMA Non-secure Security
+ *  [31:4] | ???    | 0x0   | *UNDEFINED*
+ * Field : SPI Slave 0 Security - spis0
+ * Controls whether secure or non-secure masters can access the SPI Slave 0 slave.
+ *  ALT_L3_SEC_L4MAIN_SPIS0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4MAIN_SPIS0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * :                                    |       | non-secure masters.
+ * Enumerated value for register field ALT_L3_SEC_L4MAIN_SPIS0
+ * The slave can only be accessed by a secure master.
+#define ALT_L3_SEC_L4MAIN_SPIS0_E_SECURE    0x0
+ * The slave can only be accessed by a secure or non-secure masters.
+#define ALT_L3_SEC_L4MAIN_SPIS0_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_MSB        0
+/* The width in bits of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MAIN_SPIS0 register field value. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_L4MAIN_SPIS0 register field value. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MAIN_SPIS0 field value from a register. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_L4MAIN_SPIS0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MAIN_SPIS0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : SPI Slave 1 Security - spis1
+ * Controls whether secure or non-secure masters can access the SPI Slave 1 slave.
+ *  ALT_L3_SEC_L4MAIN_SPIS1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4MAIN_SPIS1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MAIN_SPIS1
+#define ALT_L3_SEC_L4MAIN_SPIS1_E_SECURE    0x0
+#define ALT_L3_SEC_L4MAIN_SPIS1_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_MSB        1
+/* The width in bits of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MAIN_SPIS1 register field value. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_SEC_L4MAIN_SPIS1 register field value. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MAIN_SPIS1 field value from a register. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_SEC_L4MAIN_SPIS1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MAIN_SPIS1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : DMA Secure Security - dmasecure
+ * Controls whether secure or non-secure masters can access the DMA Secure slave.
+ *  ALT_L3_SEC_L4MAIN_DMASECURE_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                        |       | master.
+ *  ALT_L3_SEC_L4MAIN_DMASECURE_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MAIN_DMASECURE
+#define ALT_L3_SEC_L4MAIN_DMASECURE_E_SECURE    0x0
+#define ALT_L3_SEC_L4MAIN_DMASECURE_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_MSB        2
+/* The width in bits of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MAIN_DMASECURE register field value. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_SET_MSK    0x00000004
+/* The mask used to clear the ALT_L3_SEC_L4MAIN_DMASECURE register field value. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MAIN_DMASECURE field value from a register. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_L3_SEC_L4MAIN_DMASECURE register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MAIN_DMASECURE_SET(value) (((value) << 2) & 0x00000004)
+ * Field : DMA Non-secure Security - dmanonsecure
+ * Controls whether secure or non-secure masters can access the DMA Non-secure
+ * slave.
+ *  ALT_L3_SEC_L4MAIN_DMANONSECURE_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                           |       | master.
+ *  ALT_L3_SEC_L4MAIN_DMANONSECURE_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MAIN_DMANONSECURE
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_E_SECURE     0x0
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_E_NONSECURE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_MSB        3
+/* The width in bits of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MAIN_DMANONSECURE register field value. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_SET_MSK    0x00000008
+/* The mask used to clear the ALT_L3_SEC_L4MAIN_DMANONSECURE register field value. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MAIN_DMANONSECURE field value from a register. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_L3_SEC_L4MAIN_DMANONSECURE register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MAIN_DMANONSECURE_SET(value) (((value) << 3) & 0x00000008)
+ * The struct declaration for register ALT_L3_SEC_L4MAIN.
+struct ALT_L3_SEC_L4MAIN_s
+    uint32_t  spis0        :  1;  /* SPI Slave 0 Security */
+    uint32_t  spis1        :  1;  /* SPI Slave 1 Security */
+    uint32_t  dmasecure    :  1;  /* DMA Secure Security */
+    uint32_t  dmanonsecure :  1;  /* DMA Non-secure Security */
+    uint32_t               : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_SEC_L4MAIN. */
+typedef volatile struct ALT_L3_SEC_L4MAIN_s  ALT_L3_SEC_L4MAIN_t;
+/* The byte offset of the ALT_L3_SEC_L4MAIN register from the beginning of the component. */
+#define ALT_L3_SEC_L4MAIN_OFST        0x0
+ * Register : L4 SP Peripherals Security - l4sp
+ * Controls security settings for L4 SP peripherals.
+ * Register Layout
+ *  [0]     | W      | 0x0   | SDRAM Registers Security
+ *  [1]     | W      | 0x0   | SP Timer 0 Security
+ *  [2]     | W      | 0x0   | I2C0 Security
+ *  [3]     | W      | 0x0   | I2C1 Security
+ *  [4]     | W      | 0x0   | I2C2 (EMAC 0) Security
+ *  [5]     | W      | 0x0   | I2C3 (EMAC 1) Security
+ *  [6]     | W      | 0x0   | UART 0 Security
+ *  [7]     | W      | 0x0   | UART 1 Security
+ *  [8]     | W      | 0x0   | CAN 0 Security
+ *  [9]     | W      | 0x0   | CAN 1 Security
+ *  [10]    | W      | 0x0   | SP Timer 1 Security
+ *  [31:11] | ???    | 0x0   | *UNDEFINED*
+ * Field : SDRAM Registers Security - sdrregs
+ * Controls whether secure or non-secure masters can access the SDRAM Registers
+ * slave.
+ *  ALT_L3_SEC_L4SP_SDRREGS_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4SP_SDRREGS_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_SDRREGS
+#define ALT_L3_SEC_L4SP_SDRREGS_E_SECURE    0x0
+#define ALT_L3_SEC_L4SP_SDRREGS_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_SDRREGS register field. */
+#define ALT_L3_SEC_L4SP_SDRREGS_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_SDRREGS register field. */
+#define ALT_L3_SEC_L4SP_SDRREGS_MSB        0
+/* The width in bits of the ALT_L3_SEC_L4SP_SDRREGS register field. */
+#define ALT_L3_SEC_L4SP_SDRREGS_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_SDRREGS register field value. */
+#define ALT_L3_SEC_L4SP_SDRREGS_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_L4SP_SDRREGS register field value. */
+#define ALT_L3_SEC_L4SP_SDRREGS_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_L4SP_SDRREGS register field. */
+#define ALT_L3_SEC_L4SP_SDRREGS_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_SDRREGS field value from a register. */
+#define ALT_L3_SEC_L4SP_SDRREGS_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_L4SP_SDRREGS register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_SDRREGS_SET(value) (((value) << 0) & 0x00000001)
+ * Field : SP Timer 0 Security - sptimer0
+ * Controls whether secure or non-secure masters can access the SP Timer 0 slave.
+ *  ALT_L3_SEC_L4SP_SPTMR0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                   |       | master.
+ *  ALT_L3_SEC_L4SP_SPTMR0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_SPTMR0
+#define ALT_L3_SEC_L4SP_SPTMR0_E_SECURE     0x0
+#define ALT_L3_SEC_L4SP_SPTMR0_E_NONSECURE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR0_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR0_MSB        1
+/* The width in bits of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_SPTMR0 register field value. */
+#define ALT_L3_SEC_L4SP_SPTMR0_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_SEC_L4SP_SPTMR0 register field value. */
+#define ALT_L3_SEC_L4SP_SPTMR0_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_SPTMR0 field value from a register. */
+#define ALT_L3_SEC_L4SP_SPTMR0_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_SEC_L4SP_SPTMR0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_SPTMR0_SET(value) (((value) << 1) & 0x00000002)
+ * Field : I2C0 Security - i2c0
+ * Controls whether secure or non-secure masters can access the I2C0 slave.
+ *  ALT_L3_SEC_L4SP_I2C0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_L4SP_I2C0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_I2C0
+#define ALT_L3_SEC_L4SP_I2C0_E_SECURE       0x0
+#define ALT_L3_SEC_L4SP_I2C0_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C0 register field. */
+#define ALT_L3_SEC_L4SP_I2C0_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C0 register field. */
+#define ALT_L3_SEC_L4SP_I2C0_MSB        2
+/* The width in bits of the ALT_L3_SEC_L4SP_I2C0 register field. */
+#define ALT_L3_SEC_L4SP_I2C0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_I2C0 register field value. */
+#define ALT_L3_SEC_L4SP_I2C0_SET_MSK    0x00000004
+/* The mask used to clear the ALT_L3_SEC_L4SP_I2C0 register field value. */
+#define ALT_L3_SEC_L4SP_I2C0_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_L3_SEC_L4SP_I2C0 register field. */
+#define ALT_L3_SEC_L4SP_I2C0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_I2C0 field value from a register. */
+#define ALT_L3_SEC_L4SP_I2C0_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_L3_SEC_L4SP_I2C0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_I2C0_SET(value) (((value) << 2) & 0x00000004)
+ * Field : I2C1 Security - i2c1
+ * Controls whether secure or non-secure masters can access the I2C1 slave.
+ *  ALT_L3_SEC_L4SP_I2C1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_L4SP_I2C1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_I2C1
+#define ALT_L3_SEC_L4SP_I2C1_E_SECURE       0x0
+#define ALT_L3_SEC_L4SP_I2C1_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C1 register field. */
+#define ALT_L3_SEC_L4SP_I2C1_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C1 register field. */
+#define ALT_L3_SEC_L4SP_I2C1_MSB        3
+/* The width in bits of the ALT_L3_SEC_L4SP_I2C1 register field. */
+#define ALT_L3_SEC_L4SP_I2C1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_I2C1 register field value. */
+#define ALT_L3_SEC_L4SP_I2C1_SET_MSK    0x00000008
+/* The mask used to clear the ALT_L3_SEC_L4SP_I2C1 register field value. */
+#define ALT_L3_SEC_L4SP_I2C1_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_L3_SEC_L4SP_I2C1 register field. */
+#define ALT_L3_SEC_L4SP_I2C1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_I2C1 field value from a register. */
+#define ALT_L3_SEC_L4SP_I2C1_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_L3_SEC_L4SP_I2C1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_I2C1_SET(value) (((value) << 3) & 0x00000008)
+ * Field : I2C2 (EMAC 0) Security - i2c2
+ * Controls whether secure or non-secure masters can access the I2C2 (EMAC 0)
+ * slave.
+ *  ALT_L3_SEC_L4SP_I2C2_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_L4SP_I2C2_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_I2C2
+#define ALT_L3_SEC_L4SP_I2C2_E_SECURE       0x0
+#define ALT_L3_SEC_L4SP_I2C2_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C2 register field. */
+#define ALT_L3_SEC_L4SP_I2C2_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C2 register field. */
+#define ALT_L3_SEC_L4SP_I2C2_MSB        4
+/* The width in bits of the ALT_L3_SEC_L4SP_I2C2 register field. */
+#define ALT_L3_SEC_L4SP_I2C2_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_I2C2 register field value. */
+#define ALT_L3_SEC_L4SP_I2C2_SET_MSK    0x00000010
+/* The mask used to clear the ALT_L3_SEC_L4SP_I2C2 register field value. */
+#define ALT_L3_SEC_L4SP_I2C2_CLR_MSK    0xffffffef
+/* The reset value of the ALT_L3_SEC_L4SP_I2C2 register field. */
+#define ALT_L3_SEC_L4SP_I2C2_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_I2C2 field value from a register. */
+#define ALT_L3_SEC_L4SP_I2C2_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_L3_SEC_L4SP_I2C2 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_I2C2_SET(value) (((value) << 4) & 0x00000010)
+ * Field : I2C3 (EMAC 1) Security - i2c3
+ * Controls whether secure or non-secure masters can access the I2C3 (EMAC 1)
+ * slave.
+ *  ALT_L3_SEC_L4SP_I2C3_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_L4SP_I2C3_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_I2C3
+#define ALT_L3_SEC_L4SP_I2C3_E_SECURE       0x0
+#define ALT_L3_SEC_L4SP_I2C3_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C3 register field. */
+#define ALT_L3_SEC_L4SP_I2C3_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C3 register field. */
+#define ALT_L3_SEC_L4SP_I2C3_MSB        5
+/* The width in bits of the ALT_L3_SEC_L4SP_I2C3 register field. */
+#define ALT_L3_SEC_L4SP_I2C3_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_I2C3 register field value. */
+#define ALT_L3_SEC_L4SP_I2C3_SET_MSK    0x00000020
+/* The mask used to clear the ALT_L3_SEC_L4SP_I2C3 register field value. */
+#define ALT_L3_SEC_L4SP_I2C3_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_L3_SEC_L4SP_I2C3 register field. */
+#define ALT_L3_SEC_L4SP_I2C3_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_I2C3 field value from a register. */
+#define ALT_L3_SEC_L4SP_I2C3_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_L3_SEC_L4SP_I2C3 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_I2C3_SET(value) (((value) << 5) & 0x00000020)
+ * Field : UART 0 Security - uart0
+ * Controls whether secure or non-secure masters can access the UART 0 slave.
+ *  ALT_L3_SEC_L4SP_UART0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4SP_UART0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_UART0
+#define ALT_L3_SEC_L4SP_UART0_E_SECURE      0x0
+#define ALT_L3_SEC_L4SP_UART0_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_UART0 register field. */
+#define ALT_L3_SEC_L4SP_UART0_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_UART0 register field. */
+#define ALT_L3_SEC_L4SP_UART0_MSB        6
+/* The width in bits of the ALT_L3_SEC_L4SP_UART0 register field. */
+#define ALT_L3_SEC_L4SP_UART0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_UART0 register field value. */
+#define ALT_L3_SEC_L4SP_UART0_SET_MSK    0x00000040
+/* The mask used to clear the ALT_L3_SEC_L4SP_UART0 register field value. */
+#define ALT_L3_SEC_L4SP_UART0_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_L3_SEC_L4SP_UART0 register field. */
+#define ALT_L3_SEC_L4SP_UART0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_UART0 field value from a register. */
+#define ALT_L3_SEC_L4SP_UART0_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_L3_SEC_L4SP_UART0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_UART0_SET(value) (((value) << 6) & 0x00000040)
+ * Field : UART 1 Security - uart1
+ * Controls whether secure or non-secure masters can access the UART 1 slave.
+ *  ALT_L3_SEC_L4SP_UART1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4SP_UART1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_UART1
+#define ALT_L3_SEC_L4SP_UART1_E_SECURE      0x0
+#define ALT_L3_SEC_L4SP_UART1_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_UART1 register field. */
+#define ALT_L3_SEC_L4SP_UART1_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_UART1 register field. */
+#define ALT_L3_SEC_L4SP_UART1_MSB        7
+/* The width in bits of the ALT_L3_SEC_L4SP_UART1 register field. */
+#define ALT_L3_SEC_L4SP_UART1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_UART1 register field value. */
+#define ALT_L3_SEC_L4SP_UART1_SET_MSK    0x00000080
+/* The mask used to clear the ALT_L3_SEC_L4SP_UART1 register field value. */
+#define ALT_L3_SEC_L4SP_UART1_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_L3_SEC_L4SP_UART1 register field. */
+#define ALT_L3_SEC_L4SP_UART1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_UART1 field value from a register. */
+#define ALT_L3_SEC_L4SP_UART1_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_L3_SEC_L4SP_UART1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_UART1_SET(value) (((value) << 7) & 0x00000080)
+ * Field : CAN 0 Security - can0
+ * Controls whether secure or non-secure masters can access the CAN 0 slave.
+ *  ALT_L3_SEC_L4SP_CAN0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_L4SP_CAN0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_CAN0
+#define ALT_L3_SEC_L4SP_CAN0_E_SECURE       0x0
+#define ALT_L3_SEC_L4SP_CAN0_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_CAN0 register field. */
+#define ALT_L3_SEC_L4SP_CAN0_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_CAN0 register field. */
+#define ALT_L3_SEC_L4SP_CAN0_MSB        8
+/* The width in bits of the ALT_L3_SEC_L4SP_CAN0 register field. */
+#define ALT_L3_SEC_L4SP_CAN0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_CAN0 register field value. */
+#define ALT_L3_SEC_L4SP_CAN0_SET_MSK    0x00000100
+/* The mask used to clear the ALT_L3_SEC_L4SP_CAN0 register field value. */
+#define ALT_L3_SEC_L4SP_CAN0_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_L3_SEC_L4SP_CAN0 register field. */
+#define ALT_L3_SEC_L4SP_CAN0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_CAN0 field value from a register. */
+#define ALT_L3_SEC_L4SP_CAN0_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_L3_SEC_L4SP_CAN0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_CAN0_SET(value) (((value) << 8) & 0x00000100)
+ * Field : CAN 1 Security - can1
+ * Controls whether secure or non-secure masters can access the CAN 1 slave.
+ *  ALT_L3_SEC_L4SP_CAN1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_L4SP_CAN1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_CAN1
+#define ALT_L3_SEC_L4SP_CAN1_E_SECURE       0x0
+#define ALT_L3_SEC_L4SP_CAN1_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_CAN1 register field. */
+#define ALT_L3_SEC_L4SP_CAN1_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_CAN1 register field. */
+#define ALT_L3_SEC_L4SP_CAN1_MSB        9
+/* The width in bits of the ALT_L3_SEC_L4SP_CAN1 register field. */
+#define ALT_L3_SEC_L4SP_CAN1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_CAN1 register field value. */
+#define ALT_L3_SEC_L4SP_CAN1_SET_MSK    0x00000200
+/* The mask used to clear the ALT_L3_SEC_L4SP_CAN1 register field value. */
+#define ALT_L3_SEC_L4SP_CAN1_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_L3_SEC_L4SP_CAN1 register field. */
+#define ALT_L3_SEC_L4SP_CAN1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_CAN1 field value from a register. */
+#define ALT_L3_SEC_L4SP_CAN1_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_L3_SEC_L4SP_CAN1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_CAN1_SET(value) (((value) << 9) & 0x00000200)
+ * Field : SP Timer 1 Security - sptimer1
+ * Controls whether secure or non-secure masters can access the SP Timer 1 slave.
+ *  ALT_L3_SEC_L4SP_SPTMR1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                   |       | master.
+ *  ALT_L3_SEC_L4SP_SPTMR1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SP_SPTMR1
+#define ALT_L3_SEC_L4SP_SPTMR1_E_SECURE     0x0
+#define ALT_L3_SEC_L4SP_SPTMR1_E_NONSECURE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR1_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR1_MSB        10
+/* The width in bits of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SP_SPTMR1 register field value. */
+#define ALT_L3_SEC_L4SP_SPTMR1_SET_MSK    0x00000400
+/* The mask used to clear the ALT_L3_SEC_L4SP_SPTMR1 register field value. */
+#define ALT_L3_SEC_L4SP_SPTMR1_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
+#define ALT_L3_SEC_L4SP_SPTMR1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SP_SPTMR1 field value from a register. */
+#define ALT_L3_SEC_L4SP_SPTMR1_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_L3_SEC_L4SP_SPTMR1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SP_SPTMR1_SET(value) (((value) << 10) & 0x00000400)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_L3_SEC_L4SP.
+struct ALT_L3_SEC_L4SP_s
+    uint32_t  sdrregs  :  1;  /* SDRAM Registers Security */
+    uint32_t  sptimer0 :  1;  /* SP Timer 0 Security */
+    uint32_t  i2c0     :  1;  /* I2C0 Security */
+    uint32_t  i2c1     :  1;  /* I2C1 Security */
+    uint32_t  i2c2     :  1;  /* I2C2 (EMAC 0) Security */
+    uint32_t  i2c3     :  1;  /* I2C3 (EMAC 1) Security */
+    uint32_t  uart0    :  1;  /* UART 0 Security */
+    uint32_t  uart1    :  1;  /* UART 1 Security */
+    uint32_t  can0     :  1;  /* CAN 0 Security */
+    uint32_t  can1     :  1;  /* CAN 1 Security */
+    uint32_t  sptimer1 :  1;  /* SP Timer 1 Security */
+    uint32_t           : 21;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_SEC_L4SP. */
+typedef volatile struct ALT_L3_SEC_L4SP_s  ALT_L3_SEC_L4SP_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_L3_SEC_L4SP register from the beginning of the component. */
+#define ALT_L3_SEC_L4SP_OFST        0x4
+ * Register : L4 MP Peripherals Security - l4mp
+ * Controls security settings for L4 MP peripherals.
+ * Register Layout
+ *  Bits    | Access | Reset | Description
+ *  [0]     | W      | 0x0   | FPGA Manager Register Security
+ *  [1]     | W      | 0x0   | DAP Security
+ *  [2]     | W      | 0x0   | QSPI Registers Security
+ *  [3]     | W      | 0x0   | SDMMC Security
+ *  [4]     | W      | 0x0   | EMAC 0 Security
+ *  [5]     | W      | 0x0   | EMAC 1 Security
+ *  [6]     | W      | 0x0   | ACP ID Mapper Security
+ *  [7]     | W      | 0x0   | GPIO 0 Security
+ *  [8]     | W      | 0x0   | GPIO 1 Security
+ *  [9]     | W      | 0x0   | GPIO 2 Security
+ *  [31:10] | ???    | 0x0   | *UNDEFINED*
+ * Field : FPGA Manager Register Security - fpgamgrregs
+ * Controls whether secure or non-secure masters can access the FPGA Manager
+ * Register slave.
+ *  ALT_L3_SEC_L4MP_FPGAMGR_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4MP_FPGAMGR_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_FPGAMGR
+#define ALT_L3_SEC_L4MP_FPGAMGR_E_SECURE    0x0
+#define ALT_L3_SEC_L4MP_FPGAMGR_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_MSB        0
+/* The width in bits of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_FPGAMGR register field value. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_L4MP_FPGAMGR register field value. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_FPGAMGR field value from a register. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_L4MP_FPGAMGR register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_FPGAMGR_SET(value) (((value) << 0) & 0x00000001)
+ * Field : DAP Security - dap
+ * Controls whether secure or non-secure masters can access the DAP slave.
+ *  ALT_L3_SEC_L4MP_DAP_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                |       | master.
+ *  ALT_L3_SEC_L4MP_DAP_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_DAP
+#define ALT_L3_SEC_L4MP_DAP_E_SECURE    0x0
+#define ALT_L3_SEC_L4MP_DAP_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_DAP register field. */
+#define ALT_L3_SEC_L4MP_DAP_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_DAP register field. */
+#define ALT_L3_SEC_L4MP_DAP_MSB        1
+/* The width in bits of the ALT_L3_SEC_L4MP_DAP register field. */
+#define ALT_L3_SEC_L4MP_DAP_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_DAP register field value. */
+#define ALT_L3_SEC_L4MP_DAP_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_SEC_L4MP_DAP register field value. */
+#define ALT_L3_SEC_L4MP_DAP_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_SEC_L4MP_DAP register field. */
+#define ALT_L3_SEC_L4MP_DAP_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_DAP field value from a register. */
+#define ALT_L3_SEC_L4MP_DAP_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_SEC_L4MP_DAP register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_DAP_SET(value) (((value) << 1) & 0x00000002)
+ * Field : QSPI Registers Security - qspiregs
+ * Controls whether secure or non-secure masters can access the QSPI Registers
+ * slave.
+ *  ALT_L3_SEC_L4MP_QSPI_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_L4MP_QSPI_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_QSPI
+#define ALT_L3_SEC_L4MP_QSPI_E_SECURE       0x0
+#define ALT_L3_SEC_L4MP_QSPI_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_QSPI register field. */
+#define ALT_L3_SEC_L4MP_QSPI_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_QSPI register field. */
+#define ALT_L3_SEC_L4MP_QSPI_MSB        2
+/* The width in bits of the ALT_L3_SEC_L4MP_QSPI register field. */
+#define ALT_L3_SEC_L4MP_QSPI_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_QSPI register field value. */
+#define ALT_L3_SEC_L4MP_QSPI_SET_MSK    0x00000004
+/* The mask used to clear the ALT_L3_SEC_L4MP_QSPI register field value. */
+#define ALT_L3_SEC_L4MP_QSPI_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_L3_SEC_L4MP_QSPI register field. */
+#define ALT_L3_SEC_L4MP_QSPI_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_QSPI field value from a register. */
+#define ALT_L3_SEC_L4MP_QSPI_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_L3_SEC_L4MP_QSPI register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_QSPI_SET(value) (((value) << 2) & 0x00000004)
+ * Field : SDMMC Security - sdmmc
+ * Controls whether secure or non-secure masters can access the SDMMC slave.
+ *  ALT_L3_SEC_L4MP_SDMMC_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4MP_SDMMC_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_SDMMC
+#define ALT_L3_SEC_L4MP_SDMMC_E_SECURE      0x0
+#define ALT_L3_SEC_L4MP_SDMMC_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_SDMMC register field. */
+#define ALT_L3_SEC_L4MP_SDMMC_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_SDMMC register field. */
+#define ALT_L3_SEC_L4MP_SDMMC_MSB        3
+/* The width in bits of the ALT_L3_SEC_L4MP_SDMMC register field. */
+#define ALT_L3_SEC_L4MP_SDMMC_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_SDMMC register field value. */
+#define ALT_L3_SEC_L4MP_SDMMC_SET_MSK    0x00000008
+/* The mask used to clear the ALT_L3_SEC_L4MP_SDMMC register field value. */
+#define ALT_L3_SEC_L4MP_SDMMC_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_L3_SEC_L4MP_SDMMC register field. */
+#define ALT_L3_SEC_L4MP_SDMMC_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_SDMMC field value from a register. */
+#define ALT_L3_SEC_L4MP_SDMMC_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_L3_SEC_L4MP_SDMMC register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_SDMMC_SET(value) (((value) << 3) & 0x00000008)
+ * Field : EMAC 0 Security - emac0
+ * Controls whether secure or non-secure masters can access the EMAC 0 slave.
+ *  ALT_L3_SEC_L4MP_EMAC0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4MP_EMAC0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_EMAC0
+#define ALT_L3_SEC_L4MP_EMAC0_E_SECURE      0x0
+#define ALT_L3_SEC_L4MP_EMAC0_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_EMAC0 register field. */
+#define ALT_L3_SEC_L4MP_EMAC0_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_EMAC0 register field. */
+#define ALT_L3_SEC_L4MP_EMAC0_MSB        4
+/* The width in bits of the ALT_L3_SEC_L4MP_EMAC0 register field. */
+#define ALT_L3_SEC_L4MP_EMAC0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_EMAC0 register field value. */
+#define ALT_L3_SEC_L4MP_EMAC0_SET_MSK    0x00000010
+/* The mask used to clear the ALT_L3_SEC_L4MP_EMAC0 register field value. */
+#define ALT_L3_SEC_L4MP_EMAC0_CLR_MSK    0xffffffef
+/* The reset value of the ALT_L3_SEC_L4MP_EMAC0 register field. */
+#define ALT_L3_SEC_L4MP_EMAC0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_EMAC0 field value from a register. */
+#define ALT_L3_SEC_L4MP_EMAC0_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_L3_SEC_L4MP_EMAC0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_EMAC0_SET(value) (((value) << 4) & 0x00000010)
+ * Field : EMAC 1 Security - emac1
+ * Controls whether secure or non-secure masters can access the EMAC 1 slave.
+ *  ALT_L3_SEC_L4MP_EMAC1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4MP_EMAC1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_EMAC1
+#define ALT_L3_SEC_L4MP_EMAC1_E_SECURE      0x0
+#define ALT_L3_SEC_L4MP_EMAC1_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_EMAC1 register field. */
+#define ALT_L3_SEC_L4MP_EMAC1_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_EMAC1 register field. */
+#define ALT_L3_SEC_L4MP_EMAC1_MSB        5
+/* The width in bits of the ALT_L3_SEC_L4MP_EMAC1 register field. */
+#define ALT_L3_SEC_L4MP_EMAC1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_EMAC1 register field value. */
+#define ALT_L3_SEC_L4MP_EMAC1_SET_MSK    0x00000020
+/* The mask used to clear the ALT_L3_SEC_L4MP_EMAC1 register field value. */
+#define ALT_L3_SEC_L4MP_EMAC1_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_L3_SEC_L4MP_EMAC1 register field. */
+#define ALT_L3_SEC_L4MP_EMAC1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_EMAC1 field value from a register. */
+#define ALT_L3_SEC_L4MP_EMAC1_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_L3_SEC_L4MP_EMAC1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_EMAC1_SET(value) (((value) << 5) & 0x00000020)
+ * Field : ACP ID Mapper Security - acpidmap
+ * Controls whether secure or non-secure masters can access the ACP ID Mapper
+ * slave.
+ * Field Enumeration Values:
+ *  Enum                                 | Value | Description
+ *  ALT_L3_SEC_L4MP_ACPIDMAP_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                     |       | master.
+ *  ALT_L3_SEC_L4MP_ACPIDMAP_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_ACPIDMAP
+#define ALT_L3_SEC_L4MP_ACPIDMAP_E_SECURE       0x0
+#define ALT_L3_SEC_L4MP_ACPIDMAP_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_MSB        6
+/* The width in bits of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_ACPIDMAP register field value. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_SET_MSK    0x00000040
+/* The mask used to clear the ALT_L3_SEC_L4MP_ACPIDMAP register field value. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_ACPIDMAP field value from a register. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_L3_SEC_L4MP_ACPIDMAP register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_ACPIDMAP_SET(value) (((value) << 6) & 0x00000040)
+ * Field : GPIO 0 Security - gpio0
+ * Controls whether secure or non-secure masters can access the GPIO 0 slave.
+ *  ALT_L3_SEC_L4MP_GPIO0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4MP_GPIO0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO0
+#define ALT_L3_SEC_L4MP_GPIO0_E_SECURE      0x0
+#define ALT_L3_SEC_L4MP_GPIO0_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_GPIO0 register field. */
+#define ALT_L3_SEC_L4MP_GPIO0_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_GPIO0 register field. */
+#define ALT_L3_SEC_L4MP_GPIO0_MSB        7
+/* The width in bits of the ALT_L3_SEC_L4MP_GPIO0 register field. */
+#define ALT_L3_SEC_L4MP_GPIO0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_GPIO0 register field value. */
+#define ALT_L3_SEC_L4MP_GPIO0_SET_MSK    0x00000080
+/* The mask used to clear the ALT_L3_SEC_L4MP_GPIO0 register field value. */
+#define ALT_L3_SEC_L4MP_GPIO0_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_L3_SEC_L4MP_GPIO0 register field. */
+#define ALT_L3_SEC_L4MP_GPIO0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_GPIO0 field value from a register. */
+#define ALT_L3_SEC_L4MP_GPIO0_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_L3_SEC_L4MP_GPIO0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_GPIO0_SET(value) (((value) << 7) & 0x00000080)
+ * Field : GPIO 1 Security - gpio1
+ * Controls whether secure or non-secure masters can access the GPIO 1 slave.
+ *  ALT_L3_SEC_L4MP_GPIO1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4MP_GPIO1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO1
+#define ALT_L3_SEC_L4MP_GPIO1_E_SECURE      0x0
+#define ALT_L3_SEC_L4MP_GPIO1_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_GPIO1 register field. */
+#define ALT_L3_SEC_L4MP_GPIO1_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_GPIO1 register field. */
+#define ALT_L3_SEC_L4MP_GPIO1_MSB        8
+/* The width in bits of the ALT_L3_SEC_L4MP_GPIO1 register field. */
+#define ALT_L3_SEC_L4MP_GPIO1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_GPIO1 register field value. */
+#define ALT_L3_SEC_L4MP_GPIO1_SET_MSK    0x00000100
+/* The mask used to clear the ALT_L3_SEC_L4MP_GPIO1 register field value. */
+#define ALT_L3_SEC_L4MP_GPIO1_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_L3_SEC_L4MP_GPIO1 register field. */
+#define ALT_L3_SEC_L4MP_GPIO1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_GPIO1 field value from a register. */
+#define ALT_L3_SEC_L4MP_GPIO1_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_L3_SEC_L4MP_GPIO1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_GPIO1_SET(value) (((value) << 8) & 0x00000100)
+ * Field : GPIO 2 Security - gpio2
+ * Controls whether secure or non-secure masters can access the GPIO 2 slave.
+ *  ALT_L3_SEC_L4MP_GPIO2_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_L4MP_GPIO2_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO2
+#define ALT_L3_SEC_L4MP_GPIO2_E_SECURE      0x0
+#define ALT_L3_SEC_L4MP_GPIO2_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_GPIO2 register field. */
+#define ALT_L3_SEC_L4MP_GPIO2_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_GPIO2 register field. */
+#define ALT_L3_SEC_L4MP_GPIO2_MSB        9
+/* The width in bits of the ALT_L3_SEC_L4MP_GPIO2 register field. */
+#define ALT_L3_SEC_L4MP_GPIO2_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4MP_GPIO2 register field value. */
+#define ALT_L3_SEC_L4MP_GPIO2_SET_MSK    0x00000200
+/* The mask used to clear the ALT_L3_SEC_L4MP_GPIO2 register field value. */
+#define ALT_L3_SEC_L4MP_GPIO2_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_L3_SEC_L4MP_GPIO2 register field. */
+#define ALT_L3_SEC_L4MP_GPIO2_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4MP_GPIO2 field value from a register. */
+#define ALT_L3_SEC_L4MP_GPIO2_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_L3_SEC_L4MP_GPIO2 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4MP_GPIO2_SET(value) (((value) << 9) & 0x00000200)
+ * The struct declaration for register ALT_L3_SEC_L4MP.
+struct ALT_L3_SEC_L4MP_s
+    uint32_t  fpgamgrregs :  1;  /* FPGA Manager Register Security */
+    uint32_t  dap         :  1;  /* DAP Security */
+    uint32_t  qspiregs    :  1;  /* QSPI Registers Security */
+    uint32_t  sdmmc       :  1;  /* SDMMC Security */
+    uint32_t  emac0       :  1;  /* EMAC 0 Security */
+    uint32_t  emac1       :  1;  /* EMAC 1 Security */
+    uint32_t  acpidmap    :  1;  /* ACP ID Mapper Security */
+    uint32_t  gpio0       :  1;  /* GPIO 0 Security */
+    uint32_t  gpio1       :  1;  /* GPIO 1 Security */
+    uint32_t  gpio2       :  1;  /* GPIO 2 Security */
+    uint32_t              : 22;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_SEC_L4MP. */
+typedef volatile struct ALT_L3_SEC_L4MP_s  ALT_L3_SEC_L4MP_t;
+/* The byte offset of the ALT_L3_SEC_L4MP register from the beginning of the component. */
+#define ALT_L3_SEC_L4MP_OFST        0x8
+ * Register : L4 OSC1 Peripherals Security - l4osc1
+ * Controls security settings for L4 OSC1 peripherals.
+ * Register Layout
+ *  [0]    | W      | 0x0   | L4 Watchdog Timer 0 Security
+ *  [1]    | W      | 0x0   | L4 Watchdog Timer 0 Security
+ *  [2]    | W      | 0x0   | Clock Manager Security
+ *  [3]    | W      | 0x0   | Reset Manager Security
+ *  [4]    | W      | 0x0   | System Manager Security
+ *  [5]    | W      | 0x0   | OSC1 Timer 0 Security
+ *  [6]    | W      | 0x0   | OSC1 Timer 1 Security
+ *  [31:7] | ???    | 0x0   | *UNDEFINED*
+ * Field : L4 Watchdog Timer 0 Security - l4wd0
+ * Controls whether secure or non-secure masters can access the L4 Watchdog Timer 0
+ * slave.
+ *  ALT_L3_SEC_L4OSC1_L4WD0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4OSC1_L4WD0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4OSC1_L4WD0
+#define ALT_L3_SEC_L4OSC1_L4WD0_E_SECURE    0x0
+#define ALT_L3_SEC_L4OSC1_L4WD0_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_MSB        0
+/* The width in bits of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4OSC1_L4WD0 register field value. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_L4OSC1_L4WD0 register field value. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4OSC1_L4WD0 field value from a register. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_L4OSC1_L4WD0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4OSC1_L4WD0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : L4 Watchdog Timer 0 Security - l4wd1
+ * slave.
+ *  ALT_L3_SEC_L4OSC1_L4WD1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4OSC1_L4WD1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4OSC1_L4WD1
+#define ALT_L3_SEC_L4OSC1_L4WD1_E_SECURE    0x0
+#define ALT_L3_SEC_L4OSC1_L4WD1_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_MSB        1
+/* The width in bits of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4OSC1_L4WD1 register field value. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_SEC_L4OSC1_L4WD1 register field value. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4OSC1_L4WD1 field value from a register. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_SEC_L4OSC1_L4WD1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4OSC1_L4WD1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Clock Manager Security - clkmgr
+ * Controls whether secure or non-secure masters can access the Clock Manager
+ * slave.
+ *  ALT_L3_SEC_L4OSC1_CLKMGR_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                     |       | master.
+ *  ALT_L3_SEC_L4OSC1_CLKMGR_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4OSC1_CLKMGR
+#define ALT_L3_SEC_L4OSC1_CLKMGR_E_SECURE       0x0
+#define ALT_L3_SEC_L4OSC1_CLKMGR_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_MSB        2
+/* The width in bits of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4OSC1_CLKMGR register field value. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_SET_MSK    0x00000004
+/* The mask used to clear the ALT_L3_SEC_L4OSC1_CLKMGR register field value. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4OSC1_CLKMGR field value from a register. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_L3_SEC_L4OSC1_CLKMGR register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4OSC1_CLKMGR_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Reset Manager Security - rstmgr
+ * Controls whether secure or non-secure masters can access the Reset Manager
+ * slave.
+ *  ALT_L3_SEC_L4OSC1_RSTMGR_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                     |       | master.
+ *  ALT_L3_SEC_L4OSC1_RSTMGR_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4OSC1_RSTMGR
+#define ALT_L3_SEC_L4OSC1_RSTMGR_E_SECURE       0x0
+#define ALT_L3_SEC_L4OSC1_RSTMGR_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_MSB        3
+/* The width in bits of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4OSC1_RSTMGR register field value. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_L3_SEC_L4OSC1_RSTMGR register field value. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4OSC1_RSTMGR field value from a register. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_L3_SEC_L4OSC1_RSTMGR register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4OSC1_RSTMGR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : System Manager Security - sysmgr
+ * Controls whether secure or non-secure masters can access the System Manager
+ * slave.
+ *  ALT_L3_SEC_L4OSC1_SYSMGR_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                     |       | master.
+ *  ALT_L3_SEC_L4OSC1_SYSMGR_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4OSC1_SYSMGR
+#define ALT_L3_SEC_L4OSC1_SYSMGR_E_SECURE       0x0
+#define ALT_L3_SEC_L4OSC1_SYSMGR_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_MSB        4
+/* The width in bits of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4OSC1_SYSMGR register field value. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_L3_SEC_L4OSC1_SYSMGR register field value. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4OSC1_SYSMGR field value from a register. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_L3_SEC_L4OSC1_SYSMGR register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4OSC1_SYSMGR_SET(value) (((value) << 4) & 0x00000010)
+ * Field : OSC1 Timer 0 Security - osc1timer0
+ * Controls whether secure or non-secure masters can access the OSC1 Timer 0 slave.
+ *  ALT_L3_SEC_L4OSC1_OSC1TMR0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                       |       | master.
+ *  ALT_L3_SEC_L4OSC1_OSC1TMR0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4OSC1_OSC1TMR0
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_E_SECURE     0x0
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_E_NONSECURE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_MSB        5
+/* The width in bits of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field value. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_SET_MSK    0x00000020
+/* The mask used to clear the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field value. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4OSC1_OSC1TMR0 field value from a register. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_L3_SEC_L4OSC1_OSC1TMR0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR0_SET(value) (((value) << 5) & 0x00000020)
+ * Field : OSC1 Timer 1 Security - osc1timer1
+ * Controls whether secure or non-secure masters can access the OSC1 Timer 1 slave.
+ *  ALT_L3_SEC_L4OSC1_OSC1TMR1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                       |       | master.
+ *  ALT_L3_SEC_L4OSC1_OSC1TMR1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Field Access Macros:
+ * Enumerated value for register field ALT_L3_SEC_L4OSC1_OSC1TMR1
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_E_SECURE     0x0
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_E_NONSECURE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_MSB        6
+/* The width in bits of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field value. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_SET_MSK    0x00000040
+/* The mask used to clear the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field value. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4OSC1_OSC1TMR1 field value from a register. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_L3_SEC_L4OSC1_OSC1TMR1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4OSC1_OSC1TMR1_SET(value) (((value) << 6) & 0x00000040)
+ * The struct declaration for register ALT_L3_SEC_L4OSC1.
+struct ALT_L3_SEC_L4OSC1_s
+    uint32_t  l4wd0      :  1;  /* L4 Watchdog Timer 0 Security */
+    uint32_t  l4wd1      :  1;  /* L4 Watchdog Timer 0 Security */
+    uint32_t  clkmgr     :  1;  /* Clock Manager Security */
+    uint32_t  rstmgr     :  1;  /* Reset Manager Security */
+    uint32_t  sysmgr     :  1;  /* System Manager Security */
+    uint32_t  osc1timer0 :  1;  /* OSC1 Timer 0 Security */
+    uint32_t  osc1timer1 :  1;  /* OSC1 Timer 1 Security */
+    uint32_t             : 25;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_SEC_L4OSC1. */
+typedef volatile struct ALT_L3_SEC_L4OSC1_s  ALT_L3_SEC_L4OSC1_t;
+/* The byte offset of the ALT_L3_SEC_L4OSC1 register from the beginning of the component. */
+#define ALT_L3_SEC_L4OSC1_OFST        0xc
+ * Register : L4 SPIM Peripherals Security - l4spim
+ * Controls security settings for L4 SPIM peripherals.
+ * Register Layout
+ *  [0]    | W      | 0x0   | SPI Master 0 Security
+ *  [1]    | W      | 0x0   | SPI Master 1 Security
+ *  [2]    | W      | 0x0   | Scan Manager Security
+ *  [31:3] | ???    | 0x0   | *UNDEFINED*
+ * Field : SPI Master 0 Security - spim0
+ * Controls whether secure or non-secure masters can access the SPI Master 0 slave.
+ *  ALT_L3_SEC_L4SPIM_SPIM0_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4SPIM_SPIM0_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SPIM_SPIM0
+#define ALT_L3_SEC_L4SPIM_SPIM0_E_SECURE    0x0
+#define ALT_L3_SEC_L4SPIM_SPIM0_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_MSB        0
+/* The width in bits of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SPIM_SPIM0 register field value. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_L4SPIM_SPIM0 register field value. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SPIM_SPIM0 field value from a register. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_L4SPIM_SPIM0 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SPIM_SPIM0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : SPI Master 1 Security - spim1
+ * Controls whether secure or non-secure masters can access the SPI Master 1 slave.
+ *  ALT_L3_SEC_L4SPIM_SPIM1_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                    |       | master.
+ *  ALT_L3_SEC_L4SPIM_SPIM1_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SPIM_SPIM1
+#define ALT_L3_SEC_L4SPIM_SPIM1_E_SECURE    0x0
+#define ALT_L3_SEC_L4SPIM_SPIM1_E_NONSECURE 0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_MSB        1
+/* The width in bits of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SPIM_SPIM1 register field value. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_SEC_L4SPIM_SPIM1 register field value. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SPIM_SPIM1 field value from a register. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_SEC_L4SPIM_SPIM1 register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SPIM_SPIM1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Scan Manager Security - scanmgr
+ * Controls whether secure or non-secure masters can access the Scan Manager slave.
+ *  ALT_L3_SEC_L4SPIM_SCANMGR_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                      |       | master.
+ *  ALT_L3_SEC_L4SPIM_SCANMGR_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_L4SPIM_SCANMGR
+#define ALT_L3_SEC_L4SPIM_SCANMGR_E_SECURE      0x0
+#define ALT_L3_SEC_L4SPIM_SCANMGR_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_MSB        2
+/* The width in bits of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_L4SPIM_SCANMGR register field value. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_SET_MSK    0x00000004
+/* The mask used to clear the ALT_L3_SEC_L4SPIM_SCANMGR register field value. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_RESET      0x0
+/* Extracts the ALT_L3_SEC_L4SPIM_SCANMGR field value from a register. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_L3_SEC_L4SPIM_SCANMGR register field value suitable for setting the register. */
+#define ALT_L3_SEC_L4SPIM_SCANMGR_SET(value) (((value) << 2) & 0x00000004)
+ * The struct declaration for register ALT_L3_SEC_L4SPIM.
+struct ALT_L3_SEC_L4SPIM_s
+    uint32_t  spim0   :  1;  /* SPI Master 0 Security */
+    uint32_t  spim1   :  1;  /* SPI Master 1 Security */
+    uint32_t  scanmgr :  1;  /* Scan Manager Security */
+    uint32_t          : 29;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_SEC_L4SPIM. */
+typedef volatile struct ALT_L3_SEC_L4SPIM_s  ALT_L3_SEC_L4SPIM_t;
+/* The byte offset of the ALT_L3_SEC_L4SPIM register from the beginning of the component. */
+#define ALT_L3_SEC_L4SPIM_OFST        0x10
+ * Register : STM Peripheral Security - stm
+ * Controls security settings for STM peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | STM Security
+ *  [31:1] | ???    | 0x0   | *UNDEFINED*
+ * Field : STM Security - s
+ * Controls whether secure or non-secure masters can access the STM slave.
+ *  ALT_L3_SEC_STM_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                             |       | master.
+ *  ALT_L3_SEC_STM_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * :                             |       | non-secure masters.
+ * Enumerated value for register field ALT_L3_SEC_STM_S
+ * The slave can only be accessed by a secure master.
+#define ALT_L3_SEC_STM_S_E_SECURE       0x0
+ * The slave can only be accessed by a secure or non-secure masters.
+#define ALT_L3_SEC_STM_S_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_STM_S register field. */
+#define ALT_L3_SEC_STM_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_STM_S register field. */
+#define ALT_L3_SEC_STM_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_STM_S register field. */
+#define ALT_L3_SEC_STM_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_STM_S register field value. */
+#define ALT_L3_SEC_STM_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_STM_S register field value. */
+#define ALT_L3_SEC_STM_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_STM_S register field. */
+#define ALT_L3_SEC_STM_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_STM_S field value from a register. */
+#define ALT_L3_SEC_STM_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_STM_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_STM_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_STM.
+struct ALT_L3_SEC_STM_s
+    uint32_t  s :  1;  /* STM Security */
+    uint32_t    : 31;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_SEC_STM. */
+typedef volatile struct ALT_L3_SEC_STM_s  ALT_L3_SEC_STM_t;
+/* The byte offset of the ALT_L3_SEC_STM register from the beginning of the component. */
+#define ALT_L3_SEC_STM_OFST        0x14
+ * Register : LWHPS2FPGA AXI Bridge Registers Peripheral Security - lwhps2fpgaregs
+ * Controls security settings for LWHPS2FPGA AXI Bridge Registers peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | LWHPS2FPGA AXI Bridge Registers Security
+ * Field : LWHPS2FPGA AXI Bridge Registers Security - s
+ * Controls whether secure or non-secure masters can access the LWHPS2FPGA AXI
+ * Bridge Registers slave.
+ *  ALT_L3_SEC_LWH2F_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                               |       | master.
+ *  ALT_L3_SEC_LWH2F_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_LWH2F_S
+#define ALT_L3_SEC_LWH2F_S_E_SECURE     0x0
+#define ALT_L3_SEC_LWH2F_S_E_NONSECURE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_LWH2F_S register field. */
+#define ALT_L3_SEC_LWH2F_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_LWH2F_S register field. */
+#define ALT_L3_SEC_LWH2F_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_LWH2F_S register field. */
+#define ALT_L3_SEC_LWH2F_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_LWH2F_S register field value. */
+#define ALT_L3_SEC_LWH2F_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_LWH2F_S register field value. */
+#define ALT_L3_SEC_LWH2F_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_LWH2F_S register field. */
+#define ALT_L3_SEC_LWH2F_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_LWH2F_S field value from a register. */
+#define ALT_L3_SEC_LWH2F_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_LWH2F_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_LWH2F_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_LWH2F.
+struct ALT_L3_SEC_LWH2F_s
+    uint32_t  s :  1;  /* LWHPS2FPGA AXI Bridge Registers Security */
+/* The typedef declaration for register ALT_L3_SEC_LWH2F. */
+typedef volatile struct ALT_L3_SEC_LWH2F_s  ALT_L3_SEC_LWH2F_t;
+/* The byte offset of the ALT_L3_SEC_LWH2F register from the beginning of the component. */
+#define ALT_L3_SEC_LWH2F_OFST        0x18
+ * Register : USB1 Registers Peripheral Security - usb1
+ * Controls security settings for USB1 Registers peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | USB1 Registers Security
+ * Field : USB1 Registers Security - s
+ * Controls whether secure or non-secure masters can access the USB1 Registers
+ * slave.
+ *  ALT_L3_SEC_USB1_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                              |       | master.
+ *  ALT_L3_SEC_USB1_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_USB1_S
+#define ALT_L3_SEC_USB1_S_E_SECURE      0x0
+#define ALT_L3_SEC_USB1_S_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_USB1_S register field. */
+#define ALT_L3_SEC_USB1_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_USB1_S register field. */
+#define ALT_L3_SEC_USB1_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_USB1_S register field. */
+#define ALT_L3_SEC_USB1_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_USB1_S register field value. */
+#define ALT_L3_SEC_USB1_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_USB1_S register field value. */
+#define ALT_L3_SEC_USB1_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_USB1_S register field. */
+#define ALT_L3_SEC_USB1_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_USB1_S field value from a register. */
+#define ALT_L3_SEC_USB1_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_USB1_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_USB1_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_USB1.
+struct ALT_L3_SEC_USB1_s
+    uint32_t  s :  1;  /* USB1 Registers Security */
+/* The typedef declaration for register ALT_L3_SEC_USB1. */
+typedef volatile struct ALT_L3_SEC_USB1_s  ALT_L3_SEC_USB1_t;
+/* The byte offset of the ALT_L3_SEC_USB1 register from the beginning of the component. */
+#define ALT_L3_SEC_USB1_OFST        0x20
+ * Register : NAND Flash Controller Data Peripheral Security - nanddata
+ * Controls security settings for NAND Flash Controller Data peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | NAND Flash Controller Data Security
+ * Field : NAND Flash Controller Data Security - s
+ * Controls whether secure or non-secure masters can access the NAND Flash
+ * Controller Data slave.
+ *  ALT_L3_SEC_NANDDATA_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_NANDDATA_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_NANDDATA_S
+#define ALT_L3_SEC_NANDDATA_S_E_SECURE      0x0
+#define ALT_L3_SEC_NANDDATA_S_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_NANDDATA_S register field. */
+#define ALT_L3_SEC_NANDDATA_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_NANDDATA_S register field. */
+#define ALT_L3_SEC_NANDDATA_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_NANDDATA_S register field. */
+#define ALT_L3_SEC_NANDDATA_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_NANDDATA_S register field value. */
+#define ALT_L3_SEC_NANDDATA_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_NANDDATA_S register field value. */
+#define ALT_L3_SEC_NANDDATA_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_NANDDATA_S register field. */
+#define ALT_L3_SEC_NANDDATA_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_NANDDATA_S field value from a register. */
+#define ALT_L3_SEC_NANDDATA_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_NANDDATA_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_NANDDATA_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_NANDDATA.
+struct ALT_L3_SEC_NANDDATA_s
+    uint32_t  s :  1;  /* NAND Flash Controller Data Security */
+/* The typedef declaration for register ALT_L3_SEC_NANDDATA. */
+typedef volatile struct ALT_L3_SEC_NANDDATA_s  ALT_L3_SEC_NANDDATA_t;
+/* The byte offset of the ALT_L3_SEC_NANDDATA register from the beginning of the component. */
+#define ALT_L3_SEC_NANDDATA_OFST        0x24
+ * Register : USB0 Registers Peripheral Security - usb0
+ * Controls security settings for USB0 Registers peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | USB0 Registers Security
+ * Field : USB0 Registers Security - s
+ * Controls whether secure or non-secure masters can access the USB0 Registers
+ * slave.
+ *  ALT_L3_SEC_USB0_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                              |       | master.
+ *  ALT_L3_SEC_USB0_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_USB0_S
+#define ALT_L3_SEC_USB0_S_E_SECURE      0x0
+#define ALT_L3_SEC_USB0_S_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_USB0_S register field. */
+#define ALT_L3_SEC_USB0_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_USB0_S register field. */
+#define ALT_L3_SEC_USB0_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_USB0_S register field. */
+#define ALT_L3_SEC_USB0_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_USB0_S register field value. */
+#define ALT_L3_SEC_USB0_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_USB0_S register field value. */
+#define ALT_L3_SEC_USB0_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_USB0_S register field. */
+#define ALT_L3_SEC_USB0_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_USB0_S field value from a register. */
+#define ALT_L3_SEC_USB0_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_USB0_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_USB0_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_USB0.
+struct ALT_L3_SEC_USB0_s
+    uint32_t  s :  1;  /* USB0 Registers Security */
+/* The typedef declaration for register ALT_L3_SEC_USB0. */
+typedef volatile struct ALT_L3_SEC_USB0_s  ALT_L3_SEC_USB0_t;
+/* The byte offset of the ALT_L3_SEC_USB0 register from the beginning of the component. */
+#define ALT_L3_SEC_USB0_OFST        0x78
+ * Register : NAND Flash Controller Registers Peripheral Security - nandregs
+ * Controls security settings for NAND Flash Controller Registers peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | NAND Flash Controller Registers Security
+ * Field : NAND Flash Controller Registers Security - s
+ * Controller Registers slave.
+ *  ALT_L3_SEC_NAND_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                              |       | master.
+ *  ALT_L3_SEC_NAND_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_NAND_S
+#define ALT_L3_SEC_NAND_S_E_SECURE      0x0
+#define ALT_L3_SEC_NAND_S_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_NAND_S register field. */
+#define ALT_L3_SEC_NAND_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_NAND_S register field. */
+#define ALT_L3_SEC_NAND_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_NAND_S register field. */
+#define ALT_L3_SEC_NAND_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_NAND_S register field value. */
+#define ALT_L3_SEC_NAND_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_NAND_S register field value. */
+#define ALT_L3_SEC_NAND_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_NAND_S register field. */
+#define ALT_L3_SEC_NAND_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_NAND_S field value from a register. */
+#define ALT_L3_SEC_NAND_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_NAND_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_NAND_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_NAND.
+struct ALT_L3_SEC_NAND_s
+    uint32_t  s :  1;  /* NAND Flash Controller Registers Security */
+/* The typedef declaration for register ALT_L3_SEC_NAND. */
+typedef volatile struct ALT_L3_SEC_NAND_s  ALT_L3_SEC_NAND_t;
+/* The byte offset of the ALT_L3_SEC_NAND register from the beginning of the component. */
+#define ALT_L3_SEC_NAND_OFST        0x7c
+ * Register : QSPI Flash Controller Data Peripheral Security - qspidata
+ * Controls security settings for QSPI Flash Controller Data peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | QSPI Flash Controller Data Security
+ * Field : QSPI Flash Controller Data Security - s
+ * Controls whether secure or non-secure masters can access the QSPI Flash
+ *  ALT_L3_SEC_QSPIDATA_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                  |       | master.
+ *  ALT_L3_SEC_QSPIDATA_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_QSPIDATA_S
+#define ALT_L3_SEC_QSPIDATA_S_E_SECURE      0x0
+#define ALT_L3_SEC_QSPIDATA_S_E_NONSECURE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_QSPIDATA_S register field. */
+#define ALT_L3_SEC_QSPIDATA_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_QSPIDATA_S register field. */
+#define ALT_L3_SEC_QSPIDATA_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_QSPIDATA_S register field. */
+#define ALT_L3_SEC_QSPIDATA_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_QSPIDATA_S register field value. */
+#define ALT_L3_SEC_QSPIDATA_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_QSPIDATA_S register field value. */
+#define ALT_L3_SEC_QSPIDATA_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_QSPIDATA_S register field. */
+#define ALT_L3_SEC_QSPIDATA_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_QSPIDATA_S field value from a register. */
+#define ALT_L3_SEC_QSPIDATA_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_QSPIDATA_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_QSPIDATA_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_QSPIDATA.
+struct ALT_L3_SEC_QSPIDATA_s
+    uint32_t  s :  1;  /* QSPI Flash Controller Data Security */
+/* The typedef declaration for register ALT_L3_SEC_QSPIDATA. */
+typedef volatile struct ALT_L3_SEC_QSPIDATA_s  ALT_L3_SEC_QSPIDATA_t;
+/* The byte offset of the ALT_L3_SEC_QSPIDATA register from the beginning of the component. */
+#define ALT_L3_SEC_QSPIDATA_OFST        0x80
+ * Register : FPGA Manager Data Peripheral Security - fpgamgrdata
+ * Controls security settings for FPGA Manager Data peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | FPGA Manager Data Security
+ * Field : FPGA Manager Data Security - s
+ * Controls whether secure or non-secure masters can access the FPGA Manager Data
+ * slave.
+ *  ALT_L3_SEC_FPGAMGRDATA_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                     |       | master.
+ *  ALT_L3_SEC_FPGAMGRDATA_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_FPGAMGRDATA_S
+#define ALT_L3_SEC_FPGAMGRDATA_S_E_SECURE       0x0
+#define ALT_L3_SEC_FPGAMGRDATA_S_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_FPGAMGRDATA_S register field value. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_FPGAMGRDATA_S register field value. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_FPGAMGRDATA_S field value from a register. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_FPGAMGRDATA_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_FPGAMGRDATA_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_FPGAMGRDATA.
+struct ALT_L3_SEC_FPGAMGRDATA_s
+    uint32_t  s :  1;  /* FPGA Manager Data Security */
+/* The typedef declaration for register ALT_L3_SEC_FPGAMGRDATA. */
+typedef volatile struct ALT_L3_SEC_FPGAMGRDATA_s  ALT_L3_SEC_FPGAMGRDATA_t;
+/* The byte offset of the ALT_L3_SEC_FPGAMGRDATA register from the beginning of the component. */
+#define ALT_L3_SEC_FPGAMGRDATA_OFST        0x84
+ * Register : HPS2FPGA AXI Bridge Registers Peripheral Security - hps2fpgaregs
+ * Controls security settings for HPS2FPGA AXI Bridge Registers peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | HPS2FPGA AXI Bridge Registers Security
+ * Field : HPS2FPGA AXI Bridge Registers Security - s
+ * Controls whether secure or non-secure masters can access the HPS2FPGA AXI Bridge
+ * Registers slave.
+ *  ALT_L3_SEC_H2F_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                             |       | master.
+ *  ALT_L3_SEC_H2F_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_H2F_S
+#define ALT_L3_SEC_H2F_S_E_SECURE       0x0
+#define ALT_L3_SEC_H2F_S_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_H2F_S register field. */
+#define ALT_L3_SEC_H2F_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_H2F_S register field. */
+#define ALT_L3_SEC_H2F_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_H2F_S register field. */
+#define ALT_L3_SEC_H2F_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_H2F_S register field value. */
+#define ALT_L3_SEC_H2F_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_H2F_S register field value. */
+#define ALT_L3_SEC_H2F_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_H2F_S register field. */
+#define ALT_L3_SEC_H2F_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_H2F_S field value from a register. */
+#define ALT_L3_SEC_H2F_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_H2F_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_H2F_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_H2F.
+struct ALT_L3_SEC_H2F_s
+    uint32_t  s :  1;  /* HPS2FPGA AXI Bridge Registers Security */
+/* The typedef declaration for register ALT_L3_SEC_H2F. */
+typedef volatile struct ALT_L3_SEC_H2F_s  ALT_L3_SEC_H2F_t;
+/* The byte offset of the ALT_L3_SEC_H2F register from the beginning of the component. */
+#define ALT_L3_SEC_H2F_OFST        0x88
+ * Register : MPU ACP Peripheral Security - acp
+ * Controls security settings for MPU ACP peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | MPU ACP Security
+ * Field : MPU ACP Security - s
+ * Controls whether secure or non-secure masters can access the MPU ACP slave.
+ *  ALT_L3_SEC_ACP_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                             |       | master.
+ *  ALT_L3_SEC_ACP_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_ACP_S
+#define ALT_L3_SEC_ACP_S_E_SECURE       0x0
+#define ALT_L3_SEC_ACP_S_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_ACP_S register field. */
+#define ALT_L3_SEC_ACP_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_ACP_S register field. */
+#define ALT_L3_SEC_ACP_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_ACP_S register field. */
+#define ALT_L3_SEC_ACP_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_ACP_S register field value. */
+#define ALT_L3_SEC_ACP_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_ACP_S register field value. */
+#define ALT_L3_SEC_ACP_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_ACP_S register field. */
+#define ALT_L3_SEC_ACP_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_ACP_S field value from a register. */
+#define ALT_L3_SEC_ACP_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_ACP_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_ACP_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_ACP.
+struct ALT_L3_SEC_ACP_s
+    uint32_t  s :  1;  /* MPU ACP Security */
+/* The typedef declaration for register ALT_L3_SEC_ACP. */
+typedef volatile struct ALT_L3_SEC_ACP_s  ALT_L3_SEC_ACP_t;
+/* The byte offset of the ALT_L3_SEC_ACP register from the beginning of the component. */
+#define ALT_L3_SEC_ACP_OFST        0x8c
+ * Register : ROM Peripheral Security - rom
+ * Controls security settings for ROM peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | ROM Security
+ * Field : ROM Security - s
+ * Controls whether secure or non-secure masters can access the ROM slave.
+ *  ALT_L3_SEC_ROM_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                             |       | master.
+ *  ALT_L3_SEC_ROM_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_ROM_S
+#define ALT_L3_SEC_ROM_S_E_SECURE       0x0
+#define ALT_L3_SEC_ROM_S_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_ROM_S register field. */
+#define ALT_L3_SEC_ROM_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_ROM_S register field. */
+#define ALT_L3_SEC_ROM_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_ROM_S register field. */
+#define ALT_L3_SEC_ROM_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_ROM_S register field value. */
+#define ALT_L3_SEC_ROM_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_ROM_S register field value. */
+#define ALT_L3_SEC_ROM_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_ROM_S register field. */
+#define ALT_L3_SEC_ROM_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_ROM_S field value from a register. */
+#define ALT_L3_SEC_ROM_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_ROM_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_ROM_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_ROM.
+struct ALT_L3_SEC_ROM_s
+    uint32_t  s :  1;  /* ROM Security */
+/* The typedef declaration for register ALT_L3_SEC_ROM. */
+typedef volatile struct ALT_L3_SEC_ROM_s  ALT_L3_SEC_ROM_t;
+/* The byte offset of the ALT_L3_SEC_ROM register from the beginning of the component. */
+#define ALT_L3_SEC_ROM_OFST        0x90
+ * Register : On-chip RAM Peripheral Security - ocram
+ * Controls security settings for On-chip RAM peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | On-chip RAM Security
+ * Field : On-chip RAM Security - s
+ * Controls whether secure or non-secure masters can access the On-chip RAM slave.
+ *  ALT_L3_SEC_OCRAM_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                               |       | master.
+ *  ALT_L3_SEC_OCRAM_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_OCRAM_S
+#define ALT_L3_SEC_OCRAM_S_E_SECURE     0x0
+#define ALT_L3_SEC_OCRAM_S_E_NONSECURE  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_OCRAM_S register field. */
+#define ALT_L3_SEC_OCRAM_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_OCRAM_S register field. */
+#define ALT_L3_SEC_OCRAM_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_OCRAM_S register field. */
+#define ALT_L3_SEC_OCRAM_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_OCRAM_S register field value. */
+#define ALT_L3_SEC_OCRAM_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_OCRAM_S register field value. */
+#define ALT_L3_SEC_OCRAM_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_OCRAM_S register field. */
+#define ALT_L3_SEC_OCRAM_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_OCRAM_S field value from a register. */
+#define ALT_L3_SEC_OCRAM_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_OCRAM_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_OCRAM_S_SET(value) (((value) << 0) & 0x00000001)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_L3_SEC_OCRAM.
+struct ALT_L3_SEC_OCRAM_s
+    uint32_t  s :  1;  /* On-chip RAM Security */
+/* The typedef declaration for register ALT_L3_SEC_OCRAM. */
+typedef volatile struct ALT_L3_SEC_OCRAM_s  ALT_L3_SEC_OCRAM_t;
+/* The byte offset of the ALT_L3_SEC_OCRAM register from the beginning of the component. */
+#define ALT_L3_SEC_OCRAM_OFST        0x94
+ * Register : SDRAM Data Peripheral Security - sdrdata
+ * Controls security settings for SDRAM Data peripheral.
+ * Register Layout
+ *  [0]    | W      | 0x0   | SDRAM Data Security
+ * Field : SDRAM Data Security - s
+ * Controls whether secure or non-secure masters can access the SDRAM Data slave.
+ *  ALT_L3_SEC_SDRDATA_S_E_SECURE    | 0x0   | The slave can only be accessed by a secure
+ * :                                 |       | master.
+ *  ALT_L3_SEC_SDRDATA_S_E_NONSECURE | 0x1   | The slave can only be accessed by a secure or
+ * Enumerated value for register field ALT_L3_SEC_SDRDATA_S
+#define ALT_L3_SEC_SDRDATA_S_E_SECURE       0x0
+#define ALT_L3_SEC_SDRDATA_S_E_NONSECURE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_SDRDATA_S register field. */
+#define ALT_L3_SEC_SDRDATA_S_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_SDRDATA_S register field. */
+#define ALT_L3_SEC_SDRDATA_S_MSB        0
+/* The width in bits of the ALT_L3_SEC_SDRDATA_S register field. */
+#define ALT_L3_SEC_SDRDATA_S_WIDTH      1
+/* The mask used to set the ALT_L3_SEC_SDRDATA_S register field value. */
+#define ALT_L3_SEC_SDRDATA_S_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_SEC_SDRDATA_S register field value. */
+#define ALT_L3_SEC_SDRDATA_S_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_SEC_SDRDATA_S register field. */
+#define ALT_L3_SEC_SDRDATA_S_RESET      0x0
+/* Extracts the ALT_L3_SEC_SDRDATA_S field value from a register. */
+#define ALT_L3_SEC_SDRDATA_S_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_SEC_SDRDATA_S register field value suitable for setting the register. */
+#define ALT_L3_SEC_SDRDATA_S_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_SEC_SDRDATA.
+struct ALT_L3_SEC_SDRDATA_s
+    uint32_t  s :  1;  /* SDRAM Data Security */
+/* The typedef declaration for register ALT_L3_SEC_SDRDATA. */
+typedef volatile struct ALT_L3_SEC_SDRDATA_s  ALT_L3_SEC_SDRDATA_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_L3_SEC_SDRDATA register from the beginning of the component. */
+#define ALT_L3_SEC_SDRDATA_OFST        0x98
+ * The struct declaration for register group ALT_L3_SECGRP.
+struct ALT_L3_SECGRP_s
+    volatile ALT_L3_SEC_L4MAIN_t       l4main;              /* ALT_L3_SEC_L4MAIN */
+    volatile ALT_L3_SEC_L4SP_t         l4sp;                /* ALT_L3_SEC_L4SP */
+    volatile ALT_L3_SEC_L4MP_t         l4mp;                /* ALT_L3_SEC_L4MP */
+    volatile ALT_L3_SEC_L4OSC1_t       l4osc1;              /* ALT_L3_SEC_L4OSC1 */
+    volatile ALT_L3_SEC_L4SPIM_t       l4spim;              /* ALT_L3_SEC_L4SPIM */
+    volatile ALT_L3_SEC_STM_t          stm;                 /* ALT_L3_SEC_STM */
+    volatile ALT_L3_SEC_LWH2F_t        lwhps2fpgaregs;      /* ALT_L3_SEC_LWH2F */
+    volatile uint32_t                  _pad_0x1c_0x1f;      /* *UNDEFINED* */
+    volatile ALT_L3_SEC_USB1_t         usb1;                /* ALT_L3_SEC_USB1 */
+    volatile ALT_L3_SEC_NANDDATA_t     nanddata;            /* ALT_L3_SEC_NANDDATA */
+    volatile uint32_t                  _pad_0x28_0x77[20];  /* *UNDEFINED* */
+    volatile ALT_L3_SEC_USB0_t         usb0;                /* ALT_L3_SEC_USB0 */
+    volatile ALT_L3_SEC_NAND_t         nandregs;            /* ALT_L3_SEC_NAND */
+    volatile ALT_L3_SEC_QSPIDATA_t     qspidata;            /* ALT_L3_SEC_QSPIDATA */
+    volatile ALT_L3_SEC_FPGAMGRDATA_t  fpgamgrdata;         /* ALT_L3_SEC_FPGAMGRDATA */
+    volatile ALT_L3_SEC_H2F_t          hps2fpgaregs;        /* ALT_L3_SEC_H2F */
+    volatile ALT_L3_SEC_ACP_t          acp;                 /* ALT_L3_SEC_ACP */
+    volatile ALT_L3_SEC_ROM_t          rom;                 /* ALT_L3_SEC_ROM */
+    volatile ALT_L3_SEC_OCRAM_t        ocram;               /* ALT_L3_SEC_OCRAM */
+    volatile ALT_L3_SEC_SDRDATA_t      sdrdata;             /* ALT_L3_SEC_SDRDATA */
+/* The typedef declaration for register group ALT_L3_SECGRP. */
+typedef volatile struct ALT_L3_SECGRP_s  ALT_L3_SECGRP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SECGRP. */
+struct ALT_L3_SECGRP_raw_s
+    volatile uint32_t  l4main;              /* ALT_L3_SEC_L4MAIN */
+    volatile uint32_t  l4sp;                /* ALT_L3_SEC_L4SP */
+    volatile uint32_t  l4mp;                /* ALT_L3_SEC_L4MP */
+    volatile uint32_t  l4osc1;              /* ALT_L3_SEC_L4OSC1 */
+    volatile uint32_t  l4spim;              /* ALT_L3_SEC_L4SPIM */
+    volatile uint32_t  stm;                 /* ALT_L3_SEC_STM */
+    volatile uint32_t  lwhps2fpgaregs;      /* ALT_L3_SEC_LWH2F */
+    volatile uint32_t  usb1;                /* ALT_L3_SEC_USB1 */
+    volatile uint32_t  nanddata;            /* ALT_L3_SEC_NANDDATA */
+    volatile uint32_t  usb0;                /* ALT_L3_SEC_USB0 */
+    volatile uint32_t  nandregs;            /* ALT_L3_SEC_NAND */
+    volatile uint32_t  qspidata;            /* ALT_L3_SEC_QSPIDATA */
+    volatile uint32_t  fpgamgrdata;         /* ALT_L3_SEC_FPGAMGRDATA */
+    volatile uint32_t  hps2fpgaregs;        /* ALT_L3_SEC_H2F */
+    volatile uint32_t  acp;                 /* ALT_L3_SEC_ACP */
+    volatile uint32_t  rom;                 /* ALT_L3_SEC_ROM */
+    volatile uint32_t  ocram;               /* ALT_L3_SEC_OCRAM */
+    volatile uint32_t  sdrdata;             /* ALT_L3_SEC_SDRDATA */
+/* The typedef declaration for the raw register contents of register group ALT_L3_SECGRP. */
+typedef volatile struct ALT_L3_SECGRP_raw_s  ALT_L3_SECGRP_raw_t;
+ * Register Group : ID Register Group - ALT_L3_IDGRP
+ * ID Register Group
+ * Contains registers that identify the ARM NIC-301 IP Core.
+ * Register : Peripheral ID4 Register - periph_id_4
+ * JEP106 continuation code
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [7:0]  | R      | 0x4   | Peripheral ID4
+ *  [31:8] | ???    | 0x0   | *UNDEFINED*
+ * Field : Peripheral ID4 - periph_id_4
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_MSB        7
+/* The width in bits of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_WIDTH      8
+/* The mask used to set the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field value. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field value. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_RESET      0x4
+/* Extracts the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 field value from a register. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field value suitable for setting the register. */
+#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_PERIPH_ID_4.
+struct ALT_L3_ID_PERIPH_ID_4_s
+    const uint32_t  periph_id_4 :  8;  /* Peripheral ID4 */
+    uint32_t                    : 24;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_4. */
+typedef volatile struct ALT_L3_ID_PERIPH_ID_4_s  ALT_L3_ID_PERIPH_ID_4_t;
+/* The byte offset of the ALT_L3_ID_PERIPH_ID_4 register from the beginning of the component. */
+#define ALT_L3_ID_PERIPH_ID_4_OFST        0xfd0
+ * Register : Peripheral ID0 Register - periph_id_0
+ * Peripheral ID0
+ * Register Layout
+ *  [7:0]  | R      | 0x1   | Part Number [7:0]
+ * Field : Part Number [7:0] - pn7to0
+ * Part Number [7:0]
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_MSB        7
+/* The width in bits of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_WIDTH      8
+/* The mask used to set the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field value. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field value. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_RESET      0x1
+/* Extracts the ALT_L3_ID_PERIPH_ID_0_PN7TO0 field value from a register. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field value suitable for setting the register. */
+#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_PERIPH_ID_0.
+struct ALT_L3_ID_PERIPH_ID_0_s
+    const uint32_t  pn7to0 :  8;  /* Part Number [7:0] */
+/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_0. */
+typedef volatile struct ALT_L3_ID_PERIPH_ID_0_s  ALT_L3_ID_PERIPH_ID_0_t;
+/* The byte offset of the ALT_L3_ID_PERIPH_ID_0 register from the beginning of the component. */
+#define ALT_L3_ID_PERIPH_ID_0_OFST        0xfe0
+ * Register : Peripheral ID1 Register - periph_id_1
+ * Peripheral ID1
+ * Register Layout
+ *  [7:0]  | R      | 0xb3  | JEP106[3:0], Part Number [11:8]
+ * Field : JEP106[3:0], Part Number [11:8] - jep3to0_pn11to8
+ * JEP106[3:0], Part Number [11:8]
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_MSB        7
+/* The width in bits of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_WIDTH      8
+/* The mask used to set the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field value. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field value. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_RESET      0xb3
+/* Extracts the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 field value from a register. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field value suitable for setting the register. */
+#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_PERIPH_ID_1.
+struct ALT_L3_ID_PERIPH_ID_1_s
+    const uint32_t  jep3to0_pn11to8 :  8;  /* JEP106[3:0], Part Number [11:8] */
+/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_1. */
+typedef volatile struct ALT_L3_ID_PERIPH_ID_1_s  ALT_L3_ID_PERIPH_ID_1_t;
+/* The byte offset of the ALT_L3_ID_PERIPH_ID_1 register from the beginning of the component. */
+#define ALT_L3_ID_PERIPH_ID_1_OFST        0xfe4
+ * Register : Peripheral ID2 Register - periph_id_2
+ * Peripheral ID2
+ * Register Layout
+ *  [7:0]  | R      | 0x6b  | Revision, JEP106 code flag, JEP106[6:4]
+ * Field : Revision, JEP106 code flag, JEP106[6:4] - rev_jepcode_jep6to4
+ * Revision, JEP106 code flag, JEP106[6:4]
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_MSB        7
+/* The width in bits of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_WIDTH      8
+/* The mask used to set the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field value. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field value. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_RESET      0x6b
+/* Extracts the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 field value from a register. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field value suitable for setting the register. */
+#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_PERIPH_ID_2.
+struct ALT_L3_ID_PERIPH_ID_2_s
+    const uint32_t  rev_jepcode_jep6to4 :  8;  /* Revision, JEP106 code flag, JEP106[6:4] */
+/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_2. */
+typedef volatile struct ALT_L3_ID_PERIPH_ID_2_s  ALT_L3_ID_PERIPH_ID_2_t;
+/* The byte offset of the ALT_L3_ID_PERIPH_ID_2 register from the beginning of the component. */
+#define ALT_L3_ID_PERIPH_ID_2_OFST        0xfe8
+ * Register : Peripheral ID3 Register - periph_id_3
+ * Peripheral ID3
+ * Register Layout
+ *  [3:0]  | R      | 0x0   | Customer Model Number
+ *  [7:4]  | R      | 0x0   | Revision
+ * Field : Customer Model Number - cust_mod_num
+ * Customer Model Number
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_MSB        3
+/* The width in bits of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_WIDTH      4
+/* The mask used to set the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field value. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field value. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_RESET      0x0
+/* Extracts the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM field value from a register. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field value suitable for setting the register. */
+#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_SET(value) (((value) << 0) & 0x0000000f)
+ * Field : Revision - rev_and
+ * Revision
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_MSB        7
+/* The width in bits of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_WIDTH      4
+/* The mask used to set the ALT_L3_ID_PERIPH_ID_3_REV_AND register field value. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_SET_MSK    0x000000f0
+/* The mask used to clear the ALT_L3_ID_PERIPH_ID_3_REV_AND register field value. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_CLR_MSK    0xffffff0f
+/* The reset value of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_RESET      0x0
+/* Extracts the ALT_L3_ID_PERIPH_ID_3_REV_AND field value from a register. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_GET(value) (((value) & 0x000000f0) >> 4)
+/* Produces a ALT_L3_ID_PERIPH_ID_3_REV_AND register field value suitable for setting the register. */
+#define ALT_L3_ID_PERIPH_ID_3_REV_AND_SET(value) (((value) << 4) & 0x000000f0)
+ * The struct declaration for register ALT_L3_ID_PERIPH_ID_3.
