[PATCH 08/10] relnotes/status.texi: rtems.com to rtems.org and update to Bugzilla
Thu Mar 20 18:31:20 UTC 2014
 doc/relnotes/status.texi |    6 +++---
 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/doc/relnotes/status.texi b/doc/relnotes/status.texi
index 2705e28..109eebc 100644
--- a/doc/relnotes/status.texi
+++ b/doc/relnotes/status.texi
@@ -1,5 +1,5 @@
 @c
- at c  COPYRIGHT (c) 1989-2011.
+ at c  COPYRIGHT (c) 1989-2014.
 @c  On-Line Applications Research Corporation (OAR).
 @c  All rights reserved.
@@ -147,6 +147,6 @@ development environment.
 @node RTEMS Problem Reporting, RTEMS PROBLEM REPORT, Development Environment Problems, Development Environment Status Known Problems
 @subsection RTEMS Problem Reporting
-The RTEMS Project uses the GNATS Problem Reporting and Tracking System.
+The RTEMS Project uses the Bugzilla Problem Reporting and Tracking System.
 Instructions for reporting a problem are located at
- at uref{http://www.rtems.com/bugs.html}.
+ at uref{http://rtems.org/wiki/index.php/RTEMSBugReporting}.
1.7.1
