Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Fri Mar 21 08:30:30 UTC 2014
Hi Youren,
I just looked at a fresh RTEMS clone. I thought the patch eliminating
sensitive instructions from the x86 paravirt target was merged, but it
looks like it wasn't.
I am working on an up to date patch. The old one, doesn't work anymore.
Cheers,
Philipp
On 03/21/2014 03:27 AM, Youren Shen wrote:
> Hi,Gedare:
> Thank you for your suggestion.
> In the function bootcart() in the file
> c/src/lib/libbsp/shared/bootcard.c, there is a
> function rtems_interrupt_disable which will be compiled to be
> instruction "cli" in x86 platform. And the cli is also the reason why I
> failed to startup POK partitions [1].
> Now I consider there are two ways to solve the problem.One I called
> functional solution, The other I called instruction solution. That is
> say , we replace some functions with sensitive instructions or replace
> every instructions. The first approach seems to be easy to
> implementation, however maybe not easy to transplant to other platform.
> I'm more familiar with the second approach, but to implement the whole
> project will spent more time. And once we finish this project, we can
> easily implement paravirtualization to other platform. And if design
> properly, will also easily to transplant RTEMS to other hypervisor.
> Or we have to mix this two solutions, This needs more discussion and
> should be thoughtful and deliberate.
> By the way, I'm going to post a blog about the POK initiation and
> interrupt system this weekend.
> [1].
> http://listengine.tuxfamily.org/lists.tuxfamily.org/pok/2014/03/msg00003.html
> Best Regards.
> Youren Shen.
> On Thu, Mar 20, 2014 at 10:04 PM, Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
>     Youren Shen,
>     It looks like the problem you are having is that RTEMS "hello world"
>     executes a sensitive instruction? There should not be any such
>     instruction when you use the --enable-paravirt option, so you need to
>     determine where this instruction gets executed. The best way to do
>     this is to hook gdb up to an executing qemu. You can start qemu with
>     some -S option to prevent the boot sequence from starting to give you
>     some time to load gdb and connect it to qemu's gdbserver socket. once
>     you have done this, you should be able to set some breakpoints in the
>     pok/hello application to step through the program, or you might be
>     able to catch exceptions before they get raised to pok. The other
>     option should be that inside pok there should be some information
>     about the source of the exception that you might investigate.
>     Please keep us informed about your progress on this problem,
>     Thanks,
>     Gedare
>     On Thu, Mar 20, 2014 at 9:16 AM, Youren Shen <shenyouren at gmail.com
>     <mailto:shenyouren at gmail.com>> wrote:
>     > Hi,Gedare
>     > Maybe it's because my qemu version is low or POK has change the
>     kernel, I
>     > can't run the RTEMS Hello world on my computer anymore.
>     > The problem has spent me a few days to find. More details see this
>     mails.
>     > [1].
>     http://listengine.tuxfamily.org/lists.tuxfamily.org/pok/2014/03/msg00000.html
>     > Best Regards.
>     > Youren Shen.
>     > On Thu, Mar 20, 2014 at 8:03 PM, Philipp Eppelt
>     > <philipp.eppelt at mailbox.tu-dresden.de
>     <mailto:philipp.eppelt at mailbox.tu-dresden.de>> wrote:
>     >> On 03/16/2014 01:01 PM, Youren Shen wrote:
>     >> > Hi, every one:
>     >> > I have write a blog about how to build the RTEMS on POK.
>     However, the
>     >> > RTEMS can't run on POK now. Here is my blog[1].
>     >> > [1].
>     http://huaiyusched.github.io/rtems/2014/03/15/how-to-run-rtems-on-pok/
>     >> > Best Regards.
>     >> > Youren Shen.
>     >> Hi Youren,
>     >> great!
>     >> A screenshot of RTEMS HelloWorld sample running on POK would be even
>     >> better :).
>     >> Cheers,
>     >> Philipp
>     > Best Regards.
>     > Youren Shen.
> Best Regards.
> Youren Shen.
