[PATCH] posix: Use interal mutex for once implementation
Sebastian Huber
Tue Mar 18 07:36:38 UTC 2014
Enable pthread_once() for all configurations. The pthread_once()
function is one means to initialize POSIX keys. Another use case is the
C++ support.
cpukit/posix/Makefile.am | 7 +--
cpukit/posix/include/rtems/posix/onceimpl.h | 57 ---------------------------
cpukit/posix/preinstall.am | 4 --
cpukit/posix/src/once.c | 46 ---------------------
cpukit/posix/src/pthreadonce.c | 49 ++++++++++-------------
cpukit/sapi/include/confdefs.h | 14 +-----
cpukit/sapi/src/exinit.c | 3 +-
cpukit/sapi/src/posixapi.c | 1 -
cpukit/score/include/rtems/score/apimutex.h | 12 ++++++
testsuites/psxtests/psxconfig01/init.c | 3 +-
10 files changed, 43 insertions(+), 153 deletions(-)
delete mode 100644 cpukit/posix/include/rtems/posix/onceimpl.h
delete mode 100644 cpukit/posix/src/once.c
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 53a5887..346b65a 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -36,7 +36,6 @@ include_rtems_posix_HEADERS += include/rtems/posix/mqueue.h
include_rtems_posix_HEADERS += include/rtems/posix/mqueueimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/mutex.h
include_rtems_posix_HEADERS += include/rtems/posix/muteximpl.h
-include_rtems_posix_HEADERS += include/rtems/posix/onceimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/priorityimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/psignal.h
include_rtems_posix_HEADERS += include/rtems/posix/psignalimpl.h
@@ -113,9 +112,6 @@ libposix_a_SOURCES += src/mutexattrdestroy.c src/mutexattrgetprioceiling.c \
src/mutexlocksupp.c src/mutexsetprioceiling.c src/mutextimedlock.c \
src/mutextranslatereturncode.c src/mutextrylock.c src/mutexunlock.c
-## ONCE_C_FILES
-libposix_a_SOURCES += src/once.c src/pthreadonce.c
## PTHREAD_C_FILES
libposix_a_SOURCES += src/pthreadatfork.c src/pthreadattrdestroy.c \
src/pthreadattrgetdetachstate.c src/pthreadattrgetinheritsched.c \
@@ -160,6 +156,9 @@ libposix_a_SOURCES += src/key.c src/keycreate.c src/keydelete.c \
src/keygetspecific.c src/keyfreememory.c src/keyrundestructors.c \
src/keysetspecific.c
+## ONCE_C_FILES
+libposix_a_SOURCES += src/pthreadonce.c
libposix_a_SOURCES += src/sigaddset.c src/sigdelset.c src/sigfillset.c \
src/sigemptyset.c src/sigismember.c
diff --git a/cpukit/posix/include/rtems/posix/onceimpl.h b/cpukit/posix/include/rtems/posix/onceimpl.h
deleted file mode 100644
index 48f876a..0000000
--- a/cpukit/posix/include/rtems/posix/onceimpl.h
+++ /dev/null
@@ -1,57 +0,0 @@
- * @file
- * @brief Private Inlined Routines for POSIX Once
- * This include file contains the static inline implementation of the private
- * inlined routines for POSIX once.
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
- * COPYRIGHT (c) 2013.
- * Chris Johns <chrisj at rtems.org>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#include <rtems/score/objectimpl.h>
-#include <rtems/score/percpu.h>
-#ifndef _RTEMS_POSIX_ONCEIMPL_H
-#define _RTEMS_POSIX_ONCEIMPL_H
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @addtogroup POSIX_ONCE
- * @brief Lock to allow once mutex's to be initialized.
-POSIX_EXTERN pthread_mutex_t _POSIX_Once_Lock;
- * @brief POSIX once manager initialization.
- * This routine performs the initialization necessary for this manager.
