[PATCH 1/2] cpukit/shell: Replace task variable for current shell environment with posix keys.
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed Mar 19 11:54:21 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
cpukit/libmisc/shell/shell.c | 54 ++++++++++++++++++++++++++++++--------------
cpukit/libmisc/shell/shell.h | 4 ++--
2 files changed, 39 insertions(+), 19 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 90bb512..4c1bfea 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -38,7 +38,7 @@
#include <pwd.h>
-rtems_shell_env_t rtems_global_shell_env = {
+static rtems_shell_env_t rtems_global_shell_env = {
.magic = rtems_build_name('S', 'E', 'N', 'V'),
.devname = CONSOLE_DEVICE_NAME,
.taskname = "SHGL",
@@ -54,6 +54,27 @@ rtems_shell_env_t rtems_global_shell_env = {
.login_check = NULL
+static pthread_once_t rtems_shell_current_env_once = PTHREAD_ONCE_INIT;
+static pthread_key_t rtems_shell_current_env_key;
+ * Create the posix key.
+static void rtems_shell_current_env_make_key(void)
+ (void) pthread_key_create(&rtems_shell_current_env_key, rtems_shell_env_free);
+ * Return the current shell environment
+rtems_shell_env_t *rtems_shell_get_current_env(void)
+ void *ptr = pthread_getspecific(rtems_shell_current_env_key);
+ assert (ptr != NULL);
+ return (rtems_shell_env_t *) ptr;
rtems_shell_env_t *rtems_current_shell_env = &rtems_global_shell_env;
@@ -650,6 +671,7 @@ bool rtems_shell_main_loop(
rtems_shell_env_t *shell_env;
rtems_shell_cmd_t *shell_cmd;
rtems_status_code sc;
+ int eno;
struct termios term;
struct termios previous_term;
char *prompt = NULL;
@@ -667,23 +689,21 @@ bool rtems_shell_main_loop(
rtems_shell_initialize_command_set();
- shell_env =
- rtems_current_shell_env = rtems_shell_init_env( shell_env_arg );
- * @todo chrisj
- * Remove the use of task variables. Change to have a single
- * allocation per shell and then set into a notepad register
- * in the TCB. Provide a function to return the pointer.
- * Task variables are a virus to embedded systems software.
- sc = rtems_task_variable_add(
- RTEMS_SELF,
- (void*)&rtems_current_shell_env,
- rtems_shell_env_free
+ eno = pthread_once(
+ &rtems_shell_current_env_once,
+ rtems_shell_current_env_make_key
- if (sc != RTEMS_SUCCESSFUL) {
- rtems_error(sc,"rtems_task_variable_add(current_shell_env):");
+ assert(eno == 0);
+ shell_env = rtems_shell_init_env(shell_env_arg);
+ if (shell_env == NULL) {
+ rtems_error(0, "rtems_shell_init_env");
+ return false;
+ eno = pthread_setspecific(rtems_shell_current_env_key, shell_env);
+ if (eno != 0) {
+ rtems_error(0, "pthread_setspecific(shell_current_env_key)");
return false;
diff --git a/cpukit/libmisc/shell/shell.h b/cpukit/libmisc/shell/shell.h
index 079ef66..af09ac3 100644
--- a/cpukit/libmisc/shell/shell.h
+++ b/cpukit/libmisc/shell/shell.h
@@ -205,8 +205,8 @@ bool rtems_shell_main_loop(
rtems_shell_env_t *rtems_shell_env
-extern rtems_shell_env_t rtems_global_shell_env;
-extern rtems_shell_env_t *rtems_current_shell_env;
+rtems_shell_env_t *rtems_shell_get_current_env(void);
+#define rtems_current_shell_env rtems_shell_get_current_env()
* The types of file systems we can mount. We have them broken out
1.8.4.5
