[PATCH 1/3] posix: Prevent pthread_setspecific from returning EAGAIN.
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Mar 21 09:26:27 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
The man-page for pthread_setspecific does not define the EAGAIN return value.
Further without this patch it was not possible to set keys that have been
already set a new value.
cpukit/posix/src/keysetspecific.c | 59 +++++++++++++++++++++++----------------
1 file changed, 35 insertions(+), 24 deletions(-)
diff --git a/cpukit/posix/src/keysetspecific.c b/cpukit/posix/src/keysetspecific.c
index c6e2d30..9afd35c 100644
--- a/cpukit/posix/src/keysetspecific.c
+++ b/cpukit/posix/src/keysetspecific.c
@@ -37,37 +37,48 @@ int pthread_setspecific(
POSIX_Keys_Control *the_key;
Objects_Locations location;
POSIX_Keys_Key_value_pair *value_pair_ptr;
+ RBTree_Node *p;
+ POSIX_Keys_Key_value_pair search_node;
the_key = _POSIX_Keys_Get( key, &location );
switch ( location ) {
case OBJECTS_LOCAL:
- value_pair_ptr = _POSIX_Keys_Key_value_pair_allocate();
- if ( !value_pair_ptr ) {
- _Objects_Put( &the_key->Object );
- return ENOMEM;
- value_pair_ptr->key = key;
- value_pair_ptr->thread_id = _Thread_Executing->Object.id;
- value_pair_ptr->value = value;
- if ( _RBTree_Insert( &_POSIX_Keys_Key_value_lookup_tree,
- &(value_pair_ptr->Key_value_lookup_node) ) ) {
- _Freechain_Put( (Freechain_Control *)&_POSIX_Keys_Keypool,
- (void *) value_pair_ptr );
- return EAGAIN;
+ search_node.key = key;
+ search_node.thread_id = _Thread_Executing->Object.id;
+ p = _RBTree_Find( &_POSIX_Keys_Key_value_lookup_tree,
+ &search_node.Key_value_lookup_node );
+ if ( p ) {
+ value_pair_ptr = _RBTree_Container_of( p,
+ POSIX_Keys_Key_value_pair,
+ Key_value_lookup_node );
+ value_pair_ptr->value = value;
+ } else {
+ value_pair_ptr = _POSIX_Keys_Key_value_pair_allocate();
+ if ( !value_pair_ptr ) {
+ _Objects_Put( &the_key->Object );
+ return ENOMEM;
+ value_pair_ptr->key = key;
+ value_pair_ptr->thread_id = _Thread_Executing->Object.id;
+ /* The insert can only go wrong if the same node is already in a unique
+ * tree. This has been already checked with the _RBTree_Find() */
+ (void) _RBTree_Insert( &_POSIX_Keys_Key_value_lookup_tree,
+ &(value_pair_ptr->Key_value_lookup_node) );
+ /** append rb_node to the thread API extension's chain */
+ _Chain_Append_unprotected(
+ &_Thread_Executing->Key_Chain,
+ &value_pair_ptr->Key_values_per_thread_node
- /** append rb_node to the thread API extension's chain */
- _Chain_Append_unprotected(
- &_Thread_Executing->Key_Chain,
- &value_pair_ptr->Key_values_per_thread_node
return 0;
1.8.4.5