+struct ALT_L3_ID_PERIPH_ID_3_s
+    const uint32_t  cust_mod_num :  4;  /* Customer Model Number */
+    const uint32_t  rev_and      :  4;  /* Revision */
+/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_3. */
+typedef volatile struct ALT_L3_ID_PERIPH_ID_3_s  ALT_L3_ID_PERIPH_ID_3_t;
+/* The byte offset of the ALT_L3_ID_PERIPH_ID_3 register from the beginning of the component. */
+#define ALT_L3_ID_PERIPH_ID_3_OFST        0xfec
+ * Register : Component ID0 Register - comp_id_0
+ * Component ID0
+ * Register Layout
+ *  [7:0]  | R      | 0xd   | Preamble
+ * Field : Preamble - preamble
+ * Preamble
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_MSB        7
+/* The width in bits of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_WIDTH      8
+/* The mask used to set the ALT_L3_ID_COMP_ID_0_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_COMP_ID_0_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_RESET      0xd
+/* Extracts the ALT_L3_ID_COMP_ID_0_PREAMBLE field value from a register. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_COMP_ID_0_PREAMBLE register field value suitable for setting the register. */
+#define ALT_L3_ID_COMP_ID_0_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_COMP_ID_0.
+struct ALT_L3_ID_COMP_ID_0_s
+    const uint32_t  preamble :  8;  /* Preamble */
+/* The typedef declaration for register ALT_L3_ID_COMP_ID_0. */
+typedef volatile struct ALT_L3_ID_COMP_ID_0_s  ALT_L3_ID_COMP_ID_0_t;
+/* The byte offset of the ALT_L3_ID_COMP_ID_0 register from the beginning of the component. */
+#define ALT_L3_ID_COMP_ID_0_OFST        0xff0
+ * Register : Component ID1 Register - comp_id_1
+ * Component ID1
+ * Register Layout
+ *  [7:0]  | R      | 0xf0  | Generic IP component class, Preamble
+ * Field : Generic IP component class, Preamble - genipcompcls_preamble
+ * Generic IP component class, Preamble
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_MSB        7
+/* The width in bits of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_WIDTH      8
+/* The mask used to set the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_RESET      0xf0
+/* Extracts the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE field value from a register. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field value suitable for setting the register. */
+#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_COMP_ID_1.
+struct ALT_L3_ID_COMP_ID_1_s
+    const uint32_t  genipcompcls_preamble :  8;  /* Generic IP component class, Preamble */
+/* The typedef declaration for register ALT_L3_ID_COMP_ID_1. */
+typedef volatile struct ALT_L3_ID_COMP_ID_1_s  ALT_L3_ID_COMP_ID_1_t;
+/* The byte offset of the ALT_L3_ID_COMP_ID_1 register from the beginning of the component. */
+#define ALT_L3_ID_COMP_ID_1_OFST        0xff4
+ * Register : Component ID2 Register - comp_id_2
+ * Component ID2
+ * Register Layout
+ *  [7:0]  | R      | 0x5   | Preamble
+ * Preamble
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_MSB        7
+/* The width in bits of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_WIDTH      8
+/* The mask used to set the ALT_L3_ID_COMP_ID_2_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_COMP_ID_2_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_RESET      0x5
+/* Extracts the ALT_L3_ID_COMP_ID_2_PREAMBLE field value from a register. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_COMP_ID_2_PREAMBLE register field value suitable for setting the register. */
+#define ALT_L3_ID_COMP_ID_2_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_COMP_ID_2.
+struct ALT_L3_ID_COMP_ID_2_s
+/* The typedef declaration for register ALT_L3_ID_COMP_ID_2. */
+typedef volatile struct ALT_L3_ID_COMP_ID_2_s  ALT_L3_ID_COMP_ID_2_t;
+/* The byte offset of the ALT_L3_ID_COMP_ID_2 register from the beginning of the component. */
+#define ALT_L3_ID_COMP_ID_2_OFST        0xff8
+ * Register : Component ID3 Register - comp_id_3
+ * Component ID3
+ * Register Layout
+ *  [7:0]  | R      | 0xb1  | Preamble
+ * Preamble
+/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_MSB        7
+/* The width in bits of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_WIDTH      8
+/* The mask used to set the ALT_L3_ID_COMP_ID_3_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_L3_ID_COMP_ID_3_PREAMBLE register field value. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_CLR_MSK    0xffffff00
+/* The reset value of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_RESET      0xb1
+/* Extracts the ALT_L3_ID_COMP_ID_3_PREAMBLE field value from a register. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_L3_ID_COMP_ID_3_PREAMBLE register field value suitable for setting the register. */
+#define ALT_L3_ID_COMP_ID_3_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_L3_ID_COMP_ID_3.
+struct ALT_L3_ID_COMP_ID_3_s
+/* The typedef declaration for register ALT_L3_ID_COMP_ID_3. */
+typedef volatile struct ALT_L3_ID_COMP_ID_3_s  ALT_L3_ID_COMP_ID_3_t;
+/* The byte offset of the ALT_L3_ID_COMP_ID_3 register from the beginning of the component. */
+#define ALT_L3_ID_COMP_ID_3_OFST        0xffc
+ * The struct declaration for register group ALT_L3_IDGRP.
+struct ALT_L3_IDGRP_s
+    volatile uint32_t                 _pad_0x0_0xfcf[1012];  /* *UNDEFINED* */
+    volatile ALT_L3_ID_PERIPH_ID_4_t  periph_id_4;           /* ALT_L3_ID_PERIPH_ID_4 */
+    volatile uint32_t                 _pad_0xfd4_0xfdf[3];   /* *UNDEFINED* */
+    volatile ALT_L3_ID_PERIPH_ID_0_t  periph_id_0;           /* ALT_L3_ID_PERIPH_ID_0 */
+    volatile ALT_L3_ID_PERIPH_ID_1_t  periph_id_1;           /* ALT_L3_ID_PERIPH_ID_1 */
+    volatile ALT_L3_ID_PERIPH_ID_2_t  periph_id_2;           /* ALT_L3_ID_PERIPH_ID_2 */
+    volatile ALT_L3_ID_PERIPH_ID_3_t  periph_id_3;           /* ALT_L3_ID_PERIPH_ID_3 */
+    volatile ALT_L3_ID_COMP_ID_0_t    comp_id_0;             /* ALT_L3_ID_COMP_ID_0 */
+    volatile ALT_L3_ID_COMP_ID_1_t    comp_id_1;             /* ALT_L3_ID_COMP_ID_1 */
+    volatile ALT_L3_ID_COMP_ID_2_t    comp_id_2;             /* ALT_L3_ID_COMP_ID_2 */
+    volatile ALT_L3_ID_COMP_ID_3_t    comp_id_3;             /* ALT_L3_ID_COMP_ID_3 */
+/* The typedef declaration for register group ALT_L3_IDGRP. */
+typedef volatile struct ALT_L3_IDGRP_s  ALT_L3_IDGRP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_IDGRP. */
+struct ALT_L3_IDGRP_raw_s
+    volatile uint32_t  periph_id_4;           /* ALT_L3_ID_PERIPH_ID_4 */
+    volatile uint32_t  periph_id_0;           /* ALT_L3_ID_PERIPH_ID_0 */
+    volatile uint32_t  periph_id_1;           /* ALT_L3_ID_PERIPH_ID_1 */
+    volatile uint32_t  periph_id_2;           /* ALT_L3_ID_PERIPH_ID_2 */
+    volatile uint32_t  periph_id_3;           /* ALT_L3_ID_PERIPH_ID_3 */
+    volatile uint32_t  comp_id_0;             /* ALT_L3_ID_COMP_ID_0 */
+    volatile uint32_t  comp_id_1;             /* ALT_L3_ID_COMP_ID_1 */
+    volatile uint32_t  comp_id_2;             /* ALT_L3_ID_COMP_ID_2 */
+    volatile uint32_t  comp_id_3;             /* ALT_L3_ID_COMP_ID_3 */
+/* The typedef declaration for the raw register contents of register group ALT_L3_IDGRP. */
+typedef volatile struct ALT_L3_IDGRP_raw_s  ALT_L3_IDGRP_raw_t;
+ * Register Group : Master Register Group - ALT_L3_MSTGRP
+ * Master Register Group
+ * Registers associated with master interfaces in the L3 Interconnect. Note that a
+ * master in the L3 Interconnect connects to a slave in a module.
+ * Register Group : L4 MAIN - ALT_L3_MST_L4MAIN
+ * L4 MAIN
+ * Registers associated with the L4 MAIN master. This master is used to access the
+ * APB slaves on the L4 MAIN bus.
+ * Register : Bus Matrix Issuing Functionality Modification Register - fn_mod_bm_iss
+ * Sets the issuing capability of the preceding switch arbitration scheme to
+ * multiple or single outstanding transactions.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | ALT_L3_FN_MOD_BM_ISS_RD
+ *  [1]    | RW     | 0x0   | ALT_L3_FN_MOD_BM_ISS_WR
+ *  [31:2] | ???    | 0x0   | *UNDEFINED*
+ * Field : rd
+ * Field Enumeration Values:
+ *  Enum                             | Value | Description
+ *  ALT_L3_FN_MOD_BM_ISS_RD_E_MULT   | 0x0   | Multiple outstanding read transactions
+ *  ALT_L3_FN_MOD_BM_ISS_RD_E_SINGLE | 0x1   | Only a single outstanding read transaction
+ * Enumerated value for register field ALT_L3_FN_MOD_BM_ISS_RD
+ * Multiple outstanding read transactions
+#define ALT_L3_FN_MOD_BM_ISS_RD_E_MULT      0x0
+ * Only a single outstanding read transaction
+#define ALT_L3_FN_MOD_BM_ISS_RD_E_SINGLE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_MSB        0
+/* The width in bits of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_WIDTH      1
+/* The mask used to set the ALT_L3_FN_MOD_BM_ISS_RD register field value. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_FN_MOD_BM_ISS_RD register field value. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_RESET      0x0
+/* Extracts the ALT_L3_FN_MOD_BM_ISS_RD field value from a register. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_FN_MOD_BM_ISS_RD register field value suitable for setting the register. */
+#define ALT_L3_FN_MOD_BM_ISS_RD_SET(value) (((value) << 0) & 0x00000001)
+ * Field : wr
+ *  ALT_L3_FN_MOD_BM_ISS_WR_E_MULT   | 0x0   | Multiple outstanding write transactions
+ *  ALT_L3_FN_MOD_BM_ISS_WR_E_SINGLE | 0x1   | Only a single outstanding write transaction
+ * Field Access Macros:
+ * Enumerated value for register field ALT_L3_FN_MOD_BM_ISS_WR
+ * Multiple outstanding write transactions
+#define ALT_L3_FN_MOD_BM_ISS_WR_E_MULT      0x0
+ * Only a single outstanding write transaction
+#define ALT_L3_FN_MOD_BM_ISS_WR_E_SINGLE    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_MSB        1
+/* The width in bits of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_WIDTH      1
+/* The mask used to set the ALT_L3_FN_MOD_BM_ISS_WR register field value. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_FN_MOD_BM_ISS_WR register field value. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_RESET      0x0
+/* Extracts the ALT_L3_FN_MOD_BM_ISS_WR field value from a register. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_FN_MOD_BM_ISS_WR register field value suitable for setting the register. */
+#define ALT_L3_FN_MOD_BM_ISS_WR_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_L3_FN_MOD_BM_ISS.
+struct ALT_L3_FN_MOD_BM_ISS_s
+    uint32_t  rd :  1;  /* ALT_L3_FN_MOD_BM_ISS_RD */
+    uint32_t  wr :  1;  /* ALT_L3_FN_MOD_BM_ISS_WR */
+    uint32_t     : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_FN_MOD_BM_ISS. */
+typedef volatile struct ALT_L3_FN_MOD_BM_ISS_s  ALT_L3_FN_MOD_BM_ISS_t;
+/* The byte offset of the ALT_L3_FN_MOD_BM_ISS register from the beginning of the component. */
+#define ALT_L3_FN_MOD_BM_ISS_OFST        0x8
+/* The address of the ALT_L3_FN_MOD_BM_ISS register. */
+#define ALT_L3_FN_MOD_BM_ISS_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD_BM_ISS_OFST))
+ * The struct declaration for register group ALT_L3_MST_L4MAIN.
+struct ALT_L3_MST_L4MAIN_s
+    volatile uint32_t                _pad_0x0_0x7[2];  /* *UNDEFINED* */
+    volatile ALT_L3_FN_MOD_BM_ISS_t  fn_mod_bm_iss;    /* ALT_L3_FN_MOD_BM_ISS */
+/* The typedef declaration for register group ALT_L3_MST_L4MAIN. */
+typedef volatile struct ALT_L3_MST_L4MAIN_s  ALT_L3_MST_L4MAIN_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4MAIN. */
+struct ALT_L3_MST_L4MAIN_raw_s
+    volatile uint32_t  fn_mod_bm_iss;    /* ALT_L3_FN_MOD_BM_ISS */
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4MAIN. */
+typedef volatile struct ALT_L3_MST_L4MAIN_raw_s  ALT_L3_MST_L4MAIN_raw_t;
+ * Register Group : L4 SP - ALT_L3_MST_L4SP
+ * L4 SP
+ * Registers associated with the L4 SP master. This master is used to access the
+ * APB slaves on the L4 SP bus.
+ * The struct declaration for register group ALT_L3_MST_L4SP.
+struct ALT_L3_MST_L4SP_s
+/* The typedef declaration for register group ALT_L3_MST_L4SP. */
+typedef volatile struct ALT_L3_MST_L4SP_s  ALT_L3_MST_L4SP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4SP. */
+struct ALT_L3_MST_L4SP_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4SP. */
+typedef volatile struct ALT_L3_MST_L4SP_raw_s  ALT_L3_MST_L4SP_raw_t;
+ * Register Group : L4 MP - ALT_L3_MST_L4MP
+ * L4 MP
+ * Registers associated with the L4 MP master. This master is used to access the
+ * APB slaves on the L4 MP bus.
+ * The struct declaration for register group ALT_L3_MST_L4MP.
+struct ALT_L3_MST_L4MP_s
+/* The typedef declaration for register group ALT_L3_MST_L4MP. */
+typedef volatile struct ALT_L3_MST_L4MP_s  ALT_L3_MST_L4MP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4MP. */
+struct ALT_L3_MST_L4MP_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4MP. */
+typedef volatile struct ALT_L3_MST_L4MP_raw_s  ALT_L3_MST_L4MP_raw_t;
+ * Register Group : L4 OSC1 - ALT_L3_MST_L4OSC1
+ * L4 OSC1
+ * Registers associated with the L4 OSC1 master. This master is used to access the
+ * APB slaves on the L4 OSC1 bus.
+ * The struct declaration for register group ALT_L3_MST_L4OSC1.
+struct ALT_L3_MST_L4OSC1_s
+/* The typedef declaration for register group ALT_L3_MST_L4OSC1. */
+typedef volatile struct ALT_L3_MST_L4OSC1_s  ALT_L3_MST_L4OSC1_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4OSC1. */
+struct ALT_L3_MST_L4OSC1_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4OSC1. */
+typedef volatile struct ALT_L3_MST_L4OSC1_raw_s  ALT_L3_MST_L4OSC1_raw_t;
+ * Register Group : L4 SPIM - ALT_L3_MST_L4SPIM
+ * L4 SPIM
+ * Registers associated with the L4 SPIM master. This master is used to access the
+ * APB slaves on the L4 SPIM bus.
+ * The struct declaration for register group ALT_L3_MST_L4SPIM.
+struct ALT_L3_MST_L4SPIM_s
+/* The typedef declaration for register group ALT_L3_MST_L4SPIM. */
+typedef volatile struct ALT_L3_MST_L4SPIM_s  ALT_L3_MST_L4SPIM_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4SPIM. */
+struct ALT_L3_MST_L4SPIM_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4SPIM. */
+typedef volatile struct ALT_L3_MST_L4SPIM_raw_s  ALT_L3_MST_L4SPIM_raw_t;
+ * Register Group : STM - ALT_L3_MST_STM
+ * STM
+ * Registers associated with the STM master. This master is used to access the STM
+ * AXI slave.
+ * Register : Issuing Functionality Modification Register - fn_mod
+ * Sets the block issuing capability to multiple or single outstanding
+ * transactions.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | ALT_L3_FN_MOD_RD
+ *  [1]    | RW     | 0x0   | ALT_L3_FN_MOD_WR
+ * Field : rd
+ *  ALT_L3_FN_MOD_RD_E_MULT   | 0x0   | Multiple outstanding read transactions
+ *  ALT_L3_FN_MOD_RD_E_SINGLE | 0x1   | Only a single outstanding read transaction
+ * Enumerated value for register field ALT_L3_FN_MOD_RD
+#define ALT_L3_FN_MOD_RD_E_MULT     0x0
+#define ALT_L3_FN_MOD_RD_E_SINGLE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_RD register field. */
+#define ALT_L3_FN_MOD_RD_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_RD register field. */
+#define ALT_L3_FN_MOD_RD_MSB        0
+/* The width in bits of the ALT_L3_FN_MOD_RD register field. */
+#define ALT_L3_FN_MOD_RD_WIDTH      1
+/* The mask used to set the ALT_L3_FN_MOD_RD register field value. */
+#define ALT_L3_FN_MOD_RD_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_FN_MOD_RD register field value. */
+#define ALT_L3_FN_MOD_RD_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_FN_MOD_RD register field. */
+#define ALT_L3_FN_MOD_RD_RESET      0x0
+/* Extracts the ALT_L3_FN_MOD_RD field value from a register. */
+#define ALT_L3_FN_MOD_RD_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_FN_MOD_RD register field value suitable for setting the register. */
+#define ALT_L3_FN_MOD_RD_SET(value) (((value) << 0) & 0x00000001)
+ * Field : wr
+ *  ALT_L3_FN_MOD_WR_E_MULT   | 0x0   | Multiple outstanding write transactions
+ *  ALT_L3_FN_MOD_WR_E_SINGLE | 0x1   | Only a single outstanding write transaction
+ * Enumerated value for register field ALT_L3_FN_MOD_WR
+#define ALT_L3_FN_MOD_WR_E_MULT     0x0
+#define ALT_L3_FN_MOD_WR_E_SINGLE   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_WR register field. */
+#define ALT_L3_FN_MOD_WR_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_WR register field. */
+#define ALT_L3_FN_MOD_WR_MSB        1
+/* The width in bits of the ALT_L3_FN_MOD_WR register field. */
+#define ALT_L3_FN_MOD_WR_WIDTH      1
+/* The mask used to set the ALT_L3_FN_MOD_WR register field value. */
+#define ALT_L3_FN_MOD_WR_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_FN_MOD_WR register field value. */
+#define ALT_L3_FN_MOD_WR_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_FN_MOD_WR register field. */
+#define ALT_L3_FN_MOD_WR_RESET      0x0
+/* Extracts the ALT_L3_FN_MOD_WR field value from a register. */
+#define ALT_L3_FN_MOD_WR_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_FN_MOD_WR register field value suitable for setting the register. */
+#define ALT_L3_FN_MOD_WR_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_L3_FN_MOD.
+struct ALT_L3_FN_MOD_s
+    uint32_t  rd :  1;  /* ALT_L3_FN_MOD_RD */
+    uint32_t  wr :  1;  /* ALT_L3_FN_MOD_WR */
+/* The typedef declaration for register ALT_L3_FN_MOD. */
+typedef volatile struct ALT_L3_FN_MOD_s  ALT_L3_FN_MOD_t;
+/* The byte offset of the ALT_L3_FN_MOD register from the beginning of the component. */
+#define ALT_L3_FN_MOD_OFST        0x108
+/* The address of the ALT_L3_FN_MOD register. */
+#define ALT_L3_FN_MOD_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD_OFST))
+ * The struct declaration for register group ALT_L3_MST_STM.
+struct ALT_L3_MST_STM_s
+    volatile uint32_t                _pad_0xc_0x107[63];  /* *UNDEFINED* */
+    volatile ALT_L3_FN_MOD_t         fn_mod;              /* ALT_L3_FN_MOD */
+/* The typedef declaration for register group ALT_L3_MST_STM. */
+typedef volatile struct ALT_L3_MST_STM_s  ALT_L3_MST_STM_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_STM. */
+struct ALT_L3_MST_STM_raw_s
+    volatile uint32_t  fn_mod;              /* ALT_L3_FN_MOD */
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_STM. */
+typedef volatile struct ALT_L3_MST_STM_raw_s  ALT_L3_MST_STM_raw_t;
+ * Register Group : LWHPS2FPGA - ALT_L3_MST_LWH2F
+ * LWHPS2FPGA
+ * Registers associated with the LWHPS2FPGA AXI Bridge master. This master is used
+ * to access the LWHPS2FPGA AXI Bridge slave. This slave is used to access the
+ * registers for all 3 AXI bridges and to access slaves in the FPGA connected to
+ * the LWHPS2FPGA AXI Bridge.
+ * The struct declaration for register group ALT_L3_MST_LWH2F.
+struct ALT_L3_MST_LWH2F_s
+/* The typedef declaration for register group ALT_L3_MST_LWH2F. */
+typedef volatile struct ALT_L3_MST_LWH2F_s  ALT_L3_MST_LWH2F_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_LWH2F. */
+struct ALT_L3_MST_LWH2F_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_LWH2F. */
+typedef volatile struct ALT_L3_MST_LWH2F_raw_s  ALT_L3_MST_LWH2F_raw_t;
+ * Register Group : USB1 - ALT_L3_MST_USB1
+ * USB1
+ * Registers associated with the USB1 master. This master is used to access the
+ * registers in USB1.
+ * Register : AHB Control Register - ahb_cntl
+ * Sets the block issuing capability to one outstanding transaction.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | ALT_L3_AHB_CNTL_DECERR_EN
+ *  [1]    | RW     | 0x0   | ALT_L3_AHB_CNTL_FORCE_INCR
+ * Field : decerr_en
+ *  ALT_L3_AHB_CNTL_DECERR_EN_E_DIS | 0x0   | No DECERR response.
+ *  ALT_L3_AHB_CNTL_DECERR_EN_E_EN  | 0x1   | If the AHB protocol conversion function receives
+ * :                                |       | an unaligned address or a write data beat
+ * :                                |       | without all the byte strobes set, creates a
+ * :                                |       | DECERR response.
+ * Enumerated value for register field ALT_L3_AHB_CNTL_DECERR_EN
+ * No DECERR response.
+#define ALT_L3_AHB_CNTL_DECERR_EN_E_DIS 0x0
+ * If the AHB protocol conversion function receives an unaligned address or a write
+ * data beat without all the byte strobes set, creates a DECERR response.
+#define ALT_L3_AHB_CNTL_DECERR_EN_E_EN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_MSB        0
+/* The width in bits of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_WIDTH      1
+/* The mask used to set the ALT_L3_AHB_CNTL_DECERR_EN register field value. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_AHB_CNTL_DECERR_EN register field value. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_RESET      0x0
+/* Extracts the ALT_L3_AHB_CNTL_DECERR_EN field value from a register. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_AHB_CNTL_DECERR_EN register field value suitable for setting the register. */
+#define ALT_L3_AHB_CNTL_DECERR_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : force_incr
+ *  ALT_L3_AHB_CNTL_FORCE_INCR_E_DIS | 0x0   | Multiple outstanding write transactions
+ *  ALT_L3_AHB_CNTL_FORCE_INCR_E_EN  | 0x1   | If a beat is received that has no write data
+ * :                                 |       | strobes set, that write data beat is replaced
+ * :                                 |       | with an IDLE beat. Also, causes all transactions
+ * :                                 |       | that are to be output to the AHB domain to be an
+ * :                                 |       | undefined length INCR.
+ * Enumerated value for register field ALT_L3_AHB_CNTL_FORCE_INCR
+#define ALT_L3_AHB_CNTL_FORCE_INCR_E_DIS    0x0
+ * If a beat is received that has no write data strobes set, that write data beat
+ * is replaced with an IDLE beat. Also, causes all transactions that are to be
+ * output to the AHB domain to be an undefined length INCR.
+#define ALT_L3_AHB_CNTL_FORCE_INCR_E_EN     0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_MSB        1
+/* The width in bits of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_WIDTH      1
+/* The mask used to set the ALT_L3_AHB_CNTL_FORCE_INCR register field value. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_AHB_CNTL_FORCE_INCR register field value. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_RESET      0x0
+/* Extracts the ALT_L3_AHB_CNTL_FORCE_INCR field value from a register. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_AHB_CNTL_FORCE_INCR register field value suitable for setting the register. */
+#define ALT_L3_AHB_CNTL_FORCE_INCR_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_L3_AHB_CNTL.
+struct ALT_L3_AHB_CNTL_s
+    uint32_t  decerr_en  :  1;  /* ALT_L3_AHB_CNTL_DECERR_EN */
+    uint32_t  force_incr :  1;  /* ALT_L3_AHB_CNTL_FORCE_INCR */
+/* The typedef declaration for register ALT_L3_AHB_CNTL. */
+typedef volatile struct ALT_L3_AHB_CNTL_s  ALT_L3_AHB_CNTL_t;
+/* The byte offset of the ALT_L3_AHB_CNTL register from the beginning of the component. */
+#define ALT_L3_AHB_CNTL_OFST        0x44
+/* The address of the ALT_L3_AHB_CNTL register. */
+#define ALT_L3_AHB_CNTL_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_AHB_CNTL_OFST))
+ * The struct declaration for register group ALT_L3_MST_USB1.
+struct ALT_L3_MST_USB1_s
+    volatile uint32_t                _pad_0xc_0x43[14];  /* *UNDEFINED* */
+    volatile ALT_L3_AHB_CNTL_t       ahb_cntl;           /* ALT_L3_AHB_CNTL */
+/* The typedef declaration for register group ALT_L3_MST_USB1. */
+typedef volatile struct ALT_L3_MST_USB1_s  ALT_L3_MST_USB1_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_USB1. */
+struct ALT_L3_MST_USB1_raw_s
+    volatile uint32_t  ahb_cntl;           /* ALT_L3_AHB_CNTL */
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_USB1. */
+typedef volatile struct ALT_L3_MST_USB1_raw_s  ALT_L3_MST_USB1_raw_t;
+ * Register Group : NANDDATA - ALT_L3_MST_NANDDATA
+ * NANDDATA
+ * Registers associated with the NANDDATA master. This master is used to access
+ * data in the NAND flash controller.
+ * The struct declaration for register group ALT_L3_MST_NANDDATA.
+struct ALT_L3_MST_NANDDATA_s
+/* The typedef declaration for register group ALT_L3_MST_NANDDATA. */
+typedef volatile struct ALT_L3_MST_NANDDATA_s  ALT_L3_MST_NANDDATA_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_NANDDATA. */
+struct ALT_L3_MST_NANDDATA_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_NANDDATA. */
+typedef volatile struct ALT_L3_MST_NANDDATA_raw_s  ALT_L3_MST_NANDDATA_raw_t;
+ * Register Group : USB0 - ALT_L3_MST_USB0
+ * USB0
+ * Registers associated with the USB0 master. This master is used to access the
+ * registers in USB0.
+ * The struct declaration for register group ALT_L3_MST_USB0.
+struct ALT_L3_MST_USB0_s
+/* The typedef declaration for register group ALT_L3_MST_USB0. */
+typedef volatile struct ALT_L3_MST_USB0_s  ALT_L3_MST_USB0_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_USB0. */
+struct ALT_L3_MST_USB0_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_USB0. */
+typedef volatile struct ALT_L3_MST_USB0_raw_s  ALT_L3_MST_USB0_raw_t;
+ * Register Group : NANDREGS - ALT_L3_MST_NAND
+ * NANDREGS
+ * Registers associated with the NANDREGS master. This master is used to access the
+ * registers in the NAND flash controller.
+ * The struct declaration for register group ALT_L3_MST_NAND.
+struct ALT_L3_MST_NAND_s
+/* The typedef declaration for register group ALT_L3_MST_NAND. */
+typedef volatile struct ALT_L3_MST_NAND_s  ALT_L3_MST_NAND_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_NAND. */
+struct ALT_L3_MST_NAND_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_NAND. */
+typedef volatile struct ALT_L3_MST_NAND_raw_s  ALT_L3_MST_NAND_raw_t;
+ * Register Group : QSPIDATA - ALT_L3_MST_QSPIDATA
+ * QSPIDATA
+ * Registers associated with the QSPIDATA master. This master is used to access
+ * data in the QSPI flash controller.
+ * The struct declaration for register group ALT_L3_MST_QSPIDATA.
+struct ALT_L3_MST_QSPIDATA_s
+/* The typedef declaration for register group ALT_L3_MST_QSPIDATA. */
+typedef volatile struct ALT_L3_MST_QSPIDATA_s  ALT_L3_MST_QSPIDATA_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_QSPIDATA. */
+struct ALT_L3_MST_QSPIDATA_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_QSPIDATA. */
+typedef volatile struct ALT_L3_MST_QSPIDATA_raw_s  ALT_L3_MST_QSPIDATA_raw_t;
+ * Register Group : FPGAMGRDATA - ALT_L3_MST_FPGAMGRDATA
+ * FPGAMGRDATA
+ * Registers associated with the FPGAMGRDATA master. This master is used to send
+ * FPGA configuration image data to the FPGA Manager.
+ * Register : Write Tidemark - wr_tidemark
+ * Controls the release of the transaction in the write data FIFO.
+ * Register Layout
+ *  [3:0]  | RW     | 0x4   | Level
+ *  [31:4] | ???    | 0x0   | *UNDEFINED*
+ * Field : Level - level
+ * Stalls the transaction in the write data FIFO until the number of occupied slots
+ * in the write data FIFO exceeds the level. Note that the transaction is released
+ * before this level is achieved if the network receives the WLAST beat or the
+ * write FIFO becomes full.
+/* The Least Significant Bit (LSB) position of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_MSB        3
+/* The width in bits of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_WIDTH      4
+/* The mask used to set the ALT_L3_WR_TIDEMARK_LEVEL register field value. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_L3_WR_TIDEMARK_LEVEL register field value. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_RESET      0x4
+/* Extracts the ALT_L3_WR_TIDEMARK_LEVEL field value from a register. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_L3_WR_TIDEMARK_LEVEL register field value suitable for setting the register. */
+#define ALT_L3_WR_TIDEMARK_LEVEL_SET(value) (((value) << 0) & 0x0000000f)
+ * The struct declaration for register ALT_L3_WR_TIDEMARK.
+struct ALT_L3_WR_TIDEMARK_s
+    uint32_t  level :  4;  /* Level */
+    uint32_t        : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_WR_TIDEMARK. */
+typedef volatile struct ALT_L3_WR_TIDEMARK_s  ALT_L3_WR_TIDEMARK_t;
+/* The byte offset of the ALT_L3_WR_TIDEMARK register from the beginning of the component. */
+#define ALT_L3_WR_TIDEMARK_OFST        0x40
+/* The address of the ALT_L3_WR_TIDEMARK register. */
+#define ALT_L3_WR_TIDEMARK_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_WR_TIDEMARK_OFST))
+ * The struct declaration for register group ALT_L3_MST_FPGAMGRDATA.
+struct ALT_L3_MST_FPGAMGRDATA_s
+    volatile uint32_t                _pad_0xc_0x3f[13];    /* *UNDEFINED* */
+    volatile ALT_L3_WR_TIDEMARK_t    wr_tidemark;          /* ALT_L3_WR_TIDEMARK */
+    volatile uint32_t                _pad_0x44_0x107[49];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_L3_MST_FPGAMGRDATA. */
+typedef volatile struct ALT_L3_MST_FPGAMGRDATA_s  ALT_L3_MST_FPGAMGRDATA_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_FPGAMGRDATA. */
+struct ALT_L3_MST_FPGAMGRDATA_raw_s
+    volatile uint32_t  wr_tidemark;          /* ALT_L3_WR_TIDEMARK */
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_FPGAMGRDATA. */
+typedef volatile struct ALT_L3_MST_FPGAMGRDATA_raw_s  ALT_L3_MST_FPGAMGRDATA_raw_t;
+ * Register Group : HPS2FPGA - ALT_L3_MST_H2F
+ * HPS2FPGA
+ * Registers associated with the HPS2FPGA AXI Bridge master. This master is used to
+ * access the HPS2FPGA AXI Bridge slave. This slave is used to access slaves in the
+ * FPGA connected to the HPS2FPGA AXI Bridge.
+ * The struct declaration for register group ALT_L3_MST_H2F.
+struct ALT_L3_MST_H2F_s
+/* The typedef declaration for register group ALT_L3_MST_H2F. */
+typedef volatile struct ALT_L3_MST_H2F_s  ALT_L3_MST_H2F_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_H2F. */
+struct ALT_L3_MST_H2F_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_H2F. */
+typedef volatile struct ALT_L3_MST_H2F_raw_s  ALT_L3_MST_H2F_raw_t;
+ * Register Group : ACP - ALT_L3_MST_ACP
+ * ACP
+ * Registers associated with the ACP master. This master is used to access the MPU
+ * ACP slave via the ACP ID Mapper.
+ * The struct declaration for register group ALT_L3_MST_ACP.
+struct ALT_L3_MST_ACP_s
+/* The typedef declaration for register group ALT_L3_MST_ACP. */
+typedef volatile struct ALT_L3_MST_ACP_s  ALT_L3_MST_ACP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_ACP. */
+struct ALT_L3_MST_ACP_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_ACP. */
+typedef volatile struct ALT_L3_MST_ACP_raw_s  ALT_L3_MST_ACP_raw_t;
+ * Register Group : Boot ROM - ALT_L3_MST_ROM
+ * Boot ROM
+ * Registers associated with the Boot ROM master. This master is used to access the
+ * contents of the Boot ROM.
+ * The struct declaration for register group ALT_L3_MST_ROM.
+struct ALT_L3_MST_ROM_s
+/* The typedef declaration for register group ALT_L3_MST_ROM. */
+typedef volatile struct ALT_L3_MST_ROM_s  ALT_L3_MST_ROM_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_ROM. */
+struct ALT_L3_MST_ROM_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_ROM. */
+typedef volatile struct ALT_L3_MST_ROM_raw_s  ALT_L3_MST_ROM_raw_t;
+ * Register Group : On-chip RAM - ALT_L3_MST_OCRAM
+ * On-chip RAM
+ * Registers associated with the On-chip RAM master. This master is used to access
+ * the contents of the On-chip RAM.
+ * The struct declaration for register group ALT_L3_MST_OCRAM.
+struct ALT_L3_MST_OCRAM_s
+/* The typedef declaration for register group ALT_L3_MST_OCRAM. */
+typedef volatile struct ALT_L3_MST_OCRAM_s  ALT_L3_MST_OCRAM_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MST_OCRAM. */
+struct ALT_L3_MST_OCRAM_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_MST_OCRAM. */
+typedef volatile struct ALT_L3_MST_OCRAM_raw_s  ALT_L3_MST_OCRAM_raw_t;
+ * The struct declaration for register group ALT_L3_MSTGRP.
+struct ALT_L3_MSTGRP_s
+    volatile ALT_L3_MST_L4MAIN_t       mastergrp_l4main;            /* ALT_L3_MST_L4MAIN */
+    volatile uint32_t                  _pad_0xc_0xfff[1021];        /* *UNDEFINED* */
+    volatile ALT_L3_MST_L4SP_t         mastergrp_l4sp;              /* ALT_L3_MST_L4SP */
+    volatile uint32_t                  _pad_0x100c_0x1fff[1021];    /* *UNDEFINED* */
+    volatile ALT_L3_MST_L4MP_t         mastergrp_l4mp;              /* ALT_L3_MST_L4MP */
+    volatile uint32_t                  _pad_0x200c_0x2fff[1021];    /* *UNDEFINED* */
+    volatile ALT_L3_MST_L4OSC1_t       mastergrp_l4osc1;            /* ALT_L3_MST_L4OSC1 */
+    volatile uint32_t                  _pad_0x300c_0x3fff[1021];    /* *UNDEFINED* */
+    volatile ALT_L3_MST_L4SPIM_t       mastergrp_l4spim;            /* ALT_L3_MST_L4SPIM */
+    volatile uint32_t                  _pad_0x400c_0x4fff[1021];    /* *UNDEFINED* */
+    volatile ALT_L3_MST_STM_t          mastergrp_stm;               /* ALT_L3_MST_STM */
+    volatile uint32_t                  _pad_0x510c_0x5fff[957];     /* *UNDEFINED* */
+    volatile ALT_L3_MST_LWH2F_t        mastergrp_lwhps2fpga;        /* ALT_L3_MST_LWH2F */
+    volatile uint32_t                  _pad_0x610c_0x7fff[1981];    /* *UNDEFINED* */
+    volatile ALT_L3_MST_USB1_t         mastergrp_usb1;              /* ALT_L3_MST_USB1 */
+    volatile uint32_t                  _pad_0x8048_0x8fff[1006];    /* *UNDEFINED* */
+    volatile ALT_L3_MST_NANDDATA_t     mastergrp_nanddata;          /* ALT_L3_MST_NANDDATA */
+    volatile uint32_t                  _pad_0x910c_0x1dfff[21437];  /* *UNDEFINED* */
+    volatile ALT_L3_MST_USB0_t         mastergrp_usb0;              /* ALT_L3_MST_USB0 */
+    volatile uint32_t                  _pad_0x1e048_0x1efff[1006];  /* *UNDEFINED* */
+    volatile ALT_L3_MST_NAND_t         mastergrp_nandregs;          /* ALT_L3_MST_NAND */
+    volatile uint32_t                  _pad_0x1f10c_0x1ffff[957];   /* *UNDEFINED* */
+    volatile ALT_L3_MST_QSPIDATA_t     mastergrp_qspidata;          /* ALT_L3_MST_QSPIDATA */
+    volatile uint32_t                  _pad_0x20048_0x20fff[1006];  /* *UNDEFINED* */
+    volatile ALT_L3_MST_FPGAMGRDATA_t  mastergrp_fpgamgrdata;       /* ALT_L3_MST_FPGAMGRDATA */
+    volatile uint32_t                  _pad_0x2110c_0x21fff[957];   /* *UNDEFINED* */
+    volatile ALT_L3_MST_H2F_t          mastergrp_hps2fpga;          /* ALT_L3_MST_H2F */
+    volatile uint32_t                  _pad_0x2210c_0x22fff[957];   /* *UNDEFINED* */
+    volatile ALT_L3_MST_ACP_t          mastergrp_acp;               /* ALT_L3_MST_ACP */
+    volatile uint32_t                  _pad_0x2310c_0x23fff[957];   /* *UNDEFINED* */
+    volatile ALT_L3_MST_ROM_t          mastergrp_rom;               /* ALT_L3_MST_ROM */
+    volatile uint32_t                  _pad_0x2410c_0x24fff[957];   /* *UNDEFINED* */
+    volatile ALT_L3_MST_OCRAM_t        mastergrp_ocram;             /* ALT_L3_MST_OCRAM */
+/* The typedef declaration for register group ALT_L3_MSTGRP. */
+typedef volatile struct ALT_L3_MSTGRP_s  ALT_L3_MSTGRP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_MSTGRP. */
+struct ALT_L3_MSTGRP_raw_s
+    volatile ALT_L3_MST_L4MAIN_raw_t       mastergrp_l4main;            /* ALT_L3_MST_L4MAIN */
+    volatile ALT_L3_MST_L4SP_raw_t         mastergrp_l4sp;              /* ALT_L3_MST_L4SP */
+    volatile ALT_L3_MST_L4MP_raw_t         mastergrp_l4mp;              /* ALT_L3_MST_L4MP */
+    volatile ALT_L3_MST_L4OSC1_raw_t       mastergrp_l4osc1;            /* ALT_L3_MST_L4OSC1 */
+    volatile ALT_L3_MST_L4SPIM_raw_t       mastergrp_l4spim;            /* ALT_L3_MST_L4SPIM */
+    volatile ALT_L3_MST_STM_raw_t          mastergrp_stm;               /* ALT_L3_MST_STM */
+    volatile ALT_L3_MST_LWH2F_raw_t        mastergrp_lwhps2fpga;        /* ALT_L3_MST_LWH2F */
+    volatile ALT_L3_MST_USB1_raw_t         mastergrp_usb1;              /* ALT_L3_MST_USB1 */
+    volatile ALT_L3_MST_NANDDATA_raw_t     mastergrp_nanddata;          /* ALT_L3_MST_NANDDATA */
+    volatile ALT_L3_MST_USB0_raw_t         mastergrp_usb0;              /* ALT_L3_MST_USB0 */
+    volatile ALT_L3_MST_NAND_raw_t         mastergrp_nandregs;          /* ALT_L3_MST_NAND */
+    volatile ALT_L3_MST_QSPIDATA_raw_t     mastergrp_qspidata;          /* ALT_L3_MST_QSPIDATA */
+    volatile ALT_L3_MST_FPGAMGRDATA_raw_t  mastergrp_fpgamgrdata;       /* ALT_L3_MST_FPGAMGRDATA */
+    volatile ALT_L3_MST_H2F_raw_t          mastergrp_hps2fpga;          /* ALT_L3_MST_H2F */
+    volatile ALT_L3_MST_ACP_raw_t          mastergrp_acp;               /* ALT_L3_MST_ACP */
+    volatile ALT_L3_MST_ROM_raw_t          mastergrp_rom;               /* ALT_L3_MST_ROM */
+    volatile ALT_L3_MST_OCRAM_raw_t        mastergrp_ocram;             /* ALT_L3_MST_OCRAM */
+/* The typedef declaration for the raw register contents of register group ALT_L3_MSTGRP. */
+typedef volatile struct ALT_L3_MSTGRP_raw_s  ALT_L3_MSTGRP_raw_t;
+ * Register Group : Slave Register Group - ALT_L3_SLVGRP
+ * Slave Register Group
+ * Registers associated with slave interfaces.
+ * Register Group : DAP - ALT_L3_SLV_DAP
+ * DAP
+ * Registers associated with the DAP slave interface. This slave is used by the DAP
+ * to access slaves attached to the L3/L4 Interconnect.
+ * Register : Functionality Modification 2 Register - fn_mod2
+ * Controls bypass merge of upsizing/downsizing.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | Bypass Merge
+ *  [31:1] | ???    | 0x0   | *UNDEFINED*
+ * Field : Bypass Merge - bypass_merge
+ *  ALT_L3_FN_MOD2_BYPASS_MERGE_E_ALTER   | 0x0   | The network can alter transactions.
+ *  ALT_L3_FN_MOD2_BYPASS_MERGE_E_NOALTER | 0x1   | The network does not alter any transactions that
+ * :                                      |       | could pass through the upsizer legally without
+ * :                                      |       | alteration.
+ * Enumerated value for register field ALT_L3_FN_MOD2_BYPASS_MERGE
+ * The network can alter transactions.
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_E_ALTER     0x0
+ * The network does not alter any transactions that could pass through the upsizer
+ * legally without alteration.
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_E_NOALTER   0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_MSB        0
+/* The width in bits of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_WIDTH      1
+/* The mask used to set the ALT_L3_FN_MOD2_BYPASS_MERGE register field value. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_FN_MOD2_BYPASS_MERGE register field value. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_RESET      0x0
+/* Extracts the ALT_L3_FN_MOD2_BYPASS_MERGE field value from a register. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_FN_MOD2_BYPASS_MERGE register field value suitable for setting the register. */
+#define ALT_L3_FN_MOD2_BYPASS_MERGE_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_L3_FN_MOD2.
+struct ALT_L3_FN_MOD2_s
+    uint32_t  bypass_merge :  1;  /* Bypass Merge */
+    uint32_t               : 31;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_L3_FN_MOD2. */
+typedef volatile struct ALT_L3_FN_MOD2_s  ALT_L3_FN_MOD2_t;
+/* The byte offset of the ALT_L3_FN_MOD2 register from the beginning of the component. */
+#define ALT_L3_FN_MOD2_OFST        0x24
+/* The address of the ALT_L3_FN_MOD2 register. */
+#define ALT_L3_FN_MOD2_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD2_OFST))
+ * Register : Functionality Modification AHB Register - fn_mod_ahb
+ * Controls how AHB-lite burst transactions are converted to AXI tranactions.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | Read Increment Override
+ *  [1]    | RW     | 0x0   | Write Increment Override
+ * Field : Read Increment Override - rd_incr_override
+ * Controls how AHB-lite read burst transactions are converted to AXI tranactions.
+ *  ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_DEFAULT | 0x0   | The L3 Interconnect converts AHB-lite read
+ * :                                             |       | bursts to AXI transactions in accordance with
+ * :                                             |       | the default behavior as specified in the ARM
+ * :                                             |       | NIC-301 documentation.
+ *  ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_SINGLES | 0x1   | The L3 Interconnect converts AHB-lite read
+ * :                                             |       | bursts to AXI single transactions.
+ * Enumerated value for register field ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE
+ * The L3 Interconnect converts AHB-lite read bursts to AXI transactions in
+ * accordance with the default behavior as specified in the ARM NIC-301
+ * documentation.
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_DEFAULT    0x0
+ * The L3 Interconnect converts AHB-lite read bursts to AXI single transactions.
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_SINGLES    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_MSB        0
+/* The width in bits of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_WIDTH      1
+/* The mask used to set the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field value. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_SET_MSK    0x00000001
+/* The mask used to clear the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field value. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_RESET      0x0
+/* Extracts the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE field value from a register. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field value suitable for setting the register. */
+#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Write Increment Override - wr_incr_override
+ * Controls how AHB-lite write burst transactions are converted to AXI tranactions.
+ *  ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_DEFAULT | 0x0   | The L3 Interconnect converts AHB-lite write
+ *  ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_SINGLES | 0x1   | The L3 Interconnect converts AHB-lite write
+ * Enumerated value for register field ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE
+ * The L3 Interconnect converts AHB-lite write bursts to AXI transactions in
+ * documentation.
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_DEFAULT    0x0
+ * The L3 Interconnect converts AHB-lite write bursts to AXI single transactions.
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_SINGLES    0x1
+/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_MSB        1
+/* The width in bits of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_WIDTH      1
+/* The mask used to set the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field value. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_SET_MSK    0x00000002
+/* The mask used to clear the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field value. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_RESET      0x0
+/* Extracts the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE field value from a register. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field value suitable for setting the register. */
+#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_SET(value) (((value) << 1) & 0x00000002)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_L3_FN_MOD_AHB.
+struct ALT_L3_FN_MOD_AHB_s
+    uint32_t  rd_incr_override :  1;  /* Read Increment Override */
+    uint32_t  wr_incr_override :  1;  /* Write Increment Override */
+/* The typedef declaration for register ALT_L3_FN_MOD_AHB. */
+typedef volatile struct ALT_L3_FN_MOD_AHB_s  ALT_L3_FN_MOD_AHB_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_L3_FN_MOD_AHB register from the beginning of the component. */
+#define ALT_L3_FN_MOD_AHB_OFST        0x28
+/* The address of the ALT_L3_FN_MOD_AHB register. */
+#define ALT_L3_FN_MOD_AHB_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD_AHB_OFST))
+ * Register : Read Channel QoS Value - read_qos
+ * QoS (Quality of Service) value for the read channel.
+ * Register Layout
+ *  [3:0]  | RW     | 0x0   | Priority
+ * Field : Priority - pri
+ * QoS (Quality of Service) value for the read channel. A higher value has a higher
+ * priority.
+/* The Least Significant Bit (LSB) position of the ALT_L3_RD_QOS_PRI register field. */
+#define ALT_L3_RD_QOS_PRI_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_RD_QOS_PRI register field. */
+#define ALT_L3_RD_QOS_PRI_MSB        3
+/* The width in bits of the ALT_L3_RD_QOS_PRI register field. */
+#define ALT_L3_RD_QOS_PRI_WIDTH      4
+/* The mask used to set the ALT_L3_RD_QOS_PRI register field value. */
+#define ALT_L3_RD_QOS_PRI_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_L3_RD_QOS_PRI register field value. */
+#define ALT_L3_RD_QOS_PRI_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_L3_RD_QOS_PRI register field. */
+#define ALT_L3_RD_QOS_PRI_RESET      0x0
+/* Extracts the ALT_L3_RD_QOS_PRI field value from a register. */
+#define ALT_L3_RD_QOS_PRI_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_L3_RD_QOS_PRI register field value suitable for setting the register. */
+#define ALT_L3_RD_QOS_PRI_SET(value) (((value) << 0) & 0x0000000f)
+ * The struct declaration for register ALT_L3_RD_QOS.
+struct ALT_L3_RD_QOS_s
+    uint32_t  pri :  4;  /* Priority */
+/* The typedef declaration for register ALT_L3_RD_QOS. */
+typedef volatile struct ALT_L3_RD_QOS_s  ALT_L3_RD_QOS_t;
+/* The byte offset of the ALT_L3_RD_QOS register from the beginning of the component. */
+#define ALT_L3_RD_QOS_OFST        0x100
+/* The address of the ALT_L3_RD_QOS register. */
+#define ALT_L3_RD_QOS_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_RD_QOS_OFST))
+ * Register : Write Channel QoS Value - write_qos
+ * QoS (Quality of Service) value for the write channel.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ * QoS (Quality of Service) value for the write channel. A higher value has a
+ * higher priority.
+/* The Least Significant Bit (LSB) position of the ALT_L3_WR_QOS_PRI register field. */
+#define ALT_L3_WR_QOS_PRI_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_L3_WR_QOS_PRI register field. */
+#define ALT_L3_WR_QOS_PRI_MSB        3
+/* The width in bits of the ALT_L3_WR_QOS_PRI register field. */
+#define ALT_L3_WR_QOS_PRI_WIDTH      4
+/* The mask used to set the ALT_L3_WR_QOS_PRI register field value. */
+#define ALT_L3_WR_QOS_PRI_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_L3_WR_QOS_PRI register field value. */
+#define ALT_L3_WR_QOS_PRI_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_L3_WR_QOS_PRI register field. */
+#define ALT_L3_WR_QOS_PRI_RESET      0x0
+/* Extracts the ALT_L3_WR_QOS_PRI field value from a register. */
+#define ALT_L3_WR_QOS_PRI_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_L3_WR_QOS_PRI register field value suitable for setting the register. */
+#define ALT_L3_WR_QOS_PRI_SET(value) (((value) << 0) & 0x0000000f)
+ * The struct declaration for register ALT_L3_WR_QOS.
+struct ALT_L3_WR_QOS_s
+/* The typedef declaration for register ALT_L3_WR_QOS. */
+typedef volatile struct ALT_L3_WR_QOS_s  ALT_L3_WR_QOS_t;
+/* The byte offset of the ALT_L3_WR_QOS register from the beginning of the component. */
+#define ALT_L3_WR_QOS_OFST        0x104
+/* The address of the ALT_L3_WR_QOS register. */
+#define ALT_L3_WR_QOS_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_WR_QOS_OFST))
+ * The struct declaration for register group ALT_L3_SLV_DAP.
+struct ALT_L3_SLV_DAP_s
+    volatile uint32_t             _pad_0x0_0x23[9];    /* *UNDEFINED* */
+    volatile ALT_L3_FN_MOD2_t     fn_mod2;             /* ALT_L3_FN_MOD2 */
+    volatile ALT_L3_FN_MOD_AHB_t  fn_mod_ahb;          /* ALT_L3_FN_MOD_AHB */
+    volatile uint32_t             _pad_0x2c_0xff[53];  /* *UNDEFINED* */
+    volatile ALT_L3_RD_QOS_t      read_qos;            /* ALT_L3_RD_QOS */
+    volatile ALT_L3_WR_QOS_t      write_qos;           /* ALT_L3_WR_QOS */
+/* The typedef declaration for register group ALT_L3_SLV_DAP. */
+typedef volatile struct ALT_L3_SLV_DAP_s  ALT_L3_SLV_DAP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_DAP. */
+struct ALT_L3_SLV_DAP_raw_s
+    volatile uint32_t  fn_mod2;             /* ALT_L3_FN_MOD2 */
+    volatile uint32_t  fn_mod_ahb;          /* ALT_L3_FN_MOD_AHB */
+    volatile uint32_t  read_qos;            /* ALT_L3_RD_QOS */
+    volatile uint32_t  write_qos;           /* ALT_L3_WR_QOS */
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_DAP. */
+typedef volatile struct ALT_L3_SLV_DAP_raw_s  ALT_L3_SLV_DAP_raw_t;
+ * Register Group : MPU - ALT_L3_SLV_MPU
+ * MPU
+ * Registers associated with the MPU slave interface. This slave is used by the MPU
+ * The struct declaration for register group ALT_L3_SLV_MPU.
+struct ALT_L3_SLV_MPU_s
+    volatile uint32_t         _pad_0x0_0xff[64];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_L3_SLV_MPU. */
+typedef volatile struct ALT_L3_SLV_MPU_s  ALT_L3_SLV_MPU_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_MPU. */
+struct ALT_L3_SLV_MPU_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_MPU. */
+typedef volatile struct ALT_L3_SLV_MPU_raw_s  ALT_L3_SLV_MPU_raw_t;
+ * Register Group : SDMMC - ALT_L3_SLV_SDMMC
+ * SDMMC
+ * Registers associated with the SDMMC slave interface. This slave is used by the
+ * DMA controller built into the SDMMC to access slaves attached to the L3/L4
+ * Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_SDMMC.
+struct ALT_L3_SLV_SDMMC_s
+    volatile uint32_t             _pad_0x0_0x27[10];   /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_L3_SLV_SDMMC. */
+typedef volatile struct ALT_L3_SLV_SDMMC_s  ALT_L3_SLV_SDMMC_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_SDMMC. */
+struct ALT_L3_SLV_SDMMC_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_SDMMC. */
+typedef volatile struct ALT_L3_SLV_SDMMC_raw_s  ALT_L3_SLV_SDMMC_raw_t;
+ * Register Group : DMA - ALT_L3_SLV_DMA
+ * DMA
+ * Registers associated with the DMA Controller slave interface. This slave is used
+ * by the DMA Controller to access slaves attached to the L3/L4 Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_DMA.
+struct ALT_L3_SLV_DMA_s
+/* The typedef declaration for register group ALT_L3_SLV_DMA. */
+typedef volatile struct ALT_L3_SLV_DMA_s  ALT_L3_SLV_DMA_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_DMA. */
+struct ALT_L3_SLV_DMA_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_DMA. */
+typedef volatile struct ALT_L3_SLV_DMA_raw_s  ALT_L3_SLV_DMA_raw_t;
+ * Register Group : FPGA2HPS - ALT_L3_SLV_F2H
+ * FPGA2HPS
+ * Registers associated with the FPGA2HPS AXI Bridge slave interface. This slave is
+ * used by the FPGA2HPS AXI Bridge to access slaves attached to the L3/L4
+ * Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_F2H.
+struct ALT_L3_SLV_F2H_s
+    volatile uint32_t              _pad_0x0_0x3f[16];   /* *UNDEFINED* */
+    volatile uint32_t              _pad_0x44_0xff[47];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_L3_SLV_F2H. */
+typedef volatile struct ALT_L3_SLV_F2H_s  ALT_L3_SLV_F2H_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_F2H. */
+struct ALT_L3_SLV_F2H_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_F2H. */
+typedef volatile struct ALT_L3_SLV_F2H_raw_s  ALT_L3_SLV_F2H_raw_t;
+ * Register Group : ETR - ALT_L3_SLV_ETR
+ * ETR
+ * Registers associated with the ETR (TMC) slave interface. This slave is used by
+ * the ETR to access slaves attached to the L3/L4 Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_ETR.
+struct ALT_L3_SLV_ETR_s
+/* The typedef declaration for register group ALT_L3_SLV_ETR. */
+typedef volatile struct ALT_L3_SLV_ETR_s  ALT_L3_SLV_ETR_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_ETR. */
+struct ALT_L3_SLV_ETR_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_ETR. */
+typedef volatile struct ALT_L3_SLV_ETR_raw_s  ALT_L3_SLV_ETR_raw_t;
+ * Register Group : EMAC0 - ALT_L3_SLV_EMAC0
+ * EMAC0
+ * Registers associated with the EMAC0 slave interface. This slave is used by the
+ * DMA controller built into the EMAC0 to access slaves attached to the L3/L4
+ * Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_EMAC0.
+struct ALT_L3_SLV_EMAC0_s
+/* The typedef declaration for register group ALT_L3_SLV_EMAC0. */
+typedef volatile struct ALT_L3_SLV_EMAC0_s  ALT_L3_SLV_EMAC0_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_EMAC0. */
+struct ALT_L3_SLV_EMAC0_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_EMAC0. */
+typedef volatile struct ALT_L3_SLV_EMAC0_raw_s  ALT_L3_SLV_EMAC0_raw_t;
+ * Register Group : EMAC1 - ALT_L3_SLV_EMAC1
+ * EMAC1
+ * Registers associated with the EMAC1 slave interface. This slave is used by the
+ * DMA controller built into the EMAC1 to access slaves attached to the L3/L4
+ * Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_EMAC1.
+struct ALT_L3_SLV_EMAC1_s
+/* The typedef declaration for register group ALT_L3_SLV_EMAC1. */
+typedef volatile struct ALT_L3_SLV_EMAC1_s  ALT_L3_SLV_EMAC1_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_EMAC1. */
+struct ALT_L3_SLV_EMAC1_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_EMAC1. */
+typedef volatile struct ALT_L3_SLV_EMAC1_raw_s  ALT_L3_SLV_EMAC1_raw_t;
+ * Register Group : USB0 - ALT_L3_SLV_USB0
+ * USB0
+ * Registers associated with the USB0 slave interface. This slave is used by the
+ * DMA controller built into the USB0 to access slaves attached to the L3/L4
+ * Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_USB0.
+struct ALT_L3_SLV_USB0_s
+/* The typedef declaration for register group ALT_L3_SLV_USB0. */
+typedef volatile struct ALT_L3_SLV_USB0_s  ALT_L3_SLV_USB0_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_USB0. */
+struct ALT_L3_SLV_USB0_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_USB0. */
+typedef volatile struct ALT_L3_SLV_USB0_raw_s  ALT_L3_SLV_USB0_raw_t;
+ * Register Group : NAND - ALT_L3_SLV_NAND
+ * NAND
+ * Registers associated with the NAND slave interface. This slave is used by the
+ * DMA controller built into the NAND flash controller to access slaves attached to
+ * the L3/L4 Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_NAND.
+struct ALT_L3_SLV_NAND_s
+/* The typedef declaration for register group ALT_L3_SLV_NAND. */
+typedef volatile struct ALT_L3_SLV_NAND_s  ALT_L3_SLV_NAND_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_NAND. */
+struct ALT_L3_SLV_NAND_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_NAND. */
+typedef volatile struct ALT_L3_SLV_NAND_raw_s  ALT_L3_SLV_NAND_raw_t;
+ * Register Group : USB1 - ALT_L3_SLV_USB1
+ * USB1
+ * Registers associated with the USB1 slave interface. This slave is used by the
+ * DMA controller built into the USB1 to access slaves attached to the L3/L4
+ * Interconnect.
+ * The struct declaration for register group ALT_L3_SLV_USB1.
+struct ALT_L3_SLV_USB1_s
+/* The typedef declaration for register group ALT_L3_SLV_USB1. */
+typedef volatile struct ALT_L3_SLV_USB1_s  ALT_L3_SLV_USB1_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLV_USB1. */
+struct ALT_L3_SLV_USB1_raw_s
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_USB1. */
+typedef volatile struct ALT_L3_SLV_USB1_raw_s  ALT_L3_SLV_USB1_raw_t;
+ * The struct declaration for register group ALT_L3_SLVGRP.
+struct ALT_L3_SLVGRP_s
+    volatile ALT_L3_SLV_DAP_t    slavegrp_dap;             /* ALT_L3_SLV_DAP */
+    volatile uint32_t            _pad_0x10c_0xfff[957];    /* *UNDEFINED* */
+    volatile ALT_L3_SLV_MPU_t    slavegrp_mpu;             /* ALT_L3_SLV_MPU */
+    volatile uint32_t            _pad_0x110c_0x1fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_SDMMC_t  slavegrp_sdmmc;           /* ALT_L3_SLV_SDMMC */
+    volatile uint32_t            _pad_0x210c_0x2fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_DMA_t    slavegrp_dma;             /* ALT_L3_SLV_DMA */
+    volatile uint32_t            _pad_0x310c_0x3fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_F2H_t    slavegrp_fpga2hps;        /* ALT_L3_SLV_F2H */
+    volatile uint32_t            _pad_0x410c_0x4fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_ETR_t    slavegrp_etr;             /* ALT_L3_SLV_ETR */
+    volatile ALT_L3_SLV_EMAC0_t  slavegrp_emac0;           /* ALT_L3_SLV_EMAC0 */
+    volatile uint32_t            _pad_0x610c_0x6fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_EMAC1_t  slavegrp_emac1;           /* ALT_L3_SLV_EMAC1 */
+    volatile uint32_t            _pad_0x710c_0x7fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_USB0_t   slavegrp_usb0;            /* ALT_L3_SLV_USB0 */
+    volatile uint32_t            _pad_0x810c_0x8fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_NAND_t   slavegrp_nand;            /* ALT_L3_SLV_NAND */
+    volatile uint32_t            _pad_0x910c_0x9fff[957];  /* *UNDEFINED* */
+    volatile ALT_L3_SLV_USB1_t   slavegrp_usb1;            /* ALT_L3_SLV_USB1 */
+/* The typedef declaration for register group ALT_L3_SLVGRP. */
+typedef volatile struct ALT_L3_SLVGRP_s  ALT_L3_SLVGRP_t;
+/* The struct declaration for the raw register contents of register group ALT_L3_SLVGRP. */
+struct ALT_L3_SLVGRP_raw_s
+    volatile ALT_L3_SLV_DAP_raw_t    slavegrp_dap;             /* ALT_L3_SLV_DAP */
+    volatile ALT_L3_SLV_MPU_raw_t    slavegrp_mpu;             /* ALT_L3_SLV_MPU */
+    volatile ALT_L3_SLV_SDMMC_raw_t  slavegrp_sdmmc;           /* ALT_L3_SLV_SDMMC */
+    volatile ALT_L3_SLV_DMA_raw_t    slavegrp_dma;             /* ALT_L3_SLV_DMA */
+    volatile ALT_L3_SLV_F2H_raw_t    slavegrp_fpga2hps;        /* ALT_L3_SLV_F2H */
+    volatile ALT_L3_SLV_ETR_raw_t    slavegrp_etr;             /* ALT_L3_SLV_ETR */
+    volatile ALT_L3_SLV_EMAC0_raw_t  slavegrp_emac0;           /* ALT_L3_SLV_EMAC0 */
+    volatile ALT_L3_SLV_EMAC1_raw_t  slavegrp_emac1;           /* ALT_L3_SLV_EMAC1 */
+    volatile ALT_L3_SLV_USB0_raw_t   slavegrp_usb0;            /* ALT_L3_SLV_USB0 */
+    volatile ALT_L3_SLV_NAND_raw_t   slavegrp_nand;            /* ALT_L3_SLV_NAND */
+    volatile ALT_L3_SLV_USB1_raw_t   slavegrp_usb1;            /* ALT_L3_SLV_USB1 */
+/* The typedef declaration for the raw register contents of register group ALT_L3_SLVGRP. */
+typedef volatile struct ALT_L3_SLVGRP_raw_s  ALT_L3_SLVGRP_raw_t;
+ * The struct declaration for register group ALT_L3.
+struct ALT_L3_s
+    volatile ALT_L3_REMAP_t   remap;                        /* ALT_L3_REMAP */
+    volatile uint32_t         _pad_0x4_0x7;                 /* *UNDEFINED* */
+    volatile ALT_L3_SECGRP_t  secgrp;                       /* ALT_L3_SECGRP */
+    volatile uint32_t         _pad_0xa4_0xfff[983];         /* *UNDEFINED* */
+    volatile ALT_L3_IDGRP_t   idgrp;                        /* ALT_L3_IDGRP */
+    volatile ALT_L3_MSTGRP_t  mastergrp;                    /* ALT_L3_MSTGRP */
+    volatile uint32_t         _pad_0x2710c_0x41fff[27581];  /* *UNDEFINED* */
+    volatile ALT_L3_SLVGRP_t  slavegrp;                     /* ALT_L3_SLVGRP */
+    volatile uint32_t         _pad_0x4c10c_0x80000[53181];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_L3. */
+typedef volatile struct ALT_L3_s  ALT_L3_t;
+/* The struct declaration for the raw register contents of register group ALT_L3. */
+struct ALT_L3_raw_s
+    volatile uint32_t             remap;                        /* ALT_L3_REMAP */
+    volatile ALT_L3_SECGRP_raw_t  secgrp;                       /* ALT_L3_SECGRP */
+    volatile ALT_L3_IDGRP_raw_t   idgrp;                        /* ALT_L3_IDGRP */
+    volatile ALT_L3_MSTGRP_raw_t  mastergrp;                    /* ALT_L3_MSTGRP */
+    volatile ALT_L3_SLVGRP_raw_t  slavegrp;                     /* ALT_L3_SLVGRP */
+/* The typedef declaration for the raw register contents of register group ALT_L3. */
+typedef volatile struct ALT_L3_raw_s  ALT_L3_raw_t;
+#ifdef __cplusplus
+#endif  /* __cplusplus */
+#endif  /* __ALTERA_ALT_L3_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_rstmgr.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_rstmgr.h
new file mode 100644
index 0000000..ab4ac65
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_rstmgr.h
@@ -0,0 +1,3382 @@
+* Copyright 2013 Altera Corporation. All Rights Reserved.                      *
+* Redistribution and use in source and binary forms, with or without           *
+* modification, are permitted provided that the following conditions are met:  *
+* 1. Redistributions of source code must retain the above copyright notice,    *
+*    this list of conditions and the following disclaimer.                     *
+* 2. Redistributions in binary form must reproduce the above copyright notice, *
+*    this list of conditions and the following disclaimer in the documentation *
+*    and/or other materials provided with the distribution.                    *
+* 3. The name of the author may not be used to endorse or promote products     *
+*    derived from this software without specific prior written permission.     *
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO  *
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,       *
+* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
+* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;  *
+* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,     *
+* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR      *
+* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF       *
+* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                                   *
+/* Altera - ALT_RSTMGR */
+#ifndef __ALTERA_ALT_RSTMGR_H__
+#define __ALTERA_ALT_RSTMGR_H__
+#ifdef __cplusplus
+extern "C"
+ * Component : Reset Manager Module - ALT_RSTMGR
+ * Reset Manager Module
+ * Registers in the Reset Manager module
+ * Register : Status Register - stat
+ * The STAT register contains bits that indicate the reset source or a timeout
+ * event. For reset sources, a field is 1 if its associated reset requester caused
+ * the reset. For timeout events, a field is 1 if its associated timeout occured as
+ * part of a hardware sequenced warm/debug reset.
+ * Software clears bits by writing them with a value of 1. Writes to bits with a
+ * value of 0 are ignored.
+ * After a cold reset is complete, all bits are reset to their reset value except
+ * for the bit(s) that indicate the source of the cold reset. If multiple cold
+ * reset requests overlap with each other, the source de-asserts the request last
+ * will be logged. The other reset request source(s)  de-assert the request in the
+ * same cycle will also be logged, the rest of the fields are reset to default
+ * value of 0.
+ * After a warm reset is complete, the bit(s) that indicate the source of  the warm
+ * reset are set to 1. A warm reset doesn't clear any of the bits  in the STAT
+ * register; these bits must be cleared by software writing  the STAT register.
+ * Register Layout
+ *  [0]     | RW     | 0x0   | Power-On Voltage Detector Cold Reset
+ *  [1]     | RW     | 0x0   | nPOR Pin Cold Reset
+ *  [2]     | RW     | 0x0   | FPGA Core Cold Reset
+ *  [3]     | RW     | 0x0   | CONFIG_IO Cold Reset
+ *  [4]     | RW     | 0x0   | Software Cold Reset
+ *  [7:5]   | ???    | 0x0   | *UNDEFINED*
+ *  [8]     | RW     | 0x0   | nRST Pin Warm Reset
+ *  [9]     | RW     | 0x0   | FPGA Core Warm Reset
+ *  [10]    | RW     | 0x0   | Software Warm Reset
+ *  [11]    | ???    | 0x0   | *UNDEFINED*
+ *  [12]    | RW     | 0x0   | MPU Watchdog 0 Warm Reset
+ *  [13]    | RW     | 0x0   | MPU Watchdog 1 Warm Reset
+ *  [14]    | RW     | 0x0   | L4 Watchdog 0 Warm Reset
+ *  [15]    | RW     | 0x0   | L4 Watchdog 1 Warm Reset
+ *  [17:16] | ???    | 0x0   | *UNDEFINED*
+ *  [18]    | RW     | 0x0   | FPGA Core Debug Reset
+ *  [19]    | RW     | 0x0   | DAP Debug Reset
+ *  [23:20] | ???    | 0x0   | *UNDEFINED*
+ *  [24]    | RW     | 0x0   | SDRAM Self-Refresh Timeout
+ *  [25]    | RW     | 0x0   | FPGA manager handshake Timeout
+ *  [26]    | RW     | 0x0   | SCAN manager handshake Timeout
+ *  [27]    | RW     | 0x0   | FPGA handshake Timeout
+ *  [28]    | RW     | 0x0   | ETR Stall Timeout
+ *  [31:29] | ???    | 0x0   | *UNDEFINED*
+ * Field : Power-On Voltage Detector Cold Reset - porvoltrst
+ * Built-in POR voltage detector triggered a cold reset (por_voltage_req = 1)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_PORVOLTRST register field. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_PORVOLTRST register field. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_MSB        0
+/* The width in bits of the ALT_RSTMGR_STAT_PORVOLTRST register field. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_PORVOLTRST register field value. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_SET_MSK    0x00000001
+/* The mask used to clear the ALT_RSTMGR_STAT_PORVOLTRST register field value. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_RSTMGR_STAT_PORVOLTRST register field. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_PORVOLTRST field value from a register. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_RSTMGR_STAT_PORVOLTRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_PORVOLTRST_SET(value) (((value) << 0) & 0x00000001)
+ * Field : nPOR Pin Cold Reset - nporpinrst
+ * nPOR pin triggered a cold reset (por_pin_req = 1)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_NPORPINRST register field. */
+#define ALT_RSTMGR_STAT_NPORPINRST_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_NPORPINRST register field. */
+#define ALT_RSTMGR_STAT_NPORPINRST_MSB        1
+/* The width in bits of the ALT_RSTMGR_STAT_NPORPINRST register field. */
+#define ALT_RSTMGR_STAT_NPORPINRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_NPORPINRST register field value. */
+#define ALT_RSTMGR_STAT_NPORPINRST_SET_MSK    0x00000002
+/* The mask used to clear the ALT_RSTMGR_STAT_NPORPINRST register field value. */
+#define ALT_RSTMGR_STAT_NPORPINRST_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_RSTMGR_STAT_NPORPINRST register field. */
+#define ALT_RSTMGR_STAT_NPORPINRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_NPORPINRST field value from a register. */
+#define ALT_RSTMGR_STAT_NPORPINRST_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_RSTMGR_STAT_NPORPINRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_NPORPINRST_SET(value) (((value) << 1) & 0x00000002)
+ * Field : FPGA Core Cold Reset - fpgacoldrst
+ * FPGA core triggered a cold reset (f2h_cold_rst_req_n = 1)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_FPGACOLDRST register field. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_FPGACOLDRST register field. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_MSB        2
+/* The width in bits of the ALT_RSTMGR_STAT_FPGACOLDRST register field. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_FPGACOLDRST register field value. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_SET_MSK    0x00000004
+/* The mask used to clear the ALT_RSTMGR_STAT_FPGACOLDRST register field value. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_RSTMGR_STAT_FPGACOLDRST register field. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_FPGACOLDRST field value from a register. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_RSTMGR_STAT_FPGACOLDRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_FPGACOLDRST_SET(value) (((value) << 2) & 0x00000004)
+ * Field : CONFIG_IO Cold Reset - configiocoldrst
+ * FPGA entered CONFIG_IO mode and a triggered a cold reset
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_CFGIOCOLDRST register field. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_CFGIOCOLDRST register field. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_MSB        3
+/* The width in bits of the ALT_RSTMGR_STAT_CFGIOCOLDRST register field. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_CFGIOCOLDRST register field value. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_SET_MSK    0x00000008
+/* The mask used to clear the ALT_RSTMGR_STAT_CFGIOCOLDRST register field value. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_RSTMGR_STAT_CFGIOCOLDRST register field. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_CFGIOCOLDRST field value from a register. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_RSTMGR_STAT_CFGIOCOLDRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_CFGIOCOLDRST_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Software Cold Reset - swcoldrst
+ * Software wrote CTRL.SWCOLDRSTREQ to 1 and triggered a cold reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_SWCOLDRST register field. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_SWCOLDRST register field. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_MSB        4
+/* The width in bits of the ALT_RSTMGR_STAT_SWCOLDRST register field. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_SWCOLDRST register field value. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_SET_MSK    0x00000010
+/* The mask used to clear the ALT_RSTMGR_STAT_SWCOLDRST register field value. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_CLR_MSK    0xffffffef
+/* The reset value of the ALT_RSTMGR_STAT_SWCOLDRST register field. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_SWCOLDRST field value from a register. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_RSTMGR_STAT_SWCOLDRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_SWCOLDRST_SET(value) (((value) << 4) & 0x00000010)
+ * Field : nRST Pin Warm Reset - nrstpinrst
+ * nRST pin triggered a hardware sequenced warm reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_NRSTPINRST register field. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_NRSTPINRST register field. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_MSB        8
+/* The width in bits of the ALT_RSTMGR_STAT_NRSTPINRST register field. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_NRSTPINRST register field value. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_SET_MSK    0x00000100
+/* The mask used to clear the ALT_RSTMGR_STAT_NRSTPINRST register field value. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_RSTMGR_STAT_NRSTPINRST register field. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_NRSTPINRST field value from a register. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_RSTMGR_STAT_NRSTPINRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_NRSTPINRST_SET(value) (((value) << 8) & 0x00000100)
+ * Field : FPGA Core Warm Reset - fpgawarmrst
+ * FPGA core triggered a hardware sequenced warm reset (f2h_warm_rst_req_n = 1)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_FPGAWARMRST register field. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_FPGAWARMRST register field. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_MSB        9
+/* The width in bits of the ALT_RSTMGR_STAT_FPGAWARMRST register field. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_FPGAWARMRST register field value. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_SET_MSK    0x00000200
+/* The mask used to clear the ALT_RSTMGR_STAT_FPGAWARMRST register field value. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_RSTMGR_STAT_FPGAWARMRST register field. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_FPGAWARMRST field value from a register. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_RSTMGR_STAT_FPGAWARMRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_FPGAWARMRST_SET(value) (((value) << 9) & 0x00000200)
+ * Field : Software Warm Reset - swwarmrst
+ * Software wrote CTRL.SWWARMRSTREQ to 1 and triggered a hardware sequenced warm
+ * reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_SWWARMRST register field. */
+#define ALT_RSTMGR_STAT_SWWARMRST_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_SWWARMRST register field. */
+#define ALT_RSTMGR_STAT_SWWARMRST_MSB        10
+/* The width in bits of the ALT_RSTMGR_STAT_SWWARMRST register field. */
+#define ALT_RSTMGR_STAT_SWWARMRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_SWWARMRST register field value. */
+#define ALT_RSTMGR_STAT_SWWARMRST_SET_MSK    0x00000400
+/* The mask used to clear the ALT_RSTMGR_STAT_SWWARMRST register field value. */
+#define ALT_RSTMGR_STAT_SWWARMRST_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_RSTMGR_STAT_SWWARMRST register field. */
+#define ALT_RSTMGR_STAT_SWWARMRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_SWWARMRST field value from a register. */
+#define ALT_RSTMGR_STAT_SWWARMRST_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_RSTMGR_STAT_SWWARMRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_SWWARMRST_SET(value) (((value) << 10) & 0x00000400)
+ * Field : MPU Watchdog 0 Warm Reset - mpuwd0rst
+ * MPU Watchdog 0 triggered a hardware sequenced warm reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_MPUWD0RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_MPUWD0RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_MSB        12
+/* The width in bits of the ALT_RSTMGR_STAT_MPUWD0RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_MPUWD0RST register field value. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_SET_MSK    0x00001000
+/* The mask used to clear the ALT_RSTMGR_STAT_MPUWD0RST register field value. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_CLR_MSK    0xffffefff
+/* The reset value of the ALT_RSTMGR_STAT_MPUWD0RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_MPUWD0RST field value from a register. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_RSTMGR_STAT_MPUWD0RST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_MPUWD0RST_SET(value) (((value) << 12) & 0x00001000)
+ * Field : MPU Watchdog 1 Warm Reset - mpuwd1rst
+ * MPU Watchdog 1 triggered a hardware sequenced warm reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_MPUWD1RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_MPUWD1RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_MSB        13
+/* The width in bits of the ALT_RSTMGR_STAT_MPUWD1RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_MPUWD1RST register field value. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_SET_MSK    0x00002000
+/* The mask used to clear the ALT_RSTMGR_STAT_MPUWD1RST register field value. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_RSTMGR_STAT_MPUWD1RST register field. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_MPUWD1RST field value from a register. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_RSTMGR_STAT_MPUWD1RST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_MPUWD1RST_SET(value) (((value) << 13) & 0x00002000)
+ * Field : L4 Watchdog 0 Warm Reset - l4wd0rst
+ * L4 Watchdog 0 triggered a hardware sequenced warm reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_L4WD0RST register field. */
+#define ALT_RSTMGR_STAT_L4WD0RST_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_L4WD0RST register field. */
+#define ALT_RSTMGR_STAT_L4WD0RST_MSB        14
+/* The width in bits of the ALT_RSTMGR_STAT_L4WD0RST register field. */
+#define ALT_RSTMGR_STAT_L4WD0RST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_L4WD0RST register field value. */
+#define ALT_RSTMGR_STAT_L4WD0RST_SET_MSK    0x00004000
+/* The mask used to clear the ALT_RSTMGR_STAT_L4WD0RST register field value. */
+#define ALT_RSTMGR_STAT_L4WD0RST_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_RSTMGR_STAT_L4WD0RST register field. */
+#define ALT_RSTMGR_STAT_L4WD0RST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_L4WD0RST field value from a register. */
+#define ALT_RSTMGR_STAT_L4WD0RST_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_RSTMGR_STAT_L4WD0RST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_L4WD0RST_SET(value) (((value) << 14) & 0x00004000)
+ * Field : L4 Watchdog 1 Warm Reset - l4wd1rst
+ * L4 Watchdog 1 triggered a hardware sequenced warm reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_L4WD1RST register field. */
+#define ALT_RSTMGR_STAT_L4WD1RST_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_L4WD1RST register field. */
+#define ALT_RSTMGR_STAT_L4WD1RST_MSB        15
+/* The width in bits of the ALT_RSTMGR_STAT_L4WD1RST register field. */
+#define ALT_RSTMGR_STAT_L4WD1RST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_L4WD1RST register field value. */
+#define ALT_RSTMGR_STAT_L4WD1RST_SET_MSK    0x00008000
+/* The mask used to clear the ALT_RSTMGR_STAT_L4WD1RST register field value. */
+#define ALT_RSTMGR_STAT_L4WD1RST_CLR_MSK    0xffff7fff
+/* The reset value of the ALT_RSTMGR_STAT_L4WD1RST register field. */
+#define ALT_RSTMGR_STAT_L4WD1RST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_L4WD1RST field value from a register. */
+#define ALT_RSTMGR_STAT_L4WD1RST_GET(value) (((value) & 0x00008000) >> 15)
+/* Produces a ALT_RSTMGR_STAT_L4WD1RST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_L4WD1RST_SET(value) (((value) << 15) & 0x00008000)
+ * Field : FPGA Core Debug Reset - fpgadbgrst
+ * FPGA triggered debug reset (f2h_dbg_rst_req_n = 1)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_FPGADBGRST register field. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_LSB        18
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_FPGADBGRST register field. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_MSB        18
+/* The width in bits of the ALT_RSTMGR_STAT_FPGADBGRST register field. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_FPGADBGRST register field value. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_SET_MSK    0x00040000
+/* The mask used to clear the ALT_RSTMGR_STAT_FPGADBGRST register field value. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_CLR_MSK    0xfffbffff
+/* The reset value of the ALT_RSTMGR_STAT_FPGADBGRST register field. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_FPGADBGRST field value from a register. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_GET(value) (((value) & 0x00040000) >> 18)
+/* Produces a ALT_RSTMGR_STAT_FPGADBGRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_FPGADBGRST_SET(value) (((value) << 18) & 0x00040000)
+ * Field : DAP Debug Reset - cdbgreqrst
+ * DAP triggered debug reset
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_CDBGREQRST register field. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_LSB        19
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_CDBGREQRST register field. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_MSB        19
+/* The width in bits of the ALT_RSTMGR_STAT_CDBGREQRST register field. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_CDBGREQRST register field value. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_SET_MSK    0x00080000
+/* The mask used to clear the ALT_RSTMGR_STAT_CDBGREQRST register field value. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_CLR_MSK    0xfff7ffff
+/* The reset value of the ALT_RSTMGR_STAT_CDBGREQRST register field. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_CDBGREQRST field value from a register. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_GET(value) (((value) & 0x00080000) >> 19)
+/* Produces a ALT_RSTMGR_STAT_CDBGREQRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_CDBGREQRST_SET(value) (((value) << 19) & 0x00080000)
+ * Field : SDRAM Self-Refresh Timeout - sdrselfreftimeout
+ * A 1 indicates that Reset Manager's request to the SDRAM Controller Subsystem to
+ * put the SDRAM devices into self-refresh mode before starting a hardware
+ * sequenced warm reset timed-out and the Reset Manager had to proceed with the
+ * warm reset anyway.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_SDRSELFREFTMO register field. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_LSB        24
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_SDRSELFREFTMO register field. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_MSB        24
+/* The width in bits of the ALT_RSTMGR_STAT_SDRSELFREFTMO register field. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_SDRSELFREFTMO register field value. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_SET_MSK    0x01000000
+/* The mask used to clear the ALT_RSTMGR_STAT_SDRSELFREFTMO register field value. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_CLR_MSK    0xfeffffff
+/* The reset value of the ALT_RSTMGR_STAT_SDRSELFREFTMO register field. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_SDRSELFREFTMO field value from a register. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_GET(value) (((value) & 0x01000000) >> 24)
+/* Produces a ALT_RSTMGR_STAT_SDRSELFREFTMO register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_SDRSELFREFTMO_SET(value) (((value) << 24) & 0x01000000)
+ * Field : FPGA manager handshake Timeout - fpgamgrhstimeout
+ * A 1 indicates that Reset Manager's request to the FPGA manager to stop driving
+ * configuration clock to FPGA CB before starting a hardware sequenced warm reset
+ * timed-out and the Reset Manager had to proceed with the warm reset anyway.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_FPGAMGRHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_LSB        25
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_FPGAMGRHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_MSB        25
+/* The width in bits of the ALT_RSTMGR_STAT_FPGAMGRHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_FPGAMGRHSTMO register field value. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_SET_MSK    0x02000000
+/* The mask used to clear the ALT_RSTMGR_STAT_FPGAMGRHSTMO register field value. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_CLR_MSK    0xfdffffff
+/* The reset value of the ALT_RSTMGR_STAT_FPGAMGRHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_FPGAMGRHSTMO field value from a register. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_GET(value) (((value) & 0x02000000) >> 25)
+/* Produces a ALT_RSTMGR_STAT_FPGAMGRHSTMO register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_FPGAMGRHSTMO_SET(value) (((value) << 25) & 0x02000000)
+ * Field : SCAN manager handshake Timeout - scanhstimeout
+ * A 1 indicates that Reset Manager's request to the SCAN manager to stop driving
+ * JTAG clock to FPGA CB before starting a hardware sequenced warm reset timed-out
+ * and the Reset Manager had to proceed with the warm reset anyway.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_SCANHSTMO register field. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_LSB        26
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_SCANHSTMO register field. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_MSB        26
+/* The width in bits of the ALT_RSTMGR_STAT_SCANHSTMO register field. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_SCANHSTMO register field value. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_SET_MSK    0x04000000
+/* The mask used to clear the ALT_RSTMGR_STAT_SCANHSTMO register field value. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_CLR_MSK    0xfbffffff
+/* The reset value of the ALT_RSTMGR_STAT_SCANHSTMO register field. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_SCANHSTMO field value from a register. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_GET(value) (((value) & 0x04000000) >> 26)
+/* Produces a ALT_RSTMGR_STAT_SCANHSTMO register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_SCANHSTMO_SET(value) (((value) << 26) & 0x04000000)
+ * Field : FPGA handshake Timeout - fpgahstimeout
+ * A 1 indicates that Reset Manager's handshake request to FPGA before starting a
+ * hardware sequenced warm reset timed-out and the Reset Manager had to proceed
+ * with the warm reset anyway.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_FPGAHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_LSB        27
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_FPGAHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_MSB        27
+/* The width in bits of the ALT_RSTMGR_STAT_FPGAHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_FPGAHSTMO register field value. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_SET_MSK    0x08000000
+/* The mask used to clear the ALT_RSTMGR_STAT_FPGAHSTMO register field value. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_CLR_MSK    0xf7ffffff
+/* The reset value of the ALT_RSTMGR_STAT_FPGAHSTMO register field. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_FPGAHSTMO field value from a register. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_GET(value) (((value) & 0x08000000) >> 27)
+/* Produces a ALT_RSTMGR_STAT_FPGAHSTMO register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_FPGAHSTMO_SET(value) (((value) << 27) & 0x08000000)
+ * Field : ETR Stall Timeout - etrstalltimeout
+ * A 1 indicates that Reset Manager's request to the ETR (Embedded Trace Router) to
+ * stall its AXI master port before starting a hardware sequenced warm reset timed-
+ * out and the Reset Manager had to proceed with the warm reset anyway.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_STAT_ETRSTALLTMO register field. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_LSB        28
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_STAT_ETRSTALLTMO register field. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_MSB        28
+/* The width in bits of the ALT_RSTMGR_STAT_ETRSTALLTMO register field. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_STAT_ETRSTALLTMO register field value. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_SET_MSK    0x10000000
+/* The mask used to clear the ALT_RSTMGR_STAT_ETRSTALLTMO register field value. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_CLR_MSK    0xefffffff
+/* The reset value of the ALT_RSTMGR_STAT_ETRSTALLTMO register field. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_RESET      0x0
+/* Extracts the ALT_RSTMGR_STAT_ETRSTALLTMO field value from a register. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_GET(value) (((value) & 0x10000000) >> 28)
+/* Produces a ALT_RSTMGR_STAT_ETRSTALLTMO register field value suitable for setting the register. */
+#define ALT_RSTMGR_STAT_ETRSTALLTMO_SET(value) (((value) << 28) & 0x10000000)
+ * The struct declaration for register ALT_RSTMGR_STAT.
