[PATCH 01/10] started/buildrt.t: Change CVS to Git
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Mar 20 18:31:13 UTC 2014
doc/started/buildrt.t | 18 ++++++------------
1 files changed, 6 insertions(+), 12 deletions(-)
diff --git a/doc/started/buildrt.t b/doc/started/buildrt.t
index c3bc859..c242296 100644
--- a/doc/started/buildrt.t
+++ b/doc/started/buildrt.t
@@ -1,5 +1,5 @@
@c
- at c COPYRIGHT (c) 1988-2010.
+ at c COPYRIGHT (c) 1988-2014.
@c On-Line Applications Research Corporation (OAR).
@c All rights reserved.
@@ -41,19 +41,13 @@ tar xjf ../archive/rtems- at value{RTEMSAPI}.<VERSION>.tar.bz2
This creates the directory rtems- at value{RTEMSAPI}.<VERSION>
- at section Obtaining the RTEMS Source from CVS
+ at section Obtaining the RTEMS Source from Git
Instead of downloading release tarballs you may choose to check out the current
-RTEMS source from CVS. For details on accessing RTEMS CVS repository consult
- at uref{http://www.rtems.org/wiki/index.php/RTEMS_CVS_Repository, http://www.rtems.org/wiki/index.php/RTEMS_CVS_Repository}. The steps required
-to obtain the source code from CVS are usually like the following:
- at example
-$ cvs -d :pserver:anoncvs@@www.rtems.com:/usr1/CVS login
-Logging in to :pserver:anoncvs@@www.rtems.com:2401/usr1/CVS
-CVS password:
-$ cvs -d :pserver:anoncvs@@www.rtems.com:/usr1/CVS -z 9 co -P rtems # for the main RTEMS source
-$ cvs -d :pserver:anoncvs@@www.rtems.com:/usr1/CVS -z 9 co -P examples-v2 # for examples
- at end example
+RTEMS source from the project's source code repository. For details on
+accessing the RTEMS source repository consult:
+ at uref{http://wiki.rtems.org/wiki/index.php/RTEMS_GIT_Repository, http://wiki.rtems.org/wiki/index.php/RTEMS_GIT_Repository}.
@section Add <INSTALL_POINT>/bin to Executable PATH
1.7.1
