[PATCH 09/25] gensh1/include/bsp.h: Remove rtems_bsp_delay()
Thu Mar 20 18:29:05 UTC 2014
 c/src/lib/libbsp/sh/gensh1/include/bsp.h |   12 ++----------
 1 files changed, 2 insertions(+), 10 deletions(-)
diff --git a/c/src/lib/libbsp/sh/gensh1/include/bsp.h b/c/src/lib/libbsp/sh/gensh1/include/bsp.h
index f186e09..c80787f 100644
--- a/c/src/lib/libbsp/sh/gensh1/include/bsp.h
+++ b/c/src/lib/libbsp/sh/gensh1/include/bsp.h
@@ -50,19 +50,11 @@ extern "C" {
 /* Constants */
- *  Simple spin delay in microsecond units for device drivers.
- *  This is very dependent on the clock speed of the target.
-#define rtems_bsp_delay( microseconds ) CPU_delay(microseconds)
-#define sh_delay( microseconds ) CPU_delay(microseconds)
  * Defined in the linker script 'linkcmds'
-extern void *CPU_Interrupt_stack_low ;
-extern void *CPU_Interrupt_stack_high ;
+extern void *CPU_Interrupt_stack_low;
+extern void *CPU_Interrupt_stack_high;
  *  Device Driver Table Entries
1.7.1