+struct ALT_RSTMGR_STAT_s
+    uint32_t  porvoltrst        :  1;  /* Power-On Voltage Detector Cold Reset */
+    uint32_t  nporpinrst        :  1;  /* nPOR Pin Cold Reset */
+    uint32_t  fpgacoldrst       :  1;  /* FPGA Core Cold Reset */
+    uint32_t  configiocoldrst   :  1;  /* CONFIG_IO Cold Reset */
+    uint32_t  swcoldrst         :  1;  /* Software Cold Reset */
+    uint32_t                    :  3;  /* *UNDEFINED* */
+    uint32_t  nrstpinrst        :  1;  /* nRST Pin Warm Reset */
+    uint32_t  fpgawarmrst       :  1;  /* FPGA Core Warm Reset */
+    uint32_t  swwarmrst         :  1;  /* Software Warm Reset */
+    uint32_t                    :  1;  /* *UNDEFINED* */
+    uint32_t  mpuwd0rst         :  1;  /* MPU Watchdog 0 Warm Reset */
+    uint32_t  mpuwd1rst         :  1;  /* MPU Watchdog 1 Warm Reset */
+    uint32_t  l4wd0rst          :  1;  /* L4 Watchdog 0 Warm Reset */
+    uint32_t  l4wd1rst          :  1;  /* L4 Watchdog 1 Warm Reset */
+    uint32_t                    :  2;  /* *UNDEFINED* */
+    uint32_t  fpgadbgrst        :  1;  /* FPGA Core Debug Reset */
+    uint32_t  cdbgreqrst        :  1;  /* DAP Debug Reset */
+    uint32_t                    :  4;  /* *UNDEFINED* */
+    uint32_t  sdrselfreftimeout :  1;  /* SDRAM Self-Refresh Timeout */
+    uint32_t  fpgamgrhstimeout  :  1;  /* FPGA manager handshake Timeout */
+    uint32_t  scanhstimeout     :  1;  /* SCAN manager handshake Timeout */
+    uint32_t  fpgahstimeout     :  1;  /* FPGA handshake Timeout */
+    uint32_t  etrstalltimeout   :  1;  /* ETR Stall Timeout */
+/* The typedef declaration for register ALT_RSTMGR_STAT. */
+typedef volatile struct ALT_RSTMGR_STAT_s  ALT_RSTMGR_STAT_t;
+/* The byte offset of the ALT_RSTMGR_STAT register from the beginning of the component. */
+#define ALT_RSTMGR_STAT_OFST        0x0
+ * Register : Control Register - ctrl
+ * The CTRL register is used by software to control reset behavior.It includes
+ * fields for software to initiate the cold and warm reset, enable hardware
+ * handshake with other modules before warm reset, and perform software handshake.
+ * The software handshake sequence must match the hardware sequence. Software
+ * mustde-assert the handshake request after asserting warm reset and before de-
+ * assert the warm reset.
+ * Fields are only reset by a cold reset.
+ * Register Layout
+ *  [0]     | RW     | 0x0     | Software Cold Reset Request
+ *  [1]     | RW     | 0x0     | Software Warm Reset Request
+ *  [3:2]   | ???    | 0x0     | *UNDEFINED*
+ *  [4]     | RW     | 0x0     | SDRAM Self-Refresh Enable
+ *  [5]     | RW     | 0x0     | SDRAM Self-Refresh Request
+ *  [6]     | R      | 0x0     | SDRAM Self-Refresh Acknowledge
+ *  [7]     | ???    | 0x0     | *UNDEFINED*
+ *  [8]     | RW     | 0x0     | FPGA Manager Handshake Enable
+ *  [9]     | RW     | 0x0     | FPGA Manager Handshake Request
+ *  [10]    | R      | Unknown | FPGA Manager Handshake Acknowledge
+ *  [12]    | RW     | 0x0     | SCAN Manager Handshake Enable
+ *  [13]    | RW     | 0x0     | SCAN Manager Handshake Request
+ *  [14]    | R      | Unknown | SCAN Manager Handshake Acknowledge
+ *  [15]    | ???    | 0x0     | *UNDEFINED*
+ *  [16]    | RW     | 0x0     | FPGA Handshake Enable
+ *  [17]    | RW     | 0x0     | FPGA Handshake Request
+ *  [18]    | R      | Unknown | FPGA Handshake Acknowledge
+ *  [19]    | ???    | 0x0     | *UNDEFINED*
+ *  [20]    | RW     | 0x1     | ETR (Embedded Trace Router) Stall Enable
+ *  [21]    | RW     | 0x0     | ETR (Embedded Trace Router) Stall Request
+ *  [22]    | R      | 0x0     | ETR (Embedded Trace Router) Stall Acknowledge
+ *  [23]    | RW     | 0x0     | ETR (Embedded Trace Router) Stall After Warm Reset
+ *  [31:24] | ???    | 0x0     | *UNDEFINED*
+ * Field : Software Cold Reset Request - swcoldrstreq
+ * This is a one-shot bit written by software to 1 to trigger a cold reset. It
+ * always reads the value 0.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SWCOLDRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SWCOLDRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_MSB        0
+/* The width in bits of the ALT_RSTMGR_CTL_SWCOLDRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SWCOLDRSTREQ register field value. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_SET_MSK    0x00000001
+/* The mask used to clear the ALT_RSTMGR_CTL_SWCOLDRSTREQ register field value. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_RSTMGR_CTL_SWCOLDRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SWCOLDRSTREQ field value from a register. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_RSTMGR_CTL_SWCOLDRSTREQ register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SWCOLDRSTREQ_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Software Warm Reset Request - swwarmrstreq
+ * This is a one-shot bit written by software to 1 to trigger a hardware sequenced
+ * warm reset. It always reads the value 0.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SWWARMRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SWWARMRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_MSB        1
+/* The width in bits of the ALT_RSTMGR_CTL_SWWARMRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SWWARMRSTREQ register field value. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET_MSK    0x00000002
+/* The mask used to clear the ALT_RSTMGR_CTL_SWWARMRSTREQ register field value. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_RSTMGR_CTL_SWWARMRSTREQ register field. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SWWARMRSTREQ field value from a register. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_RSTMGR_CTL_SWWARMRSTREQ register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SWWARMRSTREQ_SET(value) (((value) << 1) & 0x00000002)
+ * Field : SDRAM Self-Refresh Enable - sdrselfrefen
+ * This field controls whether the contents of SDRAM devices survive a hardware
+ * sequenced warm reset. If set to 1, the Reset Manager makes a request to the
+ * SDRAM Controller Subsystem to put the SDRAM devices into self-refresh mode
+ * before asserting warm reset signals. However, if SDRAM is already in warm reset,
+ * Handshake with SDRAM is not performed.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SDRSELFREFEN register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SDRSELFREFEN register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_MSB        4
+/* The width in bits of the ALT_RSTMGR_CTL_SDRSELFREFEN register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SDRSELFREFEN register field value. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_SET_MSK    0x00000010
+/* The mask used to clear the ALT_RSTMGR_CTL_SDRSELFREFEN register field value. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_CLR_MSK    0xffffffef
+/* The reset value of the ALT_RSTMGR_CTL_SDRSELFREFEN register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SDRSELFREFEN field value from a register. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_RSTMGR_CTL_SDRSELFREFEN register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SDRSELFREFEN_SET(value) (((value) << 4) & 0x00000010)
+ * Field : SDRAM Self-Refresh Request - sdrselfrefreq
+ * Software writes this field 1 to request to the SDRAM Controller Subsystem that
+ * it puts the SDRAM devices into self-refresh mode. This is done to preserve SDRAM
+ * contents across a software warm reset.
+ * Software waits for the SDRSELFREFACK to be 1 and then writes this field to 0.
+ * Note that it is possible for the SDRAM Controller Subsystem to never assert
+ * SDRSELFREFACK so software should timeout if SDRSELFREFACK is never asserted.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SDRSELFREFREQ register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SDRSELFREFREQ register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_MSB        5
+/* The width in bits of the ALT_RSTMGR_CTL_SDRSELFREFREQ register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SDRSELFREFREQ register field value. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_SET_MSK    0x00000020
+/* The mask used to clear the ALT_RSTMGR_CTL_SDRSELFREFREQ register field value. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_RSTMGR_CTL_SDRSELFREFREQ register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SDRSELFREFREQ field value from a register. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_RSTMGR_CTL_SDRSELFREFREQ register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SDRSELFREFREQ_SET(value) (((value) << 5) & 0x00000020)
+ * Field : SDRAM Self-Refresh Acknowledge - sdrselfreqack
+ * This is the acknowlege for a SDRAM self-refresh mode request initiated by the
+ * SDRSELFREFREQ field.  A 1 indicates that the SDRAM Controller Subsystem has put
+ * the SDRAM devices into self-refresh mode.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SDRSELFREQACK register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SDRSELFREQACK register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_MSB        6
+/* The width in bits of the ALT_RSTMGR_CTL_SDRSELFREQACK register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SDRSELFREQACK register field value. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_SET_MSK    0x00000040
+/* The mask used to clear the ALT_RSTMGR_CTL_SDRSELFREQACK register field value. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_RSTMGR_CTL_SDRSELFREQACK register field. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SDRSELFREQACK field value from a register. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_RSTMGR_CTL_SDRSELFREQACK register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SDRSELFREQACK_SET(value) (((value) << 6) & 0x00000040)
+ * Field : FPGA Manager Handshake Enable - fpgamgrhsen
+ * Enables a handshake between the Reset Manager and FPGA Manager before a warm
+ * reset. The handshake is used to warn the FPGA Manager that a warm reset it
+ * coming so it can prepare for it. When the FPGA Manager receives a warm reset
+ * handshake, the FPGA Manager drives its output clock to a quiescent state to
+ * avoid glitches.
+ * If set to 1, the  Manager makes a request to the FPGA Managerbefore asserting
+ * warm reset signals. However if the FPGA Manager is already in warm reset, the
+ * handshake is skipped.
+ * If set to 0, the handshake is skipped.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_FPGAMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_FPGAMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_MSB        8
+/* The width in bits of the ALT_RSTMGR_CTL_FPGAMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_FPGAMGRHSEN register field value. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_SET_MSK    0x00000100
+/* The mask used to clear the ALT_RSTMGR_CTL_FPGAMGRHSEN register field value. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_RSTMGR_CTL_FPGAMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_FPGAMGRHSEN field value from a register. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_RSTMGR_CTL_FPGAMGRHSEN register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSEN_SET(value) (((value) << 8) & 0x00000100)
+ * Field : FPGA Manager Handshake Request - fpgamgrhsreq
+ * Software writes this field 1 to request to the FPGA Manager to idle its output
+ * clock.
+ * Software waits for the FPGAMGRHSACK to be 1 and then writes this field to 0.
+ * Note that it is possible for the FPGA Manager to never assert FPGAMGRHSACK so
+ * software should timeout in this case.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_FPGAMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_FPGAMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_MSB        9
+/* The width in bits of the ALT_RSTMGR_CTL_FPGAMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_FPGAMGRHSREQ register field value. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_SET_MSK    0x00000200
+/* The mask used to clear the ALT_RSTMGR_CTL_FPGAMGRHSREQ register field value. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_RSTMGR_CTL_FPGAMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_FPGAMGRHSREQ field value from a register. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_RSTMGR_CTL_FPGAMGRHSREQ register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSREQ_SET(value) (((value) << 9) & 0x00000200)
+ * Field : FPGA Manager Handshake Acknowledge - fpgamgrhsack
+ * This is the acknowlege (high active) that the FPGA manager has successfully
+ * idled its output clock.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_FPGAMGRHSACK register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_FPGAMGRHSACK register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_MSB        10
+/* The width in bits of the ALT_RSTMGR_CTL_FPGAMGRHSACK register field. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_FPGAMGRHSACK register field value. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_SET_MSK    0x00000400
+/* The mask used to clear the ALT_RSTMGR_CTL_FPGAMGRHSACK register field value. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_RSTMGR_CTL_FPGAMGRHSACK register field is UNKNOWN. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_FPGAMGRHSACK field value from a register. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_RSTMGR_CTL_FPGAMGRHSACK register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_FPGAMGRHSACK_SET(value) (((value) << 10) & 0x00000400)
+ * Field : SCAN Manager Handshake Enable - scanmgrhsen
+ * Enables a handshake between the Reset Manager and Scan Manager before a warm
+ * reset. The handshake is used to warn the Scan Manager that a warm reset it
+ * coming so it can prepare for it. When the Scan Manager receives a warm reset
+ * handshake, the Scan Manager drives its output clocks to a quiescent state to
+ * avoid glitches.
+ * If set to 1, the Reset Manager makes a request to the Scan Managerbefore
+ * asserting warm reset signals. However if the Scan Manager is already in warm
+ * reset, the handshake is skipped.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SCANMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SCANMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_MSB        12
+/* The width in bits of the ALT_RSTMGR_CTL_SCANMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SCANMGRHSEN register field value. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_SET_MSK    0x00001000
+/* The mask used to clear the ALT_RSTMGR_CTL_SCANMGRHSEN register field value. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_CLR_MSK    0xffffefff
+/* The reset value of the ALT_RSTMGR_CTL_SCANMGRHSEN register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SCANMGRHSEN field value from a register. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_RSTMGR_CTL_SCANMGRHSEN register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SCANMGRHSEN_SET(value) (((value) << 12) & 0x00001000)
+ * Field : SCAN Manager Handshake Request - scanmgrhsreq
+ * Software writes this field 1 to request to the SCAN manager to idle its output
+ * clocks.
+ * Software waits for the SCANMGRHSACK to be 1 and then writes this field to 0.
+ * Note that it is possible for the Scan Manager to never assert SCANMGRHSACK (e.g.
+ * its input clock is disabled) so software should timeout in this case.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SCANMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SCANMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_MSB        13
+/* The width in bits of the ALT_RSTMGR_CTL_SCANMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SCANMGRHSREQ register field value. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_SET_MSK    0x00002000
+/* The mask used to clear the ALT_RSTMGR_CTL_SCANMGRHSREQ register field value. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_RSTMGR_CTL_SCANMGRHSREQ register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SCANMGRHSREQ field value from a register. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_RSTMGR_CTL_SCANMGRHSREQ register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SCANMGRHSREQ_SET(value) (((value) << 13) & 0x00002000)
+ * Field : SCAN Manager Handshake Acknowledge - scanmgrhsack
+ * This is the acknowlege (high active) that the SCAN manager has   successfully
+ * idled its output clocks.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_SCANMGRHSACK register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_SCANMGRHSACK register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_MSB        14
+/* The width in bits of the ALT_RSTMGR_CTL_SCANMGRHSACK register field. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_SCANMGRHSACK register field value. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_SET_MSK    0x00004000
+/* The mask used to clear the ALT_RSTMGR_CTL_SCANMGRHSACK register field value. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_RSTMGR_CTL_SCANMGRHSACK register field is UNKNOWN. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_SCANMGRHSACK field value from a register. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_RSTMGR_CTL_SCANMGRHSACK register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_SCANMGRHSACK_SET(value) (((value) << 14) & 0x00004000)
+ * Field : FPGA Handshake Enable - fpgahsen
+ * This field controls whether to perform handshake with FPGA before asserting warm
+ * reset.
+ * If set to 1, the Reset Manager makes a request to the FPGAbefore asserting warm
+ * reset signals. However if FPGA is already in warm reset state, the handshake is
+ * not performed.
+ * If set to 0, the handshake is not performed
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_FPGAHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_FPGAHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_MSB        16
+/* The width in bits of the ALT_RSTMGR_CTL_FPGAHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_FPGAHSEN register field value. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_SET_MSK    0x00010000
+/* The mask used to clear the ALT_RSTMGR_CTL_FPGAHSEN register field value. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_CLR_MSK    0xfffeffff
+/* The reset value of the ALT_RSTMGR_CTL_FPGAHSEN register field. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_FPGAHSEN field value from a register. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_GET(value) (((value) & 0x00010000) >> 16)
+/* Produces a ALT_RSTMGR_CTL_FPGAHSEN register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_FPGAHSEN_SET(value) (((value) << 16) & 0x00010000)
+ * Field : FPGA Handshake Request - fpgahsreq
+ * Software writes this field 1 to initiate handshake  request to FPGA .
+ * Software waits for the FPGAHSACK to be active and then writes this field to 0.
+ * Note that it is possible for the FPGA to never assert FPGAHSACK so software
+ * should timeout in this case.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_FPGAHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_LSB        17
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_FPGAHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_MSB        17
+/* The width in bits of the ALT_RSTMGR_CTL_FPGAHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_FPGAHSREQ register field value. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_SET_MSK    0x00020000
+/* The mask used to clear the ALT_RSTMGR_CTL_FPGAHSREQ register field value. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_CLR_MSK    0xfffdffff
+/* The reset value of the ALT_RSTMGR_CTL_FPGAHSREQ register field. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_FPGAHSREQ field value from a register. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_GET(value) (((value) & 0x00020000) >> 17)
+/* Produces a ALT_RSTMGR_CTL_FPGAHSREQ register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_FPGAHSREQ_SET(value) (((value) << 17) & 0x00020000)
+ * Field : FPGA Handshake Acknowledge - fpgahsack
+ * This is the acknowlege (high active) that the FPGA handshake   acknowledge has
+ * been received by Reset Manager.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_FPGAHSACK register field. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_LSB        18
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_FPGAHSACK register field. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_MSB        18
+/* The width in bits of the ALT_RSTMGR_CTL_FPGAHSACK register field. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_FPGAHSACK register field value. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_SET_MSK    0x00040000
+/* The mask used to clear the ALT_RSTMGR_CTL_FPGAHSACK register field value. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_CLR_MSK    0xfffbffff
+/* The reset value of the ALT_RSTMGR_CTL_FPGAHSACK register field is UNKNOWN. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_FPGAHSACK field value from a register. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_GET(value) (((value) & 0x00040000) >> 18)
+/* Produces a ALT_RSTMGR_CTL_FPGAHSACK register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_FPGAHSACK_SET(value) (((value) << 18) & 0x00040000)
+ * Field : ETR (Embedded Trace Router) Stall Enable - etrstallen
+ * This field controls whether the ETR is requested to idle its AXI master
+ * interface (i.e. finish outstanding transactions and not initiate any more) to
+ * the L3 Interconnect before a warm or debug reset. If set to 1, the Reset Manager
+ * makes a request to the ETR to stall its AXI master and waits for it to finish
+ * any outstanding AXI transactions before a warm reset of the L3 Interconnect or a
+ * debug reset of the ETR. This stalling is required because the debug logic
+ * (including the ETR) is reset on a debug reset and the ETR AXI master is
+ * connected to the L3 Interconnect which is reset on a warm reset and these resets
+ * can happen independently.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_ETRSTALLEN register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_LSB        20
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_ETRSTALLEN register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_MSB        20
+/* The width in bits of the ALT_RSTMGR_CTL_ETRSTALLEN register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_ETRSTALLEN register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_SET_MSK    0x00100000
+/* The mask used to clear the ALT_RSTMGR_CTL_ETRSTALLEN register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_CLR_MSK    0xffefffff
+/* The reset value of the ALT_RSTMGR_CTL_ETRSTALLEN register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_RESET      0x1
+/* Extracts the ALT_RSTMGR_CTL_ETRSTALLEN field value from a register. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_GET(value) (((value) & 0x00100000) >> 20)
+/* Produces a ALT_RSTMGR_CTL_ETRSTALLEN register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_ETRSTALLEN_SET(value) (((value) << 20) & 0x00100000)
+ * Field : ETR (Embedded Trace Router) Stall Request - etrstallreq
+ * Software writes this field 1 to request to the ETR that it stalls its AXI master
+ * to the L3 Interconnect.
+ * Software waits for the ETRSTALLACK to be 1 and then writes this field to 0.
+ * Note that it is possible for the ETR to never assert ETRSTALLACK so software
+ * should timeout if ETRSTALLACK is never asserted.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_ETRSTALLREQ register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_LSB        21
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_ETRSTALLREQ register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_MSB        21
+/* The width in bits of the ALT_RSTMGR_CTL_ETRSTALLREQ register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_ETRSTALLREQ register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_SET_MSK    0x00200000
+/* The mask used to clear the ALT_RSTMGR_CTL_ETRSTALLREQ register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_CLR_MSK    0xffdfffff
+/* The reset value of the ALT_RSTMGR_CTL_ETRSTALLREQ register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_ETRSTALLREQ field value from a register. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_GET(value) (((value) & 0x00200000) >> 21)
+/* Produces a ALT_RSTMGR_CTL_ETRSTALLREQ register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_ETRSTALLREQ_SET(value) (((value) << 21) & 0x00200000)
+ * Field : ETR (Embedded Trace Router) Stall Acknowledge - etrstallack
+ * This is the acknowlege for a ETR AXI master stall initiated by the ETRSTALLREQ
+ * field.  A 1 indicates that the ETR has stalled its AXI master
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_ETRSTALLACK register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_LSB        22
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_ETRSTALLACK register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_MSB        22
+/* The width in bits of the ALT_RSTMGR_CTL_ETRSTALLACK register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_ETRSTALLACK register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_SET_MSK    0x00400000
+/* The mask used to clear the ALT_RSTMGR_CTL_ETRSTALLACK register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_CLR_MSK    0xffbfffff
+/* The reset value of the ALT_RSTMGR_CTL_ETRSTALLACK register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_ETRSTALLACK field value from a register. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_GET(value) (((value) & 0x00400000) >> 22)
+/* Produces a ALT_RSTMGR_CTL_ETRSTALLACK register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_ETRSTALLACK_SET(value) (((value) << 22) & 0x00400000)
+ * Field : ETR (Embedded Trace Router) Stall After Warm Reset - etrstallwarmrst
+ * If a warm reset occurs and ETRSTALLEN is 1, hardware sets this bit to 1 to
+ * indicate that the stall of the ETR AXI master is pending. Hardware leaves the
+ * ETR stalled until software clears this field by writing it with 1. Software must
+ * only clear this field when it is ready to have the ETR AXI master start making
+ * AXI requests to write trace data.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_CTL_ETRSTALLWARMRST register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_LSB        23
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_CTL_ETRSTALLWARMRST register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_MSB        23
+/* The width in bits of the ALT_RSTMGR_CTL_ETRSTALLWARMRST register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_CTL_ETRSTALLWARMRST register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_SET_MSK    0x00800000
+/* The mask used to clear the ALT_RSTMGR_CTL_ETRSTALLWARMRST register field value. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_CLR_MSK    0xff7fffff
+/* The reset value of the ALT_RSTMGR_CTL_ETRSTALLWARMRST register field. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_RESET      0x0
+/* Extracts the ALT_RSTMGR_CTL_ETRSTALLWARMRST field value from a register. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_GET(value) (((value) & 0x00800000) >> 23)
+/* Produces a ALT_RSTMGR_CTL_ETRSTALLWARMRST register field value suitable for setting the register. */
+#define ALT_RSTMGR_CTL_ETRSTALLWARMRST_SET(value) (((value) << 23) & 0x00800000)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_RSTMGR_CTL.
+struct ALT_RSTMGR_CTL_s
+    uint32_t        swcoldrstreq    :  1;  /* Software Cold Reset Request */
+    uint32_t        swwarmrstreq    :  1;  /* Software Warm Reset Request */
+    uint32_t        sdrselfrefen    :  1;  /* SDRAM Self-Refresh Enable */
+    uint32_t        sdrselfrefreq   :  1;  /* SDRAM Self-Refresh Request */
+    const uint32_t  sdrselfreqack   :  1;  /* SDRAM Self-Refresh Acknowledge */
+    uint32_t        fpgamgrhsen     :  1;  /* FPGA Manager Handshake Enable */
+    uint32_t        fpgamgrhsreq    :  1;  /* FPGA Manager Handshake Request */
+    const uint32_t  fpgamgrhsack    :  1;  /* FPGA Manager Handshake Acknowledge */
+    uint32_t        scanmgrhsen     :  1;  /* SCAN Manager Handshake Enable */
+    uint32_t        scanmgrhsreq    :  1;  /* SCAN Manager Handshake Request */
+    const uint32_t  scanmgrhsack    :  1;  /* SCAN Manager Handshake Acknowledge */
+    uint32_t        fpgahsen        :  1;  /* FPGA Handshake Enable */
+    uint32_t        fpgahsreq       :  1;  /* FPGA Handshake Request */
+    const uint32_t  fpgahsack       :  1;  /* FPGA Handshake Acknowledge */
+    uint32_t        etrstallen      :  1;  /* ETR (Embedded Trace Router) Stall Enable */
+    uint32_t        etrstallreq     :  1;  /* ETR (Embedded Trace Router) Stall Request */
+    const uint32_t  etrstallack     :  1;  /* ETR (Embedded Trace Router) Stall Acknowledge */
+    uint32_t        etrstallwarmrst :  1;  /* ETR (Embedded Trace Router) Stall After Warm Reset */
+    uint32_t                        :  8;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_RSTMGR_CTL. */
+typedef volatile struct ALT_RSTMGR_CTL_s  ALT_RSTMGR_CTL_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_RSTMGR_CTL register from the beginning of the component. */
+#define ALT_RSTMGR_CTL_OFST        0x4
+ * Register : Reset Cycles Count Register - counts
+ * The COUNTS register is used by software to control reset behavior.It includes
+ * fields for software to control the behavior of the warm reset and nRST pin.
+ * Register Layout
+ *  Bits    | Access | Reset | Description
+ *  [7:0]   | RW     | 0x80  | Warm reset release delay count
+ *  [27:8]  | RW     | 0x800 | nRST Pin Count
+ *  [31:28] | ???    | 0x0   | *UNDEFINED*
+ * Field : Warm reset release delay count - warmrstcycles
+ * On a warm reset, the Reset Manager releases the reset to the Clock Manager, and
+ * then waits for the number of cycles specified in this register before releasing
+ * the rest of the hardware controlled resets.  Value must be greater than 16.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_COUNTS_WARMRSTCYCLES register field. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_COUNTS_WARMRSTCYCLES register field. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_MSB        7
+/* The width in bits of the ALT_RSTMGR_COUNTS_WARMRSTCYCLES register field. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_WIDTH      8
+/* The mask used to set the ALT_RSTMGR_COUNTS_WARMRSTCYCLES register field value. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_RSTMGR_COUNTS_WARMRSTCYCLES register field value. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_CLR_MSK    0xffffff00
+/* The reset value of the ALT_RSTMGR_COUNTS_WARMRSTCYCLES register field. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_RESET      0x80
+/* Extracts the ALT_RSTMGR_COUNTS_WARMRSTCYCLES field value from a register. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_RSTMGR_COUNTS_WARMRSTCYCLES register field value suitable for setting the register. */
+#define ALT_RSTMGR_COUNTS_WARMRSTCYCLES_SET(value) (((value) << 0) & 0x000000ff)
+ * Field : nRST Pin Count - nrstcnt
+ * The Reset Manager pulls down the nRST pin on a warm reset for the number of
+ * cycles specified in this register. A value of 0x0 prevents the Reset Manager
+ * from pulling down the nRST pin.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_COUNTS_NRSTCNT register field. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_COUNTS_NRSTCNT register field. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_MSB        27
+/* The width in bits of the ALT_RSTMGR_COUNTS_NRSTCNT register field. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_WIDTH      20
+/* The mask used to set the ALT_RSTMGR_COUNTS_NRSTCNT register field value. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_SET_MSK    0x0fffff00
+/* The mask used to clear the ALT_RSTMGR_COUNTS_NRSTCNT register field value. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_CLR_MSK    0xf00000ff
+/* The reset value of the ALT_RSTMGR_COUNTS_NRSTCNT register field. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_RESET      0x800
+/* Extracts the ALT_RSTMGR_COUNTS_NRSTCNT field value from a register. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_GET(value) (((value) & 0x0fffff00) >> 8)
+/* Produces a ALT_RSTMGR_COUNTS_NRSTCNT register field value suitable for setting the register. */
+#define ALT_RSTMGR_COUNTS_NRSTCNT_SET(value) (((value) << 8) & 0x0fffff00)
+ * The struct declaration for register ALT_RSTMGR_COUNTS.
+struct ALT_RSTMGR_COUNTS_s
+    uint32_t  warmrstcycles :  8;  /* Warm reset release delay count */
+    uint32_t  nrstcnt       : 20;  /* nRST Pin Count */
+/* The typedef declaration for register ALT_RSTMGR_COUNTS. */
+typedef volatile struct ALT_RSTMGR_COUNTS_s  ALT_RSTMGR_COUNTS_t;
+/* The byte offset of the ALT_RSTMGR_COUNTS register from the beginning of the component. */
+#define ALT_RSTMGR_COUNTS_OFST        0x8
+ * Register : MPU Module Reset Register - mpumodrst
+ * The MPUMODRST register is used by software to trigger module resets (individual
+ * module reset signals). Software explicitly asserts and de-asserts module reset
+ * signals by writing bits in the appropriate *MODRST register. It is up to
+ * software to ensure module reset signals are asserted for the appropriate length
+ * of time and are de-asserted in the correct order. It is also up to software to
+ * not assert a module reset signal that would prevent software from de-asserting
+ * the module reset signal. For example, software should not assert the module
+ * reset to the CPU executing the software.
+ * Software writes a bit to 1 to assert the module reset signal and to 0 to de-
+ * assert the module reset signal.
+ * All fields except CPU1 are only reset by a cold reset. The CPU1 field is reset
+ * by a cold reset. The CPU1 field is also reset by a warm reset if not masked by
+ * the corresponding MPUWARMMASK field.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | CPU0
+ *  [1]    | RW     | 0x1   | CPU1
+ *  [2]    | RW     | 0x0   | Watchdogs
+ *  [3]    | RW     | 0x0   | SCU/Peripherals
+ *  [4]    | RW     | 0x0   | L2
+ *  [31:5] | ???    | 0x0   | *UNDEFINED*
+ * Field : CPU0 - cpu0
+ * Resets Cortex-A9 CPU0 in MPU. Whe software changes this field from 0 to 1,
+ * ittriggers the following sequence:  1. CPU0 reset is asserted. cpu0 clkoff is
+ * de-asserted 2. after 32 osc1_clk cycles, cpu0 clkoff is asserted.
+ * When software changes this field from 1 to 0, it triggers the following
+ * sequence: 1.CPU0 reset is de-asserted. 2. after 32 cycles, cpu0 clkoff is de-
+ * asserted.
+ * Software needs to wait for at least 64 osc1_clk cycles between each change of
+ * this field to keep the proper reset/clkoff sequence.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MPUMODRST_CPU0 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MPUMODRST_CPU0 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_MSB        0
+/* The width in bits of the ALT_RSTMGR_MPUMODRST_CPU0 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MPUMODRST_CPU0 register field value. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_RSTMGR_MPUMODRST_CPU0 register field value. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_RSTMGR_MPUMODRST_CPU0 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_RESET      0x0
+/* Extracts the ALT_RSTMGR_MPUMODRST_CPU0 field value from a register. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_RSTMGR_MPUMODRST_CPU0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_MPUMODRST_CPU0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : CPU1 - cpu1
+ * Resets Cortex-A9 CPU1 in MPU.
+ * It is reset to 1 on a cold or warm reset. This holds CPU1 in reset until
+ * software is ready to release CPU1 from reset by writing 0 to this field.
+ * On single-core devices, writes to this field are ignored.On dual-core devices,
+ * writes to this field trigger the same sequence as writes to the CPU0 field
+ * (except the sequence is performed on CPU1).
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MPUMODRST_CPU1 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MPUMODRST_CPU1 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_MSB        1
+/* The width in bits of the ALT_RSTMGR_MPUMODRST_CPU1 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MPUMODRST_CPU1 register field value. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_RSTMGR_MPUMODRST_CPU1 register field value. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_RSTMGR_MPUMODRST_CPU1 register field. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_RESET      0x1
+/* Extracts the ALT_RSTMGR_MPUMODRST_CPU1 field value from a register. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_RSTMGR_MPUMODRST_CPU1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_MPUMODRST_CPU1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Watchdogs - wds
+ * Resets both per-CPU Watchdog Reset Status registers in MPU.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MPUMODRST_WDS register field. */
+#define ALT_RSTMGR_MPUMODRST_WDS_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MPUMODRST_WDS register field. */
+#define ALT_RSTMGR_MPUMODRST_WDS_MSB        2
+/* The width in bits of the ALT_RSTMGR_MPUMODRST_WDS register field. */
+#define ALT_RSTMGR_MPUMODRST_WDS_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MPUMODRST_WDS register field value. */
+#define ALT_RSTMGR_MPUMODRST_WDS_SET_MSK    0x00000004
+/* The mask used to clear the ALT_RSTMGR_MPUMODRST_WDS register field value. */
+#define ALT_RSTMGR_MPUMODRST_WDS_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_RSTMGR_MPUMODRST_WDS register field. */
+#define ALT_RSTMGR_MPUMODRST_WDS_RESET      0x0
+/* Extracts the ALT_RSTMGR_MPUMODRST_WDS field value from a register. */
+#define ALT_RSTMGR_MPUMODRST_WDS_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_RSTMGR_MPUMODRST_WDS register field value suitable for setting the register. */
+#define ALT_RSTMGR_MPUMODRST_WDS_SET(value) (((value) << 2) & 0x00000004)
+ * Field : SCU/Peripherals - scuper
+ * Resets SCU and peripherals. Peripherals consist of the interrupt controller,
+ * global timer, both per-CPU private timers, and both per-CPU watchdogs (except
+ * for the Watchdog Reset Status registers).
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MPUMODRST_SCUPER register field. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MPUMODRST_SCUPER register field. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_MSB        3
+/* The width in bits of the ALT_RSTMGR_MPUMODRST_SCUPER register field. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MPUMODRST_SCUPER register field value. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_SET_MSK    0x00000008
+/* The mask used to clear the ALT_RSTMGR_MPUMODRST_SCUPER register field value. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_RSTMGR_MPUMODRST_SCUPER register field. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_RESET      0x0
+/* Extracts the ALT_RSTMGR_MPUMODRST_SCUPER field value from a register. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_RSTMGR_MPUMODRST_SCUPER register field value suitable for setting the register. */
+#define ALT_RSTMGR_MPUMODRST_SCUPER_SET(value) (((value) << 3) & 0x00000008)
+ * Field : L2 - l2
+ * Resets L2 cache controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MPUMODRST_L2 register field. */
+#define ALT_RSTMGR_MPUMODRST_L2_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MPUMODRST_L2 register field. */
+#define ALT_RSTMGR_MPUMODRST_L2_MSB        4
+/* The width in bits of the ALT_RSTMGR_MPUMODRST_L2 register field. */
+#define ALT_RSTMGR_MPUMODRST_L2_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MPUMODRST_L2 register field value. */
+#define ALT_RSTMGR_MPUMODRST_L2_SET_MSK    0x00000010
+/* The mask used to clear the ALT_RSTMGR_MPUMODRST_L2 register field value. */
+#define ALT_RSTMGR_MPUMODRST_L2_CLR_MSK    0xffffffef
+/* The reset value of the ALT_RSTMGR_MPUMODRST_L2 register field. */
+#define ALT_RSTMGR_MPUMODRST_L2_RESET      0x0
+/* Extracts the ALT_RSTMGR_MPUMODRST_L2 field value from a register. */
+#define ALT_RSTMGR_MPUMODRST_L2_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_RSTMGR_MPUMODRST_L2 register field value suitable for setting the register. */
+#define ALT_RSTMGR_MPUMODRST_L2_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_RSTMGR_MPUMODRST.
+struct ALT_RSTMGR_MPUMODRST_s
+    uint32_t  cpu0   :  1;  /* CPU0 */
+    uint32_t  cpu1   :  1;  /* CPU1 */
+    uint32_t  wds    :  1;  /* Watchdogs */
+    uint32_t  scuper :  1;  /* SCU/Peripherals */
+    uint32_t  l2     :  1;  /* L2 */
+    uint32_t         : 27;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_RSTMGR_MPUMODRST. */
+typedef volatile struct ALT_RSTMGR_MPUMODRST_s  ALT_RSTMGR_MPUMODRST_t;
+/* The byte offset of the ALT_RSTMGR_MPUMODRST register from the beginning of the component. */
+#define ALT_RSTMGR_MPUMODRST_OFST        0x10
+ * Register : Peripheral Module Reset Register - permodrst
+ * The PERMODRST register is used by software to trigger module resets (individual
+ * All fields are reset by a cold reset.All fields are also reset by a warm reset
+ * if not masked by the corresponding PERWARMMASK field.
+ * The reset value of all fields is 1. This holds the corresponding module in reset
+ * until software is ready to release the module from reset by writing 0 to its
+ * field.
+ * Register Layout
+ *  [0]     | RW     | 0x1   | EMAC0
+ *  [1]     | RW     | 0x1   | EMAC1
+ *  [2]     | RW     | 0x1   | USB0
+ *  [3]     | RW     | 0x1   | USB1
+ *  [4]     | RW     | 0x1   | NAND Flash
+ *  [5]     | RW     | 0x1   | QSPI Flash
+ *  [6]     | RW     | 0x1   | L4 Watchdog 0
+ *  [7]     | RW     | 0x1   | L4 Watchdog 1
+ *  [8]     | RW     | 0x1   | OSC1 Timer 0
+ *  [9]     | RW     | 0x1   | OSC1 Timer 1
+ *  [10]    | RW     | 0x1   | SP Timer 0
+ *  [11]    | RW     | 0x1   | SP Timer 1
+ *  [12]    | RW     | 0x1   | I2C0
+ *  [13]    | RW     | 0x1   | I2C1
+ *  [14]    | RW     | 0x1   | I2C2
+ *  [15]    | RW     | 0x1   | I2C3
+ *  [16]    | RW     | 0x1   | UART0
+ *  [17]    | RW     | 0x1   | UART1
+ *  [18]    | RW     | 0x1   | SPIM0
+ *  [19]    | RW     | 0x1   | SPIM1
+ *  [20]    | RW     | 0x1   | SPIS0
+ *  [21]    | RW     | 0x1   | SPIS1
+ *  [22]    | RW     | 0x1   | SD/MMC
+ *  [23]    | RW     | 0x1   | CAN0
+ *  [24]    | RW     | 0x1   | CAN1
+ *  [25]    | RW     | 0x1   | GPIO0
+ *  [26]    | RW     | 0x1   | GPIO1
+ *  [27]    | RW     | 0x1   | GPIO2
+ *  [28]    | RW     | 0x1   | DMA Controller
+ *  [29]    | RW     | 0x1   | SDRAM Controller Subsystem
+ *  [31:30] | ???    | 0x0   | *UNDEFINED*
+ * Field : EMAC0 - emac0
+ * Resets EMAC0
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_EMAC0 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_EMAC0 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_MSB        0
+/* The width in bits of the ALT_RSTMGR_PERMODRST_EMAC0 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_EMAC0 register field value. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_EMAC0 register field value. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_RSTMGR_PERMODRST_EMAC0 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_EMAC0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_RSTMGR_PERMODRST_EMAC0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_EMAC0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : EMAC1 - emac1
+ * Resets EMAC1
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_EMAC1 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_EMAC1 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_MSB        1
+/* The width in bits of the ALT_RSTMGR_PERMODRST_EMAC1 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_EMAC1 register field value. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_EMAC1 register field value. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_RSTMGR_PERMODRST_EMAC1 register field. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_EMAC1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_RSTMGR_PERMODRST_EMAC1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_EMAC1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : USB0 - usb0
+ * Resets USB0
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_USB0 register field. */
+#define ALT_RSTMGR_PERMODRST_USB0_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_USB0 register field. */
+#define ALT_RSTMGR_PERMODRST_USB0_MSB        2
+/* The width in bits of the ALT_RSTMGR_PERMODRST_USB0 register field. */
+#define ALT_RSTMGR_PERMODRST_USB0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_USB0 register field value. */
+#define ALT_RSTMGR_PERMODRST_USB0_SET_MSK    0x00000004
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_USB0 register field value. */
+#define ALT_RSTMGR_PERMODRST_USB0_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_RSTMGR_PERMODRST_USB0 register field. */
+#define ALT_RSTMGR_PERMODRST_USB0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_USB0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_USB0_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_RSTMGR_PERMODRST_USB0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_USB0_SET(value) (((value) << 2) & 0x00000004)
+ * Field : USB1 - usb1
+ * Resets USB1
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_USB1 register field. */
+#define ALT_RSTMGR_PERMODRST_USB1_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_USB1 register field. */
+#define ALT_RSTMGR_PERMODRST_USB1_MSB        3
+/* The width in bits of the ALT_RSTMGR_PERMODRST_USB1 register field. */
+#define ALT_RSTMGR_PERMODRST_USB1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_USB1 register field value. */
+#define ALT_RSTMGR_PERMODRST_USB1_SET_MSK    0x00000008
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_USB1 register field value. */
+#define ALT_RSTMGR_PERMODRST_USB1_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_RSTMGR_PERMODRST_USB1 register field. */
+#define ALT_RSTMGR_PERMODRST_USB1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_USB1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_USB1_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_RSTMGR_PERMODRST_USB1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_USB1_SET(value) (((value) << 3) & 0x00000008)
+ * Field : NAND Flash - nand
+ * Resets NAND flash controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_NAND register field. */
+#define ALT_RSTMGR_PERMODRST_NAND_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_NAND register field. */
+#define ALT_RSTMGR_PERMODRST_NAND_MSB        4
+/* The width in bits of the ALT_RSTMGR_PERMODRST_NAND register field. */
+#define ALT_RSTMGR_PERMODRST_NAND_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_NAND register field value. */
+#define ALT_RSTMGR_PERMODRST_NAND_SET_MSK    0x00000010
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_NAND register field value. */
+#define ALT_RSTMGR_PERMODRST_NAND_CLR_MSK    0xffffffef
+/* The reset value of the ALT_RSTMGR_PERMODRST_NAND register field. */
+#define ALT_RSTMGR_PERMODRST_NAND_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_NAND field value from a register. */
+#define ALT_RSTMGR_PERMODRST_NAND_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_RSTMGR_PERMODRST_NAND register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_NAND_SET(value) (((value) << 4) & 0x00000010)
+ * Field : QSPI Flash - qspi
+ * Resets QSPI flash controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_QSPI register field. */
+#define ALT_RSTMGR_PERMODRST_QSPI_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_QSPI register field. */
+#define ALT_RSTMGR_PERMODRST_QSPI_MSB        5
+/* The width in bits of the ALT_RSTMGR_PERMODRST_QSPI register field. */
+#define ALT_RSTMGR_PERMODRST_QSPI_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_QSPI register field value. */
+#define ALT_RSTMGR_PERMODRST_QSPI_SET_MSK    0x00000020
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_QSPI register field value. */
+#define ALT_RSTMGR_PERMODRST_QSPI_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_RSTMGR_PERMODRST_QSPI register field. */
+#define ALT_RSTMGR_PERMODRST_QSPI_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_QSPI field value from a register. */
+#define ALT_RSTMGR_PERMODRST_QSPI_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_RSTMGR_PERMODRST_QSPI register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_QSPI_SET(value) (((value) << 5) & 0x00000020)
+ * Field : L4 Watchdog 0 - l4wd0
+ * Resets watchdog 0 connected to L4
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_L4WD0 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_L4WD0 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_MSB        6
+/* The width in bits of the ALT_RSTMGR_PERMODRST_L4WD0 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_L4WD0 register field value. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_SET_MSK    0x00000040
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_L4WD0 register field value. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_RSTMGR_PERMODRST_L4WD0 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_L4WD0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_RSTMGR_PERMODRST_L4WD0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_L4WD0_SET(value) (((value) << 6) & 0x00000040)
+ * Field : L4 Watchdog 1 - l4wd1
+ * Resets watchdog 1 connected to L4
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_L4WD1 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_L4WD1 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_MSB        7
+/* The width in bits of the ALT_RSTMGR_PERMODRST_L4WD1 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_L4WD1 register field value. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_SET_MSK    0x00000080
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_L4WD1 register field value. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_RSTMGR_PERMODRST_L4WD1 register field. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_L4WD1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_RSTMGR_PERMODRST_L4WD1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_L4WD1_SET(value) (((value) << 7) & 0x00000080)
+ * Field : OSC1 Timer 0 - osc1timer0
+ * Resets OSC1 timer 0 connected to L4
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_OSC1TMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_OSC1TMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_MSB        8
+/* The width in bits of the ALT_RSTMGR_PERMODRST_OSC1TMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_OSC1TMR0 register field value. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_SET_MSK    0x00000100
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_OSC1TMR0 register field value. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_RSTMGR_PERMODRST_OSC1TMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_OSC1TMR0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_RSTMGR_PERMODRST_OSC1TMR0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR0_SET(value) (((value) << 8) & 0x00000100)
+ * Field : OSC1 Timer 1 - osc1timer1
+ * Resets OSC1 timer 1 connected to L4
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_OSC1TMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_OSC1TMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_MSB        9
+/* The width in bits of the ALT_RSTMGR_PERMODRST_OSC1TMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_OSC1TMR1 register field value. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_SET_MSK    0x00000200
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_OSC1TMR1 register field value. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_RSTMGR_PERMODRST_OSC1TMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_OSC1TMR1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_RSTMGR_PERMODRST_OSC1TMR1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_OSC1TMR1_SET(value) (((value) << 9) & 0x00000200)
+ * Field : SP Timer 0 - sptimer0
+ * Resets SP timer 0 connected to L4
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SPTMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SPTMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_MSB        10
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SPTMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SPTMR0 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_SET_MSK    0x00000400
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SPTMR0 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SPTMR0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SPTMR0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_RSTMGR_PERMODRST_SPTMR0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SPTMR0_SET(value) (((value) << 10) & 0x00000400)
+ * Field : SP Timer 1 - sptimer1
+ * Resets SP timer 1 connected to L4
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SPTMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_LSB        11
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SPTMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_MSB        11
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SPTMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SPTMR1 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_SET_MSK    0x00000800
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SPTMR1 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_CLR_MSK    0xfffff7ff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SPTMR1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SPTMR1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_GET(value) (((value) & 0x00000800) >> 11)
+/* Produces a ALT_RSTMGR_PERMODRST_SPTMR1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SPTMR1_SET(value) (((value) << 11) & 0x00000800)
+ * Field : I2C0 - i2c0
+ * Resets I2C0 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_I2C0 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C0_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_I2C0 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C0_MSB        12
+/* The width in bits of the ALT_RSTMGR_PERMODRST_I2C0 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_I2C0 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C0_SET_MSK    0x00001000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_I2C0 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C0_CLR_MSK    0xffffefff
+/* The reset value of the ALT_RSTMGR_PERMODRST_I2C0 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_I2C0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_I2C0_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_RSTMGR_PERMODRST_I2C0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_I2C0_SET(value) (((value) << 12) & 0x00001000)
+ * Field : I2C1 - i2c1
+ * Resets I2C1 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_I2C1 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C1_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_I2C1 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C1_MSB        13
+/* The width in bits of the ALT_RSTMGR_PERMODRST_I2C1 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_I2C1 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C1_SET_MSK    0x00002000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_I2C1 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C1_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_RSTMGR_PERMODRST_I2C1 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_I2C1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_I2C1_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_RSTMGR_PERMODRST_I2C1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_I2C1_SET(value) (((value) << 13) & 0x00002000)
+ * Field : I2C2 - i2c2
+ * Resets I2C2 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_I2C2 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C2_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_I2C2 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C2_MSB        14
+/* The width in bits of the ALT_RSTMGR_PERMODRST_I2C2 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C2_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_I2C2 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C2_SET_MSK    0x00004000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_I2C2 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C2_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_RSTMGR_PERMODRST_I2C2 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C2_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_I2C2 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_I2C2_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_RSTMGR_PERMODRST_I2C2 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_I2C2_SET(value) (((value) << 14) & 0x00004000)
+ * Field : I2C3 - i2c3
+ * Resets I2C3 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_I2C3 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C3_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_I2C3 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C3_MSB        15
+/* The width in bits of the ALT_RSTMGR_PERMODRST_I2C3 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C3_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_I2C3 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C3_SET_MSK    0x00008000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_I2C3 register field value. */
+#define ALT_RSTMGR_PERMODRST_I2C3_CLR_MSK    0xffff7fff
+/* The reset value of the ALT_RSTMGR_PERMODRST_I2C3 register field. */
+#define ALT_RSTMGR_PERMODRST_I2C3_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_I2C3 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_I2C3_GET(value) (((value) & 0x00008000) >> 15)
+/* Produces a ALT_RSTMGR_PERMODRST_I2C3 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_I2C3_SET(value) (((value) << 15) & 0x00008000)
+ * Field : UART0 - uart0
+ * Resets UART0
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_UART0 register field. */
+#define ALT_RSTMGR_PERMODRST_UART0_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_UART0 register field. */
+#define ALT_RSTMGR_PERMODRST_UART0_MSB        16
+/* The width in bits of the ALT_RSTMGR_PERMODRST_UART0 register field. */
+#define ALT_RSTMGR_PERMODRST_UART0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_UART0 register field value. */
+#define ALT_RSTMGR_PERMODRST_UART0_SET_MSK    0x00010000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_UART0 register field value. */
+#define ALT_RSTMGR_PERMODRST_UART0_CLR_MSK    0xfffeffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_UART0 register field. */
+#define ALT_RSTMGR_PERMODRST_UART0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_UART0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_UART0_GET(value) (((value) & 0x00010000) >> 16)
+/* Produces a ALT_RSTMGR_PERMODRST_UART0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_UART0_SET(value) (((value) << 16) & 0x00010000)
+ * Field : UART1 - uart1
+ * Resets UART1
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_UART1 register field. */
+#define ALT_RSTMGR_PERMODRST_UART1_LSB        17
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_UART1 register field. */
+#define ALT_RSTMGR_PERMODRST_UART1_MSB        17
+/* The width in bits of the ALT_RSTMGR_PERMODRST_UART1 register field. */
+#define ALT_RSTMGR_PERMODRST_UART1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_UART1 register field value. */
+#define ALT_RSTMGR_PERMODRST_UART1_SET_MSK    0x00020000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_UART1 register field value. */
+#define ALT_RSTMGR_PERMODRST_UART1_CLR_MSK    0xfffdffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_UART1 register field. */
+#define ALT_RSTMGR_PERMODRST_UART1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_UART1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_UART1_GET(value) (((value) & 0x00020000) >> 17)
+/* Produces a ALT_RSTMGR_PERMODRST_UART1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_UART1_SET(value) (((value) << 17) & 0x00020000)
+ * Field : SPIM0 - spim0
+ * Resets SPIM0 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SPIM0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_LSB        18
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SPIM0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_MSB        18
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SPIM0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SPIM0 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_SET_MSK    0x00040000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SPIM0 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_CLR_MSK    0xfffbffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SPIM0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SPIM0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_GET(value) (((value) & 0x00040000) >> 18)
+/* Produces a ALT_RSTMGR_PERMODRST_SPIM0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SPIM0_SET(value) (((value) << 18) & 0x00040000)
+ * Field : SPIM1 - spim1
+ * Resets SPIM1 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SPIM1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_LSB        19
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SPIM1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_MSB        19
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SPIM1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SPIM1 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_SET_MSK    0x00080000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SPIM1 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_CLR_MSK    0xfff7ffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SPIM1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SPIM1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_GET(value) (((value) & 0x00080000) >> 19)
+/* Produces a ALT_RSTMGR_PERMODRST_SPIM1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SPIM1_SET(value) (((value) << 19) & 0x00080000)
+ * Field : SPIS0 - spis0
+ * Resets SPIS0 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SPIS0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_LSB        20
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SPIS0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_MSB        20
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SPIS0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SPIS0 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_SET_MSK    0x00100000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SPIS0 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_CLR_MSK    0xffefffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SPIS0 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SPIS0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_GET(value) (((value) & 0x00100000) >> 20)
+/* Produces a ALT_RSTMGR_PERMODRST_SPIS0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SPIS0_SET(value) (((value) << 20) & 0x00100000)
+ * Field : SPIS1 - spis1
+ * Resets SPIS1 controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SPIS1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_LSB        21
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SPIS1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_MSB        21
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SPIS1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SPIS1 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_SET_MSK    0x00200000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SPIS1 register field value. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_CLR_MSK    0xffdfffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SPIS1 register field. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SPIS1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_GET(value) (((value) & 0x00200000) >> 21)
+/* Produces a ALT_RSTMGR_PERMODRST_SPIS1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SPIS1_SET(value) (((value) << 21) & 0x00200000)
+ * Field : SD/MMC - sdmmc
+ * Resets SD/MMC controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SDMMC register field. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_LSB        22
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SDMMC register field. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_MSB        22
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SDMMC register field. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SDMMC register field value. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_SET_MSK    0x00400000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SDMMC register field value. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_CLR_MSK    0xffbfffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SDMMC register field. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SDMMC field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_GET(value) (((value) & 0x00400000) >> 22)
+/* Produces a ALT_RSTMGR_PERMODRST_SDMMC register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SDMMC_SET(value) (((value) << 22) & 0x00400000)
+ * Field : CAN0 - can0
+ * Resets CAN0 controller.
+ * Writes to this field on devices not containing CAN controllers will be ignored.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_CAN0 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN0_LSB        23
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_CAN0 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN0_MSB        23
+/* The width in bits of the ALT_RSTMGR_PERMODRST_CAN0 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_CAN0 register field value. */
+#define ALT_RSTMGR_PERMODRST_CAN0_SET_MSK    0x00800000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_CAN0 register field value. */
+#define ALT_RSTMGR_PERMODRST_CAN0_CLR_MSK    0xff7fffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_CAN0 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_CAN0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_CAN0_GET(value) (((value) & 0x00800000) >> 23)
+/* Produces a ALT_RSTMGR_PERMODRST_CAN0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_CAN0_SET(value) (((value) << 23) & 0x00800000)
+ * Field : CAN1 - can1
+ * Resets CAN1 controller.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_CAN1 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN1_LSB        24
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_CAN1 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN1_MSB        24
+/* The width in bits of the ALT_RSTMGR_PERMODRST_CAN1 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_CAN1 register field value. */
+#define ALT_RSTMGR_PERMODRST_CAN1_SET_MSK    0x01000000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_CAN1 register field value. */
+#define ALT_RSTMGR_PERMODRST_CAN1_CLR_MSK    0xfeffffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_CAN1 register field. */
+#define ALT_RSTMGR_PERMODRST_CAN1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_CAN1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_CAN1_GET(value) (((value) & 0x01000000) >> 24)
+/* Produces a ALT_RSTMGR_PERMODRST_CAN1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_CAN1_SET(value) (((value) << 24) & 0x01000000)
+ * Field : GPIO0 - gpio0
+ * Resets GPIO0
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_GPIO0 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_LSB        25
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_GPIO0 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_MSB        25
+/* The width in bits of the ALT_RSTMGR_PERMODRST_GPIO0 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_GPIO0 register field value. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_SET_MSK    0x02000000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_GPIO0 register field value. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_CLR_MSK    0xfdffffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_GPIO0 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_GPIO0 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_GET(value) (((value) & 0x02000000) >> 25)
+/* Produces a ALT_RSTMGR_PERMODRST_GPIO0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_GPIO0_SET(value) (((value) << 25) & 0x02000000)
+ * Field : GPIO1 - gpio1
+ * Resets GPIO1
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_GPIO1 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_LSB        26
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_GPIO1 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_MSB        26
+/* The width in bits of the ALT_RSTMGR_PERMODRST_GPIO1 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_GPIO1 register field value. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_SET_MSK    0x04000000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_GPIO1 register field value. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_CLR_MSK    0xfbffffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_GPIO1 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_GPIO1 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_GET(value) (((value) & 0x04000000) >> 26)
+/* Produces a ALT_RSTMGR_PERMODRST_GPIO1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_GPIO1_SET(value) (((value) << 26) & 0x04000000)
+ * Field : GPIO2 - gpio2
+ * Resets GPIO2
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_GPIO2 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_LSB        27
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_GPIO2 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_MSB        27
+/* The width in bits of the ALT_RSTMGR_PERMODRST_GPIO2 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_GPIO2 register field value. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_SET_MSK    0x08000000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_GPIO2 register field value. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_CLR_MSK    0xf7ffffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_GPIO2 register field. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_GPIO2 field value from a register. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_GET(value) (((value) & 0x08000000) >> 27)
+/* Produces a ALT_RSTMGR_PERMODRST_GPIO2 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_GPIO2_SET(value) (((value) << 27) & 0x08000000)
+ * Field : DMA Controller - dma
+ * Resets DMA controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_DMA register field. */
+#define ALT_RSTMGR_PERMODRST_DMA_LSB        28
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_DMA register field. */
+#define ALT_RSTMGR_PERMODRST_DMA_MSB        28
+/* The width in bits of the ALT_RSTMGR_PERMODRST_DMA register field. */
+#define ALT_RSTMGR_PERMODRST_DMA_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_DMA register field value. */
+#define ALT_RSTMGR_PERMODRST_DMA_SET_MSK    0x10000000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_DMA register field value. */
+#define ALT_RSTMGR_PERMODRST_DMA_CLR_MSK    0xefffffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_DMA register field. */
+#define ALT_RSTMGR_PERMODRST_DMA_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_DMA field value from a register. */
+#define ALT_RSTMGR_PERMODRST_DMA_GET(value) (((value) & 0x10000000) >> 28)
+/* Produces a ALT_RSTMGR_PERMODRST_DMA register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_DMA_SET(value) (((value) << 28) & 0x10000000)
+ * Field : SDRAM Controller Subsystem - sdr
+ * Resets SDRAM Controller Subsystem affected by a warm or cold reset.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PERMODRST_SDR register field. */
+#define ALT_RSTMGR_PERMODRST_SDR_LSB        29
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PERMODRST_SDR register field. */
+#define ALT_RSTMGR_PERMODRST_SDR_MSB        29
+/* The width in bits of the ALT_RSTMGR_PERMODRST_SDR register field. */
+#define ALT_RSTMGR_PERMODRST_SDR_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PERMODRST_SDR register field value. */
+#define ALT_RSTMGR_PERMODRST_SDR_SET_MSK    0x20000000
+/* The mask used to clear the ALT_RSTMGR_PERMODRST_SDR register field value. */
+#define ALT_RSTMGR_PERMODRST_SDR_CLR_MSK    0xdfffffff
+/* The reset value of the ALT_RSTMGR_PERMODRST_SDR register field. */
+#define ALT_RSTMGR_PERMODRST_SDR_RESET      0x1
+/* Extracts the ALT_RSTMGR_PERMODRST_SDR field value from a register. */
+#define ALT_RSTMGR_PERMODRST_SDR_GET(value) (((value) & 0x20000000) >> 29)
+/* Produces a ALT_RSTMGR_PERMODRST_SDR register field value suitable for setting the register. */
+#define ALT_RSTMGR_PERMODRST_SDR_SET(value) (((value) << 29) & 0x20000000)
+ * The struct declaration for register ALT_RSTMGR_PERMODRST.
+struct ALT_RSTMGR_PERMODRST_s
+    uint32_t  emac0      :  1;  /* EMAC0 */
+    uint32_t  emac1      :  1;  /* EMAC1 */
+    uint32_t  usb0       :  1;  /* USB0 */
+    uint32_t  usb1       :  1;  /* USB1 */
+    uint32_t  nand       :  1;  /* NAND Flash */
+    uint32_t  qspi       :  1;  /* QSPI Flash */
+    uint32_t  l4wd0      :  1;  /* L4 Watchdog 0 */
+    uint32_t  l4wd1      :  1;  /* L4 Watchdog 1 */
+    uint32_t  osc1timer0 :  1;  /* OSC1 Timer 0 */
+    uint32_t  osc1timer1 :  1;  /* OSC1 Timer 1 */
+    uint32_t  sptimer0   :  1;  /* SP Timer 0 */
+    uint32_t  sptimer1   :  1;  /* SP Timer 1 */
+    uint32_t  i2c0       :  1;  /* I2C0 */
+    uint32_t  i2c1       :  1;  /* I2C1 */
+    uint32_t  i2c2       :  1;  /* I2C2 */
+    uint32_t  i2c3       :  1;  /* I2C3 */
+    uint32_t  uart0      :  1;  /* UART0 */
+    uint32_t  uart1      :  1;  /* UART1 */
+    uint32_t  spim0      :  1;  /* SPIM0 */
+    uint32_t  spim1      :  1;  /* SPIM1 */
+    uint32_t  spis0      :  1;  /* SPIS0 */
+    uint32_t  spis1      :  1;  /* SPIS1 */
+    uint32_t  sdmmc      :  1;  /* SD/MMC */
+    uint32_t  can0       :  1;  /* CAN0 */
+    uint32_t  can1       :  1;  /* CAN1 */
+    uint32_t  gpio0      :  1;  /* GPIO0 */
+    uint32_t  gpio1      :  1;  /* GPIO1 */
+    uint32_t  gpio2      :  1;  /* GPIO2 */
+    uint32_t  dma        :  1;  /* DMA Controller */
+    uint32_t  sdr        :  1;  /* SDRAM Controller Subsystem */
+    uint32_t             :  2;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_RSTMGR_PERMODRST. */
+typedef volatile struct ALT_RSTMGR_PERMODRST_s  ALT_RSTMGR_PERMODRST_t;
+/* The byte offset of the ALT_RSTMGR_PERMODRST register from the beginning of the component. */
+#define ALT_RSTMGR_PERMODRST_OFST        0x14
+ * Register : Peripheral 2 Module Reset Register - per2modrst
+ * The PER2MODRST register is used by software to trigger module resets (individual
+ * field.
+ * Register Layout
+ *  [0]    | RW     | 0x1   | FPGA DMA0
+ *  [1]    | RW     | 0x1   | FPGA DMA1
+ *  [2]    | RW     | 0x1   | FPGA DMA2
+ *  [3]    | RW     | 0x1   | FPGA DMA3
+ *  [4]    | RW     | 0x1   | FPGA DMA4
+ *  [5]    | RW     | 0x1   | FPGA DMA5
+ *  [6]    | RW     | 0x1   | FPGA DMA6
+ *  [7]    | RW     | 0x1   | FPGA DMA7
+ *  [31:8] | ???    | 0x0   | *UNDEFINED*
+ * Field : FPGA DMA0 - dmaif0
+ * Resets DMA channel 0 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF0 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF0 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_MSB        0
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF0 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF0 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF0 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF0 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF0 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF0 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : FPGA DMA1 - dmaif1
+ * Resets DMA channel 1 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF1 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF1 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_MSB        1
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF1 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF1 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF1 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF1 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF1 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF1 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : FPGA DMA2 - dmaif2
+ * Resets DMA channel 2 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF2 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF2 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_MSB        2
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF2 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF2 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_SET_MSK    0x00000004
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF2 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF2 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF2 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF2 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF2_SET(value) (((value) << 2) & 0x00000004)
+ * Field : FPGA DMA3 - dmaif3
+ * Resets DMA channel 3 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF3 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF3 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_MSB        3
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF3 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF3 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_SET_MSK    0x00000008
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF3 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF3 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF3 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF3 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF3_SET(value) (((value) << 3) & 0x00000008)
+ * Field : FPGA DMA4 - dmaif4
+ * Resets DMA channel 4 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF4 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF4 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_MSB        4
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF4 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF4 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_SET_MSK    0x00000010
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF4 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_CLR_MSK    0xffffffef
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF4 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF4 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF4 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF4_SET(value) (((value) << 4) & 0x00000010)
+ * Field : FPGA DMA5 - dmaif5
+ * Resets DMA channel 5 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF5 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF5 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_MSB        5
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF5 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF5 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_SET_MSK    0x00000020
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF5 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF5 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF5 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF5 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF5_SET(value) (((value) << 5) & 0x00000020)
+ * Field : FPGA DMA6 - dmaif6
+ * Resets DMA channel 6 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF6 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF6 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_MSB        6
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF6 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF6 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_SET_MSK    0x00000040
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF6 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF6 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF6 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF6 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF6_SET(value) (((value) << 6) & 0x00000040)
+ * Field : FPGA DMA7 - dmaif7
+ * Resets DMA channel 7 interface adapter between FPGA Fabric and HPS DMA
+ * Controller
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF7 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_PER2MODRST_DMAIF7 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_MSB        7
+/* The width in bits of the ALT_RSTMGR_PER2MODRST_DMAIF7 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_PER2MODRST_DMAIF7 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_SET_MSK    0x00000080
+/* The mask used to clear the ALT_RSTMGR_PER2MODRST_DMAIF7 register field value. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_RSTMGR_PER2MODRST_DMAIF7 register field. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_RESET      0x1
+/* Extracts the ALT_RSTMGR_PER2MODRST_DMAIF7 field value from a register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_RSTMGR_PER2MODRST_DMAIF7 register field value suitable for setting the register. */
+#define ALT_RSTMGR_PER2MODRST_DMAIF7_SET(value) (((value) << 7) & 0x00000080)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_RSTMGR_PER2MODRST.
+struct ALT_RSTMGR_PER2MODRST_s
+    uint32_t  dmaif0 :  1;  /* FPGA DMA0 */
+    uint32_t  dmaif1 :  1;  /* FPGA DMA1 */
+    uint32_t  dmaif2 :  1;  /* FPGA DMA2 */
+    uint32_t  dmaif3 :  1;  /* FPGA DMA3 */
+    uint32_t  dmaif4 :  1;  /* FPGA DMA4 */
+    uint32_t  dmaif5 :  1;  /* FPGA DMA5 */
+    uint32_t  dmaif6 :  1;  /* FPGA DMA6 */
+    uint32_t  dmaif7 :  1;  /* FPGA DMA7 */
+    uint32_t         : 24;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_RSTMGR_PER2MODRST. */
+typedef volatile struct ALT_RSTMGR_PER2MODRST_s  ALT_RSTMGR_PER2MODRST_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_RSTMGR_PER2MODRST register from the beginning of the component. */
+#define ALT_RSTMGR_PER2MODRST_OFST        0x18
+ * Register : Bridge Module Reset Register - brgmodrst
+ * The BRGMODRST register is used by software to trigger module resets (individual
+ * if not masked by the corresponding BRGWARMMASK field.
+ * field.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [0]    | RW     | 0x1   | HPS2FPGA Bridge
+ *  [1]    | RW     | 0x1   | LWHPS2FPGA Bridge
+ *  [2]    | RW     | 0x1   | FPGA2HPS Bridge
+ *  [31:3] | ???    | 0x0   | *UNDEFINED*
+ * Field : HPS2FPGA Bridge - hps2fpga
+ * Resets HPS2FPGA Bridge
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_BRGMODRST_H2F register field. */
+#define ALT_RSTMGR_BRGMODRST_H2F_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_BRGMODRST_H2F register field. */
+#define ALT_RSTMGR_BRGMODRST_H2F_MSB        0
+/* The width in bits of the ALT_RSTMGR_BRGMODRST_H2F register field. */
+#define ALT_RSTMGR_BRGMODRST_H2F_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_BRGMODRST_H2F register field value. */
+#define ALT_RSTMGR_BRGMODRST_H2F_SET_MSK    0x00000001
+/* The mask used to clear the ALT_RSTMGR_BRGMODRST_H2F register field value. */
+#define ALT_RSTMGR_BRGMODRST_H2F_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_RSTMGR_BRGMODRST_H2F register field. */
+#define ALT_RSTMGR_BRGMODRST_H2F_RESET      0x1
+/* Extracts the ALT_RSTMGR_BRGMODRST_H2F field value from a register. */
+#define ALT_RSTMGR_BRGMODRST_H2F_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_RSTMGR_BRGMODRST_H2F register field value suitable for setting the register. */
+#define ALT_RSTMGR_BRGMODRST_H2F_SET(value) (((value) << 0) & 0x00000001)
+ * Field : LWHPS2FPGA Bridge - lwhps2fpga
+ * Resets LWHPS2FPGA Bridge
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_BRGMODRST_LWH2F register field. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_BRGMODRST_LWH2F register field. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_MSB        1
+/* The width in bits of the ALT_RSTMGR_BRGMODRST_LWH2F register field. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_BRGMODRST_LWH2F register field value. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_SET_MSK    0x00000002
+/* The mask used to clear the ALT_RSTMGR_BRGMODRST_LWH2F register field value. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_RSTMGR_BRGMODRST_LWH2F register field. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_RESET      0x1
+/* Extracts the ALT_RSTMGR_BRGMODRST_LWH2F field value from a register. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_RSTMGR_BRGMODRST_LWH2F register field value suitable for setting the register. */
+#define ALT_RSTMGR_BRGMODRST_LWH2F_SET(value) (((value) << 1) & 0x00000002)
+ * Field : FPGA2HPS Bridge - fpga2hps
+ * Resets FPGA2HPS Bridge
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_BRGMODRST_F2H register field. */
+#define ALT_RSTMGR_BRGMODRST_F2H_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_BRGMODRST_F2H register field. */
+#define ALT_RSTMGR_BRGMODRST_F2H_MSB        2
+/* The width in bits of the ALT_RSTMGR_BRGMODRST_F2H register field. */
+#define ALT_RSTMGR_BRGMODRST_F2H_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_BRGMODRST_F2H register field value. */
+#define ALT_RSTMGR_BRGMODRST_F2H_SET_MSK    0x00000004
+/* The mask used to clear the ALT_RSTMGR_BRGMODRST_F2H register field value. */
+#define ALT_RSTMGR_BRGMODRST_F2H_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_RSTMGR_BRGMODRST_F2H register field. */
+#define ALT_RSTMGR_BRGMODRST_F2H_RESET      0x1
+/* Extracts the ALT_RSTMGR_BRGMODRST_F2H field value from a register. */
+#define ALT_RSTMGR_BRGMODRST_F2H_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_RSTMGR_BRGMODRST_F2H register field value suitable for setting the register. */
+#define ALT_RSTMGR_BRGMODRST_F2H_SET(value) (((value) << 2) & 0x00000004)
+ * The struct declaration for register ALT_RSTMGR_BRGMODRST.