-void _POSIX_Once_Manager_initialization(void);
-#ifdef __cplusplus
-#endif
-#endif
-/* end of include file */
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index d0f36f9..6e3f2a2 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -88,10 +88,6 @@ $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h: include/rtems/posix/muteximpl.h $(PR
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h
-$(PROJECT_INCLUDE)/rtems/posix/onceimpl.h: include/rtems/posix/onceimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/onceimpl.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/onceimpl.h
$(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h: include/rtems/posix/priorityimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h
diff --git a/cpukit/posix/src/once.c b/cpukit/posix/src/once.c
index e91daf2..0000000
--- a/cpukit/posix/src/once.c
+++ /dev/null
@@ -1,46 +0,0 @@
- * @file
- * @brief POSIX Once Manager Initialization
- * @ingroup POSIX_ONCE POSIX Once Support
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <pthread.h>
-#include <errno.h>
-#include <rtems.h>
-#include <rtems/posix/posixapi.h>
-#include <rtems/posix/onceimpl.h>
- pthread_mutexattr_t mattr;
- int eno;
- _POSIX_Once_Lock = PTHREAD_MUTEX_INITIALIZER;
- eno = pthread_mutexattr_init( &mattr );
- _Assert( eno == 0 );
- eno = pthread_mutexattr_settype( &mattr, PTHREAD_MUTEX_RECURSIVE );
- eno = pthread_mutex_init( &_POSIX_Once_Lock, &mattr );
- if ( eno != 0 )
- _POSIX_Fatal_error( POSIX_FD_PTHREAD_ONCE, eno );
- eno = pthread_mutexattr_destroy( &mattr );
diff --git a/cpukit/posix/src/pthreadonce.c b/cpukit/posix/src/pthreadonce.c
index aa8afe7..262f673 100644
--- a/cpukit/posix/src/pthreadonce.c
+++ b/cpukit/posix/src/pthreadonce.c
@@ -23,8 +23,7 @@
-#include <rtems.h>
-#include <rtems/system.h>
+#include <rtems/score/apimutex.h>
#define PTHREAD_ONCE_INIT_NOT_RUN 0
@@ -45,34 +44,30 @@ int pthread_once(
return EINVAL;
if ( once_control->init_executed != PTHREAD_ONCE_INIT_COMPLETE ) {
- r = pthread_mutex_lock( &_POSIX_Once_Lock );
- if ( r == 0 ) {
- int rr;
+ _Once_Lock();
- * Getting to here means the once_control is locked so we have:
- * 1. The init has not run and the state is PTHREAD_ONCE_INIT_NOT_RUN.
- * 2. The init has finished and the state is PTHREAD_ONCE_INIT_RUN.
- * 3. The init is being run by this thread and the state
- * PTHREAD_ONCE_INIT_RUNNING so we are nesting. This is an error.
+ * Getting to here means the once_control is locked so we have:
+ * 1. The init has not run and the state is PTHREAD_ONCE_INIT_NOT_RUN.
+ * 2. The init has finished and the state is PTHREAD_ONCE_INIT_RUN.
+ * 3. The init is being run by this thread and the state
+ * PTHREAD_ONCE_INIT_RUNNING so we are nesting. This is an error.
- switch ( once_control->init_executed ) {
- case PTHREAD_ONCE_INIT_NOT_RUN:
- once_control->init_executed = PTHREAD_ONCE_INIT_RUNNING;
- (*init_routine)();
- once_control->init_executed = PTHREAD_ONCE_INIT_COMPLETE;
- break;
- case PTHREAD_ONCE_INIT_RUNNING:
- r = EINVAL;
- break;
- default:
- break;
- rr = pthread_mutex_unlock( &_POSIX_Once_Lock );
- if ( r == 0 )
- r = rr;
+ switch ( once_control->init_executed ) {
+ case PTHREAD_ONCE_INIT_NOT_RUN:
+ once_control->init_executed = PTHREAD_ONCE_INIT_RUNNING;
+ (*init_routine)();
+ once_control->init_executed = PTHREAD_ONCE_INIT_COMPLETE;
+ break;
+ case PTHREAD_ONCE_INIT_RUNNING:
+ r = EINVAL;
+ break;
+ default:
+ break;
+ _Once_Unlock();
return r;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 08b8b5f..add58ae 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1766,11 +1766,6 @@ const rtems_libio_helper rtems_fs_init_helper =
#include <rtems/posix/timer.h>
- * POSIX Once support uses a single mutex.
- #define CONFIGURE_MAXIMUM_POSIX_INTERNAL_MUTEXES 1
* Account for the object control structures plus the name
* of the object to be duplicated.
