License change from www.rtems.com to www.rtems.org.
Wed Mar 19 15:00:47 UTC 2014
On Wed, Mar 19, 2014 at 1:42 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 18/02/2014 5:23 pm, Chris Johns wrote:
>> The attached script changes the license URL in the source tree. The
>> script reports 4922 files need changing.
> This is the patch with now 4958 changes ...
>  http://www.rtems.org/ftp/pub/rtems/people/chrisj/rtems-com-to-org.diff
> I will commit this Friday morning my time (UTC/GMT +10 hours).
> Please note since I first posted this change there have been 36 more .com
> references added. It is the same script and this result is confusing.
Yes, I complained about the copy-paste of .com addresses, but the
response was "Chris will fix it anyway so it doesn't matter."
>> Please let me know if you have any issue with the change or you spot any
>> problems.
> I assume there are none.
>> There will need to be some clean up in the doc directory.
> Any takers ?
Push it. All new commits should use the .org address now to reduce churn.
> Chris
> rtems-devel mailing list
> rtems-devel at rtems.org
