[PATCH 2/2] samples/fileio: Adaption for shell with posix keys.
Wed Mar 19 15:49:18 UTC 2014
On 2014-03-19 16:33, Gedare Bloom wrote:
> On Wed, Mar 19, 2014 at 11:15 AM, Christian Mauderer
> <christian.mauderer at embedded-brains.de>  wrote:
>> >From: Christian Mauderer<Christian.Mauderer at embedded-brains.de>
>> >Add necessary objects.
>> >Add login function and custom device name for better testing of the shell.
>> >  testsuites/samples/fileio/init.c   | 5 +++--
>> >  testsuites/samples/fileio/system.h | 3 +++
>> >  2 files changed, 6 insertions(+), 2 deletions(-)
>> >diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
>> >index 80da4ab..2a0f9db 100644
>> >--- a/testsuites/samples/fileio/init.c
>> >+++ b/testsuites/samples/fileio/init.c
>> >@@ -708,10 +708,11 @@ static void fileio_start_shell(void)
>> >      "SHLL",                          /* task_name */
>> >      RTEMS_MINIMUM_STACK_SIZE * 4,    /* task_stacksize */
>> >      100,                             /* task_priority */
>> >-    "/dev/console",                  /* devname */
>> >+    "/dev/foobar",                   /* devname */
>> >+    /* device is currently ignored by the shell if it is not a pty */
>> >      false,                           /* forever */
>> >      true,                            /* wait */
>> >-    NULL                             /* login */
>> >+    rtems_shell_login_check          /* login */
>> >  #endif /* USE_SHELL */
>> >diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
>> >index 726a507..654f727 100644
>> >--- a/testsuites/samples/fileio/system.h
>> >+++ b/testsuites/samples/fileio/system.h
>> >@@ -47,6 +47,9 @@ rtems_task Init(
>> >  #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY  14
>> >  #endif
>> >+#define CONFIGURE_MAXIMUM_POSIX_KEYS             1
>> >+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS  1
> Should this CONFIGURE_KEYS be dealt with at confdefs.h?
This is the basic problem with the RTEMS configuration.  You have this problem
with device drivers, C++, library functions etc.
If you don't know how many objects you need, then use unlimited objects and a
unified work space.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
