[PATCH 10/10] relnotes/intro.texi: Change rtems.com to rtems.org and update
Thu Mar 20 18:31:22 UTC 2014
 doc/relnotes/intro.texi |   40 ++++++++++++----------------------------
 1 files changed, 12 insertions(+), 28 deletions(-)
diff --git a/doc/relnotes/intro.texi b/doc/relnotes/intro.texi
index 9917d3e..b7faa9b 100644
--- a/doc/relnotes/intro.texi
+++ b/doc/relnotes/intro.texi
@@ -1,5 +1,5 @@
 @c
- at c  COPYRIGHT (c) 1989-2011.
+ at c  COPYRIGHT (c) 1989-2014.
 @c  On-Line Applications Research Corporation (OAR).
 @c  All rights reserved.
@@ -35,17 +35,9 @@ This RTEMS release package contains the following general components:
 @end itemize
-There is a mailing list dedicated to RTEMS.  This is
-a Majordomo style mailing list and may be subscribed to
-by sending a message to rtems-list-request@@rtems.com with
-the following line as the body:
- at example
-subscribe rtems_user@@your_email_goes_here.com
- at end example
-Please replace rtems_user@@your_email_goes_here.com with your
-email address.
+There are multiple mailing lists dedicated to RTEMS.
+Each list may be subscribed to, archives view, etc. by visiting
+ at uref{http://www.rtems.org/mailman/listinfo}.
 @node Introduction Supporting Tools, GNU Development Tools, Introduction, Introduction
 @section Supporting Tools
@@ -141,28 +133,20 @@ very complete and is compliant with as many standards as
 possible.  Because of this, it may be the only choice for many
 developers.
-There is currently no RTEMS support for the GNU C Library.
-The primary ftp site for this library is
-prep.ai.mit.edu (18.71.0.38).
- at node Cygnus NEWLIB C Library, Introduction Documentation, GNU C Library, Introduction Supporting Tools
- at subsection Cygnus NEWLIB C Library
-The Cygnus NEWLIB C Library was specifically designed
-for real-time embedded systems.  It is a small, reasonably
-documented Library with support for reentrancy.  This library is
-a collection of freely distributable and public domain source
-code and is freely distributable with as few restrictions as
-possible placed on the end user.
+ at node NEWLIB C Library, Introduction Documentation, GNU C Library, Introduction Supporting Tools
+ at subsection NEWLIB C Library
-The primary ftp site for this library is ftp.cygnus.com (205.180.83.42).
+The NEWLIB C Library was specifically designed for real-time embedded
+systems.  It is a small, reasonably documented Library with support
+for reentrancy.  This library is a collection of freely distributable
+and public domain source code and is freely distributable with as few
+restrictions as possible placed on the end user.
 @node Introduction Documentation, Installation Procedure, Cygnus NEWLIB C Library, Introduction
 @section Documentation
 The RTEMS Documentation Set is provided online at
- at uref{http://www.rtems.com/onlinedocs.html}
+ at uref{http://www.rtems.org/onlinedocs.html}
 as reference information for all levels of RTEMS users.
 The RTEMS documentation set is available in HTML, PostScript, PDF, and DVI.
1.7.1