+struct ALT_RSTMGR_BRGMODRST_s
+    uint32_t  hps2fpga   :  1;  /* HPS2FPGA Bridge */
+    uint32_t  lwhps2fpga :  1;  /* LWHPS2FPGA Bridge */
+    uint32_t  fpga2hps   :  1;  /* FPGA2HPS Bridge */
+    uint32_t             : 29;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_RSTMGR_BRGMODRST. */
+typedef volatile struct ALT_RSTMGR_BRGMODRST_s  ALT_RSTMGR_BRGMODRST_t;
+/* The byte offset of the ALT_RSTMGR_BRGMODRST register from the beginning of the component. */
+#define ALT_RSTMGR_BRGMODRST_OFST        0x1c
+ * Register : Miscellaneous Module Reset Register - miscmodrst
+ * The MISCMODRST register is used by software to trigger module resets (individual
+ * module reset signals). Software explicitly asserts and de-asserts module reset
+ * signals by writing bits in the appropriate *MODRST register. It is up to
+ * software to ensure module reset signals are asserted for the appropriate length
+ * of time and are de-asserted in the correct order. It is also up to software to
+ * not assert a module reset signal that would prevent software from de-asserting
+ * the module reset signal. For example, software should not assert the module
+ * reset to the CPU executing the software.
+ * Software writes a bit to 1 to assert the module reset signal and to 0 to de-
+ * assert the module reset signal.
+ * All fields are only reset by a cold reset
+ * Register Layout
+ *  [0]     | RW     | 0x0   | Boot ROM
+ *  [1]     | RW     | 0x0   | On-chip RAM
+ *  [2]     | RW     | 0x0   | System Manager (Cold or Warm)
+ *  [3]     | RW     | 0x0   | System Manager (Cold-only)
+ *  [4]     | RW     | 0x0   | FPGA Manager
+ *  [5]     | RW     | 0x0   | ACP ID Mapper
+ *  [6]     | RW     | 0x0   | HPS to FPGA Core (Cold or Warm)
+ *  [7]     | RW     | 0x0   | HPS to FPGA Core (Cold-only)
+ *  [8]     | RW     | 0x0   | nRST Pin
+ *  [9]     | RW     | 0x0   | Timestamp
+ *  [10]    | RW     | 0x0   | Clock Manager
+ *  [11]    | RW     | 0x0   | Scan Manager
+ *  [12]    | RW     | 0x0   | Freeze Controller
+ *  [13]    | RW     | 0x0   | System/Debug
+ *  [14]    | RW     | 0x0   | Debug
+ *  [15]    | RW     | 0x0   | TAP Controller
+ *  [16]    | RW     | 0x0   | SDRAM Controller Subsystem Cold Reset
+ *  [31:17] | ???    | 0x0   | *UNDEFINED*
+ * Field : Boot ROM - rom
+ * Resets Boot ROM
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_ROM register field. */
+#define ALT_RSTMGR_MISCMODRST_ROM_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_ROM register field. */
+#define ALT_RSTMGR_MISCMODRST_ROM_MSB        0
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_ROM register field. */
+#define ALT_RSTMGR_MISCMODRST_ROM_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_ROM register field value. */
+#define ALT_RSTMGR_MISCMODRST_ROM_SET_MSK    0x00000001
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_ROM register field value. */
+#define ALT_RSTMGR_MISCMODRST_ROM_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_RSTMGR_MISCMODRST_ROM register field. */
+#define ALT_RSTMGR_MISCMODRST_ROM_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_ROM field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_ROM_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_RSTMGR_MISCMODRST_ROM register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_ROM_SET(value) (((value) << 0) & 0x00000001)
+ * Field : On-chip RAM - ocram
+ * Resets On-chip RAM
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_OCRAM register field. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_OCRAM register field. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_MSB        1
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_OCRAM register field. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_OCRAM register field value. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_SET_MSK    0x00000002
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_OCRAM register field value. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_RSTMGR_MISCMODRST_OCRAM register field. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_OCRAM field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_RSTMGR_MISCMODRST_OCRAM register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_OCRAM_SET(value) (((value) << 1) & 0x00000002)
+ * Field : System Manager (Cold or Warm) - sysmgr
+ * Resets logic in System Manager that doesn't differentiate between cold and warm
+ * resets
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_SYSMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_SYSMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_MSB        2
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_SYSMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_SYSMGR register field value. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_SET_MSK    0x00000004
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_SYSMGR register field value. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_RSTMGR_MISCMODRST_SYSMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_SYSMGR field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_RSTMGR_MISCMODRST_SYSMGR register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGR_SET(value) (((value) << 2) & 0x00000004)
+ * Field : System Manager (Cold-only) - sysmgrcold
+ * Resets logic in System Manager that is only reset by a cold reset (ignores warm
+ * reset)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_SYSMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_SYSMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_MSB        3
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_SYSMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_SYSMGRCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_SET_MSK    0x00000008
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_SYSMGRCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_RSTMGR_MISCMODRST_SYSMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_SYSMGRCOLD field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_RSTMGR_MISCMODRST_SYSMGRCOLD register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_SYSMGRCOLD_SET(value) (((value) << 3) & 0x00000008)
+ * Field : FPGA Manager - fpgamgr
+ * Resets FPGA Manager
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_FPGAMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_FPGAMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_MSB        4
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_FPGAMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_FPGAMGR register field value. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_FPGAMGR register field value. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_RSTMGR_MISCMODRST_FPGAMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_FPGAMGR field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_RSTMGR_MISCMODRST_FPGAMGR register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_FPGAMGR_SET(value) (((value) << 4) & 0x00000010)
+ * Field : ACP ID Mapper - acpidmap
+ * Resets ACP ID Mapper
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_ACPIDMAP register field. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_ACPIDMAP register field. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_MSB        5
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_ACPIDMAP register field. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_ACPIDMAP register field value. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_SET_MSK    0x00000020
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_ACPIDMAP register field value. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_RSTMGR_MISCMODRST_ACPIDMAP register field. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_ACPIDMAP field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_RSTMGR_MISCMODRST_ACPIDMAP register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_ACPIDMAP_SET(value) (((value) << 5) & 0x00000020)
+ * Field : HPS to FPGA Core (Cold or Warm) - s2f
+ * Resets logic in FPGA core that doesn't differentiate between HPS cold and warm
+ * resets (h2f_rst_n = 1)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_S2F register field. */
+#define ALT_RSTMGR_MISCMODRST_S2F_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_S2F register field. */
+#define ALT_RSTMGR_MISCMODRST_S2F_MSB        6
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_S2F register field. */
+#define ALT_RSTMGR_MISCMODRST_S2F_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_S2F register field value. */
+#define ALT_RSTMGR_MISCMODRST_S2F_SET_MSK    0x00000040
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_S2F register field value. */
+#define ALT_RSTMGR_MISCMODRST_S2F_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_RSTMGR_MISCMODRST_S2F register field. */
+#define ALT_RSTMGR_MISCMODRST_S2F_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_S2F field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_S2F_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_RSTMGR_MISCMODRST_S2F register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_S2F_SET(value) (((value) << 6) & 0x00000040)
+ * Field : HPS to FPGA Core (Cold-only) - s2fcold
+ * Resets logic in FPGA core that is only reset by a cold reset (ignores warm
+ * reset) (h2f_cold_rst_n = 1)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_S2FCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_S2FCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_MSB        7
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_S2FCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_S2FCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_SET_MSK    0x00000080
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_S2FCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_RSTMGR_MISCMODRST_S2FCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_S2FCOLD field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_RSTMGR_MISCMODRST_S2FCOLD register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_S2FCOLD_SET(value) (((value) << 7) & 0x00000080)
+ * Field : nRST Pin - nrstpin
+ * Pulls nRST pin low
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_NRSTPIN register field. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_NRSTPIN register field. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_MSB        8
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_NRSTPIN register field. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_NRSTPIN register field value. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_SET_MSK    0x00000100
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_NRSTPIN register field value. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_NRSTPIN register field. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_NRSTPIN field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_RSTMGR_MISCMODRST_NRSTPIN register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_NRSTPIN_SET(value) (((value) << 8) & 0x00000100)
+ * Field : Timestamp - timestampcold
+ * Resets debug timestamp to 0 (cold reset only)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_TSCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_TSCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_MSB        9
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_TSCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_TSCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_SET_MSK    0x00000200
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_TSCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_TSCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_TSCOLD field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_RSTMGR_MISCMODRST_TSCOLD register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_TSCOLD_SET(value) (((value) << 9) & 0x00000200)
+ * Field : Clock Manager - clkmgrcold
+ * Resets Clock Manager (cold reset only)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_CLKMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_CLKMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_MSB        10
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_CLKMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_CLKMGRCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_SET_MSK    0x00000400
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_CLKMGRCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_CLKMGRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_CLKMGRCOLD field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_RSTMGR_MISCMODRST_CLKMGRCOLD register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_CLKMGRCOLD_SET(value) (((value) << 10) & 0x00000400)
+ * Field : Scan Manager - scanmgr
+ * Resets Scan Manager
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_SCANMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_LSB        11
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_SCANMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_MSB        11
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_SCANMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_SCANMGR register field value. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_SET_MSK    0x00000800
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_SCANMGR register field value. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_CLR_MSK    0xfffff7ff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_SCANMGR register field. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_SCANMGR field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_GET(value) (((value) & 0x00000800) >> 11)
+/* Produces a ALT_RSTMGR_MISCMODRST_SCANMGR register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_SCANMGR_SET(value) (((value) << 11) & 0x00000800)
+ * Field : Freeze Controller - frzctrlcold
+ * Resets Freeze Controller in System Manager (cold reset only)
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_FRZCTLCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_FRZCTLCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_MSB        12
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_FRZCTLCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_FRZCTLCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_SET_MSK    0x00001000
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_FRZCTLCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_CLR_MSK    0xffffefff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_FRZCTLCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_FRZCTLCOLD field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_RSTMGR_MISCMODRST_FRZCTLCOLD register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_FRZCTLCOLD_SET(value) (((value) << 12) & 0x00001000)
+ * Field : System/Debug - sysdbg
+ * Resets logic that spans the system and debug domains.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_SYSDBG register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_SYSDBG register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_MSB        13
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_SYSDBG register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_SYSDBG register field value. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_SET_MSK    0x00002000
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_SYSDBG register field value. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_SYSDBG register field. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_SYSDBG field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_RSTMGR_MISCMODRST_SYSDBG register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_SYSDBG_SET(value) (((value) << 13) & 0x00002000)
+ * Field : Debug - dbg
+ * Resets logic located only in the debug domain.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_DBG register field. */
+#define ALT_RSTMGR_MISCMODRST_DBG_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_DBG register field. */
+#define ALT_RSTMGR_MISCMODRST_DBG_MSB        14
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_DBG register field. */
+#define ALT_RSTMGR_MISCMODRST_DBG_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_DBG register field value. */
+#define ALT_RSTMGR_MISCMODRST_DBG_SET_MSK    0x00004000
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_DBG register field value. */
+#define ALT_RSTMGR_MISCMODRST_DBG_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_DBG register field. */
+#define ALT_RSTMGR_MISCMODRST_DBG_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_DBG field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_DBG_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_RSTMGR_MISCMODRST_DBG register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_DBG_SET(value) (((value) << 14) & 0x00004000)
+ * Field : TAP Controller - tapcold
+ * Resets portion of DAP JTAG TAP controller no reset by a debug probe reset (i.e.
+ * nTRST pin).  Cold reset only.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_TAPCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_TAPCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_MSB        15
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_TAPCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_TAPCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_SET_MSK    0x00008000
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_TAPCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_CLR_MSK    0xffff7fff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_TAPCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_TAPCOLD field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_GET(value) (((value) & 0x00008000) >> 15)
+/* Produces a ALT_RSTMGR_MISCMODRST_TAPCOLD register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_TAPCOLD_SET(value) (((value) << 15) & 0x00008000)
+ * Field : SDRAM Controller Subsystem Cold Reset - sdrcold
+ * Resets logic in SDRAM Controller Subsystem affected only by a cold reset.
+/* The Least Significant Bit (LSB) position of the ALT_RSTMGR_MISCMODRST_SDRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_RSTMGR_MISCMODRST_SDRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_MSB        16
+/* The width in bits of the ALT_RSTMGR_MISCMODRST_SDRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_WIDTH      1
+/* The mask used to set the ALT_RSTMGR_MISCMODRST_SDRCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_SET_MSK    0x00010000
+/* The mask used to clear the ALT_RSTMGR_MISCMODRST_SDRCOLD register field value. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_CLR_MSK    0xfffeffff
+/* The reset value of the ALT_RSTMGR_MISCMODRST_SDRCOLD register field. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_RESET      0x0
+/* Extracts the ALT_RSTMGR_MISCMODRST_SDRCOLD field value from a register. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_GET(value) (((value) & 0x00010000) >> 16)
+/* Produces a ALT_RSTMGR_MISCMODRST_SDRCOLD register field value suitable for setting the register. */
+#define ALT_RSTMGR_MISCMODRST_SDRCOLD_SET(value) (((value) << 16) & 0x00010000)
+ * The struct declaration for register ALT_RSTMGR_MISCMODRST.
+struct ALT_RSTMGR_MISCMODRST_s
+    uint32_t  rom           :  1;  /* Boot ROM */
+    uint32_t  ocram         :  1;  /* On-chip RAM */
+    uint32_t  sysmgr        :  1;  /* System Manager (Cold or Warm) */
+    uint32_t  sysmgrcold    :  1;  /* System Manager (Cold-only) */
+    uint32_t  fpgamgr       :  1;  /* FPGA Manager */
+    uint32_t  acpidmap      :  1;  /* ACP ID Mapper */
+    uint32_t  s2f           :  1;  /* HPS to FPGA Core (Cold or Warm) */
+    uint32_t  s2fcold       :  1;  /* HPS to FPGA Core (Cold-only) */
+    uint32_t  nrstpin       :  1;  /* nRST Pin */
+    uint32_t  timestampcold :  1;  /* Timestamp */
+    uint32_t  clkmgrcold    :  1;  /* Clock Manager */
+    uint32_t  scanmgr       :  1;  /* Scan Manager */
+    uint32_t  frzctrlcold   :  1;  /* Freeze Controller */
+    uint32_t  sysdbg        :  1;  /* System/Debug */
+    uint32_t  dbg           :  1;  /* Debug */
+    uint32_t  tapcold       :  1;  /* TAP Controller */
+    uint32_t  sdrcold       :  1;  /* SDRAM Controller Subsystem Cold Reset */
+    uint32_t                : 15;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_RSTMGR_MISCMODRST. */
+typedef volatile struct ALT_RSTMGR_MISCMODRST_s  ALT_RSTMGR_MISCMODRST_t;
+/* The byte offset of the ALT_RSTMGR_MISCMODRST register from the beginning of the component. */
+#define ALT_RSTMGR_MISCMODRST_OFST        0x20
+ * The struct declaration for register group ALT_RSTMGR.
+struct ALT_RSTMGR_s
+    volatile ALT_RSTMGR_STAT_t        stat;                 /* ALT_RSTMGR_STAT */
+    volatile ALT_RSTMGR_CTL_t         ctrl;                 /* ALT_RSTMGR_CTL */
+    volatile ALT_RSTMGR_COUNTS_t      counts;               /* ALT_RSTMGR_COUNTS */
+    volatile uint32_t                 _pad_0xc_0xf;         /* *UNDEFINED* */
+    volatile ALT_RSTMGR_MPUMODRST_t   mpumodrst;            /* ALT_RSTMGR_MPUMODRST */
+    volatile ALT_RSTMGR_PERMODRST_t   permodrst;            /* ALT_RSTMGR_PERMODRST */
+    volatile ALT_RSTMGR_PER2MODRST_t  per2modrst;           /* ALT_RSTMGR_PER2MODRST */
+    volatile ALT_RSTMGR_BRGMODRST_t   brgmodrst;            /* ALT_RSTMGR_BRGMODRST */
+    volatile ALT_RSTMGR_MISCMODRST_t  miscmodrst;           /* ALT_RSTMGR_MISCMODRST */
+    volatile uint32_t                 _pad_0x24_0x100[55];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_RSTMGR. */
+typedef volatile struct ALT_RSTMGR_s  ALT_RSTMGR_t;
+/* The struct declaration for the raw register contents of register group ALT_RSTMGR. */
+struct ALT_RSTMGR_raw_s
+    volatile uint32_t  stat;                 /* ALT_RSTMGR_STAT */
+    volatile uint32_t  ctrl;                 /* ALT_RSTMGR_CTL */
+    volatile uint32_t  counts;               /* ALT_RSTMGR_COUNTS */
+    volatile uint32_t  mpumodrst;            /* ALT_RSTMGR_MPUMODRST */
+    volatile uint32_t  permodrst;            /* ALT_RSTMGR_PERMODRST */
+    volatile uint32_t  per2modrst;           /* ALT_RSTMGR_PER2MODRST */
+    volatile uint32_t  brgmodrst;            /* ALT_RSTMGR_BRGMODRST */
+    volatile uint32_t  miscmodrst;           /* ALT_RSTMGR_MISCMODRST */
+/* The typedef declaration for the raw register contents of register group ALT_RSTMGR. */
+typedef volatile struct ALT_RSTMGR_raw_s  ALT_RSTMGR_raw_t;
+#ifdef __cplusplus
+#endif  /* __cplusplus */
+#endif  /* __ALTERA_ALT_RSTMGR_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sdr.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sdr.h
new file mode 100644
index 0000000..785aa74
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sdr.h
@@ -0,0 +1,4149 @@
+* Copyright 2013 Altera Corporation. All Rights Reserved.                      *
+* Redistribution and use in source and binary forms, with or without           *
+* modification, are permitted provided that the following conditions are met:  *
+* 1. Redistributions of source code must retain the above copyright notice,    *
+*    this list of conditions and the following disclaimer.                     *
+* 2. Redistributions in binary form must reproduce the above copyright notice, *
+*    this list of conditions and the following disclaimer in the documentation *
+*    and/or other materials provided with the distribution.                    *
+* 3. The name of the author may not be used to endorse or promote products     *
+*    derived from this software without specific prior written permission.     *
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO  *
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,       *
+* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
+* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;  *
+* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,     *
+* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR      *
+* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF       *
+* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                                   *
+/* Altera - ALT_SDR */
+#ifndef __ALTERA_ALT_SDR_H__
+#define __ALTERA_ALT_SDR_H__
+#ifdef __cplusplus
+extern "C"
+ * Component : SDRAM Controller - ALT_SDR
+ * SDRAM Controller
+ * Address map for the SDRAM Interface registers
+ * Register Group : SDRAM Controller Module - ALT_SDR_CTL
+ * SDRAM Controller Module
+ * Address map for the SDRAM controller and multi-port front-end.
+ * All registers in this group reset to zero.
+ * Register : Controller Configuration Register - ctrlcfg
+ * The Controller Configuration Register determines the behavior of the controller.
+ * Register Layout
+ *  [2:0]   | RW     | Unknown | DRAM Memory Type
+ *  [7:3]   | RW     | Unknown | DRAM Memory Burst Length
+ *  [9:8]   | RW     | Unknown | Address Interleaving Order
+ *  [10]    | RW     | Unknown | ECC Enable
+ *  [11]    | RW     | Unknown | ECC Auto-Correction Enable
+ *  [12]    | RW     | Unknown | TBD
+ *  [13]    | RW     | Unknown | Generate Single Bit Errors
+ *  [14]    | RW     | Unknown | Generate Double Bit Errors
+ *  [15]    | RW     | Unknown | Command Reorder Enable
+ *  [21:16] | RW     | Unknown | Starvation Limit
+ *  [22]    | RW     | Unknown | DQS Tracking Enable
+ *  [23]    | RW     | Unknown | No DM Pins Present
+ *  [24]    | RW     | Unknown | Burst Interrupt Enable
+ *  [25]    | RW     | Unknown | Burst Terminate Enable
+ *  [31:26] | ???    | Unknown | *UNDEFINED*
+ * Field : DRAM Memory Type - memtype
+ * Selects memory type. Program this field with one of the following binary values,
+ * "001" for DDR2 SDRAM, "010" for DDR3 SDRAM, "011"
+ * for LPDDR1 SDRAM or "100" for LPDDR2 SDRAM.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_MSB        2
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_WIDTH      3
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_MEMTYPE register field value. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_SET_MSK    0x00000007
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_MEMTYPE register field value. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_CLR_MSK    0xfffffff8
+/* The reset value of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_MEMTYPE field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_GET(value) (((value) & 0x00000007) >> 0)
+/* Produces a ALT_SDR_CTL_CTLCFG_MEMTYPE register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_MEMTYPE_SET(value) (((value) << 0) & 0x00000007)
+ * Field : DRAM Memory Burst Length - membl
+ * Configures burst length as a static decimal value.  Legal values are valid for
+ * JEDEC allowed DRAM values for the DRAM selected in cfg_type.  For DDR3, this
+ * should be programmed with 8 (binary "01000"), for DDR2 it can be
+ * either 4 or 8 depending on the exact DRAM chip.  LPDDR2 can be programmed with
+ * 4, 8, or 16 and LPDDR can be programmed with 2, 4, or 8. You must also program
+ * the membl field in the staticcfg register.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_MEMBL register field. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_MEMBL register field. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_MSB        7
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_MEMBL register field. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_WIDTH      5
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_MEMBL register field value. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_SET_MSK    0x000000f8
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_MEMBL register field value. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_CLR_MSK    0xffffff07
+/* The reset value of the ALT_SDR_CTL_CTLCFG_MEMBL register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_MEMBL field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_GET(value) (((value) & 0x000000f8) >> 3)
+/* Produces a ALT_SDR_CTL_CTLCFG_MEMBL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_MEMBL_SET(value) (((value) << 3) & 0x000000f8)
+ * Field : Address Interleaving Order - addrorder
+ * Selects the order for address interleaving.  Programming this field with
+ * different values gives different mappings between the AXI or Avalon-MM address
+ * and the SDRAM address. Program this field with the following binary values to
+ * select the ordering. "00" - chip, row, bank, column, "01" -
+ * chip, bank, row, column, "10"-row, chip, bank, column
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_MSB        9
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_WIDTH      2
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_ADDRORDER register field value. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_SET_MSK    0x00000300
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_ADDRORDER register field value. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_CLR_MSK    0xfffffcff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_ADDRORDER field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_GET(value) (((value) & 0x00000300) >> 8)
+/* Produces a ALT_SDR_CTL_CTLCFG_ADDRORDER register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_ADDRORDER_SET(value) (((value) << 8) & 0x00000300)
+ * Field : ECC Enable - eccen
+ * Enable the generation and checking of ECC.  This bit must only be set if the
+ * memory connected to the SDRAM interface is 24 or 40 bits wide. If you set this,
+ * you must clear the useeccasdata field in the staticcfg register.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_ECCEN register field. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_ECCEN register field. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_MSB        10
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_ECCEN register field. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_ECCEN register field value. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_SET_MSK    0x00000400
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_ECCEN register field value. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_ECCEN register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_ECCEN field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_SDR_CTL_CTLCFG_ECCEN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_ECCEN_SET(value) (((value) << 10) & 0x00000400)
+ * Field : ECC Auto-Correction Enable - ecccorren
+ * Enable auto correction of the read data returned when single bit error is
+ * detected.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_LSB        11
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_MSB        11
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_ECCCORREN register field value. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_SET_MSK    0x00000800
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_ECCCORREN register field value. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_CLR_MSK    0xfffff7ff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_ECCCORREN field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_GET(value) (((value) & 0x00000800) >> 11)
+/* Produces a ALT_SDR_CTL_CTLCFG_ECCCORREN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_ECCCORREN_SET(value) (((value) << 11) & 0x00000800)
+ * Field : TBD - cfg_enable_ecc_code_overwrites
+ * Set to a one to enable ECC overwrites.  ECC overwrites occur when a correctable
+ * ECC error is seen and cause a new read/modify/write to be scheduled for that
+ * location to clear the ECC error.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_MSB        12
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field value. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_SET_MSK    0x00001000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field value. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_CLR_MSK    0xffffefff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_SET(value) (((value) << 12) & 0x00001000)
+ * Field : Generate Single Bit Errors - gensbe
+ * Enable the deliberate insertion of single bit errors in data written to memory.
+ * This should only be used for testing purposes.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_GENSBE register field. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_GENSBE register field. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_MSB        13
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_GENSBE register field. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_GENSBE register field value. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_SET_MSK    0x00002000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_GENSBE register field value. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_GENSBE register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_GENSBE field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_SDR_CTL_CTLCFG_GENSBE register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_GENSBE_SET(value) (((value) << 13) & 0x00002000)
+ * Field : Generate Double Bit Errors - gendbe
+ * Enable the deliberate insertion of double bit errors in data written to memory.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_GENDBE register field. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_GENDBE register field. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_MSB        14
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_GENDBE register field. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_GENDBE register field value. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_SET_MSK    0x00004000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_GENDBE register field value. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_GENDBE register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_GENDBE field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_SDR_CTL_CTLCFG_GENDBE register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_GENDBE_SET(value) (((value) << 14) & 0x00004000)
+ * Field : Command Reorder Enable - reorderen
+ * This bit controls whether the controller can re-order operations to optimize
+ * SDRAM bandwidth.  It should generally be set to a one.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_REORDEREN register field. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_REORDEREN register field. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_MSB        15
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_REORDEREN register field. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_REORDEREN register field value. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_SET_MSK    0x00008000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_REORDEREN register field value. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_CLR_MSK    0xffff7fff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_REORDEREN register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_REORDEREN field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_GET(value) (((value) & 0x00008000) >> 15)
+/* Produces a ALT_SDR_CTL_CTLCFG_REORDEREN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_REORDEREN_SET(value) (((value) << 15) & 0x00008000)
+ * Field : Starvation Limit - starvelimit
+ * Specifies the number of DRAM burst transactions an individual transaction will
+ * allow to reorder ahead of it before its priority is raised in the memory
+ * controller.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_MSB        21
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_WIDTH      6
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field value. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_SET_MSK    0x003f0000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field value. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_CLR_MSK    0xffc0ffff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_STARVELIMIT field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_GET(value) (((value) & 0x003f0000) >> 16)
+/* Produces a ALT_SDR_CTL_CTLCFG_STARVELIMIT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_SET(value) (((value) << 16) & 0x003f0000)
+ * Field : DQS Tracking Enable - dqstrken
+ * Enables DQS tracking in the PHY.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_LSB        22
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_MSB        22
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field value. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_SET_MSK    0x00400000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field value. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_CLR_MSK    0xffbfffff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_DQSTRKEN field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_GET(value) (((value) & 0x00400000) >> 22)
+/* Produces a ALT_SDR_CTL_CTLCFG_DQSTRKEN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_SET(value) (((value) << 22) & 0x00400000)
+ * Field : No DM Pins Present - nodmpins
+ * Set to a one to enable DRAM operation if no DM pins are connected.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_NODMPINS register field. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_LSB        23
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_NODMPINS register field. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_MSB        23
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_NODMPINS register field. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_NODMPINS register field value. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_SET_MSK    0x00800000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_NODMPINS register field value. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_CLR_MSK    0xff7fffff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_NODMPINS register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_NODMPINS field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_GET(value) (((value) & 0x00800000) >> 23)
+/* Produces a ALT_SDR_CTL_CTLCFG_NODMPINS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_NODMPINS_SET(value) (((value) << 23) & 0x00800000)
+ * Field : Burst Interrupt Enable - burstintren
+ * Set to a one to enable the controller to issue burst interrupt commands. This
+ * must only be set when the DRAM memory type is LPDDR2.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_LSB        24
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_MSB        24
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field value. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_SET_MSK    0x01000000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field value. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_CLR_MSK    0xfeffffff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_BURSTINTREN field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_GET(value) (((value) & 0x01000000) >> 24)
+/* Produces a ALT_SDR_CTL_CTLCFG_BURSTINTREN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_SET(value) (((value) << 24) & 0x01000000)
+ * Field : Burst Terminate Enable - bursttermen
+ * Set to a one to enable the controller to issue burst terminate commands. This
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_LSB        25
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_MSB        25
+/* The width in bits of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field value. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_SET_MSK    0x02000000
+/* The mask used to clear the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field value. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_CLR_MSK    0xfdffffff
+/* The reset value of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLCFG_BURSTTERMEN field value from a register. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_GET(value) (((value) & 0x02000000) >> 25)
+/* Produces a ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_SET(value) (((value) << 25) & 0x02000000)
+ * The struct declaration for register ALT_SDR_CTL_CTLCFG.
+struct ALT_SDR_CTL_CTLCFG_s
+    uint32_t  memtype                        :  3;  /* DRAM Memory Type */
+    uint32_t  membl                          :  5;  /* DRAM Memory Burst Length */
+    uint32_t  addrorder                      :  2;  /* Address Interleaving Order */
+    uint32_t  eccen                          :  1;  /* ECC Enable */
+    uint32_t  ecccorren                      :  1;  /* ECC Auto-Correction Enable */
+    uint32_t  cfg_enable_ecc_code_overwrites :  1;  /* TBD */
+    uint32_t  gensbe                         :  1;  /* Generate Single Bit Errors */
+    uint32_t  gendbe                         :  1;  /* Generate Double Bit Errors */
+    uint32_t  reorderen                      :  1;  /* Command Reorder Enable */
+    uint32_t  starvelimit                    :  6;  /* Starvation Limit */
+    uint32_t  dqstrken                       :  1;  /* DQS Tracking Enable */
+    uint32_t  nodmpins                       :  1;  /* No DM Pins Present */
+    uint32_t  burstintren                    :  1;  /* Burst Interrupt Enable */
+    uint32_t  bursttermen                    :  1;  /* Burst Terminate Enable */
+    uint32_t                                 :  6;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_CTLCFG. */
+typedef volatile struct ALT_SDR_CTL_CTLCFG_s  ALT_SDR_CTL_CTLCFG_t;
+/* The byte offset of the ALT_SDR_CTL_CTLCFG register from the beginning of the component. */
+#define ALT_SDR_CTL_CTLCFG_OFST        0x0
+ * Register : DRAM Timings 1 Register - dramtiming1
+ * This register implements JEDEC standardized timing parameters.  It should be
+ * programmed in clock cycles, for the value specified by the memory vendor.
+ * Register Layout
+ *  [3:0]   | RW     | Unknown | CAS Write Latency
+ *  [8:4]   | RW     | Unknown | Additive Latency
+ *  [13:9]  | RW     | Unknown | CAS Read Latency
+ *  [17:14] | RW     | Unknown | Activate to Activate Delay
+ *  [23:18] | RW     | Unknown | Four Activate Window Time
+ *  [31:24] | RW     | Unknown | Refresh Cycle Time
+ * Field : CAS Write Latency - tcwl
+ * Memory write latency.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_MSB        3
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TCWL register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TCWL register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TCWL field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMTIMING1_TCWL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCWL_SET(value) (((value) << 0) & 0x0000000f)
+ * Field : Additive Latency - tal
+ * Memory additive latency.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TAL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TAL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_MSB        8
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TAL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_WIDTH      5
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TAL register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_SET_MSK    0x000001f0
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TAL register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_CLR_MSK    0xfffffe0f
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TAL register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TAL field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_GET(value) (((value) & 0x000001f0) >> 4)
+/* Produces a ALT_SDR_CTL_DRAMTIMING1_TAL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TAL_SET(value) (((value) << 4) & 0x000001f0)
+ * Field : CAS Read Latency - tcl
+ * Memory read latency.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_MSB        13
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TCL register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_WIDTH      5
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TCL register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_SET_MSK    0x00003e00
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TCL register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_CLR_MSK    0xffffc1ff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TCL register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TCL field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_GET(value) (((value) & 0x00003e00) >> 9)
+/* Produces a ALT_SDR_CTL_DRAMTIMING1_TCL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TCL_SET(value) (((value) << 9) & 0x00003e00)
+ * Field : Activate to Activate Delay - trrd
+ * The activate to activate, different banks timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_MSB        17
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TRRD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_SET_MSK    0x0003c000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TRRD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_CLR_MSK    0xfffc3fff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TRRD field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_GET(value) (((value) & 0x0003c000) >> 14)
+/* Produces a ALT_SDR_CTL_DRAMTIMING1_TRRD register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRRD_SET(value) (((value) << 14) & 0x0003c000)
+ * Field : Four Activate Window Time - tfaw
+ * The four-activate window timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_LSB        18
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_MSB        23
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_WIDTH      6
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TFAW register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_SET_MSK    0x00fc0000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TFAW register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_CLR_MSK    0xff03ffff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TFAW field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_GET(value) (((value) & 0x00fc0000) >> 18)
+/* Produces a ALT_SDR_CTL_DRAMTIMING1_TFAW register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TFAW_SET(value) (((value) << 18) & 0x00fc0000)
+ * Field : Refresh Cycle Time - trfc
+ * The refresh cycle timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_LSB        24
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_MSB        31
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_WIDTH      8
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TRFC register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_SET_MSK    0xff000000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TRFC register field value. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_CLR_MSK    0x00ffffff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TRFC field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_GET(value) (((value) & 0xff000000) >> 24)
+/* Produces a ALT_SDR_CTL_DRAMTIMING1_TRFC register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING1_TRFC_SET(value) (((value) << 24) & 0xff000000)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SDR_CTL_DRAMTIMING1.
+struct ALT_SDR_CTL_DRAMTIMING1_s
+    uint32_t  tcwl :  4;  /* CAS Write Latency */
+    uint32_t  tal  :  5;  /* Additive Latency */
+    uint32_t  tcl  :  5;  /* CAS Read Latency */
+    uint32_t  trrd :  4;  /* Activate to Activate Delay */
+    uint32_t  tfaw :  6;  /* Four Activate Window Time */
+    uint32_t  trfc :  8;  /* Refresh Cycle Time */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING1. */
+typedef volatile struct ALT_SDR_CTL_DRAMTIMING1_s  ALT_SDR_CTL_DRAMTIMING1_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SDR_CTL_DRAMTIMING1 register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMTIMING1_OFST        0x4
+ * Register : DRAM Timings 2 Register - dramtiming2
+ * Register Layout
+ *  Bits    | Access | Reset   | Description
+ *  [12:0]  | RW     | Unknown | Refresh Interval
+ *  [16:13] | RW     | Unknown | Activate to Read or Write Delay
+ *  [20:17] | RW     | Unknown | Row Precharge Time
+ *  [24:21] | RW     | Unknown | Write Recovery Time
+ *  [28:25] | RW     | Unknown | Write to Read Time
+ *  [31:29] | ???    | 0x0     | *UNDEFINED*
+ * Field : Refresh Interval - trefi
+ * The refresh interval timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_MSB        12
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_WIDTH      13
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TREFI register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_SET_MSK    0x00001fff
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TREFI register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_CLR_MSK    0xffffe000
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TREFI field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_GET(value) (((value) & 0x00001fff) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMTIMING2_TREFI register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TREFI_SET(value) (((value) << 0) & 0x00001fff)
+ * Field : Activate to Read or Write Delay - trcd
+ * The activate to read/write timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_MSB        16
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TRCD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_SET_MSK    0x0001e000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TRCD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_CLR_MSK    0xfffe1fff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TRCD field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_GET(value) (((value) & 0x0001e000) >> 13)
+/* Produces a ALT_SDR_CTL_DRAMTIMING2_TRCD register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRCD_SET(value) (((value) << 13) & 0x0001e000)
+ * Field : Row Precharge Time - trp
+ * The precharge to activate timing parameter.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRP register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_LSB        17
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRP register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_MSB        20
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TRP register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TRP register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_SET_MSK    0x001e0000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TRP register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_CLR_MSK    0xffe1ffff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TRP register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TRP field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_GET(value) (((value) & 0x001e0000) >> 17)
+/* Produces a ALT_SDR_CTL_DRAMTIMING2_TRP register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TRP_SET(value) (((value) << 17) & 0x001e0000)
+ * Field : Write Recovery Time - twr
+ * The write recovery timing.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWR register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_LSB        21
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWR register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_MSB        24
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TWR register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TWR register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_SET_MSK    0x01e00000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TWR register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_CLR_MSK    0xfe1fffff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TWR register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TWR field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_GET(value) (((value) & 0x01e00000) >> 21)
+/* Produces a ALT_SDR_CTL_DRAMTIMING2_TWR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWR_SET(value) (((value) << 21) & 0x01e00000)
+ * Field : Write to Read Time - twtr
+ * The write to read timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_LSB        25
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_MSB        28
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TWTR register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_SET_MSK    0x1e000000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TWTR register field value. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_CLR_MSK    0xe1ffffff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TWTR field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_GET(value) (((value) & 0x1e000000) >> 25)
+/* Produces a ALT_SDR_CTL_DRAMTIMING2_TWTR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING2_TWTR_SET(value) (((value) << 25) & 0x1e000000)
+ * The struct declaration for register ALT_SDR_CTL_DRAMTIMING2.
+struct ALT_SDR_CTL_DRAMTIMING2_s
+    uint32_t  trefi : 13;  /* Refresh Interval */
+    uint32_t  trcd  :  4;  /* Activate to Read or Write Delay */
+    uint32_t  trp   :  4;  /* Row Precharge Time */
+    uint32_t  twr   :  4;  /* Write Recovery Time */
+    uint32_t  twtr  :  4;  /* Write to Read Time */
+    uint32_t        :  3;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING2. */
+typedef volatile struct ALT_SDR_CTL_DRAMTIMING2_s  ALT_SDR_CTL_DRAMTIMING2_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMTIMING2 register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMTIMING2_OFST        0x8
+ * Register : DRAM Timings 3 Register - dramtiming3
+ * Register Layout
+ *  [3:0]   | RW     | Unknown | Read to Precharge Time
+ *  [8:4]   | RW     | Unknown | Activate to Precharge Time
+ *  [14:9]  | RW     | Unknown | Row Cycle Time
+ *  [18:15] | RW     | Unknown | Mode Register Programming Delay
+ *  [22:19] | RW     | Unknown | CAS to CAS Delay
+ *  [31:23] | ???    | 0x0     | *UNDEFINED*
+ * Field : Read to Precharge Time - trtp
+ * The read to precharge timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_MSB        3
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TRTP register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TRTP register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TRTP field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMTIMING3_TRTP register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRTP_SET(value) (((value) << 0) & 0x0000000f)
+ * Field : Activate to Precharge Time - tras
+ * The activate to precharge timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_MSB        8
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_WIDTH      5
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TRAS register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_SET_MSK    0x000001f0
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TRAS register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_CLR_MSK    0xfffffe0f
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TRAS field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_GET(value) (((value) & 0x000001f0) >> 4)
+/* Produces a ALT_SDR_CTL_DRAMTIMING3_TRAS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRAS_SET(value) (((value) << 4) & 0x000001f0)
+ * Field : Row Cycle Time - trc
+ * The activate to activate timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRC register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRC register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_MSB        14
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TRC register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_WIDTH      6
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TRC register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_SET_MSK    0x00007e00
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TRC register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_CLR_MSK    0xffff81ff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TRC register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TRC field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_GET(value) (((value) & 0x00007e00) >> 9)
+/* Produces a ALT_SDR_CTL_DRAMTIMING3_TRC register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TRC_SET(value) (((value) << 9) & 0x00007e00)
+ * Field : Mode Register Programming Delay - tmrd
+ * Mode register timing parameter.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_MSB        18
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TMRD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_SET_MSK    0x00078000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TMRD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_CLR_MSK    0xfff87fff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TMRD field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_GET(value) (((value) & 0x00078000) >> 15)
+/* Produces a ALT_SDR_CTL_DRAMTIMING3_TMRD register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TMRD_SET(value) (((value) << 15) & 0x00078000)
+ * Field : CAS to CAS Delay - tccd
+ * The CAS to CAS delay time.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_LSB        19
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_MSB        22
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TCCD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_SET_MSK    0x00780000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TCCD register field value. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_CLR_MSK    0xff87ffff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TCCD field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_GET(value) (((value) & 0x00780000) >> 19)
+/* Produces a ALT_SDR_CTL_DRAMTIMING3_TCCD register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING3_TCCD_SET(value) (((value) << 19) & 0x00780000)
+ * The struct declaration for register ALT_SDR_CTL_DRAMTIMING3.
+struct ALT_SDR_CTL_DRAMTIMING3_s
+    uint32_t  trtp :  4;  /* Read to Precharge Time */
+    uint32_t  tras :  5;  /* Activate to Precharge Time */
+    uint32_t  trc  :  6;  /* Row Cycle Time */
+    uint32_t  tmrd :  4;  /* Mode Register Programming Delay */
+    uint32_t  tccd :  4;  /* CAS to CAS Delay */
+    uint32_t       :  9;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING3. */
+typedef volatile struct ALT_SDR_CTL_DRAMTIMING3_s  ALT_SDR_CTL_DRAMTIMING3_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMTIMING3 register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMTIMING3_OFST        0xc
+ * Register : DRAM Timings 4 Register - dramtiming4
+ * Register Layout
+ *  [9:0]   | RW     | Unknown | Self-refresh Exit
+ *  [19:10] | RW     | Unknown | Power Down Exit
+ *  [23:20] | RW     | Unknown | Minimum Low Power State Cycles
+ *  [31:24] | ???    | 0x0     | *UNDEFINED*
+ * Field : Self-refresh Exit - selfrfshexit
+ * The self refresh exit cycles, tXS.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_MSB        9
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_WIDTH      10
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field value. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_SET_MSK    0x000003ff
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field value. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_CLR_MSK    0xfffffc00
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_GET(value) (((value) & 0x000003ff) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_SET(value) (((value) << 0) & 0x000003ff)
+ * Field : Power Down Exit - pwrdownexit
+ * The power down exit cycles, tXPDLL.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_MSB        19
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_WIDTH      10
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field value. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_SET_MSK    0x000ffc00
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field value. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_CLR_MSK    0xfff003ff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_GET(value) (((value) & 0x000ffc00) >> 10)
+/* Produces a ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_SET(value) (((value) << 10) & 0x000ffc00)
+ * Field : Minimum Low Power State Cycles - minpwrsavecycles
+ * The minimum number of cycles to stay in a low power state. This applies to both
+ * power down and self-refresh and should be set to the greater of tPD and tCKESR.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_LSB        20
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_MSB        23
+/* The width in bits of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field value. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_SET_MSK    0x00f00000
+/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field value. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_CLR_MSK    0xff0fffff
+/* The reset value of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES field value from a register. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_GET(value) (((value) & 0x00f00000) >> 20)
+/* Produces a ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_SET(value) (((value) << 20) & 0x00f00000)
+ * The struct declaration for register ALT_SDR_CTL_DRAMTIMING4.
+struct ALT_SDR_CTL_DRAMTIMING4_s
+    uint32_t  selfrfshexit     : 10;  /* Self-refresh Exit */
+    uint32_t  pwrdownexit      : 10;  /* Power Down Exit */
+    uint32_t  minpwrsavecycles :  4;  /* Minimum Low Power State Cycles */
+    uint32_t                   :  8;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING4. */
+typedef volatile struct ALT_SDR_CTL_DRAMTIMING4_s  ALT_SDR_CTL_DRAMTIMING4_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMTIMING4 register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMTIMING4_OFST        0x10
+ * Register : Lower Power Timing Register - lowpwrtiming
+ * This register controls the behavior of the low power logic in the controller.
+ * Register Layout
+ *  [15:0]  | RW     | Unknown | Auto-power Down Cycles
+ *  [19:16] | RW     | Unknown | Clock Disable Delay Cycles
+ *  [31:20] | ???    | 0x0     | *UNDEFINED*
+ * Field : Auto-power Down Cycles - autopdcycles
+ * The number of idle clock cycles after which the controller should place the
+ * memory into power-down mode.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_MSB        15
+/* The width in bits of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_WIDTH      16
+/* The mask used to set the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field value. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_SET_MSK    0x0000ffff
+/* The mask used to clear the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field value. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_CLR_MSK    0xffff0000
+/* The reset value of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES field value from a register. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_GET(value) (((value) & 0x0000ffff) >> 0)
+/* Produces a ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_SET(value) (((value) << 0) & 0x0000ffff)
+ * Field : Clock Disable Delay Cycles - clkdisablecycles
+ * Set to a the number of clocks after the execution of an self-refresh to stop the
+ * clock.  This register is generally set based on PHY design latency and should
+ * generally not be changed.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_MSB        19
+/* The width in bits of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field value. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_SET_MSK    0x000f0000
+/* The mask used to clear the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field value. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_CLR_MSK    0xfff0ffff
+/* The reset value of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES field value from a register. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_GET(value) (((value) & 0x000f0000) >> 16)
+/* Produces a ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_SET(value) (((value) << 16) & 0x000f0000)
+ * The struct declaration for register ALT_SDR_CTL_LOWPWRTIMING.
+struct ALT_SDR_CTL_LOWPWRTIMING_s
+    uint32_t  autopdcycles     : 16;  /* Auto-power Down Cycles */
+    uint32_t  clkdisablecycles :  4;  /* Clock Disable Delay Cycles */
+    uint32_t                   : 12;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_LOWPWRTIMING. */
+typedef volatile struct ALT_SDR_CTL_LOWPWRTIMING_s  ALT_SDR_CTL_LOWPWRTIMING_t;
+/* The byte offset of the ALT_SDR_CTL_LOWPWRTIMING register from the beginning of the component. */
+#define ALT_SDR_CTL_LOWPWRTIMING_OFST        0x14
+ * Register : ODT Control Register - dramodt
+ * This register controls which ODT pin is asserted during reads or writes. Bits
+ * [1:0] control which ODT pin is asserted during to accesses to chip select 0,
+ * bits [3:2] which ODT pin is asserted during accesses to chip select 1. For
+ * example, a value of "1001" will cause ODT[0] to be asserted for
+ * accesses to CS[0], and ODT[1] to be asserted for access to CS[1] pin. Set this
+ * to "0001" if there is only one chip select available.
+ * Register Layout
+ *  [3:0]  | RW     | Unknown | Write ODT Control
+ *  [7:4]  | RW     | Unknown | Read ODT Control
+ *  [31:8] | ???    | 0x0     | *UNDEFINED*
+ * Field : Write ODT Control - cfg_write_odt_chip
+ * This register controls which ODT pin is asserted during writes.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_MSB        3
+/* The width in bits of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field value. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field value. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP field value from a register. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_SET(value) (((value) << 0) & 0x0000000f)
+ * Field : Read ODT Control - cfg_read_odt_chip
+ * This register controls which ODT pin is asserted during reads.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_MSB        7
+/* The width in bits of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field value. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_SET_MSK    0x000000f0
+/* The mask used to clear the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field value. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_CLR_MSK    0xffffff0f
+/* The reset value of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP field value from a register. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_GET(value) (((value) & 0x000000f0) >> 4)
+/* Produces a ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_SET(value) (((value) << 4) & 0x000000f0)
+ * The struct declaration for register ALT_SDR_CTL_DRAMODT.
+struct ALT_SDR_CTL_DRAMODT_s
+    uint32_t  cfg_write_odt_chip :  4;  /* Write ODT Control */
+    uint32_t  cfg_read_odt_chip  :  4;  /* Read ODT Control */
+    uint32_t                     : 24;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMODT. */
+typedef volatile struct ALT_SDR_CTL_DRAMODT_s  ALT_SDR_CTL_DRAMODT_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMODT register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMODT_OFST        0x18
+ * Register : DRAM Address Widths Register - dramaddrw
+ * This register configures the width of the various address fields of the DRAM.
+ * The values specified in this register must match the memory devices being used.
+ * Register Layout
+ *  [4:0]   | RW     | Unknown | DRAM Column Address Bits
+ *  [9:5]   | RW     | Unknown | DRAM Row Address Bits
+ *  [12:10] | RW     | Unknown | DRAM Bank Address Bits
+ *  [15:13] | RW     | Unknown | DRAM Chip Address Bits
+ *  [31:16] | ???    | 0x0     | *UNDEFINED*
+ * Field : DRAM Column Address Bits - colbits
+ * The number of column address bits for the memory devices in your memory
+ * interface.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_MSB        4
+/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_WIDTH      5
+/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_COLBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_SET_MSK    0x0000001f
+/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_COLBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_CLR_MSK    0xffffffe0
+/* The reset value of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMADDRW_COLBITS field value from a register. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_GET(value) (((value) & 0x0000001f) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMADDRW_COLBITS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMADDRW_COLBITS_SET(value) (((value) << 0) & 0x0000001f)
+ * Field : DRAM Row Address Bits - rowbits
+ * The number of row address bits for the memory devices in your memory interface.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_MSB        9
+/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_WIDTH      5
+/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_SET_MSK    0x000003e0
+/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_CLR_MSK    0xfffffc1f
+/* The reset value of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMADDRW_ROWBITS field value from a register. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_GET(value) (((value) & 0x000003e0) >> 5)
+/* Produces a ALT_SDR_CTL_DRAMADDRW_ROWBITS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_SET(value) (((value) << 5) & 0x000003e0)
+ * Field : DRAM Bank Address Bits - bankbits
+ * The number of bank address bits for the memory devices in your memory interface.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_MSB        12
+/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_WIDTH      3
+/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_SET_MSK    0x00001c00
+/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_CLR_MSK    0xffffe3ff
+/* The reset value of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMADDRW_BANKBITS field value from a register. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_GET(value) (((value) & 0x00001c00) >> 10)
+/* Produces a ALT_SDR_CTL_DRAMADDRW_BANKBITS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_SET(value) (((value) << 10) & 0x00001c00)
+ * Field : DRAM Chip Address Bits - csbits
+ * The number of chip select address bits for the memory devices in your memory
+ * interface.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_MSB        15
+/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_WIDTH      3
+/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_CSBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_SET_MSK    0x0000e000
+/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_CSBITS register field value. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_CLR_MSK    0xffff1fff
+/* The reset value of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMADDRW_CSBITS field value from a register. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_GET(value) (((value) & 0x0000e000) >> 13)
+/* Produces a ALT_SDR_CTL_DRAMADDRW_CSBITS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMADDRW_CSBITS_SET(value) (((value) << 13) & 0x0000e000)
+ * The struct declaration for register ALT_SDR_CTL_DRAMADDRW.
+struct ALT_SDR_CTL_DRAMADDRW_s
+    uint32_t  colbits  :  5;  /* DRAM Column Address Bits */
+    uint32_t  rowbits  :  5;  /* DRAM Row Address Bits */
+    uint32_t  bankbits :  3;  /* DRAM Bank Address Bits */
+    uint32_t  csbits   :  3;  /* DRAM Chip Address Bits */
+    uint32_t           : 16;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMADDRW. */
+typedef volatile struct ALT_SDR_CTL_DRAMADDRW_s  ALT_SDR_CTL_DRAMADDRW_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMADDRW register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMADDRW_OFST        0x2c
+ * Register : DRAM Interface Data Width Register - dramifwidth
+ * Register Layout
+ *  [7:0]  | RW     | Unknown | DRAM Interface Data Width
+ * Field : DRAM Interface Data Width - ifwidth
+ * This register controls the interface width of the SDRAM interface, including any
+ * bits used for ECC. For example, for a 32-bit interface with ECC, program this
+ * register with 0x28. You must also program the ctrlwidth register.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_MSB        7
+/* The width in bits of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_WIDTH      8
+/* The mask used to set the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field value. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field value. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_CLR_MSK    0xffffff00
+/* The reset value of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH field value from a register. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_SDR_CTL_DRAMIFWIDTH.
+struct ALT_SDR_CTL_DRAMIFWIDTH_s
+    uint32_t  ifwidth :  8;  /* DRAM Interface Data Width */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMIFWIDTH. */
+typedef volatile struct ALT_SDR_CTL_DRAMIFWIDTH_s  ALT_SDR_CTL_DRAMIFWIDTH_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMIFWIDTH register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMIFWIDTH_OFST        0x30
+ * Register : DRAM Devices Data Width Register - dramdevwidth
+ * Register Layout
+ *  [3:0]  | RW     | Unknown | DRAM Devices Data Width
+ *  [31:4] | ???    | 0x0     | *UNDEFINED*
+ * Field : DRAM Devices Data Width - devwidth
+ * This register specifies the width of the physical DRAM chips, for example 8 or
+ * 16.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_MSB        3
+/* The width in bits of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_WIDTH      4
+/* The mask used to set the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field value. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field value. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH field value from a register. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_SET(value) (((value) << 0) & 0x0000000f)
+ * The struct declaration for register ALT_SDR_CTL_DRAMDEVWIDTH.
+struct ALT_SDR_CTL_DRAMDEVWIDTH_s
+    uint32_t  devwidth :  4;  /* DRAM Devices Data Width */
+    uint32_t           : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMDEVWIDTH. */
+typedef volatile struct ALT_SDR_CTL_DRAMDEVWIDTH_s  ALT_SDR_CTL_DRAMDEVWIDTH_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMDEVWIDTH register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMDEVWIDTH_OFST        0x34
+ * Register : DRAM Status Register - dramsts
+ * This register provides the status of the calibration and ECC logic.
+ * Register Layout
+ *  [0]    | RW     | Unknown | PHY Calibration Successful
+ *  [1]    | RW     | Unknown | PHY Calibration Failed
+ *  [2]    | RW     | Unknown | Single Bit Error Seen
+ *  [3]    | RW     | Unknown | Double Bit Error Seen
+ *  [4]    | RW     | Unknown | ECC Auto-Correction Dropped
+ *  [31:5] | ???    | 0x0     | *UNDEFINED*
+ * Field : PHY Calibration Successful - calsuccess
+ * This bit will be set to 1 if the PHY was able to successfully calibrate.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_MSB        0
+/* The width in bits of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field value. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field value. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMSTS_CALSUCCESS field value from a register. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_SET(value) (((value) << 0) & 0x00000001)
+ * Field : PHY Calibration Failed - calfail
+ * This bit  will be set to 1 if the PHY was unable to calibrate.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_MSB        1
+/* The width in bits of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMSTS_CALFAIL register field value. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_CALFAIL register field value. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMSTS_CALFAIL field value from a register. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SDR_CTL_DRAMSTS_CALFAIL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMSTS_CALFAIL_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Single Bit Error Seen - sbeerr
+ * This bit will be set to 1 if there have been any ECC single bit errors detected.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_SBEERR register field. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_SBEERR register field. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_MSB        2
+/* The width in bits of the ALT_SDR_CTL_DRAMSTS_SBEERR register field. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMSTS_SBEERR register field value. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_SBEERR register field value. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SDR_CTL_DRAMSTS_SBEERR register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMSTS_SBEERR field value from a register. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SDR_CTL_DRAMSTS_SBEERR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMSTS_SBEERR_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Double Bit Error Seen - dbeerr
+ * This bit will be set to 1 if there have been any ECC double bit errors detected.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_DBEERR register field. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_DBEERR register field. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_MSB        3
+/* The width in bits of the ALT_SDR_CTL_DRAMSTS_DBEERR register field. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMSTS_DBEERR register field value. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_DBEERR register field value. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SDR_CTL_DRAMSTS_DBEERR register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMSTS_DBEERR field value from a register. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SDR_CTL_DRAMSTS_DBEERR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMSTS_DBEERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : ECC Auto-Correction Dropped - corrdrop
+ * This bit will be set to 1 if there any auto-corrections have been dropped.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_MSB        4
+/* The width in bits of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMSTS_CORRDROP register field value. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_CORRDROP register field value. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMSTS_CORRDROP field value from a register. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SDR_CTL_DRAMSTS_CORRDROP register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMSTS_CORRDROP_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SDR_CTL_DRAMSTS.
+struct ALT_SDR_CTL_DRAMSTS_s
+    uint32_t  calsuccess :  1;  /* PHY Calibration Successful */
+    uint32_t  calfail    :  1;  /* PHY Calibration Failed */
+    uint32_t  sbeerr     :  1;  /* Single Bit Error Seen */
+    uint32_t  dbeerr     :  1;  /* Double Bit Error Seen */
+    uint32_t  corrdrop   :  1;  /* ECC Auto-Correction Dropped */
+    uint32_t             : 27;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMSTS. */
+typedef volatile struct ALT_SDR_CTL_DRAMSTS_s  ALT_SDR_CTL_DRAMSTS_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMSTS register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMSTS_OFST        0x38
+ * Register : ECC Interrupt  Register - dramintr
+ * Register Layout
+ *  [0]    | RW     | Unknown | Interrupt Enable
+ *  [1]    | RW     | Unknown | Mask Single Bit Error Interrupt
+ *  [2]    | RW     | Unknown | Mask Double Bit Error Interrupt
+ *  [3]    | RW     | Unknown | Mask Dropped Auto-correction Interrupt
+ *  [4]    | RW     | Unknown | Clear Interrupt Signal
+ * Field : Interrupt Enable - intren
+ * Enable the interrupt output.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_INTREN register field. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_INTREN register field. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_MSB        0
+/* The width in bits of the ALT_SDR_CTL_DRAMINTR_INTREN register field. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMINTR_INTREN register field value. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_INTREN register field value. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SDR_CTL_DRAMINTR_INTREN register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMINTR_INTREN field value from a register. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SDR_CTL_DRAMINTR_INTREN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMINTR_INTREN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Mask Single Bit Error Interrupt - sbemask
+ * Mask the single bit error interrupt.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_MSB        1
+/* The width in bits of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMINTR_SBEMSK register field value. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_SBEMSK register field value. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMINTR_SBEMSK field value from a register. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SDR_CTL_DRAMINTR_SBEMSK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMINTR_SBEMSK_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Mask Double Bit Error Interrupt - dbemask
+ * Mask the double bit error interrupt.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_MSB        2
+/* The width in bits of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMINTR_DBEMSK register field value. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_DBEMSK register field value. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMINTR_DBEMSK field value from a register. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SDR_CTL_DRAMINTR_DBEMSK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMINTR_DBEMSK_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Mask Dropped Auto-correction Interrupt - corrdropmask
+ * Set this bit to a one to mask interrupts for an ECC correction write back
+ * needing to be dropped.  This indicates a burst of memory errors in a short
+ * period of time.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_MSB        3
+/* The width in bits of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field value. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field value. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK field value from a register. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Clear Interrupt Signal - intrclr
+ * Writing to this self-clearing bit clears the interrupt signal. Writing to this
+ * bit also clears the error count and error address registers.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_MSB        4
+/* The width in bits of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_DRAMINTR_INTRCLR register field value. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_INTRCLR register field value. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field is UNKNOWN. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DRAMINTR_INTRCLR field value from a register. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SDR_CTL_DRAMINTR_INTRCLR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DRAMINTR_INTRCLR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SDR_CTL_DRAMINTR.
+struct ALT_SDR_CTL_DRAMINTR_s
+    uint32_t  intren       :  1;  /* Interrupt Enable */
+    uint32_t  sbemask      :  1;  /* Mask Single Bit Error Interrupt */
+    uint32_t  dbemask      :  1;  /* Mask Double Bit Error Interrupt */
+    uint32_t  corrdropmask :  1;  /* Mask Dropped Auto-correction Interrupt */
+    uint32_t  intrclr      :  1;  /* Clear Interrupt Signal */
+/* The typedef declaration for register ALT_SDR_CTL_DRAMINTR. */
+typedef volatile struct ALT_SDR_CTL_DRAMINTR_s  ALT_SDR_CTL_DRAMINTR_t;
+/* The byte offset of the ALT_SDR_CTL_DRAMINTR register from the beginning of the component. */
+#define ALT_SDR_CTL_DRAMINTR_OFST        0x3c
+ * Register : ECC Single Bit Error Count Register - sbecount
+ * Register Layout
+ *  [7:0]  | RW     | Unknown | Single Bit Error Count
+ * Field : Single Bit Error Count - count
+ * Reports the number of single bit errors that have occurred since the status
+ * register counters were last cleared.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_SBECOUNT_COUNT register field. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_SBECOUNT_COUNT register field. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_MSB        7
+/* The width in bits of the ALT_SDR_CTL_SBECOUNT_COUNT register field. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_WIDTH      8
+/* The mask used to set the ALT_SDR_CTL_SBECOUNT_COUNT register field value. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_SDR_CTL_SBECOUNT_COUNT register field value. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_CLR_MSK    0xffffff00
+/* The reset value of the ALT_SDR_CTL_SBECOUNT_COUNT register field is UNKNOWN. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_SBECOUNT_COUNT field value from a register. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_SDR_CTL_SBECOUNT_COUNT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_SBECOUNT_COUNT_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_SDR_CTL_SBECOUNT.
+struct ALT_SDR_CTL_SBECOUNT_s
+    uint32_t  count :  8;  /* Single Bit Error Count */
+/* The typedef declaration for register ALT_SDR_CTL_SBECOUNT. */
+typedef volatile struct ALT_SDR_CTL_SBECOUNT_s  ALT_SDR_CTL_SBECOUNT_t;
+/* The byte offset of the ALT_SDR_CTL_SBECOUNT register from the beginning of the component. */
+#define ALT_SDR_CTL_SBECOUNT_OFST        0x40
+ * Register : ECC Double Bit Error Count Register - dbecount
+ * Register Layout
+ *  [7:0]  | RW     | Unknown | Double Bit Error Count
+ * Field : Double Bit Error Count - count
+ * Reports the number of double bit errors that have occurred since the status
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DBECOUNT_COUNT register field. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DBECOUNT_COUNT register field. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_MSB        7
+/* The width in bits of the ALT_SDR_CTL_DBECOUNT_COUNT register field. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_WIDTH      8
+/* The mask used to set the ALT_SDR_CTL_DBECOUNT_COUNT register field value. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_SDR_CTL_DBECOUNT_COUNT register field value. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_CLR_MSK    0xffffff00
+/* The reset value of the ALT_SDR_CTL_DBECOUNT_COUNT register field is UNKNOWN. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DBECOUNT_COUNT field value from a register. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_SDR_CTL_DBECOUNT_COUNT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DBECOUNT_COUNT_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_SDR_CTL_DBECOUNT.
+struct ALT_SDR_CTL_DBECOUNT_s
+    uint32_t  count :  8;  /* Double Bit Error Count */
+/* The typedef declaration for register ALT_SDR_CTL_DBECOUNT. */
+typedef volatile struct ALT_SDR_CTL_DBECOUNT_s  ALT_SDR_CTL_DBECOUNT_t;
+/* The byte offset of the ALT_SDR_CTL_DBECOUNT register from the beginning of the component. */
+#define ALT_SDR_CTL_DBECOUNT_OFST        0x44
+ * Register : ECC Error Address Register - erraddr
+ * Register Layout
+ *  [31:0] | RW     | Unknown | ECC Error Address
+ * Field : ECC Error Address - addr
+ * The address of the most recent ECC error.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_ERRADDR_ADDR register field. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_ERRADDR_ADDR register field. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_MSB        31
+/* The width in bits of the ALT_SDR_CTL_ERRADDR_ADDR register field. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_WIDTH      32
+/* The mask used to set the ALT_SDR_CTL_ERRADDR_ADDR register field value. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SDR_CTL_ERRADDR_ADDR register field value. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_CLR_MSK    0x00000000
+/* The reset value of the ALT_SDR_CTL_ERRADDR_ADDR register field is UNKNOWN. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_ERRADDR_ADDR field value from a register. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SDR_CTL_ERRADDR_ADDR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_ERRADDR_ADDR_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SDR_CTL_ERRADDR.
+struct ALT_SDR_CTL_ERRADDR_s
+    uint32_t  addr : 32;  /* ECC Error Address */
+/* The typedef declaration for register ALT_SDR_CTL_ERRADDR. */
+typedef volatile struct ALT_SDR_CTL_ERRADDR_s  ALT_SDR_CTL_ERRADDR_t;
+/* The byte offset of the ALT_SDR_CTL_ERRADDR register from the beginning of the component. */
+#define ALT_SDR_CTL_ERRADDR_OFST        0x48
+ * Register : ECC Auto-correction Dropped Count Register - dropcount
+ * Register Layout
+ *  [7:0]  | RW     | Unknown | Dropped Auto-correction Count
+ * Field : Dropped Auto-correction Count - corrdropcount
+ * This gives the count of the number of ECC write back transactions dropped due to
+ * the internal FIFO overflowing.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_MSB        7
+/* The width in bits of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_WIDTH      8
+/* The mask used to set the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field value. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field value. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_CLR_MSK    0xffffff00
+/* The reset value of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field is UNKNOWN. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT field value from a register. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_SET(value) (((value) << 0) & 0x000000ff)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SDR_CTL_DROPCOUNT.
+struct ALT_SDR_CTL_DROPCOUNT_s
+    uint32_t  corrdropcount :  8;  /* Dropped Auto-correction Count */
+/* The typedef declaration for register ALT_SDR_CTL_DROPCOUNT. */
+typedef volatile struct ALT_SDR_CTL_DROPCOUNT_s  ALT_SDR_CTL_DROPCOUNT_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SDR_CTL_DROPCOUNT register from the beginning of the component. */
+#define ALT_SDR_CTL_DROPCOUNT_OFST        0x4c
+ * Register : ECC Auto-correction Dropped Address Register - dropaddr
+ * Register Layout
+ *  Bits   | Access | Reset   | Description
+ *  [31:0] | RW     | Unknown | Dropped Auto-correction Address
+ * Field : Dropped Auto-correction Address - corrdropaddr
+ * This register gives the last address which was dropped.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_MSB        31
+/* The width in bits of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_WIDTH      32
+/* The mask used to set the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field value. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field value. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_CLR_MSK    0x00000000
+/* The reset value of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field is UNKNOWN. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_DROPADDR_CORRDROPADDR field value from a register. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SDR_CTL_DROPADDR.
+struct ALT_SDR_CTL_DROPADDR_s
+    uint32_t  corrdropaddr : 32;  /* Dropped Auto-correction Address */
+/* The typedef declaration for register ALT_SDR_CTL_DROPADDR. */
+typedef volatile struct ALT_SDR_CTL_DROPADDR_s  ALT_SDR_CTL_DROPADDR_t;
+/* The byte offset of the ALT_SDR_CTL_DROPADDR register from the beginning of the component. */
+#define ALT_SDR_CTL_DROPADDR_OFST        0x50
+ * Register : Low Power Control Register - lowpwreq
+ * This register instructs the controller to put the DRAM into a power down state.
+ * Note that some commands are only valid for certain memory types.
+ * Register Layout
+ *  [0]    | RW     | Unknown | Deep Power Down Request
+ *  [2:1]  | RW     | Unknown | Deep Power Down Chip Select Mask
+ *  [3]    | RW     | Unknown | Self-refresh Request
+ *  [5:4]  | RW     | Unknown | Self-refresh Chip Select Mask
+ *  [31:6] | ???    | 0x0     | *UNDEFINED*
+ * Field : Deep Power Down Request - deeppwrdnreq
+ * Write a one to this bit to request a deep power down.  This bit should only be
+ * written with LPDDR2 DRAMs, DDR3 DRAMs do not support deep power down.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_MSB        0
+/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ field value from a register. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Deep Power Down Chip Select Mask - deeppwrdnmask
+ * Write ones to this register to select which DRAM chip selects will be powered
+ * down.  Typical usage is to set both of these bits when deeppwrdnreq is set but
+ * the controller does support putting a single chip into deep power down and
+ * keeping the other chip running.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_MSB        2
+/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_WIDTH      2
+/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_SET_MSK    0x00000006
+/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_CLR_MSK    0xfffffff9
+/* The reset value of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK field value from a register. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_GET(value) (((value) & 0x00000006) >> 1)
+/* Produces a ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_SET(value) (((value) << 1) & 0x00000006)
+ * Field : Self-refresh Request - selfrshreq
+ * Write a one to this bit to request the RAM be put into a self refresh state.
+ * This bit is treated as a static value so the RAM will remain in self-refresh as
+ * long as this register bit is set to a one.  This power down mode can be selected
+ * for all DRAMs supported by the controller.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_MSB        3
+/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ field value from a register. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Self-refresh Chip Select Mask - selfrfshmask
+ * Write a one to each bit of this field to have a self refresh request apply to
+ * both chips.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_MSB        5
+/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_WIDTH      2
+/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_SET_MSK    0x00000030
+/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field value. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_CLR_MSK    0xffffffcf
+/* The reset value of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK field value from a register. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_GET(value) (((value) & 0x00000030) >> 4)
+/* Produces a ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_SET(value) (((value) << 4) & 0x00000030)
+ * The struct declaration for register ALT_SDR_CTL_LOWPWREQ.
+struct ALT_SDR_CTL_LOWPWREQ_s
+    uint32_t  deeppwrdnreq  :  1;  /* Deep Power Down Request */
+    uint32_t  deeppwrdnmask :  2;  /* Deep Power Down Chip Select Mask */
+    uint32_t  selfrshreq    :  1;  /* Self-refresh Request */
+    uint32_t  selfrfshmask  :  2;  /* Self-refresh Chip Select Mask */
+    uint32_t                : 26;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_LOWPWREQ. */
+typedef volatile struct ALT_SDR_CTL_LOWPWREQ_s  ALT_SDR_CTL_LOWPWREQ_t;
+/* The byte offset of the ALT_SDR_CTL_LOWPWREQ register from the beginning of the component. */
+#define ALT_SDR_CTL_LOWPWREQ_OFST        0x54
+ * Register : Low Power Acknowledge Register - lowpwrack
+ * This register gives the status of the power down commands requested by the Low
+ * Power Control register.
+ * Register Layout
+ *  [0]    | RW     | Unknown | Deep Power Down Acknowledge
+ *  [1]    | RW     | Unknown | Self-refresh Acknowledge
+ *  [31:2] | ???    | 0x0     | *UNDEFINED*
+ * Field : Deep Power Down Acknowledge - deeppwrdnack
+ * This bit is set to a one after a deep power down has been executed
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_MSB        0
+/* The width in bits of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field value. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field value. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK field value from a register. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Self-refresh Acknowledge - selfrfshack
+ * This bit is a one to indicate that the controller is in a self-refresh state.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_MSB        1
+/* The width in bits of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field value. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field value. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field is UNKNOWN. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK field value from a register. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_SDR_CTL_LOWPWRACK.
+struct ALT_SDR_CTL_LOWPWRACK_s
+    uint32_t  deeppwrdnack :  1;  /* Deep Power Down Acknowledge */
+    uint32_t  selfrfshack  :  1;  /* Self-refresh Acknowledge */
+    uint32_t               : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_LOWPWRACK. */
+typedef volatile struct ALT_SDR_CTL_LOWPWRACK_s  ALT_SDR_CTL_LOWPWRACK_t;
+/* The byte offset of the ALT_SDR_CTL_LOWPWRACK register from the beginning of the component. */
+#define ALT_SDR_CTL_LOWPWRACK_OFST        0x58
+ * Register : Static Configuration Register - staticcfg
+ * This register controls configuration values which cannot be updated while
+ * transactions are flowing.
+ * You should write once to this register with the membl and eccen fields set to
+ * your desired configuration, and then write to the register again with membl and
+ * eccen and the applycfg bit set. The applycfg bit is write only.
+ * Register Layout
+ *  [1:0]  | RW     | Unknown | Memory Burst Length
+ *  [2]    | RW     | Unknown | Use ECC Bits As Data
+ *  [3]    | RW     | Unknown | Apply Configuration Changes
+ * Field : Memory Burst Length - membl
+ * This field specifies the DRAM burst length. Write the following values to set
+ * the a burst length appropriate for the specific DRAM being used. "00"
+ * for burst length 2, "01" for burst length 4, "10" for burst
+ * length 8. If you set this, you must also set the membl field in the ctrlcfg
+ * register.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_STATICCFG_MEMBL register field. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_STATICCFG_MEMBL register field. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_MSB        1
+/* The width in bits of the ALT_SDR_CTL_STATICCFG_MEMBL register field. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_WIDTH      2
+/* The mask used to set the ALT_SDR_CTL_STATICCFG_MEMBL register field value. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SDR_CTL_STATICCFG_MEMBL register field value. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SDR_CTL_STATICCFG_MEMBL register field is UNKNOWN. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_STATICCFG_MEMBL field value from a register. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SDR_CTL_STATICCFG_MEMBL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_STATICCFG_MEMBL_SET(value) (((value) << 0) & 0x00000003)
+ * Field : Use ECC Bits As Data - useeccasdata
+ * This field allows the FPGA ports to directly access the extra data bits that are
+ * normally used to hold the ECC code. The interface width must be set to 24 or 40
+ * in the dramifwidth register. If you set this, you must clear the eccen field in
+ * the ctrlcfg register.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_MSB        2
+/* The width in bits of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field value. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field value. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field is UNKNOWN. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_RESET      0x0
+/* Extracts the ALT_SDR_CTL_STATICCFG_USEECCASDATA field value from a register. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SDR_CTL_STATICCFG_USEECCASDATA register field value suitable for setting the register. */
+#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Apply Configuration Changes - applycfg
+ * Write with this bit set to apply all the settings loaded in SDR registers to the
+ * memory interface. This bit is write-only and always returns 0 if read.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_MSB        3
+/* The width in bits of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_STATICCFG_APPLYCFG register field value. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SDR_CTL_STATICCFG_APPLYCFG register field value. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field is UNKNOWN. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_RESET      0x0
+/* Extracts the ALT_SDR_CTL_STATICCFG_APPLYCFG field value from a register. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SDR_CTL_STATICCFG_APPLYCFG register field value suitable for setting the register. */
+#define ALT_SDR_CTL_STATICCFG_APPLYCFG_SET(value) (((value) << 3) & 0x00000008)
+ * The struct declaration for register ALT_SDR_CTL_STATICCFG.
+struct ALT_SDR_CTL_STATICCFG_s
+    uint32_t  membl        :  2;  /* Memory Burst Length */
+    uint32_t  useeccasdata :  1;  /* Use ECC Bits As Data */
+    uint32_t  applycfg     :  1;  /* Apply Configuration Changes */
+/* The typedef declaration for register ALT_SDR_CTL_STATICCFG. */
+typedef volatile struct ALT_SDR_CTL_STATICCFG_s  ALT_SDR_CTL_STATICCFG_t;
+/* The byte offset of the ALT_SDR_CTL_STATICCFG register from the beginning of the component. */
+#define ALT_SDR_CTL_STATICCFG_OFST        0x5c
+ * Register : Memory Controller Width Register - ctrlwidth
+ * This register controls the width of the physical DRAM interface.
+ * Register Layout
+ *  [1:0]  | RW     | Unknown | Controller Interface Width
+ * Field : Controller Interface Width - ctrlwidth
+ * Specifies controller DRAM interface width, with the following encoding.
+ * "00" for 8-bit, "01" for 16-bit (no ECC) or 24-bit (ECC
+ * enabled), "10" for 32-bit (no ECC) or 40-bit (ECC enabled). You must
+ * also program the dramifwidth register.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_MSB        1
+/* The width in bits of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_WIDTH      2
+/* The mask used to set the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field value. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field value. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field is UNKNOWN. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_RESET      0x0
+/* Extracts the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH field value from a register. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field value suitable for setting the register. */
+#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SDR_CTL_CTLWIDTH.
+struct ALT_SDR_CTL_CTLWIDTH_s
+    uint32_t  ctrlwidth :  2;  /* Controller Interface Width */
+/* The typedef declaration for register ALT_SDR_CTL_CTLWIDTH. */
+typedef volatile struct ALT_SDR_CTL_CTLWIDTH_s  ALT_SDR_CTL_CTLWIDTH_t;
+/* The byte offset of the ALT_SDR_CTL_CTLWIDTH register from the beginning of the component. */
+#define ALT_SDR_CTL_CTLWIDTH_OFST        0x60
+ * Register : Port Configuration Register - portcfg
+ * This register should be set to a zero in any bit which corresponds to a port
+ * which does mostly sequential memory accesses.  For ports with highly random
+ * accesses, the bit should be set to a one.
