Usage of POSIX keys instead of task variables
Christian Mauderer Christian.Mauderer at embedded-brains.de
Tue Mar 18 10:36:24 UTC 2014
Hello,
I've planed to work on using POSIX keys instead of task variables in
the shell, the gxx_wrappers and rtems_rpc. This should makes it
possible to use the mentioned modules with SMP.
There is a small section in the Wiki regarding this topic:
http://www.rtems.org/wiki/index.php?title=SMP#Task_Variables
The POSIX keys are already outside the POSIX-API. To use them
efficiently the function pthread_once is also necessary. Sebastian
already sent a patch to make this function available for all
configurations.
My first step will be to extract the test for pthread_once out of the
psx01 test so that it can build independent of the POSIX-API.
After this the next steps will be to replace the task variables in the
mentioned modules.
Kind regards
Christian Mauderer
embedded brains GmbH
Christian Mauderer     Dornierstr. 4
D-82178 Puchheim       Germany
email: Christian.Mauderer at embedded-brains.de
Phone: +49-89-18 94 741-18
Fax:   +49-89-18 94 741-08
