[PATCH 12/25] lm32_evr/include/bsp.h: Remove rtems_bsp_delay()
Thu Mar 20 18:29:08 UTC 2014
 c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h |   16 +---------------
 1 files changed, 1 insertions(+), 15 deletions(-)
diff --git a/c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h b/c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h
index 7a532a7..1defb2f 100644
--- a/c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h
+++ b/c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h
@@ -6,12 +6,7 @@
  * @brief Global BSP definitions.
-/*  bsp.h
- *  This include file contains all board IO definitions.
- *  XXX : put yours in here
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
@@ -74,15 +69,6 @@ extern int rtems_tsmac_driver_attach(struct rtems_bsdnet_ifconfig *config,
 #define TSMAC_FORCE_10BASET
 #endif
-   *  Simple spin delay in microsecond units for device drivers.
-   *  This is very dependent on the clock speed of the target.
-#define rtems_bsp_delay( microseconds ) \
 /* functions */
 #if 0
 rtems_isr_entry set_vector(                     /* returns old vector */
1.7.1