+ * Register Layout
+ *  [9:0]   | ???    | Unknown | *UNDEFINED*
+ *  [19:10] | RW     | Unknown | Auto-precharge Enable
+ *  [31:20] | ???    | 0x0     | *UNDEFINED*
+ * Field : Auto-precharge Enable - autopchen
+ * One bit per control port.  Set bit N to a 1 to have the controller request an
+ * automatic precharge following bus command completion (close the row
+ * automatically).  Set to a zero to request that the controller attempt to keep a
+ * row open.  For random dominated operations this register should be set to a 1
+ * for all active ports.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_MSB        19
+/* The width in bits of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_WIDTH      10
+/* The mask used to set the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field value. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_SET_MSK    0x000ffc00
+/* The mask used to clear the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field value. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_CLR_MSK    0xfff003ff
+/* The reset value of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field is UNKNOWN. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PORTCFG_AUTOPCHEN field value from a register. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_GET(value) (((value) & 0x000ffc00) >> 10)
+/* Produces a ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_SET(value) (((value) << 10) & 0x000ffc00)
+ * The struct declaration for register ALT_SDR_CTL_PORTCFG.
+struct ALT_SDR_CTL_PORTCFG_s
+    uint32_t            : 10;  /* *UNDEFINED* */
+    uint32_t  autopchen : 10;  /* Auto-precharge Enable */
+    uint32_t            : 12;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_PORTCFG. */
+typedef volatile struct ALT_SDR_CTL_PORTCFG_s  ALT_SDR_CTL_PORTCFG_t;
+/* The byte offset of the ALT_SDR_CTL_PORTCFG register from the beginning of the component. */
+#define ALT_SDR_CTL_PORTCFG_OFST        0x7c
+ * Register : FPGA Ports Reset Control Register - fpgaportrst
+ * This register implements functionality to allow the CPU to control when the MPFE
+ * will enable the ports to the FPGA fabric.
+ * Register Layout
+ *  [13:0]  | RW     | Unknown | Port Reset Control
+ *  [31:14] | ???    | 0x0     | *UNDEFINED*
+ * Field : Port Reset Control - portrstn
+ * This register should be written to with a 1 to enable the selected FPGA port to
+ * exit reset.  Writing a bit to a zero will stretch the port reset until the
+ * register is written. Read data ports are connected to bits 3:0, with read data
+ * port 0 at bit 0 to read data port 3 at bit 3. Write data ports 0 to 3 are mapped
+ * to 4 to 7, with write data port 0 connected to bit 4 to write data port 3 at bit
+ * 7. Command ports are connected to bits 8 to 13, with command port 0 at bit 8 to
+ * command port 5 at bit 13. Expected usage would be to set all the bits at the
+ * same time but setting some bits to a zero and others to a one is supported.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_MSB        13
+/* The width in bits of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_WIDTH      14
+/* The mask used to set the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field value. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_SET_MSK    0x00003fff
+/* The mask used to clear the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field value. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_CLR_MSK    0xffffc000
+/* The reset value of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field is UNKNOWN. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN field value from a register. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_GET(value) (((value) & 0x00003fff) >> 0)
+/* Produces a ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_SET(value) (((value) << 0) & 0x00003fff)
+ * The struct declaration for register ALT_SDR_CTL_FPGAPORTRST.
+struct ALT_SDR_CTL_FPGAPORTRST_s
+    uint32_t  portrstn : 14;  /* Port Reset Control */
+    uint32_t           : 18;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_FPGAPORTRST. */
+typedef volatile struct ALT_SDR_CTL_FPGAPORTRST_s  ALT_SDR_CTL_FPGAPORTRST_t;
+/* The byte offset of the ALT_SDR_CTL_FPGAPORTRST register from the beginning of the component. */
+#define ALT_SDR_CTL_FPGAPORTRST_OFST        0x80
+ * Register : Memory Protection Port Default Register - protportdefault
+ * This register controls the default protection assignment for a port.  Ports
+ * which have explicit rules which define regions which are illegal to access
+ * should set the bits to pass by default.  Ports which have explicit rules which
+ * define legal areas should set the bit to force all transactions to fail.
+ * Leaving this register to all zeros should be used for systems which do not
+ * desire any protection from the memory controller.
+ * Register Layout
+ *  [9:0]   | RW     | Unknown | Port Default Action
+ *  [31:10] | ???    | 0x0     | *UNDEFINED*
+ * Field : Port Default Action - portdefault
+ * Determines the default action for a transactions from a port.  Set a bit to a
+ * zero to indicate that all accesses from the port should pass by default, set a
+ * bit to a one if the default protection is to fail the access.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_MSB        9
+/* The width in bits of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_WIDTH      10
+/* The mask used to set the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field value. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_SET_MSK    0x000003ff
+/* The mask used to clear the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field value. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_CLR_MSK    0xfffffc00
+/* The reset value of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT field value from a register. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_GET(value) (((value) & 0x000003ff) >> 0)
+/* Produces a ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_SET(value) (((value) << 0) & 0x000003ff)
+ * The struct declaration for register ALT_SDR_CTL_PROTPORTDEFAULT.
+struct ALT_SDR_CTL_PROTPORTDEFAULT_s
+    uint32_t  portdefault : 10;  /* Port Default Action */
+    uint32_t              : 22;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_PROTPORTDEFAULT. */
+typedef volatile struct ALT_SDR_CTL_PROTPORTDEFAULT_s  ALT_SDR_CTL_PROTPORTDEFAULT_t;
+/* The byte offset of the ALT_SDR_CTL_PROTPORTDEFAULT register from the beginning of the component. */
+#define ALT_SDR_CTL_PROTPORTDEFAULT_OFST        0x8c
+ * Register : Memory Protection Address Register - protruleaddr
+ * This register is used to control the memory protection for port 0 transactions.
+ * Address ranges can either be used to allow access to memory regions or disallow
+ * access to memory regions.  If trustzone is being used, access can be enabled for
+ * protected transactions or disabled for unprotected transactions.  The default
+ * state of this register is to allow all access.  Address values used for
+ * protection are only physical addresses.
+ * Register Layout
+ *  [11:0]  | RW     | Unknown | Low Address
+ *  [23:12] | RW     | Unknown | High Address
+ *  [31:24] | ???    | 0x0     | *UNDEFINED*
+ * Field : Low Address - lowaddr
+ * Lower 12 bits of the address for a check.  Address is compared to be less than
+ * or equal to the address of a transaction.  Note that since AXI transactions
+ * cannot cross a 4K byte boundary, the transaction start and transaction end
+ * address must also fall within the same 1MByte block pointed to by this address
+ * pointer.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_MSB        11
+/* The width in bits of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_WIDTH      12
+/* The mask used to set the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field value. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_SET_MSK    0x00000fff
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field value. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_CLR_MSK    0xfffff000
+/* The reset value of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEADDR_LOWADDR field value from a register. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_GET(value) (((value) & 0x00000fff) >> 0)
+/* Produces a ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_SET(value) (((value) << 0) & 0x00000fff)
+ * Field : High Address - highaddr
+ * Upper 12 bits of the address for a check.  Address is compared to be greater
+ * than or equal to the address of a transaction.  Note that since AXI transactions
+ * pointer.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_MSB        23
+/* The width in bits of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_WIDTH      12
+/* The mask used to set the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field value. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_SET_MSK    0x00fff000
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field value. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_CLR_MSK    0xff000fff
+/* The reset value of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR field value from a register. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_GET(value) (((value) & 0x00fff000) >> 12)
+/* Produces a ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_SET(value) (((value) << 12) & 0x00fff000)
+ * The struct declaration for register ALT_SDR_CTL_PROTRULEADDR.
+struct ALT_SDR_CTL_PROTRULEADDR_s
+    uint32_t  lowaddr  : 12;  /* Low Address */
+    uint32_t  highaddr : 12;  /* High Address */
+    uint32_t           :  8;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_PROTRULEADDR. */
+typedef volatile struct ALT_SDR_CTL_PROTRULEADDR_s  ALT_SDR_CTL_PROTRULEADDR_t;
+/* The byte offset of the ALT_SDR_CTL_PROTRULEADDR register from the beginning of the component. */
+#define ALT_SDR_CTL_PROTRULEADDR_OFST        0x90
+ * Register : Memory Protection ID Register - protruleid
+ * Register Layout
+ *  [11:0]  | RW     | Unknown | Low ID
+ *  [23:12] | RW     | Unknown | High ID
+ * Field : Low ID - lowid
+ * AxID for the protection rule.  Incoming AxID needs to be greater than or equal
+ * to this value.  For all AxIDs from a port, AxID high should be programmed to all
+ * ones.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEID_LOWID register field. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEID_LOWID register field. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_MSB        11
+/* The width in bits of the ALT_SDR_CTL_PROTRULEID_LOWID register field. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_WIDTH      12
+/* The mask used to set the ALT_SDR_CTL_PROTRULEID_LOWID register field value. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_SET_MSK    0x00000fff
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEID_LOWID register field value. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_CLR_MSK    0xfffff000
+/* The reset value of the ALT_SDR_CTL_PROTRULEID_LOWID register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEID_LOWID field value from a register. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_GET(value) (((value) & 0x00000fff) >> 0)
+/* Produces a ALT_SDR_CTL_PROTRULEID_LOWID register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEID_LOWID_SET(value) (((value) << 0) & 0x00000fff)
+ * Field : High ID - highid
+ * AxID for the protection rule.  Incoming AxID needs to be less than or equal to
+ * this value.  For all AxIDs from a port, AxID high should be programmed to all
+ * ones.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEID_HIGHID register field. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEID_HIGHID register field. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_MSB        23
+/* The width in bits of the ALT_SDR_CTL_PROTRULEID_HIGHID register field. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_WIDTH      12
+/* The mask used to set the ALT_SDR_CTL_PROTRULEID_HIGHID register field value. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_SET_MSK    0x00fff000
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEID_HIGHID register field value. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_CLR_MSK    0xff000fff
+/* The reset value of the ALT_SDR_CTL_PROTRULEID_HIGHID register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEID_HIGHID field value from a register. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_GET(value) (((value) & 0x00fff000) >> 12)
+/* Produces a ALT_SDR_CTL_PROTRULEID_HIGHID register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEID_HIGHID_SET(value) (((value) << 12) & 0x00fff000)
+ * The struct declaration for register ALT_SDR_CTL_PROTRULEID.
+struct ALT_SDR_CTL_PROTRULEID_s
+    uint32_t  lowid  : 12;  /* Low ID */
+    uint32_t  highid : 12;  /* High ID */
+/* The typedef declaration for register ALT_SDR_CTL_PROTRULEID. */
+typedef volatile struct ALT_SDR_CTL_PROTRULEID_s  ALT_SDR_CTL_PROTRULEID_t;
+/* The byte offset of the ALT_SDR_CTL_PROTRULEID register from the beginning of the component. */
+#define ALT_SDR_CTL_PROTRULEID_OFST        0x94
+ * Register : Memory Protection Rule Data Register - protruledata
+ * Register Layout
+ *  [1:0]   | RW     | Unknown | Security Bit Behavior
+ *  [2]     | RW     | Unknown | Valid Rule
+ *  [12:3]  | RW     | Unknown | Port Mask
+ *  [13]    | RW     | Unknown | Rule Results
+ * Field : Security Bit Behavior - security
+ * A value of 2'b00 will make the rule apply to secure transactions.
+ * A value of 2'b01 will make the rule apply to non-secure transactions.
+ * A value of 2'b10 or 2'b11 will make the rule apply to secure and non-secure
+ * transactions.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_MSB        1
+/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_WIDTH      2
+/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEDATA_SECURITY field value from a register. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SDR_CTL_PROTRULEDATA_SECURITY register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_SET(value) (((value) << 0) & 0x00000003)
+ * Field : Valid Rule - validrule
+ * Set to bit to a one to make a rule valid, set to a zero to invalidate a rule.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_MSB        2
+/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE field value from a register. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Port Mask - portmask
+ * Set  bit x to a one to have this rule apply to port x, set bit x to a zero to
+ * have the rule not apply to a port.
Note that port 0-port 5 are the FPGA
+ * fabric ports, port 6 is L3 read, port 7 is CPU read, port 8 is L3 write, port 9
+ * is CPU write.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_MSB        12
+/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_WIDTH      10
+/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_SET_MSK    0x00001ff8
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_CLR_MSK    0xffffe007
+/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEDATA_PORTMSK field value from a register. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_GET(value) (((value) & 0x00001ff8) >> 3)
+/* Produces a ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_SET(value) (((value) << 3) & 0x00001ff8)
+ * Field : Rule Results - ruleresult
+ * Set this bit to a one to force a protection failure, zero to allow the access
+ * the succeed
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_MSB        13
+/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_SET_MSK    0x00002000
+/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field value. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULEDATA_RULERESULT field value from a register. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_SET(value) (((value) << 13) & 0x00002000)
+ * The struct declaration for register ALT_SDR_CTL_PROTRULEDATA.
+struct ALT_SDR_CTL_PROTRULEDATA_s
+    uint32_t  security   :  2;  /* Security Bit Behavior */
+    uint32_t  validrule  :  1;  /* Valid Rule */
+    uint32_t  portmask   : 10;  /* Port Mask */
+    uint32_t  ruleresult :  1;  /* Rule Results */
+/* The typedef declaration for register ALT_SDR_CTL_PROTRULEDATA. */
+typedef volatile struct ALT_SDR_CTL_PROTRULEDATA_s  ALT_SDR_CTL_PROTRULEDATA_t;
+/* The byte offset of the ALT_SDR_CTL_PROTRULEDATA register from the beginning of the component. */
+#define ALT_SDR_CTL_PROTRULEDATA_OFST        0x98
+ * Register : Memory Protection Rule Read-Write Register - protrulerdwr
+ * This register is used to perform read and write operations to the internal
+ * protection table.
+ * Register Layout
+ *  [4:0]  | RW     | Unknown | Rule Offset
+ *  [5]    | RW     | Unknown | Rule Write
+ *  [6]    | RW     | Unknown | Rule Read
+ *  [31:7] | ???    | 0x0     | *UNDEFINED*
+ * Field : Rule Offset - ruleoffset
+ * This field defines which of the 20 rules in the protection table you want to
+ * read or write.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_MSB        4
+/* The width in bits of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_WIDTH      5
+/* The mask used to set the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field value. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_SET_MSK    0x0000001f
+/* The mask used to clear the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field value. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_CLR_MSK    0xffffffe0
+/* The reset value of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET field value from a register. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_GET(value) (((value) & 0x0000001f) >> 0)
+/* Produces a ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_SET(value) (((value) << 0) & 0x0000001f)
+ * Field : Rule Write - writerule
+ * Write to this bit to have the memory_prot_data register to the table at the
+ * offset specified by port_offset.  Bit automatically clears after a single cycle
+ * and the write operation is complete.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_MSB        5
+/* The width in bits of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field value. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field value. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULERDWR_WRRULE field value from a register. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SDR_CTL_PROTRULERDWR_WRRULE register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_SET(value) (((value) << 5) & 0x00000020)
+ * Field : Rule Read - readrule
+ * Write to this bit to have the memory_prot_data register loaded with the value
+ * from the internal protection table at offset.  Table value will be loaded before
+ * a rdy is returned so read data from the register will be correct for any follow-
+ * on reads to the memory_prot_data register.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_MSB        6
+/* The width in bits of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_WIDTH      1
+/* The mask used to set the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field value. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field value. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field is UNKNOWN. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_RESET      0x0
+/* Extracts the ALT_SDR_CTL_PROTRULERDWR_RDRULE field value from a register. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SDR_CTL_PROTRULERDWR_RDRULE register field value suitable for setting the register. */
+#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_SET(value) (((value) << 6) & 0x00000040)
+ * The struct declaration for register ALT_SDR_CTL_PROTRULERDWR.
+struct ALT_SDR_CTL_PROTRULERDWR_s
+    uint32_t  ruleoffset :  5;  /* Rule Offset */
+    uint32_t  writerule  :  1;  /* Rule Write */
+    uint32_t  readrule   :  1;  /* Rule Read */
+    uint32_t             : 25;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_PROTRULERDWR. */
+typedef volatile struct ALT_SDR_CTL_PROTRULERDWR_s  ALT_SDR_CTL_PROTRULERDWR_t;
+/* The byte offset of the ALT_SDR_CTL_PROTRULERDWR register from the beginning of the component. */
+#define ALT_SDR_CTL_PROTRULERDWR_OFST        0x9c
+ * Register : QOS Control Register - qoslowpri
+ * This register controls the mapping of AXI4 QOS received from the FPGA fabric to
+ * the internal priority used for traffic prioritization.
+ * Register Layout
+ *  [19:0]  | RW     | Unknown | Low Priority QoS Value
+ * Field : Low Priority QoS Value - lowpriorityval
+ * This 20 bit field is a 2 bit field for each of the 10 ports.  The field used for
+ * each port in this register controls the priority used for a port
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_MSB        19
+/* The width in bits of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_WIDTH      20
+/* The mask used to set the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field value. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_SET_MSK    0x000fffff
+/* The mask used to clear the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field value. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_CLR_MSK    0xfff00000
+/* The reset value of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field is UNKNOWN. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL field value from a register. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_GET(value) (((value) & 0x000fffff) >> 0)
+/* Produces a ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_SET(value) (((value) << 0) & 0x000fffff)
+ * The struct declaration for register ALT_SDR_CTL_QOSLOWPRI.
+struct ALT_SDR_CTL_QOSLOWPRI_s
+    uint32_t  lowpriorityval : 20;  /* Low Priority QoS Value */
+/* The typedef declaration for register ALT_SDR_CTL_QOSLOWPRI. */
+typedef volatile struct ALT_SDR_CTL_QOSLOWPRI_s  ALT_SDR_CTL_QOSLOWPRI_t;
+/* The byte offset of the ALT_SDR_CTL_QOSLOWPRI register from the beginning of the component. */
+#define ALT_SDR_CTL_QOSLOWPRI_OFST        0xa0
+ * Register : qoshighpri Register - qoshighpri
+ * Register Layout
+ *  [19:0]  | RW     | Unknown | High Priority QoS Value
+ * Field : High Priority QoS Value - highpriorityval
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_MSB        19
+/* The width in bits of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_WIDTH      20
+/* The mask used to set the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field value. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_SET_MSK    0x000fffff
+/* The mask used to clear the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field value. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_CLR_MSK    0xfff00000
+/* The reset value of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field is UNKNOWN. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_RESET      0x0
+/* Extracts the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL field value from a register. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_GET(value) (((value) & 0x000fffff) >> 0)
+/* Produces a ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field value suitable for setting the register. */
+#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_SET(value) (((value) << 0) & 0x000fffff)
+ * The struct declaration for register ALT_SDR_CTL_QOSHIGHPRI.
+struct ALT_SDR_CTL_QOSHIGHPRI_s
+    uint32_t  highpriorityval : 20;  /* High Priority QoS Value */
+/* The typedef declaration for register ALT_SDR_CTL_QOSHIGHPRI. */
+typedef volatile struct ALT_SDR_CTL_QOSHIGHPRI_s  ALT_SDR_CTL_QOSHIGHPRI_t;
+/* The byte offset of the ALT_SDR_CTL_QOSHIGHPRI register from the beginning of the component. */
+#define ALT_SDR_CTL_QOSHIGHPRI_OFST        0xa4
+ * Register : qospriorityen Register - qospriorityen
+ * Register Layout
+ *  [9:0]   | RW     | Unknown | Per-Port QoS Enable
+ * Field : Per-Port QoS Enable - priorityen
+ * This 10 bit field is set to a one to enable QOS usage for a port.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_MSB        9
+/* The width in bits of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_WIDTH      10
+/* The mask used to set the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field value. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_SET_MSK    0x000003ff
+/* The mask used to clear the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field value. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_CLR_MSK    0xfffffc00
+/* The reset value of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field is UNKNOWN. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_RESET      0x0
+/* Extracts the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN field value from a register. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_GET(value) (((value) & 0x000003ff) >> 0)
+/* Produces a ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field value suitable for setting the register. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_SET(value) (((value) << 0) & 0x000003ff)
+ * The struct declaration for register ALT_SDR_CTL_QOSPRIORITYEN.
+struct ALT_SDR_CTL_QOSPRIORITYEN_s
+    uint32_t  priorityen : 10;  /* Per-Port QoS Enable */
+/* The typedef declaration for register ALT_SDR_CTL_QOSPRIORITYEN. */
+typedef volatile struct ALT_SDR_CTL_QOSPRIORITYEN_s  ALT_SDR_CTL_QOSPRIORITYEN_t;
+/* The byte offset of the ALT_SDR_CTL_QOSPRIORITYEN register from the beginning of the component. */
+#define ALT_SDR_CTL_QOSPRIORITYEN_OFST        0xa8
+ * Register : Scheduler priority Register - mppriority
+ * This register is used to configure the DRAM burst operation scheduling.
+ * Register Layout
+ *  [29:0]  | RW     | Unknown | Port User Priorities
+ *  [31:30] | ???    | 0x0     | *UNDEFINED*
+ * Field : Port User Priorities - userpriority
+ * Set absolute user priority of the port.  Each port is represented by a 3 bit
+ * value, 000=lowest priority, 111=highest priority.  Port 0 is bits 2:0.  Port
+ * number offset corresponds to the control port assignment.
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_MSB        29
+/* The width in bits of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_WIDTH      30
+/* The mask used to set the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field value. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_SET_MSK    0x3fffffff
+/* The mask used to clear the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field value. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_CLR_MSK    0xc0000000
+/* The reset value of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field is UNKNOWN. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_RESET      0x0
+/* Extracts the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY field value from a register. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_GET(value) (((value) & 0x3fffffff) >> 0)
+/* Produces a ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field value suitable for setting the register. */
+#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_SET(value) (((value) << 0) & 0x3fffffff)
+ * The struct declaration for register ALT_SDR_CTL_MPPRIORITY.
+struct ALT_SDR_CTL_MPPRIORITY_s
+    uint32_t  userpriority : 30;  /* Port User Priorities */
+    uint32_t               :  2;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_MPPRIORITY. */
+typedef volatile struct ALT_SDR_CTL_MPPRIORITY_s  ALT_SDR_CTL_MPPRIORITY_t;
+/* The byte offset of the ALT_SDR_CTL_MPPRIORITY register from the beginning of the component. */
+#define ALT_SDR_CTL_MPPRIORITY_OFST        0xac
+ * Register : Controller Command Pool Priority Remap Register - remappriority
+ * This register controls the priority for transactions in the controller command
+ * pool.
+ * Register Layout
+ *  [7:0]  | RW     | Unknown | Priority Remap
+ *  [31:8] | ???    | 0x0     | *UNDEFINED*
+ * Field : Priority Remap - priorityremap
+ * Set bit N of this register to the value to a one to enable the controller
+ * command pool priority bit of a transaction from MPFE priority N
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_MSB        7
+/* The width in bits of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_WIDTH      8
+/* The mask used to set the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field value. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_SET_MSK    0x000000ff
+/* The mask used to clear the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field value. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_CLR_MSK    0xffffff00
+/* The reset value of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field is UNKNOWN. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_RESET      0x0
+/* Extracts the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP field value from a register. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_GET(value) (((value) & 0x000000ff) >> 0)
+/* Produces a ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field value suitable for setting the register. */
+#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_SET(value) (((value) << 0) & 0x000000ff)
+ * The struct declaration for register ALT_SDR_CTL_REMAPPRIORITY.
+struct ALT_SDR_CTL_REMAPPRIORITY_s
+    uint32_t  priorityremap :  8;  /* Priority Remap */
+    uint32_t                : 24;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_REMAPPRIORITY. */
+typedef volatile struct ALT_SDR_CTL_REMAPPRIORITY_s  ALT_SDR_CTL_REMAPPRIORITY_t;
+/* The byte offset of the ALT_SDR_CTL_REMAPPRIORITY register from the beginning of the component. */
+#define ALT_SDR_CTL_REMAPPRIORITY_OFST        0xe0
+ * Register Group : Port Sum of Weight Register - ALT_SDR_CTL_MPWT
+ * Port Sum of Weight Register
+ * Register : Port Sum of Weight Register[1/4] - mpweight_0_4
+ * Register Layout
+ *  [31:0] | RW     | Unknown | Port Static Weights[31:0]
+ * Field : Port Static Weights[31:0] - staticweight_31_0
+ * Set static weight of the port.  Each port is programmed with a 5 bit value.
+ * Port 0 is bits 4:0, port 1 is bits 9:5, up to port 9 being bits 49:45
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_MSB        31
+/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_WIDTH      32
+/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_CLR_MSK    0x00000000
+/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field is UNKNOWN. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_RESET      0x0
+/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 field value from a register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field value suitable for setting the register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_SET(value) (((value) << 0) & 0xffffffff)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_0_4.
+struct ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_s
+    uint32_t  staticweight_31_0 : 32;  /* Port Static Weights[31:0] */
+/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_0_4. */
+typedef volatile struct ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_s  ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 register from the beginning of the component. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_OFST        0x0
+/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_OFST))
+ * Register : Port Sum of Weight Register[2/4] - mpweight_1_4
+ * Register Layout
+ *  Bits    | Access | Reset   | Description
+ *  [17:0]  | RW     | Unknown | Port Static Weights[49:32]
+ *  [31:18] | RW     | Unknown | Port Sum of Weights[13:0]
+ * Field : Port Static Weights[49:32] - staticweight_49_32
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_MSB        17
+/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_WIDTH      18
+/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_SET_MSK    0x0003ffff
+/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_CLR_MSK    0xfffc0000
+/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field is UNKNOWN. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_RESET      0x0
+/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 field value from a register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_GET(value) (((value) & 0x0003ffff) >> 0)
+/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field value suitable for setting the register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_SET(value) (((value) << 0) & 0x0003ffff)
+ * Field : Port Sum of Weights[13:0] - sumofweights_13_0
+ * Set the sum of static weights for particular user priority.  This register is
+ * used as part of the deficit round robin implementation.  It should be set to the
+ * sum of the weights for the ports
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_LSB        18
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_MSB        31
+/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_WIDTH      14
+/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_SET_MSK    0xfffc0000
+/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_CLR_MSK    0x0003ffff
+/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field is UNKNOWN. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_RESET      0x0
+/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 field value from a register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_GET(value) (((value) & 0xfffc0000) >> 18)
+/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field value suitable for setting the register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_SET(value) (((value) << 18) & 0xfffc0000)
+ * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_1_4.
+struct ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_s
+    uint32_t  staticweight_49_32 : 18;  /* Port Static Weights[49:32] */
+    uint32_t  sumofweights_13_0  : 14;  /* Port Sum of Weights[13:0] */
+/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_1_4. */
+typedef volatile struct ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_s  ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_t;
+/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 register from the beginning of the component. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_OFST        0x4
+/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_OFST))
+ * Register : Port Sum of Weight Register[3/4] - mpweight_2_4
+ * Register Layout
+ *  [31:0] | RW     | Unknown | Port Sum of Weights[45:14]
+ * Field : Port Sum of Weights[45:14] - sumofweights_45_14
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_MSB        31
+/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_WIDTH      32
+/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_CLR_MSK    0x00000000
+/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field is UNKNOWN. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_RESET      0x0
+/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 field value from a register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field value suitable for setting the register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_2_4.
+struct ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_s
+    uint32_t  sumofweights_45_14 : 32;  /* Port Sum of Weights[45:14] */
+/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_2_4. */
+typedef volatile struct ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_s  ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_t;
+/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 register from the beginning of the component. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_OFST        0x8
+/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_OFST))
+ * Register : Port Sum of Weight Register[4/4] - mpweight_3_4
+ * Register Layout
+ *  [17:0]  | RW     | Unknown | Port Sum of Weights[63:46]
+ *  [31:18] | ???    | 0x0     | *UNDEFINED*
+ * Field : Port Sum of Weights[63:46] - sumofweights_63_46
+/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_MSB        17
+/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_WIDTH      18
+/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_SET_MSK    0x0003ffff
+/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field value. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_CLR_MSK    0xfffc0000
+/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field is UNKNOWN. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_RESET      0x0
+/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 field value from a register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_GET(value) (((value) & 0x0003ffff) >> 0)
+/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field value suitable for setting the register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_SET(value) (((value) << 0) & 0x0003ffff)
+ * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_3_4.
+struct ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_s
+    uint32_t  sumofweights_63_46 : 18;  /* Port Sum of Weights[63:46] */
+    uint32_t                     : 14;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_3_4. */
+typedef volatile struct ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_s  ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_t;
+/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 register from the beginning of the component. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_OFST        0xc
+/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 register. */
+#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_OFST))
+ * The struct declaration for register group ALT_SDR_CTL_MPWT.
+struct ALT_SDR_CTL_MPWT_s
+    volatile ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_t  mpweight_0_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 */
+    volatile ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_t  mpweight_1_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 */
+    volatile ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_t  mpweight_2_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 */
+    volatile ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_t  mpweight_3_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 */
+/* The typedef declaration for register group ALT_SDR_CTL_MPWT. */
+typedef volatile struct ALT_SDR_CTL_MPWT_s  ALT_SDR_CTL_MPWT_t;
+/* The struct declaration for the raw register contents of register group ALT_SDR_CTL_MPWT. */
+struct ALT_SDR_CTL_MPWT_raw_s
+    volatile uint32_t  mpweight_0_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 */
+    volatile uint32_t  mpweight_1_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 */
+    volatile uint32_t  mpweight_2_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 */
+    volatile uint32_t  mpweight_3_4;  /* ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 */
+/* The typedef declaration for the raw register contents of register group ALT_SDR_CTL_MPWT. */
+typedef volatile struct ALT_SDR_CTL_MPWT_raw_s  ALT_SDR_CTL_MPWT_raw_t;
+ * The struct declaration for register group ALT_SDR_CTL.
+struct ALT_SDR_CTL_s
+    volatile ALT_SDR_CTL_CTLCFG_t           ctrlcfg;                /* ALT_SDR_CTL_CTLCFG */
+    volatile ALT_SDR_CTL_DRAMTIMING1_t      dramtiming1;            /* ALT_SDR_CTL_DRAMTIMING1 */
+    volatile ALT_SDR_CTL_DRAMTIMING2_t      dramtiming2;            /* ALT_SDR_CTL_DRAMTIMING2 */
+    volatile ALT_SDR_CTL_DRAMTIMING3_t      dramtiming3;            /* ALT_SDR_CTL_DRAMTIMING3 */
+    volatile ALT_SDR_CTL_DRAMTIMING4_t      dramtiming4;            /* ALT_SDR_CTL_DRAMTIMING4 */
+    volatile ALT_SDR_CTL_LOWPWRTIMING_t     lowpwrtiming;           /* ALT_SDR_CTL_LOWPWRTIMING */
+    volatile ALT_SDR_CTL_DRAMODT_t          dramodt;                /* ALT_SDR_CTL_DRAMODT */
+    volatile uint32_t                       _pad_0x1c_0x2b[4];      /* *UNDEFINED* */
+    volatile ALT_SDR_CTL_DRAMADDRW_t        dramaddrw;              /* ALT_SDR_CTL_DRAMADDRW */
+    volatile ALT_SDR_CTL_DRAMIFWIDTH_t      dramifwidth;            /* ALT_SDR_CTL_DRAMIFWIDTH */
+    volatile ALT_SDR_CTL_DRAMDEVWIDTH_t     dramdevwidth;           /* ALT_SDR_CTL_DRAMDEVWIDTH */
+    volatile ALT_SDR_CTL_DRAMSTS_t          dramsts;                /* ALT_SDR_CTL_DRAMSTS */
+    volatile ALT_SDR_CTL_DRAMINTR_t         dramintr;               /* ALT_SDR_CTL_DRAMINTR */
+    volatile ALT_SDR_CTL_SBECOUNT_t         sbecount;               /* ALT_SDR_CTL_SBECOUNT */
+    volatile ALT_SDR_CTL_DBECOUNT_t         dbecount;               /* ALT_SDR_CTL_DBECOUNT */
+    volatile ALT_SDR_CTL_ERRADDR_t          erraddr;                /* ALT_SDR_CTL_ERRADDR */
+    volatile ALT_SDR_CTL_DROPCOUNT_t        dropcount;              /* ALT_SDR_CTL_DROPCOUNT */
+    volatile ALT_SDR_CTL_DROPADDR_t         dropaddr;               /* ALT_SDR_CTL_DROPADDR */
+    volatile ALT_SDR_CTL_LOWPWREQ_t         lowpwreq;               /* ALT_SDR_CTL_LOWPWREQ */
+    volatile ALT_SDR_CTL_LOWPWRACK_t        lowpwrack;              /* ALT_SDR_CTL_LOWPWRACK */
+    volatile ALT_SDR_CTL_STATICCFG_t        staticcfg;              /* ALT_SDR_CTL_STATICCFG */
+    volatile ALT_SDR_CTL_CTLWIDTH_t         ctrlwidth;              /* ALT_SDR_CTL_CTLWIDTH */
+    volatile uint32_t                       _pad_0x64_0x7b[6];      /* *UNDEFINED* */
+    volatile ALT_SDR_CTL_PORTCFG_t          portcfg;                /* ALT_SDR_CTL_PORTCFG */
+    volatile ALT_SDR_CTL_FPGAPORTRST_t      fpgaportrst;            /* ALT_SDR_CTL_FPGAPORTRST */
+    volatile uint32_t                       _pad_0x84_0x8b[2];      /* *UNDEFINED* */
+    volatile ALT_SDR_CTL_PROTPORTDEFAULT_t  protportdefault;        /* ALT_SDR_CTL_PROTPORTDEFAULT */
+    volatile ALT_SDR_CTL_PROTRULEADDR_t     protruleaddr;           /* ALT_SDR_CTL_PROTRULEADDR */
+    volatile ALT_SDR_CTL_PROTRULEID_t       protruleid;             /* ALT_SDR_CTL_PROTRULEID */
+    volatile ALT_SDR_CTL_PROTRULEDATA_t     protruledata;           /* ALT_SDR_CTL_PROTRULEDATA */
+    volatile ALT_SDR_CTL_PROTRULERDWR_t     protrulerdwr;           /* ALT_SDR_CTL_PROTRULERDWR */
+    volatile ALT_SDR_CTL_QOSLOWPRI_t        qoslowpri;              /* ALT_SDR_CTL_QOSLOWPRI */
+    volatile ALT_SDR_CTL_QOSHIGHPRI_t       qoshighpri;             /* ALT_SDR_CTL_QOSHIGHPRI */
+    volatile ALT_SDR_CTL_QOSPRIORITYEN_t    qospriorityen;          /* ALT_SDR_CTL_QOSPRIORITYEN */
+    volatile ALT_SDR_CTL_MPPRIORITY_t       mppriority;             /* ALT_SDR_CTL_MPPRIORITY */
+    volatile ALT_SDR_CTL_MPWT_t             ctrlgrp_mpweight;       /* ALT_SDR_CTL_MPWT */
+    volatile uint32_t                       _pad_0xc0_0xdf[8];      /* *UNDEFINED* */
+    volatile ALT_SDR_CTL_REMAPPRIORITY_t    remappriority;          /* ALT_SDR_CTL_REMAPPRIORITY */
+    volatile uint32_t                       _pad_0xe4_0x1000[967];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_SDR_CTL. */
+typedef volatile struct ALT_SDR_CTL_s  ALT_SDR_CTL_t;
+/* The struct declaration for the raw register contents of register group ALT_SDR_CTL. */
+struct ALT_SDR_CTL_raw_s
+    volatile uint32_t                ctrlcfg;                /* ALT_SDR_CTL_CTLCFG */
+    volatile uint32_t                dramtiming1;            /* ALT_SDR_CTL_DRAMTIMING1 */
+    volatile uint32_t                dramtiming2;            /* ALT_SDR_CTL_DRAMTIMING2 */
+    volatile uint32_t                dramtiming3;            /* ALT_SDR_CTL_DRAMTIMING3 */
+    volatile uint32_t                dramtiming4;            /* ALT_SDR_CTL_DRAMTIMING4 */
+    volatile uint32_t                lowpwrtiming;           /* ALT_SDR_CTL_LOWPWRTIMING */
+    volatile uint32_t                dramodt;                /* ALT_SDR_CTL_DRAMODT */
+    volatile uint32_t                dramaddrw;              /* ALT_SDR_CTL_DRAMADDRW */
+    volatile uint32_t                dramifwidth;            /* ALT_SDR_CTL_DRAMIFWIDTH */
+    volatile uint32_t                dramdevwidth;           /* ALT_SDR_CTL_DRAMDEVWIDTH */
+    volatile uint32_t                dramsts;                /* ALT_SDR_CTL_DRAMSTS */
+    volatile uint32_t                dramintr;               /* ALT_SDR_CTL_DRAMINTR */
+    volatile uint32_t                sbecount;               /* ALT_SDR_CTL_SBECOUNT */
+    volatile uint32_t                dbecount;               /* ALT_SDR_CTL_DBECOUNT */
+    volatile uint32_t                erraddr;                /* ALT_SDR_CTL_ERRADDR */
+    volatile uint32_t                dropcount;              /* ALT_SDR_CTL_DROPCOUNT */
+    volatile uint32_t                dropaddr;               /* ALT_SDR_CTL_DROPADDR */
+    volatile uint32_t                lowpwreq;               /* ALT_SDR_CTL_LOWPWREQ */
+    volatile uint32_t                lowpwrack;              /* ALT_SDR_CTL_LOWPWRACK */
+    volatile uint32_t                staticcfg;              /* ALT_SDR_CTL_STATICCFG */
+    volatile uint32_t                ctrlwidth;              /* ALT_SDR_CTL_CTLWIDTH */
+    volatile uint32_t                portcfg;                /* ALT_SDR_CTL_PORTCFG */
+    volatile uint32_t                fpgaportrst;            /* ALT_SDR_CTL_FPGAPORTRST */
+    volatile uint32_t                protportdefault;        /* ALT_SDR_CTL_PROTPORTDEFAULT */
+    volatile uint32_t                protruleaddr;           /* ALT_SDR_CTL_PROTRULEADDR */
+    volatile uint32_t                protruleid;             /* ALT_SDR_CTL_PROTRULEID */
+    volatile uint32_t                protruledata;           /* ALT_SDR_CTL_PROTRULEDATA */
+    volatile uint32_t                protrulerdwr;           /* ALT_SDR_CTL_PROTRULERDWR */
+    volatile uint32_t                qoslowpri;              /* ALT_SDR_CTL_QOSLOWPRI */
+    volatile uint32_t                qoshighpri;             /* ALT_SDR_CTL_QOSHIGHPRI */
+    volatile uint32_t                qospriorityen;          /* ALT_SDR_CTL_QOSPRIORITYEN */
+    volatile uint32_t                mppriority;             /* ALT_SDR_CTL_MPPRIORITY */
+    volatile ALT_SDR_CTL_MPWT_raw_t  ctrlgrp_mpweight;       /* ALT_SDR_CTL_MPWT */
+    volatile uint32_t                remappriority;          /* ALT_SDR_CTL_REMAPPRIORITY */
+/* The typedef declaration for the raw register contents of register group ALT_SDR_CTL. */
+typedef volatile struct ALT_SDR_CTL_raw_s  ALT_SDR_CTL_raw_t;
+ * The struct declaration for register group ALT_SDR.
+struct ALT_SDR_s
+    volatile uint32_t       _pad_0x0_0x4fff[5120];       /* *UNDEFINED* */
+    volatile ALT_SDR_CTL_t  ctrlgrp;                     /* ALT_SDR_CTL */
+    volatile uint32_t       _pad_0x6000_0x20000[26624];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_SDR. */
+typedef volatile struct ALT_SDR_s  ALT_SDR_t;
+/* The struct declaration for the raw register contents of register group ALT_SDR. */
+struct ALT_SDR_raw_s
+    volatile ALT_SDR_CTL_raw_t  ctrlgrp;                     /* ALT_SDR_CTL */
+/* The typedef declaration for the raw register contents of register group ALT_SDR. */
+typedef volatile struct ALT_SDR_raw_s  ALT_SDR_raw_t;
+#ifdef __cplusplus
+#endif  /* __cplusplus */
+#endif  /* __ALTERA_ALT_SDR_H__ */
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sysmgr.h b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sysmgr.h
new file mode 100644
index 0000000..fce6d6e
--- /dev/null
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include/socal/alt_sysmgr.h
@@ -0,0 +1,24810 @@
+* Copyright 2013 Altera Corporation. All Rights Reserved.                      *
+* Redistribution and use in source and binary forms, with or without           *
+* modification, are permitted provided that the following conditions are met:  *
+* 1. Redistributions of source code must retain the above copyright notice,    *
+*    this list of conditions and the following disclaimer.                     *
+* 2. Redistributions in binary form must reproduce the above copyright notice, *
+*    this list of conditions and the following disclaimer in the documentation *
+*    and/or other materials provided with the distribution.                    *
+* 3. The name of the author may not be used to endorse or promote products     *
+*    derived from this software without specific prior written permission.     *
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
+* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
+* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO  *
+* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,       *
+* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
+* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;  *
+* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,     *
+* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR      *
+* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF       *
+* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.                                   *
+/* Altera - ALT_SYSMGR */
+#ifndef __ALTERA_ALT_SYSMGR_H__
+#define __ALTERA_ALT_SYSMGR_H__
+#ifdef __cplusplus
+extern "C"
+ * Component : System Manager Module - ALT_SYSMGR
+ * System Manager Module
+ * Registers in the System Manager module
+ * Register : Silicon ID1 Register - siliconid1
+ * Specifies Silicon ID and revision number.
+ * Register Layout
+ *  [15:0]  | R      | 0x1   | Silicon Revision
+ *  [31:16] | R      | 0x0   | Silicon ID
+ * Field : Silicon Revision - rev
+ * Silicon revision number.
+ * Field Enumeration Values:
+ *  Enum                             | Value | Description
+ *  ALT_SYSMGR_SILICONID1_REV_E_REV1 | 0x1   | Revision 1
+ * Enumerated value for register field ALT_SYSMGR_SILICONID1_REV
+ * Revision 1
+#define ALT_SYSMGR_SILICONID1_REV_E_REV1    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SILICONID1_REV register field. */
+#define ALT_SYSMGR_SILICONID1_REV_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SILICONID1_REV register field. */
+#define ALT_SYSMGR_SILICONID1_REV_MSB        15
+/* The width in bits of the ALT_SYSMGR_SILICONID1_REV register field. */
+#define ALT_SYSMGR_SILICONID1_REV_WIDTH      16
+/* The mask used to set the ALT_SYSMGR_SILICONID1_REV register field value. */
+#define ALT_SYSMGR_SILICONID1_REV_SET_MSK    0x0000ffff
+/* The mask used to clear the ALT_SYSMGR_SILICONID1_REV register field value. */
+#define ALT_SYSMGR_SILICONID1_REV_CLR_MSK    0xffff0000
+/* The reset value of the ALT_SYSMGR_SILICONID1_REV register field. */
+#define ALT_SYSMGR_SILICONID1_REV_RESET      0x1
+/* Extracts the ALT_SYSMGR_SILICONID1_REV field value from a register. */
+#define ALT_SYSMGR_SILICONID1_REV_GET(value) (((value) & 0x0000ffff) >> 0)
+/* Produces a ALT_SYSMGR_SILICONID1_REV register field value suitable for setting the register. */
+#define ALT_SYSMGR_SILICONID1_REV_SET(value) (((value) << 0) & 0x0000ffff)
+ * Field : Silicon ID - id
+ * Silicon ID
+ *  ALT_SYSMGR_SILICONID1_ID_E_CYCLONEV_ARRIAV | 0x0   | HPS in Cyclone V and Arria V SoC FPGA devices
+ * Enumerated value for register field ALT_SYSMGR_SILICONID1_ID
+ * HPS in Cyclone V and Arria V SoC FPGA devices
+#define ALT_SYSMGR_SILICONID1_ID_E_CYCLONEV_ARRIAV  0x0
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SILICONID1_ID register field. */
+#define ALT_SYSMGR_SILICONID1_ID_LSB        16
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SILICONID1_ID register field. */
+#define ALT_SYSMGR_SILICONID1_ID_MSB        31
+/* The width in bits of the ALT_SYSMGR_SILICONID1_ID register field. */
+#define ALT_SYSMGR_SILICONID1_ID_WIDTH      16
+/* The mask used to set the ALT_SYSMGR_SILICONID1_ID register field value. */
+#define ALT_SYSMGR_SILICONID1_ID_SET_MSK    0xffff0000
+/* The mask used to clear the ALT_SYSMGR_SILICONID1_ID register field value. */
+#define ALT_SYSMGR_SILICONID1_ID_CLR_MSK    0x0000ffff
+/* The reset value of the ALT_SYSMGR_SILICONID1_ID register field. */
+#define ALT_SYSMGR_SILICONID1_ID_RESET      0x0
+/* Extracts the ALT_SYSMGR_SILICONID1_ID field value from a register. */
+#define ALT_SYSMGR_SILICONID1_ID_GET(value) (((value) & 0xffff0000) >> 16)
+/* Produces a ALT_SYSMGR_SILICONID1_ID register field value suitable for setting the register. */
+#define ALT_SYSMGR_SILICONID1_ID_SET(value) (((value) << 16) & 0xffff0000)
+ * The struct declaration for register ALT_SYSMGR_SILICONID1.
+struct ALT_SYSMGR_SILICONID1_s
+    const uint32_t  rev : 16;  /* Silicon Revision */
+    const uint32_t  id  : 16;  /* Silicon ID */
+/* The typedef declaration for register ALT_SYSMGR_SILICONID1. */
+typedef volatile struct ALT_SYSMGR_SILICONID1_s  ALT_SYSMGR_SILICONID1_t;
+/* The byte offset of the ALT_SYSMGR_SILICONID1 register from the beginning of the component. */
+#define ALT_SYSMGR_SILICONID1_OFST        0x0
+ * Register : Silicon ID2 Register - siliconid2
+ * Reserved for future use.
+ * Register Layout
+ *  [31:0] | R      | 0x0   | Reserved
+ * Field : Reserved - rsv
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SILICONID2_RSV register field. */
+#define ALT_SYSMGR_SILICONID2_RSV_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SILICONID2_RSV register field. */
+#define ALT_SYSMGR_SILICONID2_RSV_MSB        31
+/* The width in bits of the ALT_SYSMGR_SILICONID2_RSV register field. */
+#define ALT_SYSMGR_SILICONID2_RSV_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_SILICONID2_RSV register field value. */
+#define ALT_SYSMGR_SILICONID2_RSV_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_SILICONID2_RSV register field value. */
+#define ALT_SYSMGR_SILICONID2_RSV_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_SILICONID2_RSV register field. */
+#define ALT_SYSMGR_SILICONID2_RSV_RESET      0x0
+/* Extracts the ALT_SYSMGR_SILICONID2_RSV field value from a register. */
+#define ALT_SYSMGR_SILICONID2_RSV_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_SILICONID2_RSV register field value suitable for setting the register. */
+#define ALT_SYSMGR_SILICONID2_RSV_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SYSMGR_SILICONID2.
+struct ALT_SYSMGR_SILICONID2_s
+    const uint32_t  rsv : 32;  /* Reserved */
+/* The typedef declaration for register ALT_SYSMGR_SILICONID2. */
+typedef volatile struct ALT_SYSMGR_SILICONID2_s  ALT_SYSMGR_SILICONID2_t;
+/* The byte offset of the ALT_SYSMGR_SILICONID2 register from the beginning of the component. */
+#define ALT_SYSMGR_SILICONID2_OFST        0x4
+ * Register : L4 Watchdog Debug Register - wddbg
+ * Controls the behavior of the L4 watchdogs when the CPUs are in debug mode. These
+ * control registers are used to drive the pause input signal of the L4 watchdogs.
+ * Note that the watchdogs built into the MPU automatically are paused when their
+ * associated CPU enters debug mode. Only reset by a cold reset.
+ * Register Layout
+ *  [1:0]  | RW     | 0x3   | Debug Mode
+ *  [3:2]  | RW     | 0x3   | Debug Mode
+ *  [31:4] | ???    | 0x0   | *UNDEFINED*
+ * Field : Debug Mode - mode_0
+ * Controls behavior of L4 watchdog when CPUs in debug mode. Field array index
+ * matches L4 watchdog index.
+ *  ALT_SYSMGR_WDDBG_MOD_0_E_CONTINUE    | 0x0   | Continue normal operation ignoring debug mode of
+ * :                                     |       | CPUs
+ *  ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU0   | 0x1   | Pause normal operation only if CPU0 is in debug
+ * :                                     |       | mode
+ *  ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU1   | 0x2   | Pause normal operation only if CPU1 is in debug
+ * :                                     |       | mode
+ *  ALT_SYSMGR_WDDBG_MOD_0_E_PAUSEEITHER | 0x3   | Pause normal operation if CPU0 or CPU1 is in
+ * :                                     |       | debug mode
+ * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_0
+ * Continue normal operation ignoring debug mode of CPUs
+#define ALT_SYSMGR_WDDBG_MOD_0_E_CONTINUE       0x0
+ * Pause normal operation only if CPU0 is in debug mode
+#define ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU0      0x1
+ * Pause normal operation only if CPU1 is in debug mode
+#define ALT_SYSMGR_WDDBG_MOD_0_E_PAUSECPU1      0x2
+ * Pause normal operation if CPU0 or CPU1 is in debug mode
+#define ALT_SYSMGR_WDDBG_MOD_0_E_PAUSEEITHER    0x3
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_0_MSB        1
+/* The width in bits of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_0_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_WDDBG_MOD_0 register field value. */
+#define ALT_SYSMGR_WDDBG_MOD_0_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_WDDBG_MOD_0 register field value. */
+#define ALT_SYSMGR_WDDBG_MOD_0_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_WDDBG_MOD_0 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_0_RESET      0x3
+/* Extracts the ALT_SYSMGR_WDDBG_MOD_0 field value from a register. */
+#define ALT_SYSMGR_WDDBG_MOD_0_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_WDDBG_MOD_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_WDDBG_MOD_0_SET(value) (((value) << 0) & 0x00000003)
+ * Field : Debug Mode - mode_1
+ *  ALT_SYSMGR_WDDBG_MOD_1_E_CONTINUE    | 0x0   | Continue normal operation ignoring debug mode of
+ * :                                     |       | CPUs
+ *  ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU0   | 0x1   | Pause normal operation only if CPU0 is in debug
+ * :                                     |       | mode
+ *  ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU1   | 0x2   | Pause normal operation only if CPU1 is in debug
+ * :                                     |       | mode
+ *  ALT_SYSMGR_WDDBG_MOD_1_E_PAUSEEITHER | 0x3   | Pause normal operation if CPU0 or CPU1 is in
+ * Enumerated value for register field ALT_SYSMGR_WDDBG_MOD_1
+#define ALT_SYSMGR_WDDBG_MOD_1_E_CONTINUE       0x0
+#define ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU0      0x1
+#define ALT_SYSMGR_WDDBG_MOD_1_E_PAUSECPU1      0x2
+#define ALT_SYSMGR_WDDBG_MOD_1_E_PAUSEEITHER    0x3
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_1_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_1_MSB        3
+/* The width in bits of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_1_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_WDDBG_MOD_1 register field value. */
+#define ALT_SYSMGR_WDDBG_MOD_1_SET_MSK    0x0000000c
+/* The mask used to clear the ALT_SYSMGR_WDDBG_MOD_1 register field value. */
+#define ALT_SYSMGR_WDDBG_MOD_1_CLR_MSK    0xfffffff3
+/* The reset value of the ALT_SYSMGR_WDDBG_MOD_1 register field. */
+#define ALT_SYSMGR_WDDBG_MOD_1_RESET      0x3
+/* Extracts the ALT_SYSMGR_WDDBG_MOD_1 field value from a register. */
+#define ALT_SYSMGR_WDDBG_MOD_1_GET(value) (((value) & 0x0000000c) >> 2)
+/* Produces a ALT_SYSMGR_WDDBG_MOD_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_WDDBG_MOD_1_SET(value) (((value) << 2) & 0x0000000c)
+ * The struct declaration for register ALT_SYSMGR_WDDBG.
+struct ALT_SYSMGR_WDDBG_s
+    uint32_t  mode_0 :  2;  /* Debug Mode */
+    uint32_t  mode_1 :  2;  /* Debug Mode */
+    uint32_t         : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_WDDBG. */
+typedef volatile struct ALT_SYSMGR_WDDBG_s  ALT_SYSMGR_WDDBG_t;
+/* The byte offset of the ALT_SYSMGR_WDDBG register from the beginning of the component. */
+#define ALT_SYSMGR_WDDBG_OFST        0x10
+ * Register : Boot Info Register - bootinfo
+ * Provides access to boot configuration information.
+ * Register Layout
+ *  [2:0]   | R      | Unknown | Boot Select
+ *  [4:3]   | R      | Unknown | Clock Select
+ *  [7:5]   | R      | Unknown | HPS Pin Boot Select
+ *  [9:8]   | R      | Unknown | HPS Pin Clock Select
+ *  [31:10] | ???    | Unknown | *UNDEFINED*
+ * Field : Boot Select - bsel
+ * The boot select field specifies the boot source. It is read by the Boot ROM code
+ * on a cold or warm reset to determine the boot source.
+ * The HPS BSEL pins value are sampled upon deassertion of cold reset.
+ *  ALT_SYSMGR_BOOT_BSEL_E_RSVD                             | 0x0   | Reserved
+ *  ALT_SYSMGR_BOOT_BSEL_E_FPGA                             | 0x1   | FPGA (HPS2FPGA Bridge)
+ *  ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_1_8V                   | 0x2   | NAND Flash (1.8v)
+ *  ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_3_0V                   | 0x3   | NAND Flash (3.0v)
+ *  ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_EXTERNAL_TRANSCEIVER_1_8V | 0x4   | SD/MMC External Transceiver (1.8v)
+ *  ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_INTERNAL_TRANSCEIVER_3_0V | 0x5   | SD/MMC Internal Transceiver (3.0v)
+ *  ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_1_8V                   | 0x6   | QSPI Flash (1.8v)
+ *  ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_3_0V                   | 0x7   | QSPI Flash (3.0v)
+ * Enumerated value for register field ALT_SYSMGR_BOOT_BSEL
+ * Reserved
+#define ALT_SYSMGR_BOOT_BSEL_E_RSVD                             0x0
+ * FPGA (HPS2FPGA Bridge)
+#define ALT_SYSMGR_BOOT_BSEL_E_FPGA                             0x1
+ * NAND Flash (1.8v)
+#define ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_1_8V                   0x2
+ * NAND Flash (3.0v)
+#define ALT_SYSMGR_BOOT_BSEL_E_NAND_FLSH_3_0V                   0x3
+ * SD/MMC External Transceiver (1.8v)
+#define ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_EXTERNAL_TRANSCEIVER_1_8V 0x4
+ * SD/MMC Internal Transceiver (3.0v)
+#define ALT_SYSMGR_BOOT_BSEL_E_SD_MMC_INTERNAL_TRANSCEIVER_3_0V 0x5
+ * QSPI Flash (1.8v)
+#define ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_1_8V                   0x6
+ * QSPI Flash (3.0v)
+#define ALT_SYSMGR_BOOT_BSEL_E_QSPI_FLSH_3_0V                   0x7
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_BSEL register field. */
+#define ALT_SYSMGR_BOOT_BSEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_BSEL register field. */
+#define ALT_SYSMGR_BOOT_BSEL_MSB        2
+/* The width in bits of the ALT_SYSMGR_BOOT_BSEL register field. */
+#define ALT_SYSMGR_BOOT_BSEL_WIDTH      3
+/* The mask used to set the ALT_SYSMGR_BOOT_BSEL register field value. */
+#define ALT_SYSMGR_BOOT_BSEL_SET_MSK    0x00000007
+/* The mask used to clear the ALT_SYSMGR_BOOT_BSEL register field value. */
+#define ALT_SYSMGR_BOOT_BSEL_CLR_MSK    0xfffffff8
+/* The reset value of the ALT_SYSMGR_BOOT_BSEL register field is UNKNOWN. */
+#define ALT_SYSMGR_BOOT_BSEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_BOOT_BSEL field value from a register. */
+#define ALT_SYSMGR_BOOT_BSEL_GET(value) (((value) & 0x00000007) >> 0)
+/* Produces a ALT_SYSMGR_BOOT_BSEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_BOOT_BSEL_SET(value) (((value) << 0) & 0x00000007)
+ * Field : Clock Select - csel
+ * The clock select field specifies clock information for booting. The clock select
+ * encoding is a function of the CSEL value. The clock select field is read by the
+ * Boot ROM code on a cold or warm reset when booting from a flash device to get
+ * information about how to setup the HPS clocking to boot from the specified clock
+ * device.
+ * The encoding of the clock select field is specified by the enum associated with
+ * this field.
+ * The HPS CSEL pins value are sampled upon deassertion of cold reset.
+ *  ALT_SYSMGR_BOOT_CSEL_E_CSEL_0 | 0x0   | QSPI device clock is osc1_clk divided by 4,
+ * :                              |       | SD/MMC device clock is osc1_clk divided by 4,
+ * :                              |       | NAND device operation is osc1_clk divided by 25
+ *  ALT_SYSMGR_BOOT_CSEL_E_CSEL_1 | 0x1   | QSPI device clock is osc1_clk divided by 2,
+ * :                              |       | SD/MMC device clock is osc1_clk divided by 1,
+ * :                              |       | NAND device operation is osc1_clk multiplied by
+ * :                              |       | 20/25
+ *  ALT_SYSMGR_BOOT_CSEL_E_CSEL_2 | 0x2   | QSPI device clock is osc1_clk divided by 1,
+ * :                              |       | SD/MMC device clock is osc1_clk divided by 2,
+ * :                              |       | 10/25
+ *  ALT_SYSMGR_BOOT_CSEL_E_CSEL_3 | 0x3   | QSPI device clock is osc1_clk multiplied by 2,
+ * :                              |       | 5/25
+ * Enumerated value for register field ALT_SYSMGR_BOOT_CSEL
+ * QSPI device clock is osc1_clk divided by 4, SD/MMC device clock is osc1_clk
+ * divided by 4, NAND device operation is osc1_clk divided by 25
+#define ALT_SYSMGR_BOOT_CSEL_E_CSEL_0   0x0
+ * QSPI device clock is osc1_clk divided by 2, SD/MMC device clock is osc1_clk
+ * divided by 1, NAND device operation is osc1_clk multiplied by 20/25
+#define ALT_SYSMGR_BOOT_CSEL_E_CSEL_1   0x1
+ * QSPI device clock is osc1_clk divided by 1, SD/MMC device clock is osc1_clk
+ * divided by 2, NAND device operation is osc1_clk multiplied by 10/25
+#define ALT_SYSMGR_BOOT_CSEL_E_CSEL_2   0x2
+ * QSPI device clock is osc1_clk multiplied by 2, SD/MMC device clock is osc1_clk
+ * divided by 4, NAND device operation is osc1_clk multiplied by 5/25
+#define ALT_SYSMGR_BOOT_CSEL_E_CSEL_3   0x3
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_CSEL register field. */
+#define ALT_SYSMGR_BOOT_CSEL_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_CSEL register field. */
+#define ALT_SYSMGR_BOOT_CSEL_MSB        4
+/* The width in bits of the ALT_SYSMGR_BOOT_CSEL register field. */
+#define ALT_SYSMGR_BOOT_CSEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_BOOT_CSEL register field value. */
+#define ALT_SYSMGR_BOOT_CSEL_SET_MSK    0x00000018
+/* The mask used to clear the ALT_SYSMGR_BOOT_CSEL register field value. */
+#define ALT_SYSMGR_BOOT_CSEL_CLR_MSK    0xffffffe7
+/* The reset value of the ALT_SYSMGR_BOOT_CSEL register field is UNKNOWN. */
+#define ALT_SYSMGR_BOOT_CSEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_BOOT_CSEL field value from a register. */
+#define ALT_SYSMGR_BOOT_CSEL_GET(value) (((value) & 0x00000018) >> 3)
+/* Produces a ALT_SYSMGR_BOOT_CSEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_BOOT_CSEL_SET(value) (((value) << 3) & 0x00000018)
+ * Field : HPS Pin Boot Select - pinbsel
+ * Specifies the sampled value of the HPS BSEL pins. The value of HPS BSEL pins are
+ * sampled upon deassertion of cold reset.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_PINBSEL register field. */
+#define ALT_SYSMGR_BOOT_PINBSEL_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_PINBSEL register field. */
+#define ALT_SYSMGR_BOOT_PINBSEL_MSB        7
+/* The width in bits of the ALT_SYSMGR_BOOT_PINBSEL register field. */
+#define ALT_SYSMGR_BOOT_PINBSEL_WIDTH      3
+/* The mask used to set the ALT_SYSMGR_BOOT_PINBSEL register field value. */
+#define ALT_SYSMGR_BOOT_PINBSEL_SET_MSK    0x000000e0
+/* The mask used to clear the ALT_SYSMGR_BOOT_PINBSEL register field value. */
+#define ALT_SYSMGR_BOOT_PINBSEL_CLR_MSK    0xffffff1f
+/* The reset value of the ALT_SYSMGR_BOOT_PINBSEL register field is UNKNOWN. */
+#define ALT_SYSMGR_BOOT_PINBSEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_BOOT_PINBSEL field value from a register. */
+#define ALT_SYSMGR_BOOT_PINBSEL_GET(value) (((value) & 0x000000e0) >> 5)
+/* Produces a ALT_SYSMGR_BOOT_PINBSEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_BOOT_PINBSEL_SET(value) (((value) << 5) & 0x000000e0)
+ * Field : HPS Pin Clock Select - pincsel
+ * Specifies the sampled value of the HPS CSEL pins. The value of HPS CSEL pins are
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_BOOT_PINCSEL register field. */
+#define ALT_SYSMGR_BOOT_PINCSEL_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_BOOT_PINCSEL register field. */
+#define ALT_SYSMGR_BOOT_PINCSEL_MSB        9
+/* The width in bits of the ALT_SYSMGR_BOOT_PINCSEL register field. */
+#define ALT_SYSMGR_BOOT_PINCSEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_BOOT_PINCSEL register field value. */
+#define ALT_SYSMGR_BOOT_PINCSEL_SET_MSK    0x00000300
+/* The mask used to clear the ALT_SYSMGR_BOOT_PINCSEL register field value. */
+#define ALT_SYSMGR_BOOT_PINCSEL_CLR_MSK    0xfffffcff
+/* The reset value of the ALT_SYSMGR_BOOT_PINCSEL register field is UNKNOWN. */
+#define ALT_SYSMGR_BOOT_PINCSEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_BOOT_PINCSEL field value from a register. */
+#define ALT_SYSMGR_BOOT_PINCSEL_GET(value) (((value) & 0x00000300) >> 8)
+/* Produces a ALT_SYSMGR_BOOT_PINCSEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_BOOT_PINCSEL_SET(value) (((value) << 8) & 0x00000300)
+ * The struct declaration for register ALT_SYSMGR_BOOT.
+struct ALT_SYSMGR_BOOT_s
+    const uint32_t  bsel    :  3;  /* Boot Select */
+    const uint32_t  csel    :  2;  /* Clock Select */
+    const uint32_t  pinbsel :  3;  /* HPS Pin Boot Select */
+    const uint32_t  pincsel :  2;  /* HPS Pin Clock Select */
+    uint32_t                : 22;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_BOOT. */
+typedef volatile struct ALT_SYSMGR_BOOT_s  ALT_SYSMGR_BOOT_t;
+/* The byte offset of the ALT_SYSMGR_BOOT register from the beginning of the component. */
+#define ALT_SYSMGR_BOOT_OFST        0x14
+ * Register : HPS Info Register - hpsinfo
+ * Provides information about the HPS capabilities.
+ * Register Layout
+ *  [0]    | R      | Unknown | Dual Core
+ *  [1]    | R      | Unknown | CAN
+ *  [31:2] | ???    | 0x0     | *UNDEFINED*
+ * Field : Dual Core - dualcore
+ * Indicates if CPU1 is available in MPU or not.
+ *  ALT_SYSMGR_HPSINFO_DUALCORE_E_SINGLECORE | 0x0   | Not dual-core (only CPU0 available).
+ *  ALT_SYSMGR_HPSINFO_DUALCORE_E_DUALCORE   | 0x1   | Is dual-core (CPU0 and CPU1 both available).
+ * Enumerated value for register field ALT_SYSMGR_HPSINFO_DUALCORE
+ * Not dual-core (only CPU0 available).
+#define ALT_SYSMGR_HPSINFO_DUALCORE_E_SINGLECORE    0x0
+ * Is dual-core (CPU0 and CPU1 both available).
+#define ALT_SYSMGR_HPSINFO_DUALCORE_E_DUALCORE      0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_HPSINFO_DUALCORE register field. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_HPSINFO_DUALCORE register field. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_MSB        0
+/* The width in bits of the ALT_SYSMGR_HPSINFO_DUALCORE register field. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_HPSINFO_DUALCORE register field value. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_HPSINFO_DUALCORE register field value. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_HPSINFO_DUALCORE register field is UNKNOWN. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_RESET      0x0
+/* Extracts the ALT_SYSMGR_HPSINFO_DUALCORE field value from a register. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_HPSINFO_DUALCORE register field value suitable for setting the register. */
+#define ALT_SYSMGR_HPSINFO_DUALCORE_SET(value) (((value) << 0) & 0x00000001)
+ * Field : CAN - can
+ * Indicates if CAN0 and CAN1 controllers are available or not.
+ *  ALT_SYSMGR_HPSINFO_CAN_E_CAN_UNAVAILABLE | 0x0   | CAN0 and CAN1 are not available.
+ *  ALT_SYSMGR_HPSINFO_CAN_E_CAN_AVAILABLE   | 0x1   | CAN0 and CAN1 are available.
+ * Enumerated value for register field ALT_SYSMGR_HPSINFO_CAN
+ * CAN0 and CAN1 are not available.
+#define ALT_SYSMGR_HPSINFO_CAN_E_CAN_UNAVAILABLE    0x0
+ * CAN0 and CAN1 are available.
+#define ALT_SYSMGR_HPSINFO_CAN_E_CAN_AVAILABLE      0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_HPSINFO_CAN register field. */
+#define ALT_SYSMGR_HPSINFO_CAN_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_HPSINFO_CAN register field. */
+#define ALT_SYSMGR_HPSINFO_CAN_MSB        1
+/* The width in bits of the ALT_SYSMGR_HPSINFO_CAN register field. */
+#define ALT_SYSMGR_HPSINFO_CAN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_HPSINFO_CAN register field value. */
+#define ALT_SYSMGR_HPSINFO_CAN_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_HPSINFO_CAN register field value. */
+#define ALT_SYSMGR_HPSINFO_CAN_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_HPSINFO_CAN register field is UNKNOWN. */
+#define ALT_SYSMGR_HPSINFO_CAN_RESET      0x0
+/* Extracts the ALT_SYSMGR_HPSINFO_CAN field value from a register. */
+#define ALT_SYSMGR_HPSINFO_CAN_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_HPSINFO_CAN register field value suitable for setting the register. */
+#define ALT_SYSMGR_HPSINFO_CAN_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_SYSMGR_HPSINFO.
+struct ALT_SYSMGR_HPSINFO_s
+    const uint32_t  dualcore :  1;  /* Dual Core */
+    const uint32_t  can      :  1;  /* CAN */
+    uint32_t                 : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_HPSINFO. */
+typedef volatile struct ALT_SYSMGR_HPSINFO_s  ALT_SYSMGR_HPSINFO_t;
+/* The byte offset of the ALT_SYSMGR_HPSINFO register from the beginning of the component. */
+#define ALT_SYSMGR_HPSINFO_OFST        0x18
+ * Register : Parity Fail Injection Register - parityinj
+ * Inject parity failures into the parity-protected RAMs in the MPU. Allows
+ * software to test the parity failure interrupt handler. The field array index
+ * corresponds to the CPU index.
+ * All fields are reset by a cold or warm reset.
+ * Register Layout
+ *  [0]     | RW     | 0x0   | Parity Fail Injection for Data Cache Data RAM
+ *  [1]     | RW     | 0x0   | Parity Fail Injection for Data Cache Data RAM
+ *  [2]     | RW     | 0x0   | Parity Fail Injection for Data Cache Tag RAM
+ *  [3]     | RW     | 0x0   | Parity Fail Injection for Data Cache Tag RAM
+ *  [4]     | RW     | 0x0   | Parity Fail Injection for Data Cache Outer RAM
+ *  [5]     | RW     | 0x0   | Parity Fail Injection for Data Cache Outer RAM
+ *  [6]     | RW     | 0x0   | Parity Fail Injection for Main TLB RAM
+ *  [7]     | RW     | 0x0   | Parity Fail Injection for Main TLB RAM
+ *  [8]     | RW     | 0x0   | Parity Fail Injection for Instruction Cache Data RAM
+ *  [9]     | RW     | 0x0   | Parity Fail Injection for Instruction Cache Data RAM
+ *  [10]    | RW     | 0x0   | Parity Fail Injection for Instruction Cache Tag RAM
+ *  [11]    | RW     | 0x0   | Parity Fail Injection for Instruction Cache Tag RAM
+ *  [12]    | RW     | 0x0   | Parity Fail Injection for GHB RAM
+ *  [13]    | RW     | 0x0   | Parity Fail Injection for GHB RAM
+ *  [14]    | RW     | 0x0   | Parity Fail Injection for BTAC RAM
+ *  [15]    | RW     | 0x0   | Parity Fail Injection for BTAC RAM
+ *  [31:16] | ???    | 0x0   | *UNDEFINED*
+ * Field : Parity Fail Injection for Data Cache Data RAM - dcdata_0
+ * If 1, injecting parity error to Data Cache Data RAM.The field array index
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_MSB        0
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_PARITYINJ_DCDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_DCDATA_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_PARITYINJ_DCDATA_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Parity Fail Injection for Data Cache Data RAM - dcdata_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_MSB        1
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_PARITYINJ_DCDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_DCDATA_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_PARITYINJ_DCDATA_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_DCDATA_1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Parity Fail Injection for Data Cache Tag RAM - dctag_0
+ * If 1, injecting parity error to Data Cache Tag RAM.The field array index
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_MSB        2
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_PARITYINJ_DCTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_DCTAG_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_PARITYINJ_DCTAG_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_0_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Parity Fail Injection for Data Cache Tag RAM - dctag_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_MSB        3
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_PARITYINJ_DCTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_DCTAG_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_PARITYINJ_DCTAG_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_DCTAG_1_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Parity Fail Injection for Data Cache Outer RAM - dcouter_0
+ * If 1, injecting parity error to Data Cache Outer RAM.The field array index
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_MSB        4
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_DCOUTER_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_PARITYINJ_DCOUTER_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_0_SET(value) (((value) << 4) & 0x00000010)
+ * Field : Parity Fail Injection for Data Cache Outer RAM - dcouter_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_MSB        5
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_DCOUTER_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_PARITYINJ_DCOUTER_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_DCOUTER_1_SET(value) (((value) << 5) & 0x00000020)
+ * Field : Parity Fail Injection for Main TLB RAM - maintlb_0
+ * If 1, injecting parity error to Main TLB RAM.The field array index corresponds
+ * to the CPU index.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_MSB        6
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_MAINTLB_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_PARITYINJ_MAINTLB_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_0_SET(value) (((value) << 6) & 0x00000040)
+ * Field : Parity Fail Injection for Main TLB RAM - maintlb_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_MSB        7
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_MAINTLB_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_PARITYINJ_MAINTLB_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_MAINTLB_1_SET(value) (((value) << 7) & 0x00000080)
+ * Field : Parity Fail Injection for Instruction Cache Data RAM - icdata_0
+ * If 1, injecting parity error to Instruction Cache Data RAM.The field array index
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_MSB        8
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_SET_MSK    0x00000100
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_ICDATA_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_ICDATA_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_SYSMGR_PARITYINJ_ICDATA_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_0_SET(value) (((value) << 8) & 0x00000100)
+ * Field : Parity Fail Injection for Instruction Cache Data RAM - icdata_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_MSB        9
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_SET_MSK    0x00000200
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_ICDATA_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_ICDATA_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_SYSMGR_PARITYINJ_ICDATA_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_ICDATA_1_SET(value) (((value) << 9) & 0x00000200)
+ * Field : Parity Fail Injection for Instruction Cache Tag RAM - ictag_0
+ * If 1, injecting parity error to Instruction Cache Tag RAM.The field array index
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_MSB        10
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_SET_MSK    0x00000400
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_ICTAG_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_ICTAG_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_SYSMGR_PARITYINJ_ICTAG_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_0_SET(value) (((value) << 10) & 0x00000400)
+ * Field : Parity Fail Injection for Instruction Cache Tag RAM - ictag_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_LSB        11
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_MSB        11
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_SET_MSK    0x00000800
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_CLR_MSK    0xfffff7ff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_ICTAG_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_ICTAG_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_GET(value) (((value) & 0x00000800) >> 11)
+/* Produces a ALT_SYSMGR_PARITYINJ_ICTAG_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_ICTAG_1_SET(value) (((value) << 11) & 0x00000800)
+ * Field : Parity Fail Injection for GHB RAM - ghb_0
+ * If 1, injecting parity error to GHB RAM.The field array index corresponds to the
+ * CPU index.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_MSB        12
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_GHB_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_SET_MSK    0x00001000
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_GHB_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_CLR_MSK    0xffffefff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_GHB_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_GHB_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_SYSMGR_PARITYINJ_GHB_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_GHB_0_SET(value) (((value) << 12) & 0x00001000)
+ * Field : Parity Fail Injection for GHB RAM - ghb_1
+ * CPU index.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_LSB        13
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_MSB        13
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_GHB_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_SET_MSK    0x00002000
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_GHB_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_CLR_MSK    0xffffdfff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_GHB_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_GHB_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_GET(value) (((value) & 0x00002000) >> 13)
+/* Produces a ALT_SYSMGR_PARITYINJ_GHB_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_GHB_1_SET(value) (((value) << 13) & 0x00002000)
+ * Field : Parity Fail Injection for BTAC RAM - btac_0
+ * If 1, injecting parity error to BTAC RAM.The field array index corresponds to
+ * the CPU index.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_LSB        14
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_MSB        14
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_BTAC_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_SET_MSK    0x00004000
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_BTAC_0 register field value. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_CLR_MSK    0xffffbfff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_BTAC_0 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_BTAC_0 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_GET(value) (((value) & 0x00004000) >> 14)
+/* Produces a ALT_SYSMGR_PARITYINJ_BTAC_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_0_SET(value) (((value) << 14) & 0x00004000)
+ * Field : Parity Fail Injection for BTAC RAM - btac_1
+ * the CPU index.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_LSB        15
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_MSB        15
+/* The width in bits of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_PARITYINJ_BTAC_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_SET_MSK    0x00008000
+/* The mask used to clear the ALT_SYSMGR_PARITYINJ_BTAC_1 register field value. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_CLR_MSK    0xffff7fff
+/* The reset value of the ALT_SYSMGR_PARITYINJ_BTAC_1 register field. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_PARITYINJ_BTAC_1 field value from a register. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_GET(value) (((value) & 0x00008000) >> 15)
+/* Produces a ALT_SYSMGR_PARITYINJ_BTAC_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_PARITYINJ_BTAC_1_SET(value) (((value) << 15) & 0x00008000)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SYSMGR_PARITYINJ.
+struct ALT_SYSMGR_PARITYINJ_s
+    uint32_t  dcdata_0  :  1;  /* Parity Fail Injection for Data Cache Data RAM */
+    uint32_t  dcdata_1  :  1;  /* Parity Fail Injection for Data Cache Data RAM */
+    uint32_t  dctag_0   :  1;  /* Parity Fail Injection for Data Cache Tag RAM */
+    uint32_t  dctag_1   :  1;  /* Parity Fail Injection for Data Cache Tag RAM */
+    uint32_t  dcouter_0 :  1;  /* Parity Fail Injection for Data Cache Outer RAM */
+    uint32_t  dcouter_1 :  1;  /* Parity Fail Injection for Data Cache Outer RAM */
+    uint32_t  maintlb_0 :  1;  /* Parity Fail Injection for Main TLB RAM */
+    uint32_t  maintlb_1 :  1;  /* Parity Fail Injection for Main TLB RAM */
+    uint32_t  icdata_0  :  1;  /* Parity Fail Injection for Instruction Cache Data RAM */
+    uint32_t  icdata_1  :  1;  /* Parity Fail Injection for Instruction Cache Data RAM */
+    uint32_t  ictag_0   :  1;  /* Parity Fail Injection for Instruction Cache Tag RAM */
+    uint32_t  ictag_1   :  1;  /* Parity Fail Injection for Instruction Cache Tag RAM */
+    uint32_t  ghb_0     :  1;  /* Parity Fail Injection for GHB RAM */
+    uint32_t  ghb_1     :  1;  /* Parity Fail Injection for GHB RAM */
+    uint32_t  btac_0    :  1;  /* Parity Fail Injection for BTAC RAM */
+    uint32_t  btac_1    :  1;  /* Parity Fail Injection for BTAC RAM */
+    uint32_t            : 16;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_PARITYINJ. */
+typedef volatile struct ALT_SYSMGR_PARITYINJ_s  ALT_SYSMGR_PARITYINJ_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SYSMGR_PARITYINJ register from the beginning of the component. */
+#define ALT_SYSMGR_PARITYINJ_OFST        0x1c
+ * Register Group : FPGA Interface Group - ALT_SYSMGR_FPGAINTF
+ * FPGA Interface Group
+ * Registers used to enable/disable interfaces between the FPGA and HPS. Required
+ * for either of the following situations:[list][*]Interfaces that cannot be
+ * disabled by putting an HPS module associated with the interface into
+ * reset.[*]HPS modules that accept signals from the FPGA fabric and those signals
+ * might interfere with the normal operation of the module.[/list].