@@ -1899,7 +1894,6 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_MEMORY_FOR_POSIX \
( CONFIGURE_MEMORY_FOR_POSIX_MUTEXES( CONFIGURE_MAXIMUM_POSIX_MUTEXES + \
- CONFIGURE_MAXIMUM_POSIX_INTERNAL_MUTEXES + \
CONFIGURE_MAXIMUM_GO_CHANNELS + CONFIGURE_GO_INIT_MUTEXES) + \
CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES( \
CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES + \
@@ -2130,11 +2124,11 @@ const rtems_libio_helper rtems_fs_init_helper =
#endif
- * RTEMS uses one instance of an internal mutex class. This accounts
- * for that mutex
+ * RTEMS uses two instance of an internal mutex class. This accounts
+ * for these mutexes.
#define CONFIGURE_API_MUTEX_MEMORY \
- _Configure_Object_RAM(1, sizeof(API_Mutex_Control))
+ _Configure_Object_RAM(2, sizeof(API_Mutex_Control))
* This calculates the amount of memory reserved for the IDLE tasks.
@@ -2349,7 +2343,6 @@ const rtems_libio_helper rtems_fs_init_helper =
CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_ADA_TASKS +
CONFIGURE_MAXIMUM_GOROUTINES,
CONFIGURE_MAXIMUM_POSIX_MUTEXES + CONFIGURE_GNAT_MUTEXES +
CONFIGURE_MAXIMUM_ADA_TASKS + CONFIGURE_MAXIMUM_FAKE_ADA_TASKS +
CONFIGURE_GO_INIT_MUTEXES + CONFIGURE_MAXIMUM_GO_CHANNELS,
@@ -2599,7 +2592,6 @@ const rtems_libio_helper rtems_fs_init_helper =
#ifdef RTEMS_POSIX_API
/* POSIX API Pieces */
CONFIGURE_MAXIMUM_GO_CHANNELS + CONFIGURE_GO_INIT_MUTEXES),
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index 077a092..cc929cb 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -116,8 +116,9 @@ void rtems_initialize_data_structures(void)
_Objects_Information_table[OBJECTS_INTERNAL_API] = _Internal_Objects;
- _API_Mutex_Initialization( 1 );
+ _API_Mutex_Initialization( 2 );
_API_Mutex_Allocate( &_RTEMS_Allocator_Mutex );
+ _API_Mutex_Allocate( &_Once_Mutex );
_Watchdog_Handler_initialization();
_TOD_Handler_initialization();
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index de502ec..7014b59 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -79,7 +79,6 @@ void _POSIX_API_Initialize(void)
_POSIX_Condition_variables_Manager_initialization();
_POSIX_Mutex_Manager_initialization();
_POSIX_Message_queue_Manager_initialization();
- _POSIX_Once_Manager_initialization();
_POSIX_Semaphore_Manager_initialization();
_POSIX_Timer_Manager_initialization();
_POSIX_Barrier_Manager_initialization();
diff --git a/cpukit/score/include/rtems/score/apimutex.h b/cpukit/score/include/rtems/score/apimutex.h
index a34270e..1178ccb 100644
--- a/cpukit/score/include/rtems/score/apimutex.h
+++ b/cpukit/score/include/rtems/score/apimutex.h
@@ -120,6 +120,18 @@ SCORE_EXTERN API_Mutex_Control *_RTEMS_Allocator_Mutex;
#define _RTEMS_Unlock_allocator() \
_API_Mutex_Unlock( _RTEMS_Allocator_Mutex )
+SCORE_EXTERN API_Mutex_Control *_Once_Mutex;
+static inline void _Once_Lock( void )
+ _API_Mutex_Lock( _Once_Mutex );
+static inline void _Once_Unlock( void )
+ _API_Mutex_Unlock( _Once_Mutex );
#ifdef __cplusplus
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index 17849b0..3481f32 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -487,8 +487,7 @@ static rtems_task Init(rtems_task_argument argument)
rtems_resource_snapshot_take(&snapshot);
rtems_test_assert(
- snapshot.posix_api.active_mutexes ==
- (CONFIGURE_MAXIMUM_POSIX_MUTEXES + CONFIGURE_MAXIMUM_POSIX_INTERNAL_MUTEXES)
+ snapshot.posix_api.active_mutexes == CONFIGURE_MAXIMUM_POSIX_MUTEXES
#endif
1.7.7