+ * All registers are only reset by a cold reset (ignore warm reset).
+ * Register : Global Disable Register - gbl
+ * Used to disable all interfaces between the FPGA and HPS.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [0]    | RW     | 0x1   | Global Interface
+ *  [31:1] | ???    | 0x0   | *UNDEFINED*
+ * Field : Global Interface - intf
+ * Used to disable all interfaces between the FPGA and HPS. Software must ensure
+ * that all interfaces between the FPGA and HPS are inactive before disabling them.
+ *  ALT_SYSMGR_FPGAINTF_GBL_INTF_E_DIS | 0x0   | All interfaces between FPGA and HPS are
+ * :                                   |       | disabled.
+ *  ALT_SYSMGR_FPGAINTF_GBL_INTF_E_EN  | 0x1   | Interfaces between FPGA and HPS are not all
+ * :                                   |       | disabled. Interfaces can be indivdually disabled
+ * :                                   |       | by putting the HPS module associated with the
+ * :                                   |       | interface in reset using registers in the Reset
+ * :                                   |       | Manager or by using registers in this register
+ * :                                   |       | group of the System Manager for interfaces
+ * :                                   |       | without an associated module.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_GBL_INTF
+ * All interfaces between FPGA and HPS are disabled.
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_E_DIS  0x0
+ * Interfaces between FPGA and HPS are not all disabled. Interfaces can be
+ * indivdually disabled by putting the HPS module associated with the interface in
+ * reset using registers in the Reset Manager or by using registers in this
+ * register group of the System Manager for interfaces without an associated
+ * module.
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_E_EN   0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_MSB        0
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_GBL_INTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_GBL_INTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_FPGAINTF_GBL_INTF register field. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_GBL_INTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_FPGAINTF_GBL_INTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_GBL_INTF_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_SYSMGR_FPGAINTF_GBL.
+struct ALT_SYSMGR_FPGAINTF_GBL_s
+    uint32_t  intf :  1;  /* Global Interface */
+    uint32_t       : 31;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_FPGAINTF_GBL. */
+typedef volatile struct ALT_SYSMGR_FPGAINTF_GBL_s  ALT_SYSMGR_FPGAINTF_GBL_t;
+/* The byte offset of the ALT_SYSMGR_FPGAINTF_GBL register from the beginning of the component. */
+#define ALT_SYSMGR_FPGAINTF_GBL_OFST        0x0
+ * Register : Individual Disable Register - indiv
+ * Used to disable individual interfaces between the FPGA and HPS.
+ * Register Layout
+ *  [0]    | RW     | 0x1   | Reset Request Interface
+ *  [1]    | RW     | 0x1   | JTAG Enable Interface
+ *  [2]    | RW     | 0x1   | CONFIG_IO Interface
+ *  [3]    | RW     | 0x1   | Boundary-Scan Interface
+ *  [4]    | RW     | 0x1   | Trace Interface
+ *  [5]    | ???    | 0x1   | *UNDEFINED*
+ *  [6]    | RW     | 0x1   | STM Event Interface
+ *  [7]    | RW     | 0x1   | Cross Trigger Interface (CTI)
+ *  [31:8] | ???    | 0x0   | *UNDEFINED*
+ * Field : Reset Request Interface - rstreqintf
+ * Used to disable the reset request interface. This interface allows logic in the
+ * FPGA fabric to request HPS resets. This field disables the following reset
+ * request signals from the FPGA fabric to HPS:[list][*]f2h_cold_rst_req_n -
+ * Triggers a cold reset of the HPS[*]f2h_warm_rst_req_n - Triggers a warm reset of
+ * the HPS[*]f2h_dbg_rst_req_n - Triggers a debug reset of the HPS[/list]
+ *  ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_DIS | 0x0   | Reset request interface is disabled. Logic in
+ * :                                           |       | the FPGA fabric cannot reset the HPS.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_EN  | 0x1   | Reset request interface is enabled. Logic in the
+ * :                                           |       | FPGA fabric can reset the HPS.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF
+ * Reset request interface is disabled. Logic in the FPGA fabric cannot reset the
+ * HPS.
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_DIS  0x0
+ * Reset request interface is enabled. Logic in the FPGA fabric can reset the HPS.
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_E_EN   0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_MSB        0
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_RSTREQINTF_SET(value) (((value) << 0) & 0x00000001)
+ * Field : JTAG Enable Interface - jtagenintf
+ * Used to disable the JTAG enable interface. This interface allows logic in the
+ * FPGA fabric to disable the HPS JTAG operation.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_DIS | 0x0   | JTAG enable interface is disabled. Logic in the
+ * :                                           |       | FPGA fabric cannot disable the HPS JTAG.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_EN  | 0x1   | JTAG enable interface is enabled. Logic in the
+ * :                                           |       | FPGA fabric can disable the HPS JTAG.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF
+ * JTAG enable interface is disabled. Logic in the FPGA fabric cannot disable the
+ * HPS JTAG.
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_DIS  0x0
+ * JTAG enable interface is enabled. Logic in the FPGA fabric can disable the HPS
+ * JTAG.
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_E_EN   0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_MSB        1
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_JTAGENINTF_SET(value) (((value) << 1) & 0x00000002)
+ * Field : CONFIG_IO Interface - configiointf
+ * Used to disable the CONFIG_IO interface. This interface allows the FPGA JTAG TAP
+ * controller to execute the CONFIG_IO instruction and configure all device I/Os
+ * (FPGA and HPS). This is typically done before executing boundary-scan
+ * instructions. The CONFIG_IO interface must be enabled before attempting to send
+ * the CONFIG_IO instruction to the FPGA JTAG TAP controller.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_DIS | 0x0   | CONFIG_IO interface is disabled. Execution of
+ * :                                          |       | the CONFIG_IO instruction in the FPGA JTAG TAP
+ * :                                          |       | controller is unsupported and produces undefined
+ * :                                          |       | results.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_EN  | 0x1   | CONFIG_IO interface is enabled. Execution of the
+ * :                                          |       | CONFIG_IO instruction in the FPGA JTAG TAP
+ * :                                          |       | controller is supported.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF
+ * CONFIG_IO interface is disabled. Execution of the CONFIG_IO instruction in the
+ * FPGA JTAG TAP controller is unsupported and produces undefined results.
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_DIS   0x0
+ * CONFIG_IO interface is enabled. Execution of the CONFIG_IO instruction in the
+ * FPGA JTAG TAP controller is supported.
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_MSB        2
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CFGIOINTF_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Boundary-Scan Interface - bscanintf
+ * Used to disable the boundary-scan interface. This interface allows the FPGA JTAG
+ * TAP controller to execute boundary-scan instructions such as SAMPLE/PRELOAD,
+ * EXTEST, and HIGHZ. The boundary-scan interface must be enabled before attempting
+ * to send the boundary-scan instructions to the FPGA JTAG TAP controller.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_DIS | 0x0   | Boundary-scan interface is disabled. Execution
+ * :                                          |       | of boundary-scan instructions in the FPGA JTAG
+ * :                                          |       | TAP controller is unsupported and produces
+ * :                                          |       | undefined results.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_EN  | 0x1   | Boundary-scan interface is enabled. Execution of
+ * :                                          |       | the boundary-scan instructions in the FPGA JTAG
+ * :                                          |       | TAP controller is supported.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF
+ * Boundary-scan interface is disabled. Execution of boundary-scan instructions in
+ * the FPGA JTAG TAP controller is unsupported and produces undefined results.
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_DIS   0x0
+ * Boundary-scan interface is enabled. Execution of the boundary-scan instructions
+ * in the FPGA JTAG TAP controller is supported.
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_MSB        3
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_BSCANINTF_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Trace Interface - traceintf
+ * Used to disable the trace interface. This interface allows the HPS debug logic
+ * to send trace data to logic in the FPGA fabric.
+ * Field Enumeration Values:
+ *  Enum                                      | Value | Description
+ *  ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_DIS | 0x0   | Trace interface is disabled.  HPS debug logic
+ * :                                          |       | cannot send trace data to the FPGA fabric.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_EN  | 0x1   | Trace interface is enabled. Other registers in
+ * :                                          |       | the HPS debug logic must be programmmed to
+ * :                                          |       | actually send trace data to the FPGA fabric.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF
+ * Trace interface is disabled.  HPS debug logic cannot send trace data to the FPGA
+ * fabric.
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_DIS   0x0
+ * Trace interface is enabled. Other registers in the HPS debug logic must be
+ * programmmed to actually send trace data to the FPGA fabric.
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_MSB        4
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_TRACEINTF_SET(value) (((value) << 4) & 0x00000010)
+ * Field : STM Event Interface - stmeventintf
+ * Used to disable the STM event interface. This interface allows logic in the FPGA
+ * fabric to trigger events to the STM debug module in the HPS.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_DIS | 0x0   | STM event interface is disabled.  Logic in the
+ * :                                             |       | FPGA fabric cannot trigger STM events.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_EN  | 0x1   | STM event interface is enabled.  Logic in the
+ * :                                             |       | FPGA fabric can trigger STM events.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF
+ * STM event interface is disabled.  Logic in the FPGA fabric cannot trigger STM
+ * events.
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_DIS    0x0
+ * STM event interface is enabled.  Logic in the FPGA fabric can trigger STM
+ * events.
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_E_EN     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_MSB        6
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_STMEVENTINTF_SET(value) (((value) << 6) & 0x00000040)
+ * Field : Cross Trigger Interface (CTI) - crosstrigintf
+ * Used to disable the FPGA Fabric from sending triggers to HPS debug logic.  Note
+ * that this doesn't prevent the HPS debug logic from sending triggers to the FPGA
+ * Fabric.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_DIS | 0x0   | FPGA Fabric cannot send triggers.
+ *  ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_EN  | 0x1   | FPGA Fabric can send triggers.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF
+ * FPGA Fabric cannot send triggers.
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_DIS   0x0
+ * FPGA Fabric can send triggers.
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_MSB        7
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field value. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_RESET      0x1
+/* Extracts the ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_CROSSTRIGINTF_SET(value) (((value) << 7) & 0x00000080)
+ * The struct declaration for register ALT_SYSMGR_FPGAINTF_INDIV.
+struct ALT_SYSMGR_FPGAINTF_INDIV_s
+    uint32_t  rstreqintf    :  1;  /* Reset Request Interface */
+    uint32_t  jtagenintf    :  1;  /* JTAG Enable Interface */
+    uint32_t  configiointf  :  1;  /* CONFIG_IO Interface */
+    uint32_t  bscanintf     :  1;  /* Boundary-Scan Interface */
+    uint32_t  traceintf     :  1;  /* Trace Interface */
+    uint32_t                :  1;  /* *UNDEFINED* */
+    uint32_t  stmeventintf  :  1;  /* STM Event Interface */
+    uint32_t  crosstrigintf :  1;  /* Cross Trigger Interface (CTI) */
+    uint32_t                : 24;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_FPGAINTF_INDIV. */
+typedef volatile struct ALT_SYSMGR_FPGAINTF_INDIV_s  ALT_SYSMGR_FPGAINTF_INDIV_t;
+/* The byte offset of the ALT_SYSMGR_FPGAINTF_INDIV register from the beginning of the component. */
+#define ALT_SYSMGR_FPGAINTF_INDIV_OFST        0x4
+ * Register : Module Disable Register - module
+ * Used to disable signals from the FPGA fabric to individual HPS modules.
+ * Register Layout
+ *  [1:0]  | ???    | 0x0   | *UNDEFINED*
+ *  [2]    | RW     | 0x0   | EMAC Module
+ *  [3]    | RW     | 0x0   | EMAC Module
+ *  [31:4] | ???    | 0x0   | *UNDEFINED*
+ * Field : EMAC Module - emac_0
+ * Used to disable signals from the FPGA fabric to the EMAC modules that could
+ * potentially interfere with their normal operation.
+ * The array index corresponds to the EMAC module instance.
+ *  ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_DIS | 0x0   | Signals from FPGA fabric cannot affect operation
+ * :                                        |       | of the EMAC module.
+ *  ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_EN  | 0x1   | Signals from FPGA fabric can potentially affect
+ * :                                        |       | operation of the EMAC module.
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0
+ * Signals from FPGA fabric cannot affect operation of the EMAC module.
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_DIS 0x0
+ * Signals from FPGA fabric can potentially affect operation of the EMAC module.
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_E_EN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_MSB        2
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field value. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field value. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_0_SET(value) (((value) << 2) & 0x00000004)
+ * Field : EMAC Module - emac_1
+ *  ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_DIS | 0x0   | Signals from FPGA fabric cannot affect operation
+ *  ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_EN  | 0x1   | Signals from FPGA fabric can potentially affect
+ * Enumerated value for register field ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_DIS 0x0
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_E_EN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_MSB        3
+/* The width in bits of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field value. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field value. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 field value from a register. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_EMAC_1_SET(value) (((value) << 3) & 0x00000008)
+ * The struct declaration for register ALT_SYSMGR_FPGAINTF_MODULE.
+struct ALT_SYSMGR_FPGAINTF_MODULE_s
+    uint32_t         :  2;  /* *UNDEFINED* */
+    uint32_t  emac_0 :  1;  /* EMAC Module */
+    uint32_t  emac_1 :  1;  /* EMAC Module */
+    uint32_t         : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_FPGAINTF_MODULE. */
+typedef volatile struct ALT_SYSMGR_FPGAINTF_MODULE_s  ALT_SYSMGR_FPGAINTF_MODULE_t;
+/* The byte offset of the ALT_SYSMGR_FPGAINTF_MODULE register from the beginning of the component. */
+#define ALT_SYSMGR_FPGAINTF_MODULE_OFST        0x8
+ * The struct declaration for register group ALT_SYSMGR_FPGAINTF.
+struct ALT_SYSMGR_FPGAINTF_s
+    volatile ALT_SYSMGR_FPGAINTF_GBL_t     gbl;            /* ALT_SYSMGR_FPGAINTF_GBL */
+    volatile ALT_SYSMGR_FPGAINTF_INDIV_t   indiv;          /* ALT_SYSMGR_FPGAINTF_INDIV */
+    volatile ALT_SYSMGR_FPGAINTF_MODULE_t  module;         /* ALT_SYSMGR_FPGAINTF_MODULE */
+    volatile uint32_t                      _pad_0xc_0x10;  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_SYSMGR_FPGAINTF. */
+typedef volatile struct ALT_SYSMGR_FPGAINTF_s  ALT_SYSMGR_FPGAINTF_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_FPGAINTF. */
+struct ALT_SYSMGR_FPGAINTF_raw_s
+    volatile uint32_t  gbl;            /* ALT_SYSMGR_FPGAINTF_GBL */
+    volatile uint32_t  indiv;          /* ALT_SYSMGR_FPGAINTF_INDIV */
+    volatile uint32_t  module;         /* ALT_SYSMGR_FPGAINTF_MODULE */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_FPGAINTF. */
+typedef volatile struct ALT_SYSMGR_FPGAINTF_raw_s  ALT_SYSMGR_FPGAINTF_raw_t;
+ * Register Group : Scan Manager Group - ALT_SYSMGR_SCANMGR
+ * Scan Manager Group
+ * Registers related to the Scan Manager that aren't located inside the Scan
+ * Manager itself.
+ * Register : Scan Manager Control Register - ctrl
+ * Controls behaviors of Scan Manager not controlled by registers in the Scan
+ * Manager itself.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | FPGA JTAG Enable
+ * Field : FPGA JTAG Enable - fpgajtagen
+ * Controls whether FPGA JTAG pins or Scan Manager drives JTAG signals to the FPGA.
+ * Only reset by a cold reset (ignores warm reset).
+ *  ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_FPGAPINS | 0x0   | FPGA JTAG pins drive JTAG signals to FPGA
+ *  ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_SCANMGR  | 0x1   | Scan Manager drives JTAG signals to FPGA
+ * Enumerated value for register field ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN
+ * FPGA JTAG pins drive JTAG signals to FPGA
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_FPGAPINS    0x0
+ * Scan Manager drives JTAG signals to FPGA
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_E_SCANMGR     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_MSB        0
+/* The width in bits of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field value. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field value. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_RESET      0x0
+/* Extracts the ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN field value from a register. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN register field value suitable for setting the register. */
+#define ALT_SYSMGR_SCANMGR_CTL_FPGAJTAGEN_SET(value) (((value) << 0) & 0x00000001)
+ * The struct declaration for register ALT_SYSMGR_SCANMGR_CTL.
+struct ALT_SYSMGR_SCANMGR_CTL_s
+    uint32_t  fpgajtagen :  1;  /* FPGA JTAG Enable */
+/* The typedef declaration for register ALT_SYSMGR_SCANMGR_CTL. */
+typedef volatile struct ALT_SYSMGR_SCANMGR_CTL_s  ALT_SYSMGR_SCANMGR_CTL_t;
+/* The byte offset of the ALT_SYSMGR_SCANMGR_CTL register from the beginning of the component. */
+#define ALT_SYSMGR_SCANMGR_CTL_OFST        0x0
+ * The struct declaration for register group ALT_SYSMGR_SCANMGR.
+struct ALT_SYSMGR_SCANMGR_s
+    volatile ALT_SYSMGR_SCANMGR_CTL_t  ctrl;  /* ALT_SYSMGR_SCANMGR_CTL */
+/* The typedef declaration for register group ALT_SYSMGR_SCANMGR. */
+typedef volatile struct ALT_SYSMGR_SCANMGR_s  ALT_SYSMGR_SCANMGR_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_SCANMGR. */
+struct ALT_SYSMGR_SCANMGR_raw_s
+    volatile uint32_t  ctrl;  /* ALT_SYSMGR_SCANMGR_CTL */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_SCANMGR. */
+typedef volatile struct ALT_SYSMGR_SCANMGR_raw_s  ALT_SYSMGR_SCANMGR_raw_t;
+ * Register Group : Freeze Control Group - ALT_SYSMGR_FRZCTL
+ * Freeze Control Group
+ * Registers used to generate HPS IO freeze signals.
+ * Register : VIO Control Register - vioctrl
+ * Used to drive freeze signals to HPS VIO banks.
+ * The register array index corresponds to the freeze channel.
+ * Freeze channel 0 provides freeze signals to VIO bank 0 and 1.
+ * Freeze channel 1 provides freeze signals to VIO bank 2 and 3. Only drives freeze
+ * signals when SRC.VIO1 is set to SW.
+ * Freeze channel 2 provides freeze signals to VIO bank 4.
+ * All fields are only reset by a cold reset (ignore warm reset).
+ * The following equation determines when the weak pullup resistor is enabled:
+ * enabled = ~wkpullup | (CFF & cfg & tristate)
+ * where CFF is the value of weak pullup as set by IO configuration
+ * Register Layout
+ *  [0]    | RW     | 0x0   | IO Configuration
+ *  [1]    | RW     | 0x0   | IO Bus Hold
+ *  [2]    | RW     | 0x0   | IO Tri-State
+ *  [3]    | RW     | 0x0   | IO Weak Pullup
+ *  [4]    | RW     | 0x0   | IO Slew-rate
+ *  [31:5] | ???    | 0x0   | *UNDEFINED*
+ * Field : IO Configuration - cfg
+ * Controls IO configuration
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_DIS | 0x0   | Disable IO configuration (forced to a safe
+ * :                                   |       | value).
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_CFG | 0x1   | Enables IO configuration as previously
+ * :                                   |       | configured by software using the Scan Manager.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_CFG
+ * Disable IO configuration (forced to a safe value).
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_DIS  0x0
+ * Enables IO configuration as previously configured by software using the Scan
+ * Manager.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_E_CFG  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_MSB        0
+/* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_CFG field value from a register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_CFG register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_CFG_SET(value) (((value) << 0) & 0x00000001)
+ * Field : IO Bus Hold - bushold
+ * Controls bus hold circuit
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_DIS | 0x0   | Disable bus hold circuit.
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_CFG | 0x1   | Bus hold circuit controlled by IO configuration.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD
+ * Disable bus hold circuit.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_DIS  0x0
+ * Bus hold circuit controlled by IO configuration.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_E_CFG  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_MSB        1
+/* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD field value from a register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_BUSHOLD_SET(value) (((value) << 1) & 0x00000002)
+ * Field : IO Tri-State - tristate
+ * Controls IO tri-state
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_EN  | 0x0   | IO tri-state enabled.
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_CFG | 0x1   | IO tri-state controlled by IO configuration.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE
+ * IO tri-state enabled.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_EN  0x0
+ * IO tri-state controlled by IO configuration.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_E_CFG 0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_MSB        2
+/* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE field value from a register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_TRISTATE_SET(value) (((value) << 2) & 0x00000004)
+ * Field : IO Weak Pullup - wkpullup
+ * Controls weak pullup resistor
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_EN  | 0x0   | Weak pullup resistor enabled.
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_CFG | 0x1   | Weak pullup resistor enable controlled by IO
+ * :                                        |       | configuration.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP
+ * Weak pullup resistor enabled.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_EN  0x0
+ * Weak pullup resistor enable controlled by IO configuration.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_E_CFG 0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_MSB        3
+/* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP field value from a register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_WKPULLUP_SET(value) (((value) << 3) & 0x00000008)
+ * Field : IO Slew-rate - slew
+ * Controls IO slew-rate
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_SLOW | 0x0   | Slew-rate forced to slow.
+ *  ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_CFG  | 0x1   | Slew-rate controlled by IO configuration.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_VIOCTL_SLEW
+ * Slew-rate forced to slow.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_SLOW    0x0
+ * Slew-rate controlled by IO configuration.
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_E_CFG     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_MSB        4
+/* The width in bits of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field value. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_VIOCTL_SLEW field value from a register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_FRZCTL_VIOCTL_SLEW register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_SLEW_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_FRZCTL_VIOCTL.
+struct ALT_SYSMGR_FRZCTL_VIOCTL_s
+    uint32_t  cfg      :  1;  /* IO Configuration */
+    uint32_t  bushold  :  1;  /* IO Bus Hold */
+    uint32_t  tristate :  1;  /* IO Tri-State */
+    uint32_t  wkpullup :  1;  /* IO Weak Pullup */
+    uint32_t  slew     :  1;  /* IO Slew-rate */
+    uint32_t           : 27;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_FRZCTL_VIOCTL. */
+typedef volatile struct ALT_SYSMGR_FRZCTL_VIOCTL_s  ALT_SYSMGR_FRZCTL_VIOCTL_t;
+/* The byte offset of the ALT_SYSMGR_FRZCTL_VIOCTL register from the beginning of the component. */
+#define ALT_SYSMGR_FRZCTL_VIOCTL_OFST        0x0
+ * Register : HIO Control Register - hioctrl
+ * Used to drive freeze signals to HPS HIO bank (DDR SDRAM).
+ * Register Layout
+ *  [5]    | RW     | 0x1   | DLL Reset
+ *  [6]    | RW     | 0x1   | OCT Reset
+ *  [7]    | RW     | 0x1   | IO and DQS Reset
+ *  [8]    | RW     | 0x0   | OCT Calibration and Configuration Enable
+ *  [31:9] | ???    | 0x0   | *UNDEFINED*
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_DIS | 0x0   | Disable IO configuration (forced to a safe
+ * :                                   |       | value).
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_CFG | 0x1   | Enables IO configuration as previously
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_CFG
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_DIS  0x0
+ * Manager.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_E_CFG  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_MSB        0
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_CFG field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_CFG register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_CFG_SET(value) (((value) << 0) & 0x00000001)
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_DIS | 0x0   | Disable bus hold circuit.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_CFG | 0x1   | Bus hold circuit controlled by IO configuration.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_DIS  0x0
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_E_CFG  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_MSB        1
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_BUSHOLD_SET(value) (((value) << 1) & 0x00000002)
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_EN  | 0x0   | IO tri-state enabled.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_CFG | 0x1   | IO tri-state controlled by IO configuration.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_EN  0x0
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_E_CFG 0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_MSB        2
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_TRISTATE_SET(value) (((value) << 2) & 0x00000004)
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_EN  | 0x0   | Weak pullup resistor enabled.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_CFG | 0x1   | Weak pullup resistor enable controlled by IO
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_EN  0x0
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_E_CFG 0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_MSB        3
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_WKPULLUP_SET(value) (((value) << 3) & 0x00000008)
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_SLOW | 0x0   | Slew-rate forced to slow.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_CFG  | 0x1   | Slew-rate controlled by IO configuration.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_SLEW
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_SLOW    0x0
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_E_CFG     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_MSB        4
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_SLEW field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_SLEW register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_SLEW_SET(value) (((value) << 4) & 0x00000010)
+ * Field : DLL Reset - dllrst
+ * Controls DLL (Delay-Locked Loop) reset.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_DIS | 0x0   | No reset or clock gating.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_EN  | 0x1   | Resets registers in the DLL and gates off DLL
+ * :                                      |       | clock.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST
+ * No reset or clock gating.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_DIS   0x0
+ * Resets registers in the DLL and gates off DLL clock.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_MSB        5
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_RESET      0x1
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_DLLRST_SET(value) (((value) << 5) & 0x00000020)
+ * Field : OCT Reset - octrst
+ * Controls OCT reset.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_DIS | 0x0   | No reset.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_EN  | 0x1   | Resets registers in the OCT.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST
+ * No reset.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_DIS   0x0
+ * Resets registers in the OCT.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_MSB        6
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_RESET      0x1
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCTRST_SET(value) (((value) << 6) & 0x00000040)
+ * Field : IO and DQS Reset - regrst
+ * Controls IO and DQS reset.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_DIS | 0x0   | No reset.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_EN  | 0x1   | Resets all IO registers and DQS registers.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_REGRST
+ * No reset.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_DIS   0x0
+ * Resets all IO registers and DQS registers.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_MSB        7
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_RESET      0x1
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_REGRST field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_REGRST register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_REGRST_SET(value) (((value) << 7) & 0x00000080)
+ * Field : OCT Calibration and Configuration Enable - oct_cfgen_calstart
+ * Controls OCT calibration and OCT IO configuration enable.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_DIS | 0x0   | Disables IO configuration (forced to a safe
+ * :                                                  |       | value) in OCT calibration block.
+ *  ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_EN  | 0x1   | Starts OCT calibration state machine and enables
+ * :                                                  |       | IO configuration in OCT calibration block.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART
+ * Disables IO configuration (forced to a safe value) in OCT calibration block.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_DIS   0x0
+ * Starts OCT calibration state machine and enables IO configuration in OCT
+ * calibration block.
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_E_EN    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_MSB        8
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_SET_MSK    0x00000100
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field value. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OCT_CFGEN_CALSTART_SET(value) (((value) << 8) & 0x00000100)
+ * The struct declaration for register ALT_SYSMGR_FRZCTL_HIOCTL.
+struct ALT_SYSMGR_FRZCTL_HIOCTL_s
+    uint32_t  dllrst             :  1;  /* DLL Reset */
+    uint32_t  octrst             :  1;  /* OCT Reset */
+    uint32_t  regrst             :  1;  /* IO and DQS Reset */
+    uint32_t  oct_cfgen_calstart :  1;  /* OCT Calibration and Configuration Enable */
+    uint32_t                     : 23;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_FRZCTL_HIOCTL. */
+typedef volatile struct ALT_SYSMGR_FRZCTL_HIOCTL_s  ALT_SYSMGR_FRZCTL_HIOCTL_t;
+/* The byte offset of the ALT_SYSMGR_FRZCTL_HIOCTL register from the beginning of the component. */
+#define ALT_SYSMGR_FRZCTL_HIOCTL_OFST        0x10
+ * Register : Source Register - src
+ * Contains register field to choose between software state machine (vioctrl array
+ * index [1] register) or hardware state machine in the Freeze Controller as the
+ * freeze signal source for VIO channel 1.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | VIO1 Freeze Signal Source
+ * Field : VIO1 Freeze Signal Source - vio1
+ * The freeze signal source for VIO channel 1 (VIO bank 2 and bank 3).
+ *  ALT_SYSMGR_FRZCTL_SRC_VIO1_E_SW | 0x0   | VIO1 freeze signals are driven by software
+ * :                                |       | writing to the VIOCTRL[1] register. The
+ * :                                |       | VIO1-related fields in the hwctrl register are
+ * :                                |       | active but don't effect the VIO1 freeze signals.
+ *  ALT_SYSMGR_FRZCTL_SRC_VIO1_E_HW | 0x1   | VIO1 freeze signals are driven by the hardware
+ * :                                |       | state machine in the Freeze Controller. The
+ * :                                |       | active and effect the VIO1 freeze signals.
+ * Field Access Macros:
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_SRC_VIO1
+ * VIO1 freeze signals are driven by software writing to the VIOCTRL[1] register.
+ * The VIO1-related fields in the hwctrl register are active but don't effect the
+ * VIO1 freeze signals.
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_E_SW 0x0
+ * VIO1 freeze signals are driven by the hardware state machine in the Freeze
+ * Controller. The VIO1-related fields in the hwctrl register are active and effect
+ * the VIO1 freeze signals.
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_E_HW 0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_MSB        0
+/* The width in bits of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field value. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field value. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_FRZCTL_SRC_VIO1 register field. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_RESET      0x0
+/* Extracts the ALT_SYSMGR_FRZCTL_SRC_VIO1 field value from a register. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_FRZCTL_SRC_VIO1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_SRC_VIO1_SET(value) (((value) << 0) & 0x00000001)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SYSMGR_FRZCTL_SRC.
+struct ALT_SYSMGR_FRZCTL_SRC_s
+    uint32_t  vio1 :  1;  /* VIO1 Freeze Signal Source */
+/* The typedef declaration for register ALT_SYSMGR_FRZCTL_SRC. */
+typedef volatile struct ALT_SYSMGR_FRZCTL_SRC_s  ALT_SYSMGR_FRZCTL_SRC_t;
+/* The byte offset of the ALT_SYSMGR_FRZCTL_SRC register from the beginning of the component. */
+#define ALT_SYSMGR_FRZCTL_SRC_OFST        0x14
+ * Register : Hardware Control Register - hwctrl
+ * Activate freeze or thaw operations on VIO channel 1 (HPS IO bank 2 and bank 3)
+ * and monitor for completeness and the current state.
+ * These fields interact with the hardware state machine in the Freeze Controller.
+ * These fields can be accessed independent of the value of SRC1.VIO1 although they
+ * only have an effect on the VIO channel 1 freeze signals when SRC1.VIO1 is setup
+ * to have the hardware state machine be the freeze signal source.
+ * Register Layout
+ *  [0]    | RW     | 0x1   | VIO channel 1 Freeze/Thaw request
+ *  [2:1]  | R      | 0x2   | VIO channel 1 State
+ *  [31:3] | ???    | 0x0   | *UNDEFINED*
+ * Field : VIO channel 1 Freeze/Thaw request - vio1req
+ * Requests hardware state machine to generate freeze signal sequence to transition
+ * between frozen and thawed states.
+ * If this field is read by software, it contains the value previously written by
+ * software (i.e. this field is not written by hardware).
+ *  ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQTHAW | 0x0   | Requests a thaw (unfreeze) operation.
+ *  ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQFRZ  | 0x1   | Requests a freeze operation.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ
+ * Requests a thaw (unfreeze) operation.
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQTHAW   0x0
+ * Requests a freeze operation.
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_E_REQFRZ    0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_MSB        0
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field value. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field value. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_RESET      0x1
+/* Extracts the ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1REQ_SET(value) (((value) << 0) & 0x00000001)
+ * Field : VIO channel 1 State - vio1state
+ * Software reads this field to determine the current frozen/thawed state of the
+ * VIO channel 1 or to determine when a freeze/thaw request is made by writing the
+ * corresponding *REQ field in this register has completed.
+ * Reset by a cold reset (ignores warm reset).
+ *  ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED2FROZEN | 0x0   | Transitioning from thawed state to frozen state.
+ *  ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED        | 0x1   | Thawed state. I/Os behave as configured. I/Os
+ * :                                                  |       | must be configured by the Scan Manager before
+ * :                                                  |       | entering this state.
+ *  ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN        | 0x2   | Frozen state. I/O configuration is ignored.
+ * :                                                  |       | Instead, I/Os are in tri-state mode with a weak
+ * :                                                  |       | pull-up. Scan Manager can be used to configure
+ * :                                                  |       | the I/Os while they are frozen.
+ *  ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN2THAWED | 0x3   | Transitioning from frozen state to thawed state.
+ * Enumerated value for register field ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE
+ * Transitioning from thawed state to frozen state.
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED2FROZEN   0x0
+ * Thawed state. I/Os behave as configured. I/Os must be configured by the Scan
+ * Manager before entering this state.
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_THAWED          0x1
+ * Frozen state. I/O configuration is ignored. Instead, I/Os are in tri-state mode
+ * with a weak pull-up. Scan Manager can be used to configure the I/Os while they
+ * are frozen.
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN          0x2
+ * Transitioning from frozen state to thawed state.
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_E_FROZEN2THAWED   0x3
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_MSB        2
+/* The width in bits of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field value. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_SET_MSK    0x00000006
+/* The mask used to clear the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field value. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_CLR_MSK    0xfffffff9
+/* The reset value of the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_RESET      0x2
+/* Extracts the ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE field value from a register. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_GET(value) (((value) & 0x00000006) >> 1)
+/* Produces a ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE register field value suitable for setting the register. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_VIO1STATE_SET(value) (((value) << 1) & 0x00000006)
+ * The struct declaration for register ALT_SYSMGR_FRZCTL_HWCTL.
+struct ALT_SYSMGR_FRZCTL_HWCTL_s
+    uint32_t        vio1req   :  1;  /* VIO channel 1 Freeze/Thaw request */
+    const uint32_t  vio1state :  2;  /* VIO channel 1 State */
+    uint32_t                  : 29;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_FRZCTL_HWCTL. */
+typedef volatile struct ALT_SYSMGR_FRZCTL_HWCTL_s  ALT_SYSMGR_FRZCTL_HWCTL_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SYSMGR_FRZCTL_HWCTL register from the beginning of the component. */
+#define ALT_SYSMGR_FRZCTL_HWCTL_OFST        0x18
+ * The struct declaration for register group ALT_SYSMGR_FRZCTL.
+struct ALT_SYSMGR_FRZCTL_s
+    volatile ALT_SYSMGR_FRZCTL_VIOCTL_t  vioctrl[3];      /* ALT_SYSMGR_FRZCTL_VIOCTL */
+    volatile uint32_t                    _pad_0xc_0xf;    /* *UNDEFINED* */
+    volatile ALT_SYSMGR_FRZCTL_HIOCTL_t  hioctrl;         /* ALT_SYSMGR_FRZCTL_HIOCTL */
+    volatile ALT_SYSMGR_FRZCTL_SRC_t     src;             /* ALT_SYSMGR_FRZCTL_SRC */
+    volatile ALT_SYSMGR_FRZCTL_HWCTL_t   hwctrl;          /* ALT_SYSMGR_FRZCTL_HWCTL */
+    volatile uint32_t                    _pad_0x1c_0x20;  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_SYSMGR_FRZCTL. */
+typedef volatile struct ALT_SYSMGR_FRZCTL_s  ALT_SYSMGR_FRZCTL_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_FRZCTL. */
+struct ALT_SYSMGR_FRZCTL_raw_s
+    volatile uint32_t  vioctrl[3];      /* ALT_SYSMGR_FRZCTL_VIOCTL */
+    volatile uint32_t  hioctrl;         /* ALT_SYSMGR_FRZCTL_HIOCTL */
+    volatile uint32_t  src;             /* ALT_SYSMGR_FRZCTL_SRC */
+    volatile uint32_t  hwctrl;          /* ALT_SYSMGR_FRZCTL_HWCTL */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_FRZCTL. */
+typedef volatile struct ALT_SYSMGR_FRZCTL_raw_s  ALT_SYSMGR_FRZCTL_raw_t;
+ * Register Group : EMAC Group - ALT_SYSMGR_EMAC
+ * EMAC Group
+ * External control registers for the EMACs
+ * Register : Control Register - ctrl
+ * Registers used by the EMACs. All fields are reset by a cold or warm reset.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [1:0]  | RW     | 0x2   | PHY Interface Select
+ *  [3:2]  | RW     | 0x2   | PHY Interface Select
+ *  [4]    | RW     | 0x0   | PTP Clock Select
+ *  [5]    | RW     | 0x0   | PTP Clock Select
+ *  [31:6] | ???    | 0x0   | *UNDEFINED*
+ * Field : PHY Interface Select - physel_0
+ * Controls the PHY interface selection of the EMACs. This is sampled by an EMAC
+ * module when it exits from reset. The associated enum defines the allowed values.
+ * The field array index corresponds to the EMAC index.
+ *  ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_GMII_MII | 0x0   | Select GMII/MII PHY interface
+ *  ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RGMII    | 0x1   | Select RGMII PHY interface
+ *  ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RMII     | 0x2   | Select RMII PHY interface
+ * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_0
+ * Select GMII/MII PHY interface
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_GMII_MII 0x0
+ * Select RGMII PHY interface
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RGMII    0x1
+ * Select RMII PHY interface
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_E_RMII     0x2
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_MSB        1
+/* The width in bits of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_RESET      0x2
+/* Extracts the ALT_SYSMGR_EMAC_CTL_PHYSEL_0 field value from a register. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_EMAC_CTL_PHYSEL_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_0_SET(value) (((value) << 0) & 0x00000003)
+ * Field : PHY Interface Select - physel_1
+ *  ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_GMII_MII | 0x0   | Select GMII/MII PHY interface
+ *  ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RGMII    | 0x1   | Select RGMII PHY interface
+ *  ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RMII     | 0x2   | Select RMII PHY interface
+ * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PHYSEL_1
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_GMII_MII 0x0
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RGMII    0x1
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_E_RMII     0x2
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_MSB        3
+/* The width in bits of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_SET_MSK    0x0000000c
+/* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_CLR_MSK    0xfffffff3
+/* The reset value of the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_RESET      0x2
+/* Extracts the ALT_SYSMGR_EMAC_CTL_PHYSEL_1 field value from a register. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_GET(value) (((value) & 0x0000000c) >> 2)
+/* Produces a ALT_SYSMGR_EMAC_CTL_PHYSEL_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_CTL_PHYSEL_1_SET(value) (((value) << 2) & 0x0000000c)
+ * Field : PTP Clock Select - ptpclksel_0
+ * Selects the source of the 1588 PTP reference clock. This is sampled by an EMAC
+ * module when it exits from reset. The field array index corresponds to the EMAC
+ * index.
+ *  ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_OSC1_CLK         | 0x0   | Selects osc1_clk
+ *  ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_FPGA_PTP_REF_CLK | 0x1   | Selects fpga_ptp_ref_clk
+ * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0
+ * Selects osc1_clk
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_OSC1_CLK          0x0
+ * Selects fpga_ptp_ref_clk
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_E_FPGA_PTP_REF_CLK  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_MSB        4
+/* The width in bits of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 field value from a register. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_0_SET(value) (((value) << 4) & 0x00000010)
+ * Field : PTP Clock Select - ptpclksel_1
+ * index.
+ *  ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_OSC1_CLK         | 0x0   | Selects osc1_clk
+ *  ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_FPGA_PTP_REF_CLK | 0x1   | Selects fpga_ptp_ref_clk
+ * Enumerated value for register field ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_OSC1_CLK          0x0
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_E_FPGA_PTP_REF_CLK  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_MSB        5
+/* The width in bits of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field value. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 field value from a register. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_CTL_PTPCLKSEL_1_SET(value) (((value) << 5) & 0x00000020)
+ * The struct declaration for register ALT_SYSMGR_EMAC_CTL.
+struct ALT_SYSMGR_EMAC_CTL_s
+    uint32_t  physel_0    :  2;  /* PHY Interface Select */
+    uint32_t  physel_1    :  2;  /* PHY Interface Select */
+    uint32_t  ptpclksel_0 :  1;  /* PTP Clock Select */
+    uint32_t  ptpclksel_1 :  1;  /* PTP Clock Select */
+    uint32_t              : 26;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_EMAC_CTL. */
+typedef volatile struct ALT_SYSMGR_EMAC_CTL_s  ALT_SYSMGR_EMAC_CTL_t;
+/* The byte offset of the ALT_SYSMGR_EMAC_CTL register from the beginning of the component. */
+#define ALT_SYSMGR_EMAC_CTL_OFST        0x0
+ * Register : EMAC L3 Master AxCACHE Register - l3master
+ * Controls the L3 master ARCACHE and AWCACHE AXI signals.
+ * These register bits should be updated only during system initialization prior to
+ * removing the peripheral from reset. They may not be changed dynamically during
+ * peripheral operation
+ * All fields are reset by a cold or warm reset.
+ * Register Layout
+ *  [3:0]   | RW     | 0x0   | EMAC ARCACHE
+ *  [7:4]   | RW     | 0x0   | EMAC ARCACHE
+ *  [11:8]  | RW     | 0x0   | EMAC AWCACHE
+ *  [15:12] | RW     | 0x0   | EMAC AWCACHE
+ *  [31:16] | ???    | 0x0   | *UNDEFINED*
+ * Field : EMAC ARCACHE - arcache_0
+ * Specifies the values of the 2 EMAC ARCACHE signals.
+ * Field Enumeration Values:
+ *  Enum                                                   | Value | Description
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF     | 0x0   | Noncacheable and nonbufferable.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_BUFF                 | 0x1   | Bufferable only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_NONALLOC       | 0x2   | Cacheable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC  | 0x3   | Cacheable and bufferable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD1                | 0x4   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD2                | 0x5   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6   | Cacheable write-through, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7   | Cacheable write-back, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD3                | 0x8   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD4                | 0x9   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa   | Cacheable write-through, allocate on writes
+ * :                                                       |       | only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb   | Cacheable write-back, allocate on writes only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD5                | 0xc   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD6                | 0xd   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC   | 0xe   | Cacheable write-through, allocate on both reads
+ * :                                                       |       | and writes.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC   | 0xf   | Cacheable write-back, allocate on both reads and
+ * :                                                       |       | writes.
+ * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_0
+ * Noncacheable and nonbufferable.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF      0x0
+ * Bufferable only.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_BUFF                  0x1
+ * Cacheable, but do not allocate.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_NONALLOC        0x2
+ * Cacheable and bufferable, but do not allocate.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC   0x3
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD1                 0x4
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD2                 0x5
+ * Cacheable write-through, allocate on reads only.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC  0x6
+ * Cacheable write-back, allocate on reads only.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC  0x7
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD3                 0x8
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD4                 0x9
+ * Cacheable write-through, allocate on writes only.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC  0xa
+ * Cacheable write-back, allocate on writes only.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC  0xb
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD5                 0xc
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_RSVD6                 0xd
+ * Cacheable write-through, allocate on both reads and writes.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC    0xe
+ * Cacheable write-back, allocate on both reads and writes.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC    0xf
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_MSB        3
+/* The width in bits of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_WIDTH      4
+/* The mask used to set the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 field value from a register. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_SYSMGR_EMAC_L3MST_ARCACHE_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_0_SET(value) (((value) << 0) & 0x0000000f)
+ * Field : EMAC ARCACHE - arcache_1
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_NONCACHE_NONBUFF     | 0x0   | Noncacheable and nonbufferable.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_BUFF                 | 0x1   | Bufferable only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_NONALLOC       | 0x2   | Cacheable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_BUFF_NONALLOC  | 0x3   | Cacheable and bufferable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD1                | 0x4   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD2                | 0x5   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_RDALLOC | 0x6   | Cacheable write-through, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_RDALLOC | 0x7   | Cacheable write-back, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD3                | 0x8   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD4                | 0x9   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_WRALLOC | 0xa   | Cacheable write-through, allocate on writes
+ * :                                                       |       | only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_WRALLOC | 0xb   | Cacheable write-back, allocate on writes only.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD5                | 0xc   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD6                | 0xd   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_ALLOC   | 0xe   | Cacheable write-through, allocate on both reads
+ *  ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_ALLOC   | 0xf   | Cacheable write-back, allocate on both reads and
+ * :                                                       |       | writes.
+ * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_ARCACHE_1
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_NONCACHE_NONBUFF      0x0
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_BUFF                  0x1
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_NONALLOC        0x2
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_BUFF_NONALLOC   0x3
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD1                 0x4
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD2                 0x5
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_RDALLOC  0x6
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_RDALLOC  0x7
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD3                 0x8
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD4                 0x9
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_WRALLOC  0xa
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_WRALLOC  0xb
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD5                 0xc
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_RSVD6                 0xd
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRTHRU_ALLOC    0xe
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_E_CACHE_WRBACK_ALLOC    0xf
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_MSB        7
+/* The width in bits of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_WIDTH      4
+/* The mask used to set the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_SET_MSK    0x000000f0
+/* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_CLR_MSK    0xffffff0f
+/* The reset value of the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 field value from a register. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_GET(value) (((value) & 0x000000f0) >> 4)
+/* Produces a ALT_SYSMGR_EMAC_L3MST_ARCACHE_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_L3MST_ARCACHE_1_SET(value) (((value) << 4) & 0x000000f0)
+ * Field : EMAC AWCACHE - awcache_0
+ * Specifies the values of the 2 EMAC AWCACHE signals.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF     | 0x0   | Noncacheable and nonbufferable.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_BUFF                 | 0x1   | Bufferable only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_NONALLOC       | 0x2   | Cacheable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC  | 0x3   | Cacheable and bufferable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD1                | 0x4   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD2                | 0x5   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6   | Cacheable write-through, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7   | Cacheable write-back, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD3                | 0x8   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD4                | 0x9   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa   | Cacheable write-through, allocate on writes
+ * :                                                       |       | only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb   | Cacheable write-back, allocate on writes only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD5                | 0xc   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD6                | 0xd   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC   | 0xe   | Cacheable write-through, allocate on both reads
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC   | 0xf   | Cacheable write-back, allocate on both reads and
+ * :                                                       |       | writes.
+ * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_0
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF      0x0
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_BUFF                  0x1
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_NONALLOC        0x2
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC   0x3
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD1                 0x4
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD2                 0x5
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC  0x6
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC  0x7
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD3                 0x8
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD4                 0x9
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC  0xa
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC  0xb
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD5                 0xc
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_RSVD6                 0xd
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC    0xe
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC    0xf
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_MSB        11
+/* The width in bits of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_WIDTH      4
+/* The mask used to set the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_SET_MSK    0x00000f00
+/* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_CLR_MSK    0xfffff0ff
+/* The reset value of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 field value from a register. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_GET(value) (((value) & 0x00000f00) >> 8)
+/* Produces a ALT_SYSMGR_EMAC_L3MST_AWCACHE_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_0_SET(value) (((value) << 8) & 0x00000f00)
+ * Field : EMAC AWCACHE - awcache_1
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_NONCACHE_NONBUFF     | 0x0   | Noncacheable and nonbufferable.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_BUFF                 | 0x1   | Bufferable only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_NONALLOC       | 0x2   | Cacheable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_BUFF_NONALLOC  | 0x3   | Cacheable and bufferable, but do not allocate.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD1                | 0x4   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD2                | 0x5   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_RDALLOC | 0x6   | Cacheable write-through, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_RDALLOC | 0x7   | Cacheable write-back, allocate on reads only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD3                | 0x8   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD4                | 0x9   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_WRALLOC | 0xa   | Cacheable write-through, allocate on writes
+ * :                                                       |       | only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_WRALLOC | 0xb   | Cacheable write-back, allocate on writes only.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD5                | 0xc   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD6                | 0xd   | Reserved.
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_ALLOC   | 0xe   | Cacheable write-through, allocate on both reads
+ *  ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_ALLOC   | 0xf   | Cacheable write-back, allocate on both reads and
+ * :                                                       |       | writes.
+ * Enumerated value for register field ALT_SYSMGR_EMAC_L3MST_AWCACHE_1
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_NONCACHE_NONBUFF      0x0
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_BUFF                  0x1
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_NONALLOC        0x2
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_BUFF_NONALLOC   0x3
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD1                 0x4
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD2                 0x5
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_RDALLOC  0x6
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_RDALLOC  0x7
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD3                 0x8
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD4                 0x9
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_WRALLOC  0xa
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_WRALLOC  0xb
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD5                 0xc
+ * Reserved.
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_RSVD6                 0xd
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRTHRU_ALLOC    0xe
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_E_CACHE_WRBACK_ALLOC    0xf
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_MSB        15
+/* The width in bits of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_WIDTH      4
+/* The mask used to set the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_SET_MSK    0x0000f000
+/* The mask used to clear the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field value. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_CLR_MSK    0xffff0fff
+/* The reset value of the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 field value from a register. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_GET(value) (((value) & 0x0000f000) >> 12)
+/* Produces a ALT_SYSMGR_EMAC_L3MST_AWCACHE_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_EMAC_L3MST_AWCACHE_1_SET(value) (((value) << 12) & 0x0000f000)
+ * The struct declaration for register ALT_SYSMGR_EMAC_L3MST.
+struct ALT_SYSMGR_EMAC_L3MST_s
+    uint32_t  arcache_0 :  4;  /* EMAC ARCACHE */
+    uint32_t  arcache_1 :  4;  /* EMAC ARCACHE */
+    uint32_t  awcache_0 :  4;  /* EMAC AWCACHE */
+    uint32_t  awcache_1 :  4;  /* EMAC AWCACHE */
+    uint32_t            : 16;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_EMAC_L3MST. */
+typedef volatile struct ALT_SYSMGR_EMAC_L3MST_s  ALT_SYSMGR_EMAC_L3MST_t;
+/* The byte offset of the ALT_SYSMGR_EMAC_L3MST register from the beginning of the component. */
+#define ALT_SYSMGR_EMAC_L3MST_OFST        0x4
+ * The struct declaration for register group ALT_SYSMGR_EMAC.
+struct ALT_SYSMGR_EMAC_s
+    volatile ALT_SYSMGR_EMAC_CTL_t    ctrl;              /* ALT_SYSMGR_EMAC_CTL */
+    volatile ALT_SYSMGR_EMAC_L3MST_t  l3master;          /* ALT_SYSMGR_EMAC_L3MST */
+    volatile uint32_t                 _pad_0x8_0x10[2];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_SYSMGR_EMAC. */
+typedef volatile struct ALT_SYSMGR_EMAC_s  ALT_SYSMGR_EMAC_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_EMAC. */
+struct ALT_SYSMGR_EMAC_raw_s
+    volatile uint32_t  ctrl;              /* ALT_SYSMGR_EMAC_CTL */
+    volatile uint32_t  l3master;          /* ALT_SYSMGR_EMAC_L3MST */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_EMAC. */
+typedef volatile struct ALT_SYSMGR_EMAC_raw_s  ALT_SYSMGR_EMAC_raw_t;
+ * Register Group : DMA Controller Group - ALT_SYSMGR_DMA
+ * DMA Controller Group
+ * Registers used by the DMA Controller to enable secured system support and select
+ * DMA channels.
+ * Registers used by the DMA Controller. All fields are reset by a cold or warm
+ * reset.
+ * These register bits should be updated during system initialization prior to
+ * removing the DMA controller from reset. They may not be changed dynamically
+ * during DMA operation.
+ * Register Layout
+ *  [0]     | RW     | 0x0   | Channel Select
+ *  [1]     | RW     | 0x0   | Channel Select
+ *  [2]     | RW     | 0x0   | Channel Select
+ *  [3]     | RW     | 0x0   | Channel Select
+ *  [4]     | RW     | 0x0   | Manager Thread Security
+ *  [12:5]  | RW     | 0x0   | IRQ Security
+ *  [31:13] | ???    | 0x0   | *UNDEFINED*
+ * Field : Channel Select - chansel_0
+ * Controls mux that selects whether FPGA or CAN connects to one of the DMA
+ * peripheral request interfaces.The peripheral request interface index equals the
+ * array index + 4. For example, array index 0 is for peripheral request index 4.
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_FPGA | 0x0   | FPGA drives peripheral request interface
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_CAN  | 0x1   | CAN drives peripheral request interface
+ * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_0
+ * FPGA drives peripheral request interface
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_FPGA 0x0
+ * CAN drives peripheral request interface
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_E_CAN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_MSB        0
+/* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_0 field value from a register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Channel Select - chansel_1
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_FPGA | 0x0   | FPGA drives peripheral request interface
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_CAN  | 0x1   | CAN drives peripheral request interface
+ * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_1
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_FPGA 0x0
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_E_CAN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_MSB        1
+/* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_1 field value from a register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Channel Select - chansel_2
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_FPGA | 0x0   | FPGA drives peripheral request interface
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_CAN  | 0x1   | CAN drives peripheral request interface
+ * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_2
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_FPGA 0x0
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_E_CAN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_MSB        2
+/* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_RESET      0x0
+/* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_2 field value from a register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_2 register field value suitable for setting the register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_2_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Channel Select - chansel_3
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_FPGA | 0x0   | FPGA drives peripheral request interface
+ *  ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_CAN  | 0x1   | CAN drives peripheral request interface
+ * Enumerated value for register field ALT_SYSMGR_DMA_CTL_CHANSEL_3
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_FPGA 0x0
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_E_CAN  0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_MSB        3
+/* The width in bits of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field value. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_RESET      0x0
+/* Extracts the ALT_SYSMGR_DMA_CTL_CHANSEL_3 field value from a register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_DMA_CTL_CHANSEL_3 register field value suitable for setting the register. */
+#define ALT_SYSMGR_DMA_CTL_CHANSEL_3_SET(value) (((value) << 3) & 0x00000008)
+ * Field : Manager Thread Security - mgrnonsecure
+ * Specifies the security state of the DMA manager thread.
+ * 0 = assigns DMA manager to the Secure state.
+ * 1 = assigns DMA manager to the Non-secure state.
+ * Sampled by the DMA controller when it exits from reset.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_MSB        4
+/* The width in bits of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field value. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field value. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_RESET      0x0
+/* Extracts the ALT_SYSMGR_DMA_CTL_MGRNONSECURE field value from a register. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_DMA_CTL_MGRNONSECURE register field value suitable for setting the register. */
+#define ALT_SYSMGR_DMA_CTL_MGRNONSECURE_SET(value) (((value) << 4) & 0x00000010)
+ * Field : IRQ Security - irqnonsecure
+ * Specifies the security state of an event-interrupt resource.
+ * If bit index [x] is 0, the DMAC assigns event<x> or irq[x] to the Secure state.
+ * If bit index [x] is 1, the DMAC assigns event<x> or irq[x] to the Non-secure
+ * state.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_MSB        12
+/* The width in bits of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_WIDTH      8
+/* The mask used to set the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field value. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_SET_MSK    0x00001fe0
+/* The mask used to clear the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field value. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_CLR_MSK    0xffffe01f
+/* The reset value of the ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_RESET      0x0
+/* Extracts the ALT_SYSMGR_DMA_CTL_IRQNONSECURE field value from a register. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_GET(value) (((value) & 0x00001fe0) >> 5)
+/* Produces a ALT_SYSMGR_DMA_CTL_IRQNONSECURE register field value suitable for setting the register. */
+#define ALT_SYSMGR_DMA_CTL_IRQNONSECURE_SET(value) (((value) << 5) & 0x00001fe0)
+ * The struct declaration for register ALT_SYSMGR_DMA_CTL.
+struct ALT_SYSMGR_DMA_CTL_s
+    uint32_t  chansel_0    :  1;  /* Channel Select */
+    uint32_t  chansel_1    :  1;  /* Channel Select */
+    uint32_t  chansel_2    :  1;  /* Channel Select */
+    uint32_t  chansel_3    :  1;  /* Channel Select */
+    uint32_t  mgrnonsecure :  1;  /* Manager Thread Security */
+    uint32_t  irqnonsecure :  8;  /* IRQ Security */
+    uint32_t               : 19;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_DMA_CTL. */
+typedef volatile struct ALT_SYSMGR_DMA_CTL_s  ALT_SYSMGR_DMA_CTL_t;
+/* The byte offset of the ALT_SYSMGR_DMA_CTL register from the beginning of the component. */
+#define ALT_SYSMGR_DMA_CTL_OFST        0x0
+ * Register : Peripheral Security Register - persecurity
+ * Controls the security state of a peripheral request interface. Sampled by the
+ * DMA controller when it exits from reset.
+ * Register Layout
+ *  [31:0] | RW     | 0x0   | Peripheral Non-Secure
+ * Field : Peripheral Non-Secure - nonsecure
+ * If bit index [x] is 0, the DMA controller assigns peripheral request interface x
+ * to the Secure state.
+ * If bit index [x] is 1, the DMA controller assigns peripheral request interface x
+ * to the Non-secure state.
+ * Reset by a cold or warm reset.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_MSB        31
+/* The width in bits of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field value. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field value. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_RESET      0x0
+/* Extracts the ALT_SYSMGR_DMA_PERSECURITY_NONSECURE field value from a register. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_DMA_PERSECURITY_NONSECURE register field value suitable for setting the register. */
+#define ALT_SYSMGR_DMA_PERSECURITY_NONSECURE_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SYSMGR_DMA_PERSECURITY.
+struct ALT_SYSMGR_DMA_PERSECURITY_s
+    uint32_t  nonsecure : 32;  /* Peripheral Non-Secure */
+/* The typedef declaration for register ALT_SYSMGR_DMA_PERSECURITY. */
+typedef volatile struct ALT_SYSMGR_DMA_PERSECURITY_s  ALT_SYSMGR_DMA_PERSECURITY_t;
+/* The byte offset of the ALT_SYSMGR_DMA_PERSECURITY register from the beginning of the component. */
+#define ALT_SYSMGR_DMA_PERSECURITY_OFST        0x4
+ * The struct declaration for register group ALT_SYSMGR_DMA.
+struct ALT_SYSMGR_DMA_s
+    volatile ALT_SYSMGR_DMA_CTL_t          ctrl;         /* ALT_SYSMGR_DMA_CTL */
+    volatile ALT_SYSMGR_DMA_PERSECURITY_t  persecurity;  /* ALT_SYSMGR_DMA_PERSECURITY */
+/* The typedef declaration for register group ALT_SYSMGR_DMA. */
+typedef volatile struct ALT_SYSMGR_DMA_s  ALT_SYSMGR_DMA_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_DMA. */
+struct ALT_SYSMGR_DMA_raw_s
+    volatile uint32_t  ctrl;         /* ALT_SYSMGR_DMA_CTL */
+    volatile uint32_t  persecurity;  /* ALT_SYSMGR_DMA_PERSECURITY */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_DMA. */
+typedef volatile struct ALT_SYSMGR_DMA_raw_s  ALT_SYSMGR_DMA_raw_t;
+ * Register Group : Preloader (initial software) Group - ALT_SYSMGR_ISW
+ * Preloader (initial software) Group
+ * Registers used by preloader code and the OS.
+ * All registers are only reset by a cold reset (ignore warm reset).
+ * Register : Preloader to OS Handoff Information - handoff
+ * These registers are used to store handoff infomation between the preloader and
+ * the OS. These 8 registers can be used to store any information. The contents of
+ * these registers have no impact on the state of the HPS hardware.
+ * Register Layout
+ *  [31:0] | RW     | 0x0   | Preloader Handoff Information
+ * Field : Preloader Handoff Information - value
+ * Preloader Handoff Information.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_MSB        31
+/* The width in bits of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_ISW_HANDOFF_VALUE register field value. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_ISW_HANDOFF_VALUE register field value. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_ISW_HANDOFF_VALUE register field. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_RESET      0x0
+/* Extracts the ALT_SYSMGR_ISW_HANDOFF_VALUE field value from a register. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_ISW_HANDOFF_VALUE register field value suitable for setting the register. */
+#define ALT_SYSMGR_ISW_HANDOFF_VALUE_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SYSMGR_ISW_HANDOFF.
+struct ALT_SYSMGR_ISW_HANDOFF_s
+    uint32_t  value : 32;  /* Preloader Handoff Information */
+/* The typedef declaration for register ALT_SYSMGR_ISW_HANDOFF. */
+typedef volatile struct ALT_SYSMGR_ISW_HANDOFF_s  ALT_SYSMGR_ISW_HANDOFF_t;
+/* The byte offset of the ALT_SYSMGR_ISW_HANDOFF register from the beginning of the component. */
+#define ALT_SYSMGR_ISW_HANDOFF_OFST        0x0
+ * The struct declaration for register group ALT_SYSMGR_ISW.
+struct ALT_SYSMGR_ISW_s
+    volatile ALT_SYSMGR_ISW_HANDOFF_t  handoff[8];  /* ALT_SYSMGR_ISW_HANDOFF */
+/* The typedef declaration for register group ALT_SYSMGR_ISW. */
+typedef volatile struct ALT_SYSMGR_ISW_s  ALT_SYSMGR_ISW_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_ISW. */
+struct ALT_SYSMGR_ISW_raw_s
+    volatile uint32_t  handoff[8];  /* ALT_SYSMGR_ISW_HANDOFF */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ISW. */
+typedef volatile struct ALT_SYSMGR_ISW_raw_s  ALT_SYSMGR_ISW_raw_t;
+ * Register Group : Boot ROM Code Register Group - ALT_SYSMGR_ROMCODE
+ * Boot ROM Code Register Group
+ * Registers used by the Boot ROM code. All fields are only reset by a cold reset
+ * (ignore warm reset).
+ * Contains information used to control Boot ROM code.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | Warm Reset Configure Pin Mux for Boot Pins
+ *  [1]    | RW     | 0x0   | Warm Reset Configure IOs for Boot Pins
+ *  [31:2] | ???    | 0x0   | *UNDEFINED*
+ * Field : Warm Reset Configure Pin Mux for Boot Pins - warmrstcfgpinmux
+ * Specifies whether the Boot ROM code configures the pin mux for boot pins after a
+ * warm reset. Note that the Boot ROM code always configures the pin mux for boot
+ * pins after a cold reset. After the Boot ROM code configures the pin mux for boot
+ * pins, it always disables this field. It is up to user software to enable this
+ * field if it wants a different behavior.
+ *  ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_DISD | 0x0   | Boot ROM code will not configure pin mux for
+ * :                                               |       | boot pins after a warm reset
+ *  ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_END  | 0x1   | Boot ROM code will configure pin mux for boot
+ * :                                               |       | pins after a warm reset
+ * Enumerated value for register field ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX
+ * Boot ROM code will not configure pin mux for boot pins after a warm reset
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_DISD  0x0
+ * Boot ROM code will configure pin mux for boot pins after a warm reset
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_E_END   0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_MSB        0
+/* The width in bits of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field value. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field value. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX field value from a register. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGPINMUX_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Warm Reset Configure IOs for Boot Pins - warmrstcfgio
+ * Specifies whether the Boot ROM code configures the IOs used by boot after a warm
+ * reset. Note that the Boot ROM code always configures the IOs used by boot after
+ * a cold reset. After the Boot ROM code configures the IOs used by boot, it always
+ * disables this field. It is up to user software to enable this field if it wants
+ * a different behavior.
+ *  ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_DISD | 0x0   | Boot ROM code will not configure IOs used by
+ * :                                           |       | boot after a warm reset
+ *  ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_END  | 0x1   | Boot ROM code will configure IOs used by boot
+ * :                                           |       | after a warm reset
+ * Enumerated value for register field ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO
+ * Boot ROM code will not configure IOs used by boot after a warm reset
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_DISD  0x0
+ * Boot ROM code will configure IOs used by boot after a warm reset
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_E_END   0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_MSB        1
+/* The width in bits of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field value. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field value. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO field value from a register. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_CTL_WARMRSTCFGIO_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_CTL.
+struct ALT_SYSMGR_ROMCODE_CTL_s
+    uint32_t  warmrstcfgpinmux :  1;  /* Warm Reset Configure Pin Mux for Boot Pins */
+    uint32_t  warmrstcfgio     :  1;  /* Warm Reset Configure IOs for Boot Pins */
+    uint32_t                   : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_CTL. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_CTL_s  ALT_SYSMGR_ROMCODE_CTL_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_CTL register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_CTL_OFST        0x0
+ * Register : CPU1 Start Address Register - cpu1startaddr
+ * When CPU1 is released from reset and the Boot ROM is located at the CPU1 reset
+ * exception address (the typical case), the Boot ROM reset handler code reads the
+ * address stored in this register and jumps it to hand off execution to user
+ * software.
+ * Register Layout
+ *  [31:0] | RW     | 0x0   | Address
+ * Field : Address - value
+ * Address for CPU1 to start executing at after coming out of reset.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_MSB        31
+/* The width in bits of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field value. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field value. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE field value from a register. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_VALUE_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_CPU1STARTADDR.
+struct ALT_SYSMGR_ROMCODE_CPU1STARTADDR_s
+    uint32_t  value : 32;  /* Address */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_CPU1STARTADDR. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_CPU1STARTADDR_s  ALT_SYSMGR_ROMCODE_CPU1STARTADDR_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_CPU1STARTADDR register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_CPU1STARTADDR_OFST        0x4
+ * Register : Preloader (initial software) State Register - initswstate
+ * The preloader software (loaded by the Boot ROM) writes the magic value
+ * 0x49535756 (ISWV in ASCII) to this register when it has reached a valid state.
+ * Register Layout
+ *  [31:0] | RW     | 0x0   | Value
+ * Field : Value - value
+ * Written with magic value.
+ *  ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_INVALID | 0x0        |
+ *  ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_VALID   | 0x49535756 |
+ * Field Access Macros:
+ * Enumerated value for register field ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_INVALID  0x0
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_E_VALID    0x49535756
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_MSB        31
+/* The width in bits of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field value. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field value. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE field value from a register. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_VALUE_SET(value) (((value) << 0) & 0xffffffff)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_INITSWSTATE.
+struct ALT_SYSMGR_ROMCODE_INITSWSTATE_s
+    uint32_t  value : 32;  /* Value */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_INITSWSTATE. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_INITSWSTATE_s  ALT_SYSMGR_ROMCODE_INITSWSTATE_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_INITSWSTATE register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_INITSWSTATE_OFST        0x8
+ * Register : Preloader (initial software) Last Image Loaded Register - initswlastld
+ * Contains the index of the last preloader software image loaded by the Boot ROM
+ * from the boot device.
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | Index
+ * Field : Index - index
+ * Index of last image loaded.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_MSB        1
+/* The width in bits of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field value. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field value. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX field value from a register. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_INDEX_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_INITSWLASTLD.
+struct ALT_SYSMGR_ROMCODE_INITSWLASTLD_s
+    uint32_t  index :  2;  /* Index */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_INITSWLASTLD. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_INITSWLASTLD_s  ALT_SYSMGR_ROMCODE_INITSWLASTLD_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_INITSWLASTLD register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_INITSWLASTLD_OFST        0xc
+ * Register : Boot ROM Software State Register - bootromswstate
+ * 32-bits general purpose register used by the Boot ROM code. Actual usage is
+ * defined in the Boot ROM source code.
+ * Register Layout
+ *  [31:0] | RW     | 0x0   | Boot ROM Software State
+ * Field : Boot ROM Software State - value
+ * Reserved for Boot ROM use.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_MSB        31
+/* The width in bits of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field value. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field value. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE field value from a register. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_VALUE_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE.
+struct ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_s
+    uint32_t  value : 32;  /* Boot ROM Software State */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_s  ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_OFST        0x10
+ * Register Group : Warm Boot from On-Chip RAM Group - ALT_SYSMGR_ROMCODE_WARMRAM
+ * Warm Boot from On-Chip RAM Group
+ * Registers used by the Boot ROM code to support booting from the On-chip RAM on a
+ * warm reset.  All these registers must be written by user software before a warm
+ * reset occurs to make use of this feature.
+ * Register : Enable Register - enable
+ * Enables or disables the warm reset from On-chip RAM feature.
+ * Register Layout
+ *  [31:0] | RW     | 0x0   | Warm Reset from On-chip RAM
+ * Field : Warm Reset from On-chip RAM - magic
+ * Controls whether Boot ROM will attempt to boot from the contents of the On-chip
+ * RAM on a warm reset. When this feature is enabled, the Boot ROM code will not
+ * configure boot IOs, the pin mux, or clocks.
+ * Note that the enable value is a 32-bit magic value (provided by the enum).
+ *  ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_DISD | 0x0        | Boot ROM code will not attempt to boot from On-
+ * :                                           |            | chip RAM on a warm reset
+ *  ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_END  | 0xae9efebc | Boot ROM code will attempt to boot from On-chip
+ * :                                           |            | RAM on a warm reset
+ * Enumerated value for register field ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC
+ * Boot ROM code will not attempt to boot from On-chip RAM on a warm reset
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_DISD  0x0
+ * Boot ROM code will attempt to boot from On-chip RAM on a warm reset
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_E_END   0xae9efebc
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_MSB        31
+/* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC field value from a register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_MAGIC_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EN.
+struct ALT_SYSMGR_ROMCODE_WARMRAM_EN_s
+    uint32_t  magic : 32;  /* Warm Reset from On-chip RAM */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EN. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_EN_s  ALT_SYSMGR_ROMCODE_WARMRAM_EN_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_EN register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_OFST        0x0
+/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EN register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EN_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_EN_OFST))
+ * Register : Data Start Register - datastart
+ * Offset into On-chip RAM of the start of the region for CRC validation
+ * Register Layout
+ *  Bits    | Access | Reset | Description
+ *  [15:0]  | RW     | 0x0   | Data Start Offset
+ * Field : Data Start Offset - offset
+ * Contains the byte offset into the On-chip RAM of the start of the On-chip RAM
+ * region for the warm boot CRC validation. The offset must be an integer multiple
+ * of 4 (i.e. aligned to a word). The Boot ROM code will set the top 16 bits to
+ * 0xFFFF and clear the bottom 2 bits.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_MSB        15
+/* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_WIDTH      16
+/* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_SET_MSK    0x0000ffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_CLR_MSK    0xffff0000
+/* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET field value from a register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_GET(value) (((value) & 0x0000ffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFFSET_SET(value) (((value) << 0) & 0x0000ffff)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART.
+struct ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_s
+    uint32_t  offset : 16;  /* Data Start Offset */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_s  ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFST        0x4
+/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_OFST))
+ * Register : Length Register - length
+ * Length of region in On-chip RAM for CRC validation.
+ * Register Layout
+ *  [15:0]  | RW     | 0x0   | Size
+ * Field : Size - size
+ * Contains the length (in bytes) of the region in the On-chip RAM for the warm
+ * boot CRC validation.
+ * If the length is 0, the Boot ROM won't perform CRC calculation and CRC check to
+ * avoid overhead caused by CRC validation.
+ * If the START + LENGTH exceeds the maximum offset into the On-chip RAM, the Boot
+ * ROM won't boot from the On-chip RAM.
+ * The length must be an integer multiple of 4.
+ * The Boot ROM code will clear the top 16 bits and the bottom 2 bits.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_MSB        15
+/* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_WIDTH      16
+/* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_SET_MSK    0x0000ffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_CLR_MSK    0xffff0000
+/* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE field value from a register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_GET(value) (((value) & 0x0000ffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_SIZE_SET(value) (((value) << 0) & 0x0000ffff)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_LEN.
+struct ALT_SYSMGR_ROMCODE_WARMRAM_LEN_s
+    uint32_t  size : 16;  /* Size */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_LEN. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_LEN_s  ALT_SYSMGR_ROMCODE_WARMRAM_LEN_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_OFST        0x8
+/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_LEN register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_LEN_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_LEN_OFST))
+ * Register : Execution Register - execution
+ * Offset into On-chip RAM to enter to on a warm boot.
+ * Register Layout
+ *  [15:0]  | RW     | 0x0   | Execution Offset
+ * Field : Execution Offset - offset
+ * Contains the byte offset into the On-chip RAM that the Boot ROM will jump to if
+ * the CRC validation succeeds.
+ * The Boot ROM code will set the top 16 bits to 0xFFFF.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_MSB        15
+/* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_WIDTH      16
+/* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_SET_MSK    0x0000ffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_CLR_MSK    0xffff0000
+/* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET field value from a register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_GET(value) (((value) & 0x0000ffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFFSET_SET(value) (((value) << 0) & 0x0000ffff)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION.
+struct ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_s
+    uint32_t  offset : 16;  /* Execution Offset */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_s  ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFST        0xc
+/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_OFST))
+ * Register : Expected CRC Register - crc
+ * Register Layout
+ *  [31:0] | RW     | 0xe763552a | Expected CRC
+ * Field : Expected CRC - expected
+ * Contains the expected CRC of the region in the On-chip RAM.The Boot ROM code
+ * calculates the actual CRC for all bytes in the region specified by the DATA
+ * START an LENGTH registers. The contents of the EXECUTION register (after it has
+ * been read and modified by the Boot ROM code) is also included in the CRC
+ * calculation. The contents of the EXECUTION register is added to the CRC
+ * accumulator a byte at a time starting with the least significant byte. If the
+ * actual CRC doesn't match the expected CRC value in this register, the Boot ROM
+ * won't boot from the On-chip RAM.
+ * The CRC is a standard CRC32 with the polynomial:
+ * x^32 + x^26 + x^23 + x^22 + x^16 + x^12 + x^11 + x^10 + x^8 + x^7 + x^5 + x^4 +
+ * x^2 + x + 1
+ * There is no reflection of the bits and the initial value of the remainder is
+ * 0xFFFFFFFF and the final value is exclusive ORed with 0xFFFFFFFF.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_MSB        31
+/* The width in bits of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_WIDTH      32
+/* The mask used to set the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_SET_MSK    0xffffffff
+/* The mask used to clear the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field value. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_CLR_MSK    0x00000000
+/* The reset value of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_RESET      0xe763552a
+/* Extracts the ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED field value from a register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_GET(value) (((value) & 0xffffffff) >> 0)
+/* Produces a ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_EXPECTED_SET(value) (((value) << 0) & 0xffffffff)
+ * The struct declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_CRC.
+struct ALT_SYSMGR_ROMCODE_WARMRAM_CRC_s
+    uint32_t  expected : 32;  /* Expected CRC */
+/* The typedef declaration for register ALT_SYSMGR_ROMCODE_WARMRAM_CRC. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_CRC_s  ALT_SYSMGR_ROMCODE_WARMRAM_CRC_t;
+/* The byte offset of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC register from the beginning of the component. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_OFST        0x10
+/* The address of the ALT_SYSMGR_ROMCODE_WARMRAM_CRC register. */
+#define ALT_SYSMGR_ROMCODE_WARMRAM_CRC_ADDR(base)  ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SYSMGR_ROMCODE_WARMRAM_CRC_OFST))
+ * The struct declaration for register group ALT_SYSMGR_ROMCODE_WARMRAM.
+struct ALT_SYSMGR_ROMCODE_WARMRAM_s
+    volatile ALT_SYSMGR_ROMCODE_WARMRAM_EN_t         enable;             /* ALT_SYSMGR_ROMCODE_WARMRAM_EN */
+    volatile ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART_t  datastart;          /* ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART */
+    volatile ALT_SYSMGR_ROMCODE_WARMRAM_LEN_t        length;             /* ALT_SYSMGR_ROMCODE_WARMRAM_LEN */
+    volatile ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION_t  execution;          /* ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION */
+    volatile ALT_SYSMGR_ROMCODE_WARMRAM_CRC_t        crc;                /* ALT_SYSMGR_ROMCODE_WARMRAM_CRC */
+    volatile uint32_t                                _pad_0x14_0x20[3];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_SYSMGR_ROMCODE_WARMRAM. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_s  ALT_SYSMGR_ROMCODE_WARMRAM_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE_WARMRAM. */
+struct ALT_SYSMGR_ROMCODE_WARMRAM_raw_s
+    volatile uint32_t  enable;             /* ALT_SYSMGR_ROMCODE_WARMRAM_EN */
+    volatile uint32_t  datastart;          /* ALT_SYSMGR_ROMCODE_WARMRAM_DATASTART */
+    volatile uint32_t  length;             /* ALT_SYSMGR_ROMCODE_WARMRAM_LEN */
+    volatile uint32_t  execution;          /* ALT_SYSMGR_ROMCODE_WARMRAM_EXECUTION */
+    volatile uint32_t  crc;                /* ALT_SYSMGR_ROMCODE_WARMRAM_CRC */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE_WARMRAM. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_WARMRAM_raw_s  ALT_SYSMGR_ROMCODE_WARMRAM_raw_t;
+ * The struct declaration for register group ALT_SYSMGR_ROMCODE.
+struct ALT_SYSMGR_ROMCODE_s
+    volatile ALT_SYSMGR_ROMCODE_CTL_t             ctrl;                   /* ALT_SYSMGR_ROMCODE_CTL */
+    volatile ALT_SYSMGR_ROMCODE_CPU1STARTADDR_t   cpu1startaddr;          /* ALT_SYSMGR_ROMCODE_CPU1STARTADDR */
+    volatile ALT_SYSMGR_ROMCODE_INITSWSTATE_t     initswstate;            /* ALT_SYSMGR_ROMCODE_INITSWSTATE */
+    volatile ALT_SYSMGR_ROMCODE_INITSWLASTLD_t    initswlastld;           /* ALT_SYSMGR_ROMCODE_INITSWLASTLD */
+    volatile ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE_t  bootromswstate;         /* ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE */
+    volatile uint32_t                             _pad_0x14_0x1f[3];      /* *UNDEFINED* */
+    volatile ALT_SYSMGR_ROMCODE_WARMRAM_t         romcodegrp_warmramgrp;  /* ALT_SYSMGR_ROMCODE_WARMRAM */
+/* The typedef declaration for register group ALT_SYSMGR_ROMCODE. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_s  ALT_SYSMGR_ROMCODE_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE. */
+struct ALT_SYSMGR_ROMCODE_raw_s
+    volatile uint32_t                          ctrl;                   /* ALT_SYSMGR_ROMCODE_CTL */
+    volatile uint32_t                          cpu1startaddr;          /* ALT_SYSMGR_ROMCODE_CPU1STARTADDR */
+    volatile uint32_t                          initswstate;            /* ALT_SYSMGR_ROMCODE_INITSWSTATE */
+    volatile uint32_t                          initswlastld;           /* ALT_SYSMGR_ROMCODE_INITSWLASTLD */
+    volatile uint32_t                          bootromswstate;         /* ALT_SYSMGR_ROMCODE_BOOTROMSWSTATE */
+    volatile ALT_SYSMGR_ROMCODE_WARMRAM_raw_t  romcodegrp_warmramgrp;  /* ALT_SYSMGR_ROMCODE_WARMRAM */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ROMCODE. */
+typedef volatile struct ALT_SYSMGR_ROMCODE_raw_s  ALT_SYSMGR_ROMCODE_raw_t;
+ * Register Group : Boot ROM Hardware Register Group - ALT_SYSMGR_ROMHW
+ * Boot ROM Hardware Register Group
+ * Registers used by the Boot ROM hardware, not the code within it.
+ * Register : Boot ROM Hardware Control Register - ctrl
+ * Controls behavior of Boot ROM hardware.
+ * All fields are only reset by a cold reset (ignore warm reset).
+ * Register Layout
+ *  [0]    | RW     | 0x0   | Wait State
+ *  [1]    | RW     | 0x1   | Enable Safe Mode Warm Reset Update
+ * Field : Wait State - waitstate
+ * Controls the number of wait states applied to the Boot ROM's read operation.
+ * This field is cleared on a cold reset and optionally updated by hardware upon
+ * deassertion of warm reset.
+ * Field Enumeration Values:
+ *  Enum                                 | Value | Description
+ *  ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_DIS | 0x0   | No wait states are applied to the Boom ROM's
+ * :                                     |       | read operation.
+ *  ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_EN  | 0x1   | A single wait state is applied to the Boot ROM's
+ * Enumerated value for register field ALT_SYSMGR_ROMHW_CTL_WAITSTATE
+ * No wait states are applied to the Boom ROM's read operation.
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_DIS    0x0
+ * A single wait state is applied to the Boot ROM's read operation.
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_E_EN     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_MSB        0
+/* The width in bits of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field value. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field value. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_RESET      0x0
+/* Extracts the ALT_SYSMGR_ROMHW_CTL_WAITSTATE field value from a register. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ROMHW_CTL_WAITSTATE register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMHW_CTL_WAITSTATE_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Enable Safe Mode Warm Reset Update - ensfmdwru
+ * Controls whether the wait state bit is updated upon deassertion of warm reset.
+ * This field is set on a cold reset.
+ *  ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_DIS | 0x0   | Wait state bit is not updated upon deassertion
+ * :                                     |       | of warm reset.
+ *  ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_EN  | 0x1   | Wait state bit is updated upon deassertion of
+ * :                                     |       | warm reset. It's value is updated based on the
+ * :                                     |       | control bit from clock manager which specifies
+ * :                                     |       | whether clock manager will be in safe mode or
+ * :                                     |       | not after warm reset.
+ * Enumerated value for register field ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU
+ * Wait state bit is not updated upon deassertion of warm reset.
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_DIS    0x0
+ * Wait state bit is updated upon deassertion of warm reset.
+ * It's value is updated based on the control bit from clock manager which
+ * specifies whether clock manager will be in safe mode or not after warm reset.
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_E_EN     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_MSB        1
+/* The width in bits of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field value. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field value. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_RESET      0x1
+/* Extracts the ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU field value from a register. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU register field value suitable for setting the register. */
+#define ALT_SYSMGR_ROMHW_CTL_ENSFMDWRU_SET(value) (((value) << 1) & 0x00000002)
+ * The struct declaration for register ALT_SYSMGR_ROMHW_CTL.
+struct ALT_SYSMGR_ROMHW_CTL_s
+    uint32_t  waitstate :  1;  /* Wait State */
+    uint32_t  ensfmdwru :  1;  /* Enable Safe Mode Warm Reset Update */
+/* The typedef declaration for register ALT_SYSMGR_ROMHW_CTL. */
+typedef volatile struct ALT_SYSMGR_ROMHW_CTL_s  ALT_SYSMGR_ROMHW_CTL_t;
+/* The byte offset of the ALT_SYSMGR_ROMHW_CTL register from the beginning of the component. */
+#define ALT_SYSMGR_ROMHW_CTL_OFST        0x0
+ * The struct declaration for register group ALT_SYSMGR_ROMHW.
+struct ALT_SYSMGR_ROMHW_s
+    volatile ALT_SYSMGR_ROMHW_CTL_t  ctrl;  /* ALT_SYSMGR_ROMHW_CTL */
+/* The typedef declaration for register group ALT_SYSMGR_ROMHW. */
+typedef volatile struct ALT_SYSMGR_ROMHW_s  ALT_SYSMGR_ROMHW_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_ROMHW. */
+struct ALT_SYSMGR_ROMHW_raw_s
+    volatile uint32_t  ctrl;  /* ALT_SYSMGR_ROMHW_CTL */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ROMHW. */
+typedef volatile struct ALT_SYSMGR_ROMHW_raw_s  ALT_SYSMGR_ROMHW_raw_t;
+ * Register Group : SDMMC Controller Group - ALT_SYSMGR_SDMMC
+ * SDMMC Controller Group
+ * Registers related to SDMMC Controller which aren't located inside the SDMMC
+ * itself.
+ * Register : Control Register - ctrl
+ * Registers used by the SDMMC Controller. All fields are reset by a cold or warm
+ * reset.
+ * Register Layout
+ *  [2:0]  | RW     | 0x0   | Drive Clock Phase Shift Select
+ *  [5:3]  | RW     | 0x0   | Sample Clock Phase Shift Select
+ *  [6]    | RW     | 0x0   | Feedback Clock Select
+ *  [31:7] | ???    | 0x0   | *UNDEFINED*
+ * Field : Drive Clock Phase Shift Select - drvsel
+ * Select which phase shift of the clock for cclk_in_drv.
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES0   | 0x0   | 0 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES45  | 0x1   | 45 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES90  | 0x2   | 90 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES135 | 0x3   | 135 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES180 | 0x4   | 180 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES225 | 0x5   | 225 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES270 | 0x6   | 270 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES315 | 0x7   | 315 degrees phase shifted clock is selected
+ * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_DRVSEL
+ * 0 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES0      0x0
+ * 45 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES45     0x1
+ * 90 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES90     0x2
+ * 135 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES135    0x3
+ * 180 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES180    0x4
+ * 225 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES225    0x5
+ * 270 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES270    0x6
+ * 315 degrees phase shifted clock is selected
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_E_DEGREES315    0x7
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_MSB        2
+/* The width in bits of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_WIDTH      3
+/* The mask used to set the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field value. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_SET_MSK    0x00000007
+/* The mask used to clear the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field value. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_CLR_MSK    0xfffffff8
+/* The reset value of the ALT_SYSMGR_SDMMC_CTL_DRVSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_SDMMC_CTL_DRVSEL field value from a register. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_GET(value) (((value) & 0x00000007) >> 0)
+/* Produces a ALT_SYSMGR_SDMMC_CTL_DRVSEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_SDMMC_CTL_DRVSEL_SET(value) (((value) << 0) & 0x00000007)
+ * Field : Sample Clock Phase Shift Select - smplsel
+ * Select which phase shift of the clock for cclk_in_sample.
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES0   | 0x0   | 0 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES45  | 0x1   | 45 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES90  | 0x2   | 90 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES135 | 0x3   | 135 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES180 | 0x4   | 180 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES225 | 0x5   | 225 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES270 | 0x6   | 270 degrees phase shifted clock is selected
+ *  ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES315 | 0x7   | 315 degrees phase shifted clock is selected
+ * Enumerated value for register field ALT_SYSMGR_SDMMC_CTL_SMPLSEL
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES0     0x0
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES45    0x1
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES90    0x2
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES135   0x3
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES180   0x4
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES225   0x5
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES270   0x6
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_E_DEGREES315   0x7
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_MSB        5
+/* The width in bits of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_WIDTH      3
+/* The mask used to set the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field value. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_SET_MSK    0x00000038
+/* The mask used to clear the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field value. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_CLR_MSK    0xffffffc7
+/* The reset value of the ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_SDMMC_CTL_SMPLSEL field value from a register. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_GET(value) (((value) & 0x00000038) >> 3)
+/* Produces a ALT_SYSMGR_SDMMC_CTL_SMPLSEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_SDMMC_CTL_SMPLSEL_SET(value) (((value) << 3) & 0x00000038)
+ * Field : Feedback Clock Select - fbclksel
+ * Select which fb_clk to be used as cclk_in_sample.
+ * If 0, cclk_in_sample is driven by internal phase shifted cclk_in.
+ * If 1, cclk_in_sample is driven by fb_clk_in. No phase shifting is provided
+ * internally on cclk_in_sample.
+ * Note: Using the feedback clock (setting this bit to 1) is not a supported use
+ * model.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_MSB        6
+/* The width in bits of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field value. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field value. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_SDMMC_CTL_FBCLKSEL field value from a register. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_SDMMC_CTL_FBCLKSEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_SDMMC_CTL_FBCLKSEL_SET(value) (((value) << 6) & 0x00000040)
+ * The struct declaration for register ALT_SYSMGR_SDMMC_CTL.
+struct ALT_SYSMGR_SDMMC_CTL_s
+    uint32_t  drvsel   :  3;  /* Drive Clock Phase Shift Select */
+    uint32_t  smplsel  :  3;  /* Sample Clock Phase Shift Select */
+    uint32_t  fbclksel :  1;  /* Feedback Clock Select */
+    uint32_t           : 25;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_SDMMC_CTL. */
+typedef volatile struct ALT_SYSMGR_SDMMC_CTL_s  ALT_SYSMGR_SDMMC_CTL_t;
+/* The byte offset of the ALT_SYSMGR_SDMMC_CTL register from the beginning of the component. */
+#define ALT_SYSMGR_SDMMC_CTL_OFST        0x0
+ * Register : SD/MMC L3 Master HPROT Register - l3master
+ * Controls the L3 master HPROT AHB-Lite signal.
+ * These register bits should be updated only during system initialization prior to
+ * removing the peripheral from reset. They may not be changed dynamically during
+ * peripheral operation
+ * All fields are reset by a cold or warm reset.
+ * Register Layout
+ *  [0]    | RW     | 0x1   | SD/MMC HPROT Data/Opcode
+ *  [1]    | RW     | 0x1   | SD/MMC HPROT Privileged
+ *  [2]    | RW     | 0x0   | SD/MMC HPROT Bufferable
+ *  [3]    | RW     | 0x0   | SD/MMC HPROT Cacheable
+ *  [31:4] | ???    | 0x0   | *UNDEFINED*
+ * Field : SD/MMC HPROT Data/Opcode - hprotdata_0
+ * Specifies if the L3 master access is for data or opcode for the SD/MMC module.
+ *  ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_OPCODE | 0x0   | Opcode fetch
+ *  ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_DATA   | 0x1   | Data access
+ * Enumerated value for register field ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0
+ * Opcode fetch
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_OPCODE 0x0
+ * Data access
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_E_DATA   0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_MSB        0
+/* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_RESET      0x1
+/* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 field value from a register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTDATA_0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : SD/MMC HPROT Privileged - hprotpriv_0
+ * If 1, L3 master accesses for the SD/MMC module are privileged.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_MSB        1
+/* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_RESET      0x1
+/* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 field value from a register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTPRIV_0_SET(value) (((value) << 1) & 0x00000002)
+ * Field : SD/MMC HPROT Bufferable - hprotbuff_0
+ * If 1, L3 master accesses for the SD/MMC module are bufferable.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_MSB        2
+/* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 field value from a register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTBUFF_0_SET(value) (((value) << 2) & 0x00000004)
+ * Field : SD/MMC HPROT Cacheable - hprotcache_0
+ * If 1, L3 master accesses for the SD/MMC module are cacheable.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_MSB        3
+/* The width in bits of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field value. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 field value from a register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_SDMMC_L3MST_HPROTCACHE_0_SET(value) (((value) << 3) & 0x00000008)
+ * The struct declaration for register ALT_SYSMGR_SDMMC_L3MST.
+struct ALT_SYSMGR_SDMMC_L3MST_s
+    uint32_t  hprotdata_0  :  1;  /* SD/MMC HPROT Data/Opcode */
+    uint32_t  hprotpriv_0  :  1;  /* SD/MMC HPROT Privileged */
+    uint32_t  hprotbuff_0  :  1;  /* SD/MMC HPROT Bufferable */
+    uint32_t  hprotcache_0 :  1;  /* SD/MMC HPROT Cacheable */
+    uint32_t               : 28;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_SDMMC_L3MST. */
+typedef volatile struct ALT_SYSMGR_SDMMC_L3MST_s  ALT_SYSMGR_SDMMC_L3MST_t;
+/* The byte offset of the ALT_SYSMGR_SDMMC_L3MST register from the beginning of the component. */
+#define ALT_SYSMGR_SDMMC_L3MST_OFST        0x4
+ * The struct declaration for register group ALT_SYSMGR_SDMMC.
+struct ALT_SYSMGR_SDMMC_s
+    volatile ALT_SYSMGR_SDMMC_CTL_t    ctrl;      /* ALT_SYSMGR_SDMMC_CTL */
+    volatile ALT_SYSMGR_SDMMC_L3MST_t  l3master;  /* ALT_SYSMGR_SDMMC_L3MST */
+/* The typedef declaration for register group ALT_SYSMGR_SDMMC. */
+typedef volatile struct ALT_SYSMGR_SDMMC_s  ALT_SYSMGR_SDMMC_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_SDMMC. */
+struct ALT_SYSMGR_SDMMC_raw_s
+    volatile uint32_t  ctrl;      /* ALT_SYSMGR_SDMMC_CTL */
+    volatile uint32_t  l3master;  /* ALT_SYSMGR_SDMMC_L3MST */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_SDMMC. */
+typedef volatile struct ALT_SYSMGR_SDMMC_raw_s  ALT_SYSMGR_SDMMC_raw_t;
+ * Register Group : NAND Flash Controller Register Group - ALT_SYSMGR_NAND
+ * NAND Flash Controller Register Group
+ * Registers related to NAND Flash Controller which aren't located in the NAND
+ * Flash Controller itself.
+ * Register : Bootstrap Control Register - bootstrap
+ * Bootstrap fields sampled by NAND Flash Controller when released from reset.
+ * Register Layout
+ *  [0]    | RW     | 0x0   | Bootstrap Inhibit Initialization
+ *  [1]    | RW     | 0x0   | Bootstrap 512 Byte Device
+ *  [2]    | RW     | 0x0   | Bootstrap Inhibit Load Block 0 Page 0
+ *  [3]    | RW     | 0x0   | Bootstrap Two Row Address Cycles
+ * Field : Bootstrap Inhibit Initialization - noinit
+ * If 1, inhibits NAND Flash Controller from performing initialization when coming
+ * out of reset. Instead, software must program all registers pertaining to device
+ * parameters like page size, width, etc.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_MSB        0
+/* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_RESET      0x0
+/* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT field value from a register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT register field value suitable for setting the register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOINIT_SET(value) (((value) << 0) & 0x00000001)
+ * Field : Bootstrap 512 Byte Device - page512
+ * If 1, NAND device has a 512 byte page size.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_MSB        1
+/* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_RESET      0x0
+/* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 field value from a register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512 register field value suitable for setting the register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_PAGE512_SET(value) (((value) << 1) & 0x00000002)
+ * Field : Bootstrap Inhibit Load Block 0 Page 0 - noloadb0p0
+ * If 1, inhibits NAND Flash Controller from loading page 0 of block 0 of the NAND
+ * device as part of the initialization procedure.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_MSB        2
+/* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_RESET      0x0
+/* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 field value from a register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_NOLDB0P0_SET(value) (((value) << 2) & 0x00000004)
+ * Field : Bootstrap Two Row Address Cycles - tworowaddr
+ * If 1, NAND device requires only 2 row address cycles instead of the normal 3 row
+ * address cycles.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_MSB        3
+/* The width in bits of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field value. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_RESET      0x0
+/* Extracts the ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR field value from a register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR register field value suitable for setting the register. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_TWOROWADDR_SET(value) (((value) << 3) & 0x00000008)
+ * The struct declaration for register ALT_SYSMGR_NAND_BOOTSTRAP.
+struct ALT_SYSMGR_NAND_BOOTSTRAP_s
+    uint32_t  noinit     :  1;  /* Bootstrap Inhibit Initialization */
+    uint32_t  page512    :  1;  /* Bootstrap 512 Byte Device */
+    uint32_t  noloadb0p0 :  1;  /* Bootstrap Inhibit Load Block 0 Page 0 */
+    uint32_t  tworowaddr :  1;  /* Bootstrap Two Row Address Cycles */
+/* The typedef declaration for register ALT_SYSMGR_NAND_BOOTSTRAP. */
+typedef volatile struct ALT_SYSMGR_NAND_BOOTSTRAP_s  ALT_SYSMGR_NAND_BOOTSTRAP_t;
+/* The byte offset of the ALT_SYSMGR_NAND_BOOTSTRAP register from the beginning of the component. */
+#define ALT_SYSMGR_NAND_BOOTSTRAP_OFST        0x0
+ * Register : NAND L3 Master AxCACHE Register - l3master
+ * Controls the L3 master ARCACHE and AWCACHE AXI signals.
+ * Register Layout
+ *  [3:0]  | RW     | 0x0   | NAND ARCACHE
+ *  [7:4]  | RW     | 0x0   | NAND AWCACHE
+ *  [31:8] | ???    | 0x0   | *UNDEFINED*
+ * Field : NAND ARCACHE - arcache_0
+ * Specifies the value of the module ARCACHE signal.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF     | 0x0   | Noncacheable and nonbufferable.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_BUFF                 | 0x1   | Bufferable only.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_NONALLOC       | 0x2   | Cacheable, but do not allocate.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC  | 0x3   | Cacheable and bufferable, but do not allocate.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD1                | 0x4   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD2                | 0x5   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6   | Cacheable write-through, allocate on reads only.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7   | Cacheable write-back, allocate on reads only.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD3                | 0x8   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD4                | 0x9   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa   | Cacheable write-through, allocate on writes
+ * :                                                       |       | only.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb   | Cacheable write-back, allocate on writes only.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD5                | 0xc   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD6                | 0xd   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC   | 0xe   | Cacheable write-through, allocate on both reads
+ * :                                                       |       | and writes.
+ *  ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC   | 0xf   | Cacheable write-back, allocate on both reads and
+ * :                                                       |       | writes.
+ * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_ARCACHE_0
+ * Noncacheable and nonbufferable.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_NONCACHE_NONBUFF      0x0
+ * Bufferable only.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_BUFF                  0x1
+ * Cacheable, but do not allocate.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_NONALLOC        0x2
+ * Cacheable and bufferable, but do not allocate.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_BUFF_NONALLOC   0x3
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD1                 0x4
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD2                 0x5
+ * Cacheable write-through, allocate on reads only.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_RDALLOC  0x6
+ * Cacheable write-back, allocate on reads only.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_RDALLOC  0x7
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD3                 0x8
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD4                 0x9
+ * Cacheable write-through, allocate on writes only.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_WRALLOC  0xa
+ * Cacheable write-back, allocate on writes only.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_WRALLOC  0xb
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD5                 0xc
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_RSVD6                 0xd
+ * Cacheable write-through, allocate on both reads and writes.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRTHRU_ALLOC    0xe
+ * Cacheable write-back, allocate on both reads and writes.
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_E_CACHE_WRBACK_ALLOC    0xf
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_MSB        3
+/* The width in bits of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_WIDTH      4
+/* The mask used to set the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field value. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_SET_MSK    0x0000000f
+/* The mask used to clear the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field value. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_CLR_MSK    0xfffffff0
+/* The reset value of the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_NAND_L3MST_ARCACHE_0 field value from a register. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_GET(value) (((value) & 0x0000000f) >> 0)
+/* Produces a ALT_SYSMGR_NAND_L3MST_ARCACHE_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_NAND_L3MST_ARCACHE_0_SET(value) (((value) << 0) & 0x0000000f)
+ * Field : NAND AWCACHE - awcache_0
+ * Specifies the value of the module AWCACHE signal.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF     | 0x0   | Noncacheable and nonbufferable.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_BUFF                 | 0x1   | Bufferable only.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_NONALLOC       | 0x2   | Cacheable, but do not allocate.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC  | 0x3   | Cacheable and bufferable, but do not allocate.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD1                | 0x4   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD2                | 0x5   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC | 0x6   | Cacheable write-through, allocate on reads only.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC | 0x7   | Cacheable write-back, allocate on reads only.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD3                | 0x8   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD4                | 0x9   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC | 0xa   | Cacheable write-through, allocate on writes
+ * :                                                       |       | only.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC | 0xb   | Cacheable write-back, allocate on writes only.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD5                | 0xc   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD6                | 0xd   | Reserved.
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC   | 0xe   | Cacheable write-through, allocate on both reads
+ *  ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC   | 0xf   | Cacheable write-back, allocate on both reads and
+ * :                                                       |       | writes.
+ * Enumerated value for register field ALT_SYSMGR_NAND_L3MST_AWCACHE_0
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_NONCACHE_NONBUFF      0x0
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_BUFF                  0x1
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_NONALLOC        0x2
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_BUFF_NONALLOC   0x3
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD1                 0x4
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD2                 0x5
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_RDALLOC  0x6
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_RDALLOC  0x7
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD3                 0x8
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD4                 0x9
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_WRALLOC  0xa
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_WRALLOC  0xb
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD5                 0xc
+ * Reserved.
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_RSVD6                 0xd
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRTHRU_ALLOC    0xe
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_E_CACHE_WRBACK_ALLOC    0xf
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_MSB        7
+/* The width in bits of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_WIDTH      4
+/* The mask used to set the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field value. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_SET_MSK    0x000000f0
+/* The mask used to clear the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field value. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_CLR_MSK    0xffffff0f
+/* The reset value of the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_NAND_L3MST_AWCACHE_0 field value from a register. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_GET(value) (((value) & 0x000000f0) >> 4)
+/* Produces a ALT_SYSMGR_NAND_L3MST_AWCACHE_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_NAND_L3MST_AWCACHE_0_SET(value) (((value) << 4) & 0x000000f0)
+ * The struct declaration for register ALT_SYSMGR_NAND_L3MST.
+struct ALT_SYSMGR_NAND_L3MST_s
+    uint32_t  arcache_0 :  4;  /* NAND ARCACHE */
+    uint32_t  awcache_0 :  4;  /* NAND AWCACHE */
+    uint32_t            : 24;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_NAND_L3MST. */
+typedef volatile struct ALT_SYSMGR_NAND_L3MST_s  ALT_SYSMGR_NAND_L3MST_t;
+/* The byte offset of the ALT_SYSMGR_NAND_L3MST register from the beginning of the component. */
+#define ALT_SYSMGR_NAND_L3MST_OFST        0x4
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register group ALT_SYSMGR_NAND.
+struct ALT_SYSMGR_NAND_s
+    volatile ALT_SYSMGR_NAND_BOOTSTRAP_t  bootstrap;  /* ALT_SYSMGR_NAND_BOOTSTRAP */
+    volatile ALT_SYSMGR_NAND_L3MST_t      l3master;   /* ALT_SYSMGR_NAND_L3MST */
+/* The typedef declaration for register group ALT_SYSMGR_NAND. */
+typedef volatile struct ALT_SYSMGR_NAND_s  ALT_SYSMGR_NAND_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_NAND. */
+struct ALT_SYSMGR_NAND_raw_s
+    volatile uint32_t  bootstrap;  /* ALT_SYSMGR_NAND_BOOTSTRAP */
+    volatile uint32_t  l3master;   /* ALT_SYSMGR_NAND_L3MST */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_NAND. */
+typedef volatile struct ALT_SYSMGR_NAND_raw_s  ALT_SYSMGR_NAND_raw_t;
+ * Register Group : USB Controller Group - ALT_SYSMGR_USB
+ * USB Controller Group
+ * Registers related to USB Controllers which aren't located inside the USB
+ * controllers themselves.
+ * Register : USB L3 Master HPROT Register - l3master
+ * Register Layout
+ *  [0]    | RW     | 0x1   | USB HPROT Data/Opcode
+ *  [1]    | RW     | 0x1   | USB HPROT Data/Opcode
+ *  [2]    | RW     | 0x1   | USB HPROT Privileged
+ *  [3]    | RW     | 0x1   | USB HPROT Privileged
+ *  [4]    | RW     | 0x0   | USB HPROT Bufferable
+ *  [5]    | RW     | 0x0   | USB HPROT Bufferable
+ *  [6]    | RW     | 0x0   | USB HPROT Cacheable
+ *  [7]    | RW     | 0x0   | USB HPROT Cacheable
+ * Field : USB HPROT Data/Opcode - hprotdata_0
+ * Specifies if the L3 master access is for data or opcode for the USB modules.
+ * The field array index corresponds to the USB index.
+ *  ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_OPCODE | 0x0   | Opcode fetch
+ *  ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_DATA   | 0x1   | Data access
+ * Field Access Macros:
+ * Enumerated value for register field ALT_SYSMGR_USB_L3MST_HPROTDATA_0
+ * Opcode fetch
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_OPCODE   0x0
+ * Data access
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_E_DATA     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_MSB        0
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_RESET      0x1
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTDATA_0 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTDATA_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_0_SET(value) (((value) << 0) & 0x00000001)
+ * Field : USB HPROT Data/Opcode - hprotdata_1
+ *  ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_OPCODE | 0x0   | Opcode fetch
+ *  ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_DATA   | 0x1   | Data access
+ * Enumerated value for register field ALT_SYSMGR_USB_L3MST_HPROTDATA_1
+ * Opcode fetch
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_OPCODE   0x0
+ * Data access
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_E_DATA     0x1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_MSB        1
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_RESET      0x1
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTDATA_1 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTDATA_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTDATA_1_SET(value) (((value) << 1) & 0x00000002)
+ * Field : USB HPROT Privileged - hprotpriv_0
+ * If 1, L3 master accesses for the USB modules are privileged.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_MSB        2
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_RESET      0x1
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTPRIV_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_0_SET(value) (((value) << 2) & 0x00000004)
+ * Field : USB HPROT Privileged - hprotpriv_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_MSB        3
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_RESET      0x1
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTPRIV_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTPRIV_1_SET(value) (((value) << 3) & 0x00000008)
+ * Field : USB HPROT Bufferable - hprotbuff_0
+ * If 1, L3 master accesses for the USB modules are bufferable.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_MSB        4
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTBUFF_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_0_SET(value) (((value) << 4) & 0x00000010)
+ * Field : USB HPROT Bufferable - hprotbuff_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_MSB        5
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTBUFF_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTBUFF_1_SET(value) (((value) << 5) & 0x00000020)
+ * Field : USB HPROT Cacheable - hprotcache_0
+ * If 1, L3 master accesses for the USB modules are cacheable.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_MSB        6
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_RESET      0x0
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTCACHE_0 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_0_SET(value) (((value) << 6) & 0x00000040)
+ * Field : USB HPROT Cacheable - hprotcache_1
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_MSB        7
+/* The width in bits of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field value. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_RESET      0x0
+/* Extracts the ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 field value from a register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_USB_L3MST_HPROTCACHE_1 register field value suitable for setting the register. */
+#define ALT_SYSMGR_USB_L3MST_HPROTCACHE_1_SET(value) (((value) << 7) & 0x00000080)
+ * The struct declaration for register ALT_SYSMGR_USB_L3MST.
+struct ALT_SYSMGR_USB_L3MST_s
+    uint32_t  hprotdata_0  :  1;  /* USB HPROT Data/Opcode */
+    uint32_t  hprotdata_1  :  1;  /* USB HPROT Data/Opcode */
+    uint32_t  hprotpriv_0  :  1;  /* USB HPROT Privileged */
+    uint32_t  hprotpriv_1  :  1;  /* USB HPROT Privileged */
+    uint32_t  hprotbuff_0  :  1;  /* USB HPROT Bufferable */
+    uint32_t  hprotbuff_1  :  1;  /* USB HPROT Bufferable */
+    uint32_t  hprotcache_0 :  1;  /* USB HPROT Cacheable */
+    uint32_t  hprotcache_1 :  1;  /* USB HPROT Cacheable */
+/* The typedef declaration for register ALT_SYSMGR_USB_L3MST. */
+typedef volatile struct ALT_SYSMGR_USB_L3MST_s  ALT_SYSMGR_USB_L3MST_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SYSMGR_USB_L3MST register from the beginning of the component. */
+#define ALT_SYSMGR_USB_L3MST_OFST        0x0
+ * The struct declaration for register group ALT_SYSMGR_USB.
+struct ALT_SYSMGR_USB_s
+    volatile ALT_SYSMGR_USB_L3MST_t  l3master;  /* ALT_SYSMGR_USB_L3MST */
+/* The typedef declaration for register group ALT_SYSMGR_USB. */
+typedef volatile struct ALT_SYSMGR_USB_s  ALT_SYSMGR_USB_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_USB. */
+struct ALT_SYSMGR_USB_raw_s
+    volatile uint32_t  l3master;  /* ALT_SYSMGR_USB_L3MST */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_USB. */
+typedef volatile struct ALT_SYSMGR_USB_raw_s  ALT_SYSMGR_USB_raw_t;
+ * Register Group : ECC Management Register Group - ALT_SYSMGR_ECC
+ * ECC Management Register Group
+ * ECC error status and control for all ECC-protected HPS RAM blocks.
+ * Register : L2 Data RAM ECC Enable Register - l2
+ * This register is used to enable ECC on the L2 Data RAM. ECC errors can be
+ * injected into the write path using bits in this register. This register contains
+ * interrupt status of the ECC single/double bit error.
+ * Only reset by a cold reset (ignores warm reset).
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [0]    | RW     | 0x0   | L2 Data RAM ECC Enable
+ *  [1]    | RW     | 0x0   | L2 Data RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | L2 Data RAM ECC inject double bit, non-correctable error
+ *  [31:3] | ???    | 0x0   | *UNDEFINED*
+ * Field : L2 Data RAM ECC Enable - en
+ * Enable ECC for L2 Data RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_L2_EN register field. */
+#define ALT_SYSMGR_ECC_L2_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_L2_EN register field. */
+#define ALT_SYSMGR_ECC_L2_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_L2_EN register field. */
+#define ALT_SYSMGR_ECC_L2_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_L2_EN register field value. */
+#define ALT_SYSMGR_ECC_L2_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_L2_EN register field value. */
+#define ALT_SYSMGR_ECC_L2_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_L2_EN register field. */
+#define ALT_SYSMGR_ECC_L2_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_L2_EN field value from a register. */
+#define ALT_SYSMGR_ECC_L2_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_L2_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_L2_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : L2 Data RAM ECC inject single, correctable Error - injs
+ * Changing this bit from zero to one injects a single, correctable error into the
+ * L2 Data RAM. This only injects one error into the L2 Data RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_L2_INJS register field. */
+#define ALT_SYSMGR_ECC_L2_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_L2_INJS register field. */
+#define ALT_SYSMGR_ECC_L2_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_L2_INJS register field. */
+#define ALT_SYSMGR_ECC_L2_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_L2_INJS register field value. */
+#define ALT_SYSMGR_ECC_L2_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_L2_INJS register field value. */
+#define ALT_SYSMGR_ECC_L2_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_L2_INJS register field. */
+#define ALT_SYSMGR_ECC_L2_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_L2_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_L2_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_L2_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_L2_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : L2 Data RAM ECC inject double bit, non-correctable error - injd
+ * Changing this bit from zero to one injects a double, non-correctable error into
+ * the L2 Data RAM. This only injects one double bit error into the L2 Data RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_L2_INJD register field. */
+#define ALT_SYSMGR_ECC_L2_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_L2_INJD register field. */
+#define ALT_SYSMGR_ECC_L2_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_L2_INJD register field. */
+#define ALT_SYSMGR_ECC_L2_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_L2_INJD register field value. */
+#define ALT_SYSMGR_ECC_L2_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_L2_INJD register field value. */
+#define ALT_SYSMGR_ECC_L2_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_L2_INJD register field. */
+#define ALT_SYSMGR_ECC_L2_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_L2_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_L2_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_L2_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_L2_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * The struct declaration for register ALT_SYSMGR_ECC_L2.
+struct ALT_SYSMGR_ECC_L2_s
+    uint32_t  en   :  1;  /* L2 Data RAM ECC Enable */
+    uint32_t  injs :  1;  /* L2 Data RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* L2 Data RAM ECC inject double bit, non-correctable error */
+    uint32_t       : 29;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_ECC_L2. */
+typedef volatile struct ALT_SYSMGR_ECC_L2_s  ALT_SYSMGR_ECC_L2_t;
+/* The byte offset of the ALT_SYSMGR_ECC_L2 register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_L2_OFST        0x0
+ * Register : On-chip RAM ECC Enable Register - ocram
+ * This register is used to enable ECC on the On-chip RAM. ECC errors can be
+ * Register Layout
+ *  [0]    | RW     | 0x0   | On-chip RAM ECC Enable
+ *  [1]    | RW     | 0x0   | On-chip RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | On-chip RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | On-chip RAM ECC single, correctable error interrupt status
+ *  [4]    | RW     | 0x0   | On-chip RAM ECC double bit, non-correctable error interrupt status
+ *  [31:5] | ???    | 0x0   | *UNDEFINED*
+ * Field : On-chip RAM ECC Enable - en
+ * Enable ECC for On-chip RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_OCRAM_EN register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_EN register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_OCRAM_EN register field. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_OCRAM_EN field value from a register. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_OCRAM_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_OCRAM_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : On-chip RAM ECC inject single, correctable Error - injs
+ * On-chip RAM. This only injects one error into the On-chip RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_OCRAM_INJS register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_INJS register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_OCRAM_INJS register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_OCRAM_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_OCRAM_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_OCRAM_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : On-chip RAM ECC inject double bit, non-correctable error - injd
+ * the On-chip RAM. This only injects one double bit error into the On-chip RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_OCRAM_INJD register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_INJD register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_OCRAM_INJD register field. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_OCRAM_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_OCRAM_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_OCRAM_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : On-chip RAM ECC single, correctable error interrupt status - serr
+ * This bit is an interrupt status bit for On-chip RAM ECC single, correctable
+ * error. It is set by hardware when single, correctable error occurs in On-chip
+ * RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_OCRAM_SERR register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_SERR register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_OCRAM_SERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_OCRAM_SERR field value from a register. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_OCRAM_SERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_OCRAM_SERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : On-chip RAM ECC double bit, non-correctable error interrupt status - derr
+ * This bit is an interrupt status bit for On-chip RAM ECC double bit, non-
+ * correctable error. It is set by hardware when double bit, non-correctable error
+ * occurs in On-chip RAM. Software needs to write 1 into this bit to clear the
+ * interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_OCRAM_DERR register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_OCRAM_DERR register field value. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_OCRAM_DERR register field. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_OCRAM_DERR field value from a register. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_OCRAM_DERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_OCRAM_DERR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_ECC_OCRAM.
+struct ALT_SYSMGR_ECC_OCRAM_s
+    uint32_t  en   :  1;  /* On-chip RAM ECC Enable */
+    uint32_t  injs :  1;  /* On-chip RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* On-chip RAM ECC inject double bit, non-correctable error */
+    uint32_t  serr :  1;  /* On-chip RAM ECC single, correctable error interrupt status */
+    uint32_t  derr :  1;  /* On-chip RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t       : 27;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_ECC_OCRAM. */
+typedef volatile struct ALT_SYSMGR_ECC_OCRAM_s  ALT_SYSMGR_ECC_OCRAM_t;
+/* The byte offset of the ALT_SYSMGR_ECC_OCRAM register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_OCRAM_OFST        0x4
+ * Register : USB0 RAM ECC Enable Register - usb0
+ * This register is used to enable ECC on the USB0 RAM. ECC errors can be injected
+ * into the write path using bits in this register. This register contains
+ * Register Layout
+ *  [0]    | RW     | 0x0   | USB0 RAM ECC Enable
+ *  [1]    | RW     | 0x0   | USB0 RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | USB0 RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | USB0 RAM ECC single, correctable error interrupt status
+ *  [4]    | RW     | 0x0   | USB0 RAM ECC double bit, non-correctable error interrupt status
+ * Field : USB0 RAM ECC Enable - en
+ * Enable ECC for USB0 RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_EN register field. */
+#define ALT_SYSMGR_ECC_USB0_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_EN register field. */
+#define ALT_SYSMGR_ECC_USB0_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_USB0_EN register field. */
+#define ALT_SYSMGR_ECC_USB0_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB0_EN register field value. */
+#define ALT_SYSMGR_ECC_USB0_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_USB0_EN register field value. */
+#define ALT_SYSMGR_ECC_USB0_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_USB0_EN register field. */
+#define ALT_SYSMGR_ECC_USB0_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB0_EN field value from a register. */
+#define ALT_SYSMGR_ECC_USB0_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_USB0_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB0_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : USB0 RAM ECC inject single, correctable Error - injs
+ * USB0 RAM. This only injects one error into the USB0 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_INJS register field. */
+#define ALT_SYSMGR_ECC_USB0_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_INJS register field. */
+#define ALT_SYSMGR_ECC_USB0_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_USB0_INJS register field. */
+#define ALT_SYSMGR_ECC_USB0_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB0_INJS register field value. */
+#define ALT_SYSMGR_ECC_USB0_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_USB0_INJS register field value. */
+#define ALT_SYSMGR_ECC_USB0_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_USB0_INJS register field. */
+#define ALT_SYSMGR_ECC_USB0_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB0_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_USB0_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_USB0_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB0_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : USB0 RAM ECC inject double bit, non-correctable error - injd
+ * the USB0 RAM. This only injects one double bit error into the USB0 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_INJD register field. */
+#define ALT_SYSMGR_ECC_USB0_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_INJD register field. */
+#define ALT_SYSMGR_ECC_USB0_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_USB0_INJD register field. */
+#define ALT_SYSMGR_ECC_USB0_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB0_INJD register field value. */
+#define ALT_SYSMGR_ECC_USB0_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_USB0_INJD register field value. */
+#define ALT_SYSMGR_ECC_USB0_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_USB0_INJD register field. */
+#define ALT_SYSMGR_ECC_USB0_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB0_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_USB0_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_USB0_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB0_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : USB0 RAM ECC single, correctable error interrupt status - serr
+ * This bit is an interrupt status bit for USB0 RAM ECC single, correctable error.
+ * It is set by hardware when single, correctable error occurs in USB0 RAM.
+ * Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_SERR register field. */
+#define ALT_SYSMGR_ECC_USB0_SERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_SERR register field. */
+#define ALT_SYSMGR_ECC_USB0_SERR_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_USB0_SERR register field. */
+#define ALT_SYSMGR_ECC_USB0_SERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB0_SERR register field value. */
+#define ALT_SYSMGR_ECC_USB0_SERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_USB0_SERR register field value. */
+#define ALT_SYSMGR_ECC_USB0_SERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_USB0_SERR register field. */
+#define ALT_SYSMGR_ECC_USB0_SERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB0_SERR field value from a register. */
+#define ALT_SYSMGR_ECC_USB0_SERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_USB0_SERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB0_SERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : USB0 RAM ECC double bit, non-correctable error interrupt status - derr
+ * This bit is an interrupt status bit for USB0 RAM ECC double bit, non-correctable
+ * error. It is set by hardware when double bit, non-correctable error occurs in
+ * USB0 RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB0_DERR register field. */
+#define ALT_SYSMGR_ECC_USB0_DERR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB0_DERR register field. */
+#define ALT_SYSMGR_ECC_USB0_DERR_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_USB0_DERR register field. */
+#define ALT_SYSMGR_ECC_USB0_DERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB0_DERR register field value. */
+#define ALT_SYSMGR_ECC_USB0_DERR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_USB0_DERR register field value. */
+#define ALT_SYSMGR_ECC_USB0_DERR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_USB0_DERR register field. */
+#define ALT_SYSMGR_ECC_USB0_DERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB0_DERR field value from a register. */
+#define ALT_SYSMGR_ECC_USB0_DERR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_USB0_DERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB0_DERR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_ECC_USB0.
+struct ALT_SYSMGR_ECC_USB0_s
+    uint32_t  en   :  1;  /* USB0 RAM ECC Enable */
+    uint32_t  injs :  1;  /* USB0 RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* USB0 RAM ECC inject double bit, non-correctable error */
+    uint32_t  serr :  1;  /* USB0 RAM ECC single, correctable error interrupt status */
+    uint32_t  derr :  1;  /* USB0 RAM ECC double bit, non-correctable error interrupt status */
+/* The typedef declaration for register ALT_SYSMGR_ECC_USB0. */
+typedef volatile struct ALT_SYSMGR_ECC_USB0_s  ALT_SYSMGR_ECC_USB0_t;
+/* The byte offset of the ALT_SYSMGR_ECC_USB0 register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_USB0_OFST        0x8
+ * Register : USB1 RAM ECC Enable Register - usb1
+ * This register is used to enable ECC on the USB1 RAM. ECC errors can be injected
+ * Register Layout
+ *  [0]    | RW     | 0x0   | USB1 RAM ECC Enable
+ *  [1]    | RW     | 0x0   | USB1 RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | USB1 RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | USB1 RAM ECC single, correctable error interrupt status
+ *  [4]    | RW     | 0x0   | USB1 RAM ECC double bit, non-correctable error interrupt status
+ * Field : USB1 RAM ECC Enable - en
+ * Enable ECC for USB1 RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_EN register field. */
+#define ALT_SYSMGR_ECC_USB1_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_EN register field. */
+#define ALT_SYSMGR_ECC_USB1_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_USB1_EN register field. */
+#define ALT_SYSMGR_ECC_USB1_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB1_EN register field value. */
+#define ALT_SYSMGR_ECC_USB1_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_USB1_EN register field value. */
+#define ALT_SYSMGR_ECC_USB1_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_USB1_EN register field. */
+#define ALT_SYSMGR_ECC_USB1_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB1_EN field value from a register. */
+#define ALT_SYSMGR_ECC_USB1_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_USB1_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB1_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : USB1 RAM ECC inject single, correctable Error - injs
+ * USB1 RAM. This only injects one error into the USB1 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_INJS register field. */
+#define ALT_SYSMGR_ECC_USB1_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_INJS register field. */
+#define ALT_SYSMGR_ECC_USB1_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_USB1_INJS register field. */
+#define ALT_SYSMGR_ECC_USB1_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB1_INJS register field value. */
+#define ALT_SYSMGR_ECC_USB1_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_USB1_INJS register field value. */
+#define ALT_SYSMGR_ECC_USB1_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_USB1_INJS register field. */
+#define ALT_SYSMGR_ECC_USB1_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB1_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_USB1_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_USB1_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB1_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : USB1 RAM ECC inject double bit, non-correctable error - injd
+ * the USB1 RAM. This only injects one double bit error into the USB1 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_INJD register field. */
+#define ALT_SYSMGR_ECC_USB1_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_INJD register field. */
+#define ALT_SYSMGR_ECC_USB1_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_USB1_INJD register field. */
+#define ALT_SYSMGR_ECC_USB1_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB1_INJD register field value. */
+#define ALT_SYSMGR_ECC_USB1_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_USB1_INJD register field value. */
+#define ALT_SYSMGR_ECC_USB1_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_USB1_INJD register field. */
+#define ALT_SYSMGR_ECC_USB1_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB1_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_USB1_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_USB1_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB1_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : USB1 RAM ECC single, correctable error interrupt status - serr
+ * This bit is an interrupt status bit for USB1 RAM ECC single, correctable error.
+ * It is set by hardware when single, correctable error occurs in USB1 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_SERR register field. */
+#define ALT_SYSMGR_ECC_USB1_SERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_SERR register field. */
+#define ALT_SYSMGR_ECC_USB1_SERR_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_USB1_SERR register field. */
+#define ALT_SYSMGR_ECC_USB1_SERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB1_SERR register field value. */
+#define ALT_SYSMGR_ECC_USB1_SERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_USB1_SERR register field value. */
+#define ALT_SYSMGR_ECC_USB1_SERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_USB1_SERR register field. */
+#define ALT_SYSMGR_ECC_USB1_SERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB1_SERR field value from a register. */
+#define ALT_SYSMGR_ECC_USB1_SERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_USB1_SERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB1_SERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : USB1 RAM ECC double bit, non-correctable error interrupt status - derr
+ * This bit is an interrupt status bit for USB1 RAM ECC double bit, non-correctable
+ * USB1 RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_USB1_DERR register field. */
+#define ALT_SYSMGR_ECC_USB1_DERR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_USB1_DERR register field. */
+#define ALT_SYSMGR_ECC_USB1_DERR_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_USB1_DERR register field. */
+#define ALT_SYSMGR_ECC_USB1_DERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_USB1_DERR register field value. */
+#define ALT_SYSMGR_ECC_USB1_DERR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_USB1_DERR register field value. */
+#define ALT_SYSMGR_ECC_USB1_DERR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_USB1_DERR register field. */
+#define ALT_SYSMGR_ECC_USB1_DERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_USB1_DERR field value from a register. */
+#define ALT_SYSMGR_ECC_USB1_DERR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_USB1_DERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_USB1_DERR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_ECC_USB1.
+struct ALT_SYSMGR_ECC_USB1_s
+    uint32_t  en   :  1;  /* USB1 RAM ECC Enable */
+    uint32_t  injs :  1;  /* USB1 RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* USB1 RAM ECC inject double bit, non-correctable error */
+    uint32_t  serr :  1;  /* USB1 RAM ECC single, correctable error interrupt status */
+    uint32_t  derr :  1;  /* USB1 RAM ECC double bit, non-correctable error interrupt status */
+/* The typedef declaration for register ALT_SYSMGR_ECC_USB1. */
+typedef volatile struct ALT_SYSMGR_ECC_USB1_s  ALT_SYSMGR_ECC_USB1_t;
+/* The byte offset of the ALT_SYSMGR_ECC_USB1 register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_USB1_OFST        0xc
+ * Register : EMAC0 RAM ECC Enable Register - emac0
+ * This register is used to enable ECC on the EMAC0 RAM. ECC errors can be injected
+ * Register Layout
+ *  [0]    | RW     | 0x0   | EMAC0 RAM ECC Enable
+ *  [1]    | RW     | 0x0   | EMAC0 TXFIFO RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | EMAC0 TXFIFO RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | EMAC0 RXFIFO RAM ECC inject single, correctable Error
+ *  [4]    | RW     | 0x0   | EMAC0 RXFIFO RAM ECC inject double bit, non-correctable error
+ *  [5]    | RW     | 0x0   | EMAC0 TXFIFO RAM ECC single, correctable error interrupt status
+ *  [6]    | RW     | 0x0   | EMAC0 TXFIFO RAM ECC double bit, non-correctable error interrupt status
+ *  [7]    | RW     | 0x0   | EMAC0 RXFIFO RAM ECC single, correctable error interrupt status
+ *  [8]    | RW     | 0x0   | EMAC0 RXFIFO RAM ECC double bit, non-correctable error interrupt status
+ *  [31:9] | ???    | 0x0   | *UNDEFINED*
+ * Field : EMAC0 RAM ECC Enable - en
+ * Enable ECC for EMAC0 RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_EN register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_EN register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_EN field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : EMAC0 TXFIFO RAM ECC inject single, correctable Error - txfifoinjs
+ * EMAC0 TXFIFO RAM. This only injects one error into the EMAC0 TXFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : EMAC0 TXFIFO RAM ECC inject double bit, non-correctable error - txfifoinjd
+ * the EMAC0 TXFIFO RAM. This only injects one double bit error into the EMAC0
+ * TXFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOINJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : EMAC0 RXFIFO RAM ECC inject single, correctable Error - rxfifoinjs
+ * EMAC0 RXFIFO RAM. This only injects one error into the EMAC0 RXFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJS_SET(value) (((value) << 3) & 0x00000008)
+ * Field : EMAC0 RXFIFO RAM ECC inject double bit, non-correctable error - rxfifoinjd
+ * the EMAC0 RXFIFO RAM. This only injects one double bit error into the EMAC0
+ * RXFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOINJD_SET(value) (((value) << 4) & 0x00000010)
+ * Field : EMAC0 TXFIFO RAM ECC single, correctable error interrupt status - txfifoserr
+ * This bit is an interrupt status bit for EMAC0 TXFIFO RAM ECC single, correctable
+ * error. It is set by hardware when single, correctable error occurs in EMAC0
+ * TXFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
+ * status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_MSB        5
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFOSERR_SET(value) (((value) << 5) & 0x00000020)
+ * Field : EMAC0 TXFIFO RAM ECC double bit, non-correctable error interrupt status - txfifoderr
+ * This bit is an interrupt status bit for EMAC0 TXFIFO RAM ECC double bit, non-
+ * occurs in EMAC0 TXFIFO RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_MSB        6
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_TXFIFODERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_TXFIFODERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_TXFIFODERR_SET(value) (((value) << 6) & 0x00000040)
+ * Field : EMAC0 RXFIFO RAM ECC single, correctable error interrupt status - rxfifoserr
+ * This bit is an interrupt status bit for EMAC0 RXFIFO RAM ECC single, correctable
+ * RXFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
+ * status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_MSB        7
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFOSERR_SET(value) (((value) << 7) & 0x00000080)
+ * Field : EMAC0 RXFIFO RAM ECC double bit, non-correctable error interrupt status - rxfifoderr
+ * This bit is an interrupt status bit for EMAC0 RXFIFO RAM ECC double bit, non-
+ * occurs in EMAC0 RXFIFO RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_MSB        8
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_SET_MSK    0x00000100
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC0_RXFIFODERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_SYSMGR_ECC_EMAC0_RXFIFODERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC0_RXFIFODERR_SET(value) (((value) << 8) & 0x00000100)
+ * The struct declaration for register ALT_SYSMGR_ECC_EMAC0.
+struct ALT_SYSMGR_ECC_EMAC0_s
+    uint32_t  en         :  1;  /* EMAC0 RAM ECC Enable */
+    uint32_t  txfifoinjs :  1;  /* EMAC0 TXFIFO RAM ECC inject single, correctable Error */
+    uint32_t  txfifoinjd :  1;  /* EMAC0 TXFIFO RAM ECC inject double bit, non-correctable error */
+    uint32_t  rxfifoinjs :  1;  /* EMAC0 RXFIFO RAM ECC inject single, correctable Error */
+    uint32_t  rxfifoinjd :  1;  /* EMAC0 RXFIFO RAM ECC inject double bit, non-correctable error */
+    uint32_t  txfifoserr :  1;  /* EMAC0 TXFIFO RAM ECC single, correctable error interrupt status */
+    uint32_t  txfifoderr :  1;  /* EMAC0 TXFIFO RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t  rxfifoserr :  1;  /* EMAC0 RXFIFO RAM ECC single, correctable error interrupt status */
+    uint32_t  rxfifoderr :  1;  /* EMAC0 RXFIFO RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t             : 23;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_ECC_EMAC0. */
+typedef volatile struct ALT_SYSMGR_ECC_EMAC0_s  ALT_SYSMGR_ECC_EMAC0_t;
+/* The byte offset of the ALT_SYSMGR_ECC_EMAC0 register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_EMAC0_OFST        0x10
+ * Register : EMAC1 RAM ECC Enable Register - emac1
+ * This register is used to enable ECC on the EMAC1 RAM. ECC errors can be injected
+ * Register Layout
+ *  [0]    | RW     | 0x0   | EMAC1 RAM ECC Enable
+ *  [1]    | RW     | 0x0   | EMAC1 TXFIFO RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | EMAC1 TXFIFO RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | EMAC1 RXFIFO RAM ECC inject single, correctable Error
+ *  [4]    | RW     | 0x0   | EMAC1 RXFIFO RAM ECC inject double bit, non-correctable error
+ *  [5]    | RW     | 0x0   | EMAC1 TXFIFO RAM ECC single, correctable error interrupt status
+ *  [6]    | RW     | 0x0   | EMAC1 TXFIFO RAM ECC double bit, non-correctable error interrupt status
+ *  [7]    | RW     | 0x0   | EMAC1 RXFIFO RAM ECC single, correctable error interrupt status
+ *  [8]    | RW     | 0x0   | EMAC1 RXFIFO RAM ECC double bit, non-correctable error interrupt status
+ * Field : EMAC1 RAM ECC Enable - en
+ * Enable ECC for EMAC1 RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_EN register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_EN register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_EN register field. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_EN field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : EMAC1 TXFIFO RAM ECC inject single, correctable Error - txfifoinjs
+ * EMAC1 TXFIFO RAM. This only injects one error into the EMAC1 TXFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : EMAC1 TXFIFO RAM ECC inject double bit, non-correctable error - txfifoinjd
+ * the EMAC1 TXFIFO RAM. This only injects one double bit error into the EMAC1
+ * TXFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOINJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : EMAC1 RXFIFO RAM ECC inject single, correctable Error - rxfifoinjs
+ * EMAC1 RXFIFO RAM. This only injects one error into the EMAC1 RXFIFO RAM.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJS_SET(value) (((value) << 3) & 0x00000008)
+ * Field : EMAC1 RXFIFO RAM ECC inject double bit, non-correctable error - rxfifoinjd
+ * the EMAC1 RXFIFO RAM. This only injects one double bit error into the EMAC1
+ * RXFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOINJD_SET(value) (((value) << 4) & 0x00000010)
+ * Field : EMAC1 TXFIFO RAM ECC single, correctable error interrupt status - txfifoserr
+ * This bit is an interrupt status bit for EMAC1 TXFIFO RAM ECC single, correctable
+ * error. It is set by hardware when single, correctable error occurs in EMAC1
+ * status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_MSB        5
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFOSERR_SET(value) (((value) << 5) & 0x00000020)
+ * Field : EMAC1 TXFIFO RAM ECC double bit, non-correctable error interrupt status - txfifoderr
+ * This bit is an interrupt status bit for EMAC1 TXFIFO RAM ECC double bit, non-
+ * occurs in EMAC1 TXFIFO RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_MSB        6
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_TXFIFODERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_TXFIFODERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_TXFIFODERR_SET(value) (((value) << 6) & 0x00000040)
+ * Field : EMAC1 RXFIFO RAM ECC single, correctable error interrupt status - rxfifoserr
+ * This bit is an interrupt status bit for EMAC1 RXFIFO RAM ECC single, correctable
+ * status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_MSB        7
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFOSERR_SET(value) (((value) << 7) & 0x00000080)
+ * Field : EMAC1 RXFIFO RAM ECC double bit, non-correctable error interrupt status - rxfifoderr
+ * This bit is an interrupt status bit for EMAC1 RXFIFO RAM ECC double bit, non-
+ * occurs in EMAC1 RXFIFO RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_MSB        8
+/* The width in bits of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_SET_MSK    0x00000100
+/* The mask used to clear the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_EMAC1_RXFIFODERR field value from a register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_SYSMGR_ECC_EMAC1_RXFIFODERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_EMAC1_RXFIFODERR_SET(value) (((value) << 8) & 0x00000100)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SYSMGR_ECC_EMAC1.
+struct ALT_SYSMGR_ECC_EMAC1_s
+    uint32_t  en         :  1;  /* EMAC1 RAM ECC Enable */
+    uint32_t  txfifoinjs :  1;  /* EMAC1 TXFIFO RAM ECC inject single, correctable Error */
+    uint32_t  txfifoinjd :  1;  /* EMAC1 TXFIFO RAM ECC inject double bit, non-correctable error */
+    uint32_t  rxfifoinjs :  1;  /* EMAC1 RXFIFO RAM ECC inject single, correctable Error */
+    uint32_t  rxfifoinjd :  1;  /* EMAC1 RXFIFO RAM ECC inject double bit, non-correctable error */
+    uint32_t  txfifoserr :  1;  /* EMAC1 TXFIFO RAM ECC single, correctable error interrupt status */
+    uint32_t  txfifoderr :  1;  /* EMAC1 TXFIFO RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t  rxfifoserr :  1;  /* EMAC1 RXFIFO RAM ECC single, correctable error interrupt status */
+    uint32_t  rxfifoderr :  1;  /* EMAC1 RXFIFO RAM ECC double bit, non-correctable error interrupt status */
+/* The typedef declaration for register ALT_SYSMGR_ECC_EMAC1. */
+typedef volatile struct ALT_SYSMGR_ECC_EMAC1_s  ALT_SYSMGR_ECC_EMAC1_t;
+/* The byte offset of the ALT_SYSMGR_ECC_EMAC1 register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_EMAC1_OFST        0x14
+ * Register : DMA RAM ECC Enable Register - dma
+ * This register is used to enable ECC on the DMA RAM. ECC errors can be injected
+ * Register Layout
+ *  [0]    | RW     | 0x0   | DMA RAM ECC Enable
+ *  [1]    | RW     | 0x0   | DMA RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | DMA RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | DMA RAM ECC single, correctable error interrupt status
+ *  [4]    | RW     | 0x0   | DMA RAM ECC double bit, non-correctable error interrupt status
+ * Field : DMA RAM ECC Enable - en
+ * Enable ECC for DMA RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_EN register field. */
+#define ALT_SYSMGR_ECC_DMA_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_EN register field. */
+#define ALT_SYSMGR_ECC_DMA_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_DMA_EN register field. */
+#define ALT_SYSMGR_ECC_DMA_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_DMA_EN register field value. */
+#define ALT_SYSMGR_ECC_DMA_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_DMA_EN register field value. */
+#define ALT_SYSMGR_ECC_DMA_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_DMA_EN register field. */
+#define ALT_SYSMGR_ECC_DMA_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_DMA_EN field value from a register. */
+#define ALT_SYSMGR_ECC_DMA_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_DMA_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_DMA_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : DMA RAM ECC inject single, correctable Error - injs
+ * DMA RAM. This only injects one error into the DMA RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_INJS register field. */
+#define ALT_SYSMGR_ECC_DMA_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_INJS register field. */
+#define ALT_SYSMGR_ECC_DMA_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_DMA_INJS register field. */
+#define ALT_SYSMGR_ECC_DMA_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_DMA_INJS register field value. */
+#define ALT_SYSMGR_ECC_DMA_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_DMA_INJS register field value. */
+#define ALT_SYSMGR_ECC_DMA_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_DMA_INJS register field. */
+#define ALT_SYSMGR_ECC_DMA_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_DMA_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_DMA_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_DMA_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_DMA_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : DMA RAM ECC inject double bit, non-correctable error - injd
+ * the DMA RAM. This only injects one double bit error into the DMA RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_INJD register field. */
+#define ALT_SYSMGR_ECC_DMA_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_INJD register field. */
+#define ALT_SYSMGR_ECC_DMA_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_DMA_INJD register field. */
+#define ALT_SYSMGR_ECC_DMA_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_DMA_INJD register field value. */
+#define ALT_SYSMGR_ECC_DMA_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_DMA_INJD register field value. */
+#define ALT_SYSMGR_ECC_DMA_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_DMA_INJD register field. */
+#define ALT_SYSMGR_ECC_DMA_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_DMA_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_DMA_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_DMA_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_DMA_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : DMA RAM ECC single, correctable error interrupt status - serr
+ * This bit is an interrupt status bit for DMA RAM ECC single, correctable error.
+ * It is set by hardware when single, correctable error occurs in DMA RAM. Software
+ * needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_SERR register field. */
+#define ALT_SYSMGR_ECC_DMA_SERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_SERR register field. */
+#define ALT_SYSMGR_ECC_DMA_SERR_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_DMA_SERR register field. */
+#define ALT_SYSMGR_ECC_DMA_SERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_DMA_SERR register field value. */
+#define ALT_SYSMGR_ECC_DMA_SERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_DMA_SERR register field value. */
+#define ALT_SYSMGR_ECC_DMA_SERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_DMA_SERR register field. */
+#define ALT_SYSMGR_ECC_DMA_SERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_DMA_SERR field value from a register. */
+#define ALT_SYSMGR_ECC_DMA_SERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_DMA_SERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_DMA_SERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : DMA RAM ECC double bit, non-correctable error interrupt status - derr
+ * This bit is an interrupt status bit for DMA RAM ECC double bit, non-correctable
+ * DMA RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_DMA_DERR register field. */
+#define ALT_SYSMGR_ECC_DMA_DERR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_DMA_DERR register field. */
+#define ALT_SYSMGR_ECC_DMA_DERR_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_DMA_DERR register field. */
+#define ALT_SYSMGR_ECC_DMA_DERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_DMA_DERR register field value. */
+#define ALT_SYSMGR_ECC_DMA_DERR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_DMA_DERR register field value. */
+#define ALT_SYSMGR_ECC_DMA_DERR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_DMA_DERR register field. */
+#define ALT_SYSMGR_ECC_DMA_DERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_DMA_DERR field value from a register. */
+#define ALT_SYSMGR_ECC_DMA_DERR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_DMA_DERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_DMA_DERR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_ECC_DMA.
+struct ALT_SYSMGR_ECC_DMA_s
+    uint32_t  en   :  1;  /* DMA RAM ECC Enable */
+    uint32_t  injs :  1;  /* DMA RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* DMA RAM ECC inject double bit, non-correctable error */
+    uint32_t  serr :  1;  /* DMA RAM ECC single, correctable error interrupt status */
+    uint32_t  derr :  1;  /* DMA RAM ECC double bit, non-correctable error interrupt status */
+/* The typedef declaration for register ALT_SYSMGR_ECC_DMA. */
+typedef volatile struct ALT_SYSMGR_ECC_DMA_s  ALT_SYSMGR_ECC_DMA_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SYSMGR_ECC_DMA register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_DMA_OFST        0x18
+ * Register : CAN0 RAM ECC Enable Register - can0
+ * This register is used to enable ECC on the CAN0 RAM. ECC errors can be injected
+ * interrupt status of the ECC single/double bit error.
+ * Only reset by a cold reset (ignores warm reset).
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [0]    | RW     | 0x0   | CAN0 RAM ECC Enable
+ *  [1]    | RW     | 0x0   | CAN0 RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | CAN0 RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | CAN0 RAM ECC single, correctable error interrupt status
+ *  [4]    | RW     | 0x0   | CAN0 RAM ECC double bit, non-correctable error interrupt status
+ *  [31:5] | ???    | 0x0   | *UNDEFINED*
+ * Field : CAN0 RAM ECC Enable - en
+ * Enable ECC for CAN0 RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_EN register field. */
+#define ALT_SYSMGR_ECC_CAN0_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_EN register field. */
+#define ALT_SYSMGR_ECC_CAN0_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_CAN0_EN register field. */
+#define ALT_SYSMGR_ECC_CAN0_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN0_EN register field value. */
+#define ALT_SYSMGR_ECC_CAN0_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN0_EN register field value. */
+#define ALT_SYSMGR_ECC_CAN0_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_CAN0_EN register field. */
+#define ALT_SYSMGR_ECC_CAN0_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN0_EN field value from a register. */
+#define ALT_SYSMGR_ECC_CAN0_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_CAN0_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN0_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : CAN0 RAM ECC inject single, correctable Error - injs
+ * Changing this bit from zero to one injects a single, correctable error into the
+ * CAN0 RAM. This only injects one error into the CAN0 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN0_INJS register field value. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN0_INJS register field value. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_CAN0_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN0_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_CAN0_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN0_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : CAN0 RAM ECC inject double bit, non-correctable error - injd
+ * Changing this bit from zero to one injects a double, non-correctable error into
+ * the CAN0 RAM. This only injects one double bit error into the CAN0 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN0_INJD register field value. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN0_INJD register field value. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_CAN0_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN0_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_CAN0_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN0_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : CAN0 RAM ECC single, correctable error interrupt status - serr
+ * This bit is an interrupt status bit for CAN0 RAM ECC single, correctable error.
+ * It is set by hardware when single, correctable error occurs in CAN0 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN0_SERR register field value. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN0_SERR register field value. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_CAN0_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN0_SERR field value from a register. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_CAN0_SERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN0_SERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : CAN0 RAM ECC double bit, non-correctable error interrupt status - derr
+ * This bit is an interrupt status bit for CAN0 RAM ECC double bit, non-correctable
+ * CAN0 RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN0_DERR register field value. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN0_DERR register field value. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_CAN0_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN0_DERR field value from a register. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_CAN0_DERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN0_DERR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_ECC_CAN0.
+struct ALT_SYSMGR_ECC_CAN0_s
+    uint32_t  en   :  1;  /* CAN0 RAM ECC Enable */
+    uint32_t  injs :  1;  /* CAN0 RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* CAN0 RAM ECC inject double bit, non-correctable error */
+    uint32_t  serr :  1;  /* CAN0 RAM ECC single, correctable error interrupt status */
+    uint32_t  derr :  1;  /* CAN0 RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t       : 27;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_ECC_CAN0. */
+typedef volatile struct ALT_SYSMGR_ECC_CAN0_s  ALT_SYSMGR_ECC_CAN0_t;
+/* The byte offset of the ALT_SYSMGR_ECC_CAN0 register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_CAN0_OFST        0x1c
+ * Register : CAN1 RAM ECC Enable Register - can1
+ * This register is used to enable ECC on the CAN1 RAM. ECC errors can be injected
+ * into the write path using bits in this register. This register contains
+ * Register Layout
+ *  [0]    | RW     | 0x0   | CAN1 RAM ECC Enable
+ *  [1]    | RW     | 0x0   | CAN1 RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | CAN1 RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | CAN1 RAM ECC single, correctable error interrupt status
+ *  [4]    | RW     | 0x0   | CAN1 RAM ECC double bit, non-correctable error interrupt status
+ * Field : CAN1 RAM ECC Enable - en
+ * Enable ECC for CAN1 RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_EN register field. */
+#define ALT_SYSMGR_ECC_CAN1_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_EN register field. */
+#define ALT_SYSMGR_ECC_CAN1_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_CAN1_EN register field. */
+#define ALT_SYSMGR_ECC_CAN1_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN1_EN register field value. */
+#define ALT_SYSMGR_ECC_CAN1_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN1_EN register field value. */
+#define ALT_SYSMGR_ECC_CAN1_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_CAN1_EN register field. */
+#define ALT_SYSMGR_ECC_CAN1_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN1_EN field value from a register. */
+#define ALT_SYSMGR_ECC_CAN1_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_CAN1_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN1_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : CAN1 RAM ECC inject single, correctable Error - injs
+ * CAN1 RAM. This only injects one error into the CAN1 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN1_INJS register field value. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN1_INJS register field value. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_CAN1_INJS register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN1_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_CAN1_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN1_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : CAN1 RAM ECC inject double bit, non-correctable error - injd
+ * the CAN1 RAM. This only injects one double bit error into the CAN1 RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN1_INJD register field value. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN1_INJD register field value. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_CAN1_INJD register field. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN1_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_CAN1_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN1_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : CAN1 RAM ECC single, correctable error interrupt status - serr
+ * This bit is an interrupt status bit for CAN1 RAM ECC single, correctable error.
+ * It is set by hardware when single, correctable error occurs in CAN1 RAM.
+ * Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN1_SERR register field value. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN1_SERR register field value. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_CAN1_SERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN1_SERR field value from a register. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_CAN1_SERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN1_SERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : CAN1 RAM ECC double bit, non-correctable error interrupt status - derr
+ * This bit is an interrupt status bit for CAN1 RAM ECC double bit, non-correctable
+ * error. It is set by hardware when double bit, non-correctable error occurs in
+ * CAN1 RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_CAN1_DERR register field value. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_CAN1_DERR register field value. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_CAN1_DERR register field. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_CAN1_DERR field value from a register. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_CAN1_DERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_CAN1_DERR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_ECC_CAN1.
+struct ALT_SYSMGR_ECC_CAN1_s
+    uint32_t  en   :  1;  /* CAN1 RAM ECC Enable */
+    uint32_t  injs :  1;  /* CAN1 RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* CAN1 RAM ECC inject double bit, non-correctable error */
+    uint32_t  serr :  1;  /* CAN1 RAM ECC single, correctable error interrupt status */
+    uint32_t  derr :  1;  /* CAN1 RAM ECC double bit, non-correctable error interrupt status */
+/* The typedef declaration for register ALT_SYSMGR_ECC_CAN1. */
+typedef volatile struct ALT_SYSMGR_ECC_CAN1_s  ALT_SYSMGR_ECC_CAN1_t;
+/* The byte offset of the ALT_SYSMGR_ECC_CAN1 register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_CAN1_OFST        0x20
+ * Register : NAND RAM ECC Enable Register - nand
+ * This register is used to enable ECC on the NAND RAM. ECC errors can be injected
+ * Register Layout
+ *  [0]     | RW     | 0x0   | NAND RAM ECC Enable
+ *  [1]     | RW     | 0x0   | NAND ECCBUFFER RAM ECC inject single, correctable Error
+ *  [2]     | RW     | 0x0   | NAND ECCBUFFER RAM ECC inject double bit, non-correctable error
+ *  [3]     | RW     | 0x0   | NAND WRFIFO RAM ECC inject single, correctable Error
+ *  [4]     | RW     | 0x0   | NAND WRFIFO RAM ECC inject double bit, non-correctable error
+ *  [5]     | RW     | 0x0   | NAND RDFIFO RAM ECC inject single, correctable Error
+ *  [6]     | RW     | 0x0   | NAND RDFIFO RAM ECC inject double bit, non-correctable error
+ *  [7]     | RW     | 0x0   | NAND ECCBUFFER RAM ECC single, correctable error interrupt status
+ *  [8]     | RW     | 0x0   | NAND ECCBUFFER RAM ECC double bit, non-correctable error interrupt status
+ *  [9]     | RW     | 0x0   | NAND WRFIFO RAM ECC single, correctable error interrupt status
+ *  [10]    | RW     | 0x0   | NAND WRFIFO RAM ECC double bit, non-correctable error interrupt status
+ *  [11]    | RW     | 0x0   | NAND RDFIFO RAM ECC single, correctable error interrupt status
+ *  [12]    | RW     | 0x0   | NAND RDFIFO RAM ECC double bit, non-correctable error interrupt status
+ *  [31:13] | ???    | 0x0   | *UNDEFINED*
+ * Field : NAND RAM ECC Enable - en
+ * Enable ECC for NAND RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_EN register field. */
+#define ALT_SYSMGR_ECC_NAND_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_EN register field. */
+#define ALT_SYSMGR_ECC_NAND_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_EN register field. */
+#define ALT_SYSMGR_ECC_NAND_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_EN register field value. */
+#define ALT_SYSMGR_ECC_NAND_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_EN register field value. */
+#define ALT_SYSMGR_ECC_NAND_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_NAND_EN register field. */
+#define ALT_SYSMGR_ECC_NAND_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_EN field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_NAND_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : NAND ECCBUFFER RAM ECC inject single, correctable Error - eccbufinjs
+ * NAND ECCBUFFER RAM. This only injects one error into the NAND ECCBUFFER RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFINJS field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFINJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : NAND ECCBUFFER RAM ECC inject double bit, non-correctable error - eccbufinjd
+ * the NAND ECCBUFFER RAM. This only injects one double bit error into the NAND
+ * ECCBUFFER RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFINJD field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFINJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFINJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : NAND WRFIFO RAM ECC inject single, correctable Error - wrfifoinjs
+ * NAND WRFIFO RAM. This only injects one error into the NAND WRFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFOINJS field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_NAND_WRFIFOINJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJS_SET(value) (((value) << 3) & 0x00000008)
+ * Field : NAND WRFIFO RAM ECC inject double bit, non-correctable error - wrfifoinjd
+ * the NAND WRFIFO RAM. This only injects one double bit error into the NAND WRFIFO
+ * RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFOINJD field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_NAND_WRFIFOINJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOINJD_SET(value) (((value) << 4) & 0x00000010)
+ * Field : NAND RDFIFO RAM ECC inject single, correctable Error - rdfifoinjs
+ * NAND RDFIFO RAM. This only injects one error into the NAND RDFIFO RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_MSB        5
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFOINJS field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_ECC_NAND_RDFIFOINJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJS_SET(value) (((value) << 5) & 0x00000020)
+ * Field : NAND RDFIFO RAM ECC inject double bit, non-correctable error - rdfifoinjd
+ * the NAND RDFIFO RAM. This only injects one double bit error into the NAND RDFIFO
+ * RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_MSB        6
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFOINJD field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_ECC_NAND_RDFIFOINJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOINJD_SET(value) (((value) << 6) & 0x00000040)
+ * Field : NAND ECCBUFFER RAM ECC single, correctable error interrupt status - eccbufserr
+ * This bit is an interrupt status bit for NAND ECCBUFFER RAM ECC single,
+ * correctable error. It is set by hardware when single, correctable error occurs
+ * in NAND ECCBUFFER RAM. Software needs to write 1 into this bit to clear the
+ * interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_MSB        7
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFSERR field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFSERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFSERR_SET(value) (((value) << 7) & 0x00000080)
+ * Field : NAND ECCBUFFER RAM ECC double bit, non-correctable error interrupt status - eccbufderr
+ * This bit is an interrupt status bit for NAND ECCBUFFER RAM ECC double bit, non-
+ * correctable error. It is set by hardware when double bit, non-correctable error
+ * occurs in NAND ECCBUFFER RAM. Software needs to write 1 into this bit to clear
+ * the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_MSB        8
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_SET_MSK    0x00000100
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_ECCBUFDERR field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_SYSMGR_ECC_NAND_ECCBUFDERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_ECCBUFDERR_SET(value) (((value) << 8) & 0x00000100)
+ * Field : NAND WRFIFO RAM ECC single, correctable error interrupt status - wrfifoserr
+ * This bit is an interrupt status bit for NAND WRFIFO RAM ECC single, correctable
+ * error. It is set by hardware when single, correctable error occurs in NAND
+ * WRFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
+ * status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_LSB        9
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_MSB        9
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_SET_MSK    0x00000200
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_CLR_MSK    0xfffffdff
+/* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFOSERR field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_GET(value) (((value) & 0x00000200) >> 9)
+/* Produces a ALT_SYSMGR_ECC_NAND_WRFIFOSERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFOSERR_SET(value) (((value) << 9) & 0x00000200)
+ * Field : NAND WRFIFO RAM ECC double bit, non-correctable error interrupt status - wrfifoderr
+ * This bit is an interrupt status bit for NAND WRFIFO RAM ECC double bit, non-
+ * occurs in NAND WRFIFO RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_LSB        10
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_MSB        10
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_SET_MSK    0x00000400
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_CLR_MSK    0xfffffbff
+/* The reset value of the ALT_SYSMGR_ECC_NAND_WRFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_WRFIFODERR field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_GET(value) (((value) & 0x00000400) >> 10)
+/* Produces a ALT_SYSMGR_ECC_NAND_WRFIFODERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_WRFIFODERR_SET(value) (((value) << 10) & 0x00000400)
+ * Field : NAND RDFIFO RAM ECC single, correctable error interrupt status - rdfifoserr
+ * This bit is an interrupt status bit for NAND RDFIFO RAM ECC single, correctable
+ * RDFIFO RAM. Software needs to write 1 into this bit to clear the interrupt
+ * status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_LSB        11
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_MSB        11
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_SET_MSK    0x00000800
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_CLR_MSK    0xfffff7ff
+/* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFOSERR field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_GET(value) (((value) & 0x00000800) >> 11)
+/* Produces a ALT_SYSMGR_ECC_NAND_RDFIFOSERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFOSERR_SET(value) (((value) << 11) & 0x00000800)
+ * Field : NAND RDFIFO RAM ECC double bit, non-correctable error interrupt status - rdfifoderr
+ * This bit is an interrupt status bit for NAND RDFIFO RAM ECC double bit, non-
+ * occurs in NAND RDFIFO RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_LSB        12
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_MSB        12
+/* The width in bits of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_SET_MSK    0x00001000
+/* The mask used to clear the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field value. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_CLR_MSK    0xffffefff
+/* The reset value of the ALT_SYSMGR_ECC_NAND_RDFIFODERR register field. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_NAND_RDFIFODERR field value from a register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_GET(value) (((value) & 0x00001000) >> 12)
+/* Produces a ALT_SYSMGR_ECC_NAND_RDFIFODERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_NAND_RDFIFODERR_SET(value) (((value) << 12) & 0x00001000)
+ * The struct declaration for register ALT_SYSMGR_ECC_NAND.
+struct ALT_SYSMGR_ECC_NAND_s
+    uint32_t  en         :  1;  /* NAND RAM ECC Enable */
+    uint32_t  eccbufinjs :  1;  /* NAND ECCBUFFER RAM ECC inject single, correctable Error */
+    uint32_t  eccbufinjd :  1;  /* NAND ECCBUFFER RAM ECC inject double bit, non-correctable error */
+    uint32_t  wrfifoinjs :  1;  /* NAND WRFIFO RAM ECC inject single, correctable Error */
+    uint32_t  wrfifoinjd :  1;  /* NAND WRFIFO RAM ECC inject double bit, non-correctable error */
+    uint32_t  rdfifoinjs :  1;  /* NAND RDFIFO RAM ECC inject single, correctable Error */
+    uint32_t  rdfifoinjd :  1;  /* NAND RDFIFO RAM ECC inject double bit, non-correctable error */
+    uint32_t  eccbufserr :  1;  /* NAND ECCBUFFER RAM ECC single, correctable error interrupt status */
+    uint32_t  eccbufderr :  1;  /* NAND ECCBUFFER RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t  wrfifoserr :  1;  /* NAND WRFIFO RAM ECC single, correctable error interrupt status */
+    uint32_t  wrfifoderr :  1;  /* NAND WRFIFO RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t  rdfifoserr :  1;  /* NAND RDFIFO RAM ECC single, correctable error interrupt status */
+    uint32_t  rdfifoderr :  1;  /* NAND RDFIFO RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t             : 19;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_ECC_NAND. */
+typedef volatile struct ALT_SYSMGR_ECC_NAND_s  ALT_SYSMGR_ECC_NAND_t;
+/* The byte offset of the ALT_SYSMGR_ECC_NAND register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_NAND_OFST        0x24
+ * Register : QSPI RAM ECC Enable Register - qspi
+ * This register is used to enable ECC on the QSPI RAM. ECC errors can be injected
+ * Register Layout
+ *  [0]    | RW     | 0x0   | QSPI RAM ECC Enable
+ *  [1]    | RW     | 0x0   | QSPI RAM ECC inject single, correctable Error
+ *  [2]    | RW     | 0x0   | QSPI RAM ECC inject double bit, non-correctable error
+ *  [3]    | RW     | 0x0   | QSPI RAM ECC single, correctable error interrupt status
+ *  [4]    | RW     | 0x0   | QSPI RAM ECC double bit, non-correctable error interrupt status
+ * Field : QSPI RAM ECC Enable - en
+ * Enable ECC for QSPI RAM
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_EN register field. */
+#define ALT_SYSMGR_ECC_QSPI_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_EN register field. */
+#define ALT_SYSMGR_ECC_QSPI_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_QSPI_EN register field. */
+#define ALT_SYSMGR_ECC_QSPI_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_QSPI_EN register field value. */
+#define ALT_SYSMGR_ECC_QSPI_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_QSPI_EN register field value. */
+#define ALT_SYSMGR_ECC_QSPI_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_QSPI_EN register field. */
+#define ALT_SYSMGR_ECC_QSPI_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_QSPI_EN field value from a register. */
+#define ALT_SYSMGR_ECC_QSPI_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_QSPI_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_QSPI_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : QSPI RAM ECC inject single, correctable Error - injs
+ * QSPI RAM. This only injects one error into the QSPI RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_QSPI_INJS register field value. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_QSPI_INJS register field value. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_QSPI_INJS register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_QSPI_INJS field value from a register. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_QSPI_INJS register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_QSPI_INJS_SET(value) (((value) << 1) & 0x00000002)
+ * Field : QSPI RAM ECC inject double bit, non-correctable error - injd
+ * the QSPI RAM. This only injects one double bit error into the QSPI RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_QSPI_INJD register field value. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_QSPI_INJD register field value. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_QSPI_INJD register field. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_QSPI_INJD field value from a register. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_QSPI_INJD register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_QSPI_INJD_SET(value) (((value) << 2) & 0x00000004)
+ * Field : QSPI RAM ECC single, correctable error interrupt status - serr
+ * This bit is an interrupt status bit for QSPI RAM ECC single, correctable error.
+ * It is set by hardware when single, correctable error occurs in QSPI RAM.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_QSPI_SERR register field value. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_QSPI_SERR register field value. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_QSPI_SERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_QSPI_SERR field value from a register. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_QSPI_SERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_QSPI_SERR_SET(value) (((value) << 3) & 0x00000008)
+ * Field : QSPI RAM ECC double bit, non-correctable error interrupt status - derr
+ * This bit is an interrupt status bit for QSPI RAM ECC double bit, non-correctable
+ * QSPI RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_QSPI_DERR register field value. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_QSPI_DERR register field value. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_QSPI_DERR register field. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_QSPI_DERR field value from a register. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_QSPI_DERR register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_QSPI_DERR_SET(value) (((value) << 4) & 0x00000010)
+ * The struct declaration for register ALT_SYSMGR_ECC_QSPI.
+struct ALT_SYSMGR_ECC_QSPI_s
+    uint32_t  en   :  1;  /* QSPI RAM ECC Enable */
+    uint32_t  injs :  1;  /* QSPI RAM ECC inject single, correctable Error */
+    uint32_t  injd :  1;  /* QSPI RAM ECC inject double bit, non-correctable error */
+    uint32_t  serr :  1;  /* QSPI RAM ECC single, correctable error interrupt status */
+    uint32_t  derr :  1;  /* QSPI RAM ECC double bit, non-correctable error interrupt status */
+/* The typedef declaration for register ALT_SYSMGR_ECC_QSPI. */
+typedef volatile struct ALT_SYSMGR_ECC_QSPI_s  ALT_SYSMGR_ECC_QSPI_t;
+/* The byte offset of the ALT_SYSMGR_ECC_QSPI register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_QSPI_OFST        0x28
+ * Register : SDMMC RAM ECC Enable Register - sdmmc
+ * This register is used to enable ECC on the SDMMC RAM.ECC errors can be injected
+ * Register Layout
+ *  [0]    | RW     | 0x0   | SDMMC RAM ECC Enable
+ *  [1]    | RW     | 0x0   | SDMMC Port A RAM ECC inject single, correctable Error at Port A
+ *  [2]    | RW     | 0x0   | SDMMC Port A RAM ECC inject double bit, non-correctable error at Port A
+ *  [3]    | RW     | 0x0   | SDMMC Port B RAM ECC inject single, correctable Error at Port B
+ *  [4]    | RW     | 0x0   | SDMMC Port B RAM ECC inject double bit, non-correctable error at Port B
+ *  [5]    | RW     | 0x0   | SDMMC Port A RAM ECC single, correctable error interrupt status
+ *  [6]    | RW     | 0x0   | SDMMC Port A RAM ECC double bit, non-correctable error interrupt status
+ *  [7]    | RW     | 0x0   | SDMMC Port B RAM ECC single, correctable error interrupt status
+ *  [8]    | RW     | 0x0   | SDMMC Port B RAM ECC double bit, non-correctable error interrupt status
+ *  [31:9] | ???    | 0x0   | *UNDEFINED*
+ * Field : SDMMC RAM ECC Enable - en
+ * Enable ECC for SDMMC RAM
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_MSB        0
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_EN register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_SET_MSK    0x00000001
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_EN register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_CLR_MSK    0xfffffffe
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_EN register field. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_EN field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_GET(value) (((value) & 0x00000001) >> 0)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_EN register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_EN_SET(value) (((value) << 0) & 0x00000001)
+ * Field : SDMMC Port A RAM ECC inject single, correctable Error at Port A - injsporta
+ * SDMMC RAM at Port A. This only injects one error into the SDMMC RAM at Port A.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_LSB        1
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_MSB        1
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_SET_MSK    0x00000002
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_CLR_MSK    0xfffffffd
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_INJSPORTA field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_GET(value) (((value) & 0x00000002) >> 1)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_INJSPORTA register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTA_SET(value) (((value) << 1) & 0x00000002)
+ * Field : SDMMC Port A RAM ECC inject double bit, non-correctable error at Port A - injdporta
+ * the SDMMC RAM at Port A. This only injects one double bit error into the SDMMC
+ * RAM at Port A.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_LSB        2
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_MSB        2
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_SET_MSK    0x00000004
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_CLR_MSK    0xfffffffb
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_INJDPORTA field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_GET(value) (((value) & 0x00000004) >> 2)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_INJDPORTA register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTA_SET(value) (((value) << 2) & 0x00000004)
+ * Field : SDMMC Port B RAM ECC inject single, correctable Error at Port B - injsportb
+ * SDMMC RAM at Port B. This only injects one error into the SDMMC RAM at Port B.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_LSB        3
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_MSB        3
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_SET_MSK    0x00000008
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_CLR_MSK    0xfffffff7
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_INJSPORTB field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_GET(value) (((value) & 0x00000008) >> 3)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_INJSPORTB register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJSPORTB_SET(value) (((value) << 3) & 0x00000008)
+ * Field : SDMMC Port B RAM ECC inject double bit, non-correctable error at Port B - injdportb
+ * the SDMMC RAM at Port B. This only injects one double bit error into the SDMMC
+ * RAM at Port B.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_LSB        4
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_MSB        4
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_SET_MSK    0x00000010
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_CLR_MSK    0xffffffef
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_INJDPORTB field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_GET(value) (((value) & 0x00000010) >> 4)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_INJDPORTB register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_INJDPORTB_SET(value) (((value) << 4) & 0x00000010)
+ * Field : SDMMC Port A RAM ECC single, correctable error interrupt status - serrporta
+ * This bit is an interrupt status bit for SDMMC Port A RAM ECC single, correctable
+ * error. It is set by hardware when single, correctable error occurs in SDMMC Port
+ * A RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_LSB        5
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_MSB        5
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_SET_MSK    0x00000020
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_CLR_MSK    0xffffffdf
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_SERRPORTA field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_GET(value) (((value) & 0x00000020) >> 5)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_SERRPORTA register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTA_SET(value) (((value) << 5) & 0x00000020)
+ * Field : SDMMC Port A RAM ECC double bit, non-correctable error interrupt status - derrporta
+ * This bit is an interrupt status bit for SDMMC Port A RAM ECC double bit, non-
+ * occurs in SDMMC Port A RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_LSB        6
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_MSB        6
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_SET_MSK    0x00000040
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_CLR_MSK    0xffffffbf
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_DERRPORTA field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_GET(value) (((value) & 0x00000040) >> 6)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_DERRPORTA register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTA_SET(value) (((value) << 6) & 0x00000040)
+ * Field : SDMMC Port B RAM ECC single, correctable error interrupt status - serrportb
+ * This bit is an interrupt status bit for SDMMC Port B RAM ECC single, correctable
+ * B RAM. Software needs to write 1 into this bit to clear the interrupt status.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_LSB        7
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_MSB        7
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_SET_MSK    0x00000080
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_CLR_MSK    0xffffff7f
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_SERRPORTB field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_GET(value) (((value) & 0x00000080) >> 7)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_SERRPORTB register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_SERRPORTB_SET(value) (((value) << 7) & 0x00000080)
+ * Field : SDMMC Port B RAM ECC double bit, non-correctable error interrupt status - derrportb
+ * This bit is an interrupt status bit for SDMMC Port B RAM ECC double bit, non-
+ * occurs in SDMMC Port B RAM. Software needs to write 1 into this bit to clear the
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_LSB        8
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_MSB        8
+/* The width in bits of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_WIDTH      1
+/* The mask used to set the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_SET_MSK    0x00000100
+/* The mask used to clear the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field value. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_CLR_MSK    0xfffffeff
+/* The reset value of the ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_RESET      0x0
+/* Extracts the ALT_SYSMGR_ECC_SDMMC_DERRPORTB field value from a register. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_GET(value) (((value) & 0x00000100) >> 8)
+/* Produces a ALT_SYSMGR_ECC_SDMMC_DERRPORTB register field value suitable for setting the register. */
+#define ALT_SYSMGR_ECC_SDMMC_DERRPORTB_SET(value) (((value) << 8) & 0x00000100)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SYSMGR_ECC_SDMMC.
+struct ALT_SYSMGR_ECC_SDMMC_s
+    uint32_t  en        :  1;  /* SDMMC RAM ECC Enable */
+    uint32_t  injsporta :  1;  /* SDMMC Port A RAM ECC inject single, correctable Error at Port A */
+    uint32_t  injdporta :  1;  /* SDMMC Port A RAM ECC inject double bit, non-correctable error at Port A */
+    uint32_t  injsportb :  1;  /* SDMMC Port B RAM ECC inject single, correctable Error at Port B */
+    uint32_t  injdportb :  1;  /* SDMMC Port B RAM ECC inject double bit, non-correctable error at Port B */
+    uint32_t  serrporta :  1;  /* SDMMC Port A RAM ECC single, correctable error interrupt status */
+    uint32_t  derrporta :  1;  /* SDMMC Port A RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t  serrportb :  1;  /* SDMMC Port B RAM ECC single, correctable error interrupt status */
+    uint32_t  derrportb :  1;  /* SDMMC Port B RAM ECC double bit, non-correctable error interrupt status */
+    uint32_t            : 23;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_ECC_SDMMC. */
+typedef volatile struct ALT_SYSMGR_ECC_SDMMC_s  ALT_SYSMGR_ECC_SDMMC_t;
+/* The byte offset of the ALT_SYSMGR_ECC_SDMMC register from the beginning of the component. */
+#define ALT_SYSMGR_ECC_SDMMC_OFST        0x2c
+ * The struct declaration for register group ALT_SYSMGR_ECC.
+struct ALT_SYSMGR_ECC_s
+    volatile ALT_SYSMGR_ECC_L2_t     l2;                 /* ALT_SYSMGR_ECC_L2 */
+    volatile ALT_SYSMGR_ECC_OCRAM_t  ocram;              /* ALT_SYSMGR_ECC_OCRAM */
+    volatile ALT_SYSMGR_ECC_USB0_t   usb0;               /* ALT_SYSMGR_ECC_USB0 */
+    volatile ALT_SYSMGR_ECC_USB1_t   usb1;               /* ALT_SYSMGR_ECC_USB1 */
+    volatile ALT_SYSMGR_ECC_EMAC0_t  emac0;              /* ALT_SYSMGR_ECC_EMAC0 */
+    volatile ALT_SYSMGR_ECC_EMAC1_t  emac1;              /* ALT_SYSMGR_ECC_EMAC1 */
+    volatile ALT_SYSMGR_ECC_DMA_t    dma;                /* ALT_SYSMGR_ECC_DMA */
+    volatile ALT_SYSMGR_ECC_CAN0_t   can0;               /* ALT_SYSMGR_ECC_CAN0 */
+    volatile ALT_SYSMGR_ECC_CAN1_t   can1;               /* ALT_SYSMGR_ECC_CAN1 */
+    volatile ALT_SYSMGR_ECC_NAND_t   nand;               /* ALT_SYSMGR_ECC_NAND */
+    volatile ALT_SYSMGR_ECC_QSPI_t   qspi;               /* ALT_SYSMGR_ECC_QSPI */
+    volatile ALT_SYSMGR_ECC_SDMMC_t  sdmmc;              /* ALT_SYSMGR_ECC_SDMMC */
+    volatile uint32_t                _pad_0x30_0x40[4];  /* *UNDEFINED* */
+/* The typedef declaration for register group ALT_SYSMGR_ECC. */
+typedef volatile struct ALT_SYSMGR_ECC_s  ALT_SYSMGR_ECC_t;
+/* The struct declaration for the raw register contents of register group ALT_SYSMGR_ECC. */
+struct ALT_SYSMGR_ECC_raw_s
+    volatile uint32_t  l2;                 /* ALT_SYSMGR_ECC_L2 */
+    volatile uint32_t  ocram;              /* ALT_SYSMGR_ECC_OCRAM */
+    volatile uint32_t  usb0;               /* ALT_SYSMGR_ECC_USB0 */
+    volatile uint32_t  usb1;               /* ALT_SYSMGR_ECC_USB1 */
+    volatile uint32_t  emac0;              /* ALT_SYSMGR_ECC_EMAC0 */
+    volatile uint32_t  emac1;              /* ALT_SYSMGR_ECC_EMAC1 */
+    volatile uint32_t  dma;                /* ALT_SYSMGR_ECC_DMA */
+    volatile uint32_t  can0;               /* ALT_SYSMGR_ECC_CAN0 */
+    volatile uint32_t  can1;               /* ALT_SYSMGR_ECC_CAN1 */
+    volatile uint32_t  nand;               /* ALT_SYSMGR_ECC_NAND */
+    volatile uint32_t  qspi;               /* ALT_SYSMGR_ECC_QSPI */
+    volatile uint32_t  sdmmc;              /* ALT_SYSMGR_ECC_SDMMC */
+/* The typedef declaration for the raw register contents of register group ALT_SYSMGR_ECC. */
+typedef volatile struct ALT_SYSMGR_ECC_raw_s  ALT_SYSMGR_ECC_raw_t;
+#endif  /* __ASSEMBLY__ */
+ * Register Group : Pin Mux Control Group - ALT_SYSMGR_PINMUX
+ * Pin Mux Control Group
+ * Controls Pin Mux selections
+ * NOTE: These registers should not be modified after IO configuration.There is no
+ * support for dynamically changing the Pin Mux selections.
+ * Register : emac0_tx_clk Mux Selection Register - EMACIO0
+ * This register is used to control the peripherals connected to emac0_tx_clk
+ * Only reset by a cold reset (ignores warm reset).
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [1:0]  | RW     | 0x0   | emac0_tx_clk Mux Selection Field
+ *  [31:2] | ???    | 0x0   | *UNDEFINED*
+ * Field : emac0_tx_clk Mux Selection Field - sel
+ * Select peripheral signals connected emac0_tx_clk.
+ * 0 : Pin is connected to GPIO/LoanIO number 0.
+ * 1 : Pin is connected to Peripheral signal not applicable.
+ * 2 : Pin is connected to Peripheral signal not applicable.
+ * 3 : Pin is connected to Peripheral signal RGMII0.TX_CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO0_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO0_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO0.
+struct ALT_SYSMGR_PINMUX_EMACIO0_s
+    uint32_t  sel :  2;  /* emac0_tx_clk Mux Selection Field */
+    uint32_t      : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO0. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO0_s  ALT_SYSMGR_PINMUX_EMACIO0_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO0 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO0_OFST        0x0
+ * Register : emac0_tx_d0 Mux Selection Register - EMACIO1
+ * This register is used to control the peripherals connected to emac0_tx_d0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_tx_d0 Mux Selection Field
+ * Field : emac0_tx_d0 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_tx_d0.
+ * 0 : Pin is connected to GPIO/LoanIO number 1.
+ * 2 : Pin is connected to Peripheral signal USB1.D0.
+ * 3 : Pin is connected to Peripheral signal RGMII0.TXD0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO1_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO1_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO1.
+struct ALT_SYSMGR_PINMUX_EMACIO1_s
+    uint32_t  sel :  2;  /* emac0_tx_d0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO1. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO1_s  ALT_SYSMGR_PINMUX_EMACIO1_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO1 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO1_OFST        0x4
+ * Register : emac0_tx_d1 Mux Selection Register - EMACIO2
+ * This register is used to control the peripherals connected to emac0_tx_d1
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_tx_d1 Mux Selection Field
+ * Field : emac0_tx_d1 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_tx_d1.
+ * 0 : Pin is connected to GPIO/LoanIO number 2.
+ * 2 : Pin is connected to Peripheral signal USB1.D1.
+ * 3 : Pin is connected to Peripheral signal RGMII0.TXD1.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO2_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO2_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO2.
+struct ALT_SYSMGR_PINMUX_EMACIO2_s
+    uint32_t  sel :  2;  /* emac0_tx_d1 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO2. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO2_s  ALT_SYSMGR_PINMUX_EMACIO2_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO2 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO2_OFST        0x8
+ * Register : emac0_tx_d2 Mux Selection Register - EMACIO3
+ * This register is used to control the peripherals connected to emac0_tx_d2
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_tx_d2 Mux Selection Field
+ * Field : emac0_tx_d2 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_tx_d2.
+ * 0 : Pin is connected to GPIO/LoanIO number 3.
+ * 2 : Pin is connected to Peripheral signal USB1.D2.
+ * 3 : Pin is connected to Peripheral signal RGMII0.TXD2.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO3_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO3_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO3.
+struct ALT_SYSMGR_PINMUX_EMACIO3_s
+    uint32_t  sel :  2;  /* emac0_tx_d2 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO3. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO3_s  ALT_SYSMGR_PINMUX_EMACIO3_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO3 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO3_OFST        0xc
+ * Register : emac0_tx_d3 Mux Selection Register - EMACIO4
+ * This register is used to control the peripherals connected to emac0_tx_d3
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_tx_d3 Mux Selection Field
+ * Field : emac0_tx_d3 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_tx_d3.
+ * 0 : Pin is connected to GPIO/LoanIO number 4.
+ * 2 : Pin is connected to Peripheral signal USB1.D3.
+ * 3 : Pin is connected to Peripheral signal RGMII0.TXD3.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO4_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO4_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO4.
+struct ALT_SYSMGR_PINMUX_EMACIO4_s
+    uint32_t  sel :  2;  /* emac0_tx_d3 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO4. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO4_s  ALT_SYSMGR_PINMUX_EMACIO4_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO4 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO4_OFST        0x10
+ * Register : emac0_rx_d0 Mux Selection Register - EMACIO5
+ * This register is used to control the peripherals connected to emac0_rx_d0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_rx_d0 Mux Selection Field
+ * Field : emac0_rx_d0 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_rx_d0.
+ * 0 : Pin is connected to GPIO/LoanIO number 5.
+ * 2 : Pin is connected to Peripheral signal USB1.D4.
+ * 3 : Pin is connected to Peripheral signal RGMII0.RXD0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO5_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO5_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO5.
+struct ALT_SYSMGR_PINMUX_EMACIO5_s
+    uint32_t  sel :  2;  /* emac0_rx_d0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO5. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO5_s  ALT_SYSMGR_PINMUX_EMACIO5_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO5 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO5_OFST        0x14
+ * Register : emac0_mdio Mux Selection Register - EMACIO6
+ * This register is used to control the peripherals connected to emac0_mdio
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_mdio Mux Selection Field
+ * Field : emac0_mdio Mux Selection Field - sel
+ * Select peripheral signals connected emac0_mdio.
+ * 0 : Pin is connected to GPIO/LoanIO number 6.
+ * 1 : Pin is connected to Peripheral signal I2C2.SDA.
+ * 2 : Pin is connected to Peripheral signal USB1.D5.
+ * 3 : Pin is connected to Peripheral signal RGMII0.MDIO.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO6_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO6_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO6.
+struct ALT_SYSMGR_PINMUX_EMACIO6_s
+    uint32_t  sel :  2;  /* emac0_mdio Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO6. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO6_s  ALT_SYSMGR_PINMUX_EMACIO6_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO6 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO6_OFST        0x18
+ * Register : emac0_mdc Mux Selection Register - EMACIO7
+ * This register is used to control the peripherals connected to emac0_mdc
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_mdc Mux Selection Field
+ * Field : emac0_mdc Mux Selection Field - sel
+ * Select peripheral signals connected emac0_mdc.
+ * 0 : Pin is connected to GPIO/LoanIO number 7.
+ * 1 : Pin is connected to Peripheral signal I2C2.SCL.
+ * 2 : Pin is connected to Peripheral signal USB1.D6.
+ * 3 : Pin is connected to Peripheral signal RGMII0.MDC.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO7_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO7_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO7.
+struct ALT_SYSMGR_PINMUX_EMACIO7_s
+    uint32_t  sel :  2;  /* emac0_mdc Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO7. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO7_s  ALT_SYSMGR_PINMUX_EMACIO7_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO7 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO7_OFST        0x1c
+ * Register : emac0_rx_ctl Mux Selection Register - EMACIO8
+ * This register is used to control the peripherals connected to emac0_rx_ctl
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_rx_ctl Mux Selection Field
+ * Field : emac0_rx_ctl Mux Selection Field - sel
+ * Select peripheral signals connected emac0_rx_ctl.
+ * 0 : Pin is connected to GPIO/LoanIO number 8.
+ * 2 : Pin is connected to Peripheral signal USB1.D7.
+ * 3 : Pin is connected to Peripheral signal RGMII0.RX_CTL.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO8_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO8_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO8.
+struct ALT_SYSMGR_PINMUX_EMACIO8_s
+    uint32_t  sel :  2;  /* emac0_rx_ctl Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO8. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO8_s  ALT_SYSMGR_PINMUX_EMACIO8_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO8 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO8_OFST        0x20
+ * Register : emac0_tx_ctl Mux Selection Register - EMACIO9
+ * This register is used to control the peripherals connected to emac0_tx_ctl
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_tx_ctl Mux Selection Field
+ * Field : emac0_tx_ctl Mux Selection Field - sel
+ * Select peripheral signals connected emac0_tx_ctl.
+ * 0 : Pin is connected to GPIO/LoanIO number 9.
+ * 3 : Pin is connected to Peripheral signal RGMII0.TX_CTL.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO9_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO9_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO9.
+struct ALT_SYSMGR_PINMUX_EMACIO9_s
+    uint32_t  sel :  2;  /* emac0_tx_ctl Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO9. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO9_s  ALT_SYSMGR_PINMUX_EMACIO9_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO9 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO9_OFST        0x24
+ * Register : emac0_rx_clk Mux Selection Register - EMACIO10
+ * This register is used to control the peripherals connected to emac0_rx_clk
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_rx_clk Mux Selection Field
+ * Field : emac0_rx_clk Mux Selection Field - sel
+ * Select peripheral signals connected emac0_rx_clk.
+ * 0 : Pin is connected to GPIO/LoanIO number 10.
+ * 2 : Pin is connected to Peripheral signal USB1.CLK.
+ * 3 : Pin is connected to Peripheral signal RGMII0.RX_CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO10_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO10_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO10.
+struct ALT_SYSMGR_PINMUX_EMACIO10_s
+    uint32_t  sel :  2;  /* emac0_rx_clk Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO10. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO10_s  ALT_SYSMGR_PINMUX_EMACIO10_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO10 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO10_OFST        0x28
+ * Register : emac0_rx_d1 Mux Selection Register - EMACIO11
+ * This register is used to control the peripherals connected to emac0_rx_d1
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_rx_d1 Mux Selection Field
+ * Field : emac0_rx_d1 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_rx_d1.
+ * 0 : Pin is connected to GPIO/LoanIO number 11.
+ * 2 : Pin is connected to Peripheral signal USB1.STP.
+ * 3 : Pin is connected to Peripheral signal RGMII0.RXD1.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO11_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO11_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO11.
+struct ALT_SYSMGR_PINMUX_EMACIO11_s
+    uint32_t  sel :  2;  /* emac0_rx_d1 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO11. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO11_s  ALT_SYSMGR_PINMUX_EMACIO11_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO11 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO11_OFST        0x2c
+ * Register : emac0_rx_d2 Mux Selection Register - EMACIO12
+ * This register is used to control the peripherals connected to emac0_rx_d2
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_rx_d2 Mux Selection Field
+ * Field : emac0_rx_d2 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_rx_d2.
+ * 0 : Pin is connected to GPIO/LoanIO number 12.
+ * 2 : Pin is connected to Peripheral signal USB1.DIR.
+ * 3 : Pin is connected to Peripheral signal RGMII0.RXD2.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO12_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO12_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO12.
+struct ALT_SYSMGR_PINMUX_EMACIO12_s
+    uint32_t  sel :  2;  /* emac0_rx_d2 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO12. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO12_s  ALT_SYSMGR_PINMUX_EMACIO12_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO12 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO12_OFST        0x30
+ * Register : emac0_rx_d3 Mux Selection Register - EMACIO13
+ * This register is used to control the peripherals connected to emac0_rx_d3
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac0_rx_d3 Mux Selection Field
+ * Field : emac0_rx_d3 Mux Selection Field - sel
+ * Select peripheral signals connected emac0_rx_d3.
+ * 0 : Pin is connected to GPIO/LoanIO number 13.
+ * 2 : Pin is connected to Peripheral signal USB1.NXT.
+ * 3 : Pin is connected to Peripheral signal RGMII0.RXD3.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO13_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO13_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO13.
+struct ALT_SYSMGR_PINMUX_EMACIO13_s
+    uint32_t  sel :  2;  /* emac0_rx_d3 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO13. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO13_s  ALT_SYSMGR_PINMUX_EMACIO13_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO13 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO13_OFST        0x34
+ * Register : emac1_tx_clk Mux Selection Register - EMACIO14
+ * This register is used to control the peripherals connected to emac1_tx_clk
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac1_tx_clk Mux Selection Field
+ * Field : emac1_tx_clk Mux Selection Field - sel
+ * Select peripheral signals connected emac1_tx_clk.
+ * 0 : Pin is connected to GPIO/LoanIO number 48.
+ * 3 : Pin is connected to Peripheral signal RGMII1.TX_CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO14_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO14_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO14.
+struct ALT_SYSMGR_PINMUX_EMACIO14_s
+    uint32_t  sel :  2;  /* emac1_tx_clk Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO14. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO14_s  ALT_SYSMGR_PINMUX_EMACIO14_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO14 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO14_OFST        0x38
+ * Register : emac1_tx_d0 Mux Selection Register - EMACIO15
+ * This register is used to control the peripherals connected to emac1_tx_d0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac1_tx_d0 Mux Selection Field
+ * Field : emac1_tx_d0 Mux Selection Field - sel
+ * Select peripheral signals connected emac1_tx_d0.
+ * 0 : Pin is connected to GPIO/LoanIO number 49.
+ * 3 : Pin is connected to Peripheral signal RGMII1.TXD0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO15_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO15_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO15.
+struct ALT_SYSMGR_PINMUX_EMACIO15_s
+    uint32_t  sel :  2;  /* emac1_tx_d0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO15. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO15_s  ALT_SYSMGR_PINMUX_EMACIO15_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO15 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO15_OFST        0x3c
+ * Register : emac1_tx_d1 Mux Selection Register - EMACIO16
+ * This register is used to control the peripherals connected to emac1_tx_d1
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac1_tx_d1 Mux Selection Field
+ * Field : emac1_tx_d1 Mux Selection Field - sel
+ * Select peripheral signals connected emac1_tx_d1.
+ * 0 : Pin is connected to GPIO/LoanIO number 50.
+ * 3 : Pin is connected to Peripheral signal RGMII1.TXD1.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO16_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO16_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO16.
+struct ALT_SYSMGR_PINMUX_EMACIO16_s
+    uint32_t  sel :  2;  /* emac1_tx_d1 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO16. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO16_s  ALT_SYSMGR_PINMUX_EMACIO16_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO16 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO16_OFST        0x40
+ * Register : emac1_tx_ctl Mux Selection Register - EMACIO17
+ * This register is used to control the peripherals connected to emac1_tx_ctl
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac1_tx_ctl Mux Selection Field
+ * Field : emac1_tx_ctl Mux Selection Field - sel
+ * Select peripheral signals connected emac1_tx_ctl.
+ * 0 : Pin is connected to GPIO/LoanIO number 51.
+ * 3 : Pin is connected to Peripheral signal RGMII1.TX_CTL.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO17_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO17_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO17.
+struct ALT_SYSMGR_PINMUX_EMACIO17_s
+    uint32_t  sel :  2;  /* emac1_tx_ctl Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO17. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO17_s  ALT_SYSMGR_PINMUX_EMACIO17_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO17 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO17_OFST        0x44
+ * Register : emac1_rx_d0 Mux Selection Register - EMACIO18
+ * This register is used to control the peripherals connected to emac1_rx_d0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac1_rx_d0 Mux Selection Field
+ * Field : emac1_rx_d0 Mux Selection Field - sel
+ * Select peripheral signals connected emac1_rx_d0.
+ * 0 : Pin is connected to GPIO/LoanIO number 52.
+ * 3 : Pin is connected to Peripheral signal RGMII1.RXD0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO18_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO18_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO18.
+struct ALT_SYSMGR_PINMUX_EMACIO18_s
+    uint32_t  sel :  2;  /* emac1_rx_d0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO18. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO18_s  ALT_SYSMGR_PINMUX_EMACIO18_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO18 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO18_OFST        0x48
+ * Register : emac1_rx_d1 Mux Selection Register - EMACIO19
+ * This register is used to control the peripherals connected to emac1_rx_d1
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | emac1_rx_d1 Mux Selection Field
+ * Field : emac1_rx_d1 Mux Selection Field - sel
+ * Select peripheral signals connected emac1_rx_d1.
+ * 0 : Pin is connected to GPIO/LoanIO number 53.
+ * 3 : Pin is connected to Peripheral signal RGMII1.RXD1.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_EMACIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_EMACIO19_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_EMACIO19_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_EMACIO19.
+struct ALT_SYSMGR_PINMUX_EMACIO19_s
+    uint32_t  sel :  2;  /* emac1_rx_d1 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_EMACIO19. */
+typedef volatile struct ALT_SYSMGR_PINMUX_EMACIO19_s  ALT_SYSMGR_PINMUX_EMACIO19_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_EMACIO19 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_EMACIO19_OFST        0x4c
+ * Register : sdmmc_cmd Mux Selection Register - FLASHIO0
+ * This register is used to control the peripherals connected to sdmmc_cmd
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_cmd Mux Selection Field
+ * Field : sdmmc_cmd Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_cmd.
+ * 0 : Pin is connected to GPIO/LoanIO number 36.
+ * 2 : Pin is connected to Peripheral signal USB0.D0.
+ * 3 : Pin is connected to Peripheral signal SDMMC.CMD.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO0_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO0_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO0.
+struct ALT_SYSMGR_PINMUX_FLSHIO0_s
+    uint32_t  sel :  2;  /* sdmmc_cmd Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO0. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO0_s  ALT_SYSMGR_PINMUX_FLSHIO0_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO0 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO0_OFST        0x50
+ * Register : sdmmc_pwren Mux Selection Register - FLASHIO1
+ * This register is used to control the peripherals connected to sdmmc_pwren
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_pwren Mux Selection Field
+ * Field : sdmmc_pwren Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_pwren.
+ * 0 : Pin is connected to GPIO/LoanIO number 37.
+ * 2 : Pin is connected to Peripheral signal USB0.D1.
+ * 3 : Pin is connected to Peripheral signal SDMMC.PWREN.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO1_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO1_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO1.
+struct ALT_SYSMGR_PINMUX_FLSHIO1_s
+    uint32_t  sel :  2;  /* sdmmc_pwren Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO1. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO1_s  ALT_SYSMGR_PINMUX_FLSHIO1_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO1 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO1_OFST        0x54
+ * Register : sdmmc_d0 Mux Selection Register - FLASHIO2
+ * This register is used to control the peripherals connected to sdmmc_d0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d0 Mux Selection Field
+ * Field : sdmmc_d0 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d0.
+ * 0 : Pin is connected to GPIO/LoanIO number 38.
+ * 2 : Pin is connected to Peripheral signal USB0.D2.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO2_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO2_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO2.
+struct ALT_SYSMGR_PINMUX_FLSHIO2_s
+    uint32_t  sel :  2;  /* sdmmc_d0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO2. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO2_s  ALT_SYSMGR_PINMUX_FLSHIO2_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO2 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO2_OFST        0x58
+ * Register : sdmmc_d1 Mux Selection Register - FLASHIO3
+ * This register is used to control the peripherals connected to sdmmc_d1
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d1 Mux Selection Field
+ * Field : sdmmc_d1 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d1.
+ * 0 : Pin is connected to GPIO/LoanIO number 39.
+ * 2 : Pin is connected to Peripheral signal USB0.D3.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D1.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO3_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO3_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO3.
+struct ALT_SYSMGR_PINMUX_FLSHIO3_s
+    uint32_t  sel :  2;  /* sdmmc_d1 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO3. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO3_s  ALT_SYSMGR_PINMUX_FLSHIO3_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO3 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO3_OFST        0x5c
+ * Register : sdmmc_d4 Mux Selection Register - FLASHIO4
+ * This register is used to control the peripherals connected to sdmmc_d4
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d4 Mux Selection Field
+ * Field : sdmmc_d4 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d4.
+ * 0 : Pin is connected to GPIO/LoanIO number 40.
+ * 2 : Pin is connected to Peripheral signal USB0.D4.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D4.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO4_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO4_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO4.
+struct ALT_SYSMGR_PINMUX_FLSHIO4_s
+    uint32_t  sel :  2;  /* sdmmc_d4 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO4. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO4_s  ALT_SYSMGR_PINMUX_FLSHIO4_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO4 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO4_OFST        0x60
+ * Register : sdmmc_d5 Mux Selection Register - FLASHIO5
+ * This register is used to control the peripherals connected to sdmmc_d5
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d5 Mux Selection Field
+ * Field : sdmmc_d5 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d5.
+ * 0 : Pin is connected to GPIO/LoanIO number 41.
+ * 2 : Pin is connected to Peripheral signal USB0.D5.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D5.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO5_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO5_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO5.
+struct ALT_SYSMGR_PINMUX_FLSHIO5_s
+    uint32_t  sel :  2;  /* sdmmc_d5 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO5. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO5_s  ALT_SYSMGR_PINMUX_FLSHIO5_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO5 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO5_OFST        0x64
+ * Register : sdmmc_d6 Mux Selection Register - FLASHIO6
+ * This register is used to control the peripherals connected to sdmmc_d6
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d6 Mux Selection Field
+ * Field : sdmmc_d6 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d6.
+ * 0 : Pin is connected to GPIO/LoanIO number 42.
+ * 2 : Pin is connected to Peripheral signal USB0.D6.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D6.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO6_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO6_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_SEL_SET(value) (((value) << 0) & 0x00000003)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO6.
+struct ALT_SYSMGR_PINMUX_FLSHIO6_s
+    uint32_t  sel :  2;  /* sdmmc_d6 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO6. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO6_s  ALT_SYSMGR_PINMUX_FLSHIO6_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO6 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO6_OFST        0x68
+ * Register : sdmmc_d7 Mux Selection Register - FLASHIO7
+ * This register is used to control the peripherals connected to sdmmc_d7
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d7 Mux Selection Field
+ * Field : sdmmc_d7 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d7.
+ * 0 : Pin is connected to GPIO/LoanIO number 43.
+ * 2 : Pin is connected to Peripheral signal USB0.D7.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D7.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO7_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO7_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO7.
+struct ALT_SYSMGR_PINMUX_FLSHIO7_s
+    uint32_t  sel :  2;  /* sdmmc_d7 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO7. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO7_s  ALT_SYSMGR_PINMUX_FLSHIO7_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO7 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO7_OFST        0x6c
+ * Register : sdmmc_clk_in Mux Selection Register - FLASHIO8
+ * This register is used to control the peripherals connected to sdmmc_clk_in
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_clk_in Mux Selection Field
+ * Field : sdmmc_clk_in Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_clk_in.
+ * 0 : Pin is connected to GPIO/LoanIO number 44.
+ * 2 : Pin is connected to Peripheral signal USB0.CLK.
+ * 3 : Pin is connected to Peripheral signal SDMMC.CLK_IN.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO8_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO8_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO8.
+struct ALT_SYSMGR_PINMUX_FLSHIO8_s
+    uint32_t  sel :  2;  /* sdmmc_clk_in Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO8. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO8_s  ALT_SYSMGR_PINMUX_FLSHIO8_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO8 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO8_OFST        0x70
+ * Register : sdmmc_clk Mux Selection Register - FLASHIO9
+ * Only reset by a cold reset (ignores warm reset).
+ * NOTE: These registers should not be modified after IO configuration.There is no
+ * support for dynamically changing the Pin Mux selections.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [1:0]  | RW     | 0x0   | sdmmc_clk Mux Selection Field
+ *  [31:2] | ???    | 0x0   | *UNDEFINED*
+ * Field : sdmmc_clk Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_clk.
+ * 0 : Pin is connected to GPIO/LoanIO number 45.
+ * 1 : Pin is connected to Peripheral signal not applicable.
+ * 2 : Pin is connected to Peripheral signal USB0.STP.
+ * 3 : Pin is connected to Peripheral signal SDMMC.CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO9_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO9_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO9.
+struct ALT_SYSMGR_PINMUX_FLSHIO9_s
+    uint32_t  sel :  2;  /* sdmmc_clk Mux Selection Field */
+    uint32_t      : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO9. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO9_s  ALT_SYSMGR_PINMUX_FLSHIO9_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO9 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO9_OFST        0x74
+ * Register : sdmmc_d2 Mux Selection Register - FLASHIO10
+ * This register is used to control the peripherals connected to sdmmc_d2
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d2 Mux Selection Field
+ * Field : sdmmc_d2 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d2.
+ * 0 : Pin is connected to GPIO/LoanIO number 46.
+ * 2 : Pin is connected to Peripheral signal USB0.DIR.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D2.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO10_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO10_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO10.
+struct ALT_SYSMGR_PINMUX_FLSHIO10_s
+    uint32_t  sel :  2;  /* sdmmc_d2 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO10. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO10_s  ALT_SYSMGR_PINMUX_FLSHIO10_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO10 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO10_OFST        0x78
+ * Register : sdmmc_d3 Mux Selection Register - FLASHIO11
+ * This register is used to control the peripherals connected to sdmmc_d3
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | sdmmc_d3 Mux Selection Field
+ * Field : sdmmc_d3 Mux Selection Field - sel
+ * Select peripheral signals connected sdmmc_d3.
+ * 0 : Pin is connected to GPIO/LoanIO number 47.
+ * 2 : Pin is connected to Peripheral signal USB0.NXT.
+ * 3 : Pin is connected to Peripheral signal SDMMC.D3.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_FLSHIO11_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_FLSHIO11_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_FLSHIO11.
+struct ALT_SYSMGR_PINMUX_FLSHIO11_s
+    uint32_t  sel :  2;  /* sdmmc_d3 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_FLSHIO11. */
+typedef volatile struct ALT_SYSMGR_PINMUX_FLSHIO11_s  ALT_SYSMGR_PINMUX_FLSHIO11_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_FLSHIO11 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_FLSHIO11_OFST        0x7c
+ * Register : trace_clk Mux Selection Register - GENERALIO0
+ * This register is used to control the peripherals connected to trace_clk
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_clk Mux Selection Field
+ * Field : trace_clk Mux Selection Field - sel
+ * Select peripheral signals connected trace_clk.
+ * 2 : Pin is connected to Peripheral signal not applicable.
+ * 3 : Pin is connected to Peripheral signal TRACE.CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO0_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO0_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO0.
+struct ALT_SYSMGR_PINMUX_GENERALIO0_s
+    uint32_t  sel :  2;  /* trace_clk Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO0. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO0_s  ALT_SYSMGR_PINMUX_GENERALIO0_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO0 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO0_OFST        0x80
+ * Register : trace_d0 Mux Selection Register - GENERALIO1
+ * This register is used to control the peripherals connected to trace_d0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d0 Mux Selection Field
+ * Field : trace_d0 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d0.
+ * 1 : Pin is connected to Peripheral signal UART0.RX.
+ * 2 : Pin is connected to Peripheral signal SPIS0.CLK.
+ * 3 : Pin is connected to Peripheral signal TRACE.D0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO1_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO1_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO1.
+struct ALT_SYSMGR_PINMUX_GENERALIO1_s
+    uint32_t  sel :  2;  /* trace_d0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO1. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO1_s  ALT_SYSMGR_PINMUX_GENERALIO1_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO1 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO1_OFST        0x84
+ * Register : trace_d1 Mux Selection Register - GENERALIO2
+ * This register is used to control the peripherals connected to trace_d1
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d1 Mux Selection Field
+ * Field : trace_d1 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d1.
+ * 1 : Pin is connected to Peripheral signal UART0.TX.
+ * 2 : Pin is connected to Peripheral signal SPIS0.MOSI.
+ * 3 : Pin is connected to Peripheral signal TRACE.D1.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO2_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO2_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO2.
+struct ALT_SYSMGR_PINMUX_GENERALIO2_s
+    uint32_t  sel :  2;  /* trace_d1 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO2. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO2_s  ALT_SYSMGR_PINMUX_GENERALIO2_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO2 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO2_OFST        0x88
+ * Register : trace_d2 Mux Selection Register - GENERALIO3
+ * This register is used to control the peripherals connected to trace_d2
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d2 Mux Selection Field
+ * Field : trace_d2 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d2.
+ * 1 : Pin is connected to Peripheral signal I2C1.SDA.
+ * 2 : Pin is connected to Peripheral signal SPIS0.MISO.
+ * 3 : Pin is connected to Peripheral signal TRACE.D2.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO3_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO3_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO3.
+struct ALT_SYSMGR_PINMUX_GENERALIO3_s
+    uint32_t  sel :  2;  /* trace_d2 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO3. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO3_s  ALT_SYSMGR_PINMUX_GENERALIO3_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO3 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO3_OFST        0x8c
+ * Register : trace_d3 Mux Selection Register - GENERALIO4
+ * This register is used to control the peripherals connected to trace_d3
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d3 Mux Selection Field
+ * Field : trace_d3 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d3.
+ * 1 : Pin is connected to Peripheral signal I2C1.SCL.
+ * 2 : Pin is connected to Peripheral signal SPIS0.SS0.
+ * 3 : Pin is connected to Peripheral signal TRACE.D3.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO4_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO4_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO4.
+struct ALT_SYSMGR_PINMUX_GENERALIO4_s
+    uint32_t  sel :  2;  /* trace_d3 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO4. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO4_s  ALT_SYSMGR_PINMUX_GENERALIO4_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO4 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO4_OFST        0x90
+ * Register : trace_d4 Mux Selection Register - GENERALIO5
+ * This register is used to control the peripherals connected to trace_d4
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d4 Mux Selection Field
+ * Field : trace_d4 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d4.
+ * 1 : Pin is connected to Peripheral signal CAN1.RX.
+ * 2 : Pin is connected to Peripheral signal SPIS1.CLK.
+ * 3 : Pin is connected to Peripheral signal TRACE.D4.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO5_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO5_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO5.
+struct ALT_SYSMGR_PINMUX_GENERALIO5_s
+    uint32_t  sel :  2;  /* trace_d4 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO5. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO5_s  ALT_SYSMGR_PINMUX_GENERALIO5_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO5 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO5_OFST        0x94
+ * Register : trace_d5 Mux Selection Register - GENERALIO6
+ * This register is used to control the peripherals connected to trace_d5
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d5 Mux Selection Field
+ * Field : trace_d5 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d5.
+ * 0 : Pin is connected to GPIO/LoanIO number 54.
+ * 1 : Pin is connected to Peripheral signal CAN1.TX.
+ * 2 : Pin is connected to Peripheral signal SPIS1.MOSI.
+ * 3 : Pin is connected to Peripheral signal TRACE.D5.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO6_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO6_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO6.
+struct ALT_SYSMGR_PINMUX_GENERALIO6_s
+    uint32_t  sel :  2;  /* trace_d5 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO6. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO6_s  ALT_SYSMGR_PINMUX_GENERALIO6_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO6 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO6_OFST        0x98
+ * Register : trace_d6 Mux Selection Register - GENERALIO7
+ * This register is used to control the peripherals connected to trace_d6
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d6 Mux Selection Field
+ * Field : trace_d6 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d6.
+ * 0 : Pin is connected to GPIO/LoanIO number 55.
+ * 1 : Pin is connected to Peripheral signal I2C0.SDA.
+ * 2 : Pin is connected to Peripheral signal SPIS1.SS0.
+ * 3 : Pin is connected to Peripheral signal TRACE.D6.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO7_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO7_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO7.
+struct ALT_SYSMGR_PINMUX_GENERALIO7_s
+    uint32_t  sel :  2;  /* trace_d6 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO7. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO7_s  ALT_SYSMGR_PINMUX_GENERALIO7_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO7 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO7_OFST        0x9c
+ * Register : trace_d7 Mux Selection Register - GENERALIO8
+ * This register is used to control the peripherals connected to trace_d7
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | trace_d7 Mux Selection Field
+ * Field : trace_d7 Mux Selection Field - sel
+ * Select peripheral signals connected trace_d7.
+ * 0 : Pin is connected to GPIO/LoanIO number 56.
+ * 1 : Pin is connected to Peripheral signal I2C0.SCL.
+ * 2 : Pin is connected to Peripheral signal SPIS1.MISO.
+ * 3 : Pin is connected to Peripheral signal TRACE.D7.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO8_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO8_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO8.
+struct ALT_SYSMGR_PINMUX_GENERALIO8_s
+    uint32_t  sel :  2;  /* trace_d7 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO8. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO8_s  ALT_SYSMGR_PINMUX_GENERALIO8_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO8 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO8_OFST        0xa0
+ * Register : spim0_clk Mux Selection Register - GENERALIO9
+ * This register is used to control the peripherals connected to spim0_clk
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spim0_clk Mux Selection Field
+ * Field : spim0_clk Mux Selection Field - sel
+ * Select peripheral signals connected spim0_clk.
+ * 0 : Pin is connected to GPIO/LoanIO number 57.
+ * 1 : Pin is connected to Peripheral signal UART0.CTS.
+ * 2 : Pin is connected to Peripheral signal I2C1.SDA.
+ * 3 : Pin is connected to Peripheral signal SPIM0.CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO9_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO9_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO9.
+struct ALT_SYSMGR_PINMUX_GENERALIO9_s
+    uint32_t  sel :  2;  /* spim0_clk Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO9. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO9_s  ALT_SYSMGR_PINMUX_GENERALIO9_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO9 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO9_OFST        0xa4
+ * Register : spim0_mosi Mux Selection Register - GENERALIO10
+ * This register is used to control the peripherals connected to spim0_mosi
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spim0_mosi Mux Selection Field
+ * Field : spim0_mosi Mux Selection Field - sel
+ * Select peripheral signals connected spim0_mosi.
+ * 0 : Pin is connected to GPIO/LoanIO number 58.
+ * 1 : Pin is connected to Peripheral signal UART0.RTS.
+ * 2 : Pin is connected to Peripheral signal I2C1.SCL.
+ * 3 : Pin is connected to Peripheral signal SPIM0.MOSI.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO10_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO10_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO10.
+struct ALT_SYSMGR_PINMUX_GENERALIO10_s
+    uint32_t  sel :  2;  /* spim0_mosi Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO10. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO10_s  ALT_SYSMGR_PINMUX_GENERALIO10_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO10 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO10_OFST        0xa8
+ * Register : spim0_miso Mux Selection Register - GENERALIO11
+ * This register is used to control the peripherals connected to spim0_miso
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spim0_miso Mux Selection Field
+ * Field : spim0_miso Mux Selection Field - sel
+ * Select peripheral signals connected spim0_miso.
+ * 0 : Pin is connected to GPIO/LoanIO number 59.
+ * 1 : Pin is connected to Peripheral signal UART1.CTS.
+ * 2 : Pin is connected to Peripheral signal CAN1.RX.
+ * 3 : Pin is connected to Peripheral signal SPIM0.MISO.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO11_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO11_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO11.
+struct ALT_SYSMGR_PINMUX_GENERALIO11_s
+    uint32_t  sel :  2;  /* spim0_miso Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO11. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO11_s  ALT_SYSMGR_PINMUX_GENERALIO11_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO11 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO11_OFST        0xac
+ * Register : spim0_ss0 Mux Selection Register - GENERALIO12
+ * This register is used to control the peripherals connected to spim0_ss0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spim0_ss0 Mux Selection Field
+ * Field : spim0_ss0 Mux Selection Field - sel
+ * Select peripheral signals connected spim0_ss0.
+ * 0 : Pin is connected to GPIO/LoanIO number 60.
+ * 1 : Pin is connected to Peripheral signal UART1.RTS.
+ * 2 : Pin is connected to Peripheral signal CAN1.TX.
+ * 3 : Pin is connected to Peripheral signal SPIM0.SS0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO12_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO12_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO12.
+struct ALT_SYSMGR_PINMUX_GENERALIO12_s
+    uint32_t  sel :  2;  /* spim0_ss0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO12. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO12_s  ALT_SYSMGR_PINMUX_GENERALIO12_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO12 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO12_OFST        0xb0
+ * Register : uart0_rx Mux Selection Register - GENERALIO13
+ * This register is used to control the peripherals connected to uart0_rx
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | uart0_rx Mux Selection Field
+ * Field : uart0_rx Mux Selection Field - sel
+ * Select peripheral signals connected uart0_rx.
+ * 0 : Pin is connected to GPIO/LoanIO number 61.
+ * 1 : Pin is connected to Peripheral signal SPIM0.SS1.
+ * 2 : Pin is connected to Peripheral signal CAN0.RX.
+ * 3 : Pin is connected to Peripheral signal UART0.RX.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO13_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO13_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO13.
+struct ALT_SYSMGR_PINMUX_GENERALIO13_s
+    uint32_t  sel :  2;  /* uart0_rx Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO13. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO13_s  ALT_SYSMGR_PINMUX_GENERALIO13_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO13 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO13_OFST        0xb4
+ * Register : uart0_tx Mux Selection Register - GENERALIO14
+ * This register is used to control the peripherals connected to uart0_tx
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | uart0_tx Mux Selection Field
+ * Field : uart0_tx Mux Selection Field - sel
+ * Select peripheral signals connected uart0_tx.
+ * 0 : Pin is connected to GPIO/LoanIO number 62.
+ * 1 : Pin is connected to Peripheral signal SPIM1.SS1.
+ * 2 : Pin is connected to Peripheral signal CAN0.TX.
+ * 3 : Pin is connected to Peripheral signal UART0.TX.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO14_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO14_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO14.
+struct ALT_SYSMGR_PINMUX_GENERALIO14_s
+    uint32_t  sel :  2;  /* uart0_tx Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO14. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO14_s  ALT_SYSMGR_PINMUX_GENERALIO14_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO14 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO14_OFST        0xb8
+ * Register : i2c0_sda Mux Selection Register - GENERALIO15
+ * This register is used to control the peripherals connected to i2c0_sda
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | i2c0_sda Mux Selection Field
+ * Field : i2c0_sda Mux Selection Field - sel
+ * Select peripheral signals connected i2c0_sda.
+ * 0 : Pin is connected to GPIO/LoanIO number 63.
+ * 1 : Pin is connected to Peripheral signal SPIM1.CLK.
+ * 2 : Pin is connected to Peripheral signal UART1.RX.
+ * 3 : Pin is connected to Peripheral signal I2C0.SDA.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO15_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO15_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO15.
+struct ALT_SYSMGR_PINMUX_GENERALIO15_s
+    uint32_t  sel :  2;  /* i2c0_sda Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO15. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO15_s  ALT_SYSMGR_PINMUX_GENERALIO15_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO15 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO15_OFST        0xbc
+ * Register : i2c0_scl Mux Selection Register - GENERALIO16
+ * This register is used to control the peripherals connected to i2c0_scl
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | i2c0_scl Mux Selection Field
+ * Field : i2c0_scl Mux Selection Field - sel
+ * Select peripheral signals connected i2c0_scl.
+ * 0 : Pin is connected to GPIO/LoanIO number 64.
+ * 1 : Pin is connected to Peripheral signal SPIM1.MOSI.
+ * 2 : Pin is connected to Peripheral signal UART1.TX.
+ * 3 : Pin is connected to Peripheral signal I2C0.SCL.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO16_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO16_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO16.
+struct ALT_SYSMGR_PINMUX_GENERALIO16_s
+    uint32_t  sel :  2;  /* i2c0_scl Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO16. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO16_s  ALT_SYSMGR_PINMUX_GENERALIO16_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO16 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO16_OFST        0xc0
+ * Register : can0_rx Mux Selection Register - GENERALIO17
+ * This register is used to control the peripherals connected to can0_rx
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | can0_rx Mux Selection Field
+ * Field : can0_rx Mux Selection Field - sel
+ * Select peripheral signals connected can0_rx.
+ * 0 : Pin is connected to GPIO/LoanIO number 65.
+ * 1 : Pin is connected to Peripheral signal SPIM1.MISO.
+ * 2 : Pin is connected to Peripheral signal UART0.RX.
+ * 3 : Pin is connected to Peripheral signal CAN0.RX.
+ * Field Access Macros:
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO17_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO17_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO17.
+struct ALT_SYSMGR_PINMUX_GENERALIO17_s
+    uint32_t  sel :  2;  /* can0_rx Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO17. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO17_s  ALT_SYSMGR_PINMUX_GENERALIO17_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO17 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO17_OFST        0xc4
+ * Register : can0_tx Mux Selection Register - GENERALIO18
+ * This register is used to control the peripherals connected to can0_tx
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | can0_tx Mux Selection Field
+ * Field : can0_tx Mux Selection Field - sel
+ * Select peripheral signals connected can0_tx.
+ * 0 : Pin is connected to GPIO/LoanIO number 66.
+ * 1 : Pin is connected to Peripheral signal SPIM1.SS0.
+ * 2 : Pin is connected to Peripheral signal UART0.TX.
+ * 3 : Pin is connected to Peripheral signal CAN0.TX.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO18_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO18_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO18.
+struct ALT_SYSMGR_PINMUX_GENERALIO18_s
+    uint32_t  sel :  2;  /* can0_tx Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO18. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO18_s  ALT_SYSMGR_PINMUX_GENERALIO18_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO18 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO18_OFST        0xc8
+ * Register : spis1_clk Mux Selection Register - GENERALIO19
+ * This register is used to control the peripherals connected to spis1_clk
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis1_clk Mux Selection Field
+ * Field : spis1_clk Mux Selection Field - sel
+ * Select peripheral signals connected spis1_clk.
+ * 0 : Pin is connected to GPIO/LoanIO number 67.
+ * 2 : Pin is connected to Peripheral signal SPIM1.CLK.
+ * 3 : Pin is connected to Peripheral signal SPIS1.CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO19_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO19_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO19.
+struct ALT_SYSMGR_PINMUX_GENERALIO19_s
+    uint32_t  sel :  2;  /* spis1_clk Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO19. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO19_s  ALT_SYSMGR_PINMUX_GENERALIO19_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO19 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO19_OFST        0xcc
+ * Register : spis1_mosi Mux Selection Register - GENERALIO20
+ * This register is used to control the peripherals connected to spis1_mosi
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis1_mosi Mux Selection Field
+ * Field : spis1_mosi Mux Selection Field - sel
+ * Select peripheral signals connected spis1_mosi.
+ * 0 : Pin is connected to GPIO/LoanIO number 68.
+ * 2 : Pin is connected to Peripheral signal SPIM1.MOSI.
+ * 3 : Pin is connected to Peripheral signal SPIS1.MOSI.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO20_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO20_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO20.
+struct ALT_SYSMGR_PINMUX_GENERALIO20_s
+    uint32_t  sel :  2;  /* spis1_mosi Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO20. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO20_s  ALT_SYSMGR_PINMUX_GENERALIO20_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO20 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO20_OFST        0xd0
+ * Register : spis1_miso Mux Selection Register - GENERALIO21
+ * This register is used to control the peripherals connected to spis1_miso
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis1_miso Mux Selection Field
+ * Field : spis1_miso Mux Selection Field - sel
+ * Select peripheral signals connected spis1_miso.
+ * 0 : Pin is connected to GPIO/LoanIO number 69.
+ * 2 : Pin is connected to Peripheral signal SPIM1.MISO.
+ * 3 : Pin is connected to Peripheral signal SPIS1.MISO.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO21_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO21_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_SEL_SET(value) (((value) << 0) & 0x00000003)
+#ifndef __ASSEMBLY__
+ * WARNING: The C register and register group struct declarations are provided for
+ * convenience and illustrative purposes. They should, however, be used with
+ * caution as the C language standard provides no guarantees about the alignment or
+ * atomicity of device memory accesses. The recommended practice for writing
+ * hardware drivers is to use the SoCAL access macros and alt_read_word() and
+ * alt_write_word() functions.
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO21.
+struct ALT_SYSMGR_PINMUX_GENERALIO21_s
+    uint32_t  sel :  2;  /* spis1_miso Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO21. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO21_s  ALT_SYSMGR_PINMUX_GENERALIO21_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO21 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO21_OFST        0xd4
+ * Register : spis1_ss0 Mux Selection Register - GENERALIO22
+ * This register is used to control the peripherals connected to spis1_ss0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis1_ss0 Mux Selection Field
+ * Field : spis1_ss0 Mux Selection Field - sel
+ * Select peripheral signals connected spis1_ss0.
+ * 0 : Pin is connected to GPIO/LoanIO number 70.
+ * 2 : Pin is connected to Peripheral signal SPIM1.SS0.
+ * 3 : Pin is connected to Peripheral signal SPIS1.SS0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO22_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO22_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO22.
+struct ALT_SYSMGR_PINMUX_GENERALIO22_s
+    uint32_t  sel :  2;  /* spis1_ss0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO22. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO22_s  ALT_SYSMGR_PINMUX_GENERALIO22_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO22 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO22_OFST        0xd8
+ * Register : uart1_rx Mux Selection Register - GENERALIO23
+ * This register is used to control the peripherals connected to uart1_rx
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | uart1_rx Mux Selection Field
+ * Field : uart1_rx Mux Selection Field - sel
+ * Select peripheral signals connected uart1_rx.
+ * 2 : Pin is connected to Peripheral signal SPIM1.SS1.
+ * 3 : Pin is connected to Peripheral signal UART1.RX.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO23_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO23_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO23.
+struct ALT_SYSMGR_PINMUX_GENERALIO23_s
+    uint32_t  sel :  2;  /* uart1_rx Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO23. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO23_s  ALT_SYSMGR_PINMUX_GENERALIO23_t;
+#endif  /* __ASSEMBLY__ */
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO23 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO23_OFST        0xdc
+ * Register : uart1_tx Mux Selection Register - GENERALIO24
+ * This register is used to control the peripherals connected to uart1_tx
+ * Only reset by a cold reset (ignores warm reset).
+ * NOTE: These registers should not be modified after IO configuration.There is no
+ * support for dynamically changing the Pin Mux selections.
+ * Register Layout
+ *  Bits   | Access | Reset | Description
+ *  [1:0]  | RW     | 0x0   | uart1_tx Mux Selection Field
+ *  [31:2] | ???    | 0x0   | *UNDEFINED*
+ * Field : uart1_tx Mux Selection Field - sel
+ * Select peripheral signals connected uart1_tx.
+ * 1 : Pin is connected to Peripheral signal not applicable.
+ * 2 : Pin is connected to Peripheral signal SPIM0.CLK.
+ * 3 : Pin is connected to Peripheral signal UART1.TX.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO24_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO24_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO24.
+struct ALT_SYSMGR_PINMUX_GENERALIO24_s
+    uint32_t  sel :  2;  /* uart1_tx Mux Selection Field */
+    uint32_t      : 30;  /* *UNDEFINED* */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO24. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO24_s  ALT_SYSMGR_PINMUX_GENERALIO24_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO24 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO24_OFST        0xe0
+ * Register : i2c1_sda Mux Selection Register - GENERALIO25
+ * This register is used to control the peripherals connected to i2c1_sda
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | i2c1_sda Mux Selection Field
+ * Field : i2c1_sda Mux Selection Field - sel
+ * Select peripheral signals connected i2c1_sda.
+ * 2 : Pin is connected to Peripheral signal SPIM0.MOSI.
+ * 3 : Pin is connected to Peripheral signal I2C1.SDA.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO25_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO25_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO25.
+struct ALT_SYSMGR_PINMUX_GENERALIO25_s
+    uint32_t  sel :  2;  /* i2c1_sda Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO25. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO25_s  ALT_SYSMGR_PINMUX_GENERALIO25_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO25 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO25_OFST        0xe4
+ * Register : i2c1_scl Mux Selection Register - GENERALIO26
+ * This register is used to control the peripherals connected to i2c1_scl
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | i2c1_scl Mux Selection Field
+ * Field : i2c1_scl Mux Selection Field - sel
+ * Select peripheral signals connected i2c1_scl.
+ * 2 : Pin is connected to Peripheral signal SPIM0.MISO.
+ * 3 : Pin is connected to Peripheral signal I2C1.SCL.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO26_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO26_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO26.
+struct ALT_SYSMGR_PINMUX_GENERALIO26_s
+    uint32_t  sel :  2;  /* i2c1_scl Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO26. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO26_s  ALT_SYSMGR_PINMUX_GENERALIO26_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO26 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO26_OFST        0xe8
+ * Register : spim0_ss0_alt Mux Selection Register - GENERALIO27
+ * This register is used to control the peripherals connected to spim0_ss0_alt
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spim0_ss0_alt Mux Selection Field
+ * Field : spim0_ss0_alt Mux Selection Field - sel
+ * Select peripheral signals connected spim0_ss0_alt.
+ * 2 : Pin is connected to Peripheral signal SPIM0.SS0.
+ * 3 : Pin is connected to Peripheral signal not applicable.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO27_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO27_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO27.
+struct ALT_SYSMGR_PINMUX_GENERALIO27_s
+    uint32_t  sel :  2;  /* spim0_ss0_alt Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO27. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO27_s  ALT_SYSMGR_PINMUX_GENERALIO27_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO27 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO27_OFST        0xec
+ * Register : spis0_clk Mux Selection Register - GENERALIO28
+ * This register is used to control the peripherals connected to spis0_clk
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis0_clk Mux Selection Field
+ * Field : spis0_clk Mux Selection Field - sel
+ * Select peripheral signals connected spis0_clk.
+ * 2 : Pin is connected to Peripheral signal SPIM0.SS1.
+ * 3 : Pin is connected to Peripheral signal SPIS0.CLK.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO28_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO28_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO28.
+struct ALT_SYSMGR_PINMUX_GENERALIO28_s
+    uint32_t  sel :  2;  /* spis0_clk Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO28. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO28_s  ALT_SYSMGR_PINMUX_GENERALIO28_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO28 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO28_OFST        0xf0
+ * Register : spis0_mosi Mux Selection Register - GENERALIO29
+ * This register is used to control the peripherals connected to spis0_mosi
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis0_mosi Mux Selection Field
+ * Field : spis0_mosi Mux Selection Field - sel
+ * Select peripheral signals connected spis0_mosi.
+ * 2 : Pin is connected to Peripheral signal not applicable.
+ * 3 : Pin is connected to Peripheral signal SPIS0.MOSI.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO29_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO29_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO29.
+struct ALT_SYSMGR_PINMUX_GENERALIO29_s
+    uint32_t  sel :  2;  /* spis0_mosi Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO29. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO29_s  ALT_SYSMGR_PINMUX_GENERALIO29_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO29 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO29_OFST        0xf4
+ * Register : spis0_miso Mux Selection Register - GENERALIO30
+ * This register is used to control the peripherals connected to spis0_miso
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis0_miso Mux Selection Field
+ * Field : spis0_miso Mux Selection Field - sel
+ * Select peripheral signals connected spis0_miso.
+ * 3 : Pin is connected to Peripheral signal SPIS0.MISO.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO30_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO30_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO30.
+struct ALT_SYSMGR_PINMUX_GENERALIO30_s
+    uint32_t  sel :  2;  /* spis0_miso Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO30. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO30_s  ALT_SYSMGR_PINMUX_GENERALIO30_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO30 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO30_OFST        0xf8
+ * Register : spis0_ss0 Mux Selection Register - GENERALIO31
+ * This register is used to control the peripherals connected to spis0_ss0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | spis0_ss0 Mux Selection Field
+ * Field : spis0_ss0 Mux Selection Field - sel
+ * Select peripheral signals connected spis0_ss0.
+ * 3 : Pin is connected to Peripheral signal SPIS0.SS0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_GENERALIO31_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_GENERALIO31_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_GENERALIO31.
+struct ALT_SYSMGR_PINMUX_GENERALIO31_s
+    uint32_t  sel :  2;  /* spis0_ss0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_GENERALIO31. */
+typedef volatile struct ALT_SYSMGR_PINMUX_GENERALIO31_s  ALT_SYSMGR_PINMUX_GENERALIO31_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_GENERALIO31 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_GENERALIO31_OFST        0xfc
+ * Register : nand_ale Mux Selection Register - MIXED1IO0
+ * This register is used to control the peripherals connected to nand_ale
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_ale Mux Selection Field
+ * Field : nand_ale Mux Selection Field - sel
+ * Select peripheral signals connected nand_ale.
+ * 0 : Pin is connected to GPIO/LoanIO number 14.
+ * 1 : Pin is connected to Peripheral signal QSPI.SS3.
+ * 2 : Pin is connected to Peripheral signal RGMII1.TX_CLK.
+ * 3 : Pin is connected to Peripheral signal NAND.ale.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO0_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO0_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO0.
+struct ALT_SYSMGR_PINMUX_MIXED1IO0_s
+    uint32_t  sel :  2;  /* nand_ale Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO0. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO0_s  ALT_SYSMGR_PINMUX_MIXED1IO0_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO0 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO0_OFST        0x100
+ * Register : nand_ce Mux Selection Register - MIXED1IO1
+ * This register is used to control the peripherals connected to nand_ce
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_ce Mux Selection Field
+ * Field : nand_ce Mux Selection Field - sel
+ * Select peripheral signals connected nand_ce.
+ * 0 : Pin is connected to GPIO/LoanIO number 15.
+ * 1 : Pin is connected to Peripheral signal USB1.D0.
+ * 2 : Pin is connected to Peripheral signal RGMII1.TXD0.
+ * 3 : Pin is connected to Peripheral signal NAND.ce.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO1_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO1_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO1.
+struct ALT_SYSMGR_PINMUX_MIXED1IO1_s
+    uint32_t  sel :  2;  /* nand_ce Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO1. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO1_s  ALT_SYSMGR_PINMUX_MIXED1IO1_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO1 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO1_OFST        0x104
+ * Register : nand_cle Mux Selection Register - MIXED1IO2
+ * This register is used to control the peripherals connected to nand_cle
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_cle Mux Selection Field
+ * Field : nand_cle Mux Selection Field - sel
+ * Select peripheral signals connected nand_cle.
+ * 0 : Pin is connected to GPIO/LoanIO number 16.
+ * 1 : Pin is connected to Peripheral signal USB1.D1.
+ * 2 : Pin is connected to Peripheral signal RGMII1.TXD1.
+ * 3 : Pin is connected to Peripheral signal NAND.cle.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO2_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO2_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO2.
+struct ALT_SYSMGR_PINMUX_MIXED1IO2_s
+    uint32_t  sel :  2;  /* nand_cle Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO2. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO2_s  ALT_SYSMGR_PINMUX_MIXED1IO2_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO2 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO2_OFST        0x108
+ * Register : nand_re Mux Selection Register - MIXED1IO3
+ * This register is used to control the peripherals connected to nand_re
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_re Mux Selection Field
+ * Field : nand_re Mux Selection Field - sel
+ * Select peripheral signals connected nand_re.
+ * 0 : Pin is connected to GPIO/LoanIO number 17.
+ * 1 : Pin is connected to Peripheral signal USB1.D2.
+ * 2 : Pin is connected to Peripheral signal RGMII1.TXD2.
+ * 3 : Pin is connected to Peripheral signal NAND.re.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO3_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO3_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO3.
+struct ALT_SYSMGR_PINMUX_MIXED1IO3_s
+    uint32_t  sel :  2;  /* nand_re Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO3. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO3_s  ALT_SYSMGR_PINMUX_MIXED1IO3_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO3 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO3_OFST        0x10c
+ * Register : nand_rb Mux Selection Register - MIXED1IO4
+ * This register is used to control the peripherals connected to nand_rb
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_rb Mux Selection Field
+ * Field : nand_rb Mux Selection Field - sel
+ * Select peripheral signals connected nand_rb.
+ * 0 : Pin is connected to GPIO/LoanIO number 18.
+ * 1 : Pin is connected to Peripheral signal USB1.D3.
+ * 2 : Pin is connected to Peripheral signal RGMII1.TXD3.
+ * 3 : Pin is connected to Peripheral signal NAND.rb.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO4_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO4_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO4.
+struct ALT_SYSMGR_PINMUX_MIXED1IO4_s
+    uint32_t  sel :  2;  /* nand_rb Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO4. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO4_s  ALT_SYSMGR_PINMUX_MIXED1IO4_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO4 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO4_OFST        0x110
+ * Register : nand_dq0 Mux Selection Register - MIXED1IO5
+ * This register is used to control the peripherals connected to nand_dq0
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_dq0 Mux Selection Field
+ * Field : nand_dq0 Mux Selection Field - sel
+ * Select peripheral signals connected nand_dq0.
+ * 0 : Pin is connected to GPIO/LoanIO number 19.
+ * 2 : Pin is connected to Peripheral signal RGMII1.RXD0.
+ * 3 : Pin is connected to Peripheral signal NAND.dq0.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO5_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO5_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO5.
+struct ALT_SYSMGR_PINMUX_MIXED1IO5_s
+    uint32_t  sel :  2;  /* nand_dq0 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO5. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO5_s  ALT_SYSMGR_PINMUX_MIXED1IO5_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO5 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO5_OFST        0x114
+ * Register : nand_dq1 Mux Selection Register - MIXED1IO6
+ * This register is used to control the peripherals connected to nand_dq1
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_dq1 Mux Selection Field
+ * Field : nand_dq1 Mux Selection Field - sel
+ * Select peripheral signals connected nand_dq1.
+ * 0 : Pin is connected to GPIO/LoanIO number 20.
+ * 1 : Pin is connected to Peripheral signal I2C3.SDA.
+ * 2 : Pin is connected to Peripheral signal RGMII1.MDIO.
+ * 3 : Pin is connected to Peripheral signal NAND.dq1.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO6_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO6_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO6.
+struct ALT_SYSMGR_PINMUX_MIXED1IO6_s
+    uint32_t  sel :  2;  /* nand_dq1 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO6. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO6_s  ALT_SYSMGR_PINMUX_MIXED1IO6_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO6 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO6_OFST        0x118
+ * Register : nand_dq2 Mux Selection Register - MIXED1IO7
+ * This register is used to control the peripherals connected to nand_dq2
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_dq2 Mux Selection Field
+ * Field : nand_dq2 Mux Selection Field - sel
+ * Select peripheral signals connected nand_dq2.
+ * 0 : Pin is connected to GPIO/LoanIO number 21.
+ * 1 : Pin is connected to Peripheral signal I2C3.SCL.
+ * 2 : Pin is connected to Peripheral signal RGMII1.MDC.
+ * 3 : Pin is connected to Peripheral signal NAND.dq2.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO7_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO7_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO7.
+struct ALT_SYSMGR_PINMUX_MIXED1IO7_s
+    uint32_t  sel :  2;  /* nand_dq2 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO7. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO7_s  ALT_SYSMGR_PINMUX_MIXED1IO7_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO7 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO7_OFST        0x11c
+ * Register : nand_dq3 Mux Selection Register - MIXED1IO8
+ * This register is used to control the peripherals connected to nand_dq3
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_dq3 Mux Selection Field
+ * Field : nand_dq3 Mux Selection Field - sel
+ * Select peripheral signals connected nand_dq3.
+ * 0 : Pin is connected to GPIO/LoanIO number 22.
+ * 1 : Pin is connected to Peripheral signal USB1.D4.
+ * 2 : Pin is connected to Peripheral signal RGMII1.RX_CTL.
+ * 3 : Pin is connected to Peripheral signal NAND.dq3.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO8_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO8_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO8.
+struct ALT_SYSMGR_PINMUX_MIXED1IO8_s
+    uint32_t  sel :  2;  /* nand_dq3 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO8. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO8_s  ALT_SYSMGR_PINMUX_MIXED1IO8_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO8 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO8_OFST        0x120
+ * Register : nand_dq4 Mux Selection Register - MIXED1IO9
+ * This register is used to control the peripherals connected to nand_dq4
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_dq4 Mux Selection Field
+ * Field : nand_dq4 Mux Selection Field - sel
+ * Select peripheral signals connected nand_dq4.
+ * 0 : Pin is connected to GPIO/LoanIO number 23.
+ * 1 : Pin is connected to Peripheral signal USB1.D5.
+ * 2 : Pin is connected to Peripheral signal RGMII1.TX_CTL.
+ * 3 : Pin is connected to Peripheral signal NAND.dq4.
+/* The Least Significant Bit (LSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_LSB        0
+/* The Most Significant Bit (MSB) position of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_MSB        1
+/* The width in bits of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_WIDTH      2
+/* The mask used to set the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_SET_MSK    0x00000003
+/* The mask used to clear the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field value. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_CLR_MSK    0xfffffffc
+/* The reset value of the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_RESET      0x0
+/* Extracts the ALT_SYSMGR_PINMUX_MIXED1IO9_SEL field value from a register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_GET(value) (((value) & 0x00000003) >> 0)
+/* Produces a ALT_SYSMGR_PINMUX_MIXED1IO9_SEL register field value suitable for setting the register. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_SEL_SET(value) (((value) << 0) & 0x00000003)
+ * The struct declaration for register ALT_SYSMGR_PINMUX_MIXED1IO9.
+struct ALT_SYSMGR_PINMUX_MIXED1IO9_s
+    uint32_t  sel :  2;  /* nand_dq4 Mux Selection Field */
+/* The typedef declaration for register ALT_SYSMGR_PINMUX_MIXED1IO9. */
+typedef volatile struct ALT_SYSMGR_PINMUX_MIXED1IO9_s  ALT_SYSMGR_PINMUX_MIXED1IO9_t;
+/* The byte offset of the ALT_SYSMGR_PINMUX_MIXED1IO9 register from the beginning of the component. */
+#define ALT_SYSMGR_PINMUX_MIXED1IO9_OFST        0x124
+ * Register : nand_dq5 Mux Selection Register - MIXED1IO10
+ * This register is used to control the peripherals connected to nand_dq5
+ * Register Layout
+ *  [1:0]  | RW     | 0x0   | nand_dq5 Mux Selection Field
+ * Field : nand_dq5 Mux Selection Field - sel
+ * Select peripheral signals connected nand_dq5.
+ * 0 : Pin is connected to GPIO/LoanIO number 24.
+ * 1 : Pin is connected to Peripheral signal USB1.D6.
+ * 2 : Pin is connected to Peripheral signal RGMII1.RX_CLK.
+ * 3 : Pin is connected to Peripheral signal NAND.dq5.
